- 12-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-NETCONF commands
- 08-EAA commands
- 09-Process monitoring and maintenance commands
- 10-Sampler commands
- 11-Mirroring commands
- 12-sFlow commands
- 13-Information center commands
- 14-GOLD commands
- 15-Packet capture commands
- 16-VCF fabric commands
- 17-CWMP commands
- 18-SmartMC commands
02-NQA commands | 298.48 KB |
operation (FTP operation view)
operation (HTTP/HTTPS operation view)
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
source interface (ICMP echo/UDP tracert operation view)
NQA commands
NQA client commands
advantage-factor
Use advantage-factor to set the advantage factor to be used for calculating Mean Opinion Scores (MOS) and Calculated Planning Impairment Factor (ICPIF) values.
Use undo advantage-factor to restore the default.
advantage-factor factor
The advantage factor is 0.
Voice operation view
factor: Specifies the advantage factor in the range of 0 to 20.
The evaluation of voice quality depends on users' tolerance for voice quality. For users with higher tolerance for voice quality, use the advantage-factor command to set an advantage factor. When the system calculates the ICPIF value, it subtracts the advantage factor to modify ICPIF and MOS values for voice quality evaluation.
# Set the advantage factor to 10 for the voice operation.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] advantage-factor 10
codec-type
Use codec-type to configure the codec type for the voice operation.
Use undo codec-type to restore the default.
codec-type { g711a | g711u | g729a }
undo codec-type
The codec type for the voice operation is G.711 A-law.
g711a: Specifies G.711 A-law codec type.
g711u: Specifies G.711 µ-law codec type
g729a: Specifies G.729 A-law codec type.
# Set the codec type to g729a for the voice operation.
[Sysname-nqa-admin-test-voice] codec-type g729a
community read
Use community read to specify the community name for the SNMP operation.
Use undo community read to restore the default.
community read { cipher | simple } community-name
undo community read
The SNMP operation uses the community name public.
SNMP operation view
cipher: Specifies a community name in encrypted form.
simple: Specifies a community name in plaintext form. For security purposes, the community name specified in plaintext form will be stored in encrypted form.
community-name: Specifies the community name. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 33 to 73 characters.
You must specify the community name for the SNMP operation when both of the following conditions exist:
· The SNMP operation uses the SNMPv1 or SNMPv2c agent.
· The SNMPv1 or SNMPv2c agent is configured with a read-only or read-write community name.
The specified community name must be the same as the community name configured on the SNMP agent.
The community name configuration is not required if the SNMP operation uses the SNMPv3 agent.
For more information about SNMP, see "Configuring SNMP."
# Specify readaccess as the community name for the SNMP operation.
[Sysname-nqa-admin-test] type snmp
[Sysname-nqa-admin-test-snmp] community read simple readaccess
data-fill
Use data-fill to configure the payload fill string for probe packets.
Use undo data-fill to restore the default.
data-fill string
undo data-fill
The default payload fill string is the hexadecimal string 00010203040506070809.
ICMP/UDP echo operation view
Path jitter/UDP jitter/voice operation view
ICMP/TCP/UDP template view
string: Specifies a case-sensitive string of 1 to 200 characters.
If the payload length is smaller than the string length, only the first part of the string is filled. For example, if you configure the string as abcd and set the payload size to 3 bytes, abc is filled.
If the payload length is greater than the string length, the system fills the payload with the string cyclically until the payload is full. For example, if you configure the string as abcd and the payload size as 6 bytes, abcdab is filled.
How the string is filled depends on the operation type.
· For the ICMP echo operation, the string fills the whole payload of an ICMP echo request.
· For the UDP echo operation, the first five bytes of the payload of a UDP packet are for special purpose. The string fills the remaining part of payload.
· For the UDP jitter operation, the first 68 bytes of the payload of a UDP packet are for special purpose. The string fills the remaining part of the payload.
· For the voice operation, the first 16 bytes of the payload of a UDP packet are for special purpose. The string fills the remaining part of the payload.
· For the path jitter operation, the first four bytes of the payload of an ICMP echo request are for special purpose. The string fills the remaining part of payload.
# Specify abcd as the payload fill string for ICMP echo requests.
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] data-fill abcd
# In TCP template view, specify abcd as the payload fill string for probe packets.
[Sysname] nqa template tcp tcptplt
[Sysname-nqatplt-tcp-tcptplt] data-fill abcd
data-size
Use data-size to set the payload size for each probe packet.
Use undo data-size to restore the default.
data-size size
undo data-size
The default payload size of a probe packet for different operations is described in Table 1.
Table 1 Default payload size of a probe packet
Operation type |
Codec type |
Default size (bytes) |
ICMP echo |
N/A |
100 |
UDP echo |
N/A |
100 |
UDP jitter |
N/A |
100 |
UDP tracert |
N/A |
100 |
Path jitter |
N/A |
100 |
Voice |
G.711 A-law |
172 |
Voice |
G.711 µ-law |
172 |
Voice |
G.729 A-law |
32 |
ICMP/UDP template view
size: Specifies the payload size. Available value ranges include:
· 20 to 65507 bytes for the ICMP echo, UDP echo, or UDP tracert operation.
· 68 to 65507 bytes for the UDP jitter or path jitter operation.
· 16 to 65507 bytes for the voice operation.
In ICMP echo and path jitter operations, the command sets the payload size for each ICMP echo request.
In UDP echo, UDP jitter, UDP tracert, and voice operations, the command sets the payload size for each UDP packet.
# Set the payload size to 80 bytes for each ICMP echo request.
[Sysname-nqa-admin-test-icmp-echo] data-size 80
# In ICMP template view, set the payload size to 80 bytes for each probe packet.
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] data-size 80
description
Use description to configure a description for an NQA operation, such as the operation type or purpose.
No description is configured for an NQA operation.
Any NQA operation view
Any NQA template view
text: Specifies a description, a case-sensitive string of 1 to 200 characters.
# Configure the description as icmp-probe for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] description icmp-probe
# In ICMP template view, configure the description as icmp-probe for the NQA operation.
[Sysname-nqatplt-icmp-icmptplt] description icmp-probe
destination host
Use destination host to configure the destination host name for the operation.
Use undo destination host to restore the default.
destination host host-name
No destination host name is configured for the operation.
host-name: Specifies the destination host name, a case-sensitive string of 1 to 254 characters. The host name can contain letters, digits, hyphens (-), underscores (_), and dots (.), but consecutive dots (.) are not allowed. If the host name is a series of dot-separated labels, each label can contain a maximum of 63 characters.
# Specify www.test.com as the destination host name for the UDP tracert operation.
[Sysname-nqa-admin-test] type udp-tracert
[Sysname-nqa-admin-test-udp-tracert] destination host www.test.com
destination ip
Use destination ip to configure the destination IPv4 address for the operation.
Use undo destination ip to restore the default.
destination ip ip-address
undo destination ip
No destination IPv4 address is configured for an operation.
ICMP echo/TCP/UDP echo operation view
DHCP/DLSw/DNS/SNMP operation view
ICMP jitter/path jitter/UDP jitter/voice operation view
DNS/ICMP/RADIUS/SSL/TCP/TCP half open/UDP template view
ip-address: Specifies the destination IPv4 address for the operation.
# Specify 10.1.1.1 as the destination IPv4 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
# In ICMP template view, specify 10.1.1.1 as the destination IPv4 address for the ICMP echo operation.
[Sysname-nqatplt-icmp-icmptplt] destination ip 10.1.1.1
destination ipv6
Use destination ipv6 to configure the destination IPv6 address for the operation.
Use undo destination ipv6 to restore the default.
destination ipv6 ipv6-address
No destination IPv6 address is configured for an operation.
ICMP echo operation view
ipv6-address: Specifies the destination IPv6 address for the operation. IPv6 link-local addresses are not supported.
# Specify 1::1 as the destination IPv6 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] destination ipv6 1::1
# In ICMP template view, specify 1::1 as the destination IPv6 address for the operation.
[Sysname-nqatplt-icmp-icmptplt] destination ipv6 1::1
destination port
Use destination port to configure the destination port number for the operation.
Use undo destination port to restore the default.
destination port port-number
The destination port number is 33434 for the UDP tracert operation and 161 for the SNMP operation.
The destination port numbers for the operations that use the following NQA templates are:
· 53 for the DNS template.
· 1812 for the RADIUS template.
No destination port number is configured for other types of operations.
DNS/RADIUS/SSL/TCP/UDP template view
port-number: Specifies the destination port number for the operation, in the range of 1 to 65535.
# Set the destination port number to 9000 for the UDP echo operation.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] destination port 9000
# In TCP template view, set the destination port number to 9000 for the NQA operation.
[Sysname-nqatplt-tcp-tcptplt] destination port 9000
display nqa history
Use display nqa history to display the history records of NQA operations.
display nqa history [ admin-name operation-tag ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays the history records of all NQA operations.
The display nqa history command does not display the results or statistics of the following operations:
· ICMP jitter.
· Path jitter.
· UDP jitter.
· Voice.
To view the results or statistics of the ICMP jitter, path jitter, UDP jitter, and voice operations, use the display nqa result or display nqa statistics command.
# Display the history records of the UDP tracert operation with administrator name administrator and operation tag tracert.
<Sysname> display nqa history administrator tracert
NQA entry (admin administrator, tag tracert) history records:
Index TTL Response Hop IP Status Time
1 2 328 4.1.1.1 Succeeded 2013-09-09 14:46:06.2
1 2 328 4.1.1.1 Succeeded 2013-09-09 14:46:05.2
1 2 328 4.1.1.1 Succeeded 2013-09-09 14:46:04.2
1 1 328 3.1.1.2 Succeeded 2013-09-09 14:46:03.2
1 1 328 3.1.1.1 Succeeded 2013-09-09 14:46:02.2
1 1 328 3.1.1.1 Succeeded 2013-09-09 14:46:01.2
# Display the history records of the NQA operation with administrator name administrator and operation tag test.
<Sysname> display nqa history administrator test
NQA entry (admin administrator, tag test) history records:
Index Response Status Time
10 329 Succeeded 2011-04-29 20:54:26.5
9 344 Succeeded 2011-04-29 20:54:26.2
8 328 Succeeded 2011-04-29 20:54:25.8
7 328 Succeeded 2011-04-29 20:54:25.5
6 328 Succeeded 2011-04-29 20:54:25.1
5 328 Succeeded 2011-04-29 20:54:24.8
4 328 Succeeded 2011-04-29 20:54:24.5
3 328 Succeeded 2011-04-29 20:54:24.1
2 328 Succeeded 2011-04-29 20:54:23.8
1 328 Succeeded 2011-04-29 20:54:23.4
Index |
History record ID. The history records in one UDP tracert operation have the same ID. |
TTL |
If the routing table bypass feature is not enabled in the operation, this field displays the TTL value in the probe packet. If the routing table bypass feature is enabled, this field displays the TTL value configured by using the init-ttl command. However, the actual TTL value in the probe packet is fixed at 1. |
Response |
Round-trip time if the operation succeeds, timeout time upon timeout, or 0 if the operation cannot be completed, in milliseconds. |
Hop IP |
IP address of the node that sent the reply packet. |
Status |
Status of the operation result: · Succeeded. · Unknown error. · Internal error. · Timeout. |
Time |
Time when the operation was completed. |
display nqa reaction counters
Use display nqa reaction counters to display the current monitoring results of reaction entries.
display nqa reaction counters [ admin-name operation-tag [ item-number ] ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays the current monitoring results of reaction entries for all NQA operations.
item-number: Specifies a reaction entry by its ID in the range of 1 to 10. If you do not specify a reaction entry, the command displays the results of all reaction entries.
