H3C S3600 Series EPON OLT Switches Command Manual-Release 3103-6W100
09-DLDP-Fiber Backup Commands
Chapters Download  (67.22 KB)
1  DLDP Configuration Commands
display dldp
display dldp [ interface-type interface-number ]
View
Default Level
1: Monitor level
interface-type interface-number: Port type and port number.
Use the display dldp command to display the DLDP configuration of a port.
If you do not provide the interface-type or interface-number arguments, this command displays the DLDP configuration of all the DLDP-enabled ports.
# Display the DLDP configuration of all the DLDP-enabled ports.
<Sysname> display dldp
 DLDP global status : enable
 DLDP interval : 5s
 DLDP work-mode : enhance
 DLDP authentication-mode : simple, password is 123
 DLDP unidirectional-shutdown : auto
 DLDP delaydown-timer : 2s
 The number of enabled ports is 2.
Interface GigabitEthernet1/1/2
 DLDP port state : advertisement
 DLDP link state : up
 The neighbor number of the port is 1.
    Neighbor mac address : 0000-0000-0100
    Neighbor port index : 79
    Neighbor state : two way
    Neighbor aged time : 13
Interface GigabitEthernet1/1/4
    Neighbor mac address : 0000-0000-1100
    Neighbor port index : 81
    Neighbor aged time : 12
# Display the DLDP configuration of GigabitEthernet 1/1/2.
<Sysname> display dldp gigabitethernet 1/1/2
Table 1-1 display dldp command output description
DLDP global status
Global DLDP state (enable or disable)
DLDP interval
Interval for sending Advertisement packets (in seconds)
DLDP work-mode
DLDP mode (enhance or normal)
DLDP authentication mode (none, simple, or md5)
password
Password for DLDP authentication
Port shutdown mode (auto or manual)
Setting of the DelayDown timer
Number of the DLDP-enabled ports
Index of a DLDP-enabled port
DLDP port state
DLDP state on a port (initial, inactive, active, advertisement, probe, disable, or delaydown)
DLDP link state
Port state (up or down)
Number of the neighbors of a port
MAC address of a neighbor
Neighbor port index
Neighbor port index
Neighbor state
Neighbor state (unknown, one way, or two way)
Neighbor aged time
Neighbor aging time
display dldp statistics
display dldp statistics [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display dldp statistics command to display the statistics on the DLDP packets passing through a port.
If you do not provide the interface-type or interface-number argument, this command displays the statistics on the DLDP packets passing through all the DLDP-enabled ports.
# Display the statistics on the DLDP packets passing through all the DLDP-enabled ports.
<Sysname> display dldp statistics
 Packets sent : 6
 Packets received : 5
 Invalid packets received : 2
 Loop packets received : 0
 Authentication failed packets received : 0
 Valid packets received : 3
 Packets sent : 7
 Packets received : 7
 Invalid packets received : 3
 Valid packets received : 4
# Display the statistics on the DLDP packets passing through GigabitEthernet1/1/2.
<Sysname> display dldp statistics gigabitethernet 1/1/2
 Packets sent : 6
Table 1-2 display dldp statistics command output description
Port index
Packets sent
Total number of DLDP packets sent
Packets received
Total number of DLDP packets received
Number of the invalid packets received
Number of the loopback packets received
Number of the received packets that failed to pass the authentication
Number of the valid packets received
dldp authentication-mode
dldp authentication-mode { md5 md5-password | none | simple simple-password }
undo dldp authentication-mode
View
Default Level
2: System level
md5 md5-password: Specifies to perform MD5 authentication and sets the password. The md5-password argument is the password, a string of 1 to 16 characters or a 24-bit string. The former indicates a plain text password and the latter indicates a cipher text password. Note that this argument is case-sensitive.
None: Specifies not to perform authentication.
simple simple-password: Specifies to perform plain text authentication and sets the password. The simple-password argument is the password, a case-sensitive string of 1 to 16 characters.
Use the dldp authentication-mode command to configure DLDP authentication.
Use the undo dldp authentication-mode command to restore the default.
By default, DLDP authentication is not performed.
To enable DLDP to operate properly, make sure the DLDP authentication modes and the passwords of the both sides of a link are the same.
