24-AAA Commands
Chapters Download (300.38 KB)
Table of Contents
local-server authentication eap-profile
local-user password-display-mode
2 RADIUS Configuration Commands
data-flow-format (RADIUS scheme view)
display stop-accounting-buffer
primary accounting (RADIUS scheme view)
primary authentication (RADIUS scheme view)
retry stop-accounting (RADIUS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (RADIUS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (RADIUS scheme view)
user-name-format (RADIUS scheme view)
3 HWTACACS Configuration Commands
data-flow-format (HWTACACS scheme view)
primary accounting (HWTACACS scheme view)
primary authentication (HWTACACS scheme view)
retry stop-accounting (HWTACACS scheme view)
secondary accounting (HWTACACS scheme view)
secondary authentication (HWTACACS scheme view)
stop-accounting-buffer enable (HWTACACS scheme view)
timer quiet (HWTACACS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer response-timeout (HWTACACS scheme view)
user-name-format (HWTACACS scheme view)
access-limit enable max-user-number
undo access-limit
View
ISP domain view
Default Level
2: System level
max-user-number: Maximum number of user connections for the current ISP domain. The valid range is from 0 to 2147483646.
Use the access-limit enable command to enable the limit on the number of user connections in an ISP domain and set the allowed maximum number. After the number of user connections reaches the maximum number allowed, no more users will be accepted.
Use the undo access-limit command to restore the default.
By default, there is no limit to the number of user connections in an ISP domain.
As user connections may compete for network resources, setting a proper limit to the number of user connections helps provide a reliable system performance.
# Set a limit of 500 user connections for ISP domain aabbcc.net.
[Sysname] domain aabbcc.net
[Sysname-isp-aabbcc.net] access-limit enable 500
access-limit max-user-number
undo access-limit
View
Local user view
Default Level
3: Manage level
max-user-number: Maximum number of user connections using the current username, in the range 1 to 1024.
Use the access-limit command to enable the limit on the number of user connections using the current username and set the allowed maximum number.
Use the undo access-limit command to remove the limitation.
By default, there is no limit to the number of user connections using the same username.
Note that the access-limit command takes effect only when local accounting is configured.
Related commands: display local-user.
# Enable the limit on the number of user connections using the username abc and set the allowed maximum number to 5.
[Sysname] local-user abc
[Sysname-luser-abc] access-limit 5
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo accounting default
View
ISP domain view
Default Level
2: System level
hwtacacs-scheme hwtacacs-scheme-name: Specifies an HWTACACS scheme by its name, which is a string of 1 to 32 characters.
local: Performs local accounting.
none: Does not perform any accounting.
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, which is a string of 1 to 32 characters.
Use the accounting default command to configure the default accounting method for all types of users.
Use the undo accounting default command to restore the default.
By default, the accounting method is local.
Note that:
l The RADIUS or HWTACACS scheme specified for the current ISP domain must have been configured.
l The accounting method configured with the accounting default command is for all types of users and has a priority lower than that for a specific access mode.
l Local accounting is only for managing the local user connection number; it does not provide the statistics function. The local user connection number management is only for local accounting; it does not affect local authentication and authorization.
Related commands: authentication default, authorization default, hwtacacs scheme, radius scheme.
# Configure the default ISP domain system to use the local accounting method for all types of users.
[Sysname] domain system
[Sysname-isp-system] accounting default local
# Configure the default ISP domain system to use RADIUS accounting scheme rd for all types of users and use local accounting as the backup.
[Sysname-isp-system] accounting default radius-scheme rd local
accounting lan-access { local | none | radius-scheme radius-scheme-name [ local ] }
undo accounting lan-access
View
ISP domain view
Default Level
2: System level
Use the accounting lan-access command to configure the accounting method for LAN access users.
Use the undo accounting lan-access command to restore the default.
By default, the default accounting method that the accounting default command prescribes is used for LAN access users.
Note that the RADIUS scheme specified for the current ISP domain must have been configured.
Related commands: accounting default, radius scheme.
# Configure the default ISP domain system to use the local accounting method for LAN access users.
[Sysname-isp-system] accounting lan-access local
# Configure the default ISP domain system to use RADIUS accounting scheme rd for LAN access users and use local accounting as the backup.
[Sysname-isp-system] accounting lan-access radius-scheme rd local
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo accounting login
View
ISP domain view
Default Level
2: System level
local: Performs local accounting. It is not used for charging purposes, but for collecting statistics on and limiting the number of local user connections.
Use the accounting login command to configure the accounting method for login users.
Use the undo accounting login command to restore the default.
By default, the default accounting method is used for login users.
Note that:
l Accounting is not supported for login users’ FTP services.
Related commands: accounting default, hwtacacs scheme, radius scheme.
# Configure the default ISP domain system to use the local accounting method for login users.
[Sysname-isp-system] accounting login local
# Configure the default ISP domain system to use RADIUS accounting scheme rd for login users and use local accounting as the backup.
[Sysname-isp-system] accounting login radius-scheme rd local
accounting optional
undo accounting optional
View
ISP domain view
Default Level
2: System level
None
Use the accounting optional command to enable the accounting optional feature.
Use the undo accounting optional command to disable the feature.
By default, the feature is disabled.
Note that with the accounting optional command configured for a domain:
l A user that will be disconnected otherwise can use the network resources even when there is no accounting server available or communication with the current accounting server fails. This command applies to scenarios where authentication is required but accounting is not.
l If accounting for a user in the domain fails, the device will not send real-time accounting updates for the user any more.
l The limit on the number of local user connections configured by using the access-limit command in local user view is not effective.
# Enable the accounting optional feature for users in domain aabbcc.net.
[Sysname-isp-aabbcc.net] accounting optional
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo authentication default
View
ISP domain view
Default Level
2: System level
local: Performs local authentication.
none: Does not perform any authentication.
Use the authentication default command to configure the default authentication method for all types of users.
Use the undo authentication default command to restore the default.
By default, the authentication method is local.
Note that:
l The RADIUS, HWTACACS scheme specified for the current ISP domain must have been configured.
l The authentication method specified with the authentication default command is for all types of users and has a priority lower than that for a specific access mode.
Related commands: authorization default, accounting default, hwtacacs scheme, radius scheme.
# Configure the default ISP domain system to use local authentication for all types of users.
[Sysname-isp-system] authentication default local
# Configure the default ISP domain system to use RADIUS authentication scheme rd for all types of users and use local authentication as the backup.
[Sysname-isp-system] authentication default radius-scheme rd local
authentication lan-access { local | none | radius-scheme radius-scheme-name [ local ] }
undo authentication lan-access
View
ISP domain view
Default Level
2: System level
Use the authentication lan-access command to configure the authentication method for LAN access users.
Use the undo authentication login command to restore the default.
By default, the default authentication method is used for LAN access users.
Related commands: authentication default, radius scheme.
# Configure the default ISP domain system to use local authentication for LAN access users.
[Sysname-isp-system] authentication lan-access local
# Configure the default ISP domain system to use RADIUS authentication scheme rd for LAN access users and use local authentication as the backup.
[Sysname-isp-system] authentication lan-access radius-scheme rd local
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
View
ISP domain view
Default Level
2: System level
Use the authentication login command to configure the authentication method for login users.
By default, the default authentication method is used for login users.
Note that the RADIUS, HWTACACS scheme specified for the current ISP domain must have been configured.
Related commands: authentication default, hwtacacs scheme, radius scheme.
# Configure the default ISP domain system to use local authentication for login users.
[Sysname-isp-system] authentication login local
# Configure the default ISP domain system to use RADIUS authentication scheme rd for login users and use local authentication as the backup.
[Sysname-isp-system] authentication login radius-scheme rd local
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local | none ] | local | none }
undo authorization command
View
ISP domain view
Default Level
2: System level
local: Performs local authorization.
none: Does not perform any authorization. In this case, an authenticated user is automatically authorized with the corresponding default rights.
Use the authorization command command to configure the authorization method for command line users.
Use the undo authorization command command to restore the default.
By default, the default authorization method is used for command line users.
Note that:
l The HWTACACS scheme specified for the current ISP domain must have been configured.
l For local authorization, the local users must have been configured for the command line users on the device, and the level of the commands authorized to a local user must be lower than or equal to that of the local user. Otherwise, local authorization will fail.
Related commands: authorization default, hwtacacs scheme.
# Configure the default ISP domain system to use HWTACACS authorization scheme hw for command line users.
[Sysname-isp-system] authorization command hwtacacs-scheme hw
# Configure the default ISP domain system to use HWTACACS authorization scheme hw for command line users and use local authorization as the backup.
[Sysname-isp-system] authorization command hwtacacs-scheme hw local
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo authorization default
View
ISP domain view
Default Level
2: System level
Use the authorization default command to configure the authorization method for all types of users.
Use the undo authorization default command to restore the default.
By default, the authorization method for all types of users is local.
Note that:
l The authorization method specified with the authorization default command is for all types of users and has a priority lower than that for a specific access mode.
l RADIUS authorization is special in that it takes effect only when the RADIUS authorization scheme is the same as the RADIUS authentication scheme. In addition, if a RADIUS authorization fails, the error message returned to the NAS says that the server is not responding.
Related commands: authentication default, accounting default, hwtacacs scheme, radius scheme.
# Configure the default ISP domain system to use local authorization for all types of users.
[Sysname-isp-system] authorization default local
# Configure the default ISP domain system to use RADIUS authorization scheme rd for all types of users and use local authorization as the backup.
[Sysname-isp-system] authorization default radius-scheme rd local
authorization lan-access { local | none | radius-scheme radius-scheme-name [ local ] }
undo authorization lan-access
View
ISP domain view
Default Level
2: System level
none: Does not perform any authorization. In this case, an authenticated user is automatically authorized with the default rights.
Use the authorization lan-access command to configure the authorization method for LAN access users.
Use the undo authorization lan-access command to restore the default.
By default, the default authorization method is used for LAN access users.
Related commands: authorization default, radius scheme.
