25-SSH2.0 Commands
Chapters Download (139.21 KB)
Table of Contents
1 SSH2.0 Configuration Commands
SSH2.0 Server Configuration Commands
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
SSH2.0 Client Configuration Commands
ssh client authentication server
SFTP Server Configuration Commands
SFTP Client Configuration Commands
View
Default Level
1: Monitor level
session: Displays the session information of the SSH server.
status: Displays the status information of the SSH server.
Use the display ssh server command on an SSH server to display SSH server status information or session information.
Related commands: ssh server authentication-retries, ssh server rekey-interval, ssh server authentication-timeout, ssh server enable, ssh server compatible-ssh1x enable.
This command is also available on an SFTP server.
# Display the SSH server status information.
<Sysname> display ssh server status
SSH Server: Disable
SSH version : 1.99
SSH authentication-timeout : 60 second(s)
SSH server key generating interval : 0 hour(s)
SSH Authentication retries : 3 time(s)
SFTP Server: Disable
SFTP Server Idle-Timeout: 10 minute(s)
Table 1-1 display ssh server status command output description
SSH Server |
Whether the SSH server function is enabled |
SSH version |
SSH protocol version When the SSH supports SSH1, the protocol version is 1.99. Otherwise, the protocol version is 2.0. |
SSH authentication-timeout |
Authentication timeout period |
SSH server key generating interval |
SSH server key pair update interval |
SSH Authentication retries |
Maximum number of SSH authentication attempts |
SFTP Server |
Whether the SFTP server function is enabled |
SFTP Server Idle-Timeout |
SFTP connection idle timeout period |
# Display the SSH server session information.
<Sysname> display ssh server session
Conn Ver Encry State Retry SerType Username
VTY 0 2.0 DES Established 0 SFTP client001
Table 1-2 display ssh server session command output description
Conn |
Connected VTY channel |
Ver |
SSH server protocol version |
Encry |
Encryption algorithm |
State |
Status of the session, including: Init, Ver-exchange, Keys-exchange, Auth-request, Serv-request, Established, Disconnected |
Retry |
Number of authentication attempts |
SerType |
Service type (SFTP, Stelnet) |
Username |
Name of a user during login |
View
Default Level
1: Monitor level
username: SSH username, a string of 1 to 80 characters.
Use the display ssh user-information command on an SSH server to display information about one or all SSH users.
With the username argument not specified, the command displays information about all SSH users.
Related commands: ssh user.
# Display information about all SSH users.
<Sysname> display ssh user-information
Total ssh users : 2
Username Authentication-type User-public-key-name Service-type
yemx password null stelnet|sftp
test publickey pubkey sftp
Table 1-3 display ssh user-information command output description
Username |
Name of the user |
Authentication-type |
Authentication method. If this field has a value of password, the next field will have a value of null. |
User-public-key-name |
Public key of the user |
Service-type |
Service type |
ssh server authentication-retries times
undo ssh server authentication-retries
View
Default Level
2: System level
times: Maximum number of authentication attempts, in the range 1 to 5.
Use the ssh server authentication-retries command to set the maximum number of SSH connection authentication attempts, which takes effect at next login.
Use the undo ssh server authentication-retries command to restore the default.
By default, the maximum number of SSH connection authentication attempts is 3.
Note that:
l Authentication will fail if the number of authentication attempts (including both publickey and password authentication) exceeds that specified in the ssh server authentication-retries command.
l If the authentication method of SSH users is password-publickey, the maximum number of SSH connection authentication attempts must be at least 2. This is because SSH2.0 users must pass both password and publickey authentication.
Related commands: display ssh server.
# Set the maximum number of SSH connection authentication attempts to 4.
[Sysname] ssh server authentication-retries 4
undo ssh server authentication-timeout
View
Default Level
2: System level
time-out-value: Authentication timeout period in seconds, in the range 1 to 120.
Use the ssh server authentication-timeout command to set the SSH user authentication timeout period on the SSH server.
Use the undo ssh server authentication-timeout command to restore the default.
By default, the authentication timeout period is 60 seconds.
# Set the SSH user authentication timeout period to 10 seconds.
[Sysname] ssh server authentication-timeout 10
undo ssh server compatible-ssh1x
View
Default Level
2: System level
None
Use the ssh server compatible-ssh1x command to enable the SSH server to support SSH1 clients.
