- 07-Layer 3 - IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 IS-IS commands
- 12-IPv6 policy-based routing commands
- 13-Routing policy commands
- 14-MTR commands
- 15-DCN commands
11-IPv6 IS-IS commands | 164.36 KB |
display isis redistribute ipv6
import-route isisv6 level-1 into level-2·
import-route isisv6 level-2 into level-1·
isis ipv6 fast-reroute lfa-backup exclude
isis ipv6 primary-path-detect bfd
IPv6 IS-IS commands
IPv6 IS-IS supports all the features of IPv4 IS-IS except that it advertises IPv6 routing information. This chapter describes only IPv6 IS-IS exclusive commands. For other IS-IS configuration commands, see "IS-IS commands."
address-family ipv6
Use address-family ipv6 to create the IS-IS IPv6 address family and enter its view.
Use undo address-family ipv6 to remove the IS-IS IPv6 address family and all configurations in the view.
undo address-family ipv6 [ unicast ]
No IS-IS IPv6 address family exists.
IS-IS view
unicast: Specifies the unicast address family (the default).
This command enables IPv6 for an IS-IS process.
# Create the IS-IS IPv6 address family and enter its view.
[Sysname] isis 100
[Sysname-isis-100] address-family ipv6
[Sysname-isis-100-ipv6]
auto-cost enable
Use auto-cost enable to enable automatic link cost calculation.
Use undo auto-cost enable to disable automatic link cost calculation.
auto-cost enable
Automatic link cost calculation is disabled.
IS-IS IPv6 unicast address family view
After automatic link cost calculation is enabled, the link cost is automatically calculated based on the bandwidth reference value of an interface. When the cost-style is wide or wide-compatible, the cost value of an interface is calculated by using the following formula: Cost = (Reference bandwidth value / Link bandwidth) × 10. For other cost styles, Table 1 applies.
Table 1 Automatic cost calculation scheme for cost styles other than wide and wide-compatible
Interface bandwidth |
Cost |
≤10 Mbps |
60 |
≤100 Mbps |
50 |
≤155 Mbps |
40 |
≤622 Mbps |
30 |
≤2500 Mbps |
20 |
>2500 Mbps |
10 |
# Enable automatic link cost calculation for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] auto-cost enable
bandwidth-reference
cost-style
isis ipv6 cost
bandwidth-reference
Use bandwidth-reference to set the bandwidth reference value for automatic link cost calculation.
Use undo bandwidth-reference to restore the default.
bandwidth-reference value
The bandwidth reference value is 100 Mbps.
value: Specifies the bandwidth reference value in the range of 1 to 2147483648 Mbps.
# Set the IPv6 bandwidth reference to 200 Mbps for IS-IS process 1.
[Sysname-isis-1-ipv6] bandwidth-reference 200
auto-cost enable
isis cost
circuit-cost
Use circuit-cost to set a global IPv6 IS-IS link cost.
Use undo circuit-cost to remove the configuration.
circuit-cost value [ level-1 | level-2 ]
undo circuit-cost [ level-1 | level-2 ]
No global link cost is configured.
value: Specifies the link cost value. The value range varies by cost style.
· For styles narrow, narrow-compatible, and compatible, the cost value is in the range of 0 to 63.
· For styles wide and wide-compatible, the cost value is in the range of 0 to 16777215.
level-1: Applies the link cost to Level-1.
level-2: Applies the link cost to Level-2.
If no level is specified, the specified cost applies to both Level-1 and Level-2.
# Set the global Level-1 IPv6 link cost of IS-IS process 1 to 11.
[Sysname] isis 1
[Sysname-isis-1-ipv6] circuit-cost 11 level-1
cost-style
isis cost
default-route-advertise
Use default-route-advertise to configure IPv6 IS-IS to advertise a Level-1 or Level-2 default route.
Use undo default-route-advertise to restore the default.
default-route-advertise [ avoid-learning | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
IPv6 IS-IS does not advertise Level-1 and Level-2 default routes.
avoid-learning: Avoids learning the default route received in LSPs or generated by using the ATT bit to prevent routing loops.
level-1: Advertises a Level-1 default route.
level-1-2: Advertises a Level-1-2 default route.
level-2: Advertises a Level-2 default route.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag value for the default route, in the range of 1 to 4294967295.
If no level is specified, this command advertises a Level-2 default route.
A Level-1 default route is advertised to the routers of the local area. A Level-2 route is advertised to all Level-2 and Level-1-2 routers.
