H3C S3600 Series EPON OLT Switches Command Manual-Release 3103-6W100
00-Cover
Chapters Download  (77.19 KB)
00-Cover
Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: 6W100-20090520
Product Version: Release 3103
Copyright © 2009, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
service@h3c.com
http://www.h3c.com
About This Manual
Organization
H3C S3600 Series EPON OLT Switches Command Manual-Release 3103 is organized as follows:
Part
01-EPON-OLT Commands
l      OLT Configuration Commands
l      ONU Remote Management Configuration Commands
02-Login Commands
l      Commands for Logging into an Ethernet Switch
l      Commands for Controlling Login Users
03-Port Commands
l      Port configuration commands
04-MAC Address Table Commands
l      MAC address table management Commands
05-Link Aggregation Commands
l      Link aggregation Commands
06-Port Isolation Commands
l      Port isolation group configuration Commands
07-Port Mirroring Commands
l      Local port mirroring commands
l      Remote port mirroring commands
08-Smart Link Commands
l      Smart link configuration Commands
09-DLDP-Fiber Backup Commands
l      DLDP configuration commands
l      Fiber backup configuration commands
10-Extended OAM Commands
l      Extended OAM basic configuration commands
l      Extended OAM alarms configuration commands
11-VLAN Commands
l      VLAN configuration commands
l      Port-based VLAN configuration commands
l      Protocol-based VLAN configuration commands
12-QinQ Commands
l      QinQ configuration commands
13-BPDU Tunneling Commands
l      BPDU tunneling configuration commands
14-VLAN Mapping Commands
l      VLAN mapping configuration commands
15-MSTP Commands
l      MSTP configuration commands
l      Protection functions commands
l      RSTP for UNIs of an ONU configuration commands
16-RRPP Commands
l      RRPP configuration commands
17-IP Addressing-IP Performance Optimization Commands
l      IP Addressing configuration commands
l      IP performance optimization configuration commands
18-ARP Commands
l      ARP configuration commands
l      Gratuitous ARP configuration commands
19-DHCP Snooping Commands
l      DHCP snooping configuration commands
20-Static Routing Commands
l      IP routing table commands
l      Static routing configuration commands
21-Mulitcast Commands
l      Multicast mode configuration commands
l      IGMP snooping configuration commands
l      Multicast VLAN configuration commands
22-ACL Commands
l      Common Configuration Commands
l      IPv4 ACL Configuration Commands
l      IPv6 ACL Configuration Commands
23-QoS Commands
l      Traffic policing and line rate configuration commands
l      QoS policy configuration commands
l      Congestion management configuration commands
l      Priority mapping configuration commands
l      Traffic mirroring configuration commands
24-AAA Commands
l      AAA configuration commands
l      RADIUS configuration commands
l      HWTACACS configuration commands
25-SSH2.0 Commands
l      SSH2.0 server configuration commands
l      SSH2.0 client configuration commands
l      SFTP server configuration commands
l      SFTP client configuration commands
26-Public Key Commands
l      Public key configuration commands
27-SNMP-RMON Commands
l      SNMP configuration commands
l      MIB configuration commands
l      RMON configuration commands
28-NTP Commands
l      NTP configuration commands
29-Information Center Commands
l      Information center configuration commands
30-DNS Commands
l      DNS configuration commands
31-File System Management Commands
l      File system configuration commands
l      Configuration file management commands
l      FTP server configuration commands
l      FTP client configuration commands
l      TFTP client configuration commands
32-System Configuration and Debugging
l      Basic configuration commands
l      Device management commands
l      System maintaining and debugging commands
l      Hotfix configuration commands
33-Appendix
Lists all the commands described in this command manual in an alphabetic order. The parts and pages where the commands are described are also given.
Conventions
The manual uses the following conventions:
Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
Related Documentation
In addition to this manual, each H3C S3600 series EPON OLT switch documentation set includes the following:
Manual
H3C S3600 Series EPON OLT Switches  Installation Manual
It introduces the installation procedure, commissioning, maintenance and monitoring of the S3600 Series EPON OLT switches.
H3C S3600 Series EPON OLT Switches Operation Manual-Release 3103
It is used for assisting the users in data configurations and typical applications.
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, operation, and maintenance.
[Technical Support & Document > Product Support > Software]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
