29-Information Center Commands
Chapters Download (123.13 KB)
Table of Contents
1 Information Center Configuration Commands
display channel [ channel-number | channel-name ]
View
Default Level
1: Monitor level
channel-number: Displays information of the channel with a specified number, where channel-number represents the channel number, in the range 0 to 9.
channel-name: Displays information of the channel with a specified name, where channel-name represents the channel name, which could be a default name or a self-defined name. The user needs to specify a channel name first before using it as a self-defined channel name. For more information, refer to the info-center channel name command.
Table 1-1 Information channels for different output destinations
Output destination |
Information channel number |
Default channel name |
Console |
0 |
console |
Monitor terminal |
1 |
monitor |
Log host |
2 |
loghost |
Trap buffer |
3 |
trapbuffer |
Log buffer |
4 |
logbuffer |
SNMP module |
5 |
snmpagent |
Use the display channel command to display channel information.
If no channel is specified, information for all channels is displayed.
# Display information for channel 0.
<Sysname> display channel 0
channel number:0, channel name:console
MODU_ID NAME ENABLE LOG_LEVEL ENABLE TRAP_LEVEL ENABLE DEBUG_LEVEL
ffff0000 default Y warnings Y debugging Y debugging
The above information indicates to output log information with the severity from 0 to 4, trap information with the severity from 0 to 7 and debugging information with the severity from 0 to 7 to the console. The information source modules are all modules (default).
Table 1-2 display channel command output description
channel number |
A specified channel number, in the range 0 to 9. |
channel name |
A specified channel name, which varies with user’s configuration. For more information, refer to the info-center channel name command. |
MODU_ID |
The ID of the module to which the information permitted to pass through the current channel belongs |
NAME |
The name of the module to which the information permitted to pass through the current channel belongs Default means all modules are allowed to output system information, but the module type varies with devices. |
ENABLE |
Indicates whether to enable or disable the output of log information, which could be Y or N. |
LOG_LEVEL |
The severity of log information, refer to Table 1-4 for details. |
ENABLE |
Indicates whether to enable or disable the output of trap information, which could be Y or N. |
TRAP_LEVEL |
The severity of trap information, refer to Table 1-4 for details. |
ENABLE |
Indicates whether to enable or disable the output of debugging information, which could be Y or N. |
DEBUG_LEVEL |
The severity of debugging information, refer to Table 1-4 for details. |
display info-center
View
Default Level
1: Monitor level
None
Use the display info-center command to display the information of each output destination.
# Display configurations on each output destination.
<Sysname> display info-center
Information Center:enabled
Log host:
2.2.2.2, channel number : 8, channel name : channel8,
host facility local7
Console:
channel number : 0, channel name : console
Monitor:
channel number : 1, channel name : monitor
SNMP Agent:
channel number : 5, channel name : snmpagent
Log buffer:
enabled,max buffer size 1024, current buffer size 512,
current messages 512, dropped messages 0, overwritten messages 740
channel number : 4, channel name : logbuffer
Trap buffer:
enabled,max buffer size 1024, current buffer size 256,
current messages 216, dropped messages 0, overwritten messages 0
channel number : 3, channel name : trapbuffer
Information timestamp setting:
log - date, trap - date, debug - date,
loghost - date
Table 1-3 display info-center command output description
Information Center |
The current state of the information center, which could be enabled or disabled. |
Log host: 2.2.2.2, channel number : 8, channel name : channel8, host facility local7 |
Configurations on the log host destination (It can be displayed only when the info-center loghost command is configured), including IP address of the log host, the channel number and channel name used, and logging facility used.) |
Console: channel number : 0, channel name : console |
Configurations on the console destination, including the channel number and channel name used |
Monitor: channel number : 1, channel name : monitor |
Configurations on the monitor terminal destination, including the channel number and channel name used |
SNMP Agent: channel number : 5, channel name : snmpagent |
Configurations on the SNMP module destination, including the channel number and channel name used |
Log buffer: enabled,max buffer size 1024, current buffer size 512, current messages 512, dropped messages 0, overwritten messages 740 channel number : 4, channel name : logbuffer |
Configurations on the log buffer destination, including whether information output to this destination is enabled or disabled, the maximum capacity, the current capacity, the current number of messages, the number of dropped messages, the number of messages that have been overwritten, and the channel number and channel name used. |
Trap buffer: enabled,max buffer size 1024, current buffer size 256, current messages 216, dropped messages 0, overwritten messages 0 channel number : 3, channel name : trapbuffer |
Configurations on the trap buffer destination, including whether information output to this destination is enabled or disabled, the maximum capacity, the current capacity, the current number of messages, the number of dropped messages, the number of messages that have been overwritten, and the channel number and channel name used. |
Information timestamp setting |
The timestamp configurations, specifying the timestamp format for log, trap, debug, and log host information. |
Only devices that support the logfile feature display the related logfile information after the execution of the display info-center command.