You can use a routing policy to specify a level for the default route. The default route can be generated only when a route entry in the routing table matches the routing policy. Use the following commands in routing policy node view to specify different default route levels:
· Use the apply isis level-1 command to specify Level-1.
· Use the apply isis level-2 command to specify Level-2.
· Use the apply isis level-1-2 command to specify both Level-1 and Level-2.
The tag value specified in the routing policy takes precedence over the tag value specified in this command.
# Configure IS-IS process 1 to advertise a Level-2 IPv6 default route.
[Sysname] isis 1
[Sysname-isis-1-ipv6] default-route-advertise
apply isis
Use display isis redistribute ipv6 to display information about redistributed IPv6 IS-IS routes.
display isis redistribute ipv6 [ ipv6-address mask-length ] [ level-1 | level-2 ] [ process-id ]
ipv6-address mask-length: Displays redistributed routes for the specified IPv6 address and mask length.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535.
level-1: Displays IPv6 IS-IS Level-1 route information.
level-2: Displays IPv6 IS-IS Level-2 route information.
If no IPv6 IS-IS level is specified, this command displays both Level-1 and Level-2 route information.
# Display information about redistributed IPv6 IS-IS routes.
<Sysname> display isis redistribute ipv6 1
Level-1 IPv6 Redistribute Table
Type : direct Destination: 12:1::/64
IntCost : 0 Tag :
State : Active
Level-2 IPv6 Redistribute Table
IntCost : 0 Tag :
State : Active
Route information for IS-IS(1) |
Redistributed route information for IS-IS process 1. |
Level-1 IPv6 Redistribute Table |
Redistributed route information of IS-IS Level-1. |
Level-2 IPv6 Redistribute Table |
Redistributed route information of IS-IS Level-2. |
Type |
Redistributed route types: · Direct. · IS-ISv6. · Static. · OSPFv3. · BGP4+. · RIPng. |
Destination |
IPv6 destination address. |
IntCost |
Internal route cost. |
Tag |
Tag value. |
State |
Indicates whether the redistributed route is valid. |
display isis route ipv6
Use display isis route ipv6 to display IPv6 IS-IS route information.
display isis route ipv6 [ ipv6-address ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv6-address: Displays IPv6 IS-IS route information with the specified IPv6 destination address.
level-1: Displays Level-1 IPv6 IS-IS route information.
level-2: Displays Level-2 IPv6 IS-IS route information.
verbose: Displays detailed IPv6 IS-IS routing information.
If no level is specified, this command displays both Level-1 and Level-2 route information.
# Display IPv6 IS-IS route information.
<Sysname> display isis route ipv6
Level-1 IPv6 forwarding table
Destination: 2001:1:: PrefixLen: 64
Flag : R/L/- Cost : 20
Next hop : FE80::200:5EFF:FE64:8905 Interface: GE1/1/1
Destination: 2001:2:: PrefixLen: 64
Flag : D/L/- Cost : 10
Next hop : Direct Interface: GE1/1/1
Flags: D-Direct, R-Added to Rib, L-Advertised in LSPs, U-Up/Down bit set
Level-2 IPv6 forwarding table
Flag : -/-/- Cost : 20
Destination |
IPv6 destination prefix. |
PrefixLen |
Length of the prefix. |
Flag/Flags |
Route flag: · D—This is a direct route. · R—The route has been added into the routing table. · L—The route has been advertised in an LSP. · U—Route leaking flag, indicating that the Level-1 route is from Level-2. U means the route will not be returned to Level-2. |
Cost |
Route cost. |
Next hop |
Next hop. |
Output interface. |
# Display detailed IPv6 IS-IS routing information.
<Sysname> display isis route ipv6 verbose
IPv6 dest : 2001:1::/64
Admin tag : - Src count : 2
Nexthop : Direct
Interface : GE1/1/1
Nib ID : 0x0
IPv6 dest : 2001:2::/64
Flag : R/-/- Cost : 20
Nexthop : FE80::200:5EFF:FE64:8905
Interface : GE1/1/1
BkNexthop : FE80::200:5EFF:FE64:8905
BkInterface : GE1/1/1
Nib ID : 0x24000002
Level-2 IPv6 Forwarding Table
Nexthop : -
Interface : -
Nib ID : -
Nexthop : -
Interface : -
Nib ID : -
IPv6 dest |
IPv6 destination address and prefix. |
Flag/Flags |
Route flag: · D—This is a direct route. · R—The route has been added into the routing table. · L—The route has been advertised in an LSP. · U—Route leaking flag, indicating the Level-1 route is from Level-2. U means the route will not be returned to Level-2. |
Cost |
Route cost. |
Admin tag |
Administrative tag. |
Src count |
Number of advertisement sources. |
Nexthop |
Next hop. |
Output interface. |
BkNexthop |
Backup next hop. |
BkInterface |
Backup output interface. |
Nib ID |
Next hop index assigned by the routing management module. |
display isis spf-tree ipv6
Use display isis spf-tree ipv6 to display IPv6 IS-IS topology information.
