- 06-Layer 3 - IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-IP forwarding basics commands
- 07-Fast forwarding commands
- 08-Flow classification commands
- 09-Adjacency table commands
- 10-IRDP commands
- 11-IP performance optimization commands
- 12-UDP Helper commands
- 13-IPv6 basics commands
- 14-DHCPv6 commands
- 15-IPv6 fast forwarding commands
- 16-Tunneling commands
- 17-GRE commands
- 18-ADVPN commands
- 19-AFT commands
- 20-WAAS commands
| 06-IP forwarding basics commands | 43.09 KB |
Basic IP forwarding commands
display fib
Use display fib to display FIB entries. Each FIB entry contains a destination IP address/mask, next hop, and output interface.
display fib [ topology topology-name | vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
topology topology-name: Specifies a topology by its name, a case-sensitive string of 1 to 31 characters. To specify a public topology, use base as the topology name. To display FIB entries for the public network, do not specify this option.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display FIB entries for the topology mt.
<Sysname> display fib topology mt
Destination count: 8 FIB entry count: 8
Flag:
U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
0.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
127.255.255.255/32 127.0.0.1 UH InLoop0 Null
224.0.0.0/4 0.0.0.0 UB NULL0 Null
224.0.0.0/24 0.0.0.0 UB NULL0 Null
255.255.255.255/32 127.0.0.1 UH InLoop0 Null
# Display all FIB entries of the public network.
Destination count: 5 FIB entry count: 5
Flag:
R:Relay F:FRR
1.1.1.0/24 192.168.126.1 USGF M-GE0/0/0 Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Destination count: 6 FIB entry count: 6
Flag:
R:Relay F:FRR
20.20.20.0/24 20.20.20.25 U M-GE0/0/0 Null
20.20.20.0/32 20.20.20.25 UBH M-GE0/0/0 Null
20.20.20.25/32 127.0.0.1 UH InLoop0 Null
20.20.20.25/32 20.20.20.25 H M-GE0/0/0 Null
20.20.20.255/32 20.20.20.25 UBH M-GE0/0/0 Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
R:Relay F:FRR
10.2.1.1/32 127.0.0.1 UH InLoop0 Null
Destination count |
Total number of destination addresses. |
FIB entry count |
Total number of FIB entries. |
Destination/Mask |
Destination address and the mask length. |
Nexthop |
Next hop address. |
Flag |
Flags of routes: · U—Usable route. · G—Gateway route. · H—Host route. · B—Blackhole route. · D—Dynamic route. · S—Static route. · R—Relay route. · F—Fast reroute. |
OutInterface/Token |
Output interface/LSP index number. |
Label |
Inner label. |
Load sharing commands
bandwidth-based-sharing
Use bandwidth-based-sharing to enable IPv4 load sharing based on bandwidth.
Use undo bandwidth-based-sharing to disable IPv4 load sharing based on bandwidth.
The IPv4 load sharing based on bandwidth is disabled.
This feature load shares flow traffic among multiple output interfaces based on their load percentages. The device calculates the load percentage for each output interface in terms of their expected bandwidths.
Devices that run load sharing protocols, such as Locator/ID Separation Protocol (LISP), implement load sharing based on the ratios defined by these protocols.
# Enable IPv4 load sharing based on bandwidth.
[Sysname] bandwidth-based-sharing
ip load-sharing mode
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
In standalone mode:
ip load-sharing mode { per-flow [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * | per-packet } { global | slot slot-number }
undo ip load-sharing mode { global | slot slot-number }
ip load-sharing mode { per-flow [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * | per-packet } { chassis chassis-number slot slot-number | global }
undo ip load-sharing mode { chassis chassis-number slot slot-number | global }
The default load sharing mode is per-flow.
per-flow: Implements per-flow load sharing.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
ingress-port: Identifies flows by ingress port.
algorithm algorithm-number: Specifies an algorithm for per-flow load sharing. The value range for the algorithm-number argument is 0 to 7, and the default value is 0.
global: Configures the load sharing mode globally.
per-packet: Implements per-packet load sharing.
slot slot-number: Specifies the slot number of the device, which is fixed at 0. Alternatively, you can execute the command without specifying this option. The command execution results are the same. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the device, which is fixed at 0. If you do not specify an IRF member device, this command configures the load sharing mode for all member devices. (In IRF mode.)
# (In IRF mode.) Configure per-packet load sharing for IRF member device 1.
[Sysname] ip load-sharing mode per-packet chassis 1 slot 0
