01-Fundamentals Command Reference
HomeSupportResource CenterRoutersH3C SR6600-X Router SeriesH3C SR6600-X Router SeriesTechnical DocumentsReference GuidesCommand ReferencesH3C SR6600 SR6600-X Routers Command References-R7607-6W10001-Fundamentals Command Reference
05-File system management commands
05-File system management commands 100.53 KB
IMPORTANT
IMPORTANT:
·     Before managing storage media, file systems, directories, and files, make sure you know the possible impact.
·     A file or directory whose name starts with a dot character (.) is a hidden file or directory. To prevent the system from hiding a file or directory, make sure the file or directory name does not start with a dot character.
·     Some system files and directories are hidden. For correct system operation and full functionality, do not modify or delete hidden files or directories.
File system names, directory names, or file names must be compliant with the naming conventions. For more information about the naming conventions and the methods for specifying the names, see Fundamentals Configuration Guide.
Before you use the copy, delete, fixdisk, format, gunzip, gzip, mkdir, move, rename, rmdir, or undelete command on a USB disk, make sure the disk is not write protected.
You cannot access a file system that is being formatted or repaired. To access a file system after it is formatted or repaired, use one of the following methods:
·     Use the absolute path to specify a file or directory. For example, use the dir cfa0:/ command to display the files and directories in the cfa0: file system.
·     Use the cd command to change the working directory to the root directory of the file system before accessing a file or directory in the file system. For example, to display the files and directories in the root directory of the cfa0: file system, perform the following tasks:
a.     Use the cd cfa0:/ command to change the working directory to the root directory of the file system.
b.     Execute the dir command.
cd
Use cd to change the working directory.
cd { directory | .. }
directory: Specifies the destination directory.
..: Specifies the parent directory. If the working directory is the root directory, an error message appears when you execute the cd .. command. No online help information is available for this keyword.
# Change to the test directory after logging in to the device.
<Sysname> cd test
# Change to the parent directory.
<Sysname> cd ..
# (In standalone mode.) Change to the root directory of the cfa0: file system on slot 0.
<Sysname> cd slot0#cfa0:/
# (In standalone mode.) Change back to the test directory of the cfa0: file system on the active MPU.
<Sysname> cd cfa0:/test
# (In IRF mode.) Change the working directory.
1.     Display the member IDs and slot numbers of all MPUs.
<Sysname> display irf
 Member   Slot   Role    Priority    CPU-Mac
   1      0      Standby 20          00e0-fc0f-8c0f
 *+2      0      Master  20          00e0-fc0f-8c22
 The Bridge MAC of the IRF is: 00e0-fc00-0a00
 Auto upgrade                  : yes
 Mac persistent                : 6 min
2.     Access the test directory in the root directory of the cfa0: file system on the global active MPU.
3.     Access the root directory of the cfa0: file system on a global standby MPU.
<Sysname> cd chassis2#slot0#cfa0:/
4.     Change back to the root directory of the cfa0: file system on the global active MPU.
<Sysname> cd cfa0:/
copy
Use copy to copy a file.
In non-FIPS mode:
copy source-file { dest-file | dest-directory } [ vpn-instance vpn-instance-name ] [ source interface interface-type interface-number ]
In FIPS mode:
source-file: Specifies the name or URL of the file to be copied in non-FIPS mode, and specifies the name of the file to be copied in FIPS mode. If the file resides on an FTP or TFTP server rather than on the device, specify the URL of the file. Whether a URL is case sensitive depends on the server.
dest-file: Specifies the name or URL for the destination file in non-FIPS mode, and specifies the name for the destination file in FIPS mode. To copy the source file to an FTP or TFTP server, specify a URL. Whether a URL is case sensitive depends on the server.
dest-directory: Specifies the destination directory or URL in non-FIPS mode, and specifies the destination directory in FIPS mode. To copy the source file to an FTP or TFTP server, specify a URL. The device copies the source file to the destination location and saves the file with its original file name. Whether a URL is case sensitive depends on the server.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the destination FTP or TFTP server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the server belongs to the public network, do not specify this option.
source interface interface-type interface-number: Specifies the source interface used to connect to the server. After you specify the source interface, the device uses the primary IP address of the source interface as the source IP address for outgoing packets. If you do not specify this option, the device uses the outgoing interface as the source interface.