display isis spf-tree ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
level-1: Displays Level-1 IPv6 IS-IS topology information. If you do not specify this keyword, the command displays both Level-1 and Level-2 topology information.
level-2: Displays Level-2 IPv6 IS-IS topology information. If you do not specify this keyword, the command displays both Level-1 and Level-2 topology information.
verbose: Displays detailed IPv6 IS-IS topology information. If you do not specify this keyword, the command displays brief IPv6 IS-IS topology information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays IPv6 topology information about all IS-IS processes.
# Display brief IPv6 IS-IS topology information.
<Sysname> display isis spf-tree ipv6
Shortest Path Tree for IS-IS(1)
Flags: S-Node is on SPF tree T-Node is on tent list
O-Node is overload R-Node is directly reachable
I-Node or Link is isolated D-Node or Link is to be deleted
C-Neighbor is child P-Neighbor is parent
V-Link is involved N-Link is a new path
L-Link is on change list U-Protocol usage is changed
H-Nexthop is changed
Level-1 Shortest Path Tree
SpfNode NodeFlag SpfLink LinkCost LinkFlag
0000.0000.0032.00 S/-/-/-/-/-
-->0000.0000.0032.01 10 -/-/C/-/-/-/-/-/-
-->0000.0000.0064.00 10 -/-/C/-/-/-/-/-/-
0000.0000.0032.01 S/-/-/R/-/-
-->0000.0000.0064.00 0 -/-/C/-/-/-/-/-/-
-->0000.0000.0032.00 0 -/-/-/P/-/-/-/-/-
0000.0000.0064.00 S/-/-/R/-/-
-->0000.0000.0032.00 10 -/-/-/P/-/-/-/-/-
-->0000.0000.0032.01 10 -/-/-/P/-/-/-/-/-
Level-2 Shortest Path Tree
# Display detailed Level-1 IPv6 IS-IS topology information.
<Sysname> display isis spf-tree ipv6 level-1 verbose
SpfNode : 0000.0000.0032.00
Distance : 0
TE distance : 0
NodeFlag : S/-/-/-/-/-
RelayNibID : 0x0
TE tunnel count: 0
Nexthop count : 0
SpfLink count : 2
LinkCost : 10
LinkNewCost : 10
LinkFlag : -/-/C/-/-/-/-/-/-
LinkSrcCnt : 1
Type : Adjacent Interface: N/A
Cost : 10 Nexthop : N/A
LinkCost : 10
LinkNewCost : 10
LinkSrcCnt : 1
Type : Adjacent Interface: Tun1
Cost : 10 Nexthop : FE80::A0A:A40
SpfNode : 0000.0000.0032.01
Distance : 10
TE distance : 10
NodeFlag : S/-/-/R/-/-
RelayNibID : 0x0
TE tunnel count: 0
Nexthop count : 0
SpfLink count : 2
LinkCost : 0
LinkNewCost : 0
LinkSrcCnt : 1
Type : Adjacent Interface: GE1/1/2
Cost : 10 Nexthop : FE80::200:12FF:FE34:1
LinkCost : 0
LinkNewCost : 0
LinkFlag : -/-/-/P/-/-/-/-/-
LinkSrcCnt : 1
Cost : 0 Nexthop : N/A
SpfNode : 0000.0000.0064.00
Distance : 10
TE distance : 10
RelayNibID : 0x0
TE tunnel count: 0
Nexthop count : 2
Neighbor : 0000.0000.0064.00 Interface : GE1/1/2
NextHop : FE80::200:12FF:FE34:1
BkNeighbor: N/A BkInterface: N/A
BkNextHop : N/A
Neighbor : 0000.0000.0064.00 Interface : Tun1
NextHop : FE80::A0A:A40
BkNextHop : N/A
SpfLink count : 2
LinkCost : 10
LinkNewCost : 10
LinkSrcCnt : 1
Type : Remote Interface: N/A
AdvMtID : 0
LinkCost : 10
LinkNewCost : 10
LinkSrcCnt : 1
Type : Remote Interface: Tun1
AdvMtID : 0
Table 5 Command output
SpfNode |
ID of the topology node. |
Distance |
Shortest distance from the root node to the current node. |
TE distance |
Shortest distance from the root node to the current node (including tunnel links). If no tunnels are configured, TE distance equals Distance. |
NodeFlag |
Node flag: · S—The node is on the SPF tree. · T—The node is on the tent list. · O—The node is overloaded. · R—The node is directly connected. · I—The node is isolated. · D—The node is to be deleted. |
TE tunnel count |
Number of tunnels destined for this node. |
Nexthop count |
Number of next hops. |
NextHop |
Primary next hop of the node or the link advertising source. |
AdvMtID |
Topology from which the routing information is learned: · 0—Base topology. · 6-4094—Other topologies. |
Primary output interface of the node or the link advertising source. |
BkNextHop |
Backup next hop. |