display logbuffer [ reverse ] [ level severity | size buffersize ] * [ | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
reverse: Displays log entries chronologically, with the most recent entry at the top. If this keyword is not specified, the log entries will be displayed chronologically, with the oldest entry at the top.
level severity: Displays information of the log with specified level, where severity represents information level, in the range 0 to 7.
Table 1-4 Severity description
Severity |
Value |
Emergency |
0 |
The system is unusable. |
Alert |
1 |
Action must be taken immediately |
Critical |
2 |
Critical conditions |
Error |
3 |
Error conditions |
Warning |
4 |
Warning conditions |
Notice |
5 |
Normal but significant condition |
Informational |
6 |
Informational messages |
Debug |
7 |
Debug-level messages |
size buffersize: Displays specified number of the latest log messages in the log buffer, where buffersize represents the number of the latest log messages to be displayed in the log buffer, in the range 1 to 1,024.
slot slot-number: Slot number.
|: Uses a regular expression to filter the output information. For detailed information about regular expression, refer to section CLI Display in Basic System Configuration in the System Volume.
l begin: Displays the line that matches the regular expression and all the subsequent lines.
l exclude: Displays the lines that do not match the regular expression.
l include: Displays the lines that match the regular expression.
regular-expression: Regular expression, a string of 1 to 256 characters. Note that this argument is case-sensitive and can have spaces included.
Use the display logbuffer command to display the state of the log buffer and the log information recorded. Absence of the size buffersize argument indicates that all log information recorded in the log buffer is displayed.
# Display the state of the log buffer and the log information recorded on a centralized device.
<Sysname> display logbuffer
Logging buffer configuration and contents:enabled
Allowed max buffer size : 1024
Actual buffer size : 512
Channel number : 4 , Channel name : logbuffer
Dropped messages : 0
Overwritten messages : 718
Current messages : 512
%Jun 17 15:57:09:578 2006 Sysname IC/7/SYS_RESTART:
System restarted --
The rest is omitted here.
# Display the state of the log buffer and the log information recorded on a distributed device.
Overwritten messages : 0
Current messages : 127
%Jun 19 18:03:24:55 2006 Sysname IC/7/SYS_RESTART:
System restarted --
Table 1-5 display logbuffer command output description
Logging buffer configuration and contents |
Indicates the current state of the log buffer and its contents, which could be enabled or disabled. |
Allowed max buffer size |
The maximum buffer size allowed |
Actual buffer size |
The actual buffer size |
Channel number |
The channel number of the log buffer, defaults to 4. |
Channel name |
The channel name of the log buffer, defaults to logbuffer. |
Dropped messages |
The number of dropped messages |
Overwritten messages |
The number of overwritten messages (when the buffer size is not big enough to hold all messages, the latest messages overwrite the old ones). |
Current messages |
The number of the current messages |
display logbuffer summary [ level severity ]
View
Default Level
1: Monitor level
level severity: Displays the summary of the log buffer, where severity represents information level, in the range 0 to 7.
Use the display logbuffer summary command to display the summary of the log buffer.
