- 11-Security Command Reference
- 01-AAA commands
- 02-Portal commands
- 03-User profile commands
- 04-Password control commands
- 05-Keychain commands
- 06-Public key management commands
- 07-PKI commands
- 08-IPsec commands
- 09-Group domain VPN commands
- 10-SSH commands
- 11-SSL commands
- 12-SSL VPN commands
- 13-ASPF commands
- 14-APR commands
- 15-Session management commands
- 16-Connection limit commands
- 17-Object group commands
- 18-Object policy commands
- 19-Attack detection and prevention commands
- 20-ARP attack protection commands
- 21-ND attack defense commands
- 22-uRPF commands
- 23-Crypto engine commands
- 24-FIPS commands
- 25-SMA commands
| 15-Session management commands | 183.35 KB |
display session aging-time application
display session aging-time state
display session relation-table
display session statistics ipv4
display session statistics ipv6
display session statistics multicast
display session table multicast ipv4·
display session table multicast ipv6·
display session top-statistics
reset session statistics multicast
reset session table multicast ipv4
reset session table multicast ipv6
session log { bytes-active | packets-active }
session state-machine mode loose
Use display session aging-time application to display the aging time for sessions of different application layer protocols or applications.
# Display the aging time for sessions of different application layer protocols and applications.
<Sysname> display session aging-time application
Application Aging time(s)
bootpc 120
bootps 120
dns 1
ftp 3600
ftp-data 240
gprs-data 60
gprs-sig 60
gtp-control 60
gtp-user 60
h225 3600
h245 3600
https 600
ils 3600
l2tp 120
mgcp-callagent 60
mgcp-gateway 60
netbios-dgm 3600
netbios-ns 3600
netbios-ssn 3600
ntp 120
pptp 3600
qq 120
ras 300
rip 120
rsh 60
rtsp 3600
sccp 3600
sip 300
snmp 120
snmptrap 120
sqlnet 600
stun 600
syslog 120
tacacs-ds 120
tftp 60
who 120
xdmcp 3600
others: 1200
Application |
Name of an application layer protocol or an application. |
Aging time(s) |
Aging time in seconds. |
others:1200 |
All application layer protocols and applications whose aging time is 1200 seconds is displayed as others. |
Use display session aging-time stat to display the aging time for sessions in different protocol states.
# Display the aging time for sessions in different protocol states.
<Sysname> display session aging-time state
State Aging Time(s)
SYN 10
TCP-EST 3600
FIN 10
UDP-OPEN 10
UDP-READY 30
ICMP-REQUEST 30
ICMP-REPLY 10
RAWIP-OPEN 30
RAWIP-READY 60
UDPLITE-OPEN 30
UDPLITE-READY 60
DCCP-REQUEST 30
DCCP-EST 3600
DCCP-CLOSEREQ 30
SCTP-INIT 30
SCTP-EST 3600
SCTP-SHUTDOWN 30
ICMPV6-REQUEST 60
ICMPV6-REPLY 30
TCP-TIME-WAIT 2
TCP-CLOSE 2
State |
Protocol state. |
Aging Time(s) |
Use display session relation-table to display relation entries.
In standalone mode:
display session relation-table { ipv4 | ipv6 } [ slot slot-number ]
In IRF mode:
display session relation-table { ipv4 | ipv6 } [ chassis chassis-number slot slot-number ]
ipv4: Specifies IPv4 relation entries.
ipv6: Specifies IPv6 relation entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays relation entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays relation entries for all cards. (In IRF mode.)
# (In standalone mode.) Display all IPv4 relation entries.
<Sysname> display session relation-table ipv4
Slot 1:
Source IP/port: 192.168.1.100/-
Destination IP/port: 192.168.2.100/99
DS-Lite tunnel peer: -
VPN instance/VLAN ID/Inline ID: 1/-/-
Protocol: TCP(6) TTL: 1234s App: FTP-DATA
Source IP/port: -/-
Destination IP/port: 192.168.2.200/1212
Protocol: TCP(6) TTL: 3100s App: H225
Total entries found: 2
# (In standalone mode.) Display all IPv6 relation entries.
<Sysname> display session relation-table ipv6
Slot 1:
Source IP: 2011::0002
Destination IP/port: 2011::0008/1212
Protocol: TCP(6) TTL: 567s App: FTP-DATA
Total entries found: 1
Slot 1:
Source IP/port: -/-
Slot 1:
Source IP/port |
Source IP address and port number of the session. If the IP or port number is not specified, this field displays a hyphen (-). For an IPv6 relation entry, the source port number is not displayed. |
Destination IP/port |
Destination IP address and port number of the session. |
DS-Lite tunnel peer |
Peer tunnel interface address of the DS-Lite tunnel to which the session belongs. If no peer tunnel interface address is specified, a hyphen (-) is displayed. |
VPN instance/VLAN ID/Inline ID |
MPLS L3VPN instance to which the relation entry belongs. VLAN and inline to which the relation entry belongs during Layer 2 forwarding. If a parameter is not specified, a hyphen (-) is displayed for the proper field. |
Protocol |
Transport layer protocol. |
TTL |
Remaining lifetime of the relation entry, in seconds. |
App |
Application layer protocol. |
Total entries found |
Total number of found relation entries. |
Use display session statistics ipv4 to display IPv4 unicast session statistics.