The result fields display hyphens (-) in one of the following conditions:
· The threshold type is the average value.
· The monitored performance metric is ICPIF or MOS of the voice operation.
The monitoring results of an operation are accumulated, and are not cleared after the operation completes.
# Display the monitoring results of all reaction entries of the ICMP echo operation with administrator name admin and operation tag test.
<Sysname> display nqa reaction counters admin test
NQA entry (admin admin, tag test) reaction counters:
Index Checked Element Threshold Type Checked Num Over-threshold Num
1 probe-duration accumulate 12 4
2 probe-duration average - -
3 probe-duration consecutive 160 56
4 probe-fail accumulate 12 0
5 probe-fail consecutive 162 2
Index |
ID of a reaction entry. |
Checked Element |
Monitored performance metric. The available performance metrics vary by NQA operation type. For more information, see Table 4 and Table 5. |
Threshold Type |
Threshold type. |
Checked Num |
Number of targets that have been monitored for data collection. |
Over-threshold Num |
Number of threshold violations. |
Monitored performance metric |
Threshold type |
Collect data in |
Checked Num |
probe-duration |
accumulate |
Probes after the operation starts. |
Number of completed probes. |
Number of probes with duration exceeding the threshold. |
average |
N/A |
N/A |
N/A |
consecutive |
probe-fail |
accumulate |
Number of probe failures. |
consecutive |
Table 5 Monitored performance metrics for ICMP jitter/UDP jitter/voice operations
Threshold type |
Collect data in |
Checked Num |
RTT |
accumulate |
Packets sent after the operation starts. |
Number of sent packets. |
Number of packets with round-trip time exceeding threshold. |
average |
N/A |
N/A |
N/A |
jitter-DS/jitter-SD |
accumulate |
Number of packets with the one-way jitter exceeding the threshold. |
average |
N/A |
N/A |
N/A |
OWD-DS/OWD-SD |
N/A |
Number of packets with the one-way delay exceeding the threshold. |
packet-loss |
accumulate |
Total packet loss. |
ICPIF/MOS (available only for the voice operation) |
N/A |
N/A |
N/A |
N/A |
display nqa result
Use display nqa result to display the most recent result of an NQA operation.
display nqa result [ admin-name operation-tag ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays the most recent results of all NQA operations.
# Display the most recent result of the TCP operation with administrator name admin and operation tag test.
<Sysname> display nqa result admin test
NQA entry (admin admin, tag test) test results:
Send operation times: 1 Receive response times: 1
Min/Max/Average round trip time: 35/35/35
Square-Sum of round trip time: 1225
Last succeeded probe time: 2011-05-29 10:50:33.2
Extended results:
Packet loss ratio: 0%
Failures due to timeout: 0
Failures due to disconnect: 0
Failures due to no connection: 0
Failures due to internal error: 0
Failures due to other errors: 0
# Display the most recent result of the ICMP jitter operation with administrator name admin and operation tag test.
Send operation times: 10 Receive response times: 10
Min/Max/Average round trip time: 1/2/1
Square-Sum of round trip time: 13
Last packet received time: 2015-03-09 17:40:29.8
Extended results:
Packets out of sequence: 0
Packets arrived late: 0
ICMP-jitter results:
RTT number: 10
Min positive SD: 0 Min positive DS: 0
Max positive SD: 0 Max positive DS: 0
Positive SD number: 0 Positive DS number: 0
Positive SD sum: 0 Positive DS sum: 0
Positive SD average: 0 Positive DS average: 0
Positive SD square-sum: 0 Positive DS square-sum: 0
Min negative SD: 1 Min negative DS: 2
Max negative SD: 1 Max negative DS: 2
Negative SD number: 1 Negative DS number: 1
Negative SD sum: 1 Negative DS sum: 2
Negative SD average: 1 Negative DS average: 2
Negative SD square-sum: 1 Negative DS square-sum: 4
One way results:
Max SD delay: 1 Max DS delay: 2
Min SD delay: 1 Min DS delay: 2
Number of SD delay: 1 Number of DS delay: 1
Sum of SD delay: 1 Sum of DS delay: 2
Square-Sum of SD delay: 1 Square-Sum of DS delay: 4
Lost packets for unknown reason: 0
# Display the most recent result of the UDP jitter operation with administrator name admin and operation tag test.
Min/Max/Average round trip time: 15/46/26
Square-Sum of round trip time: 8103
Last packet received time: 2011-05-29 10:56:38.7
Extended results:
UDP-jitter results:
RTT number: 10
Min positive SD: 8 Min positive DS: 8
Max positive SD: 18 Max positive DS: 8
Positive SD number: 5 Positive DS number: 2
Positive SD sum: 75 Positive DS sum: 32
Positive SD average: 15 Positive DS average: 16
Positive SD square-sum: 1189 Positive DS square-sum: 640
Min negative SD: 8 Min negative DS: 1
Max negative SD: 24 Max negative DS: 30
Negative SD number: 4 Negative DS number: 7
Negative SD sum: 56 Negative DS sum: 99
Negative SD average: 14 Negative DS average: 14
Negative SD square-sum: 946 Negative DS square-sum: 1495
One way results:
Max SD delay: 22 Max DS delay: 23
Min SD delay: 7 Min DS delay: 7
Number of SD delay: 10 Number of DS delay: 10
Sum of SD delay: 125 Sum of DS delay: 132
Square-Sum of SD delay: 1805 Square-Sum of DS delay: 1988
SD lost packets: 0 DS lost packets: 0
# Display the most recent result of the voice operation with administrator name admin and operation tag test.
Send operation times: 1000 Receive response times: 0
Min/Max/Average round trip time: 0/0/0
Square-Sum of round trip time: 0
Last packet received time: 0-00-00 00:00:00.0
Extended results:
Packet loss ratio: 100%
Failures due to timeout: 1000
Voice results:
RTT number: 0
Min negative SD: 0 Min negative DS: 0
Max negative SD: 0 Max negative DS: 0
Negative SD number: 0 Negative DS number: 0
Negative SD sum: 0 Negative DS sum: 0
Negative SD average: 0 Negative DS average: 0
Negative SD square-sum: 0 Negative DS square-sum: 0
One way results:
Max SD delay: 0 Max DS delay: 0
Min SD delay: 0 Min DS delay: 0
Number of SD delay: 0 Number of DS delay: 0
Sum of SD delay: 0 Sum of DS delay: 0
Square-Sum of SD delay: 0 Square-Sum of DS delay: 0
Lost packets for unknown reason: 1000
Voice scores:
MOS value: 0.99 ICPIF value: 87
# Display the most recent result of the path jitter operation with administrator name admin and operation tag test.
Hop IP 192.168.40.210
Basic Results:
Min/Max/Average round trip time: 1/1/1
Square-Sum of round trip time: 10
Extended Results:
Path-Jitter Results:
Jitter number: 9
Min/Max/Average jitter: 0/0/0
Positive jitter number: 0
Min/Max/Average positive jitter: 0/0/0
Sum/Square-Sum positive jitter: 0/0
Negative jitter number: 0
Min/Max/Average negative jitter: 0/0/0
Sum/Square-Sum negative jitter: 0/0
Hop IP 192.168.50.209
Basic Results:
Extended Results:
Jitter number: 9
# Display the most recent result of the UDP tracert operation with administrator name admin and operation tag test.
Send operation times: 6 Receive response times: 6
Last succeeded probe time: 2013-09-09 14:23:24.5
Extended results:
UDP-tracert results:
TTL Hop IP Time
1 3.1.1.1 2013-09-09 14:23:24.5
2 4.1.1.1 2013-09-09 14:23:24.5
Table 6 Command output
Data collecting in progress |
The operation is in progress. |
Send operation times |
Number of operations. |
Receive response times |
Number of response packets received. |
Min/Max/Average round trip time |
Minimum/maximum/average round-trip time in milliseconds. |
Square-Sum of round trip time |
Square sum of round-trip time. |
Last succeeded probe time |
Time when the last successful probe was completed. If no probes are successful in an operation, the field displays 0. This field is not available for UDP jitter, path jitter, and voice operations. |
Last packet received time |
Time when the last response packet was received. If no response packets in a probe were received, the field displays 0. This field is available only for UDP jitter and voice operations. |
Packet loss ratio |
Average packet loss ratio. |
Failures due to timeout |
Number of timeout occurrences in an operation. |
Failures due to disconnect |
Number of disconnections by the peer. |
Failures due to no connection |
Number of failures to connect with the peer. |
Failures due to internal error |
Number of failures due to internal errors. |
Failures due to other errors |
Failures due to other errors. |
Packets out of sequence |
Number of failures due to out-of-sequence packets. |
ICMP-jitter results |
ICMP jitter operation results. This field is available only for the ICMP jitter operation. |
Packets arrived late |
Number of response packets received after a probe times out. |
UDP-jitter results |
UDP jitter operation results. This field is available only for the UDP jitter operation. |
Voice results |
Voice operation results. This field is available only for the voice operation. |
RTT number |
Min positive SD |
Minimum positive jitter from source to destination. |
Min positive DS |
Minimum positive jitter from destination to source. |
Max positive SD |
Maximum positive jitter from source to destination. |
Max positive DS |
Maximum positive jitter from destination to source. |
Positive SD number |
Number of positive jitters from source to destination. |
Positive DS number |
Number of positive jitters from destination to source. |
Positive SD sum |
Sum of positive jitters from source to destination. |
Positive DS sum |
Sum of positive jitters from destination to source. |
Positive SD average |
Average positive jitters from source to destination. |
Positive DS average |
Average positive jitters from destination to source. |
Positive SD square-sum |
Square sum of positive jitters from source to destination. |
Positive DS square-sum |
Square sum of positive jitters from destination to source. |
Min negative SD |
Minimum absolute value among negative jitters from source to destination. |
Min negative DS |
Minimum absolute value among negative jitters from destination to source. |
Max negative SD |
Maximum absolute value among negative jitters from source to destination. |
Max negative DS |
Maximum absolute value among negative jitters from destination to source. |
Negative SD number |
Number of negative jitters from source to destination. |
Negative DS number |
Number of negative jitters from destination to source. |
Negative SD sum |
Sum of absolute values of negative jitters from source to destination. |
Negative DS sum |
Sum of absolute values of negative jitters from destination to source. |
Negative SD average |
Average absolute value of negative jitters from source to destination. |
Negative DS average |
Average absolute value of negative jitters from destination to source. |
Negative SD square-sum |
Square sum of negative jitters from source to destination. |
Negative DS square-sum |
Square sum of negative jitters from destination to source. |
One way results |
Unidirectional delay. This field is available only for the ICMP jitter, UDP jitter, and voice operations. |
Max SD delay |
Maximum delay from source to destination. |
Max DS delay |
Maximum delay from destination to source. |
Min SD delay |
Minimum delay from source to destination. |
Min DS delay |
Minimum delay from destination to source. |
Number of SD delay |
Number of delays from source to destination. |
Number of DS delay |
Number of delays from destination to source. |
Sum of SD delay |
Sum of delays from source to destination. |
Sum of DS delay |
Sum of delays from destination to source. |
Square-Sum of SD delay |
Square sum of delays from source to destination. |
Square-Sum of DS delay |
Square sum of delays from destination to source. |
SD lost packets |
Number of lost packets from the source to the destination. |
DS lost packets |
Number of lost packets from the destination to the source. |
Lost packets for unknown reason |
Number of lost packets for unknown reasons. |
Voice scores |
Voice parameters. This field is available only for the voice operation. |
MOS value |
MOS value calculated for the voice operation. |
ICPIF value |
ICPIF value calculated for the voice operation. |
Hop IP |
IP address of the hop. This field is available only for the path jitter operation. |
Path-jitter results |
Path jitter operation results. This field is available only for the path jitter operation. |
Jitter number |
Number of jitters. This field is available only for the path jitter operation. |
Min/Max/Average jitter |
Minimum/maximum/average jitter in milliseconds. This field is available only for the path jitter operation. |
Positive jitter number |
Number of positive jitter. This field is available only for the path jitter operation. |
Min/Max/Average positive jitter |
Minimum/maximum/average positive jitter in milliseconds. This field is available only for the path jitter operation. |
Sum/Square-Sum positive jitter |
Sum/square sum of the positive jitter. This field is available only for the path jitter operation. |
Negative jitter number |
Number of negative jitter. This field is available only for the path jitter operation. |
Min/Max/Average negative jitter |
Minimum/maximum/average negative jitter in milliseconds. This field is available only for the path jitter operation. |
Sum/Square-Sum negative jitter |
Sum/square sum of the negative jitter. This field is available only for the path jitter operation. |
TTL |
Hop IP |
Time |
Time when the NQA client received the reply packet. |
Use display nqa statistics to display NQA operation statistics.
display nqa statistics [ admin-name operation-tag ]
admin-name operation-tag: Specifies an NQA operation by its administrator name and operation tag. The admin-name argument represents the name of the administrator who creates the NQA operation. The operation-tag argument represents the operation tag. Each of the arguments is a case-insensitive string of 1 to 32 characters that cannot contain hyphens (-). If you do not specify an NQA operation, the command displays statistics for all NQA operations.
The statistics are generated after the NQA operation completes. If you execute the display nqa statistics command before the operation completes, the statistics are displayed as all 0s.
If a reaction entry is configured, the command displays the monitoring results of the reaction entry in the period specified by the statistics internal command. The result fields display hyphens (-) in one of the following conditions:
· The threshold type is average value.
· The monitored performance metric is ICPIF or MOS for the voice operation.
This command is not available for the UDP tracert operation.
# Display the statistics for the TCP operation with administrator name admin and operation tag test.
<Sysname> display nqa statistics admin test
NQA entry (admin admin, tag test) test statistics:
NO. : 1
Start time: 2007-01-01 09:30:20.0
Life time: 2 seconds
Min/Max/Average round trip time: 13/13/13
Square-Sum of round trip time: 169
Extended results:
# Display the statistics for the ICMP jitter operation with administrator name admin and operation tag test.
NO. : 1
Start time: 2015-03-09 17:42:10.7
Life time: 156 seconds
Send operation times: 1560 Receive response times: 1560
Square-Sum of round trip time: 1563
Extended results:
RTT number: 1560
Min positive SD: 1 Min positive DS: 1
Max positive SD: 1 Max positive DS: 2
Positive SD number: 18 Positive DS number: 46
Positive SD sum: 18 Positive DS sum: 49
Positive SD average: 1 Positive DS average: 1
Positive SD square-sum: 18 Positive DS square-sum: 55
Min negative SD: 1 Min negative DS: 1
Negative SD number: 24 Negative DS number: 57
Negative SD sum: 24 Negative DS sum: 58
Negative SD average: 1 Negative DS average: 1
Negative SD square-sum: 24 Negative DS square-sum: 60
One way results:
Min SD delay: 1 Min DS delay: 1
Number of SD delay: 4 Number of DS delay: 4
Sum of SD delay: 4 Sum of DS delay: 5
Square-Sum of SD delay: 4 Square-Sum of DS delay: 7
Reaction statistics:
1 jitter-DS accumulate 1500 10
2 jitter-SD average - -
3 OWD-DS - 1560 2
4 OWD-SD - 1560 0
5 packet-loss accumulate 0 0
6 RTT accumulate 1560 0
# Display the statistics for the UDP jitter operation with administrator name admin and operation tag test.
NO. : 1
Start time: 2007-01-01 09:33:22.3
Life time: 23 seconds
Send operation times: 100 Receive response times: 100
Min/Max/Average round trip time: 1/11/5
Square-Sum of round trip time: 24360
Extended results:
UDP-jitter results:
RTT number: 550
Max positive SD: 7 Max positive DS: 1
Positive SD number: 220 Positive DS number: 97
Positive SD sum: 283 Positive DS sum: 287
Positive SD average: 1 Positive DS average: 2
Positive SD square-sum: 709 Positive DS square-sum: 1937
Min negative SD: 2 Min negative DS: 1
Max negative SD: 10 Max negative DS: 1
Negative SD number: 81 Negative DS number: 94
Negative SD sum: 556 Negative DS sum: 191
Negative SD average: 6 Negative DS average: 2
Negative SD square-sum: 4292 Negative DS square-sum: 967
One way results:
Max SD delay: 5 Max DS delay: 5
Number of SD delay: 550 Number of DS delay: 550
Sum of SD delay: 1475 Sum of DS delay: 1201
Square-Sum of SD delay: 5407 Square-Sum of DS delay: 3959
1 jitter-DS accumulate 90 25
3 OWD-DS - 100 24
4 OWD-SD - 100 13
6 RTT accumulate 100 52
# Display the statistics for the voice operation with administrator name admin and operation tag test.
NO. : 1
Start time: 2007-01-01 09:33:45.3
Life time: 120 seconds
Min/Max/Average round trip time: 1/12/7
Square-Sum of round trip time: 620
Extended results:
Voice results:
RTT number: 10
Min positive SD: 3 Min positive DS: 1
Max positive SD: 10 Max positive DS: 1
Positive SD number: 3 Positive DS number: 2
Positive SD sum: 18 Positive DS sum: 2
Positive SD average: 6 Positive DS average: 1
Positive SD square-sum: 134 Positive DS square-sum: 2
Min negative SD: 3 Min negative DS: 1
Max negative SD: 9 Max negative DS: 1
Negative SD number: 4 Negative DS number: 2
Negative SD sum: 25 Negative DS sum: 2
Negative SD average: 6 Negative DS average: 1
Negative SD square-sum: 187 Negative DS square-sum: 2
One way results:
Voice scores:
Max MOS value: 4.40 Min MOS value: 4.40
Max ICPIF value: 0 Min ICPIF value: 0
1 ICPIF - - -
2 MOS - - -
# Display the statistics for the path jitter operation with administrator name admin and operation tag test.
NO. : 1
Path 1:
Basic Results:
Extended Results:
Jitter number: 9
Basic Results:
Extended Results:
Jitter number: 9
Table 7 Command output
No. |
Statistics group ID. |
Start time |
Time when the operation started. |
Life time |
Duration of the operation in seconds. |
Number of probe packets sent. |
Packet loss ratio |
Voice results |
RTT number |
Min positive SD |
Min positive DS |
Max positive SD |
Max positive DS |
Positive SD sum |
Positive DS sum |
Min negative SD |
Min negative DS |
Max negative SD |
Max negative DS |
Negative SD sum |
Negative DS sum |
One way results |
Unidirectional delay result. This field is available only for the ICMP jitter, UDP jitter, and voice operations. |
Max SD delay |
Max DS delay |
Min SD delay |
Min DS delay |
Sum of SD delay |
Sum of DS delay |
SD lost packets |
DS lost packets |
Voice scores |
Max MOS value |
Maximum MOS value. |
Min MOS value |
Minimum MOS value. |
Max ICPIF value |
Maximum ICPIF value. |
Min ICPIF value |
Minimum ICPIF value. |
Reaction statistics |
Statistics about the reaction entry in the counting interval. |
Index |
Checked Element |
Monitored element. |
Threshold Type |
Threshold type. |
Checked Num |
Path |
Serial number for the path in the path jitter operation. This field is available only for the path jitter operation. |
Hop IP |
Jitter number |
Number of positive jitters. This field is available only for the path jitter operation. |
Sum/square sum of positive jitters. This field is available only for the path jitter operation. |
Number of negative jitters. This field is available only for the path jitter operation. |
Sum/square sum of negative jitters. This field is available only for the path jitter operation. |
Table 8 Monitored performance metrics for DHCP/DLSw/DNS/FTP/HTTP/ICMP echo/SNMP/TCP/UDP echo operations
Threshold type |
Collect data in |
Checked Num |
probe-duration |
accumulate |
Probes in the counting interval. |
Number of probes of which the duration exceeds the threshold. |
average |
N/A |
N/A |
N/A |
consecutive |
probe-fail |
accumulate |
consecutive |
Table 9 Monitored performance metrics for ICMP jitter/UDP jitter/voice operations
Threshold type |
Collect data in |
Checked Num |
RTT |
accumulate |
Packets sent in the counting interval. |
Number of packets of which the round-trip time exceeds the threshold. |
average |
N/A |
N/A |
N/A |
accumulate |
Number of packets of which the one-way jitter exceeds the threshold. |
average |
N/A |
N/A |
N/A |
OWD-DS/OWD-SD |
N/A |
Number of packets of which the one-way delay exceeds the threshold. |
packet-loss |
accumulate |
Number of packet loss. |
N/A |
N/A |
N/A |
N/A |
statistics interval
expect data
Use expect data to configure the expected data.