# Display the summary of the log buffer on a centralized device.
<Sysname> display logbuffer summary
EMERG ALERT CRIT ERROR WARN NOTIF INFO DEBUG
0 0 0 0 22 0 1 0
Table 1-6 display logbuffer summary command output description
EMERG |
Represents emergency, refer to Table 1-4 for details |
ALERT |
Represents alert, refer to Table 1-4 for details |
CRIT |
Represents critical, refer to Table 1-4 for details |
ERROR |
Represents error, refer to Table 1-4 for details |
WARN |
Represents warning, refer to Table 1-4 for details |
NOTIF |
Represents notice, refer to Table 1-4 for details |
INFO |
Represents informational, refer to Table 1-4 for details |
DEBUG |
Represents debug, refer to Table 1-4 for details |
display trapbuffer [ reverse ] [ size buffersize ]
View
Default Level
1: Monitor level
reverse: Displays trap entries chronologically, with the most recent entry at the top. If this keyword is not specified, trap entries will be displayed chronologically, with the oldest entry at the top.
size buffersize: Displays specified number of the latest trap messages in a trap buffer, where buffersize represents the number of the latest trap messages in a trap buffer, in the range 1 to 1,024.
Use the display trapbuffer command to display the state and the trap information recorded.
Absence of the size buffersize argument indicates that all trap information is displayed.
# Display the state of the trap buffer and the trap information recorded.
<Sysname> display trapbuffer
Trapping buffer configuration and contents:enabled
Actual buffer size : 256
Channel number : 3 , channel name : trapbuffer
Current messages : 2
#Aug 7 14:47:35:636 2008 Sysname IFNET/4/INTERFACE UPDOWN:
Trap 1.3.6.1.6.3.1.1.5.3<linkDown>: Interface 983041 is Down, ifAdminStatus is 2, ifOperStatus is 2
#Aug 7 14:47:47:724 2008 Sysname IFNET/4/INTERFACE UPDOWN:
Trap 1.3.6.1.6.3.1.1.5.4<linkUp>: Interface 983041 is Up, ifAdminStatus is 1, ifOperStatus is 1
Table 1-7 display trapbuffer command output description
Trapping buffer configuration and contents |
Indicates the current state of the trap buffer and its contents, which could be enabled or disabled. |
Channel number |
The channel number of the trap buffer, defaults to 3. |
channel name |
The channel name of the trap buffer, defaults to trapbuffer. |
Dropped messages |
Current messages |
display onu-event interface interface-type interface-number
View
Default Level
2: System level
interface-type: Port type. It is ONU.
interface-number: ONU port number.
Use the display onu-event interface command to display the registration and deregistration records of an ONU.
l The system supports up to 50 records for each ONU. After the number of records for an ONU reaches this maximum number, the old records will be overwritten by the new ones.
l If an ONU port is unbound from its ONU or the EPON card is reset, records will be cleared.
# Display the registration and deregistration information of the ONU.
<Sysname> display onu-event interface onu 3/0/1:1
Date Time ONU Event ONU Status
2008/07/28 13:57:03 Registration Down
2008/07/28 18:00:06 Deregistration Up
Table 1-8 display onu-event interface command output description
Date |
Date of the ONU event |
Time |
Time of the ONU event |
ONU Event |
ONU event: l Registration l Deregistration |
ONU Status |
ONU status: l Up: Up is displayed when the ONU is registered. l Down: Down is displayed when the ONU is deregistered. |
enable log updown
undo enable log updown
View
Interface view, ONU port view, OLT port view
Default Level
2: System level
None
Use the enable log updown command to allow a port to generate link up/down logging information when the port state changes.
Use the undo enable log updown command to disable a port from generating link up/down logging information when the port state changes.
By default, all the ports are allowed to generate port link up/down logging information when the port state changes.
# Disable port GigabitEthernet1/1/1 from generating link up/down logging information.
[Sysname] interface gigabitethernet1/1/1
[Sysname-GigabitEthernet1/1/1] undo enable log updown
info-center channel channel-number name channel-name
undo info-center channel channel-number
View
Default Level
2: System level
channel-number: Specifies a channel number, in the range 0 to 9.
channel-name: Specifies a channel name, a string of 1 to 30 characters. It must be a combination of letters and numbers, and start with a letter and is case insensitive.