BkInterface |
Neighbor |
ID of the primary next hop neighbor. |
BkNeighbor |
ID of the backup next hop neighbor. |
SpfLink |
Topology link. |
SpfLink count |
Number of topology links. |
LinkCost |
Link cost. |
LinkNewCost |
New link cost. |
LinkFlag |
Link flag: · I—The link is isolated. · D—The link is to be deleted. · C—The neighbor is a child node. · P—The neighbor is the parent node. · V—The link is involved. · N—The link is a new path. · L—The link is on the change list. · U—The protocol of the link is changed. · H—The next hop of the link is changed. |
LinkSrcCnt |
Number of link advertising sources. |
Type |
Type of the link advertising source: · Adjacent—The link advertising source is a local neighbor. · Remote—The link advertising source is advertised by a remote node in an LSP. |
Cost |
Cost of the link advertising source. |
display isis statistics ipv6
Use display isis statistics ipv6 to display IPv6 IS-IS statistics.
display isis statistics ipv6 [ level-1 | level-1-2 | level-2 ] [ process-id ]
level-1: Displays IPv6 IS-IS Level-1 statistics.
level-1-2: Displays IPv6 IS-IS Level-1-2 statistics.
level-2: Displays IPv6 IS-IS Level-2 statistics.
process-id: Displays statistics for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays the statistics for all IS-IS processes.
If you do not specify a level, this command displays both Level-1 and Level-2 statistics.
# Display IPv6 IS-IS statistics.
<Sysname> display isis statistics ipv6
Statistics information for IS-IS(1)
Level-1 Statistics
MTR(base)
Learnt routes information:
Total IPv6 Learnt Routes in IPv6 Routing Table: 0
Imported routes information:
IPv6 Imported Routes:
Static: 0 Direct: 0
ISISv6: 0 BGP4+: 0
RIPng: 0 OSPFv3: 0
Total Number: 0
Level-2 Statistics
MTR(base)
Static: 0 Direct: 0
ISISv6: 0 BGP4+: 0
RIPng: 0 OSPFv3: 0
Total Number: 0
Table 6 Command output
Statistics information for IS-IS(processid) |
Statistics for the IPv6 IS-IS process. |
MTR(topo-name) |
MTR topology. base represents the base topology. |
Learnt routes information |
Total IPv6 Learnt Routes in IPv6 Routing Table means the number of learned IPv6 routes. |
IPv6 Imported Routes |
Numbers of different types of redistributed IPv6 routes, including static, direct, IS-ISv6, BGP4+, RIPng, and OSPFv3 routes. |
Lsp information |
LSP information: · LSP Source ID—ID of the source system. · No. of used LSPs—Number of used LSPs. |
fast-reroute
Use fast-reroute to configure IPv6 IS-IS FRR.
Use undo fast-reroute to disable IPv6 IS-IS FRR.
fast-reroute { lfa | route-policy route-policy-name }
undo fast-reroute
IPv6 IS-IS FRR is disabled.
lfa: Calculates a backup next hop through Loop Free Alternate (LFA) calculation for all routes.
route-policy route-policy-name: Uses the specified routing policy to designate a backup next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
ECMP routes do not support FRR.
# Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation for all routes.
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute lfa
filter-policy export
Use filter-policy export to configure IPv6 IS-IS to filter redistributed routes.
Use undo filter-policy export to remove the configuration.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
IPv6 IS-IS does not filter redistributed routes.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999 to filter redistributed routes.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter the redistributed routes.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes.
protocol: Filters routes redistributed from the specified routing protocol. If you do not specify this argument, the command filters routes redistributed from all routing protocols.
process-id: Specifies a process by its ID in the range of 1 to 65535. This argument is available only when the protocol is isisv6, ospfv3, or ripng.