In FIPS mode, you can use the copy command only to copy a local file and save it locally.
In non-FIPS mode, you can use the copy command to perform the following tasks:
·     Copy a local file and save it locally.
·     Copy a local file and save it to an FTP or TFTP server.
·     Copy a file from an FTP or TFTP server and save it locally.
To specify a file or directory, use the following guidelines:
Location
Name format
Remarks
On the device
Use the file name guidelines in Fundamentals Configuration Guide.
N/A
On an FTP server
Enter the URL in the format of ftp://FTP username[:password]@server address[:port number]/file path[/file name].
The username and password must be the same as those configured on the FTP server. If the server authenticates users only by the username, you are not required to enter the password.
For example, to use the username 1 and password 1 and specify the startup.cfg file in the authorized working directory on the FTP server 1.1.1.1, enter ftp://1:[email protected]/startup.cfg.
To specify an IPv6 address, enclose the IPv6 address in square brackets ([ ]), for example, ftp://test:test@[2001::1]:21/test.cfg.
On a TFTP server
Enter the URL in the format of tftp://server address[:port number]/file path[/file name].
For example, to specify the startup.cfg file in the working directory on TFTP server 1.1.1.1, enter the URL tftp://1.1.1.1/startup.cfg.
To enter an IPv6 address, enclose the IPv6 address in square brackets ([ ]), for example, tftp://test:test@[2001::1]:21/test.cfg.
# Copy the test.cfg file in the current directory and save it to the current directory as testbackup.cfg.
<Sysname> copy test.cfg testbackup.cfg
Copy cfa0:/test.cfg to cfa0:/testbackup.cfg? [Y/N]:y
Copying file cfa0:/test.cfg to cfa0:/testbackup.cfg...Done.
# Copy test.cfg from the working directory on the FTP server 1.1.1.1. Save the copy to the local current directory as testbackup.cfg. The FTP username is user. The password is private.
<Sysname> copy ftp://user:[email protected]/test.cfg testbackup.cfg
Copy ftp://user:[email protected]/test.cfg to cfa0:/testbackup.cfg? [Y/N]:y
Copying file ftp://user:[email protected]/test.cfg to cfa0:/testbackup.cfg... Done.
# Copy test.cfg from the current directory. Save the copy to the working directory on the FTP server 1.1.1.1 as testbackup.cfg.  The FTP username is user. The password is private.
<Sysname> copy test.cfg ftp://user:[email protected]/testbackup.cfg
Copy cfa0:/test.cfg to ftp://user:[email protected]/testbackup.cfg? [Y/N]:y
Copying file cfa0:/test.cfg to ftp://user:[email protected]/testbackup.cfg... Done.
# Copy test.cfg from the working directory on the TFTP server 1.1.1.1. Save the copy to the local current directory as testbackup.cfg.
<Sysname> copy tftp://1.1.1.1/test.cfg testbackup.cfg
Copy tftp://1.1.1.1/test.cfg to cfa0:/testbackup.cfg? [Y/N]:y
Copying file tftp://1.1.1.1/test.cfg to cfa0:/testbackup.cfg... Done.
# Copy test.cfg from the current directory. Save the copy to the working directory on the TFTP server 1.1.1.1 as testbackup.cfg.
<Sysname> copy test.cfg tftp://1.1.1.1/testbackup.cfg
Copy cfa0:/test.cfg to tftp://1.1.1.1/testbackup.cfg? [Y/N]:y
Copying file cfa0:/test.cfg to tftp://1.1.1.1/testbackup.cfg... Done.
# Copy test.cfg from the working directory on the FTP server 1.1.1.1. Save the copy to the local current directory as testbackup.cfg. The FTP username is user. The password is private. The FTP server belongs to VPN instance vpn1.
<Sysname> copy ftp://user:[email protected]/test.cfg testbackup.cfg vpn-instance vpn1
# Copy test.cfg from the working directory on the TFTP server 1.1.1.1. Save the copy to the local current directory as testbackup.cfg. The TFTP server belongs to VPN instance vpn1.
<Sysname> copy tftp://1.1.1.1/test.cfg testbackup.cfg vpn-instance vpn1
# Copy test.cfg from the working directory on the FTP server 2001::1. Save the copy to the local current directory as testbackup.cfg. The FTP username is user. The password is private.