Use the info-center channel name command to name a channel with a specified channel number.
Use the undo info-center channel command to restore the default name for a channel with a specified channel number.
Refer to Table 1-1 for details of default channel names and channel numbers.
# Name channel 0 as abc.
[Sysname] info-center channel 0 name abc
info-center console channel { channel-number | channel-name }
undo info-center console channel
View
Default Level
2: System level
channel-name: Specifies a channel name, which could be a default name or a self-defined name. The user needs to specify a channel name first before using it as a self-defined channel name. For more information, refer to the info-center channel name command.
Use the info-center console channel command to specify the channel to output system information to the console.
Use the undo info-center console channel command to restore the default output channel to the console.
By default, output of information to the console is enabled with channel 0 as the default channel (known as console).
Note that the info-center console channel command takes effect only after the information center is enabled first with the info-center enable command.
# Set channel 0 to output system information to the console.
[Sysname] info-center console channel 0
info-center enable
undo info-center enable
View
Default Level
2: System level
None
Use the info-center enable command to enable information center.
Use the undo info-center enable command to disable the information center.
The system outputs information to the log host or the console only after the information center is enabled first.
By default, the information center is enabled.
# Enable the information center.
[Sysname] info-center enable
% Information center is enabled
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ] *
undo info-center logbuffer [ channel | size ]
View
Default Level
2: System level
channel-number: A specified channel number, in the range 0 to 9.
buffersize: Specifies the maximum number of log messages that can be stored in a log buffer, in the range 0 to 1,024 with 512 as the default value.
Use the info-center logbuffer command to enable information output to a log buffer and set the corresponding parameters.
Use the undo info-center logbuffer command to disable information output to a log buffer.
By default, information is output to the log buffer with the default channel of channel 4 (logbuffer) and the default buffer size of 512.
Note that the info-center logbuffer command takes effect only after the information center is enabled with the info-center enable command.
# Configure the system to output information to the log buffer through channel 4, and set the log buffer size to 50.
[Sysname] info-center logbuffer size 50
info-center loghost host-ip [ channel { channel-number | channel-name } | facility local-number ] *
undo info-center loghost host-ip
View
Default Level
2: System level
host-ip: The IP address of the log host.
channel: Specifies the channel through which system information can be output to the log host.
facility local-number: The logging facility of the log host. The value can be local0 to local7 and defaults to local7. Logging facility is mainly used to mark different logging sources, query and filer the logs of the corresponding log source.
Use the info-center loghost command to specify a log host and to configure the related parameters.
Use the undo info-center loghost command to restore the default configurations on a log host.
By default, output of system information to the log host is disabled. When it is enabled, the default channel name will be loghost and the default channel number will be 2.
Note that:
l The info-center loghost command takes effect only after the information center is enabled with the info-center enable command.
l Ensure to input a correct IP address while using the info-center loghost command to configure the IP address for a log host. System will prompt an invalid address if the loopback address (127.0.0.1) is input.
l A maximum number of 4 hosts (different) can be designated as the log host.
# Output log information to a Unix station with the IP address being 1.1.1.1/16.
[Sysname] info-center loghost 1.1.1.1
undo info-center loghost source
View
Default Level
2: System level
interface-type interface-number: Specifies the egress interface for log information by the interface type and interface number.
Use the info-center loghost source command to specify the source IP address for log information.
Use the undo info-center loghost source command to restore the default.
By default, the interface for sending log information is determined by the matched route, and the primary IP address of this interface is the source IP address of the log information.
After the source IP address of log information is specified, no matter the log information is actually output through which physical interface, the source IP address of the log information is the primary IP address of the specified interface. If you want to display the source IP address in the log information, you can configure it by using this command.
Note that:
l The info-center loghost source command takes effect only after the information center is enabled with the info-center enable command.
l The IP address of the specified source interface must be configured; otherwise, although the info-center loghost source command can be configured successfully, the log host will not receive any log information.