In standalone mode:
display session statistics ipv4 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ slot slot-number ]
In IRF mode:
display session statistics ipv4 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ chassis chassis-number slot slot-number ]
source-ip source-ip: Specifies a source IPv4 address for a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address for a unicast session from the initiator to the responder.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol, including DCCP, ICMP, RawIP, SCTP, TCP, UDP, and UDP-Lite.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of an IPv4 unicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of an IPv6 unicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv4 unicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv4 unicast session statistics for all cards. (In IRF mode.)
# Display statistics for unicast sessions from IP address 111.15.111.66.
<Sysname> display session statistics ipv4 source-ip 111.15.111.66
Slot 1:
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMP sessions: 3
ICMPv6 sessions: 0
UDP-Lite sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
# Display statistics for IPv4 unicast TCP sessions.
<Sysname> display session statistics ipv4 protocol tcp
Slot 1:
Current sessions: 3
TCP sessions: 3
UDP sessions: 0
ICMP sessions: 0
ICMPv6 sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
Current sessions |
Total number of unicast sessions. |
TCP sessions |
Number of TCP unicast sessions and number of TCP unicast sessions in different states. |
UDP sessions |
Number of UDP unicast sessions and number of UDP unicast sessions in different states. |
ICMP sessions |
Number of ICMP unicast sessions and number of ICMP unicast sessions in different states. |
ICMPv6 sessions |
Number of ICMPv6 unicast sessions and number of ICMPv6 unicast sessions in different states. |
UDP-Lite sessions |
Number of UDP-Lite unicast sessions and number of UDP-Lite unicast sessions in different states. |
SCTP sessions |
Number of SCTP unicast sessions and number of SCTP unicast sessions in different states. |
DCCP sessions |
Number of DCCP unicast sessions and number of DCCP unicast sessions in different states. |
RAWIP sessions |
Number of Raw IP unicast sessions and number of Raw IP unicast sessions in different states. |
Use display session statistics ipv6 to display IPv6 unicast session statistics.
In standalone mode:
display session statistics ipv6 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ slot slot-number ]
In IRF mode:
display session statistics ipv6 { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * [ chassis chassis-number slot slot-number ]
source-ip source-ip: Specifies a source IPv6 address for a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address for a unicast session from the initiator to the responder.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol, including DCCP, ICMPv6, RawIP, SCTP, TCP, UDP, and UDP-Lite.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of an IPv6 unicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 unicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 unicast session statistics for all cards. (In IRF mode.)
# Display statistics for unicast sessions from IPv6 address 100::2.
<Sysname> display session statistics ipv6 source-ip 100::2
Slot 1:
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMP sessions: 3
ICMPv6 sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
# Display statistics for IPv6 unicast TCP sessions.
<Sysname> display session statistics ipv6 protocol tcp
Slot 1:
Current sessions: 3
TCP sessions: 3
UDP sessions: 0
ICMP sessions: 0
ICMPv6 sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
Table 5 Command output
Current sessions |
TCP sessions |
UDP sessions |
ICMP sessions |
ICMPv6 sessions |
UDP-Lite sessions |
SCTP sessions |
DCCP sessions |
RAWIP sessions |
Use display session statistic multicast to display multicast session statistics.
In standalone mode:
display session statistics multicast [ slot slot-number ]
In IRF mode:
display session statistics multicast [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays multicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays multicast session statistics for all cards. (In IRF mode.)
# (In standalone mode.) Display information about multicast session statistics.
<Sysname> display session statistics multicast
Slot 0:
Current sessions: 0
Session establishment rate: 0/s
Received: 0 packets 0 bytes
Sent : 0 packets 0 bytes
Slot 1:
Current sessions: 0
# (In IRF mode.) Display information about multicast session statistics.
Slot 0 in chassis 1:
Current sessions: 0
Slot 1 in chassis 1:
Current sessions: 0
Slot 2 in chassis 1:
Current sessions: 0
Table 6 Command output
Current sessions |
Total number of multicast sessions. |
Session establishment rate |
Rate of multicast session creation. |
Received |
Number of received multicast packets and bytes. |
Sent |
Number of sent multicast packets and bytes. |
Use display session statistics to display unicast session statistics.
In standalone mode:
display session statistics [ summary ] [ slot slot-number ]
In IRF mode:
display session statistics [ summary ] [ chassis chassis-number slot slot-number ]
summary: Displays summary information about unicast session statistics. If you do not specify this keyword, the command displays detailed information about unicast session statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays unicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays unicast session statistics for all cards. (In IRF mode.)
