02-Ethernet OAM commands | 123.31 KB |
oam errored-frame-period threshold
oam errored-frame-period window
oam errored-frame-seconds threshold
oam errored-frame-seconds window
oam errored-symbol-period threshold
oam errored-symbol-period window
oam global errored-frame threshold
oam global errored-frame window
oam global errored-frame-period threshold
oam global errored-frame-period window
oam global errored-frame-seconds threshold
oam global errored-frame-seconds window
oam global errored-symbol-period threshold
oam global errored-symbol-period window
oam remote-loopback reject-request
display oam
Use display oam to display the information about an Ethernet OAM connection, including connection status, information contained in Ethernet OAM packet header, and Ethernet OAM packet statistics.
display oam { local | remote } [ interface interface-type interface-number ]
local: Displays the Ethernet OAM connection information of the local end.
remote: Displays the Ethernet OAM connection information of the remote end.
interface interface-type interface-number: Specifies a port by its type and number.
If you do not specify the interface keyword, the command displays information about all the Ethernet OAM connections.
# Display information about the Ethernet OAM connection established on all local ports.
<Sysname> display oam local
----------- [GigabitEthernet2/1/1] -----------
Enable status : Enable
Loopback status : No loopback
Link status : UP
OAM mode : Active
PDU : ANY
Mux action : FWD
Par action : FWD
# Display information about the Ethernet OAM connection established on the local port GigabitEthernet 2/1/1.
<Sysname> display oam local interface gigabitethernet 2/1/1
Link status : UP
OAM mode : Active
PDU : ANY
Mux action : FWD
Par action : FWD
Flags
Link fault : Not occurred
Dying gasp : Not occurred
Critical event : Not occurred
Local evaluating : COMPLETE
Remote evaluating : COMPLETE
Packets statistics
Packet type Sent Received
OAMPDU 100 80
OAMInformation 64 60
OAMEventNotification 36 20
OAMUniqueEventNotification 36 10
OAMDuplicateEventNotification 0 10
GigabitEthernet2/1/1 |
Information on GigabitEthernet 2/1/1. |
Enable status |
Ethernet OAM state (enabled or disabled). |
Loopback status |
Ethernet OAM loopback state: · No loopback. · Remote loopback. · Local loopback. |
Link status |
Link state (UP or DOWN). |
OAM mode |
Local Ethernet OAM mode: · Active—The port operates in the active Ethernet OAM mode. · Passive—The port operates in the passive Ethernet OAM mode. |
PDU |
The way in which the local end processes Ethernet OAMPDUs: · RX_INFO—The port only receives Information OAMPDUs and does not send any Ethernet OAMPDUs. · LF_INFO—The port only sends the Information OAMPDUs without Information TLV triplets and with their link error flag bits being set. · INFO—The port sends and receives only Information OAMPDUs. · ANY—The port sends and receives Ethernet OAMPDUs of any type. |
Mux action |
Operating mode of the local transmitter: · FWD—The port can send any packets. · DISCARD—The port only sends Ethernet OAMPDUs. |
Par action |
Operating mode of the local receiver: · FWD—The port can receive any packets. · DISCARD—The port only receives Ethernet OAMPDUs. · LB—The local receiver is in loopback state. All the packets, other than Ethernet OAMPDUs, received on the local receiver are returned to their sources along their original routes. |
Flags |
Local flags inserted in the local flag fields of the Ethernet OAMPDUs sent. |
Link fault |
Indicates whether an Ethernet OAM link error is present. |
Dying gasp |
Indicates whether a fatal error is present. |
Critical event |
Indicates whether a critical error is present. |
Local evaluating |
Indicates whether the local-to-remote configuration negotiation is complete: · COMPLETE—The negotiation is completed. · NOTCOMPLETE—The negotiation is uncompleted. |
Remote evaluating |
Indicates whether the remote-to-local configuration negotiation is complete: · COMPLETE—The negotiation is completed. · NOTCOMPLETE—The negotiation is uncompleted. · RESERVED—The field is reserved and the negotiation is uncompleted. · UNSATISFIED—The remote end is not satisfied with the local configuration and the negotiation is uncompleted. |
Packets statistics |
Statistics about Ethernet OAMPDUs sent and received. |
OAMPDU |
Total number of the Ethernet OAMPDUs sent and received. |
OAMInformation |
Number of the Information OAMPDUs sent and received. |
OAMEventNotification |
Number of the Event notification OAMPDUs sent and received. |
OAMUniqueEventNotification |
Number of the unduplicated Event notification OAMPDUs sent or received uniquely. |
