| 03-MPLS QoS commands | 33.80 KB |
MPLS QoS commands
if-match mpls-exp
Use if-match mpls-exp to define a criterion to match the EXP field in the first (topmost) MPLS label.
Use undo if-match mpls-exp to delete the match criterion.
if-match [ not ] mpls-exp exp-value&<1-8>
undo if-match [ not ] mpls-exp exp-value&<1-8>
No criterion is defined to match the EXP field in the first (topmost) MPLS label.
Traffic class view
not: Matches packets not conforming to the specified criterion.
exp-value&<1-8>: Specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7. If the same EXP value is specified multiple times, the system considers them as one. If a packet matches one of the defined MPLS EXP values, it matches the if-match clause.
# Define a criterion to match packets with EXP value 3 or 4 in the topmost MPLS label.
[Sysname] traffic classifier database
[Sysname-classifier-database] if-match mpls-exp 3 4
if-match second-mpls-exp
Use if-match second-mpls-exp to define a criterion to match the EXP field in the second MPLS label.
Use undo if-match second-mpls-exp to delete the match criterion.
if-match [ not ] second-mpls-exp exp-value&<1-8>
undo if-match [ not ] second-mpls-exp exp-value&<1-8>
No criterion is defined to match the EXP field in the second MPLS label.
Traffic class view
exp-value&<1-8>: Specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7. If the same MPLS EXP value is specified multiple times, the system considers them as one. If a packet matches one of the defined MPLS EXP values, it matches the if-match clause.
# Define a criterion to match packets with EXP value 3 or 4 in the second MPLS label.
[Sysname-classifier-database] if-match second-mpls-exp 3 4
remark mpls-exp
Use remark mpls-exp to configure an EXP value marking action in a traffic behavior.
Use undo remark mpls-exp to delete the action.
remark mpls-exp exp-value
No EXP value marking action is configured in a traffic behavior.
Traffic behavior view
exp-value: Specifies an EXP value in the range of 0 to 7.
If an MPLS packet has multiple labels, this command marks the topmost label.
# Set the EXP value to 0 for MPLS packets.
[Sysname-behavior-database] remark mpls-exp 0
remark second-mpls-exp
Use remark second-mpls-exp to configure an EXP value marking action for the second label in a traffic behavior.
Use undo remark second-mpls-exp to delete the action.
remark second-mpls-exp exp-value
No EXP value marking action is configured for the second label in a traffic behavior.
# Set the EXP value to 0 for the second label of MPLS packets.
[Sysname-behavior-database] remark second-mpls-exp 0