By default, the log information in the following format is displayed on the log host:
<188>Jul 22 05:58:06 2008 Sysname %%10IFNET/4/LINK UPDOWN(l): Vlan-interface1: link status is UP
# Specify the primary IP address of interface Vlan-interface1 as the source IP address of log information.
[Sysname] interface vlan-interface1
[Sysname- Vlan-interface1] ip address 2.2.2.2
[Sysname- Vlan-interface1] quit
[Sysname] info-center loghost source e vlan-interface1
After the above configuration, the log information in the following format is displayed on the log host (compared with the default format, the following format has the -DevIP=2.2.2.2 field):
<188>Jul 22 06:11:31 2008 Sysname %%10IFNET/4/LINK UPDOWN(l):-DevIP=2.2.2.2; Vlan-interface1: link status is UP0
info-center monitor channel { channel-number | channel-name }
undo info-center monitor channel
View
Default Level
2: System level
Use the info-center monitor channel command to configure the channel to output system information to the monitor.
Use the undo info-center monitor channel command to restore the default channel to output system information to the monitor.
By default, output of system information to the monitor is enabled with a default channel name of monitor and a default channel number of 1.
Note that the info-center monitor channel command takes effect only after the information center is enabled with the info-center enable command.
# Output system information to the monitor through channel 0.
[Sysname] info-center monitor channel 0
info-center snmp channel { channel-number | channel-name }
undo info-center snmp channel
View
Default Level
2: System level
Use the info-center snmp channel command to configure the channel to output system information to the SNMP module.
Use the undo info-center snmp channel command to restore the default channel to output system information to the SNMP module.
By default, output of system information to the SNMP module is enabled with a default channel name of snmpagent and a default channel number of 5.
For more information, refer to the display snmp-agent command in the SNMP Commands in the System Volume.
# Output system information to the SNMP module through channel 6.
[Sysname] info-center snmp channel 6
info-center source { module-name | default } channel { channel-number | channel-name } [ debug { level severity | state state } * | log { level severity | state state } * | trap { level severity | state state } * ] *
undo info-center source { module-name | default } channel { channel-number | channel-name }
View
Default Level
2: System level
module-name: Specifies the output rules of the system information of the specified modules. For instance, if information on ARP module is to be output, you can configure this argument as ARP. You can use the info-center source ? command to view the modules supported by the device.
default: Specifies the output rules of the system information of all the modules allowed to output the system information, including all the modules displayed by using the info-center source ? command.
debug: Debugging information.
log: Log information.
trap: Trap information.
level severity: Specifies the severity of system information, refer to Table 1-4 for details. With this keyword, you can specify the severity level of the information allowed/denied to output.
state state: Configures whether to output the system information, which could be on (enabled) or off (disabled). With this keyword, you can specify whether to output the specified system information.
Use the info-center source command to specify the output rules of the system information.
Use the undo info-center source command to remove the specified output rules.
By default, the output rules for the system information are listed in Table 1-9.
This command can be used to set the filter and redirection rules of log, trap and debugging information.
For example, the user can set to output log information with severity higher than warning to the log host, and information with severity higher than informational to the log buffer. The user can also set to output trap information of the IP module to a specified output destination.
Note that:
l If you do not use the module-name argument to set output rules for a module, the module uses the default output rules or the output rules set by the default keyword; otherwise the module uses the output rules separately set for it.
l If you use the default keyword to set the output rules for all the modules without specifying the debug, log, and trap keywords, the default output rules for the modules are used. Refer to Table 1-9 for details.
l If you use the module-name argument to set the output rules for a module without specifying the debug, log, and trap keywords, the default output rules for the module are as follows: the output of log and trap information is enabled, with severity being informational; the output of debugging information is disabled, with severity being debug. For example, if you execute the command info-center source snmp channel 5, the command is actually equal to the command info-center source snmp channel 5 debug level debugging state off log level informational state on trap level informational state on.
l If you repeatedly use the command to set the output rules for a module or for all the modules with the default keyword, the last configured output rules take effect
l After you separately set the output rules for a module, you must use the module-name argument to modify or remove the rules. The new configuration by using the default keyword is invalid on the module.
l You can configure to output the log, trap and debugging information to the trap buffer, but the trap buffer only receives the trap information and discards the log and debugging information.
l You can configure to output the log, trap and debugging information to the log buffer, but the log buffer only receives the log and debugging information and discards the trap information.
l You can configure to output the log, trap and debugging information to the SNMP module, but the SNMP module only receives the trap information and discards the log and debugging information.