# Configure the default ISP domain system to use local authorization for LAN access users.
[Sysname-isp-system]authorization lan-access local
# Configure the default ISP domain system to use RADIUS authorization scheme rd for LAN access users and use local authorization as the backup.
[Sysname-isp-system] authorization lan-access radius-scheme rd local
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo authorization login
View
ISP domain view
Default Level
2: System level
Use the authorization login command to configure the authorization method for login users.
Use the undo authorization login command to restore the default.
By default, the default authorization method is used for login users.
Related commands: authorization default, hwtacacs scheme, radius scheme.
# Configure the default ISP domain system to use local authorization for login users.
[Sysname-isp-system] authorization login local
# Configure the default ISP domain system to use RADIUS authorization scheme rd for login users and use local authorization as the backup.
[Sysname-isp-system] authorization login radius-scheme rd local
authorization-attribute { acl acl-number | callback-number callback-number | idle-cut minute | level level | user-profile profile-name | vlan vlan-id | work-directory directory-name } *
undo authorization-attribute { acl | callback-number | idle-cut | level | user-profile | vlan | work-directory } *
View
Local user view, user group view
Default Level
3: Manage level
acl: Specifies the authorized ACL of the local user(s).
acl-number: Authorized ACL for the local user(s), in the range 2000 to 5999.
callback-number: Specifies the authorization PPP callback number of the local user(s).
callback-number: Authorization PPP callback number for the local user(s), a case-sensitive string of 1 to 64 characters.
idle-cut: Specifies the idle cut function for the local user(s). With the idle cut function enabled, an online user whose idle period exceeds the specified idle time will be logged out.
minute: Idle time allowed, in the range 1 to 120 minutes.
level: Specifies the level of the local user(s).
level: Level of the local user(s), which can be 0 for visit level, 1 for monitor level, 2 for system level, and 3 for manage level. A smaller number means a lower level. The default is 0.
user-profile: Specifies the authorization user profile of the local user(s).
profile-name: Name of the authorization user profile for the local user(s), a case-sensitive string of 1 to 32 characters. It can consist of English letters, digits, and underlines and must start with an English letter.
vlan: Specifies the authorized VLAN of the local user(s).
vlan-id: Authorized VLAN for the local user(s), in the range 1 to 4094.
work-directory: Specifies the authorized work directory of the local user(s), if the user or users are authorized the FTP or SFTP service type.
directory-name: Authorized work directory, a case-insensitive string of 1 to 135 characters. This directory must already exist.
Use the authorization-attribute command to configure authorization attributes for the local user or user group. After the local user or a local user of the user group passes authentication, the device will assign these attributes to the user.
Use the undo authorization-attribute command to remove authorization attributes.
By default, no authorization attribute is configured for a local user or user group.
Note that:
l Every configurable authorization attribute has its definite application environments and purposes. However, the assignment of local user authorization attributes does not take the service type into account. Therefore, when configuring authorization attributes for a local user, consider what attributes are needed.
l Authorization attributes configured for a user group are effective on all local users of the group.
l An authorization attribute configured in local user view takes precedence over the same attribute configured in user group view.
l If you specify to perform no authentication or perform password authentication, the levels of commands that a user can access after login depends on the level of the user interface. For information about user interface login authentication method, refer to the authentication-mode command in Login Commands. If the authentication method requires users to provide usernames and passwords, the levels of commands that a user can access after login depends on the level of the user. For an SSH user authenticated with an RSA public key, available commands depend on the level specified on the user interface.
l If you remove the specified work directory from the file system, the FTP/SFTP user(s) will not be able to access the directory.
l If the specified work directory carries slot information, the FTP/SFTP user(s) will not be able to access the directory after a switchover occurs. Therefore, specifying slot information for the work directory is not recommended.
# Configure the authorized VLAN of user group abc as VLAN 3.
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
bind-attribute { call-number call-number [ : subcall-number ] | ip ip-address | location port slot-number subslot-number port-number | mac mac-address | vlan vlan-id } *
undo bind-attribute { call-number| ip | location | mac | vlan } *
View
Local user view
Default Level
3: Manage level
call-number call-number: Specifies a calling number for ISDN user authentication. The call-number argument is a string of 1 to 64 characters.
subcall-number: Specifies the sub-calling number. The total length of the calling number and the sub-calling number cannot be more than 62 characters.
ip ip-address: Specifies the IP address of the user.
location: Specifies the port binding attribute of the user.
port slot-number subslot-number port-number: Specifies the port to which the user is bound. The slot-number argument is in the range 0 to 15, the subslot-number argument is in the range 0 to 15, and the port-number argument is in the range 0 to 255. Only the numbers make sense here; port types are not taken into account.
mac mac-address: Specifies the MAC address of the user in the format of H-H-H.
vlan vlan-id: Specifies the VLAN to which the user belongs. The vlan-id argument is in the range 1 to 4094.
Use the bind-attribute command to configure binding attributes for a local user.
Use the undo bind-attribute command to remove binding attributes of a local user.
By default, no binding attribute is configured for a local user.
Note that:
l Binding attributes are checked upon authentication of a local user. If the binding attributes of a local user do not match the configured ones, the checking will fail and the user will fail the authentication as a result. In addition, such binding attribute checking does not take the service types of the users into account. That is, a configured binding attribute is effective on all types of users. Therefore, be cautious when deciding which binding attributes should be configured for which type of local users.
l The bind-attribute ip command applies only when the authentication method supports IP address upload. If you configure the command when the authentication method does not support IP address upload, local authentication will fail.
# Configure the bound IP of local user abc as 3.3.3.3.
[Sysname-luser-abc] bind-attribute ip 3.3.3.3
cut connection { all | domain isp-name | ucibindex ucib-index | user-name user-name }
View
Default Level
2: System level
all: Specifies all user connections.
domain isp-name: Specifies all user connections of an ISP domain. The isp-name argument refers to the name of an existing ISP domain and is a string of 1 to 24 characters.
ucibindex ucib-index: Specifies a user connection by connection index. The value range is from 0 to 4294967295.
user-name user-name: Specifies a user connection by username. The user-name argument is a case-sensitive string of 1 to 80 characters and must contain the domain name. If you enter a username without any domain name, the system assumes that the default domain name is used for the username.
Use the cut connection command to tear down the specified connections forcibly.
At present, this command applies to only LAN access user connections.
Related commands: display connection, service-type.
# Tear down all connections in ISP domain aabbcc.net.
[Sysname] cut connection domain aabbcc.net
display connection [ domain isp-name | ucibindex ucib-index | user-name user-name ]
View
Default Level
1: Monitor level
domain isp-name: Specifies all user connections of an ISP domain. The isp-name argument refers to the name of an existing ISP domain and is a case-insensitive string of 1 to 24 characters.
ucibindex ucib-index: Specifies all user connections using the specified connection index. The value range is from 0 to 4294967295.
user-name user-name: Specifies all user connections using the specified username. The user-name argument is a case-sensitive string of 1 to 80 characters and must contain the domain name. If you enter a username without any domain name, the system assumes that the default domain name is used for the username.
Use the display connection command to display information about specified or all AAA user connections.
Note that:
l With no parameter specified, the command displays brief information about all AAA user connections.
l If you specify the ucibindex ucib-index combination, the command displays detailed information; otherwise, the command displays brief information.
l This command does not apply to FTP user connections.
Related commands: cut connection.
# Display information about all AAA user connections.
<Sysname> display connection
Index=1 ,Username=telnet@system
IP=10.0.0.1
Total 1 connection(s) matched.
Table 1-1 display connection command output description
Index |
Index number |
Username |
Username of the connection, in the format username@domain |
IP |
IP address of the user |
Total 1 connection(s) matched. |
Total number of user connections |
display domain [ isp-name ]
View
Default Level
1: Monitor level
isp-name: Name of an existing ISP domain, a string of 1 to 24 characters.
Use the display domain command to display the configuration information of a specified ISP domain or all ISP domains.
Related commands: access-limit enable, domain, state.
# Display the configuration information of all ISP domains.
0 Domain = system
State = Active
Access-limit = Disable
Accounting method = Required
Default authentication scheme : local
Default authorization scheme : local
Default accounting scheme : local
Domain User Template:
Idle-cut = Disabled
Self-service = Disabled
1 Domain = aabbcc
State = Active
Lan-access authentication scheme : radius=test, local
Lan-access authorization scheme : hwtacacs=hw, local
Lan-access accounting scheme : local
Idle-cut = Disabled
Default Domain Name: system
Total 2 domain(s)
Table 1-2 display domain command output description
Domain |
Domain name |
State |
Status of the domain (active or block) |
Access-limit |
Limit on the number of user connections |
Accounting method |
Accounting method (either required or optional) |
Default authentication scheme |
Default authentication method |
Default authorization scheme |
Default authorization method |
Default accounting scheme |
Default accounting method |
Lan-access authentication scheme |
Authentication method for LAN users |
Lan-access authorization scheme |
Lan-access accounting scheme |
Accounting method for LAN users |
Domain User Template |
Template for users in the domain |
Idle-cut |
Whether idle cut is enabled |
Self-service |
Whether self service is enabled |
Default Domain Name |
Default ISP domain name |
Total 2 domain(s). |
2 ISP domains in total |
display local-user [ idle-cut { disable | enable } | service-type { ftp | lan-access | ssh | telnet | terminal } | state { active | block } | user-name user-name | vlan vlan-id ]
View
Default Level
1: Monitor level
idle-cut { disable | enable }: Specifies local users with the idle cut function disabled or enabled.
service-type: Specifies the local users of a type.
l ftp refers to users using FTP.
l lan-access refers to users accessing the network through an Ethernet.
l ssh refers to users using SSH.
l telnet refers to users using Telnet.
l terminal refers to users logging in through the console port, AUX port.
state { active | block }: Specifies all local users in the state of active or block. A local user in the state of active can access network services, while a local user in the state of blocked cannot.
user-name user-name: Specifies all local users using the specified username. The username is a case-sensitive string of 1 to 55 characters and does not contain the domain name.
vlan vlan-id: Specifies all local users in a VLAN. The VLAN ID ranges from 1 to 4094.