# Display detailed information about unicast session statistics.
Current sessions: 3
TCP sessions: 0
UDP sessions: 0
ICMP sessions: 3
ICMPv6 sessions: 0
SCTP sessions: 0
DCCP sessions: 0
RAWIP sessions: 0
History average sessions per second:
Past hour: 1
Past 24 hours: 0
Past 30 days: 0
History average session establishment rate:
Past hour: 0/s
Past 24 hours: 0/s
Past 30 days: 0/s
Current relation-table entries: 0
TCP: 0/s
UDP: 0/s
ICMP: 0/s
ICMPv6: 0/s
UDP-Lite: 0/s
SCTP: 0/s
DCCP: 0/s
RAWIP: 0/s
Received TCP : 0 packets 0 bytes
Received UDP : 118 packets 13568 bytes
Received ICMP : 105 packets 8652 bytes
Received ICMPv6 : 0 packets 0 bytes
Received UDP-Lite : 0 packets 0 bytes
Received SCTP : 0 packets 0 bytes
Received DCCP : 0 packets 0 bytes
Received RAWIP : 0 packets 0 bytes
Table 7 Command output
Current sessions |
TCP sessions |
Number of TCP sessions and number of TCP sessions in different states. |
UDP sessions |
Number of UDP sessions and number of UDP sessions in different states. |
ICMP sessions |
Number of ICMP sessions and number of ICMP sessions in different states. |
ICMPv6 sessions |
Number of ICMPv6 sessions and number of ICMPv6 sessions in different states. |
UDP-Lite sessions |
Number of UDP-Lite sessions and number of UDP-Lite sessions in different states. |
SCTP sessions |
Number of SCTP sessions and number of SCTP sessions in different states. |
DCCP sessions |
Number of DCCP sessions and number of DCCP sessions in different states. |
RAWIP sessions |
Number of Raw IP sessions and number of Raw IP sessions in different states. |
History statistics of average sessions per second. |
The average number of sessions per second in the most recent hour. |
The average number of sessions per second in the most recent 24 hours. |
The average number of sessions per second in the most recent 30 days. |
History statistics of average session establishment rates. |
The average session establishment rate in the most recent hour. |
The average session establishment rate in the most recent 24 hours. |
The average session establishment rate in the most recent 30 days. |
Current relation-table entries |
Total number of relation entries. |
Unicast session establishment rate, and rates for establishing unicast sessions of different protocols. |
Received TCP |
Number of received TCP packets and bytes. |
Received UDP |
Number of received UDP packets and bytes. |
Received ICMP |
Number of received ICMP packets and bytes. |
Received ICMPv6 |
Number of received ICMPv6 packets and bytes. |
Received UDP-Lite |
Number of received UDP-Lite packets and bytes. |
Received SCTP |
Number of received SCTP packets and bytes. |
Received DCCP |
Number of received DCCP packets and bytes. |
Received RAWIP |
Number of received Raw IP packets and bytes. |
# (In standalone mode.) Display summary information about unicast session statistics.
<Sysname> display session statistics summary
Slot Sessions TCP UDP Rate TCP rate UDP rate
2 3 0 0 0/s 0/s 0/s
# (In IRF mode.) Display summary information about unicast session statistics.
Chassis Slot Sessions TCP UDP Rate TCP rate UDP rate
1 2 3 0 0 0/s 0/s 0/s
Table 8 Command output
Chassis |
IRF member ID. This field is available in IRF mode. |
Slot |
Card number. This field is available in standalone mode. |
Sessions |
TCP |
Number of TCP unicast sessions. |
UDP |
Number of UDP unicast sessions. |
Rate |
Rate of unicast session creation. |
TCP rate |
Rate of TCP unicast session creation. |
UDP rate |
Rate of UDP unicast session creation. |
display session table ipv4
Use display session table ipv4 to display information about IPv4 unicast session entries that match specific criteria.
In standalone mode:
In IRF mode:
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards. (In IRF mode.)
responder: Displays entries of IPv4 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 unicast sessions from the initiator to the responder.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a unicast session. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a unicast session. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session. The value range for the destination-port argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
verbose: Displays detailed information about IPv4 unicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 unicast session entries.
If you do not specify any parameters, this command displays all IPv4 unicast session entries.
# (In standalone mode.) Display brief information about all IPv4 unicast session entries.
<Sysname> display session table ipv4
Slot 1:
Initiator:
Source IP/port: 192.168.1.18/1877
Destination IP/port: 192.168.1.55/22
Protocol: TCP(6)
Inbound interface: GigabitEthernet2/1/1
Source security zone: Trust
Initiator:
Source IP/port: 192.168.1.18/1792
Destination IP/port: 192.168.1.55/2048
Protocol: ICMP(1)