OAMDuplicateEventNotification |
Number of the duplicate Event notification OAMPDUs sent or received. |
# Display the Ethernet OAM information about all remote ports.
<Sysname> display oam remote
OAM mode : Active
MAC address : 3822-d6a2-a800
MTU size : 1500
Mux action : FWD
Par action : FWD
# Display the Ethernet OAM information about the peer port GigabitEthernet 2/1/1.
<Sysname> display oam remote interface gigabitethernet 2/1/1
OAM mode : Active
MTU size : 1500
Mux action : FWD
Par action : FWD
Configuration
Unidirectional : Not supported
Remote loopback : Supported
Link events : Supported
MIB retrieval : Not supported
Flags
OAM mode |
MAC address |
MAC address of the remote end. |
MTU size |
MTU size, in bytes. |
Mux action |
Operating mode of the remote transmitter: · FWD—The port can send any packets. · DISCARD—The port only sends Ethernet OAMPDUs. |
Par action |
Operating mode of the remote receiver: · FWD—The port can receive any packets. · DISCARD—The port only receives Ethernet OAMPDUs. · LB—The local receiver is in loopback state. All the packets, other than Ethernet OAMPDUs, received on the local receiver are returned to their sources along their original routes. |
Configuration |
Configuration of the remote Ethernet OAM entity. |
Unidirectional |
Indicates whether unidirectional transmission is supported. |
Remote loopback |
Indicates whether Ethernet OAM remote loopback is supported. |
Link events |
Indicates whether Ethernet OAM link error events are supported. |
MIB retrieval |
Indicates whether MIB variable retrieval is supported. |
Flags |
Values of the peer Ethernet OAM flag fields in OAM packets. |
Link fault |
Dying gasp |
Critical event |
Local evaluating |
Indicates whether the local-to-remote configuration negotiation is complete: · COMPLETE—The negotiation is completed. · NOTCOMPLETE—The negotiation is uncompleted. · RESERVED—The field is reserved and the negotiation is uncompleted. · UNSATISFIED—The remote end is not satisfied with the local configuration and the negotiation is uncompleted. |
Remote evaluating |
Indicates whether the remote-to-local configuration negotiation is complete: · COMPLETE—The negotiation is completed. · NOTCOMPLETE—The negotiation is uncompleted. · UNSATISFIED—The remote end is not satisfied with the local configuration and the negotiation is uncompleted. |
reset oam
display oam configuration
Use display oam configuration to display global Ethernet OAM configuration on the specified port, including the periods and thresholds for Ethernet OAM link error event detection.
display oam configuration [ interface interface-type interface-number ]
If you do not specify the interface keyword, the command displays Ethernet OAM configuration globally and on ports that do not use the default configuration.