Table 1-9 Default output rules for different output destinations
Modules allowed |
LOG |
TRAP |
DEBUG |
Enabled/disabled |
Severity |
Enabled/disabled |
Severity |
Enabled/disabled |
Severity |
Console |
default (all modules) |
Enabled |
Warning |
Enabled |
Debug |
Enabled |
Debug |
Monitor terminal |
Enabled |
Warning |
Enabled |
Debug |
Enabled |
Debug |
Log host |
Enabled |
Informational |
Enabled |
Debug |
Disabled |
Debug |
Trap buffer |
Disabled |
Informational |
Enabled |
Warning |
Disabled |
Debug |
Log buffer |
Enabled |
Warning |
Disabled |
Debug |
Disabled |
Debug |
SNMP module |
Disabled |
Debug |
Enabled |
Warning |
Disabled |
Debug |
# Set the output channel for the log information of VLAN module to snmpagent and to output information with severity being emergency. Log information of other modules cannot be output to this channel; other types of information of this module may or may not be output to this channel.
[Sysname] info-center source default channel snmpagent log state off
[Sysname] info-center source vlan channel snmpagent log level emergencies state on
# Set the output channel for the log information of VLAN module to snmpagent and to output information with severity being emergency. Log information of other modules and all the other system information cannot be output to this channel.
[Sysname] info-center source default channel snmpagent debug state off log state off trap state off
info-center synchronous
View
Default Level
2: System level
None
Use the info-center synchronous command to enable synchronous information output.
Use the undo info-center synchronous command to disable the synchronous information output.
By default, the synchronous information output is disabled.
l If system information, such as log information, is output before you input any information under a current command line prompt, the system will not display the command line prompt after the system information output.
l If system information is output when you are inputting some interactive information (non Y/N confirmation information), then after the system information output, the system will not display the command line prompt but your previous input in a new line.
# Enable the synchronous information output function, and then input the display interface GigabitEthernet command to view Ethernet interface information.
[Sysname] info-center synchronous
% Info-center synchronous output is on
[Sysname] display interface GigabitEthernee
At this time, the system receives log messages, and it then displays the log messages first. After the system displays all the log messages, it displays the user’s previous input, which is display interface ethe in this example.
%Apr 29 08:12:44:71 2007 Sysname IFNET/4/LINK UPDOWN:
display interface GigabitEthernet 1/1/1: link status is UP
[Sysname] display interface GigabitEthernete
# Enable the synchronous information output function, and then save the current configuration (input interactive information).
[Sysname] save
The current configuration will be written to the device. Are you sure? [Y/N]:
At this time, the system receives the log information, and it then displays the log information first. After the system displays all the log information, it displays the user’s previous input, which is [Y/N] in this example.
%May 21 14:33:19:425 2007 Sysname SHELL/4/LOGIN: VTY login from 192.168.1.44
[Y/N]:
info-center timestamp { debugging | log | trap } { boot | date | none }
undo info-center timestamp { debugging | log | trap }
View
Default Level
2: System level
debugging: Sets the timestamp format of the debugging information.
log: Sets the timestamp output format of the log information.
trap: Sets the timestamp output format of the trap information.
boot: The time taken to boot up the system, in the format of xxxxxx.yyyyyy, in which xxxxxx represents the most significant 32 bits of the time taken to boot up the system (in milliseconds) whereas yyyyyy is the least significant 32 bits. For example, 0.21990989 equals Jun 25 14:09:26:881 2007.
date: The current system date and time, in the format of “Mmm dd hh:mm:ss:sss yyyy”.
l Mmm: The abbreviations of the months in English, which could be Jan, Feb, Mar, Apr, May, Jun, Jul, Aug, Sep, Oct, Nov, or Dec.
l dd: The date, starting with a space if less than 10, for example “ 7”.
l hh:mm:ss:sss: The local time, with hh ranging from 00 to 23, mm and ss ranging from 00 to 59, and sss ranging from 0 to 999.
l yyyy: Represents the year.
none: Indicates no time information is provided.