Total sessions found: 2
# (In standalone mode.) Display detailed information about all IPv4 unicast session entries.
<Sysname> display session table ipv4 verbose
Slot 1:
Initiator:
DS-Lite tunnel peer:-
Protocol: TCP(6)
Responder:
Source IP/port: 192.168.1.55/22
Destination IP/port: 192.168.1.18/1877
Protocol: TCP(6)
Inbound interface: GigabitEthernet2/1/2
Source security zone: Local
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36 TTL: 28s
Initiator->Responder: 1 packets 48 bytes
Responder->Initiator: 0 packets 0 bytes
Initiator:
Protocol: ICMP(1)
Responder:
Source IP/port: 192.168.1.55/1792
Destination IP/port: 192.168.1.18/0
Protocol: ICMP(1)
State: ICMP_REQUEST
Application: OTHER
Start time: 2011-07-29 19:12:33 TTL: 55s
Initiator->Responder: 1 packets 60 bytes
Slot 1:
Initiator:
Protocol: TCP(6)
Initiator:
Protocol: ICMP(1)
Slot 1:
Initiator:
Protocol: TCP(6)
Responder:
Protocol: TCP(6)
State: TCP_SYN_SENT
Application: SSH
Initiator:
Protocol: ICMP(1)
Responder:
Protocol: ICMP(1)
State: ICMP_REQUEST
Application: OTHER
Table 9 Command output
Initiator |
Information about the unicast session from the initiator to the responder. |
Responder |
Information about the unicast session from the responder to the initiator. |
Address of the DS-Lite tunnel peer. When the unicast session does not belong to any DS-Lite tunnel, this field displays a hyphen (-). |
MPLS L3VPN instance to which the unicast session belongs. VLAN and inline to which the session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Transport layer protocol: · DCCP. · ICMP. · ICMPv6. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
Source security zone |
Security zone to which the inbound interface belongs. If the inbound interface does not belong to any security zone, this field displays a hyphen (-). |
State |
Unicast session state. |
Application |
Application layer protocol, FTP or DNS. If it is an unknown protocol identified by an unknown port, this field displays OTHER. |
Start time |
Unicast session establishment time. |
TTL |
Remaining lifetime of the unicast session, in seconds. |
Initiator->Responder |
Number of packets and bytes from the initiator to the responder. |
Responder->Initiator |
Number of packets and bytes from the responder to the initiator. |
Total sessions found |
Total number of found unicast session entries. |
display session table ipv6
Use display session table ipv6 to display information about IPv6 unicast session entries that match specific criteria.
In standalone mode:
display session table ipv6 [ slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-name ] [ verbose ]
In IRF mode:
display session table ipv6 [ chassis chassis-number slot slot-number ] [ source-ip start-source-ip [ end-source-ip ] ] [ destination-ip start-destination-ip [ end-destination-ip ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-name ] [ verbose ]
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards. (In IRF mode.)
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv6 address or IPv6 address range for a unicast session from the initiator to the responder. The start source-ip argument specifies the start source IPv6 address. The end source-ip argument specifies the end source IPv6 address.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv6 address or IPv6 address range for a unicast session from the initiator to the responder. The start destination-ip argument specifies the start destination IPv6 address. The end destination-ip argument specifies the end destination IPv6 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
verbose: Displays detailed information about IPv6 unicast session entries. If you do not specify this keyword, the command displays brief information about IPv6 unicast session entries.
If you do not specify any parameters, this command displays all IPv6 unicast session entries.
# (In standalone mode.) Display brief information about all IPv6 unicast session entries.
<Sysname> display session table ipv6
Slot 1:
Initiator:
Source IP/port: 2011::2/58473
Destination IP/port: 2011::8/32768
Protocol: IPV6-ICMP(58)
Total sessions found: 1
# (In standalone mode.) Display detailed information about all IPv6 unicast session entries.
<Sysname> display session table ipv6 verbose
Slot 1:
Initiator:
Responder:
Source IP/port: 2011::8/58473
Destination IP/port: 2011::2/33024
State: ICMPV6_REQUEST
Application: OTHER
Start time: 2011-07-29 19:23:41 TTL: 55s
Initiator->Responder: 1 packets 104 bytes
Slot 1:
Initiator:
Slot 1:
Initiator:
Responder:
Application: OTHER
Table 10 Command output
Initiator |
Responder |
Address of the DS-Lite tunnel peer. When the unicast session is not tunneled by DS-Lite, this field displays a hyphen (-). |
MPLS L3VPN instance to which the unicast session belongs. VLAN and inline to which the unicast session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
State |
Application |
Start time |
TTL |
Use display session table multicast ipv4 to display information about IPv4 multicast session entries that match specific criteria.
In standalone mode:
In IRF mode:
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a multicast session from the initiator to the responder. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a multicast session from the initiator to the responder. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a multicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a multicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
verbose: Displays detailed information about IPv4 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 multicast session entries.
If you do not specify any parameters, this command displays all IPv4 multicast session entries.