# Display Ethernet OAM configuration globally and on ports that do not use the default configuration.
<Sysname> display oam configuration
---------------- [Global] ----------------
OAM timers
Hello timer : 1000 milliseconds
Keepalive timer : 5000 milliseconds
Link monitoring
Errored symbol period
Window : 100 x 1000000 symbols
Threshold : 1 error symbols
Errored frame
Window : 10 x 100 milliseconds
Threshold : 1 error frames
Errored frame period
Window : 1000 x 10000 frames
Errored frame seconds
Window : 600 x 100 milliseconds
Threshold : 1 error seconds
OAM timers
Hello timer : 500 milliseconds
Link monitoring
Errored frame
Global |
Global information. |
OAM timers |
Ethernet OAM connection detection timers. |
Hello timer |
Ethernet OAM handshake packet transmission interval. |
Keepalive timer |
Ethernet OAM connection timeout timer. |
Link monitoring |
Link event detection window and threshold. |
Errored symbol period |
Errored symbol event. |
Errored frame |
Errored frame event. |
Errored frame period |
Errored frame period event. |
Errored frame seconds |
Errored frame seconds event. |
Window |
Detection window configured for link events. |
Threshold |
Triggering threshold configured for link events. |
display oam critical-event
Use display oam critical-event to display the statistics for critical Ethernet OAM link events that occurred on a port.
display oam critical-event [ interface interface-type interface-number ]
If you do not specify the interface keyword, the command displays the statistics for the critical Ethernet OAM link events that occurred on all the ports of the switch.
# Display the statistics for critical Ethernet OAM link events that occurred on all the ports.
<Sysname> display oam critical-event
Local link status : UP
Event statistics
Local link status |
Local link status, up or down. |
Event statistics |
Statistics for critical Ethernet OAM link events. |
Link fault |
Indicates whether a link fault is present. |
Dying Gasp |
Indicates whether a fatal fault is present. |
Critical Event |
Indicates whether a critical fault is present. |
display oam link-event
Use display oam link-event to display the statistics for Ethernet OAM link error events that occurred on a local port or a peer port. Ethernet OAM link error events include errored symbol events, errored frame events, errored frame period events, and errored frame seconds events.
display oam link-event { local | remote } [ interface interface-type interface-number ]
local: Displays the statistics for the local Ethernet OAM link error events.
remote: Displays the statistics for the peer Ethernet OAM link error events.
If you do not specify the interface keyword, the command displays the statistics for the Ethernet OAM link error events that occurred on all the local/peer ports.