Use undo expect data to restore the default.
expect data expression [ offset number ]
undo expect data
No expected data is configured.
HTTP/HTTPS/TCP/UDP template view
expression: Specifies the expected data, a case-sensitive string of 1 to 200 characters.
offset number: Specifies the offset in bytes after which the first match operation starts. The value range for the number argument is 0 to 1000, and the default value is 0. If you do not specify an offset, the match operation starts from the beginning byte of the payload.
Upon receiving a response packet, the NQA client examines the target payload for the expected data.
· If a match is found, the NQA client verifies the NQA destination device as legal.
· If no match is found, the NQA client looks up the entire payload for a match. If no match is found again, the NQA destination device is verified as illegal. The NQA client does not perform the second round if no offset is specified. It verifies the NQA destination as illegal directly if no match is found for the first round.
Expected data check takes place in the following conditions:
· For features that use the HTTP or HTTPS template, the NQA client checks for the expected data if the response contains the Content-Length header.
· For features that use the TCP or UDP template, the NQA client checks for the expected data if the data-fill command is configured.
The first five bytes of the UDP packet payload identify the probe packet type. The start byte of the offset is the sixth byte of the UDP payload.
# In HTTP template view, set the expected data to welcome!.
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] expect data welcome!
expect ip
Use expect ip to specify the expected IPv4 address.
Use undo expect ip to restore the default.
expect ip ip-address
undo expect ip
No expected IPv4 address is specified.
DNS template view
ip-address: Specifies the expected IPv4 address for a DNS echo request.
During a DNS operation, the NQA client compares the expected IPv4 address with the IPv4 address resolved by the DNS server. If they are the same, it considers the DNS server legal.
# In DNS template view, specify 1.1.1.1 as the expected IPv4 address.
[Sysname] nqa template dns dnstplt
[Sysname-nqatplt-dns-dnstplt] expect ip 1.1.1.1
expect ipv6
Use expect ipv6 to specify the expected IPv6 address.
Use undo expect ipv6 to restore the default.
expect ipv6 ipv6-address
undo expect ipv6
No expected IPv6 address is specified.
DNS template view
ip-address: Specifies the expected IPv6 address for a DNS echo request.
During a DNS operation, the NQA client compares the expected IPv6 address with the IPv6 address resolved by the DNS server. If they are the same, it considers the DNS server legal.
# In DNS template view, specify 1::1 as the expected IPv6 address.
[Sysname-nqatplt-dns-dnstplt] expect ipv6 1::1
expect status
Use expect status to configure the expected status code.
Use undo expect status to restore the default.
expect status status-list
undo expect status [ status-list ]
No expected status code is configured.
HTTP template view
HTTPS template view
status-list: Specifies a space-separated list of up to 10 status code items. Each item specifies a status code or a range of status codes in the form of status-num 1 to status-num 2. The value ranges for both the status-num 1 and status-num 2 arguments are 0 to 999. The value for the status-num 2 argument must be equal to or greater than the value for the status-num 1 argument.
The status code of the HTTP or HTTPS packet is a three-digit field in decimal notation, and the code includes the server status information. The first digit defines the class of response.
# In HTTP template view, set the expected status codes to 200, 300, and 400 to 500.
[Sysname-nqatplt-http-httptplt] expect status 200 300 400 to 500
filename
Use filename to specify a file to be transferred between the FTP server and the FTP client.
Use undo filename to restore the default.
filename filename
undo filename
No file is specified.
FTP operation view
FTP template view
filename: Specifies the name of a file, a case-sensitive string of 1 to 200 characters that cannot contain slashes (/).
# Specify config.txt as the file to be transferred between the FTP server and the FTP client for the FTP operation.
[Sysname-nqa-admin-test] type ftp
[Sysname-nqa-admin-test-ftp] filename config.txt
# In FTP template view, specify config.txt as the file to be transferred between the FTP server and the FTP client.
[Sysname] nqa template ftp ftptplt
[Sysname-nqatplt-ftp-ftptplt] filename config.txt
frequency
Use frequency to specify the interval at which the NQA operation repeats.
Use undo frequency to restore the default.
frequency interval
undo frequency
In NQA operation view, the interval between two consecutive voice or path jitter operations is 60000 milliseconds. The interval between two consecutive operations of other types is 0 milliseconds.
In NQA template view, the interval between two consecutive operations is 5000 milliseconds.
DHCP/DLSw/DNS/FTP/HTTP/SNMP operation view
interval: Specifies the interval between two consecutive operations, in the range of 0 to 604800000 milliseconds. An interval of 0 milliseconds configures NQA to perform the operation only once, and not to generate any statistics.
If an operation is not completed when the interval is reached, the next operation does not start.
# Configure the ICMP echo operation to repeat every 1000 milliseconds.
[Sysname-nqa-admin-test-icmp-echo] frequency 1000
# In DNS template view, configure the DNS operation to repeat every 1000 milliseconds.
[Sysname-nqatplt-dns-dnstplt] frequency 1000
history-record enable
Use history-record enable to enable the saving of history records for the NQA operation.
Use undo history-record enable to disable the saving of history records.
The saving of history records is enabled only for the UDP tracert operation.
To display the history records of the NQA operation, use the display nqa history command.
The undo form of the command also removes existing history records of an NQA operation.
# Enable the saving of history records for the NQA operation.
[Sysname-nqa-admin-test-icmp-echo] history-record enable
display nqa history
history-record keep-time
Use history-record keep-time to set the lifetime of history records for an NQA operation.
Use undo history-record keep-time to restore the default.
history-record keep-time keep-time
The history records of an NQA operation are kept for 120 minutes.
keep-time: Specifies how long the history records can be saved. The value range is 1 to 1440 minutes.
When an NQA operation completes, the timer starts. All records are removed when the lifetime is reached.
# Set the lifetime of the history records to 100 minutes for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] history-record keep-time 100
history-record number
Use history-record number to set the maximum number of history records that can be saved for an NQA operation.
Use undo history-record number to restore the default.
history-record number number
A maximum of 50 history records can be saved for an NQA operation.
number: Specifies the maximum number of history records that can be saved for an NQA operation. The value range is 0 to 50.
If the number of history records for an NQA operation exceeds the maximum number, earliest history records are removed.
# Set the maximum number of history records to 10 for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] history-record number 10
init-ttl
Use init-ttl to set the TTL value for UDP packets in the start round of the UDP tracert operation.
Use undo init-ttl to restore the default.
init-ttl value
undo init-ttl
The NQA client sends a UDP packet with the TTL value 1 to start the UDP tracert operation.
value: Specifies the TTL value in the range of 1 to 255.
# Set the TTL value to 5 for the UDP packets in the start round.
[Sysname-nqa-admin-test-udp-tracert] init-ttl 5
key
Use key to set the shared key for secure RADIUS authentication.
Use undo key to restore the default.
key { cipher | simple } string
undo key
No shared key is configured for secure RADIUS authentication.
RADIUS template view
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the shared key string. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
Make sure the NQA client and the RADIUS server have the same shared key.
# In RADIUS template view, set the shared key to abc in plain text for secure RADIUS authentication.
[Sysname] nqa template radius radiustplt
[Sysname-nqatplt-radius-radiustplt] key simple abc
lsr-path
Use lsr-path to specify a loose source routing (LSR) path.
Use undo lsr-path to restore the default.
lsr-path ip-address&<1-8>
undo lsr-path
No LSR path is configured.
Path jitter operation view
ip-address&<1-8>: Specifies a space-separated list of up to eight IP addresses. Each IP address represents a hop on the path.
The path jitter operation first uses tracert to detect each hop to the destination. It then sends ICMP echo requests to measure the delay and jitters from the source to each node. If multiple routes exist between the source and destination, the operation uses the path specified by using lsr-path command.
# Specify 10.1.1.20 and 10.1.2.10 as the hops on the LSR path for the path jitter operation.
[Sysname-nqa-admin-test] type path-jitter
[Sysname-nqa-admin-test- path-jitter] lsr-path 10.1.1.20 10.1.2.10
max-failure
Use max-failure to set the maximum number of consecutive probe failures in a UDP tracert operation.
Use undo max-failure to restore the default.
max-failure times
undo max-failure
A UDP tracert operation stops and fails when it detects five consecutive probe failures.
times: Specifies the maximum number in the range of 0 to 255. When this argument is set to 0 or 255, the UDP tracert operation does not stop when consecutive probe failures occur.
When a UDP tracert operation detects the maximum number of consecutive probe failures, the operation fails and stops probing the path.
# Set the maximum number of consecutive probe failures to 20 in a UDP tracert operation.
[Sysname-nqa-admin-test-udp-tracert] max-failure 20
mode
Use mode to set the data transmission mode for the FTP operation.
Use undo mode to restore the default.
mode { active | passive }
undo mode
The FTP operation uses the data transmission mode active.
FTP operation view
FTP template view
active: Sets the data transmission mode to active. The FTP server initiates a connection request.
passive: Sets the data transmission mode to passive. The FTP client initiates a connection request.
# Set the data transmission mode to passive for the FTP operation.
[Sysname-nqa-admin-test-ftp] mode passive
# In FTP template view, set the data transmission mode to passive for the FTP operation.
[Sysname-nqatplt-ftp-ftptplt] mode passive
next-hop ip
Use next-hop ip to specify the next hop IPv4 address for probe packets.
Use undo next-hop ip to restore the default.
next-hop ip ip-address
undo next-hop ip
No next hop IPv4 address is specified for probe packets.
ICMP/TCP half open template view
ip-address: Specifies the IPv4 address of the next hop.
If the next hop IPv4 address is not configured, the device searches the routing table to determine the next hop IPv4 address for the probe packets.
# Specify 10.1.1.1 as the next hop IPv4 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] next-hop ip 10.1.1.1
next-hop ipv6
Use next-hop ipv6 to specify the next hop IPv6 address for probe packets.
Use undo next-hop ipv6 to restore the default.
next-hop ipv6 ipv6-address
undo next-hop ipv6
No next hop IPv6 address is specified for probe packets.
ipv6-address: Specifies the IPv6 address of the next hop. IPv6 link-local addresses are not supported.