<Sysname> copy ftp://user:private@[2001::1]/test.cfg testbackup.cfg
Copy ftp://user:private@[2001::1]/test.cfg to cfa0:/testbackup.cfg? [Y/N]:y
Copying file ftp://user:private@[2001::1]/test.cfg to cfa0:/testbackup.cfg... Done.
# Copy test.cfg from the working directory on the TFTP server 2001::1. Save the copy to the local current directory as testbackup.cfg.
<Sysname> copy tftp://[2001::1]/test.cfg testbackup.cfg
Copy tftp://[2001::1]/test.cfg to cfa0:/testbackup.cfg? [Y/N]:y
Copying file tftp://[2001::1]/test.cfg to cfa0:/testbackup.cfg... Done.
# (In standalone mode.) Copy the active MPU's configuration file test.cfg to the root directory of the cfa0: file system on the standby MPU.
<Sysname> copy test.cfg slot1#cfa0:/
Copy cfa0:/test.cfg to slot1#cfa0:/test.cfg? [Y/N]:y
Copying file cfa0:/test.cfg to slot1#cfa0:/test.cfg...Done.
# (In IRF mode.) Copy a configuration file of the global active MPU. Save the copy to the root directory of the cfa0: file system on the global standby MPU that resides in slot 1 of member device 1.
<Sysname> copy test.cfg chassis1#slot1#cfa0:/
Copy cfa0:/test.cfg to chassis1#slot1#cfa0:/test.cfg? [Y/N]:y
Copying file cfa0:/test.cfg to chassis1#slot1#cfa0:/test.cfg...Done.
# (In IRF mode.) Copy a configuration file of the global standby MPU that resides in slot 1 of member device 1. Save the copy to the root directory of the cfa0: file system on the global standby MPU that resides in slot 1 of member device 2.
<Sysname> copy chassis1#slot1#cfa0:/test.cfg chassis2#slot1#cfa0:/
Copy chassis1#slot1#cfa0:/test.cfg to chassis2#slot1#cfa0:/test.cfg? [Y/N]:y
Copying file chassis1#slot1#cfa0:/test.cfg to chassis2#slot1#cfa0:/test.cfg...Done.
delete
Use delete to delete a file.
delete [ /unreserved ] file
/unreserved: Permanently deletes the specified file. If you do not specify this keyword, the command moves the file to the recycle bin.
file: Specifies the name of the file to be deleted. Asterisks (*) are acceptable as wildcards. For example, to remove files with the .txt extension in the current directory, enter delete *.txt.
Use the delete /unreserved file command with caution. You cannot restore a file that was deleted with this command.
The delete file command (without /unreserved) moves the specified file to the recycle bin, except in the following two situations, where the file is permanently deleted:
·     The file system is running out of storage space.
·     You are logged in to the default MDC and are using this command to delete a file from a non-default MDC.
A file moved to the recycle bin can be restored by using the undelete command.
Do not use the delete command to delete files from the recycle bin. To delete files from the recycle bin, use the reset recycle-bin command.
If you delete two files that have the same name from different directories, both files are retained in the recycle bin. If you successively delete two files that have the same name from the same directory, only the most recently deleted file is retained in the recycle bin.
# (In standalone mode.) Remove the file 1.cfg from the root directory of the cfa0: file system on the active MPU.
<Sysname> delete 1.cfg
Delete cfa0:/1.cfg? [Y/N]:y
Deleting file cfa0:/1.cfg...Done.
# (In standalone mode.) Permanently delete the file 1.cfg from the root directory of the cfa0: file system on the active MPU.
<Sysname> delete /unreserved 1.cfg
The file cannot be restored. Delete cfa0:/1.cfg? [Y/N]:y
Deleting the file permanently will take a long time. Please wait...
# (In standalone mode.) Remove the file 1.cfg from the root directory of the cfa0: file system on the standby MPU (in slot 1).
·     Method 1:
<Sysname> delete slot1#cfa0:/1.cfg
Delete slot1#cfa0:/1.cfg? [Y/N]:y
Deleting file slot1#cfa0:/1.cfg...Done.
·     Method 2:
<Sysname> cd slot1#cfa0:/
# (In IRF mode.) Remove the file 1.cfg from the root directory of the cfa0: file system on the global active MPU.
# (In IRF mode.) Permanently delete the file 1.cfg from the root directory of the cfa0: file system on the global active MPU.