This command filters routes redistributed by the import-route command. Only routes that have not been filtered can be advertised.
To reference an advanced ACL (with a number from 3000 to 3999) in the command or in the routing policy, configure the ACL using one of the following methods:
· To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix command.
· To deny/permit a route with the specified destination and prefix, use the rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix destination dest dest-prefix command.
The source keyword specifies the destination address of a route and the destination keyword specifies the prefix of the route. The specified prefix must be valid. Otherwise, the configuration does not take effect.
# Use IPv6 basic ACL 2006 to filter redistributed routes.
[Sysname] isis 1
[Sysname-isis-1-ipv6] filter-policy 2006 export
# Configure IPv6 advanced ACL 3000 to permit only route 2001::1/128 to pass. Use the ACL to filter redistributed routes.
[Sysname-acl-ipv6-adv-3000] rule 10 permit ipv6 source 2001::1 128 destination ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff 128
[Sysname-acl-ipv6-adv-3000] rule 100 deny ipv6
[Sysname-acl-ipv6-adv-3000] quit
[Sysname] isis 1
[Sysname-isis-1-ipv6] filter-policy 3000 export
filter-policy import
Use filter-policy import to configure IPv6 IS-IS to filter received routes.
Use undo filter-policy import to restore the default.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
IPv6 IS-IS does not filter received routes.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999 to filter received routes.
prefix-list ipv6-prefix-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter received routes.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter received routes.
This command filters received routes. Only routes that have not been filtered can be added into the routing table.
# Use IPv6 basic ACL 2003 to filter received routes.
[Sysname] isis 1
[Sysname-isis-1-ipv6] filter-policy 2003 import
# Configure IPv6 advanced ACL 3000 to permit only route 2001::1/128 to pass. Use the ACL to filter received routes.
[Sysname] isis 1
[Sysname-isis-1-ipv6] filter-policy 3000 import
import-route
Use import-route to enable IPv6 IS-IS to redistribute routes from another routing protocol.
Use undo import-route to remove the configuration.
import-route protocol [ as-number | process-id ] [ allow-ibgp ] [ allow-direct | cost cost-value | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name| tag tag ] *
undo import-route protocol [ process-id ]
IPv6 does not redistribute routes from any other routing protocol.
protocol: Redistributes routes from the specified routing protocol.
as-number: Specifies an AS by its number in the range of 1 to 4294967295. This argument applies only to the bgp4+ protocol. If you do not specify this argument, the command redistributes all IPv6 EBGP routes. As a best practice, specify an AS to prevent the system from redistributing excessive routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. The default value is 1. This argument is available only when the protocol is ripng, isisv6, or ospfv3.
allow-direct: Redistributes the networks of the local interfaces enabled with the specified routing protocol. By default, the networks of the local interfaces are not redistributed. If you specify both the allow-direct keyword and the route-policy route-policy-name option, make sure the if-match rule defined in the routing policy does not conflict with the allow-direct keyword. For example, if you specify the allow-direct keyword, do not configure the if-match route-type rule for the routing policy. Otherwise, the allow-direct keyword does not take effect.
cost cost-value: Specifies a cost for redistributed routes, in the range of 0 to 4261412864.
level-1: Redistributes routes into the Level-1 routing table.
level-1-2: Redistributes routes into Level-1 and Level-2 routing tables.
level-2: Redistributes routes into the Level-2 routing table. If you do not specify a level, the routes are redistributed into the Level-2 routing table.
tag tag: Specifies an administrative tag for marking redistributed routes, in the range of 1 to 4294967295.
allow-ibgp: Allows redistribution of IBGP routes. This keyword is available only when the protocol is bgp4+.
IPv6 IS-IS considers redistributed routes as AS-external routes.
You can specify a cost and a level for redistributed routes.
The import-route bgp4+ command redistributes only EBGP routes. The import-route bgp4+ allow-ibgp command redistributes both EBGP and IBGP routes, and might cause routing loops. Therefore, use it with caution.
# Configure IPv6 IS-IS to redistribute static routes and set the cost for redistributed routes to 15.
[Sysname] isis 1
[Sysname-isis-1-ipv6] import-route static cost 15
Use import-route isisv6 level-1 into level-2 to enable route advertisement from Level-1 to Level-2.
Use undo import-route isisv6 level-1 into level-2 to disable route advertisement from Level-1 to Level-2.
import-route isisv6 level-1 into level-2 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
Route advertisement from Level-1 to Level-2 is enabled.
filter-policy: Specifies a filtering policy.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
This command enables a Level-1-2 router to redistribute Level-1 routes to Level-2 routers and Level-1-2 routers in the local area.