Use the undo ssh server compatible-ssh1x command to disable the SSH server from supporting SSH1 clients.
By default, the SSH server supports SSH1 clients.
This configuration takes effect only for users logging in after the configuration.
# Enable the SSH server to support SSH1 clients.
[Sysname] ssh server compatible-ssh1x enable
ssh server enable
undo ssh server enable
View
Default Level
2: System level
None
Use the ssh server enable command to enable SSH server.
Use the undo ssh server enable command to disable SSH server.
By default, SSH server is disabled.
# Enable SSH server.
[Sysname] ssh server enable
ssh server rekey-interval hours
undo ssh server rekey-interval
View
Default Level
2: System level
hours: Server key pair update interval in hours, in the range 1 to 24.
Use the ssh server rekey-interval command to set the interval for updating the RSA server key.
Use the undo ssh server rekey-interval command to remove the configuration.
By default, the update interval of the RSA server key is 0, that is, the RSA server key is not updated.
l This command is only available to SSH users using SSH1 client software.
l The system does not update any DSA key pair periodically.
# Set the RSA server key pair update interval to 3 hours.
[Sysname] ssh server rekey-interval 3
ssh user username service-type stelnet authentication-type { password | { any | password-publickey | publickey } assign publickey keyname }
ssh user username service-type { all | sftp } authentication-type { password | { any | password-publickey | publickey } assign publickey keyname work-directory directory-name }
undo ssh user username
View
Default Level
2: System level
username: SSH username, a case-sensitive string of 1 to 80 characters.
service-type: Specifies the service type of an SSH user, which can be one of the following:
l all: Specifies both secure Telnet and secure FTP.
l sftp: Specifies the service type as secure FTP.
l stelnet: Specifies the service type of secure Telnet.
authentication-type: Specifies the authentication method of an SSH user, which can be one the following:
l password: Performs password authentication.
l any: Performs either password authentication or publickey authentication.
l password-publickey: Specifies that SSH2 clients perform both password authentication and publickey authentication and that SSH1 clients perform either type of authentication.
l publickey: Performs publickey authentication.
assign publickey keyname: Assigns an existing public key to an SSH user. keyname indicates the name of the client public key and is a string of 1 to 64 characters.
work-directory directory-name: Specifies the working folder for an SFTP user. directory-name indicates the name of the working folder and is a string of 1 to 135 characters.
Use the ssh user command to create an SSH user and specify the service type and authentication method.
Use the undo ssh user command to delete an SSH user.
Note that:
l For a publickey authentication user, you must configure the username and the public key on the device. For a password authentication user, you can configure the account information on either the device or the remote authentication server such as a RADIUS server.
l If you use the ssh user command to configure a public key for a user who has already had a public key, the new one overwrites the old one.
l Authentication method and public key configuration takes effect only for users logging in after the configuration.
l If an SFTP user has been assigned a public key, it is necessary to set a working folder for the user.
l The working folder of an SFTP user is subject to the user authentication method. For a user using only password authentication, the working folder is the AAA authorized one. For a user using only publickey authentication or using both the publickey and password authentication methods, the working folder is the one set by using the ssh user command.
Related commands: display ssh user-information.
# Create an SSH user named user1, setting the service type as sftp, the authentication method as publickey, the work folder of the SFTP server as flash, and assigning a public key named key1 to the user.
[Sysname] ssh user user1 service-type sftp authentication-type publickey assign publickey key1 work-directory flash:
display ssh client source
View
Default Level
1: Monitor level
None
Use the display ssh client source command to display the source IP address or source interface currently set for the SSH client.
If neither source IP address nor source interface is specified for the SSH client, the system will prompt you to specify the source information.
Related commands: ssh client source.
# Display the source IP address of the SSH client.
<Sysname> display ssh client source
The source IP address you specified is 192.168.0.1
display ssh server-info
View
Default Level
1: Monitor level
None
Use the display ssh server-info command on a client to display mappings between SSH servers and their host public keys saved on the client.
When an SSH client needs to authenticate the SSH server, it uses the locally saved public key of the server for the authentication. If the authentication fails, you can use this command to check the public key of the server saved on the client.
Related commands: ssh client authentication server.
This command is also available on an SFTP client.