# (In IRF mode.) Remove the file 1.cfg from the root directory of the cfa0: file system on the global standby MPU that resides in slot 1 of member device 1.
·     Method 1:
<Sysname> delete chassis1#slot1#cfa0:/1.cfg
Delete chassis1#slot1#cfa0:/1.cfg? [Y/N]:y
Deleting file chassis1#slot1#cfa0:/1.cfg...Done.
·     Method 2:
<Sysname> cd chassis1#slot1#cfa0:/
reset recycle-bin
undelete
dir
Use dir to display files or directories.
dir [ /all ] [ file | directory | /all-filesystems ]
/all: Displays all files and directories in the current directory, visible or hidden. If you do not specify this option, only visible files and directories are displayed.
file: Displays a specific file. This argument can use the asterisk (*) as a wildcard. For example, to display files with the .txt extension in the current directory, enter dir *.txt.
directory: Displays a specific directory.
/all-filesystems: Displays files and directories in the root directories of all file systems on the device.
If no option is specified, the command displays all visible files and directories in the current directory.
The directory name of the recycle bin is .trash. To display files in the recycle bin, use either of the following methods:
·     Execute the dir /all .trash command.
·     Execute the cd .trash command and then the dir command.
# (In standalone mode.) Display information about all files and directories in the current directory.
<Sysname> dir /all
Directory of cfa0:/
# (In standalone mode.) Display files and directories in the root directories of all file systems on the device.
<Sysname> dir /all-filesystems
Directory of cfa0:/
# (In standalone mode.) Display information about all files and directories in the cfa0: file system of the standby MPU (in slot 1).
<Sysname> dir /all
# (In IRF mode.) Display information about all files and directories in the cfa0: file system of the global active MPU.
<Sysname> dir /all
Directory of cfa0:/
# (In IRF mode.) Display files and directories in the root directories of all file systems in the IRF fabric.
Directory of cfa0:/
Directory of chassis1#slot0#cfa0:/
# (In IRF mode.) Display information about all files and directories in the cfa0: file system of a global standby MPU.
·     Method 1:
<Sysname> dir /all chassis1#slot0#cfa0:/
·     Method 2:
<Sysname> cd chassis1#slot0#cfa0:/
<Sysname> dir /all
Directory of
Current directory.
0     -rwh      3144  Apr 26 2014 13:45:28   xx.xx
File or directory information:
·     0—File or directory number, which is automatically allocated by the system.
·     -rwh—Attributes of the file or directory. The first character is the directory indicator (d for directory and for file). The second character indicates whether the file or directory is readable (r for readable). The third character indicates whether the file or directory is writable (w for writable). The fourth character indicates whether the file or directory is hidden (h for hidden, - for visible). Modifying, renaming, or deleting hidden files might affect functions.
·     3144—File size in bytes. For a directory, a hyphen (-) is displayed.
·     Apr 26 2014 13:45:28—Last date and time when the file or directory was modified.
·     xx.xx—File or directory name.
file prompt
Use file prompt to set the operation mode for files and directories.
Use undo file prompt to restore the default.
file prompt { alert | quiet }
undo file prompt
The operation mode is alert. The system prompts for confirmation when you perform a destructive file or directory operation.
alert: Prompts for confirmation when a destructive file or directory operation is being performed.
quiet: Gives no confirmation prompt for file or directory operations.
In quiet mode, the system does not prompt for confirmation when a user performs a file or directory operation. The alert mode provides an opportunity to cancel a disruptive operation.
# Set the file and directory operation mode to alert.
[Sysname] file prompt alert
fixdisk
Use fixdisk to check a file system for damage and repair any damage.
fixdisk filesystem
filesystem: Specifies the name of a file system.
This command is supported only on the default MDC.
Use this command to fix a file system when space in the file system cannot be used or released.
You can repair a file system only when no other users are accessing the file system.
# Repair the file system cfa0:.
<Sysname> fixdisk cfa0:
Restoring cfa0: may take some time...
Restoring cfa0:...Done.
format
Use format to format a file system.
format filesystem
Formatting a file system permanently deletes all files in the file system. If a startup configuration file exists in the file system, back it up if necessary.
You can format a file system only when no other users are accessing the medium.