# Display the statistics for Ethernet OAM link error events that occurred on all the local ports.
<Sysname> display oam link-event local
Link status: UP
OAM local errored frame event
Event time stamp : 49582 x 100 milliseconds
Errored frame window : 10 x 100 milliseconds
Errored frame threshold : 1 error frames
Errored frame : 1 error frames
Error running total : 6 error frames
Event running total : 6 events
OAM local errored frame period event
Event time stamp : 16382 x 100 milliseconds
Errored frame period window : 10000000 frames
Errored frame period threshold : 1 error frames
Errored frame period : 1 error frames
Error running total : 5 error frames
Event running total : 5 events
OAM local errored frame seconds summary event
Event time stamp : 50022 x 100 milliseconds
Errored frame seconds window : 600 x 100 milliseconds
Errored frame seconds threshold : 1 error seconds
Errored frame seconds : 1 error seconds
Error running total : 1 error seconds
Event running total : 1 events
# Display Ethernet OAM link event statistics for the remote ends of all the ports.
<Sysname> display oam link-event remote
Link status: UP
OAM remote errored symbol event
Event time stamp : 35498 x 100 milliseconds
Errored symbol window : 100000000 symbols
Errored symbol threshold : 1 error symbols
Errored symbol : 1 error symbols
Error running total : 4 error symbols
Event running total : 4 events
OAM remote errored frame event
OAM remote errored frame period event
OAM remote errored frame seconds summary event
Table 5 Command output
Link status |
Link status, up or down. |
OAM remote errored symbol event |
Information about remote errored symbol events (available only when remote errored symbol events occur): · Event time stamp—Time when an errored symbol event occurred. · Errored symbol window—Errored symbol detection interval. · Errored symbol threshold—Errored threshold that triggers an errored symbol event. · Errored symbol—Number of detected errored symbols in the most recent errored symbol event. · Error running total—Total number of errored symbols. · Event running total—Total number of errored symbol events that have occurred. |
OAM local/remote errored frame event |
Information about local/remote end errored frame events (available only when local/remote end errored frame events occur): · Event time stamp—Time when an errored frame event occurred. · Errored frame window—Errored frame detection interval. · Errored frame threshold—Errored threshold that triggers an errored frame event. · Errored frame—Number of detected errored frames in the most recent errored frame event. · Error running total—Total number of errored frames. · Event running total—Total number of errored frame events that have occurred. |
OAM local/remote errored frame period event |
Information about local errored frame period events (available only when local/remote errored frame period events occur): · Event time stamp—Time when an errored frame period event occurred. · Errored frame period window—Errored frame period detection interval. · Errored frame period threshold—Errored threshold that triggers an errored frame period event. · Errored frame period—Number of detected errored frames in the most recent errored frame period event. · Error running total—Total number of errored frames that have detected. · Event running total—Total number of errored frame period events. |
OAM local/remote errored frame seconds summary event |
Information about local/remote end errored frame seconds events (available only when local/remote end errored frame seconds events occur): · Event time stamp—Time when an errored frame seconds event occurred. · Errored frame second window—Errored frame second detection interval. · Errored Frame seconds threshold—Errored threshold that triggers an errored frame seconds event. · Errored frame seconds—Number of detected errored frame seconds in the most recent errored frame seconds event. · Error running total—Total number of errored frame seconds. · Event running total—Total number of errored frame seconds events that have occurred. |
reset oam
oam enable
Use oam enable to enable Ethernet OAM.
Use undo oam enable to disable Ethernet OAM.
oam enable
undo oam enable
Ethernet OAM is disabled.
Layer 2 Ethernet port view
Layer 3 Ethernet port view
# Enable OAM on GigabitEthernet 2/1/1.
[Sysname] interface gigabitethernet 2/1/1
[Sysname-GigabitEthernet2/1/1] oam enable
oam errored-frame threshold
Use oam errored-frame threshold to set the errored frame event triggering threshold for a port.
Use undo oam errored-frame threshold to restore the default.
oam errored-frame threshold threshold-value
The port uses the global setting.
threshold-value: Specifies the errored frame event triggering threshold in number of errored frame seconds, in the range of 0 to 4294967295.
The configuration in port view takes effect on the specified port. For a port, the configuration in port view takes precedence.
# Set the errored frame event triggering threshold to 100.
[Sysname-GigabitEthernet2/1/1] oam errored-frame threshold 100
oam errored-frame window
Use oam errored-frame window to set the errored frame event detection window.
Use undo oam errored-frame window to restore the default.
oam errored-frame window window-value
window-value: Specifies the errored frame event detection window in the range of 10 to 600 and in steps of 10 (in 100 milliseconds).
# Set the errored frame event detection window on GigabitEthernet 2/1/1 to 2000 milliseconds.
[Sysname-GigabitEthernet2/1/1] oam errored-frame window 20
Use oam errored-frame-period threshold to set the errored frame period event triggering threshold on a port.
Use undo oam errored-frame-period threshold to restore the default.
oam errored-frame-period threshold threshold-value
threshold-value: Specifies the errored frame period event triggering threshold in the range of 0 to 4294967295.
# Set the errored frame period event triggering threshold on GigabitEthernet 2/1/1 to 100.
[Sysname-GigabitEthernet2/1/1] oam errored-frame-period threshold 100
Use oam errored-frame-period window to set the errored frame period event detection window.
Use undo oam errored-frame-period window to restore the default.
oam errored-frame-period window window-value
window-value: Specifies the errored frame period event detection window in the range of 1 to 65535. The value of this argument must be a multiple of 10000.
# Set the errored frame period event detection window to 20000000.
[Sysname-GigabitEthernet2/1/1] oam errored-frame-period window 2000
Use oam errored-frame-seconds threshold to set the errored frame seconds event triggering threshold on a port.