# (In standalone mode.) Display detailed information about all IPv4 multicast session entries.
<Sysname> display session table multicast ipv4 verbose
Slot 0:
Total sessions found: 0
Slot 2:
Inbound initiator:
Source IP/port: 3.3.3.4/1609
Destination IP/port: 232.0.0.1/1025
Protocol: UDP(17)
Inbound responder:
Source IP/port: 232.0.0.1/1025
Destination IP/port: 3.3.3.4/1609
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 15:59:22 TTL: 18s
Initiator->Responder: 1 packets 84 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: GigabitEthernet2/1/2
Destination security zone: aaa
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Outbound interface: GigabitEthernet2/1/3
Destination security zone: bbb
State: UDP_OPEN
Application: OTHER
Total sessions found: 3
Table 11 Command output
Information about the multicast session from the initiator to the responder on the inbound interface. |
Information about the multicast session from the responder to the initiator on the inbound interface. |
Information about the multicast session from the initiator to the responder on the outbound interface. |
Information about the multicast session from the responder to the initiator on the outbound interface. |
Address of the DS-Lite tunnel peer. If the multicast session is not tunneled by DS-Lite, this field displays a hyphen (-). |
MPLS L3VPN instance to which the multicast session belongs. VLAN and inline to which the multicast session belongs during Layer 2 forwarding. If a parameter is not specified, a hyphens (-) is displayed for the proper field. |
Protocol |
Transport layer protocol: · DCCP. · ICMP. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
State |
Multicast session state. |
Application |
Start time |
Time when the multicast session was created. |
TTL |
Remaining lifetime of the multicast session, in seconds. |
Inbound interface of the first packet from the initiator to responder. |
Outbound interface of the first packet from the initiator to responder. |
Outbound interfaces of the first packet from the initiator to responder. |
Security zone to which the outbound interface belongs. If the outbound interface does not belong to any security zone, this field displays a hyphen (-). |
Total number of found multicast session entries. |
Use display session table multicast ipv6 to display information about IPv6 multicast session entries that match specific criteria.
In standalone mode:
In IRF mode:
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv6 address or IPv6 address range for a multicast session from the initiator to the responder. The start source-ip argument specifies the start source IPv6 address. The end source-ip argument specifies the end source IPv6 address.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv6 address or IPv6 address range for a multicast session from the initiator to the responder. The start destination-ip argument specifies the start destination IPv6 address. The end destination-ip argument specifies the end destination IPv6 address.
verbose: Displays detailed information about IPv6 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv6 multicast session entries.
If you do not specify any parameters, this command displays all IPv6 multicast session entries.
# (In standalone mode.) Display brief information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6
Slot 0:
Slot 2:
Inbound initiator:
Source IP/port: 3::4/1617
Destination IP/port: FF0E::1/1025
Protocol: UDP(17)
Outbound interface list:
# (In standalone mode.) Display detailed information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6 verbose
Slot 0:
Slot 2:
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Source IP/port: FF0E::1/1025
Destination IP/port: 3::4/1617
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 16:10:58 TTL: 23s
Initiator->Responder: 5 packets 520 bytes
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
Destination security zone: ccc
State: UDP_OPEN
Application: OTHER
# (In IRF mode.) Display detailed information about all IPv6 multicast session entries.
Inbound initiator:
Protocol: UDP(17)
Inbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Outbound initiator:
Protocol: UDP(17)
Outbound responder:
Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Table 12 Command output
Inbound initiator |
Inbound responder |
Outbound initiator |
Outbound responder |
Protocol |
Transport layer protocol: · DCCP. · ICMPv6. · Raw IP. · SCTP. · TCP. · UDP. · UDP-Lite. The number in the brackets indicates the protocol number. |
State |
Application |
Start time |
TTL |
Inbound interface |
Outbound interface |
Outbound interface list |
Destination security zone |
Use display session top-statistics to display top session statistics.
display session top-statistics { last-1-hour | last-24-hours | last-30-days }
last-1-hour: Displays top session statistics in last hour.
last-24-hours: Displays top session statistics in last 24 hours.
last-30-days: Displays top session statistics in last 30 days.
This command displays nothing if the top session statistics feature is not enabled. A maximum of ten session items can be displayed.
# Display top session statistics in last hour.
<Sysname> display session top-statistics last-1-hour
Counting by source addresses:
No. Source address Sessions
1 10.1.2.3 50004302
2 10.1.2.2 40123255
3 10.2.2.10 26664302
4 10.1.2.11 7123255
5 10.1.2.12 424302
6 10.1.2.13 253255
7 10.1.2.14 55302
8 10.1.2.15 50025
9 10.1.2.16 3555
10 10.1.2.1 995
Counting by destination addresses:
No. Destination address Sessions
1 20.1.2.3 50004302
2 20.1.2.2 40123255
3 20.2.2.10 26664302
4 20.1.2.11 7123255
5 20.1.2.12 424302
6 20.1.2.13 325325
7 20.1.2.14 55530
8 20.1.2.15 50025
9 20.1.2.16 3555
10 20.1.2.1 995
Table 13 Command output
Counting by source addresses |
Top session statistics based on source addresses. |
Counting by destination addresses |
Top session statistics based on destination addresses. |
No. |
Ranking number. |
Source address |
Source IP address of the sessions. |
Destination address |
Destination IP address of the sessions. |
Sessions |
Total number of sessions. |
session top-statistics enable
reset session relation-table
Use reset session relation-table to clear relation entries.