If the next hop IPv6 address is not configured, the device searches the routing table to determine the next hop IPv6 address for the probe packets.
# Specify 10::1 as the next hop IPv6 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] next-hop ipv6 10::1
no-fragment enable
Use no-fragment enable to enable the no-fragmentation feature.
Use undo no-fragment enable to disable the no-fragmentation feature.
no-fragment enable
The no-fragmentation feature is disabled.
The no-fragmentation feature sets the DF field to 1. Packets with the DF field set cannot be fragmented during the forwarding process.
You can use this command to test the path MTU of a link.
# Enable the no-fragmentation feature for the UDP tracert operation.
[Sysname-nqa-admin-test-udp-tracert] no-fragment enable
nqa
Use nqa to create an NQA operation and enter its view, or enter the view of an existing NQA operation.
Use undo nqa to remove the operation.
nqa entry admin-name operation-tag
undo nqa { all | entry admin-name operation-tag }
No NQA operations exist.
all: Removes all NQA operations.
# Create an NQA operation with administrator name admin and operation tag test, and enter NQA operation view.
nqa agent enable
Use nqa agent enable to enable the NQA client.
Use undo nqa agent enable to disable the NQA client and stop all operations being performed.
nqa agent enable
The NQA client is enabled.
# Enable the NQA client.
[Sysname] nqa agent enable
nqa server enable
nqa schedule
Use nqa schedule to configure scheduling parameters for an NQA operation.
Use undo nqa schedule to stop the operation.
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd | mm/dd/yyyy ] | now } lifetime { lifetime | forever } [ recurring ]
undo nqa schedule admin-name operation-tag
No schedule is configured for an NQA operation.
start-time: Specifies the start time and date of the NQA operation.
hh:mm:ss: Specifies the start time of an NQA operation.
yyyy/mm/dd: Specifies the start date of an NQA operation. The default value is the current system time, and the value for the yyyy argument is in the range of 2000 to 2035.
mm/dd/yyyy: Specifies the start date of an NQA operation. The default value is the current system time, and the value for the yyyy argument is in the range of 2000 to 2035.
now: Starts the operation immediately.
lifetime: Specifies the duration of an operation.
lifetime: Specifies the duration of an operation in seconds. The value range is 1 to 2147483647.
forever: Performs the operation until you stop it by using the undo nqa schedule command.
recurring: Runs the operation automatically at the start time and for the specified duration. If you do not specify this keyword, the NQA operation is performed only once at the specified date and time.
The NQA operation works between the specified start time and the end time (the start time plus operation duration). If the specified start time is ahead of the system time, the operation starts immediately. If both the specified start time and end time are ahead of the system time, the operation does not start. To display the current system time, use the display clock command.
You cannot enter the view of a scheduled NQA operation. If you want to enter such view, use the undo nqa schedule command to stop the NQA operation first.
Specify a lifetime long enough for an operation to complete.
# Schedule the operation with administrator name admin and operation tag test to start on 08:08:08 2008/08/08 and last 1000 seconds.
[Sysname] nqa schedule admin test start-time 08:08:08 2008/08/08 lifetime 1000 recurring
destination ip
display clock (Fundamentals Command Reference)
nqa entry
type
nqa template
Use nqa template to create an NQA template and enter its view, or enter the view of an existing NQA template.
Use undo nqa template to remove an NQA template.
nqa template { dns | ftp | http | https | icmp | radius | ssl | tcp | tcphalfopen | udp } name
undo nqa template { dns | ftp | http | https | icmp | radius | ssl | tcp | tcphalfopen | udp } name
No NQA templates exist.
dns: Specifies the DNS template.
ftp: Specifies the FTP template.
http: Specifies the HTTP template.
https: Specifies the HTTPS template.
icmp: Specifies the ICMP template.
radius: Specifies the RADIUS template.
ssl: Specifies the SSL template.
tcp: Specifies the TCP template.
tcphalfopen: Specifies the TCP half open template.
udp: Specifies the UDP template.
name: Specifies the name of the NQA template, a case-insensitive string of 1 to 32 characters.
# Create an ICMP template named icmptplt, and enter its view.
Use operation to specify the operation type for the FTP operation.
Use undo operation to restore the default.
operation { get | put }
undo operation
The FTP operation type is get.
FTP operation view
FTP template view
get: Gets a file from the FTP server.
put: Transfers a file to the FTP server.
When you perform the put operation with the filename command configured, make sure the file exists on the NQA client.
If you get a file from the FTP server, make sure the file specified in the URL exists on the FTP server. The NQA client does not save the file obtained from the FTP server.
Use a small file for the FTP operation. A big file might result in transfer failure because of timeout, or might affect other services for occupying much network bandwidth.
# Set the operation type to put for the FTP operation.
[Sysname-nqa-admin-test-ftp] operation put
# In FTP template view, set the operation type to put for the FTP operation.
[Sysname-nqatplt-ftp-ftptplt] operation put
password
username
Use operation to specify the operation type for the HTTP or HTTPS operation.
operation { get | post | raw }
undo operation
The HTTP or HTTPS operation type is get.
HTTP operation view
HTTP/HTTPS template view
get: Gets data from the HTTP or HTTPS server.
post: Transfers data to the HTTP or HTTPS server.
raw: Sends the RAW request to the HTTP or HTTPS server.
The HTTP and HTTPS operations use HTTP and HTTPS requests as probe packets.
For the get or post operation, the content in the request is obtained from the URL specified by the url command.
For the raw operation, the content in the request is configured in raw request view. You can use the raw-request command to enter the raw request view.
# Set the operation type to raw for the HTTP operation.
[Sysname-nqa-admin-test] type http
[Sysname-nqa-admin-test-http] operation raw
# In HTTP template view, set the operation type to raw for the HTTP operation.
[Sysname-nqatplt-http-httptplt] operation raw
password
raw-request
username
out interface
Use out interface to specify the output interface for probe packets.
Use undo out interface to restore the default.
out interface interface-type interface-number
undo out interface
The output interface for probe packets is not specified. The NQA client determines the output interface based on the routing table lookup.
DHCP operation view
For successful operation, the specified output interface must be up.
If both the next-hop and out interface commands are configured for the ICMP echo operation, the out interface command does not take effect.
# Specify VLAN-interface 1 as the output interface for probe packets in the UDP tracert operation.
[Sysname-nqa-admin-test-udp-tracert] out interface vlan-interface 1
password
Use password to specify a password.
Use undo password to restore the default.
undo password
No password is specified.
FTP/HTTP operation view
FTP/HTTP/HTTPS/RADIUS template view
string: Specifies the password. The value of the argument varies as follows:
· For FTP, HTTP, and HTTPS operations, the plaintext form of the password is a case-sensitive string of 1 to 32 characters. The encrypted form of the password is a case-sensitive string of 1 to 73 characters.
· For RADIUS templates, the plaintext form of the password is a case-sensitive string of 1 to 64 characters. The encrypted form of the password is a case-sensitive string of 1 to 117 characters.
# Set the FTP login password to ftpuser.
[Sysname-nqa-admin-test-ftp] password simple ftpuser
# Set the FTP login password to ftpuser in FTP template view.
[Sysname-nqatplt-ftp-ftptplt] password simple ftpuser
operation
username
probe count
Use probe count to specify the probe times.
Use undo probe count to restore the default.
probe count times
undo probe count
In an UDP tracert operation, the NQA client sends three probe packets to each hop along the path.
In other types of operations, the NQA client performs one probe to the destination per operation.
ICMP jitter/UDP jitter operation view
times: Specifies the probe times.
· For the UDP tracert operation, this argument specifies the times of probes to each hop along the path. The value range for this argument is 1 to 10.
· For other types of operations, this argument specifies the times of probes to the destination per operation. The value range for this argument is 1 to 15.
The following describes how NQA performs different types of operations:
· A TCP or DLSw operation sets up a connection.
· An ICMP jitter or UDP jitter operation sends a number of probe packets. The number of probe packets is set by using the probe packet-number command.
· An FTP operation uploads or downloads a file.
· An HTTP operation gets a Web page.
· A DHCP operation gets an IP address through DHCP.
· A DNS operation translates a domain name to an IP address.
· An ICMP echo sends an ICMP echo request.
· A UDP echo operation sends a UDP packet.
· An SNMP operation sends one SNMPv1 packet, one SNMPv2c packet, and one SNMPv3 packet.
· A UDP tracert operation determines the routing path from the source to the destination. The number of probe packets sent to each hop is set by using the probe count command.
· A frame loss, latency, or throughput operation sends probe frames to the destination device to test the frame loss ratio, latency, or throughput of the network.
If an operation is to perform multiple probes, the NQA client starts a new probe in one of the following conditions:
· The NQA client receives responses to packets sent in the last probe.
· The probe timeout time expires.
This command is not available for the voice or path jitter operations. Each of these operations performs only one probe.
# Configure the ICMP echo operation to perform 10 probes.
[Sysname-nqa-admin-test-icmp-echo] probe count 10
probe packet-interval
Use probe packet-interval to configure the packet sending interval in the probe.
Use undo probe packet-interval to restore the default.
probe packet-interval interval
The packet sending interval is 20 milliseconds.
interval: Specifies the sending interval in the range of 10 to 60000 milliseconds.
# Configure the UDP jitter operation to send packets every 100 milliseconds.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type udp-jitter
[Sysname-nqa-admin-test-udp-jitter] probe packet-interval 100
probe packet-number
Use probe packet-number to set the number of packets to be sent in a UDP jitter, path jitter, or voice probe.
Use undo probe packet-number to restore the default.
probe packet-number packet-number
An ICMP jitter, UDP jitter, or path jitter probe sends 10 packets and a voice probe sends 1000 packets.
packet-number: Specifies the number of packets to be sent per probe. Available value ranges include:
· 10 to 1000 for the ICMP jitter, UDP jitter, and path jitter operations.
· 10 to 60000 for the voice operation.
# Configure the UDP jitter probe to send 100 packets.
[Sysname-nqa-admin-test-udp-jitter] probe packet-number 100
probe packet-timeout
Use probe packet-timeout to set the timeout time for waiting for a response in the UDP jitter, path jitter, or voice operation.
Use undo probe packet-timeout to restore the default.
probe packet-timeout timeout
The response timeout time in the UDP jitter or path jitter operation is 3000 milliseconds.
The response timeout time in the voice operation is 5000 milliseconds.
timeout: Specifies the timeout time in milliseconds. The value range is 10 to 3600000.
# Set the response timeout time to 100 milliseconds in the UDP jitter operation.
[Sysname-nqa-admin-test-udp-jitter] probe packet-timeout 100
probe timeout
Use probe timeout to set the probe timeout time.