Use undo oam errored-frame-seconds threshold to restore the default.
oam errored-frame-seconds threshold threshold-value
threshold-value: Specifies the errored frame seconds event triggering threshold in the range of 0 to 900.
The value of the errored frame seconds event triggering threshold cannot be greater than the value of the errored frame seconds event detection window (in seconds). Otherwise, errored frame seconds events cannot be generated.
# Set the errored frame seconds event triggering threshold on GigabitEthernet 2/1/1 to 100.
[Sysname-GigabitEthernet2/1/1] oam errored-frame-seconds threshold 100
Use oam errored-frame-seconds window to set the errored frame seconds event detection window.
Use undo oam errored-frame-seconds window to restore the default.
oam errored-frame-seconds window window-value
window-value: Specifies the errored frame seconds event detection window in the range of 100 to 9000 and in steps of 10 (in 100 milliseconds).
# Set the errored frame seconds event detection window to 10000 milliseconds.
[Sysname-GigabitEthernet2/1/1] oam errored-frame-seconds window 100
oam errored-frame-seconds period
Use oam errored-symbol-period threshold to set the errored symbol event triggering threshold.
Use undo oam errored-symbol-period threshold to restore the default.
oam errored-symbol-period threshold threshold-value
threshold-value: Specifies the errored symbol event triggering threshold in the range of 0 to 4294967295.
# Set the errored symbol event triggering threshold to 100.
[Sysname-GigabitEthernet2/1/1] oam errored-symbol-period threshold 100
Use oam errored-symbol-period window to set the errored symbol event detection window.
Use undo oam errored-symbol-period window to restore the default.
oam errored-symbol-period window window-value
window-value: Specifies the errored symbol event detection window in the range of 1 to 65535. The value of this argument must be a multiple of 1000000.
# Set the errored symbol event detection window on GigabitEthernet 2/1/1 to 200000000.
[Sysname-GigabitEthernet2/1/1] oam errored-symbol-period window 200
Use oam global errored-frame threshold to set the global errored frame event triggering threshold.
Use undo oam global errored-frame threshold to restore the default.
oam global errored-frame threshold threshold-value
The errored frame event triggering threshold is 1.
threshold-value: Specifies the errored frame event triggering threshold in the range of 0 to 4294967295.
The configuration in system view takes effect on all ports, but has a lower precedence than the configuration in port view.
[Sysname] oam global errored-frame threshold 100
Use oam global errored-frame window to set the global errored frame event detection window.
Use undo oam global errored-frame window to restore the default.
oam global errored-frame window window-value
The global errored frame event detection window is 1000 milliseconds.
# Set the errored frame event detection window to 2000 milliseconds.
[Sysname] oam global errored-frame window 20
Use oam global errored-frame-period threshold to set the global errored frame period event triggering threshold.
Use undo oam global errored-frame-period threshold to restore the default.
oam global errored-frame-period threshold threshold-value
The errored frame period event triggering threshold is 1.
# Set the errored frame period event triggering threshold to 100.
[Sysname] oam global errored-frame-period threshold 100
Use oam global errored-frame-period window to set the global errored frame period event detection window.
Use undo oam global errored-frame-period window to restore the default.
oam global errored-frame-period window window-value
The global errored frame period event detection window is 10000000.
[Sysname] oam global errored-frame-period window 2000
Use oam global errored-frame-seconds threshold to set the global errored frame seconds event triggering threshold.
Use undo oam global errored-frame-seconds threshold to restore the default.
oam global errored-frame-seconds threshold threshold-value
The global errored frame seconds event detection interval is 1.
# Set the errored frame seconds event triggering threshold to 100.
[Sysname] oam global errored-frame-seconds threshold 100
Use oam global errored-frame-seconds window to set the global errored frame seconds event detection window.
Use undo oam global errored-frame-seconds window to restore the default.
oam global errored-frame-seconds window window-value
The global errored frame seconds event detection window is 60000 milliseconds.