In standalone mode:
reset session relation-table [ ipv4 | ipv6 ] [ slot slot-number ]
In IRF mode:
reset session relation-table [ ipv4 | ipv6 ] [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears relation entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears relation entries for all cards. (In IRF mode.)
If you do not specify the IPv4 keyword or the IPv6 keyword, this command clears all IPv4 and IPv6 relation entries.
# Clear all IPv4 relation entries.
<Sysname> reset session relation-table ipv4
Use reset session statistics to clear unicast session statistics.
In standalone mode:
reset session statistics [ slot slot-number ]
In IRF mode:
reset session statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears unicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears unicast session statistics for all cards. (In IRF mode.)
# Clear all unicast session statistics.
<Sysname> reset session statistics
Use reset session statistics multicast to clear multicast session statistics.
In standalone mode:
reset session statistics multicast [ slot slot-number ]
In IRF mode:
reset session statistics multicast [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears multicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears multicast session statistics for all cards. (In IRF mode.)
# Clear all multicast session statistics.
<Sysname> reset session statistics multicast
reset session table
Use reset session table to clear IPv4 and IPv6 unicast session entries.
In standalone mode:
reset session table [ slot slot-number ]
In IRF mode:
reset session table [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears unicast session entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears unicast session entries for all cards. (In IRF mode.)
# Clear all IPv4 and IPv6 unicast session entries.
<Sysname> reset session table
reset session table ipv4
Use reset session table ipv4 to clear information about IPv4 unicast session entries that match specific criteria.
In standalone mode:
reset session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
In IRF mode:
reset session table ipv4 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears information for all cards. (In IRF mode.)
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a unicast session from the initiator to the responder.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv4 unicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv4 unicast session entries on the public network.
# Clear all IPv4 unicast session entries.
<Sysname> reset session table ipv4
# Clear the IPv4 unicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table ipv4 source-ip 10.10.10.10
reset session table ipv6
Use reset session table ipv6 to clear information about IPv6 unicast session entries that match the specified criteria.
In standalone mode:
reset session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
In IRF mode:
reset session table ipv6 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
source-ip source-ip: Specifies a source IPv6 address. The source-ip argument specifies the source IPv6 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address. The destination-ip argument specifies the destination IPv6 address of a unicast session from the initiator to the responder.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol, including DCCP, ICMPv6, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv6 unicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv6 unicast session entries on the public network.
# Clear all IPv6 unicast session entries.
<Sysname> reset session table ipv6
# Clear the IPv6 unicast session entries with the source IP address of 2011::0002.
<Sysname> reset session table ipv6 source-ip 2011::0002
Use reset session table multicast to clear IPv4 and IPv6 multicast session entries.
In standalone mode:
reset session table multicast [ slot slot-number ]
In IRF mode:
reset session table multicast [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears multicast session entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears multicast session entries for all cards. (In IRF mode.)
# Clear all IPv4 and IPv6 multicast session entries.
<Sysname> reset session table multicast
Use reset session table multicast ipv4 to clear information about IPv4 multicast session entries that match specific criteria.
In standalone mode:
In IRF mode:
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a multicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a multicast session from the initiator to the responder.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv4 multicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv4 multicast session entries on the public network.
# Clear all IPv4 multicast session entries.
<Sysname> reset session table multicast ipv4
# Clear the IPv4 multicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table multicast ipv4 source-ip 10.10.10.10
Use reset session table multicast ipv6 to clear information about IPv6 multicast session entries that match specific criteria.
In standalone mode:
In IRF mode:
source-ip source-ip: Specifies a source IPv6 address. The source-ip argument specifies the source IPv6 address of a multicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address. The destination-ip argument specifies the destination IPv6 address of a multicast session from the initiator to the responder.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv6 multicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv6 multicast session entries on the public network.
# Clear all IPv6 multicast session entries.
<Sysname> reset session table multicast ipv6
# Clear the IPv6 multicast session entries with the source IP address of 2011::0002.
<Sysname> reset session table multicast ipv6 source-ip 2011::0002
Use session aging-time application to set the aging time for sessions of an application layer protocol or an application.
Use undo session aging-time application to restore the default. If you do not specify an application layer protocol or an application, this command restores the default aging time for all sessions of the supported application layer protocols and applications.
session aging-time application application-name time-value
undo session aging-time application [ application-name ]
The aging time is 1200 seconds for sessions of application layer protocols or applications except for the following sessions:
· BOOTPC sessions: 120 seconds.
· BOOTPS sessions: 120 seconds.
· DNS sessions: 1 second.
· FTP sessions: 3600 seconds.
· FTP-DATA sessions: 240 seconds.
· GTP-CONTROL sessions: 60 seconds.
· GTP-USER sessions: 60 seconds.
· GPRS-DATA sessions: 60 seconds.
· GPRS-SIG sessions: 60 seconds.
· H.225 sessions: 3600 seconds.
· H.245 sessions: 3600 seconds.
· HTTPS sessions: 600 seconds.
· ILS sessions: 3600 seconds.
· L2TP sessions: 120 seconds.