Use undo probe timeout to restore the default.
probe timeout timeout
undo probe timeout
The timeout time of a probe is 3000 milliseconds.
UDP tracert operation view
timeout: Specifies the probe timeout time in milliseconds. The value range for this argument varies as follows:
· For FTP and HTTP operations, the value range is 10 to 86400000.
· For DHCP, DNS, DLSw, ICMP echo, SNMP, TCP, UDP echo, and UDP tracert operations, the value range is 10 to 3600000.
· For FTP, HTTP, and HTTPS templates, the value range is 10 to 86400000.
· For other types of NQA templates, the value range is 10 to 3600000.
If a probe does not complete within the period, the probe is timed out.
# Set the probe timeout time to 10000 milliseconds for the DHCP operation.
[Sysname-nqa-admin-test] type dhcp
[Sysname-nqa-admin-test-dhcp] probe timeout 10000
# In HTTP template view, set the probe timeout time to 10000 milliseconds for the HTTP operation.
[Sysname-nqatplt-http-httptplt] probe timeout 10000
raw-request
Use raw-request to enter raw request view and specify the content of an HTTP or HTTPS request.
Use undo raw-request to restore the default.
raw-request
undo raw-request
The contents of an HTTP or HTTPS raw request are not specified.
HTTP operation view
This command places you in raw request view and deletes the previously configured request content.
If the HTTP or HTTPS operation type is set to raw, you must enter raw request view and configure the request content to be sent to the HTTP or HTTPS server. To ensure successful operations, make sure the request content does not contain command aliases configured by using the alias command. For more information about the alias command, see CLI commands in Fundamentals Command Reference.
# Enter raw request view and specify the content of a GET request for the HTTP operation.
[Sysname-nqa-admin-test-http] raw-request
[Sysname-nqa-admin-test-http-raw-request] GET /sdn/ui/app/index HTTP/1.0\r\nHost: 172.0.0.2\r\n\r\n
# In HTTP template view, enter raw request view and specify the content of a POST request for the HTTP operation.
[Sysname-nqatplt-http-httptplt] raw-request
[Sysname-nqatplt-http-httptplt-raw-request] POST /sdn/ui/app/index HTTP/1.0\r\nHost:
172.0.0.2\r\nAuthorization: Basic cm9vdDoxMjM0NTY=\r\n\r\n
reaction checked-element { jitter-ds | jitter-sd }
Use reaction checked-element { jitter-ds | jitter-sd } to configure a reaction entry for monitoring one-way jitter in the NQA operation.
Use undo reaction to delete a reaction entry.
reaction item-number checked-element { jitter-ds | jitter-sd } threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
undo reaction item-number
No reaction entries for monitoring one-way jitter exist.
ICMP jitter/UDP jitter/voice operation view
item-number: Assigns an ID to the reaction entry, in the range of 1 to 10.
jitter-ds: Specifies the destination-to-source jitter of each probe packet as the monitored element (or performance metric).
jitter-sd: Specifies source-to-destination jitter of each probe packet as the monitored element.
threshold-type: Specifies a threshold type.
accumulate accumulate-occurrences: Checks the total number of threshold violations in the operation. The value range is 1 to 14999 for the ICMP jitter and UDP jitter operations, and 1 to 59999 for the voice operation.
average: Checks the average one-way jitter.
threshold-value: Specifies threshold range in milliseconds.
upper-threshold: Specifies the upper limit in the range of 0 to 3600000.
lower-threshold: Specifies the lower limit in the range of 0 to 3600000. It must not be greater than the upper limit.
action-type: Specifies the action to be triggered. The default action is none.
none: Specifies the action of displaying results on the terminal display.
trap-only: Specifies the action of displaying results on the terminal display and meanwhile sending SNMP trap messages to the NMS.
You cannot edit a reaction entry after it is created. To change the attributes in a reaction entry, use the undo reaction command to delete the entry, and then configure a new one.
Only successful probe packets are monitored. Statistics about failed probe packets are not collected.
# Create reaction entry 1 for monitoring the average destination-to-source jitter of UDP jitter packets, and set the upper limit to 50 milliseconds and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average destination-to-source jitter is checked against the threshold range. If it exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element jitter-ds threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the destination-to-source jitter of UDP jitter probe packets, and set the upper limit to 50 milliseconds, and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the destination-to-source jitter is checked against the threshold range. If the total number of threshold violations reaches or exceeds 100, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 2 checked-element jitter-ds threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction checked-element { owd-ds | owd-sd }
Use reaction checked-element { owd-ds | owd-sd } to configure a reaction entry for monitoring the one-way delay.
reaction item-number checked-element { owd-ds | owd-sd } threshold-value upper-threshold lower-threshold
No reaction entries for monitoring the one-way delay exist.
owd-ds: Specifies the destination-to-source delay of each probe packet as the monitored element.
owd-sd: Specifies the source-to-destination delay of each probe packet as the monitored element.
No actions can be configured for a reaction entry of monitoring one-way delays. To display the monitoring results and statistics, use the display nqa reaction counters and display nqa statistics commands.
# Create reaction entry 1 for monitoring the destination-to-source delay of every UDP jitter packet, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. The destination-to-source delay is calculated after the response to the probe packet arrives. If the delay exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element owd-ds threshold-value 50 5
reaction checked-element icpif
Use reaction checked-element icpif to configure a reaction entry for monitoring the ICPIF value in the voice operation.
reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entries for monitoring ICPIF values exist.
Voice operation view
threshold-value: Specifies threshold range.
upper-threshold: Specifies the upper limit in the range of 1 to 100.
lower-threshold: Specifies the lower limit in the range of 1 to 100. It must not be greater than the upper limit.
action-type: Specifies what action to be triggered. The default action is none.
# Create reaction entry 1 for monitoring the ICPIF value in the voice operation, and set the upper limit to 50 and lower limit to 5. Before the voice operation starts, the initial state of the reaction entry is invalid. After the operation, the ICPIF value is checked against the threshold range. If it exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] reaction 1 checked-element icpif threshold-value 50 5 action-type trap-only
reaction checked-element mos
Use reaction checked-element mos to configure a reaction entry for monitoring the MOS value in the voice operation.
reaction item-number checked-element mos threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entries for monitoring the MOS value exist.
upper-threshold: Specifies the upper limit in the range of 1 to 500.
lower-threshold: Specifies the lower limit in the range of 1 to 500. It must not be greater than the upper limit.
For the MOS threshold, the number is expressed in three digits representing ones, tenths, and hundredths. For example, to express a MOS threshold of 1, enter 100.
# Create reaction entry 1 for monitoring the MOS value of the voice operation, and set the upper limit to 2 and lower limit to 1. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the MOS value is checked against the threshold range. If it exceeds the upper limit, the state of the reaction entry is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-voice] reaction 1 checked-element mos threshold-value 200 100 action-type trap-only
reaction checked-element packet-loss
Use reaction checked-element packet-loss to configure a reaction entry for monitoring packet loss in UDP jitter or voice operation.
reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences [ action-type { none | trap-only } ]
No reaction entries for monitoring packet loss exist.
accumulate accumulate-occurrences: Specifies the total number of lost packets in the operation. The value range is 1 to 15000 for the ICMP jitter and UDP jitter operations and 1 to 60000 for the voice operation.
# Create reaction entry 1 for monitoring packet loss in the UDP jitter operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the total number of the lost packets is checked against the threshold. If the number reaches or exceeds 100, the state of the reaction entry is set to over-threshold. Otherwise, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element packet-loss threshold-type accumulate 100 action-type trap-only
reaction checked-element probe-duration
Use reaction checked-element probe-duration to configure a reaction entry for monitoring the probe duration.
reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entries for monitoring the probe duration exist.
ICMP echo/TCP/UDP echo operation view
accumulate accumulate-occurrences: Checks the total number of threshold violations. The value range is 1 to 15.
average: Checks the average probe duration.
consecutive consecutive-occurrences: Specifies the number of consecutive threshold violations after the NQA operation starts. The value range is 1 to 16.
lower-threshold: Specifies the lower limit in the range of 0 to 3600000. It must not be greater than the upper threshold.
trap-only: Specifies the action of displaying results on the terminal display and meanwhile sending SNMP trap messages to the NMS. This keyword is not available for the DNS operation.
# Create reaction entry 1 for monitoring the average probe duration of ICMP echo operation, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average probe duration is checked. If it exceeds the upper limit, the state is set to over-threshold. If it is below the lower limit, the state of the reaction entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-duration threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the probe duration of ICMP echo operation, and set the upper limit to 50 milliseconds and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the accumulated probe duration is checked against the threshold range. If the total number of threshold violations reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-duration threshold-type accumulate 10 threshold-value 50 5 action-type trap-only
# Create reaction entry 3 for monitoring the probe duration time of ICMP echo operation, and set the upper limit to 50 milliseconds and the lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the consecutive probe duration is checked against the threshold range. If the total number of consecutive threshold violations reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the lower threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 3 checked-element probe-duration threshold-type consecutive 10 threshold-value 50 5 action-type trap-only
reaction checked-element probe-fail (for trap)
Use reaction checked-element probe-fail to configure a reaction entry for monitoring the probe failures of the operation.
reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } [ action-type { none | trap-only } ]
No reaction entries for monitoring probe failures exist.
accumulate accumulate-occurrences: Checks the total number of probe failures. The value range is 1 to 15.
consecutive consecutive-occurrences: Checks the maximum number of consecutive probe failures. The value range is 1 to 16.
# Create reaction entry 1 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the total number of probe failures reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type accumulate 10 action-type trap-only
# Create reaction entry 2 for monitoring the probe failures in ICMP echo operation. Before the NQA operation starts, the initial state of the reaction entry is invalid. If the number of consecutive probe failures reaches or exceeds 10, the state of the entry is set to over-threshold. If it is below the threshold, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-fail threshold-type consecutive 10 action-type trap-only
reaction checked-element probe-fail (for trigger)
Use reaction checked-element probe-fail to configure a reaction entry for monitoring probe failures.
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only
consecutive consecutive-occurrences: Checks the maximum number of consecutive probe failures, in the range of 1 to 16.
trigger-only: Triggers other modules to react to certain conditions.
# Create reaction entry 1. If the number of consecutive probe failures reaches 3, collaboration is triggered.
[Sysname-nqa-admin-test] type tcp
[Sysname-nqa-admin-test-tcp] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
track (High Availability Command Reference)
reaction checked-element rtt
Use reaction checked-element rtt to configure a reaction entry for monitoring packet round-trip time.
reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
No reaction entries for monitoring packet round-trip time exist.
accumulate accumulate-occurrences: Checks the total number of threshold violations. Available value ranges include:
· 1 to 15000 for the ICMP jitter and UDP jitter operations.