Use the display local-user command to display information about specified or all local users.
Related commands: local-user.
# Display information about all local users.
<Sysname> display local-user
The contents of local user abc:
State: Active
ServiceType: telnet
Access-limit: Disable Current AccessNum: 0
User-group: system
Bind attributes:
Authorization attributes:
User Privilege: 3
The contents of local user admin:
State: Active
ServiceType: telnet
User-group: system
Bind attributes:
User Privilege: 3
Total 2 local user(s) matched.
Table 1-3 display local-user command output description
State |
Status of the local user, Active or Block |
ServiceType |
Service types that the local user can use, including FTP, LAN, SSH, Telnet, and terminal. |
Access-limit |
Limit on the number of user connections using the current username |
Current AccessNum |
Current number of user connections using the current username |
Authorization attributes |
Authorization attributes of the local user |
display user-group [ group-name ]
View
Default Level
2: System level
group-name: User group name, a case-insensitive string of 1 to 32 characters.
Use the display user-group command to display configuration information about one or all user groups.
Related commands: user-group.
# Display configuration information about user group abc.
<Sysname> display user-group abc
The contents of user group abc:
Total 1 user group(s) matched.
domain isp-name
undo domain isp-name
View
Default Level
3: Manage level
isp-name: ISP domain name, a case-insensitive string of 1 to 24 characters that cannot contain any forward slash (/), colon (:), asterisk (*), question mark (?), less-than sign (<), greater-than sign (>), or @.
Use the domain isp-name command to create an ISP domain and/or enter ISP domain view.
Use the undo domain command to remove an ISP domain.
Note that:
l If the specified ISP domain does not exist, the system will create a new ISP domain. All the ISP domains are in the active state when they are created.
l There is a default domain in the system, which cannot be deleted and can only be changed. A user providing no ISP domain name at login is considered in the default domain. For details about the default domain, refer to command domain default enable.
Related commands: state, display domain.
# Create ISP domain aabbcc.net, and enter ISP domain view.
domain default enable isp-name
undo domain default enable
View
Default Level
3: Manage level
isp-name: Name of the default ISP domain, a string of 1 to 24 characters.
Use the domain default enable command to configure the system default ISP domain.
Use the undo domain default enable command to restore the default.
By default, there is a default ISP domain named system.
Note that:
l There must be only one default ISP domain.
l The specified domain must have existed.
l The default ISP domain configured cannot be deleted unless you configure it as a non-default domain again.
# Create a new ISP domain named aabbcc.net, and configure it as the default ISP domain.
[Sysname-isp-aabbcc.net] quit
[Sysname] domain default enable aabbcc.net
eap-profile profile-name
undo eap-profile profile-name
View
Default Level
2: System level
profile-name: Name of the profile for local EAP authentication, a case-insensitive string of 1 to 16 characters.
Use the eap-profile command to create an EAP profile and/or enter EAP profile view.
Use the undo eap-profile command to remove an EAP profile.
An EAP profile is a collection of local EAP authentication settings, including the authentication method to be used and, for some authentication methods, the SSL server policy to be referenced.
Related commands: eap method, ssl-server-policy.
# Create an EAP profile and enter its view.
[Sysname] eap-profile aprf1
[Sysname-eap-prof-aprf1]
expiration-date time
undo expiration-date
View
Local user view
Default Level
3: Manage level
time: Expiration time of the local user, in the format HH:MM:SS-MM/DD/YYYY or HH:MM:SS-YYYY/MM/DD. HH:MM:SS indicates the time, where HH ranges from 0 to 23, MM and SS range from 0 to 59. YYYY/MM/DD indicates the date, where YYYY ranges from 2000 to 2035, MM ranges from 1 to 12, and DD depends on the month. Except for the zeros in 00:00:00, leading zeros can be omitted. For example, 2:2:0-2008/2/2 equals to 02:02:00-2008/02/02.
Use the expiration-date command to configure the expiration time of a local user.
Use the undo expiration-date command to remove the configuration.
By default, a local user has no expiration time and no time validity checking is performed.
When some users need to access the network temporarily, you can create a guest account and specify an expiration time for the account. When a user uses the guest account for local authentication and passes the authentication, the access device checks whether the current system time is within the expiration time. If so, it permits the user to access the network. Otherwise, it denies the access request of the user.
Note that if you change the system time manually or the system time is changed in any other way, the access device uses the new system time for time validity checking.
# Configure the expiration time of user abc to be 12:10:20 on May 31, 2008.
[Sysname-luser-abc] expiration-date 12:10:20-2008/05/31
group group-name
undo group
View
Local user view
Default Level
3: Manage level
Use the group command to specify the user group for the local user to belong to.
Use the undo group command to restore the default.
By default, a local user belongs to user group system, which is automatically created by the device.
# Specify that local user 111 belongs to user group abc.
[Sysname] local-user 111
[Sysname-luser-111] group abc
idle-cut enable minute
undo idle-cut enable
View
ISP domain view
Default Level
2: System level
minute: Maximum idle duration allowed, in the range 1 to 120 minutes.
Use the idle-cut enable command to enable the idle cut function and set the maximum idle duration allowed. With the idle cut function enabled for a domain, the system will log out any user in the domain who has been idle for a period greater than the maximum idle duration.
Use the undo idle-cut command to restore the default.
By default, the function is disabled.
Related commands: domain.
# Enable the idle cut function and set the idle threshold to 50 minutes for ISP domain aabbcc.net.
[Sysname-isp-aabbcc.net] idle-cut enable 50
local-server authentication eap-profile profile-name
undo local-server authentication eap-profile
View
Default Level
2: System level
profile-name: EAP profile name, a case-insensitive string of 1 to 16 characters.
Use the local-server authentication eap-profile command to specify the EAP profile for the local authentication server to use.
Use the undo local-server authentication eap-profile command to remove the configuration.
Note that the specified EAP profile must already exist.
Related commands: eap-profile.
# Specify the EAP profile for the local authentication server to use as aprf1.
[Sysname] local-server authentication eap-profile aprf1
local-user user-name
undo local-user { user-name | all service-type { ftp | lan-access | ssh | telnet | terminal } }
View
Default Level
3: Manage level
user-name: Name for the local user, a case-sensitive string of 1 to 55 characters that does not contain the domain name. It cannot contain any backward slash (\), forward slash (/), vertical line (|), colon (:), asterisk (*), question mark (?), less-than sign (<), greater-than sign (>) and the @ sign and cannot be a, al, or all.
all: Specifies all users.
service-type: Specifies the users of a type.
Use the local-user command to add a local user and enter local user view.
Use the undo local-user command to remove the specified local users.
By default, no local user is configured.
Related commands: display local-user, service-type.
# Add a local user named user1.
[Sysname] local-user user1
[Sysname-luser-user1]
local-user password-display-mode { auto | cipher-force }
undo local-user password-display-mode
View
Default Level
2: System level
auto: Displays the password of a user based on the configuration of the user by using the password command.
cipher-force: Displays the passwords of all users in cipher text.
Use the local-user password-display-mode command to set the password display mode for all local users.
Use the undo local-user password-display-mode command to restore the default.
The default mode is auto.
With the cipher-force mode configured:
l A local user password is always displayed in cipher text, regardless of the configuration of the password command.
l If you use the save command to save the configuration, all existing local user passwords will still be displayed in cipher text after the device restarts, even if you restore the display mode to auto.
Related commands: display local-user, password.
# Specify to display the passwords of all users in cipher text.
[Sysname] local-user password-display-mode cipher-force
method { md5 | peap-mschapv2 | tls }
undo method { md5 | peap-mschapv2 | tls }
View
EAP profile view
Default Level
2: System level
md5: Specifies the Message Digest 5 (MD5) authentication method.
peap-mschapv2: Specifies the Protected Extensible Authentication Protocol (PEAP) together with the MSCHAPv2 for authentication in TLS tunnels.
tls: Specifies the Transport Layer Security (TLS) authentication method.
Use the method command to specify the EAP authentication method.
Use the undo method command to remove the configuration.
By default, no EAP authentication method is specified for an EAP profile.
You can specify more than one EAP authentication method for an EAP profile. An authentication method specified earlier has a higher priority.
When an EAP client and the local server communicate for EAP authentication, they first negotiate the EAP authentication method to be used. During negotiation, the local server prefers the authentication method with the highest priority among the ones specified for it. If the client supports the authentication method, the negotiation succeeds and they proceed with the authentication process. Otherwise, the local server tries the one with the next highest priority until a supported one is found, or if none of the authentication methods are found supported, the local server sends an EAP-Failure packet to the client for notification of the authentication failure.
# Create an EAP profile and specify authentication methods MD5 and PEAP-MSCHAPv2 for the profile, with PEAP-MSCHAPv2 has a higher priority.
[System-eap-prof-aprf1] method peap-mschapv2
[System-eap-prof-aprf1] method md5
password { cipher | simple } password
undo password
View
Local user view
Default Level
2: System level
cipher: Specifies to display the password in cipher text.
simple: Specifies to display the password in simple text.
password: Password for the local user.
l In simple text, it must be a string of 1 to 63 characters that contains no blank space, for example, aabbcc.
l In cipher text, it must be a string of 24 or 88 characters, for example, _(TT8F]Y\5SQ=^Q`MAF4<1!!.
l With the simple keyword, you must specify the password in simple text. With the cipher keyword, you can specify the password in either simple or cipher text.
Use the password command to configure a password for a local user.
Use the undo password command to delete the password of a local user.
Note that:
l With the local-user password-display-mode cipher-force command configured, the password is always displayed in cipher text, regardless of the configuration of the password command.
l With the cipher keyword specified, a password of up to 16 characters in plain text will be encrypted into a password of 24 characters in cipher text, and a password of 16 to 63 characters in plain text will be encrypted into a password of 88 characters in cipher text. For a password of 24 characters, if the system can decrypt the password, the system treats it as a password in cipher text. Otherwise, the system treats it as a password in plain text.