# Configure to perform plain text authentication, setting the password as abc (assuming that Device A and Device B are connected by the DLDP link).
l          Configuration on Device A
[DeviceA] dldp authentication-mode simple abc
l          Configuration on Device B
[DeviceB] dldp authentication-mode simple abc
dldp delaydown-timer
dldp delaydown-timer time
undo dldp delaydown-timer
View
Default Level
2: System level
Time: Setting of the DelayDown timer, in the range 1 to 5 (in seconds).
Use the dldp delaydown-timer command to set the DelayDown timer.
Use the undo dldp delaydown-timer command to restore the default.
By default, the setting of the DelayDown timer is 1 second.
Note that these two commands apply to all the DLDP-enabled ports.
# Set the DelayDown timer to 2 seconds.
[Sysname] dldp delaydown-timer 2
dldp enable
dldp enable
undo dldp enable
View
System view, Ethernet port view, port group view
Default Level
2: System level
None
Use the dldp enable command to enable DLDP.
Use the undo dldp enable command to disable DLDP.
When executed in system view, these two commands enables/disables DLDP globally; when executed in Ethernet port view, these two commands enables/disables DLDP on the current port; when executed in port group view, these two commands enables/disables DLDP on all the ports in the port group.
By default, DLDP is disabled globally or on a port.
l          These two commands are applicable to Layer 2 Ethernet ports, including optical ports and electrical ports.
l          DLDP can take effect only when it is enabled both globally and on a port.
# Enable DLDP globally.
[Sysname] dldp enable
# Enable DLDP on GigabitEthernet 1/1/2.
[Sysname] interface gigabitethernet 1/1/2
[Sysname-GigabitEthernet1/1/2] dldp enable
dldp interval
dldp interval time
undo dldp interval
View
Default Level
2: System level
time: Interval for sending Advertisement packets, in the range 1 to 100 (in seconds).
Use the dldp interval command to set the interval for sending Advertisement packets.
Use the undo dldp interval command to restore the default.
By default, the interval for sending Advertisement packets is 5 seconds.
Note that:
l          These two commands apply to all the DLDP-enabled ports.
l          Set the interval for sending Advertisement packets to a value not longer than one-third of the STP convergence time. If the interval is too long, STP loops may occur before unidirectional links are torn down; if the interval is too short, network traffic may increase in vain due to excessive Advertisement packets.
# Set the interval for sending Advertisement packets to 20 seconds.
[Sysname] dldp interval 20
dldp reset
dldp reset
View
Default Level
2: System level
None
Use the dldp reset command to reset DLDP state for ports shut down by DLDP to enable them to perform unidirectional link detect.
When executed in system view, this command applies to all the ports shut down by DLDP; when executed in Ethernet port view, this command applies to the current port; when executed in port group view, this command applies to all the ports in the port group shut down by DLDP.
Related commands: dldp enable, dldp unidirectional-shutdown.
# Reset DLDP state for all the ports shut down by DLDP.
[Sysname] dldp reset
# Reset DLDP state for GigabitEthernet 1/1/2 (assuming that GigabitEthernet 1/1/2 is shut down by DLDP).
[Sysname-GigabitEthernet1/1/2] dldp reset
dldp unidirectional-shutdown { auto | manual }
undo dldp unidirectional-shutdown
View
Default Level
2: System level
auto: Sets the port shutdown mode as auto mode, where, when a unidirectional link is detected, the port involved is shut down by DLDP.
manual: Sets the port shutdown mode as manual mode, where, when a unidirectional link is detected, DLDP prompts you to shut down the involved port instead of doing so automatically.
Use the dldp unidirectional-shutdown command to set the port shutdown mode.
Use the undo dldp unidirectional-shutdown command to restore the default.
By default, the port shutdown mode is auto mode.
Related commands: dldp work-mode.
# Set the port shutdown mode as auto mode.
[Sysname] dldp unidirectional-shutdown auto
dldp work-mode
dldp work-mode { enhance | normal }
undo dldp work-mode
View
Default Level
2: System level
enhance: Specifies the enhanced DLDP mode. When a device operates in this mode and a neighbor entry it maintains expires, the device detects the neighbor before removing the neighbor entry.
normal: Specifies the normal DLDP mode. When a device operates in this mode and a neighbor entry it maintains expires, the device removes the neighbor entry directly.
