Title | Size | Downloads |
H3C S12500X-AF LSXM1CGP12FX1 Card Manual-6PW101-book.pdf | 22.65 KB |
LSXM1CGP12FX1 12-port 100-GE CFP2
fiber interface card
1 Card identifier
The card identifier LSXM1CGP12FX1 is at the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specification |
Processor |
MIPS64 (Dual Core) @ 1.2 GHz. |
SDRAM |
4 GB DDR3 SDRAM. |
Power consumption |
388 W to 610 W. |
Interfaces |
12 CFP2 ports. |
Transmission rate |
100 Gbps. |
Transmission medium and max transmission distance |
See Table 2 |
Compatible device models |
S12500X-AF Switch Series. |
Compatible switching fabric modules |
Type F switching fabric modules. |
IMPORTANT: · To verify the compatibility of the module with the software release you are using, see the release notes. · This card can be used only with Type F switching fabric modules, which have a character string of SFF in their card identifiers (for example, LSXM1SFF16C1). This card cannot operate correctly if it is used with a switching fabric module that is not Type F. |
NOTE: Switching fabric module slots are covered by fan trays. To verify the card identifiers of the switching fabric modules when the switch is operating, use the display device command. |
The card supports CFP2 modules described in Table 2.
Table 2 CFP2 module specifications
CFP2 module |
Central wavelength |
Connector |
Cable specifications |
Max. transmission distance |
CFP2-100G-LR4-WDM1300 |
Four lanes: · 1295.56 nm · 1300.05 nm · 1304.58 nm · 1309.14 nm |
LC |
9/125 μm single-mode optical fiber |
10 km (6.21 miles) |
3 Obtaining documentation
For card installation, see H3C S12500X-AF Switch Series Installation Guide.
To access the most up-to-date H3C product documentation, go to
http://www.h3c.com.hk/Technical_Documents
For software upgrade, see the release notes for the device.
To access the release notes, go to
http://www.h3c.com.hk/Software_Download
Copyright © 2017 New H3C Technologies Co., Ltd.