# Display the mappings between host public keys and SSH servers saved on the client.
<Sysname> display ssh server-info
Server Name(IP) Server public key name
______________________________________________________
192.168.0.1 abc_key01
192.168.0.2 abc_key02
Table 1-4 display ssh server-info command output description
Server Name(IP) |
Name or IP address of the server |
Server public key name |
Name of the host public key of the server |
ssh client authentication server server assign publickey keyname
undo ssh client authentication server server assign publickey
View
Default Level
2: System level
server: IP address or name of the server, a string of 1 to 80 characters.
keyname: Name of the host public key of the server, a string of 1 to 64 characters.
Use the ssh client authentication server command on a client to configure the host public key of the server so that the client can determine whether the server is trustworthy.
Use the undo ssh authentication server command to remove the configuration.
By default, the host public key of the server is not configured, and when logging into the server, the client uses the IP address or host name used for login as the public key name.
If the client does not support first authentication, it will reject unauthenticated servers. In this case, you need to configure the public keys of the servers and specify the mappings between public keys and servers on the client, so that the client uses the correct public key of a server to authenticate the server.
Note that the specified host public key of the server must already exist.
Related commands: ssh client first-time enable.
# Configure the public key of the server with the IP address of 192.168.0.1 to be key1.
[Sysname] ssh client authentication server 192.168.0.1 assign publickey key1
undo ssh client first-time
View
Default Level
2: System level
None
Use the ssh client first-time enable command to enable the first authentication function.
Use the undo ssh client first-time command to disable the function.
By default, the function is enabled.
With first-time authentication, when an SSH client not configured with the server host public key accesses the server for the first time, the user can continue accessing the server, and save the host public key on the client. When accessing the server again, the client will use the saved server host public key to authenticate the server.
Without first-time authentication, a client not configured with the server host public key will deny to access the server. To access the server, a user must configure in advance the server host public key locally and specify the public key name for authentication.
Note that as the server may update its key pairs periodically, clients must obtain the most recent public keys of the server for successful authentication of the server.
# Enable the first authentication function.
[Sysname] ssh client first-time enable
ssh client source { ip ip-address | interface interface-type interface-number }
undo ssh client source
View
Default Level
3: Manage level
ip ip-address: Specifies a source IPv4 address.
interface interface-type interface-number: Specifies a source interface by its type and number.
Use the ssh client source command to specify the source IPv4 address or source interface of the SSH client.
Use the undo ssh client source command to remove the configuration.
By default, an SSH client uses the IP address of the interface specified by the route to access the SSH server.
Related commands: display ssh client source.
# Specify the source IPv4 address of the SSH client as 192.168.0.1.
[Sysname] ssh client source ip 192.168.0.1
ssh2 server [ port-number ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Default Level
0: Visit level
server: IPv4 address or host name of the server, a case-insensitive string of 1 to 20 characters.
port-number: Port number of the server, in the range 0 to 65535. The default is 22.
identity-key: Specifies the algorithm for publickey authentication, either dsa or rsa. The default is dsa.
prefer-ctos-cipher: Preferred encryption algorithm from client to server, defaulted to aes128.
l 3des: Encryption algorithm 3des-cbc.
l aes128: Encryption algorithm aes128-cbc
l des: Encryption algorithm des-cbc.
prefer-ctos-hmac: Preferred HMAC algorithm from client to server, defaulted to sha1.
l md5: HMAC algorithm hmac-md5.
l md5-96: HMAC algorithm hmac-md5-96.
l sha1: HMAC algorithm hmac-sha1.
l sha1-96: HMAC algorithm hmac-sha1-96.
prefer-kex: Preferred key exchange algorithm, defaulted to dh-group-exchange.
l dh-group-exchange: Key exchange algorithm diffie-hellman-group-exchange-sha1.
l dh-group1: Key exchange algorithm diffie-hellman-group1-sha1.
l dh-group14: Key exchange algorithm diffie-hellman-group14-sha1.
prefer-stoc-cipher: Preferred encryption algorithm from server to client, defaulted to aes128.
prefer-stoc-hmac: Preferred HMAC algorithm from server to client, defaulted to sha1.
Use the ssh2 command to establish a connection to an IPv4 SSH server and specify the public key algorithm, the preferred key exchange algorithm, and the preferred encryption algorithms and preferred HMAC algorithms between the client and server.
Note that when the client’s authentication method is publickey, the client needs to get the local private key for validation. As the publickey authentication includes RSA and DSA algorithms, you must specify an algorithm (by using the identity-key keyword) in order to get the correct data for the local private key. By default, the encryption algorithm is DSA.