Use the dldp work-mode command to set the DLDP mode.
Use the undo dldp work-mode command to restore the default DLDP mode.
By default, a device operates in normal DLDP mode.
Note that:
l          In normal DLDP mode, only fiber cross-connected unidirectional links can be detected.
l          In enhanced DLDP mode, two types of unidirectional links can be detected. One is fiber cross-connected links. The other refers to fiber pairs with one fiber not connected or disconnected.
# Configure the device to operate in enhanced DLDP mode.
[Sysname] dldp work-mode enhance
reset dldp statistics
reset dldp statistics [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the reset dldp statistics command to clear the statistics on DLDP packets passing through a port.
If you do not provide the interface-type or interface-number argument, this command clears the statistics on the DLDP packets passing through all the DLDP-enabled ports.
# Clear the statistics on the DLDP packets passing through all the DLDP-enabled ports.
<Sysname> reset dldp statistics
Fiber Backup Configuration Commands
display fiber-backup group
display fiber-backup group { all | group-number }
View
Default Level
2: System level
all: Specifies all the fiber backup groups.
group-number: Fiber backup group number, in the range 1 to 80.
Use the display fiber-backup group command to display the information of the member OLT ports, their roles and states in the specified or all fiber backup groups.
# Display the information of the member OLT ports, their roles and states in fiber backup group 1.
<Sysname> display fiber-backup group 1
 fiber backup group 1 information:
 Member         Role       State
 Olt1/0/1       MASTER     ACTIVE
 Olt1/0/2       SLAVE      READY
Table 2-1 display fiber-backup group command output description
Information about fiber backup group 1
Member
Member port information of the fiber backup group
Role
Role of the OLT port in the backup group:
l      MASTER: master port
l      SLAVE: slave port
OLT port state:
l      ACTIVE: The master port is active (the chip is active and the optical module is plugged in).
l      READY: The slave port is ready and a master-slave switchover can be performed.
l      DOWN: Any other condition.
fiber-backup group
fiber-backup group group-number
undo fiber-backup group group-number
View
FTTH view
Default Level
2: System level
Use the fiber-backup group command to create a fiber backup group and enter fiber backup group view or directly enter fiber backup group view if the fiber backup group already exists.
Use the undo fiber-backup group command to delete a fiber backup group.
You can only delete a fiber backup group without any member ports.
# Create fiber backup group 1 and enter fiber backup group view.
[Sysname] ftth
[Sysname-ftth] fiber-backup group 1
 Create group 1 successfully.
[Sysname-fiber-group1]
group member
group member interface-type interface-number
undo group member interface-type interface-number
View
Fiber backup group view
Default Level
2: System level
interface-type: Port type. It is OLT
interface-number: OLT port number.
Use the group member command to add an OLT port to a fiber backup group (the group must exist).
Use the undo group member command to remove an OLT port from a fiber backup group.
Related commands: fiber-backup group.
# In fiber backup group view, add OLT 1/0/1 to fiber backup group 1.
[Sysname] ftth
Create group ID successfully.
[Sysname-fiber-group1] group member olt1/0/1
port fiber-backup group
port fiber-backup group group-number
undo port fiber-backup group
View
OLT port view
Default Level
2: System level
Use the port fiber-backup group command to add the OLT port to the specified fiber backup group (the group must exist).
Use the undo group member command to remove the OLT port from the fiber backup group.
# In OLT port view, add OLT 1/0/1 to fiber backup group 1.
[Sysname] ftth
[Sysname-fiber-group1] quit
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] port fiber-backup group 1
port switch-over
port switch-over
View
Default Level
2: System level
None
Use the port switch-over command to perform a master/slave switchover between the two OLT ports in the fiber backup group.
After this command is executed, the original master OLT port becomes the new slave, while the original slave OLT port becomes the new master.
Note that the slave OLT must be in the ready state for a switchover to happen.
Related commands: display fiber-backup group.
# Perform a manual master/slave switchover between the two OLT ports in fiber backup group 1.
[Sysname] ftth
[Sysname-fiber-group1] port switch-over
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