# Set the password of user1 to 123456 and specify to display the password in plain text.
[Sysname-luser-user1] password simple 123456
self-service-url enable url-string
undo self-service-url
View
ISP domain view
Default Level
2: System level
url-string: URL of the self-service server for changing user password, a string of 1 to 64 characters. It must start with http:// and contain no question mark.
Use the self-service-url enable command to enable the self-service server localization function and specify the URL of the self-service server for changing user password.
Use the undo self-service-url command to restore the default.
Note that:
l A self-service RADIUS server, for example, CAMS, is required for the self-service server localization function. With the self-service function, a user can manage and control his or her accounting information or card number. A server with self-service software is a self-service server.
l After you configure the self-service-url enable command, a user can locate the self-service server by selecting [Service/Change Password] from the 802.1x client. The client software automatically launches the default browser, IE or Netscape, and opens the URL page of the self-service server for changing the user password. A user can change his or her password through the page.
l Only authenticated users can select [Service/Change Password] from the 802.1x client. The option is gray and unavailable for unauthenticated users.
# Enable the self-service server localization function and specify the URL of the self-service server for changing user password to http://10.153.89.94/selfservice/modPasswd1x.jsp|userName for the default ISP domain system.
[Sysname-isp-system] self-service-url enable http://10.153.89.94/selfservice/modPasswd1x.jsp|userName
service-type { ftp | lan-access | { ssh | telnet | terminal } * }
undo service-type { ftp | lan-access | { ssh | telnet | terminal } * }
View
Local user view
Default Level
3: Manage level
ftp: Authorizes the user to use the FTP service. The user can use the root directory of the FTP server by default.
lan-access: Authorizes the user to use the LAN access service. Such users are mainly Ethernet users, for example, 802.1x users.
ssh: Authorizes the user to use the SSH service.
telnet: Authorizes the user to use the Telnet service.
terminal: Authorizes the user to use the terminal service, allowing the user to login from the console, AUX port.
Use the service-type command to specify the service types that a user can use.
Use the undo service-type command to delete one or all service types configured for a user.
By default, a user is authorized with no service.
# Authorize user user1 to use the Telnet service.
[Sysname-luser-user1] service-type telnet
ssl-server-policy policy-name
undo ssl-server-policy
View
EAP profile view
Default Level
2: System level
policy-name: SSL server policy name, a case-insensitive string of 1 to 16 characters.
Use the ssl-server-policy command to specify an SSL server policy for the EAP authentication.
Use the undo ssl-server-policy command to remove the configuration.
By default, no SSL server policy is specified for an EAP profile.
Note that the SSL server policy and the relevant PKI domain settings must have been configured before you specify the policy for an EAP profile. Otherwise, the command does not take effect.
# Create an EAP profile and specify an SSL server policy for it.
[System-eap-prof-aprf1] ssl-server-policy tls-server
undo state
View
ISP domain view, local user view
Default Level
2: System level
active: Places the current ISP domain or local user in the active state, allowing the users in the current ISP domain or the current local user to request network services.
block: Places the current ISP domain or local user in the blocked state, preventing users in the current ISP domain or the current local user from requesting network services.
Use the state command to configure the status of the current ISP domain or local user.
Use the undo state command to restore the default.
By default, an ISP domain is active when created. So is a local user.
By blocking an ISP domain, you disable users of the domain that are offline from requesting network services. Note that the online users are not affected.
By blocking a user, you disable the user from requesting network services. No other users are affected.
# Place the current ISP domain aabbcc.net to the state of blocked.
[Sysname-isp-aabbcc.net] state block
# Place the current user user1 to the state of blocked.
[Sysname-user-user1] state block
user-group group-name
undo user-group group-name
View
Default Level
3: Manage level
Use the user-group command to create a user group and enter its view.
Use the undo user-group command to remove a user group.
A user group consists of a group of local users and has a set of local user attributes. You can configure local user attributes for a user group to implement centralized management of user attributes for the local users in the group. Currently, you can configure password control attributes and authorization attributes for a user group.
Note that:
l A user group with one or more local users cannot be removed.
l The default system user group system cannot be removed but you can change its configurations.
Related commands: display user-group.
# Create a user group named abc and enter its view.
accounting-on enable
undo accounting-on enable
View
RADIUS scheme view
Default Level
2: System level
None
Use the accounting-on enable command to enable the accounting-on function. After doing so, when the device reboots, an accounting-on message will be sent to the RADIUS server to log out the online users of the device.
Use the undo accounting-on enable command to disable the accounting-on function.
By default, the accounting-on function is disabled.
Note that:
l Execution of this command does not affect the results of other accounting-on related commands such as accounting-on enable send.
l When you execute the accounting-on enable command, if the system has another authentication scheme already enabled with the accounting-on function, the command takes effect immediately. Otherwise, you need to save the configuration by using the save command, so that the command takes effect after the device reboots. For information about the save command, refer to File System Management Commands.
Related commands: radius scheme.
# Enable the accounting-on function for RADIUS authentication scheme rd.
[Sysname] radius scheme rd
[Sysname-radius-rd] accounting-on enable
accounting-on enable interval seconds
undo accounting-on interval
View
RADIUS scheme view
Default Level
2: System level
seconds: Time interval to retransmit accounting-on packet in seconds, ranging from 1 to 15.
Use the accounting-on enable interval command to configure the retransmission interval of accounting-on packets.
Use the undo accounting-on enable interval command to restore the default.
By default, the retransmission interval of accounting-on packets is 3 seconds.
Note that:
l Execution of this command does not affect the results of other accounting-on related commands such as accounting-on enable. That is, execution of the undo accounting-on enable interval command will not disable the accounting-on function.
l The retransmission interval configured with this command takes effect immediately.
Related commands: radius scheme, accounting-on enable.
# In RADIUS scheme rd, set the retransmission interval of accounting-on packet to 5 seconds.
[Sysname-radius-rd] accounting-on enable interval 5
accounting-on enable send send-times
undo accounting-on send
View
RADIUS scheme view
Default Level
2: System level
send-times: Maximum number of accounting-on packet transmission attempts, ranging from 1 to 255.
Use the accounting-on enable send command to set the maximum number of accounting-on packet transmission attempts.
Use the undo accounting-on enable send command to restore the default.
By default, the maximum number of accounting-on packet transmission attempts is 5.
Note that:
l The maximum number of accounting-on packet transmission attempts configured with this command takes effect immediately.
# In RADIUS scheme rd, set the maximum number of accounting-on packet transmission attempts to 10.
[Sysname-radius-rd] accounting-on enable send 10
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
View
RADIUS scheme view
Default Level
2: System level
data: Specifies the unit for data flows, which can be byte, kilobyte, megabyte, or gigabyte.
packet: Specifies the unit for data packets, which can be one-packet, kilo-packet, mega-packet, or giga-packet.
Use the data-flow-format command to specify the unit for data flows or packets to be sent to a RADIUS server.
Use the undo data-flow-format command to restore the default.
By default, the unit for data flows is byte and that for data packets is one-packet.
Note that:
l The specified unit of data flows sent to the RADIUS server must be consistent with the traffic statistics unit of the RADIUS server. Otherwise, accounting cannot be performed correctly.
l You can use the commands to change the settings only when no user is using the RADIUS scheme.
Related commands: display radius scheme.
# Define RADIUS scheme radius1 to send data flows and packets destined for the RADIUS server in kilobytes and kilo-packets.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
display radius scheme [ radius-scheme-name ]
View
Default Level
2: System level
radius-scheme-name: RADIUS scheme name.
Use the display radius scheme command to display the configuration information of a specified RADIUS scheme or all RADIUS schemes.
Note that: If no RADIUS scheme is specified, the command will display the configurations of all RADIUS schemes.
# Display the configurations of all RADIUS schemes.
<Sysname> display radius scheme
SchemeName : radius1
Index : 0 Type : extended
Primary Auth IP : 1.1.1.1 Port : 1812 State : active
Primary Acct IP : 1.1.1.1 Port : 1813 State : active
Second Auth IP : 0.0.0.0 Port : 1812 State : block
Second Acct IP : 0.0.0.0 Port : 1813 State : block
Auth Server Encryption Key : 123
Acct Server Encryption Key : Not configured
Accounting-On packet disable, send times : 5 , interval : 3s
Interval for timeout(second) : 3
Retransmission times for timeout : 3
Interval for realtime accounting(minute) : 12
Retransmission times of realtime-accounting packet : 5
Retransmission times of stop-accounting packet : 500
Quiet-interval(min) : 5
Username format : without-domain
Data flow unit : Byte
Packet unit : one
Total 1 RADIUS scheme(s).
Table 2-1 display radius scheme command output description
SchemeName |
Name of the RADIUS scheme |
Index |
Index number of the RADIUS scheme |
Type |
Type of the RADIUS server |
Primary Auth IP/ Port/ State |
IP address/access port number/current status of the primary authentication server: (active or block) If there is no primary authentication server specified, the IP address is 0.0.0.0 and the port number is the default. This rule is also applicable to the following three fields. |
Primary Acct IP/ Port/ State |
IP address/access port number/current status of the primary accounting server: (active or block) |
Second Auth IP/ Port/ State |
IP address/access port number/current status of the secondary authentication server: (active or block) |
Second Acct IP/ Port/ State |
IP address/access port number/current status of the secondary accounting server: (active or block) |
Auth Server Encryption Key |
Shared key of the authentication server |
Acct Server Encryption Key |
Shared key of the accounting server |
Accounting-On packet disable |
The accounting-on function is disabled |
send times |
Retransmission times of accounting-on packets |
interval |
Interval to retransmit accounting-on packets |
Interval for timeout(second) |
Timeout time in seconds |
Retransmission times for timeout |
Times of retransmission in case of timeout |
Interval for realtime accounting(minute) |
Interval for realtime accounting in minutes |
Retransmission times of realtime-accounting packet |
Retransmission times of stop-accounting packet |
Quiet-interval(min) |
Quiet interval for the primary server |
Username format |
Format of the username |
Data flow unit |
Unit of data flows |
Packet unit |
Unit of packets |
Total 1 RADIUS scheme(s) |
1 RADIUS scheme in total |
display radius statistics
View
Default Level
2: System level
None
Use the display radius statistics command to display statistics about RADIUS packets.
