- 05-Layer 3 - IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-IP forwarding basics configuration
- 06-Fast forwarding configuration
- 07-Adjacency table configuration
- 08-IRDP configuration
- 09-IP performance optimization configuration
- 10-UDP Helper configuration
- 11-IPv6 basics configuration
- 12-DHCPv6 configuration
- 13-IPv6 fast forwarding configuration
- 14-Tunneling configuration
- 15-GRE configuration
- 16-HTTP redirect configuration
13-IPv6 fast forwarding configuration | 45.77 KB |
Configuring IPv6 fast forwarding
Configuring the aging time for IPv6 fast forwarding entries
Configuring IPv6 fast forwarding load sharing
Displaying and maintaining IPv6 fast forwarding
Overview
Fast forwarding reduces route lookup time and improves packet forwarding efficiency by using a high-speed cache and data-flow-based technology. It identifies a data flow by using the following fields:
· Source IPv6 address.
· Destination IPv6 address.
· Source port number.
· Destination port number.
· Protocol number.
After a flow's first packet is forwarded through the routing table, fast forwarding creates an entry and uses the entry to forward subsequent packets of the flow.
The IPv6 fast forwarding table uses an aging timer for each forwarding entry. If an entry is not updated before the timer expires, the device deletes the entry. If an entry has a hit within the aging time, the aging timer restarts.
To configure the aging time for IPv6 fast forwarding entries:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Set the aging time for IPv6 fast forwarding entries. |
ipv6 fast-forwarding aging-time aging-time |
By default, the aging time is 30 seconds. |
IPv6 fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the five-tuple (source IP, source port, destination IP, destination port, and protocol).
If IPv6 fast forwarding load sharing is disabled, the device identifies a data flow by the five-tuple and the input interface. No load sharing is implemented.
To configure IPv6 fast forwarding load sharing:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable IPv6 fast forwarding load sharing. |
Ipv6 fast-forwarding load-sharing |
By default, IPv6 fast forwarding load sharing is enabled. |
Task |
Command |
(In standalone mode.) Display IPv6 fast forwarding entries. |
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ] |
(In IRF mode.) Display IPv6 fast forwarding entries. |
display ipv6 fast-forwarding cache [ ipv6-address ] [ chassis chassis-number slot slot-number ] |
Display the aging time of the IPv6 fast forwarding entries. |
display ipv6 fast-forwarding aging-time |
(In standalone mode.) Clear IPv6 fast forwarding table information. |
reset ipv6 fast-forwarding cache [ slot slot-number ] |
(In IRF mode.) Clear the IPv6 fast forwarding table. |
reset ipv6 fast-forwarding cache [ chassis chassis-number slot slot-number ] |