[Sysname] oam global errored-frame-seconds window 100
Use oam global errored-symbol-period threshold to set the global errored symbol event triggering threshold.
Use undo oam global errored-symbol-period threshold to restore the default.
oam global errored-symbol-period threshold threshold-value
The global errored symbol event triggering threshold is 1.
[Sysname] oam global errored-symbol-period threshold 100
Use oam global errored-symbol-period window to set the global errored symbol event detection window.
Use undo oam global errored-symbol-period window to restore the default.
oam global errored-symbol-period window window-value
The global errored symbol event detection window is 100000000.
# Set the errored symbol event detection window to 200000000.
[Sysname] oam global errored-symbol-period window 200
oam global timer hello
Use oam global timer hello to configure the global Ethernet OAM handshake packet transmission interval.
Use undo oam global timer hello to restore the default.
oam global timer hello interval
The global Ethernet OAM handshake packet transmission interval is 1000 milliseconds.
interval: Specifies the Ethernet OAM handshake packet transmission interval, in steps of 100 (in milliseconds). The value range for this argument is 500 to 5000.
After the timeout timer of an Ethernet OAM connection expires, the local OAM entity ages out and terminates its connection with the peer OAM entity. To keep the Ethernet OAM connections stable, set the connection timeout timer to be a minimum of five times the handshake packet transmission interval.
# Set the Ethernet OAM handshake packet transmission interval to 600 milliseconds.
[Sysname] oam global timer hello 600
oam timer hello
oam global timer keepalive
Use oam global timer keepalive to configure the global Ethernet OAM connection timeout timer.
Use undo oam global timer keepalive to restore the default.
oam global timer keepalive interval
The global Ethernet OAM connection timeout timer is 5000 milliseconds.
interval: Specifies the Ethernet OAM connection timeout timer, in steps of 100 (in milliseconds). The value range for this argument is 1000 to 25000.
After the timeout timer of an Ethernet OAM connection expires, the local OAM entity ages out and terminates its connection with the peer OAM entity. To keep the Ethernet OAM connections stable, set the connection timeout timer to be a minimum of five times the handshake packet transmission interval.,
# Set the Ethernet OAM connection timeout timer to 6000 milliseconds.
[Sysname] oam global timer keepalive 6000
oam timer keepalive
oam mode
Use oam mode to set the Ethernet OAM mode.
Use undo oam mode to restore the default.
oam mode { active | passive }
undo oam mode
An Ethernet OAM-enabled Ethernet port operates in the active Ethernet OAM mode.
active: Specifies the active Ethernet OAM mode.
passive: Specifies the passive Ethernet OAM mode.
To change the Ethernet OAM mode of an Ethernet OAM-enabled Ethernet port, first disable Ethernet OAM on the port.
# Disable Ethernet OAM on GigabitEthernet 2/1/1, and then configure GigabitEthernet 2/1/1 to operate in passive Ethernet OAM mode.
[Sysname-GigabitEthernet2/1/1] undo oam enable
[Sysname-GigabitEthernet2/1/1] oam mode passive
oam enable
oam remote-failure action
Use oam remote-failure action to configure the action the port takes after it receives an Ethernet OAM event from the remote end.
Use undo oam remote-failure action to remove the configuration.
oam remote-failure { connection-expired | critical-event | dying-gasp | link-fault } action error-link-down
undo oam remote-failure { connection-expired | critical-event | dying-gasp | link-fault } action error-link-down
The port only logs the Ethernet OAM event it receives from the remote end.
connection-expired: Specifies a connection timeout fault.
critical-event: Specifies a critical fault.
dying-gasp: Specifies a fatal fault.
link-fault: Specifies a link fault.
error-link-down: Terminates the OAM connection, and sets the link state of the port to down.
# Configure GigabitEthernet 2/1/1 to terminate the OAM connection after it receives a fatal fault from the remote end, and set the link state of the port to down.