# Format the file system cfa0:.
<Sysname> format cfa0:
All data on cfa0: will be lost, continue? [Y/N]:y
Formatting cfa0:... Done.
gunzip
Use gunzip to decompress a file.
gunzip file
file: Specifies the name of the file to be decompressed. This argument must have .gz as the extension.
This command deletes the specified file after decompressing it.
# Decompress the file system.bin.gz:
1.     Before decompressing the file, you can display files whose names start with the system. string.
<Sysname> dir system.*
Directory of cfa0:
   1 -rw-          20 Jun 14 2012 10:18:53   system.bin.gz
472972 KB total (472840 KB free)
2.     Decompress the file system.bin.gz.
<Sysname> gunzip system.bin.gz
Decompressing file cfa0:/system.bin.gz..... Done.
3.     Verify the decompress operation.
Directory of cfa0:
   1 -rw-           0 May 30 2012 11:42:25   system.bin
472972 KB total (472844 KB free)
gzip
Use gzip to compress a file.
gzip file
file: Specifies the name of the file to be compressed. The compressed file will be saved to the file.gz file.
This command deletes the specified file after compressing it.
# Compress the file system.bin:
1.     Before compressing the file, you can display files whose names start with the system. string.
Directory of cfa0:
   1 -rw-           0 May 30 2012 11:42:24   system.bin
2.     Compress the file system.bin.
<Sysname> gzip system.bin
Compressing file cfa0:/system.bin..... Done.
3.     Verify the compress operation.
Directory of cfa0:
md5sum
Use md5sum to use the MD5 algorithm to calculate the digest of a file.
md5sum file
file: Specifies the name of a file.
You can use file digests to verify file integrity.
# Use the MD5 algorithm to calculate the digest of the file system.bin.
<Sysname> md5sum system.bin
MD5 digest:
4f22b6190d151a167105df61c35f0917
mkdir
Use mkdir to create a directory.
mkdir directory
directory: Specifies a directory.
The name of the directory to be created must be unique in the parent directory.
You can create a directory only in an existing directory. For example, to create the cfa0:/test/mytest directory, make sure the test directory already exists.
# Create the test directory in the current directory.
<Sysname> mkdir test
Creating directory cfa0:/test... Done.
# Create the test/subtest directory in the current directory.
<Sysname> mkdir test/subtest
Creating directory cfa0:/test/subtest... Done.
# (In standalone mode.) Create the test directory in the root directory of the cfa0: file system on slot 0.
<Sysname> mkdir slot0#cfa0:/test
Creating directory slot0#cfa0:/test... Done.
# (In IRF mode.) Create the test directory on the global active MPU.
# (In IRF mode.) Create the test directory in the root directory of the cfa0: file system on the global standby MPU that resides in slot 1 of member device 2.
<Sysname> mkdir chassis2#slot1#cfa0:/test
Creating directory chassis2#slot1#cfa0:/test... Done.
more
Use more to display the contents of a text file.
more file
# Display the contents of the test.txt file.
<Sysname> more test.txt
Have a nice day.
# Display the contents of the testcfg.cfg file.
<Sysname> more testcfg.cfg
# (In standalone mode.) Display the contents of the testcfg.cfg file in slot 0.
<Sysname> more slot0#cfa0:/testcfg.cfg
# (In IRF mode.) Display the contents of the testcfg.cfg file on the global active MPU.
# (In IRF mode.) Display the contents of the testcfg.cfg file on the global standby MPU that resides in slot 1 of member device 2.
<Sysname> more chassis2#slot1#cfa0:/testcfg.cfg
mount
Use mount to mount a file system.
mount filesystem
Generally, file systems on a hot-swappable storage medium are automatically mounted when the storage medium is connected to the device. If the system cannot recognize a file system, however, you must mount the file system before you can access it.
To avoid file system corruption, do not perform the following tasks while the system is mounting a file system:
·     Install or remove storage media.
·     Install or remove cards.
·     Perform an active/standby switchover. (In standalone mode.)
·     Perform a switchover between the global active MPU and a global standby MPU. (In IRF mode.)
·     Creating, deleting, starting, or stopping an MDC.