# Display statistics about RADIUS packets.
<Sysname> display radius statistics
state statistic(total=18000):
DEAD = 18000 AuthProc = 0 AuthSucc = 0
AcctStart = 0 RLTSend = 0 RLTWait = 0
AcctStop = 0 OnLine = 0 Stop = 0
Received and Sent packets statistic:
Sent PKT total = 1547 Received PKT total = 23
RADIUS received packets statistic:
Code = 2 Num = 15 Err = 0
Code = 3 Num = 4 Err = 0
Code = 5 Num = 4 Err = 0
Code = 11 Num = 0 Err = 0
Running statistic:
RADIUS received messages statistic:
Normal auth request Num = 24 Err = 0 Succ = 24
EAP auth request Num = 0 Err = 0 Succ = 0
Account request Num = 4 Err = 0 Succ = 4
Account off request Num = 503 Err = 0 Succ = 503
PKT auth timeout Num = 15 Err = 5 Succ = 10
PKT acct_timeout Num = 1509 Err = 503 Succ = 1006
Realtime Account timer Num = 0 Err = 0 Succ = 0
PKT response Num = 23 Err = 0 Succ = 23
Session ctrl pkt Num = 0 Err = 0 Succ = 0
Normal author request Num = 0 Err = 0 Succ = 0
Set policy result Num = 0 Err = 0 Succ = 0
RADIUS sent messages statistic:
Auth accept Num = 10
Auth reject Num = 14
EAP auth replying Num = 0
Account success Num = 4
Account failure Num = 3
Server ctrl req Num = 0
RecError_MSG_sum = 0
SndMSG_Fail_sum = 0
Timer_Err = 0
Alloc_Mem_Err = 0
State Mismatch = 0
Other_Error = 0
No-response-acct-stop packet = 1
Discarded No-response-acct-stop packet for buffer overflow = 0
Table 2-2 display radius statistics command output description
state statistic |
state statistics |
DEAD |
Number of idle users |
AuthProc |
Number of users waiting for authentication |
AuthSucc |
Number of users who have passed authentication |
AcctStart |
Number of users for whom accounting has been started |
RLTSend |
Number of users for whom the system sends real-time accounting packets |
RLTWait |
Number of users waiting for real-time accounting |
AcctStop |
Number of users in the state of accounting waiting stopped |
OnLine |
Number of online users |
Stop |
Number of users in the state of stop |
Received and Sent packets statistic |
Statistics of packets received and sent |
Sent PKT total |
Number of packets sent |
Received PKT total |
Number of packets received |
RADIUS received packets statistic |
Statistics of packets received by RADIUS |
Code |
Packet type |
Num |
Total number of packets |
Err |
Number of error packets |
Running statistic |
RADIUS operation message statistics |
RADIUS received messages statistic |
Number of messages received by RADIUS |
Normal auth request |
Number of normal authentication requests |
EAP auth request |
Number of EAP authentication requests |
Account request |
Number of accounting requests |
Account off request |
Number of stop-accounting requests |
PKT auth timeout |
Number of authentication timeout messages |
PKT acct_timeout |
Number of accounting timeout messages |
Realtime Account timer |
Number of realtime accounting requests |
PKT response |
Number of responses |
Session ctrl pkt |
Number of session control messages |
Normal author request |
Number of normal authorization requests |
Succ |
Number of acknowledgement messages |
Set policy result |
Number of responses to the Set policy packets |
RADIUS sent messages statistic |
Number of messages that have been sent by RADIUS |
Auth accept |
Number of accepted authentication packets |
Auth reject |
Number of rejected authentication packets |
EAP auth replying |
Number of replying packets of EAP authentication |
Account success |
Number of accounting succeeded packets |
Account failure |
Number of accounting failed packets |
Server ctrl req |
Number of server control requests |
RecError_MSG_sum |
Number of received packets in error |
SndMSG_Fail_sum |
Number of packets that failed to be sent out |
Timer_Err |
Number of timer errors |
Alloc_Mem_Err |
Number of memory errors |
State Mismatch |
Number of errors for mismatching status |
Other_Error |
Number of errors of other types |
No-response-acct-stop packet |
Number of times that no response was received for stop-accounting packets |
Discarded No-response-acct-stop packet for buffer overflow |
Number of stop-accounting packets that were buffered but then discarded due to full memory |
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name }
View
Default Level
2: System level
session-id session-id: Specifies a session by its ID. The ID is a string of 1 to 50 characters.
time-range start-time stop-time: Specifies a time range by its start time and end time in the format of hh:mm:ss-mm/dd/yyyy or hh:mm:ss-yyyy/mm/dd.
user-name user-name: Specifies a user by the user name, which is a case-sensitive string of 1 to 80 characters. Whether the user-name argument should include the domain name depends on the setting by the user-name-format command for the RADIUS scheme.
Use the display stop-accounting-buffer command to display information about the stop-accounting requests buffered in the device by scheme, session ID, time range, user name.
Note that if receiving no response after sending a stop-accounting request to a RADIUS server, the device buffers the request and retransmits it. You can use the retry stop-accounting command to set the number of allowed transmission attempts.
Related commands: reset stop-accounting-buffer, stop-accounting-buffer enable, user-name-format, retry stop-accounting.
# Display information about the buffered stop-accounting requests from 0:0:0 to 23:59:59 on August 31, 2006.
<Sysname> display stop-accounting-buffer time-range 0:0:0-08/31/2006 23:59:59-08/31/2006
Total find 0 record (0)
eap offload method peap-mschapv2
undo eap offload method peap-mschapv2
View
RADIUS scheme view
Default Level
2: System level
method peap-mschapv2: Specifies the EAP authentication method. Currently, only PEAP-MSCHAPv2 authentication is supported.
Use the eap offload command to configure the EAP offload function.
Use the undo eap offload command to cancel the EAP offload function.
By default, the EAP offload function is disabled.
As some RADIUS servers do not support EAP authentication, it is necessary to configure the EAP offload function for a RADIUS scheme that uses such a RADIUS server. Later, the access device will process received EAP authentication requests from its clients before forwarding the requests to the RADIUS server for authentication. By default, an access device forwards received EAP authentication requests in pass-through mode; it does not perform offload operations.
# Configure the EAP offload function for RADIUS scheme rd1.
[Sysname] radius scheme rd1
[Sysname-radius-rd1] eap offload method peap-mschapv2
key { accounting | authentication } string
undo key { accounting | authentication }
View
RADIUS scheme view
Default Level
2: System level
accounting: Sets the shared key for RADIUS accounting packets.
authentication: Sets the shared key for RADIUS authentication/authorization packets.
string: Shared key, a case-sensitive string of 1 to 64 characters.
Use the key command to set the shared key for RADIUS authentication/authorization or accounting packets.
Use the undo key command to restore the default.
By default, no shared key is configured.
Note that:
l You must ensure that the same shared key is set on the device and the RADIUS server.
# Set the shared key for authentication/authorization packets to hello for RADIUS scheme radius1.
[Sysname-radius-radius1] key authentication hello
# Set the shared key for accounting packets to ok for RADIUS scheme radius1.
[Sysname-radius-radius1] key accounting ok
nas-ip ip-address
undo nas-ip
View
RADIUS scheme view
Default Level
2: System level
ip-address: IP address in dotted decimal notation. It must be an address of the device and cannot be all 0s address, all 1s address, a class D address, a class E address or a loopback address.
Use the nas-ip command to set the IP address for the device to use as the source address of the RADIUS packets to be sent to the server.
Use the undo nas-ip command to remove the configuration.
By default, the source IP address of a packet sent to the server is that configured by the radius nas-ip command in system view.
Note that:
l Specifying a source address for the RADIUS packets to be sent to the server can avoid the situation where the packets sent back by the RADIUS server cannot reach the device as the result of a physical interface failure. The address of a loopback interface is recommended.
l The nas-ip command in RADIUS scheme view is only for the current RADIUS scheme, while the radius nas-ip command in system view is for all RADIUS schemes. However, the nas-ip command in RADIUS scheme view overwrites the configuration of the radius nas-ip command.
Related commands: radius nas-ip.
# Set the IP address for the device to use as the source address of the RADIUS packets to 10.1.1.1.
[Sysname] radius scheme test1
[Sysname-radius-test1] nas-ip 10.1.1.1
primary accounting ip-address [ port-number ]
undo primary accounting
View
RADIUS scheme view
Default Level
2: System level
ip-address: IP address of the primary accounting server.
port-number: UDP port number of the primary accounting server, which ranges from 1 to 65535 and defaults to 1813.
Use the primary accounting command to specify the primary RADIUS accounting server.
Use the undo primary accounting command to remove the configuration.
By default, no primary RADIUS accounting server is specified.
Note that:
l The IP addresses of the primary and secondary accounting servers cannot be the same. Otherwise, the configuration fails.
l The RADIUS service port configured on the device and that of the RADIUS server must be consistent.
Related commands: key, radius scheme, state.
# Specify the IP address of the primary accounting server for RADIUS scheme radius1 as 10.110.1.2 and the UDP port of the server as 1813.
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813
primary authentication ip-address [ port-number ]
undo primary authentication
View
RADIUS scheme view
Default Level
2: System level
ip-address: IP address of the primary authentication/authorization server.
port-number: UDP port number of the primary authentication/authorization server, which ranges from 1 to 65535 and defaults to 1812.
Use the primary authentication command to specify the primary RADIUS authentication/authorization server.
Use the undo primary authentication command to remove the configuration.
By default, no primary RADIUS authentication/authorization server is specified.
Note that:
l After creating a RADIUS scheme, you are supposed to configure the IP address and UDP port of each RADIUS server (primary/secondary authentication/authorization or accounting server). Ensure that at least one authentication/authorization server and one accounting server are configured, and that the RADIUS service port settings on the device are consistent with the port settings on the RADIUS servers.
l The IP addresses of the primary and secondary authentication/authorization servers cannot be the same. Otherwise, the configuration fails.
