Title | Size | Downloads |
H3C S9800 Switch Series Installation Guide-6W106-book.pdf | 8.55 MB |
Preface
The H3C S9800 Switch Series Installation Guide guides you through the installation of your switch. It covers product overview, preparing for installation, installing the switch, powering on the switch for the first time, setting up an IRF fabric, and troubleshooting.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S9800.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