# Enable route advertisement from Level-1 to Level-2.
[Sysname] isis 1
[Sysname-isis-1-ipv6] import-route isisv6 level-1 into level-2
Use import-route isisv6 level-2 into level-1 to enable IPv6 IS-IS route advertisement from Level-2 to Level-1.
Use undo import-route isisv6 level-2 into level-1 to restore the default.
import-route isisv6 level-2 into level-1 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
Route advertisement from Level-2 to Level-1 is disabled.
This command enables a Level-1-2 router to redistribute Level-2 routes to the Level-1 and Level-1-2 routers in the local area.
# Enable IPv6 IS-IS route advertisement from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] import-route isisv6 level-2 into level-1
import-route limit
Use import-route limit to configure the maximum number of redistributed Level-1/Level-2 IPv6 routes.
Use undo import-route limit to restore the default.
import-route limit number
The maximum number of redistributed Level-1/Level-2 IPv6 routes is 1000100.
number: Specifies the maximum number of redistributed Level-1/Level-2 IPv6 routes, in the range of 1 to 1000100.
# Configure IS-IS process 1 to redistribute a maximum of 1000 Level-1/Level-2 IPv6 routes.
[Sysname] isis 1
[Sysname-isis-1-ipv6] import-route limit 1000
isis ipv6 bfd enable
Use isis ipv6 bfd enable to enable BFD for IPv6 IS-IS.
Use undo isis ipv6 bfd enable to disable BFD for IPv6 IS-IS.
BFD for IPv6 IS-IS is disabled.
Interface view
# Enable BFD for IPv6 IS-IS on GigabitEthernet 1/1/1.
[Sysname] interface gigabitethernet 1/1/1
[Sysname-GigabitEthernet1/1/1] isis ipv6 bfd enable
isis ipv6 cost
Use isis ipv6 cost to set the IPv6 IS-IS cost for an interface.
Use undo isis ipv6 cost to remove the configuration.
isis ipv6 cost cost-value [ level-1 | level-2 ]
undo isis ipv6 cost [ level-1 | level-2 ]
No IPv6 IS-IS cost is configured for an interface.
Interface view
cost-value: Specifies an IPv6 IS-IS cost in the range of 1 to 16777215.
level-1: Applies the cost to Level-1 routes.
level-2: Applies the cost to Level-2 routes.
This command applies to interfaces that are enabled with IPv6 IS-IS.
This command takes effect only when the standard MTR mode is enabled.
# Set the IPv6 IS-IS cost to 10 for GigabitEthernet 1/1/1.
[Sysname] isis 100
[Sysname-isis-100] address-family ipv6 unicast
[Sysname-isis-100-ipv6] quit
[Sysname-isis-100] quit
[Sysname-GigabitEthernet1/1/1] isis ipv6 enable 100
[Sysname-GigabitEthernet1/1/1] isis ipv6 cost 10
isis ipv6 enable
Use isis ipv6 enable to enable IPv6 for IS-IS on an interface.
Use undo isis ipv6 enable to disable IPv6 for IS-IS on an interface.
isis ipv6 enable [ process-id ]
IPv6 is disabled for IS-IS on an interface.
Interface view
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. The default is 1.
# Enable IPv6 for IS-IS on GigabitEthernet 1/1/1.
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] address-family ipv6 unicast
[Sysname-isis-1-ipv6] quit
[Sysname-isis-1] quit
[Sysname-GigabitEthernet1/1/1] ipv6 address 2002::1/64
Use isis ipv6 fast-reroute lfa-backup exclude to disable LFA calculation on an interface.
Use undo isis ipv6 fast-reroute lfa-backup exclude to restore the default.
LFA calculation is enabled on an interface.
Interface view
# Disable LFA calculation on the interface GigabitEthernet 1/1/1.
[Sysname] isis 1
[Sysname-GigabitEthernet1/1/1] isis ipv6 fast-reroute lfa-backup exclude
fast-reroute
isis ipv6 prefix-suppression
Use isis ipv6 prefix-suppression to enable prefix suppression on an interface.
Use undo isis ipv6 prefix-suppression to disable prefix suppression on an interface.
Prefix suppression is disabled on an interface.
Interface view
By default, IS-IS interfaces advertise their IPv6 prefixes in LSPs. Use this command to disable an interface from advertising its IPv6 prefix in LSPs. This enhances network security by preventing IP routing to the internal nodes and speeds up network convergence.