· 1 to 60000 for the voice operation.
average: Checks the packet average round-trip time.
# Create reaction entry 1 for monitoring the average round-trip time of UDP jitter probe packets, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the average packet round-trip time is checked. If it exceeds the upper limit, the state is set to over-threshold. If it is below the lower limit, the state is set to below-threshold. Once the reaction entry state changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the round-trip time of UDP jitter probe packets, and set the upper limit to 50 milliseconds and lower limit to 5 milliseconds. Before the NQA operation starts, the initial state of the reaction entry is invalid. After the operation, the packet round-trip time is checked. If the total number of threshold violations reaches or exceeds 100, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the NMS.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction trap
Use reaction trap to configure the sending of traps to the NMS under specific conditions.
Use undo reaction trap to restore the default.
reaction trap { path-change | probe-failure consecutive-probe-failures | test-complete | test-failure [ accumulate-probe-failures ] }
undo reaction trap { path-change | probe-failure | test-complete | test-failure }
No traps are sent to the NMS.
path-change: Sends a trap when the UDP tracert operation detects a different path to the destination.
probe-failure consecutive-probe-failures: Sends a trap to the NMS if the number of consecutive probe failures in an operation is greater than or equal to consecutive-probe-failures. The value range for the consecutive-probe-failures argument is 1 to 15. The system counts the number of consecutive probe failures for each operation, so multiple traps might be sent.
test-complete: Sends a trap to indicate that the operation is completed.
test-failure: Sends a trap when an operation fails. For operations other than UDP tracert operation, the system counts the total number of probe failures in an operation. If the number reaches or exceeds the value for the accumulate-probe-failures argument, a trap is sent for the operation failure.
accumulate-probe-failures: Specifies the total number of probe failures in an operation. The value range is 1 to 15. This argument is not supported by the UDP tracert operation.
The ICMP jitter, UDP jitter, and voice operations support only the test-complete keyword.
The following parameters are not available for the UDP tracert operation:
· The probe-failure consecutive-probe-failures option.
· The accumulate-probe-failures argument.
# Configure the system to send a trap if five or more consecutive probe failures occur in an ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] reaction trap probe-failure 5
reaction trigger per-probe
Use reaction trigger per-probe to configure the probe result sending on a per-probe basis.
Use undo reaction trigger per-probe to restore the default.
The probe result is sent to the feature that uses the template after three consecutive failed or successful probes.
The feature enables the NQA client to send the probe result to the feature that uses the NQA template every time a probe is completed.
If you execute this command and the reaction trigger probe-fail command multiple times, the most recent configuration takes effect.
If you execute this command and the reaction trigger probe-pass command multiple times, the most recent configuration takes effect.
# In ICMP template view, configure the probe result sending on a per-probe basis.
[Sysname] nqa template icmp icmptplt
[Sysname-nqatplt-icmp-icmptplt] reaction trigger per-probe
Use reaction trigger probe-fail to set the number of consecutive probe failures to determine an operation failure.
Use undo reaction trigger probe-fail to restore the default.
reaction trigger probe-fail count
The NQA client notifies the feature of the operation failure when the number of consecutive probe failures reaches 3.
Any NQA template view
count: Specifies the number of consecutive probe failures, in the range of 1 to 15.
If the number of consecutive probe failures is reached, the NQA client notifies the feature that uses the NQA template of the operation failure.
If you execute this command and the reaction trigger per-probe command multiple times, the most recent configuration takes effect.
# In HTTP template view, configure the NQA client to notify the feature of the operation failure when the number of consecutive probe failures reaches 5.
[Sysname-nqatplt-http-httptplt] reaction trigger probe-fail 5
Use reaction trigger probe-pass to set the number of consecutive successful probes to determine a successful operation event.
Use undo reaction trigger probe-pass to restore the default.
reaction trigger probe-pass count
The NQA client notifies the feature of the successful operation event if the number of consecutive successful probes reaches 3.
count: Specifies the number of consecutive successful probes, in the range of 1 to 15.
If number of consecutive successful probes is reached, the NQA client notifies the feature that uses the template of the successful operation event.
If you execute this command and the reaction trigger per-probe command multiple times, the most configuration takes effect.
# In HTTP template view, configure the NQA client to notify the feature of the successful operation event if the number of consecutive successful probes reaches 5.
[Sysname-nqatplt-http-httptplt] reaction trigger probe-pass 5
resolve-target
Use resolve-target to specify the domain name to be resolved in the DNS operation.
Use undo resolve-target to restore the default.
resolve-target domain-name
undo resolve-target
The domain name to be resolved in the DNS operation is not specified.
DNS operation view
DNS template view
domain-name: Specifies the domain name to be resolved. It is a dot-separated case-sensitive string of 1 to 255 characters including letters, digits, hyphens (-), and underscores (_) (for example, aabbcc.com). Each part consists of 1 to 63 characters, and consecutive dots (.) are not allowed.
# Specify domain1 as the domain name to be resolved.
[Sysname-nqa-admin-test] type dns
[Sysname-nqa-admin-test-dns] resolve-target domain1
# In DNS template view, specify domain1 as the domain name to be resolved.
[Sysname-nqatplt-dns-dnstplt] resolve-target domain1
resolve-type
Use resolve-type to configure the domain name resolution type.
Use undo resolve-type to restore the default.
resolve-type { A | AAAA }
undo resolve-type
The domain name resolution type is type A.
DNS template view
A: Specifies the type A queries. A type A query resolves a domain name to a mapped IPv4 address.
AAAA: Specifies the type AAAA queries. A type AAAA query resolves a domain name to a mapped IPv6 address.
# In DNS template view, set the domain name resolution type to A.
[Sysname-nqatplt-dns-dnstplt] resolve-type A
route-option bypass-route
Use route-option bypass-route to enable the routing table bypass feature to test the connectivity to the direct destination.
Use undo route-option bypass-route to disable the routing table bypass feature.
The routing table bypass feature is disabled.
When the routing table bypass feature is enabled, the following events occur:
· The routing table is not searched. Packets are sent to the destination on a directly connected network.
· The TTL value in the probe packet is set to 1. The TTL set in the ttl command does not take effect.
This command does not take effect if the destination address of the NQA operation is an IPv6 address.
# Enable the routing table bypass feature.
[Sysname-nqa-admin-test-icmp-echo] route-option bypass-route
source interface (ICMP echo/UDP tracert operation view)
Use source interface to specify the IP address of an interface as the source IP address of probe packets.
Use undo source interface to restore the default.
source interface interface-type interface-number
The probe packets take the primary IP address of the outgoing interface as their source IP address.
ICMP echo operation view
ICMP template view
The specified interface must be up. If the interface is down, no probe requests can be sent out.
If you execute this command and the source ip or source ipv6 command for an ICMP echo operation or ICMP template multiple times, the most recent configuration takes effect.
If you execute this command and the source ip command for a UDP tracert operation multiple times, the most recent configuration takes effect.
# Specify the IP address of the interface VLAN-interface 1 as the source IP address of ICMP echo request packets.
[Sysname-nqa-admin-test-icmp-echo] source interface vlan-interface 1
# In ICMP template view, specify the IP address of the interface VLAN-interface 1 as the source IP address of ICMP echo request packets.
[Sysname-nqatplt-icmp-icmptplt] source interface vlan-interface 1
source ip
source ipv6
source ip
Use source ip to configure the source IPv4 address for probe packets.
Use undo source ip to restore the default.
source ip ip-address
undo source ip
The probe packets takes the primary IP address of their output interface as the source IPv4 address.
DHCP/DLSw/FTP/HTTP/SNMP operation view
ICMP jitter/path jitter/UDP jitter/voice operation view
ip-address: Specifies the source IPv4 address for probe packets.
The specified source IP address must be the IPv4 address of a local interface, and the local interface must be up. Otherwise, no probe packets can be sent out.
For an NQA template, if the source and destination addresses have different IP versions, the source address does not take effect.
If you execute the source interface and source ip commands multiple times for an ICMP echo operation, ICMP template, or UDP tracert operation, the most recent configuration takes effect.
# Specify 10.1.1.1 as the source IPv4 address for ICMP echo requests.
[Sysname-nqa-admin-test-icmp-echo] source ip 10.1.1.1
# In ICMP template view, specify 10.1.1.1 as the source IPv4 address for ICMP echo requests.
[Sysname-nqatplt-icmp-icmptplt] source ip 10.1.1.1
source interface
source ipv6
Use source ipv6 to configure the source IPv6 address for probe packets.
Use undo source ipv6 to restore the default.
source ipv6 ipv6-address
undo source ipv6
The probe packets takes the IPv6 address of their output interface as the source IPv6 address.
ipv6-address: Specifies the source IPv6 address for probe packets. IPv6 link-local addresses are not supported.
The specified source IPv6 address must be the IPv6 address of a local interface. The local interface must be up. Otherwise, no probe packets can be sent out.
If you execute the source interface and source ipv6 commands multiple times for an ICMP echo operation or ICMP template, the most recent configuration takes effect.
# Specify 1::1 as the source IPv6 address for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] source ipv6 1::1
# In ICMP template view, specify 1::1 as the source IPv6 address for ICMP echo requests.
[Sysname-nqatplt-icmp-icmptplt] source ipv6 1::1
source interface
source port
Use source port to configure the source port number for probe packets.
Use undo source port to restore the default.
source port port-number
undo source port
The source port number is not specified.
SNMP operation view
DNS template view
port-number: Specifies the source port number in the range of 1 to 65535.
# Set the source port number to 8000 for probe packets in the UDP echo operation.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] source port 8000
# In DNS template view, set the source port number to 8000 for probe packets in the DNS operation.
[Sysname-nqatplt-dns-dnstplt] source port 8000
ssl-client-policy
Use ssl-client-policy to specify an SSL client policy for an HTTPS or SSL template.
Use undo ssl-client-policy to restore the default.
ssl-client-policy policy-name
No SSL client policy is specified for an HTTPS or SSL template.
HTTPS/SSL template view
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters.
In the HTTPS or SSL operation, the NQA client uses the specified SSL client policy to establish an SSL connection to the server.
# Specify SSL client policy policy for SSL template ssltplt.
[Sysname] nqa template ssl ssltplt
[Sysname-nqatplt-ssl-ssltplt] ssl-client-policy policy
statistics hold-time
Use statistics hold-time to set the hold time of statistics groups for an NQA operation.
Use undo statistics hold-time to restore the default.
statistics hold-time hold-time
The hold time of statistics groups for an NQA operation is 120 minutes.
hold-time: Specifies the hold time in minutes, in the range of 1 to 1440.