# (In standalone mode.) Mount the file system on a CF card of the active MPU.
<Sysname> mount cfa0:
# (In standalone mode.) Mount the file system on a CF card of the standby MPU (in slot 1).
<Sysname> mount slot1#cfa0:
# (In IRF mode.) Mount the file system on a CF card of the global active MPU.
# (In IRF mode.) Mount the file system on a CF card of a global standby MPU (in slot 1 of the subordinate device with the member ID 2).
<Sysname> mount chassis2#slot1#cfa0:
umount
move
Use move to move a file.
source-file: Specifies the name of the source file.
dest-file: Specifies the name of the destination file.
dest-directory: Specifies the name of the destination directory.
If you specify a destination directory, the system moves the source file to the specified directory without changing the file name.
# Move the cfa0:/test/sample.txt file to cfa0:/, and save it as 1.txt.
<Sysname> move test/sample.txt 1.txt
Move cfa0:/test/sample.txt to cfa0:/1.txt? [Y/N]:y
Moving file cfa0:/test/sample.txt to cfa0:/1.txt ...Done.
# Move the b.cfg file to the directory test2.
<Sysname> move b.cfg test2
Move cfa0:/b.cfg to cfa0:/test2/b.cfg? [Y/N]:y
Moving file cfa0:/b.cfg to cfa0:/test2/b.cfg... Done.
pwd
Use pwd to display the working directory.
pwd
# Display the working directory.
<Sysname> pwd
cfa0:
rename
Use rename to rename a file or directory.
rename { source-file | source-directory } { dest-file | dest-directory }
source-directory: Specifies the name of the source directory.
This command is not executed if the destination file or directory name is already used by an existing file or directory in the working directory.
# Rename the copy.cfg file as test.cfg.
<Sysname> rename copy.cfg test.cfg
Rename cfa0:/copy.cfg as cfa0:/test.cfg? [Y/N]:y
Renaming cfa0:/copy.cfg as cfa0:/test.cfg... Done.
reset recycle-bin
Use reset recycle-bin to delete files from the recycle bin.
reset recycle-bin [ /force ]
/force: Deletes all files in the recycle bin without prompting for confirmation. If you do not specify this option, the command prompts you to confirm the deletion operation for each file.
The delete file command only moves a file to the recycle bin. To permanently delete the file, use the reset recycle-bin command to delete the file from the recycle bin.
# Empty the recycle bin. (In this example there are two files in the recycle bin.)
<Sysname> reset recycle-bin
Clear cfa0:/a.cfg? [Y/N]:y
Clearing file cfa0:/a.cfg... Done.
Clear cfa0:/b.cfg? [Y/N]:y
Clearing file cfa0:/b.cfg... Done.
# Delete the b.cfg file from the recycle bin. (In this example there are two files in the recycle bin.)
Clear cfa0:/a.cfg? [Y/N]:n
delete
rmdir
Use rmdir to delete a directory.
rmdir directory
To delete a directory, you must delete all files and subdirectories in the directory permanently or move them to the recycle bin. If you move them to the recycle bin, executing the rmdir command permanently deletes them.
# Delete the subtest directory.
<Sysname>rmdir subtest/
Remove directory cfa0:/test/subtest and the files in the recycle-bin under this directory will be deleted permanently. Continue? [Y/N]:y
Removing directory cfa0:/test/subtest... Done.
sha256sum
Use sha256sum to use the SHA-256 algorithm to calculate the digest of a file.
sha256sum file
# Use the SHA-256 algorithm to calculate the digest of file system.bin.
<Sysname> sha256sum system.bin
SHA256 digest:
0851e0139f2770e87d01ee8c2995ca9e59a8f5f4062e99af14b141b1a36ca152
tar create
Use tar create to archive files and directories.
tar create [ gz ] archive-file dest-file [ verbose ] source { source-file | source-directory }&<1-5>
gz: Uses gzip to compress the files and directories before archiving them. If you do not specify this keyword, the command archives the files and directories without compressing them.
archive-file dest-file: Specifies the archive file name. If you specified the gz keyword, the suffix of the archive file name must be .tar.gz. If you did not specify the gz keyword, the suffix of the archive file name must be .tar.
verbose: Displays the names of the successfully archived files and directories. If you do not specify this keyword, the command does not display the names of the successfully archived files and directories.
source { source-file | source-directory }&<1-5>: Specifies the files and directories to be archived. The argument can be a space-separated list of up to five items. Each item can be a file or directory name.