# Enable prefix suppression on GigabitEthernet 1/1/1.
[Sysname-GigabitEthernet1/1/1] isis ipv6 prefix-suppression
Use isis ipv6 primary-path-detect bfd to enable BFD for IPv6 IS-IS.
Use undo isis ipv6 primary-path-detect bfd to disable BFD for IPv6 IS-IS.
isis ipv6 primary-path-detect bfd { ctrl | echo }
BFD is disabled for IPv6 IS-IS.
Interface view
ctrl: Enables BFD control packet mode.
echo: Enables BFD echo packet mode.
This command enables IPv6 IS-IS FRR or IPv6 IS-IS PIC to use BFD to detect primary link failures.
# Enable BFD control packet mode for IPv6 IS-IS FRR on the interface GigabitEthernet 1/1/1.
[Sysname] isis 1
[Sysname-GigabitEthernet1/1/1] isis ipv6 primary-path-detect bfd ctrl
# Enable BFD echo packet mode for IPv6 IS-IS PIC on the interface GigabitEthernet 1/1/2.
[Sysname] isis 1
[Sysname-isis-1] pic additional-path-always
[Sysname] bfd echo-source-ipv6 1::1
[Sysname] interface gigabitethernet 1/1/2
[Sysname-GigabitEthernet1/1/2] isis ipv6 primary-path-detect bfd echo
isis ipv6 tag
Use isis ipv6 tag to configure the tag value on an interface.
Use undo isis ipv6 tag to restore the default.
isis ipv6 tag tag
undo isis ipv6 tag
No tag value is configured on an interface.
Interface view
tag: Specifies a tag value in the range of 1 to 4294967295.
When IS-IS advertises an IPv6 prefix with a tag value, it adds the tag to the IPv6 reachability information TLV, regardless of the link cost style.
# Set the tag value on GigabitEthernet 1/1/1.
[Sysname-GigabitEthernet1/1/1] isis ipv6 tag 4294967295
ispf enable
Use ispf enable to enable IPv6 IS-IS incremental SPF (ISPF).
Use undo ispf enable to disable IPv6 IS-IS ISPF.
ispf enable
undo ispf enable
IPv6 IS-IS ISPF is enabled.
ISPF recomputes only the affected part of the shortest path tree (SPT) instead of the entire SPT when a network topology is changed.
# Enable IPv6 IS-IS ISPF.
[Sysname] isis 1
[Sysname-isis-1-ipv6] ispf enable
maximum load-balancing
Use maximum load-balancing to configure the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of IPv6 IS-IS ECMP routes is 8.
number: Specifies the maximum number of ECMP routes, in the range of 1 to 8.
# Set the maximum number of ECMP routes to 2.
[Sysname] isis 1
[Sysname-isis-1-ipv6] maximum load-balancing 2
multi-topology
Use multi-topology to enable IPv6 IS-IS MTR.
Use undo multiple-topology to disable IPv6 IS-IS MTR.
multi-topology [ compatible ]
undo multi-topology
IPv6 IS-IS MTR is disabled.
IS-IS IPv6 address family view
compatible: Specifies the compatible mode to advertise IPv6 prefixes to both IPv4 and IPv6 topologies. If you do not specify this keyword, the command advertises IPv6 prefixes only to the IPv6 topology.
This command enables separate route calculation in IPv4 and IPv6 topologies.
This command is available when the link cost style is wide, compatible, or wide-compatible.
# Enable IPv6 IS-IS MTR.
[Sysname] isis 1
[Sysname-isis-1-ipv6] multi-topology
cost-style
preference
Use preference to configure the preference for IPv6 IS-IS.
Use undo preference to restore the default.
undo preference
The preference for IPv6 IS-IS is 15.
preference: Specifies a preference for IPv6 IS-IS, in the range of 1 to 255.
If multiple dynamic routing protocols find routes to the same destination, the route found by the protocol with the highest preference is selected as the optimal route.
# Set the preference for IPv6 IS-IS to 20.
[Sysname] isis 1
[Sysname-isis-1-ipv6] preference 20
prefix-priority
Use prefix-priority to assign a convergence priority to the specified IPv6 IS-IS routes.
Use undo prefix-priority to remove the configuration.
prefix-priority { critical | high | medium } { prefix-list prefix-list-name | tag tag-value }
undo prefix-priority { critical | high | medium } [ prefix-list | tag ]
undo prefix-priority route-policy
IPv6 IS-IS routes have the low convergence priority.
critical: Specifies the highest convergence priority.
high: Specifies the high convergence priority.
medium: Specifies the medium convergence priority.
tag tag-value: Specifies a tag value in the range of 1 to 4294967295.