A statistics group is deleted when its hold time expires.
# Set the hold time to 3 minutes for statistics groups of the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] statistics hold-time 3
statistics interval
Use statistics interval to set the statistics collection interval for an NQA operation.
Use undo statistics interval to restore the default.
statistics interval interval
The statistics collection interval is 60 minutes.
interval: Specifies the interval in minutes, in the range of 1 to 35791394.
NQA forms statistics within the same collection interval as a statistics group. To display information about the statistics groups, use the display nqa statistics command.
# Configure NQA to collect the ICMP echo operation statistics every 2 minutes.
[Sysname-nqa-admin-test-icmp-echo] statistics interval 2
statistics max-group
Use statistics max-group to set the maximum number of statistics groups that can be saved.
Use undo statistics max-group to restore the default.
statistics max-group number
A maximum of two statistics groups can be saved.
number: Specifies the maximum number of statistics groups, in the range of 0 to 100. To disable statistics collection, set the value to 0.
When the maximum number of statistics groups is reached and a new statistics group is to be saved, the earliest statistics group is deleted.
# Configure NQA to save a maximum of five statistics groups for the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] statistics max-group 5
target-only
Use target-only to perform the path jitter operation only on the destination address.
Use undo target-only to restore the default.
target-only
undo target-only
NQA performs the path jitter operation to the destination hop by hop.
# Perform the path jitter operation only on the destination address.
[Sysname-nqa-admin-test-path-jitter] target-only
tos
Use tos to set the ToS value in the IP header for probe packets.
Use undo tos to restore the default.
tos value
undo tos
The ToS value in the IP header of probe packets is 0.
Any operation view
value: Specifies the ToS value in the range of 0 to 255.
# In ICMP echo operation view, set the ToS value to 1 in the IP header for probe packets.
[Sysname-nqa-admin-test-icmp-echo] tos 1
# In ICMP template view, set the ToS value to 1 in the IP header for probe packets.
[Sysname-nqatplt-icmp-icmptplt] tos 1
ttl
Use ttl to set the maximum number of hops that the probe packets can traverse.
Use undo ttl to restore the default.
ttl value
undo ttl
The maximum number of hops is 30 for probe packets of the UDP tracert operation, and is 20 for probe packets of other types of operations.
value: Specifies the maximum number of hops that the probe packets can traverse, in the range of 1 to 255.
The route-option bypass-route command sets the TTL to 1 for probe packets. If you configure both the route-option bypass-route and ttl commands for an operation, the ttl command does not take effect.
For a successful UDP tracert operation, make sure the maximum number of hops is not smaller than the value set in the init-ttl command.
# Set the maximum number of hops to 16 for probe packets in the ICMP echo operation.
[Sysname-nqa-admin-test-icmp-echo] ttl 16
# In ICMP template view, set the maximum number of hops to 16 for probe packets.
[Sysname-nqatplt-icmp-icmptplt] ttl 16
type
Use type to specify an NQA operation type and enter its view.
type { dhcp | dlsw | dns | ftp | http | icmp-echo | icmp-jitter | path-jitter | snmp | tcp | udp-echo | udp-jitter | udp-tracert | voice }
No operation type is specified.
NQA operation view
dhcp: Specifies the DHCP operation type.
dlsw: Specifies the DLSw operation type.
dns: Specifies the DNS operation type.
ftp: Specifies the FTP operation type.
http: Specifies the HTTP operation type.
icmp-echo: Specifies the ICMP echo operation type.
icmp-jitter: Specifies the ICMP jitter operation type.
path-jitter: Specifies the path jitter operation type.
snmp: Specifies the SNMP operation type.
tcp: Specifies the TCP operation type.
udp-echo: Specifies the UDP echo operation type.
udp-jitter: Specifies the UDP jitter operation type.
udp-tracert: Specifies the UDP tracert operation type.
voice: Specifies the voice operation type.
You can specify only one type for an NQA operation. After that, you can configure the operation type-related settings for the NQA operation. To change the type of the NQA operation, remove the NQA operation in system view, and then re-create the NQA operation.
# Specify FTP as the NQA operation type and enter FTP operation view.
[Sysname-nqa-admin-test] type ftp
url
Use url to specify the URL of the destination.
Use undo url to restore the default.
url url
undo url
The destination URL is not specified.
FTP/HTTP/HTTPS template view
url: Specifies the URL of the destination server, a case-sensitive string of 1 to 255 characters. The following table describes the URL format and parameters for different operations.
Operation |
URL format |
Parameter description |
HTTP operation |
http://host/resource http://host:port/resource |
The host parameter represents the host name of the destination server. The host name is a dot-separated case-sensitive string including letters, digits, hyphens (-), and underscores (_). Host names are composed of series of labels, aabbcc.com for example. Each label consists of 1 to 63 characters. Consecutive dots (.) and question marks are not allowed. For description about the filename parameter, see Fundamentals Configuration Guide. |
HTTPS operation |
https://host/resource https://host:port/resource |
FTP operation |
ftp://host/filename ftp://host:port/filename |
# Configure the URL that the HTTP operation visits as http://www.company.com/index.htm.
[Sysname-nqa-admin-test-http] url http://www.company.com/index.html
# In HTTP template view, configure the URL that the HTTP operation visits as http://www.company.com/index.htm.
[Sysname] nqa template http httptplt
[Sysname-nqatplt-http-httptplt] url http://www.company.com/index.html
username
Use username to specify a username.
Use undo username to restore the default.
username username
undo username
No username is configured.
username: Specifies the username. This argument is case sensitive. It is a string of 1 to 32 characters for an FTP, HTTP, or HTTPS username, and a string of 1 to 253 characters for a RADIUS authentication username.
# Set the FTP login username to administrator.
[Sysname-nqa-admin-test-ftp] username administrator
# Set the FTP login username to administrator in FTP template view.
[Sysname] nqa template ftp ftptplt
[Sysname-nqatplt-ftp-ftptplt] username administrator
operation
password
version
Use version to specify the version used in the HTTP or HTTPS operation.
Use undo version to restore the default.
version { v1.0 | v1.1 }
undo version
Version 1.0 is used in the HTTP operation or HTTPS operation.
HTTP operation view
v1.0: Uses version 1.0.
v1.1: Uses version 1.1.
# Configure the HTTP operation to use the HTTP version 1.1.
[Sysname-nqa-admin-test-http] version v1.1
vpn-instance
Use vpn-instance to apply the operation to a VPN instance.
Use undo vpn-instance to restore the default.
undo vpn-instance
The operation applies to the public network.
DHCP/DLSw/DNS/FTP/HTTP/SNMP operation view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
After you specify the VPN, the NQA operation tests the connectivity in the specified VPN instance.
# Apply the ICMP echo operation to vpn1.
[Sysname-nqa-admin-test-icmp-echo] vpn-instance vpn1
# In FTP template view, apply the FTP operation to vpn1.
[Sysname-nqatplt-ftp-ftptplt] vpn-instance vpn1
NQA server commands
IMPORTANT: Configure the NQA server only for UDP jitter, TCP, UDP echo, and voice operations. |
display nqa server
Use display nqa server status to display NQA server status.
display nqa server
# Display NQA server status.
<Sysname> display nqa server
NQA server status: Enabled
TCP connect:
IP address Port Tos VPN instance
2.2.2.2 2000 200 -
UDP echo:
3.3.3.3 3000 255 -
Table 10 Command output
NQA server status |
Whether the NQA server is enabled. |
TCP connect |
Information about the TCP listening service on the NQA server. |
UDP echo |
Information about the UDP listening service on the NQA server. |
IP address |
IP address specified for the TCP/UDP listening service on the NQA server. |
Port |
Port number specified for the TCP/UDP listening service on the NQA server. |
Tos |
ToS value in reply packets sent by the NQA server. |
VPN instance |
Name of the VPN instance to which the IP address that the NQA server listens on belongs. This field displays a hyphen (-) if the NQA server listens on a public IP address. |
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nqa server enable
Use nqa server enable to enable the NQA server.
Use undo nqa server enable to disable the NQA server.
nqa server enable
The NQA server is disabled.
# Enable the NQA server.
[Sysname] nqa server enable
display nqa server
nqa server udp-echo
Use nqa server tcp-connect to configure a TCP listening service to enable the NQA server to listen to a port on an IP address.
Use undo nqa server tcp-connect to remove a TCP listening service.
nqa server tcp-connect ip-address port-number [ vpn-instance vpn-instance-name ] [ tos tos ]
undo nqa server tcp-connect ip-address port-number
No TCP listening services exist.
ip-address: Specifies the IP address for the TCP listening service.
port-number: Specifies the port number for the TCP listening service, in the range of 1 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the NQA server listens on a public IP address.
tos tos: Specifies the ToS value in the IP header for reply packets. The value range is 0 to 255, and the default value is 0.
Use this command on the NQA server only for the TCP operation.
When you configure the IP address and port number for a TCP listening service on the NQA server, follow these restrictions and guidelines:
· The IP address, port number, and VPN instance must be unique on the NQA server and match the configuration on the NQA client.
· The IP address must be the address of an interface on the NQA server.
· To ensure successful NQA operations and avoid affecting existing services, do not configure the TCP listening service on well-known ports from 1 to 1023.
# Configure a TCP listening service to enable the NQA server to listen to port 9000 on the IP address 169.254.10.2.
[Sysname] nqa server tcp-connect 169.254.10.2 9000
display nqa server
nqa server enable
nqa server udp-echo
Use nqa server udp-echo to configure a UDP listening service to enable the NQA server to listen to a port on an IP address.
Use undo nqa server udp-echo to remove the UDP listening service created.
nqa server udp-echo ip-address port-number [ vpn-instance vpn-instance-name ][ tos tos ]
undo nqa server udp-echo ip-address port-number
No UDP listening services exist.
ip-address: Specifies the IP address for the UDP listening service.
port-number: Specifies the port number for the UDP listening service, in the range of 1 to 65535.
tos tos: Specifies the ToS value in the IP header for reply packets. The value range for this argument is 0 to 255, and the default value is 0.
Use this command on the NQA server only for the UDP jitter, UDP echo, and voice operations.
When you configure the IP address and port number for a UDP listening service on the NQA server, follow these restrictions and guidelines:
· To ensure successful NQA operations and avoid affecting existing services, do not configure the UDP listening service on well-known ports from 1 to 1023.
# Configure a UDP listening service to enable the NQA server to listen to port 9000 on the IP address 169.254.10.2.
[Sysname] nqa server udp-echo 169.254.10.2 9000
display nqa server
nqa server enable