Use the info-center timestamp command to configure the timestamp format.
Use the undo info-center timestamp command to restore the default.
By default, the timestamp format of log, trap and debugging information is date.
# Configure the timestamp format for log information as boot.
[Sysname] info-center timestamp log boot
At this time, if you execute the shutdown command on GigabitEthernet1/1/1 that is in the UP state, the log information generated is as follows:
%0.1382605158 Sysname IFNET/4/LINK UPDOWN:
GigabitEthernet1/1/1: link status is DOWN
# Configure the timestamp format for log information as date.
[Sysname] info-center timestamp log date
At this time, if you execute the shutdown command on GigabitEthernet1/1/1that is in the UP state, the log information generated is as follows:
%Sep 29 17:19:11:188 2007 Sysname IFNET/4/LINK UPDOWN:
# Configure the timestamp format for log information as none.
[Sysname] info-center timestamp log none
% Sysname IFNET/4/LINK UPDOWN:
info-center timestamp loghost { date | no-year-date | none }
undo info-center timestamp loghost
View
Default Level
2: System level
date: Indicates the current system date and time, in the format of "Mmm dd hh:mm:ss:ms yyyy". However, the display format depends on the log host.
no-year-date: Indicates the current system date and time (year exclusive).
none: Indicates that no time stamp information is provided.
Use the info-center timestamp loghost command to configure the time stamp format of the system information sent to the log host.
Use the undo info-center timestamp loghost command to restore the default.
By default, the time stamp format for system information sent to the log host is date.
# Configure that the system information output to the log host does not include the year information.
[Sysname] info-center timestamp loghost no-year-date
info-center trapbuffer [ channel { channel-number | channel-name } | size buffersize ] *
undo info-center trapbuffer [ channel | size ]
View
Default Level
2: System level
size buffersize: Specifies the maximum number of trap messages in a trap buffer, in the range 0 to 1,024 with 256 as the default value.
Use the info-center trapbuffer command to enable information output to the trap buffer and set the corresponding parameters.
Use the undo info-center trapbuffer command to disable information output to the trap buffer.
By default, information output to the trap buffer is enabled with channel 3 (trapbuffer) as the default channel and a maximum buffer size of 256.
Note that the info-center trapbuffer command takes effect only after the information center is enabled with the info-center enable command.
# Configure the system to output information to the trap buffer through the default channel, and set the trap buffer size to 30.
[Sysname] info-center trapbuffer size 30
reset logbuffer
View
Default Level
3: Manage level
None
Use the reset logbuffer command to reset the log buffer contents.
# Reset the log buffer contents.
<Sysname> reset logbuffer
reset trapbuffer
View
Default Level
3: Manage level
None
Use the reset trapbuffer command to reset the trap buffer contents.
# Reset the trap buffer contents.
<Sysname> reset trapbuffer
onu-event { debug | log | trap } enable level severity
undo onu-event { debug | log | trap }
View
ONU port view
debug: Displays the types of debugging information allowed to be output by the ONU on the OLT.
log: Displays the log information generated by the ONU on the OLT.
trap: Displays the trap information generated by the OLT on the ONU.
severity: Severity level of the information that the ONU reports to the OLT. The severity levels include (in the descending order of priority):
emergencies, alerts, critical, errors, warnings, notifications, information, and debugging.
Use the onu-event { debug | log | trap } enable level command to specify the ONU to report log, debugging, or trap information to the OLT.
Use the undo onu-event { debug | log | trap } command to restore the default.
By default, an ONU reports no information to the OLT.
Note that: because a large number of ONUs are attached to an OLT, enabling ONUs to report information to the OLT may generate a large amount of traffic and thus cause congestion. Therefore, you are recommended to select the reported information types as required.