The higher the convergence priority, the faster the convergence speed.
IPv6 IS-IS host routes have a medium convergence priority.
# Assign the high convergence priority to IS-IS routes permitted by IPv6 prefix list standtest.
[Sysname] isis 1
[Sysname-isis-1-ipv6] prefix-priority high prefix-list standtest
set-overload
Use set-overload to set the overload bit.
Use undo set-overload to restore the default.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp4+ [ timeout3 ] ] ] [ allow { external | interlevel } * ]
undo set-overload
The overload bit is not set.
on-startup: Sets the overload bit upon system startup.
start-from-nbr system-id [ timeout1 [ nbr-timeout ] ]: Starts the nbr-timeout timer when the router begins to establish the neighbor relationship with the neighbor after system startup. If the neighbor relationship is formed within the nbr-timeout interval, IS-IS keeps the overload bit set. If not, the bit is cleared. IS-IS keeps the overload bit set within the timeout1 interval after the neighbor relationship is formed within the nbr-timeout interval.
· system-id—Specifies the neighbor.
· timeout1—The value range for the timeout1 interval is 5 to 86400 seconds, and the default is 600 seconds.
· nbr-timeout—The timer has an interval from 5 to 86400 seconds. The default is 1200 seconds.
timeout2: Sets the overload bit within the timeout2 interval after system startup. The value range for the interval is 5 to 86400 seconds, and the default is 600 seconds.
wait-for-bgp4+ [ timeout3 ]: Starts the timeout3 timer for IPv6 BGP convergence after system startup. If IPv6 BGP is not converged within the timeout3 interval, IPv6 IS-IS clears the overload bit. The value range for the timeout3 argument is 5 to 86400 seconds, and the default is 600 seconds.
allow: Allows advertising address prefixes. By default, no address prefixes are allowed to be advertised when the overload bit is set.
external: Allows advertising IP address prefixes redistributed from other routing protocols with the allow keyword specified.
interlevel: Allows advertising IP address prefixes learned from different IS-IS levels with the allow keyword specified.
If the on-startup keyword is not specified, the command sets the overload bit immediately until the undo set-overload command is executed.
If the on-startup keyword is specified, IS-IS sets the overload bit upon system startup and keeps it set within the timeout2 interval.
# Set the overload bit on the current router.
[Sysname] isis 1
[Sysname-isis-1-ipv6] set-overload
summary
Use summary to configure an IPv6 IS-IS summary route.
Use undo summary to remove an IPv6 IS-IS summary route.
summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
undo summary ipv6-prefix prefix-length [ level-1 | level-1-2 | level-2 ]
No summary route is configured.
ipv6-prefix: Specifies an IPv6 prefix for the summary route.
prefix-length: Specifies the length of the IPv6 prefix, in the range of 0 to 128.
avoid-feedback: Avoids learning the summary route by route calculation.
generate_null0_route: Generates a NULL 0 route to avoid routing loops.
level-1: Summarizes only the routes redistributed to Level-1.
level-1-2: Summarizes all the routes redistributed to both Level-1 and Level-2.
level-2: Summarize only the routes redistributed to Level-2.
tag: Specifies an administrative tag in the range of 1 to 4294967295.
If no level is specified, the command applies to Level-2.
You can summarize routes with the same next hop into a single route to reduce the size of the routing table, as well as the size of the LSDB. This command can summarize both learned and redistributed IPv6 IS-IS routes. The cost of the summary route is the smallest cost of the summarized routes.
# Configure a summary route 2002::/32.
[Sysname] isis
[Sysname-isis-1-ipv6] summary 2002:: 32
timer spf
Use timer spf to set the SPF calculation interval.
Use undo timer spf to restore the default.
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
undo timer spf
The maximum interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
maximum-interval: Specifies the maximum SPF calculation interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum SPF calculation interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental SPF calculation interval in the range of 10 to 60000 milliseconds.
Based on the LSDB, an IS-IS router uses the SPF algorithm to calculate an SPT with itself being the root. The router uses the SPT to determine the next hop to a destination network. By adjusting the SPF calculation interval, you can prevent bandwidth and router resources from being overused due to frequent topology changes.
For a stable network, the minimum interval is used. If network changes become frequent, the SPF calculation interval is incremented by the incremental interval for each calculation until the maximum interval is reached.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
# Set the maximum, minimum, and incremental SPF calculation interval to 10 seconds, 100 milliseconds, and 300 milliseconds, respectively.
[Sysname] isis 1