· MGCP-CALLAGENT sessions: 60 seconds.
· MGCP-GATEWAY sessions: 60 seconds.
· NETBIOS-DGM sessions: 3600 seconds.
· NETBIOS-NS sessions: 3600 seconds.
· NETBIOS-SSN sessions: 3600 seconds.
· NTP sessions: 120 seconds.
· PPTP sessions: 3600 seconds.
· QQ sessions: 120 seconds.
· RAS sessions: 300 seconds.
· RIP sessions: 120 seconds.
· RSH sessions: 60 seconds.
· SCCP sessions: 3600 seconds.
· SIP sessions: 300 seconds.
· SNMP sessions: 120 seconds.
· SNMPTRAP sessions: 120 seconds.
· SQLNET sessions: 600 seconds.
· STUN sessions: 600 seconds.
· SYSLOG sessions: 120 seconds.
· TFTP sessions: 60 seconds.
· TACACS-DS sessions: 120 seconds.
· WHO sessions: 120 seconds.
· XDMCP sessions: 3600 seconds.
application-name: Specifies an application layer protocol or an application by its name, a case-insensitive string of 1 to 63 characters. Valid characters can be digits, letters, hyphens (-), and underscores (_). The names invalid and other are not allowed. The application layer protocol or application must exist on the device.
time-value: Specifies the aging time in seconds. The value range 1 to 100000.
This command sets the aging time for stable sessions of the specified application layer protocol or applications. For TCP sessions, the stable state is ESTABLISHED. For UDP sessions, the stable state is READY.
For sessions of application layer protocols or applications that are not supported by this command, the aging time is set by the session aging-time state command. For persistent sessions, the aging time is set by the session persistent acl command.
Supported application layer protocols or applications specified in this command depend on the APR module. For information about APR, see Security Configuration Guide.
# Set the aging time for FTP sessions to 1800 seconds.
[Sysname] session aging-time application ftp 1800
# Set the aging time for 126WebEmail sessions to 1800 seconds.
[Sysname] session aging-time application 126WebEmail 1800
nbar application
port-mapping
port-mapping acl
port-mapping host
port-mapping subnet
Use session aging-time state to set the aging time for the sessions in a protocol state.
Use undo session aging-time state to restore the default for the sessions in a protocol state. If you do not specify a protocol state, this command restores all aging time for sessions in different protocol states to the default.
session aging-time state { fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready } time-value
undo session aging-time state [ fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready ]
The aging time for sessions in different protocol states is as follows:
· FIN_WAIT: 30 seconds.
· ICMP-REPLY: 30 seconds.
· ICMP-REQUEST: 60 seconds.
· RAWIP-OPEN: 30 seconds.
· RAWIP-READY: 60 seconds.
· TCP SYN-SENT and SYN-RCV: 30 seconds.
· TCP CLOSE: 2 seconds.
· TCP ESTABLISHED: 3600 seconds.
· TCP TIME-WAIT: 2 seconds.
· UDP-OPEN: 30 seconds.
· UDP-READY: 60 seconds.
fin: Specifies the TCP FIN_WAIT state.
icmp-reply: Specifies the ICMP REPLY state.
icmp-request: Specifies the IGMP REQUEST state.
rawip-open: Specifies the RAWIP-OPEN state.
rawip-ready: Specifies the RAWIP-READY state.
syn: Specifies the TCP SYN-SENT and SYN-RCV states.
tcp-close: Specifies the TCP CLOSE state.
tcp-est: Specifies the TCP ESTABLISHED state.
tcp-time-wait: Specifies the TCP TIME-WAIT state.
udp-open: Specifies the UDP OPEN state.
udp-ready: Specifies the UDP READY state.
time-value: Specifies the aging time in seconds. The value range is 1 to 100000.
This command sets the aging time for stable sessions of the application layer protocols that are not supported by the session aging-time application command. For persistent sessions, the aging time is set by the session persistent acl command.
# Set the aging time for TCP sessions in SYN-SENT and SYN-RCV states to 60 seconds.
[Sysname] session aging-time state syn 60
Use session log { bytes-active | packets-active } to set a threshold for traffic-based logging.
Use undo session log { bytes-active | packets-active } to restore the default.
session log { bytes-active bytes-value | packets-active packets-value }
No threshold is set for traffic-based logging.
bytes-value: Specifies the byte-based threshold in the range of 1 to 100000 MB.
packets-value: Specifies the packet-based threshold in the range of 1 to 100000 mega-packets.
For this command to take effect, make sure the session statistics collection for software fast forwarding feature is enabled.
If you set both the traffic-based and time-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
# Configure the device to output session logs on a per-10-mega-packet basis.
[Sysname] session statistics enable
[Sysname] session log packets-active 10
session log enable
session log enable
Use session log enable to enable session logging.
Use undo session log enable to disable session logging.
session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
undo session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
Session logging is disabled.
Interface view
ipv4: Logs IPv4 sessions.
ipv6: Logs IPv6 sessions.