# Configure the OLT attached to ONU 1/0/3:1 to report log information with severity levels higher than errors.
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] onu-event log enable level ?
alerts <=ALERT level messages to OLT (severity=1)
critical <=CRIT level messages to OLT (severity=2)
debugging <=DEBUG level messages to OLT (severity=7)
emergencies <=EMERG Level Switch to OLT (severity=0)
errors <=ERR level messages to OLT (severity=3)
information <=INFO level messages to OLT (severity=6)
notifications <=NOTICE level messages to OLT (severity=5)
warnings <=WARN level messages to OLT (severity=4)
[Sysname-Onu1/0/1:1] onu-event log enable level errors
# Disable the OLT attached to ONU 1/0/3:1 from reporting log information to the ONU.
[Sysname-Onu1/0/1:1] undo onu-event log enable
Table 1-10 onu-event log enable level command output description
Severity level |
Remarks |
emergencies |
0 |
Indicating that the system is unavailable. |
alerts |
1 |
Errors that need to be corrected immediately. |
critical |
2 |
Critical Information. |
errors |
3 |
Errors. |
warnings |
4 |
Warning Information. |
notifications |
5 |
Normal information that needs to be noticed. |
information |
6 |
Normal prompt information that needs to be recorded. |
debugging |
7 |
Debugging information. |
terminal debugging
undo terminal debugging
View
Default Level
1: Monitor level
None
Use the terminal debugging command to enable the display of debugging information on the current terminal.
Use the undo terminal debugging command to disable the display of debugging information on the current terminal.
By default, the display of debugging information on the current terminal is disabled.
Note that:
l The debugging information is displayed (using the terminal debugging command) only after the monitoring of system information is enabled on the current terminal first (using the terminal monitor command).
l The configuration of this command is valid for only the current connection between the terminal and the device. If a new connection is established, the display of debugging information on the terminal restores the default.
# Enable the display of debugging information on the current terminal.
<Sysname> terminal debugging
% Current terminal debugging is on
terminal logging
undo terminal logging
View
Default Level
1: Monitor level
None
Use the terminal logging command to enable the display of log information on the current terminal.
Use the undo terminal logging command to disable the display of log information on the current terminal.
By default, the display of log information on the current terminal is disabled.
Note that:
l The log information is displayed (using the terminal logging command) only after the monitoring of system information is enabled on the current terminal first (using the terminal monitor command).
l The configuration of this command is valid for only the current connection between the terminal and the device. If a new connection is established, the display of log information on the terminal restores the default.
# Disable the display of log information on the current terminal.
<Sysname> undo terminal logging
% Current terminal logging is off
terminal monitor
undo terminal monitor
View
Default Level
1: Monitor level
None
Use the terminal monitor command to enable the monitoring of system information on the current terminal.
Use the undo terminal monitor command to disable the monitoring of system information on the current terminal.
By default, monitoring of the system information on the console is enabled and that on the monitor terminal is disabled.
Note that:
l You need to configure the terminal monitor command before you can display the log, trap, and debugging information.
l Configuration of the undo terminal monitor command automatically disables the monitoring of log, trap, and debugging information.
l The configuration of this command is valid for only the current connection between the terminal and the device. If a new connection is established, the monitoring of system information on the terminal restores the default.
# Enable the monitoring of system information on the current terminal.
<Sysname> terminal monitor
% Current terminal monitor is on
terminal trapping
undo terminal trapping
View
Default Level
1: Monitor level
None
Use the terminal trapping command to enable the display of trap information on the current terminal.
Use the undo terminal trapping command to disable the display of trap information on the current terminal.
By default, the display of trap information on the current terminal is enabled.
Note that:
l The trap information is displayed (using the terminal trapping command) only after the monitoring of system information is enabled on the current terminal first (using the terminal monitor command).
l The configuration of this command is valid for only the current connection between the terminal and the device. If a new connection is established, the display of trap information on the terminal restores the default.
# Enable the display of trap information on the current terminal.
<Sysname> terminal trapping