# Archive the files 1.cfg, 2.cfg, and the directory test to the file a.tar.
<Sysname> tar create archive-file a.tar source 1.cfg 2.cfg test
Creating archive cfa0:/a.tar Done.
# Compress and archive the files 1.cfg, 2.cfg, and the directory test to b.tar.gz.
<Sysname> tar create gz archive-file b.tar.gz source 1.cfg 2.cfg test
Creating archive cfa0:/b.tar.gz Done.
# Compress and archive files and directories, and display the successfully archived files and directories.
<Sysname> tar create gz archive-file c.tar.gz verbose source 1.cfg 2.cfg test
1.cfg
2.cfg
test/
test/a.log
test/subtest/
test/subtest/aa.log
tar extract
tar list
tar extract
Use tar extract to extract files and directories.
tar extract archive-file file [ verbose ] [ screen | to directory ]
archive-file file: Specifies the archive file name. The suffix can be .tar or .tar.gz.
verbose: Displays the names of the successfully extracted files and directories.
screen: Displays the content of the extracted files and directories on the screen. The extracted files are not saved.
to directory: Saves the extracted files and directories to a different directory. The directory argument specifies the directory.
If you do not specify the screen keyword or the to directory option, the command saves the extracted files and directories to the working directory.
The command saves the extracted files and directories by using their original names. If a file or directory that has the same name as an extracted file or directory already exists in the destination directory, the file or directory is overwritten.
# Extract files and directories from the archive file a.tar.
<Sysname> tar extract archive-file a.tar
Extracting archive cfa0:/a.tar Done.
# Extract files and directories from the archive file a.tar, and display the names of the successfully extracted files and directories.
<Sysname> tar extract archive-file a.tar.gz verbose
1.cfg
2.cfg
test/
test/a.log
test/subtest/
test/subtest/aa.log
# Extract files and directories from the archive file a.tar, and display the content of the files on the screen.
<Sysname> tar extract archive-file a.tar.gz screen
 version 7.1.055, Demo 2501008
 sysname Sysname
tar create
tar list
tar list
Use tar list to display the names of archived files and directories.
tar list archive-file file
# Display the names of archived files and directories.
<Sysname> tar list archive-file a.tar
1.cfg
2.cfg
test/
test/a.log
test/subtest/
test/subtest/aa.log
tar create
tar extract
umount
Use umount to unmount a file system.
umount filesystem
File systems on a storage medium are automatically mounted when the storage medium is connected to the device. To remove a hot-swappable storage medium from the device, you must first unmount all file systems on the storage medium to disconnect the medium from the device. Removing a connected hot-swappable storage medium might damage files on the storage medium or even the storage medium.
You can unmount a file system only when no other users are accessing the file system.
To avoid file system corruption, do not perform the following tasks while the system is unmounting a file system:
# (In standalone mode.) Unmount the file system on a USB disk of the active MPU.
<Sysname> umount usba0:
# (In standalone mode.) Unmount the file system on a USB disk of the standby MPU (in slot 1).
<Sysname> umount slot1#usba0:
# (In IRF mode.) Unmount the file system on a USB disk of the global active MPU.
# (In IRF mode.) Unmount the file system on a USB disk of a global standby MPU (in slot 1 of the subordinate member with the member ID 2).
<Sysname> umount chassis2#slot1#usba0:
mount
undelete
Use undelete to restore a file from the recycle bin.
undelete file
file: Specifies the name of the file to be restored.
If a file with the same name already exists in the directory, the system prompts whether or not you want to overwrite the existing file. If you enter Y, the existing file is overwritten. If you enter N, the command is not executed.
# Restore the copy.cfg file, which was moved from the root directory of the cfa0: file system to the recycle bin.
<Sysname>undelete copy.cfg
Undelete cfa0:/copy.cfg? [Y/N]:y
Undeleting file cfa0:/copy.cfg... Done.
# Restore the startup.cfg file, which was moved from the cfa0:/seclog directory to the recycle bin.
·     Method 1:
<Sysname>undelete seclog/startup.cfg
Undelete cfa0:/seclog/startup.cfg? [Y/N]:y
Undeleting file cfa0:/seclog/startup.cfg... Done.
<Sysname>
·     Method 2:
<Sysname> cd seclog
<Sysname> undelete startup.cfg
  • Become a Partner
  • Partner Resources