[Sysname-GigabitEthernet2/1/1] oam remote-failure dying-gasp action error-link-down
oam remote-loopback
Use oam remote-loopback start to enable Ethernet OAM remote loopback on the specified Ethernet port.
Use oam remote-loopback stop to disable Ethernet OAM remote loopback on the Ethernet port.
Ethernet OAM remote loopback is disabled on the Ethernet port.
Ethernet OAM remote loopback is available only after the Ethernet OAM connection is established. It can be performed only by the Ethernet OAM entities operating in active Ethernet OAM mode.
You can enable Ethernet OAM remote loopback on a specified port in user view or system view. You can also enable it on the current port in port view. The configurations have the same effect.
# Configure the active Ethernet OAM mode and enable Ethernet OAM on GigabitEthernet 2/1/1. Enable Ethernet OAM remote loopback on GigabitEthernet 2/1/1 in Layer 2 Ethernet port view.
[Sysname-GigabitEthernet2/1/1] oam mode active
[Sysname-GigabitEthernet2/1/1] oam remote-loopback start
oam enable
oam mode
oam remote-loopback interface
Use oam remote-loopback start interface to enable Ethernet OAM remote loopback on an Ethernet port.
Use oam remote-loopback stop interface to disable Ethernet OAM remote loopback on an Ethernet port.
oam remote-loopback start interface interface-type interface-number
oam remote-loopback stop interface interface-type interface-number
Ethernet OAM remote loopback is disabled on an Ethernet port.
# Configure the active Ethernet OAM mode and enable Ethernet OAM on GigabitEthernet 2/1/1. Enable Ethernet OAM remote loopback on GigabitEthernet 2/1/1 in system view.
[Sysname-GigabitEthernet2/1/1] quit
[Sysname] oam remote-loopback start interface gigabitethernet 2/1/1
oam enable
oam mode
oam remote-loopback
Use oam remote-loopback reject-request to configure a port to reject the Ethernet OAM remote loopback request from a remote port.
Use undo oam remote-loopback reject-request to restore the default.
A port does not reject the Ethernet OAM remote loopback request from a remote port.
If a port is in loopback state when you execute the oam remote-loopback reject-request command, the configuration takes effect when the next loopback starts.
# Configure GigabitEthernet 2/1/1 to reject the Ethernet OAM remote loopback request from a remote port.
[Sysname-GigabitEthernet2/1/1] oam remote-loopback reject-request
oam timer hello
Use oam timer hello to configure the Ethernet OAM handshake packet transmission interval.
Use undo oam timer hello to restore the default.
oam timer hello interval
After the timeout timer of an Ethernet OAM connection expires, the local OAM entity ages out and terminates its connection with the peer OAM entity. To keep the Ethernet OAM connections stable, set the connection timeout timer to be a minimum of five times the handshake packet transmission interval..
[Sysname-GigabitEthernet2/1/1] oam timer hello 600
oam timer keepalive
Use oam timer keepalive to configure the Ethernet OAM connection timeout timer.
Use undo oam timer keepalive to restore the default.
oam timer keepalive interval
After the timeout timer of an Ethernet OAM connection expires, the local OAM entity ages out and terminates its connection with the peer OAM entity. To keep the Ethernet OAM connections stable, set the connection timeout timer to be at least five times the handshake packet transmission interval.
[Sysname-GigabitEthernet2/1/1] oam timer keepalive 6000
reset oam
Use reset oam to clear the statistics for Ethernet OAM packets and Ethernet OAM link error events for an Ethernet port.
reset oam [ interface interface-type interface-number ]
If you do not specify the interface keyword, the command clears the statistics for Ethernet OAM packets and Ethernet OAM link error events for all the ports.
# Clear the statistics for Ethernet OAM packets and Ethernet OAM link error events for all the ports.
<Sysname> reset oam
display oam