# Log in to remote SSH2.0 server 10.214.50.51, using the following algorithms:
l Preferred key exchange algorithm: DH-group1
l Preferred encryption algorithm from server to client: AES128
l Preferred HMAC algorithm from client to server: MD5
l Preferred HMAC algorithm from server to client: SHA1-96.
<Sysname> ssh2 10.214.50.51 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
sftp server enable
undo sftp server enable
View
Default Level
2: System level
None
Use the sftp server enable command to enable SFTP server.
Use the undo sftp server enable command to disable SFTP server.
By default, SFTP server is disabled.
# Enable SFTP server.
[Sysname] sftp server enable
undo sftp server idle-timeout
View
Default Level
2: System level
time-out-value: Timeout period in minutes. It ranges from 1 to 35,791.
Use the sftp server idle-timeout command to set the idle timeout period for SFTP user connections.
Use the undo sftp server idle-timeout command to restore the default.
By default, the idle timeout period is 10 minutes.
# Set the idle timeout period for SFTP user connections to 500 minutes.
[Sysname] sftp server idle-timeout 500
bye
View
SFTP client view
Default Level
3: Manage level
None
Use the bye command to terminate the connection with a remote SFTP server and return to user view.
This command functions as the exit and quit commands.
# Terminate the connection with the remote SFTP server.
sftp-client> bye
Bye
Connection closed.
<Sysname>
cd [ remote-path ]
View
SFTP client view
Default Level
3: Manage level
remote-path: Name of a path on the server.
Use the cd command to change the working path on a remote SFTP server. With the argument not specified, the command displays the current working path.
l You can use the cd .. command to return to the upper-level directory.
l You can use the cd / command to return to the root directory of the system.
# Change the working path to new1.
sftp-client> cd new1
Current Directory is:
/new1
cdup
View
SFTP client view
Default Level
3: Manage level
None
Use the cdup command to return to the upper-level directory.
# From the current working directory /new1, return to the upper-level directory.
sftp-client> cdup
delete remote-file&<1-10>
View
SFTP client view
Default Level
3: Manage level
remote-file&<1-10>: Name of a file on the server. &<1-10> means that you can provide up to 10 filenames, which are separated by space.
Use the delete command to delete the specified file(s) from a server.
This command functions as the remove command.
# Delete file temp.c from the server.
sftp-client> delete temp.c
The following files will be deleted:
/temp.c
Are you sure to delete it? [Y/N]:y
This operation may take a long time. Please wait...
File successfully Removed
View
SFTP client view
Default Level
3: Manage level
-a: Displays the filenames or the folder names of the specified directory.
-l: Displays in a list form detailed information of the files and folders of the specified directory.
remote-path: Name of the directory to be queried.
Use the dir command to display file and folder information under a specified directory.
With the –a and –l keyword not specified, the command displays detailed information of files and folders under the specified directory in a list form.
With the remote-path not specified, the command displays the file and folder information of the current working directory.
This command functions as the ls command.
# Display in a list form detailed file and folder information under the current working directory.
sftp-client> dir
-rwxrwxrwx 1 noone nogroup 1759 Aug 23 06:52 config.cfg
-rwxrwxrwx 1 noone nogroup 225 Aug 24 08:01 pubkey2
-rwxrwxrwx 1 noone nogroup 283 Aug 24 07:39 pubkey1
-rwxrwxrwx 1 noone nogroup 225 Sep 28 08:28 pub1
drwxrwxrwx 1 noone nogroup 0 Sep 28 08:24 new1
drwxrwxrwx 1 noone nogroup 0 Sep 28 08:18 new2
-rwxrwxrwx 1 noone nogroup 225 Sep 28 08:30 pub2
display sftp client source
View
Default Level
1: Monitor level
None
Use the display sftp client source command to display the source IP address or source interface currently set for the SFTP client.
If neither source IP address nor source interface is specified for the SFTP client, the system will prompt you to specify the source information.
Related commands: sftp client source.
# Display the source IP address of the SFTP client.
<Sysname> display sftp client source
exit
View
SFTP client view
Default Level
3: Manage level
None
Use the exit command to terminate the connection with a remote SFTP server and return to user view.
This command functions as the bye and quit commands.
sftp-client> exit
Bye
Connection closed.
<Sysname>
View
SFTP client view
Default Level
3: Manage level
remote-file: Name of a file on the remote SFTP server.
local-file: Name for the local file.