# Specify the primary authentication/authorization server for RADIUS scheme radius1.
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812
radius client enable
undo radius client
View
Default Level
2: System level
None
Use the radius client enable command to enable the listening port of the RADIUS client.
Use the undo radius client command to disable the listening port of the RADIUS client.
By default, the listening port is enabled.
Note that when the listening port of the RADIUS client is disabled:
l The RADIUS client can either accept authentication, authorization or accounting requests or process timer messages. However, it fails to transmit and receive packets to and from the RADIUS server.
l The end account packets of online users cannot be sent out and buffered. This may cause a problem that the RADIUS server still has the user record after a user goes offline for a period of time.
l The authentication, authorization and accounting turn to the local scheme after the RADIUS request fails if the RADIUS scheme and the local authentication, authorization and accounting scheme are configured.
l The buffered accounting packets cannot be sent out and will be deleted from the buffer when the configured maximum number of attempts is reached.
# Enable the listening port of the RADIUS client.
[Sysname] radius client enable
radius nas-ip ip-address
undo radius nas-ip
View
Default Level
2: System level
Use the radius nas-ip command to set the IP address for the device to use as the source address of the RADIUS packets to be sent to the server.
Use the undo radius nas-ip command to remove the configuration.
By default, the source IP address of a packet sent to the server is the IP address of the outbound port.
Note that:
l If you configure the command for more than one time, the last configuration takes effect.
Related commands: nas-ip.
# Set the IP address for the device to use as the source address of the RADIUS packets to 129.10.10.1.
[Sysname] radius nas-ip 129.10.10.1
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
View
Default Level
3: Manage level
radius-scheme-name: RADIUS scheme name, a case-insensitive string of 1 to 32 characters.
Use the radius scheme command to create a RADIUS scheme and enter RADIUS scheme view.
Use the undo radius scheme command to delete a RADIUS scheme.
By default, no RADIUS scheme is defined.
Note that:
l The RADIUS protocol is configured scheme by scheme. Every RADIUS scheme must at least specify the IP addresses and UDP ports of the RADIUS authentication/authorization/accounting servers and the parameters necessary for a RADIUS client to interact with the servers.
l A RADIUS scheme can be referenced by more than one ISP domain at the same time.
l You cannot remove the RADIUS scheme being used by online users with the undo radius scheme command.
Related commands: key, retry realtime-accounting, timer realtime-accounting, stop-accounting-buffer enable, retry stop-accounting, server-type, state, user-name-format, retry, display radius scheme, display radius statistics.
# Create a RADIUS scheme named radius1 and enter RADIUS scheme view.
radius trap { accounting-server-down | authentication-server-down }
undo radius trap { accounting-server-down | authentication-server-down }
View
Default Level
2: System level
accounting-server-down: RADIUS trap for accounting servers.
authentication-server-down: RADIUS trap for authentication servers.
Use the radius trap command to enable the RADIUS trap function.
Use the undo radius trap command to disable the function.
By default, the RADIUS trap function is disabled.
Note that:
l If a NAS sends an accounting or authentication request to the RADIUS server but gets no response, the NAS retransmits the request. With the RADIUS trap function enabled, when the NAS transmits the request for half of the specified maximum number of transmission attempts, it sends a trap message; when the NAS transmits the request for the specified maximum number, it sends another trap message.
l If the specified maximum number of transmission attempts is odd, the half of the number refers to the smallest integer greater than the half of the number.
# Enable the RADIUS trap function for accounting servers.
[Sysname] radius trap accounting-server-down
reset radius statistics
View
Default Level
2: System level
None
Use the reset radius statistics command to clear RADIUS statistics.
# Clear RADIUS statistics.
<Sysname> reset radius statistics
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name }
View
Default Level
2: System level
radius-scheme radius-scheme-name: Specifies a RADIUS scheme by its name, a string of 1 to 32 characters.
session-id session-id: Specifies a session by its ID, a string of 1 to 50 characters.
user-name user-name: Specifies a user name based on which to reset the stop-accounting buffer. The username is a case-sensitive string of 1 to 80 characters. The format of the user-name argument (for example, whether the domain name should be included) must comply with that specified for usernames to be sent to the RADIUS server in the RADIUS scheme.
Use the reset stop-accounting-buffer command to clear the buffered stop-accounting requests, which get no responses.
Related commands: stop-accounting-buffer enable, retry stop-accounting, user-name-format, display stop-accounting-buffer.
# Clear the buffered stop-accounting requests for user [email protected].
<Sysname> reset stop-accounting-buffer user-name [email protected]
# Clear the buffered stop-accounting requests in the time range from 0:0:0 to 23:59:59 on August 31, 2006.
<Sysname> reset stop-accounting-buffer time-range 0:0:0-08/31/2006 23:59:59-08/31/2006
retry retry-times
undo retry
View
RADIUS scheme view
Default Level
2: System level
retry-times: Maximum number of transmission attempts, in the range 1 to 20.
Use the retry command to set the maximum number of RADIUS transmission attempts.
Use the undo retry command to restore the default.
The default value for the retry-times argument is 3.
Note that:
l As RADIUS uses UDP packets to transmit data, the communication is not reliable. If the device does not receive a response to its request from the RADIUS server within the response timeout time, it will retransmit the RADIUS request. If the number of transmission attempts exceeds the limit but the device still receives no response from the RADIUS server, the device regards that the authentication fails.
l The maximum number of transmission attempts defined by this command refers to the sum of all transmission attempts sent by the device to the primary server and the secondary server. For example, assume that the maximum number of transmission attempts is N and both the primary server and secondary RADIUS server are specified and exist, the device will send a request to the other server if the current server does not respond after the sum of transmission attempts reaches N/2 (if N is an even number) or (N+1)/2 (if N is an odd number).
l The maximum number of transmission attempts multiplied by the RADIUS server response timeout period cannot be greater than 75.
Related commands: radius scheme, timer response-timeout.
# Set the maximum number of RADIUS request transmission attempts to 5 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry 5
retry realtime-accounting retry-times
undo retry realtime-accounting
View
RADIUS scheme view
Default Level
2: System level
retry-times: Maximum number of accounting request transmission attempts. It ranges from 1 to 255 and defaults to 5.
Use the retry realtime-accounting command to set the maximum number of accounting request transmission attempts.
Use the undo retry realtime-accounting command to restore the default.
Note that:
l A RADIUS server usually checks whether a user is online by a timeout timer. If it receives from the NAS no real-time accounting packet for a user in the timeout period, it considers that there may be line or device failure and stops accounting for the user. This may happen when some unexpected failure occurs. In this case, the NAS is required to disconnect the user in accordance. This is done by the maximum number of accounting request transmission attempts. Once the limit is reached but the NAS still receives no response, the NAS disconnects the user.
l Suppose that the RADIUS server response timeout period is 3 seconds (set with the timer response-timeout command), the timeout retransmission attempts is 3 (set with the retry command), and the real-time accounting interval is 12 minutes (set with the timer realtime-accounting command), and the maximum number of accounting request transmission attempts is 5 (set with the retry realtime-accounting command). In such a case, the device generates an accounting request every 12 minutes, and retransmits the request when receiving no response within 3 seconds. The accounting is deemed unsuccessful if no response is received within 3 requests. Then the device sends a request every 12 minutes, and if for 5 times it still receives no response, the device will cut the user connection.
Related commands: radius scheme, timer realtime-accounting.
# Set the maximum number of accounting request transmission attempts to 10 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry realtime-accounting 10
retry stop-accounting retry-times
undo retry stop-accounting
View
RADIUS scheme view
Default Level
2: System level
retry-times: Maximum number of stop-accounting request transmission attempts. It ranges from 10 to 65,535 and defaults to 500.
Use the retry stop-accounting command to set the maximum number of stop-accounting request transmission attempts.
Use the undo retry stop-accounting command to restore the default.
l Suppose that the RADIUS server response timeout period is 3 seconds (set with the timer response-timeout command), the timeout retransmission attempts is 5 (set with the retry command), and the maximum number of stop-accounting request transmission attempts is 20 (set with the retry stop-accounting command). This means that for each stop-accounting request, if the device receives no response within 3 seconds, it will initiate a new request. If still no responses are received within 5 renewed requests, the stop-accounting request is deemed unsuccessful. Then the device will temporarily store the request in the device and resend a request and repeat the whole process described above. Only when 20 consecutive attempts fail will the device discard the request.
Related commands: reset stop-accounting-buffer, radius scheme, display stop-accounting-buffer.
# Set the maximum number of stop-accounting request transmission attempts to 1,000 for RADIUS scheme radius1.
[Sysname-radius-radius1] retry stop-accounting 1000
secondary accounting ip-address [ port-number ]
undo secondary accounting
View
RADIUS scheme view
Default Level
2: System level
ip-address: IP address of the secondary accounting server, in dotted decimal notation. The default is 0.0.0.0.
port-number: UDP port number of the secondary accounting server, which ranges from 1 to 65535 and defaults to 1813.
Use the secondary accounting command to specify the secondary RADIUS accounting server.
Use the undo secondary accounting command to remove the configuration.
By default, no secondary RADIUS accounting server is specified.
Note that:
# Specify the secondary accounting server for RADIUS scheme radius1.
[Sysname-radius-radius1] secondary accounting 10.110.1.1 1813
secondary authentication ip-address [ port-number ]
undo secondary authentication
View
RADIUS scheme view
Default Level
2: System level
ip-address: IP address of the secondary authentication/authorization server, in dotted decimal notation. The default is 0.0.0.0.
port-number: UDP port number of the secondary authentication/authorization server, which ranges from 1 to 65535 and defaults to 1812.
Use the secondary authentication command to specify the secondary RADIUS authentication/authorization server.
Use the undo secondary authentication command to remove the configuration.
By default, no secondary RADIUS authentication/authorization server is specified.