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
If you do not specify an ACL, this command enables session logging for all IPv4 or IPv6 sessions on the interface.
If you do not specify the inbound or the outbound keyword, this command enables session logging on both directions.
Up to one IPv4 ACL and one IPv6 ACL can be applied to each direction.
The session logging feature must work with the flow log feature to generate session logs. For information about flow log, see Network Management and Monitoring.
After session logging is enabled, the device outputs session logs as follows:
· Outputs a session log when the specified traffic threshold or interval is reached.
· Outputs a session log when a session entry is created or removed only if the logging for session creation or deletion is enabled.
# Enable IPv4 session logging in the inbound direction of GigabitEthernet 2/1/1.
[Sysname] session log flow-begin
[Sysname] session log flow-end
[Sysname] interface gigabitethernet 2/1/1
[Sysname-GigabitEthernet2/1/1] session log enable ipv4 inbound
# Enable session logging on GigabitEthernet 2/1/2 for IPv4 sessions that match ACL 2050 in the outbound direction.
[Sysname] interface gigabitethernet 2/1/2
[Sysname-GigabitEthernet2/1/2] session log enable ipv4 acl 2050 outbound
# Enable session logging on GigabitEthernet 2/1/3 for IPv6 sessions that match ACL 2050 in the outbound direction.
[Sysname] interface gigabitethernet 2/1/3
[Sysname-GigabitEthernet2/1/3] session log enable ipv6 acl 2050 outbound
session log bytes-active
session log time-active
Use session log flow-begin to enable logging for session creation.
Use undo session log flow-begin to disable logging for session creation.
Logging for session creation is disabled.
For the device to output a session log when a session entry is created, make sure both session logging and logging for session creation are enabled.
# Enable logging for session creation.
session log enable
Use session log flow-end to enable logging for session deletion.
Use undo session log flow-end to disable logging for session deletion.
Logging for session deletion is disabled.
For the device to output a session log when a session entry is deleted, make sure both session logging and logging for session deletion are enabled.
# Enable logging for session deletion.
session log enable
Use session log time-active to set the threshold for time-based session logging.
Use undo session log time-active to restore the default.
session log time-active time-value
No threshold is set for time-based session logging.
time-value: Specifies the time-based threshold in minutes. The value range for the time-value argument is 10 to 120 and the value must be integer times of 10.
If you set both time-based and traffic-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
# Configure the device to output session logs every 50 minutes.
<Sysname> system
[Sysname] session log time-active 50
session log enable
Use session persistent acl to specify persistent sessions.
Use undo session persistent acl to delete persistent sessions that match the specified ACL.
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
undo session persistent acl [ ipv6 ] acl-number
No persistent sessions exist.
ipv6: Specifies an IPv6 ACL. To specify an IPv4 ACL, do not specify this keyword.
aging-time time-value: Specifies the aging time for persistent sessions in hours. The value range for the time-value argument is 0 to 360, and the default value is 24. To disable the aging for persistent sessions, set the value to 0.
This command is effective only on TCP sessions in ESTABLISHED state.
For a TCP session in ESTABLISHED state, the priority of the aging time is as follows:
· Aging time for persistent sessions.
· Aging time for sessions of application layer protocols.
· Aging time for sessions in different protocol states.
A never-age-out session is not removed until the device receives a connection close request from the initiator or responder, or you manually clear the session entries.
The configuration of persistent sessions applies only to new sessions. It has no effect on existing sessions.
Repeat this command to use multiple ACLs to specify persistent sessions.
# Specify IPv4 ACL 2000 for identifying persistent sessions and set the aging time to 72 hours.
[Sysname] session persistent acl 2000 aging-time 72
# Specify IPv6 ACL 3000 for identifying persistent sessions and set the aging time to 100 hours.
[Sysname] session persistent acl ipv6 3000 aging-time 100
Use session state-machine mode loose to set the mode of session state machine to loose.
Use undo session state-machine mode loose to restore the default.
The session state machine is in strict mode.
For asymmetric-path networks, to prevent the device from dropping packets abnormally, set the mode of the session state machine to loose.
As a best practice, use the default setting on symmetric-path networks.
# Set the mode of session state machine to loose.
[Sysname] session state-machine mode loose
Use session statistics enable to enable session statistics collection for software fast forwarding.
Use undo session statistics enable to disable session statistics collection for software fast forwarding.
Session statistics collection is disabled for software fast forwarding.
This command enables the device to collect the session-based outbound and inbound packets and bytes for software fast forwarding.
To display statistics per session, use the display session table command. To display statistics per packet type, use the display session statistics command.
For information about fast forwarding, see Layer 3—IP Services Configuration Guide.
# Enable session statistics collection for software fast forwarding.
Use session top-statistics enable to enable the top session statistics feature.
Use undo session top-statistics enable to disable the top session statistics feature.
The top session statistics feature is disabled.
This command collects the number of sessions for session-based services and ranks the sessions by source address and by destination address.
To display the top session statistics, use the display session top-statistics command.
# Enable the top session statistics feature.
[Sysname] session top-statistics enable