Use the get command to download a file from a remote SFTP server and save it locally.
If you do not specify the local-file argument, the file will be saved locally with the same name as that on the remote SFTP server.
# Download file temp1.c and save it as temp.c locally.
sftp-client> get temp1.c temp.c
Remote file:/temp1.c ---> Local file: temp.c
Downloading file successfully ended
help [ all | command-name ]
View
SFTP client view
Default Level
3: Manage level
all: Displays a list of all commands.
command-name: Name of a command.
Use the help command to display a list of all commands or the help information of an SFTP client command.
With neither the argument nor the keyword specified, the command displays a list of all commands.
# Display the help information of the get command.
sftp-client> help get
get remote-path [local-path] Download file.Default local-path is the same
as remote-path
View
SFTP client view
Default Level
3: Manage level
Use the ls command to display file and folder information under a specified directory.
This command functions as the dir command.
sftp-client> ls
mkdir remote-path
View
SFTP client view
Default Level
3: Manage level
remote-path: Name for the directory on a remote SFTP server.
Use the mkdir command to create a directory on a remote SFTP server.
# Create a directory named test on the remote SFTP server.
sftp-client> mkdir test
New directory created
View
SFTP client view
Default Level
3: Manage level
local-file: Name of a local file.
remote-file: Name for the file on a remote SFTP server.
Use the put command to upload a local file to a remote SFTP server.
If you do not specify the remote-file argument, the file will be saved remotely with the same name as the local one.
# Upload local file temp.c to the remote SFTP server and save it as temp1.c.
sftp-client> put temp.c temp1.c
Local file:temp.c ---> Remote file: /temp1.c
Uploading file successfully ended
pwd
View
SFTP client view
Default Level
3: Manage level
None
Use the pwd command to display the current working directory of a remote SFTP server.
# Display the current working directory of the remote SFTP server.
sftp-client> pwd
View
SFTP client view
Default Level
3: Manage level
None
Use the quit command to terminate the connection with a remote SFTP server and return to user view.
This command functions as the bye and exit commands.
sftp-client> quit
Bye
Connection closed.
<Sysname>
remove remote-file&<1-10>
View
SFTP client view
Default Level
3: Manage level
remote-file&<1-10>: Name of a file on an SFTP server. &<1-10> means that you can provide up to 10 filenames, which are separated by space.
Use the remove command to delete the specified file(s) from a remote server.
This command functions as the delete command.
sftp-client> remove temp.c
/temp.c
This operation may take a long time.Please wait...
rename oldname newname
View
SFTP client view
Default Level
3: Manage level
oldname: Original file name or directory name.
newname: New file name or directory name.
Use the rename command to change the name of a specified file or directory on an SFTP server.
# Change the name of a file on the SFTP server from temp1.c to temp2.c.
sftp-client> rename temp1.c temp2.c
File successfully renamed
rmdir remote-path&<1-10>
View
SFTP client view
Default Level
3: Manage level
remote-path&<1-10>: Name of the directory on the remote SFTP server. &<1-10> means that you can provide up to 10 directory names that are separated by space.
Use the rmdir command to delete the specified directories from an SFTP server.
# On the SFTP server, delete directory temp1 in the current directory.
sftp-client> rmdir temp1
Directory successfully removed
sftp server [ port-number ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Default Level
3: Manage level
l aes128: Encryption algorithm aes128-cbc.
Use the sftp command to establish a connection to a remote IPv4 SFTP server and enter SFTP client view.
# Connect to SFTP server 10.1.1.2, using the following algorithms:
l Preferred key exchange algorithm: dh-group1.
l Preferred encryption algorithm from server to client: aes128.
l Preferred HMAC algorithm from client to server: md5.
l Preferred HMAC algorithm from server to client: sha1-96.
<Sysname> sftp 10.1.1.2 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
Input Username:
sftp client source { ip ip-address | interface interface-type interface-number }
undo sftp client source
View
Default Level
3: Manage level
Use the sftp client source command to specify the source IPv4 address or interface of an SFTP client.
Use the undo sftp source-interface command to remove the configuration.
By default, a client uses the IP address of the interface specified by the route to access the SFTP server.
Related commands: display sftp client source.
# Specify the source IP address of the SFTP client as 192.168.0.1.
[Sysname] sftp client source ip 192.168.0.1