Note that:
# Specify the secondary authentication/authorization server for RADIUS scheme radius1.
[Sysname-radius-radius1] secondary authentication 10.110.1.2 1812
server-type { extended | standard }
undo server-type
View
RADIUS scheme view
Default Level
2: System level
extended: Specifies the extended RADIUS server (generally CAMS), which requires the RADIUS client and RADIUS server to interact according to the procedures and packet formats provisioned by the private RADIUS protocol.
standard: Specifies the standard RADIUS server, which requires the RADIUS client end and RADIUS server to interact according to the regulation and packet format of the standard RADIUS protocol (RFC 2865/2866 or newer).
Use the server-type command to specify the RADIUS server type supported by the device.
Use the undo server-type command to restore the default.
By default, the supported RADIUS server type is standard.
Note that you can use the commands to change the setting only when no user is using the RADIUS scheme.
# Set the RADIUS server type of RADIUS scheme radius1 to standard.
[Sysname-radius-radius1] server-type standard
state { primary | secondary } { accounting | authentication } { active | block }
View
RADIUS scheme view
Default Level
2: System level
primary: Sets the status of the primary RADIUS server.
secondary: Sets the status of the secondary RADIUS server.
accounting: Sets the status of the RADIUS accounting server.
authentication: Sets the status of the RADIUS authentication/authorization server.
active: Sets the status of the RADIUS server to active, namely the normal operation state.
block: Sets the status of the RADIUS server to block.
Use the state command to set the status of a RADIUS server.
By default, every RADIUS server configured with an IP address in the RADIUS scheme is in the state of active.
Note that:
l When a primary server, authentication/authorization server or accounting server, fails, the device automatically turns to the secondary server.
l Once the primary server fails, the primary server turns into the blocked state, and the device turns to the secondary server. In this case, if the secondary server is available, the device triggers the primary server quiet timer. After the quiet timer times out, the status of the primary server is active again and the status of the secondary server remains the same. If the secondary server fails, the device restores the status of the primary server to active immediately. If the primary server has resumed, the device turns to use the primary server and stops communicating with the secondary server. After accounting starts, the communication between the client and the secondary server remains unchanged.
l When both the primary server and the secondary server are in the state of blocked, you need to set the status of the secondary server to active to use the secondary server for authentication. Otherwise, the switchover will not occur.
l If one server is in the active state while the other is blocked, the switchover will not take place even if the active server is not reachable.
l You can use this command to change the settings only when no user is using the RADIUS scheme.
Related commands: radius scheme, primary authentication, secondary authentication, primary accounting, secondary accounting.
# Set the status of the secondary server in RADIUS scheme radius1 to active.
[Sysname-radius-radius1] state secondary authentication active
undo stop-accounting-buffer enable
View
RADIUS scheme view
Default Level
2: System level
None
Use the stop-accounting-buffer enable command to enable the device to buffer stop-accounting requests getting no responses.
Use the undo stop-accounting-buffer enable command to disable the device from buffering stop-accounting requests getting no responses.
By default, the device is enabled to buffer stop-accounting requests getting no responses.
Since stop-accounting requests affect the charge to users, a NAS must make its best effort to send every stop-accounting request to the RADIUS accounting servers. For each stop-accounting request getting no response in the specified period of time, the NAS buffers and resends the packet until it receives a response or the number of transmission retries reaches the configured limit. In the latter case, the NAS discards the packet.
# In RADIUS scheme radius1, enable the device to buffer the stop-accounting requests getting no responses.
[Sysname-radius-radius1] stop-accounting-buffer enable
timer quiet minutes
undo timer quiet
View
RADIUS scheme view
Default Level
2: System level
minutes: Primary server quiet period, in minutes. It ranges from 1 to 255 and defaults to 5.
Use the timer quiet command to set the quiet timer for the primary server, that is, the duration that the status of the primary server stays blocked before resuming the active state.
Use the undo timer quiet command to restore the default.
# Set the quiet timer for the primary server to 10 minutes.
[Sysname-radius-test1] timer quiet 10
timer realtime-accounting minutes
undo timer realtime-accounting
View
RADIUS scheme view
Default Level
2: System level
minutes: Real-time accounting interval in minutes, must be a multiple of 3 and in the range 3 to 60, with the default value being 12.
Use the timer realtime-accounting command to set the real-time accounting interval.
Use the undo timer realtime-accounting command to restore the default.
Note that:
l For real-time accounting, a NAS must transmit the accounting information of online users to the RADIUS accounting server periodically. This command is for setting the interval.
l The setting of the real-time accounting interval somewhat depends on the performance of the NAS and the RADIUS server: a shorter interval means higher accounting precision but requires higher performance. You are therefore recommended to adopt a longer interval when there are a large number of users (1000 or more). The following table lists the recommended ratios of the interval to the number of users.
Table 2-3 Recommended ratios of the accounting interval to the number of users
Number of users |
Real-time accounting interval (minute) |
1 to 99 |
3 |
100 to 499 |
6 |
500 to 999 |
12 |
1000 or more |
15 or more |
Related commands: retry realtime-accounting, radius scheme.
# Set the real-time accounting interval to 51 minutes for RADIUS scheme radius1.
[Sysname-radius-radius1] timer realtime-accounting 51
timer response-timeout seconds
undo timer response-timeout
View
RADIUS scheme view
Default Level
2: System level
seconds: RADIUS server response timeout period in seconds. It ranges from 1 to 10 and defaults to 3.
Use the timer response-timeout command to set the RADIUS server response timeout timer.
Use the undo timer command to restore the default.
Note that:
l If a NAS receives no response from the RADIUS server in a period of time after sending a RADIUS request (authentication/authorization or accounting request), it has to resend the request so that the user has more opportunity to obtain the RADIUS service. The NAS uses the RADIUS server response timeout timer to control the transmission interval.
l A proper value for the RADIUS server response timeout timer can help improve the system performance. Set the timer based on the network conditions.
l The maximum total number of all types of retransmission attempts multiplied by the RADIUS server response timeout period cannot be greater than 75.
Related commands: radius scheme, retry.
# Set the RADIUS server response timeout timer to 5 seconds for RADIUS scheme radius1.
[Sysname-radius-radius1] timer response-timeout 5
user-name-format { keep-original | with-domain | without-domain }
View
RADIUS scheme view
Default Level
2: System level
keep-original: Sends the username to the RADIUS server as it is input.
with-domain: Includes the ISP domain name in the username sent to the RADIUS server.
without-domain: Excludes the ISP domain name from the username sent to the RADIUS server.
Use the user-name-format command to specify the format of the username to be sent to a RADIUS server.
By default, the ISP domain name is included in the username.
Note that:
l A username is generally in the format of userid@isp-name, of which isp-name is used by the device to determine the ISP domain to which a user belongs. Some earlier RADIUS servers, however, cannot recognize a username including an ISP domain name. Before sending a username including a domain name to such a RADIUS server, the device must remove the domain name. This command is thus provided for you to decide whether to include a domain name in a username to be sent to a RADIUS server.
l If a RADIUS scheme defines that the username is sent without the ISP domain name, do not apply the RADIUS scheme to more than one ISP domain, thus avoiding the confused situation where the RADIUS server regards two users in different ISP domains but with the same user ID as one.
l When 802.1x users use EAP authentication, the user-name-format command configured for a RADIUS scheme does not take effect and the device does not change the usernames from clients when forwarding them to the RADIUS server.
l If the RADIUS scheme is for wireless users, specify the keep-original keyword. Otherwise, authentication of the wireless users may fail.
l You can use this command to change the setting only when no user is using the RADIUS scheme.
# Specify the device to remove the domain name in the username sent to the RADIUS servers for the RADIUS scheme radius1.
[Sysname-radius-radius1] user-name-format without-domain
View
HWTACACS scheme view
Default Level
2: System level
Use the data-flow-format command to specify the unit for data flows or packets to be sent to a HWTACACS server.
Related commands: display hwtacacs.
# Define HWTACACS scheme hwt1 to send data flows and packets destined for the TACACS server in kilobytes and kilo-packets.
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
display hwtacacs [ hwtacacs-scheme-name [ statistics ] ]
View
Default Level
2: System level
hwtacacs-scheme-name: HWTACACS scheme name.
statistics: Displays complete statistics about the HWTACACS server.
Use the display hwtacacs command to display configuration information or statistics of the specified or all HWTACACS schemes.
Note that: If no HWTACACS scheme is specified, the command will display the configuration information of all HWTACACS schemes.
Related commands: hwtacacs scheme.
# Display configuration information about HWTACACS scheme gy.
HWTACACS-server template name : gy
Primary-authentication-server : 172.31.1.11:49
Primary-authorization-server : 172.31.1.11:49
Primary-accounting-server : 172.31.1.11:49
Secondary-authentication-server : 0.0.0.0:0
Secondary-authorization-server : 0.0.0.0:0
Secondary-accounting-server : 0.0.0.0:0
Current-authentication-server : 172.31.1.11:49
Current-authorization-server : 172.31.1.11:49
Current-accounting-server : 172.31.1.11:49
NAS-IP-address : 0.0.0.0
key authentication : 790131
key authorization : 790131
key accounting : 790131
Realtime-accounting-interval(min) : 12
Response-timeout-interval(sec) : 5
Acct-stop-PKT retransmit times : 100
Username format : with-domain
Data traffic-unit : B
Packet traffic-unit : one-packet
Table 3-1 display hwtacacs command output description
HWTACACS-server template name |
Name of the HWTACACS scheme |
Primary-authentication-server |
IP address and port number of the primary authentication server. If there is no primary authentication server specified, the value of this field is 0.0.0.0:0. This rule is also applicable to the following eight fields. |
Primary-authorization-server |
IP address and port number of the primary authorization server |
Primary-accounting-server |
IP address and port number of the primary accounting server |
Secondary-authentication-server |
IP address and port number of the secondary authentication server |
Secondary-authorization-server |
IP address and port number of the secondary authorization server |
Secondary-accounting-server |
IP address and port number of the secondary accounting server |
Current-authentication-server |
IP address and port number of the currently used authentication server |
Current-authorization-server |
IP address and port number of the currently used authorization server |
Current-accounting-server |
IP address and port number of the currently used accounting server |
NAS-IP-address |
IP address of the NAS If no NAS is specified, the value of this field is 0.0.0.0. |
key authentication |
Key for authentication |
key authorization |
Key for authorization |
key accounting |
Key for accounting |
Quiet-interval |
Realtime-accounting-interval |
Real-time accounting interval |
Response-timeout-interval |
Server response timeout period |
Acct-stop-PKT retransmit times |
Number of stop-accounting packet transmission retries |
Username format |
Whether a user name includes the domain name |
Data traffic-unit |
Unit for data flows |
Packet traffic-unit |
Unit for data packets |
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
View
Default Level
2: System level
hwtacacs-scheme hwtacacs-scheme-name: Specifies a HWTACACS scheme by its name, a string of 1 to 32 characters.
Use the display stop-accounting-buffer command to display information about the stop-accounting requests buffered in the device.
Related commands: reset stop-accounting-buffer, stop-accounting-buffer enable, retry stop-accounting.
# Display information about the buffered stop-accounting requests for HWTACACS scheme hwt1.
<Sysname> display stop-accounting-buffer hwtacacs-scheme hwt1
Total 0 record(s) Matched
hwtacacs nas-ip ip-address
undo hwtacacs nas-ip
View
Default Level
2: System level
Use the hwtacacs nas-ip command to set the IP address for the device to use as the source address of the HWTACACS packets to be sent to the server.
Use the undo hwtacacs nas-ip command to remove the configuration.
Note that:
l Specifying a source address for the HWTACACS packets to be sent to the server can avoid the situation where the packets sent back by the HWTACACS server cannot reach the device as the result of a physical interface failure.
l The nas-ip command in HWTACACS scheme view is only for the current HWTACACS scheme, while the hwtacacs nas-ip command in system view is for all HWTACACS schemes. However, the nas-ip command in HWTACACS scheme view overwrites the configuration of the hwtacacs nas-ip command.
# Set the IP address for the device to use as the source address of the HWTACACS packets to 129.10.10.1.
[Sysname] hwtacacs nas-ip 129.10.10.1
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
View
Default Level
3: Manage level
hwtacacs-scheme-name: HWTACACS scheme name, a case-insensitive string of 1 to 32 characters.
Use the hwtacacs scheme command to create an HWTACACS scheme and enter HWTACACS scheme view.
Use the undo hwtacacs scheme command to delete an HWTACACS scheme.
By default, no HWTACACS scheme exists.
Note that you cannot delete an HWTACACS scheme with online users.
# Create an HWTACACS scheme named hwt1 and enter HWTACACS scheme view.
key { accounting | authentication | authorization } string
undo key { accounting | authentication | authorization } string
View
Default Level
2: System level
accounting: Sets the shared key for HWTACACS accounting packets.
authentication: Sets the shared key for HWTACACS authentication packets.
authorization: Sets the shared key for HWTACACS authorization packets.
string: Shared key, a string of 1 to 16 characters.
Use the key command to set the shared key for HWTACACS authentication, authorization, or accounting packets.
Use the undo key command to remove the configuration.
# Set the shared key for HWTACACS accounting packets to hello for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] key accounting hello
nas-ip ip-address
undo nas-ip
View
Default Level
2: System level
Use the nas-ip command to set the IP address for the device to use as the source address of the HWTACACS packets to be sent to the server.
Note that:
Related commands: hwtacacs nas-ip.
# Set the IP address for the device to use as the source address of the HWTACACS packets to 10.1.1.1.
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
View
Default Level
2: System level
ip-address: IP address of the server, a valid unicast address in dotted decimal notation. The default is 0.0.0.0.
port-number: Port number of the server. It ranges from 1 to 65535 and defaults to 49.
Use the primary accounting command to specify the primary HWTACACS accounting server.
By default, no primary HWTACACS accounting server is specified.
Note that:
l The HWTACACS service port configured on the device and that of the HWTACACS server must be consistent.
l You can remove an accounting server only when no active TCP connection for sending accounting packets is using it.
# Specify the primary accounting server.
[Sysname] hwtacacs scheme test1
[Sysname-hwtacacs-test1] primary accounting 10.163.155.12 49
View
Default Level
2: System level
Use the primary authentication command to specify the primary HWTACACS authentication server.
By default, no primary HWTACACS authentication server is specified.
Note that:
l The IP addresses of the primary and secondary authentication servers cannot be the same. Otherwise, the configuration fails.
l You can remove an authentication server only when no active TCP connection for sending authentication packets is using it.
# Specify the primary authentication server.
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49
primary authorization ip-address [ port-number ]
undo primary authorization
View
Default Level
2: System level
Use the primary authorization command to specify the primary HWTACACS authorization server.
Use the undo primary authorization command to remove the configuration.
By default, no primary HWTACACS authorization server is specified.
Note that:
l The IP addresses of the primary and secondary authorization servers cannot be the same. Otherwise, the configuration fails.
l You can remove an authorization server only when no active TCP connection for sending authorization packets is using it.
# Configure the primary authorization server.
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49
reset hwtacacs statistics { accounting | all | authentication | authorization }
View
Default Level
1: Monitor level
accounting: Clears HWTACACS accounting statistics.
all: Clears all HWTACACS statistics.
authentication: Clears HWTACACS authentication statistics.
authorization: Clears HWTACACS authorization statistics.
Use the reset hwtacacs statistics command to clear HWTACACS statistics.
# Clear all HWTACACS statistics.
<Sysname> reset hwtacacs statistics all
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name
View
Default Level
2: System level
Use the reset stop-accounting-buffer command to clear the buffered stop-accounting requests that get no responses.
Related commands: stop-accounting-buffer enable, retry stop-accounting, display stop-accounting-buffer.
# Clear the buffered stop-accounting requests for HWTACACS scheme hwt1.
<Sysname> reset stop-accounting-buffer hwtacacs-scheme hwt1
View
Default Level
2: System level
retry-times: Maximum number of stop-accounting request transmission attempts. It ranges from 1 to 300 and defaults to 100.
Related commands: reset stop-accounting-buffer, hwtacacs scheme, display stop-accounting-buffer.
# Set the maximum number of stop-accounting request transmission attempts to 50.
[Sysname-hwtacacs-hwt1] retry stop-accounting 50
View
Default Level
2: System level
Use the secondary accounting command to specify the secondary HWTACACS accounting server.
By default, no secondary HWTACACS accounting server is specified.
Note that:
# Specify the secondary accounting server.
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49
View
Default Level
2: System level
Use the secondary authentication command to specify the secondary HWTACACS authentication server.
By default, no secondary HWTACACS authentication server is specified.
Note that:
# Specify the secondary authentication server.
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49
secondary authorization ip-address [ port-number ]
undo secondary authorization
View
Default Level
2: System level
Use the secondary authorization command to specify the secondary HWTACACS authorization server.
Use the undo secondary authorization command to remove the configuration.
By default, no secondary HWTACACS authorization server is specified.
Note that:
# Configure the secondary authorization server.
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49
View
Default Level
2: System level
None
Since stop-accounting requests affect the charge to users, a NAS must make its best effort to send every stop-accounting request to the HWTACACS accounting servers. For each stop-accounting request getting no response in the specified period of time, the NAS buffers and resends the packet until it receives a response or the number of transmission retries reaches the configured limit. In the latter case, the NAS discards the packet.
# In HWTACACS scheme hwt1, enable the device to buffer the stop-accounting requests getting no responses.
[Sysname-hwtacacs-hwt1] stop-accounting-buffer enable
timer quiet minutes
undo timer quiet
View
Default Level
2: System level
[Sysname-hwtacacs-hwt1] timer quiet 10
View
Default Level
2: System level
minutes: Real-time accounting interval in minutes. It is a multiple of 3 in the range 3 to 60 and defaults to 12.
Note that:
l For real-time accounting, a NAS must transmit the accounting information of online users to the HWTACACS accounting server periodically. This command is for setting the interval.
l The setting of the real-time accounting interval somewhat depends on the performance of the NAS and the HWTACACS server: a shorter interval requires higher performance. You are therefore recommended to adopt a longer interval when there are a large number of users (more than 1000, inclusive). The following table lists the recommended ratios of the interval to the number of users.
Table 3-2 Recommended ratios of the accounting interval to the number of users
Number of users |
1 to 99 |
3 |
100 to 499 |
6 |
500 to 999 |
12 |
1000 or more |
15 or more |
# Set the real-time accounting interval to 51 minutes for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
View
Default Level
2: System level
seconds: HWTACACS server response timeout period in seconds. It ranges from 1 to 300 and defaults to 5.
Use the timer response-timeout command to set the HWTACACS server response timeout timer.
As HWTACACS is based on TCP, the timeout of the server response timeout timer and/or the TCP timeout timer will cause the device to be disconnected from the HWTACACS server.
# Set the HWTACACS server response timeout timer to 30 seconds for HWTACACS scheme hwt1.
[Sysname-hwtacacs-hwt1] timer response-timeout 30
View
Default Level
2: System level
keep-original: Sends the username to the HWTACACS server as it is input.
with-domain: Includes the ISP domain name in the username sent to the HWTACACS server.
without-domain: Excludes the ISP domain name from the username sent to the HWTACACS server.
Use the user-name-format command to specify the format of the username to be sent to a HWTACACS server.
Note that:
l A username is generally in the format of userid@isp-name, of which isp-name is used by the device to determine the ISP domain to which a user belongs. Some earlier HWTACACS servers, however, cannot recognize a username including an ISP domain name. Before sending a username including a domain name to such a HWTACACS server, the device must remove the domain name. This command is thus provided for you to decide whether to include a domain name in a username to be sent to a HWTACACS server.
l If a HWTACACS scheme defines that the username is sent without the ISP domain name, do not apply the HWTACACS scheme to more than one ISP domain, thus avoiding the confused situation where the HWTACACS server regards two users in different ISP domains but with the same userid as one.
l If the HWTACACS scheme is for wireless users, specify the keep-original keyword. Otherwise, authentication of the wireless users may fail.
# Specify the device to remove the ISP domain name in the username sent to the HWTACACS servers for the HWTACACS scheme hwt1.
