23-QoS Commands
Chapters Download (244.19 KB)
Table of Contents
1 Traffic Policing and Line Rate Configuration Commands
Traffic Policing Configuration Commands
bandwidth downstream policy enable
High-Priority Packet Buffer Configuration Commands
bandwidth downstream high-priority enable
bandwidth downstream priority-queue
2 QoS Policy Configuration Commands
Traffic Behavior Configuration Commands
QoS Policy Configuration and Application Commands
qos apply policy (interface view, port group view)
3 Congestion Management Configuration Commands
SP Queuing Configuration Commands
WRR Queuing Configuration Commands
4 Priority Mapping Configuration Commands
Priority Mapping Table Configuration Commands
Port Priority Configuration Commands
Trusted Precedence Type Configuration Commands
5 Traffic Mirroring Configuration Commands
On the S3600 series EPON OLT switches, you can use QoS policies to perform traffic policing for Ethernet ports and OLT ports. For details about the related commands, refer to QoS Policy Configuration Commands. This section introduces the traffic policing configuration commands for UNI ports.
bandwidth downstream { max-bandwidth value | max-burstsize value } *
undo bandwidth downstream { max-bandwidth | max-burstsize } *
View
ONU port view
Default Level
2: System level
max-bandwidth value: Specifies the maximum bandwidth in kbps. The value argument ranges from 0 to 999994. The system default is 999994 kbps.
max-burstsize value: Specifies the maximum burst buffer size in bytes. The value argument ranges from 0 to 8388480. The system default is 8388480 bytes.
Use the bandwidth downstream command to configure the downlink bandwidth limit.
Use the undo bandwidth downstream command to restore the default.
Related commands: bandwidth downstream policy enable.
l This command takes effect only when the downlink bandwidth allocation policy is enabled.
l The configured downlink bandwidth limit takes effect only on known unicasts, but not on unknown unicasts, multicasts, or broadcasts.
# Set the downstream bandwidth limit to 800000 kbps and maximum burst size to 8000000 bytes on ONU 1/0/1:1.
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] bandwidth downstream max-bandwidth 800000 max-burstsize 8000000
undo bandwidth downstream policy enable
View
ONU port view
Default Level
2: System level
None
Use the bandwidth downstream command to enable the downlink bandwidth allocation policy for the ONU port.
By default, the downlink bandwidth allocation policy is disabled.
Related commands: bandwidth downstream.
The downlink bandwidth limit configuration commands take effect only when the downlink bandwidth allocation policy is enabled.
# Enable the downlink bandwidth allocation policy for ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] bandwidth downstream policy enable
uni uni-number port-policy { { inbound { cir cir-value | bucket-depth bucket-depth-value | extra-burst-size ebs-value }* } | outbound cir cir-value [ pir pir-value] }
undo uni uni-number port-policy { inbound | outbound }
View
ONU port view
Default Level
2: System level
uni-number: UNI number, in the range 1 to the number of UNI ports of the current ONU. The number of UNIs can be up to 80.
inbound: Configure the traffic policing parameters for inbound packets on the UNI port.
cir-value: Committed information rate (CIR) value – guaranteed bandwidth, in the range 0 to 1024000 Kbps. It must be a multiple of 64 and defaults to 102400.
bucket-depth-value: Bucket depth – the maximum burst bandwidth, in the range 1522 to 65535 bytes. The default is 1522.
ebs-value: Available extra bandwidth when the maximum burst bandwidth is exceeded. It is in the range 0 to 1522 bytes, and the default is 0.
pir-value: Peak information rate, in the range of 1 to 1024000 kbps. It must be a multiple of 64.
outbound: Configure the traffic policing parameters for outbound packets on the UNI port.
Use the uni port-policing command to configure the traffic policing parameters for the inbound/outbound packets on a UNI port.
Use the undo uni port-policy command to restore the traffic policing parameters for the inbound/outbound packets on a UNI port to defaults.
By default, no traffic policing parameter is configured for a UNI.
# Configure the traffic policing parameters for UNI 1.
[Sysname-Onu1/0/1:1] uni 1 port-policy inbound cir 25600 bucket-depth 5608 extra-burst-size 800
View
Default Level
1: Monitor level
interface-type interface-number: Specify an interface by its type and number.
Use the display qos lr interface command to view the line rate configuration information and operational statistics on a specified interface or all the interfaces.
If no interface is specified, the line rate configuration information and operational statistics on all the interfaces are displayed.
# Display the line rate configuration information and operational statistics on all the interfaces.
Interface: Olt1/0/1
Direction: Outbound
CIR 640 (kbps), CBS 50000 (byte)
Table 1-1 display qos lr command output description
Interface type and interface number |
Direction |
The direction in which the line rate configuration is applied: inbound or outbound Currently, the S3600 series EPON OLT switches support line rate only in the outbound direction. |
CIR |
Committed information rate (CIR) in kbps |
CBS |
Committed burst size (CBS) in bytes, that is, the depth of the token bucket for holding bursty traffic |
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
View
Interface view, port group view, OLT port view
Default Level
2: System level
outbound: Limits the rate of outgoing packets on the interface.
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps. The range of committed-information-rate is from 64 to 1000000, and committed-information-rate argument must be a multiple of 64.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes, in the range of 4000 to 16000000. The default CBS is the traffic transmitted at the rate of CIR in 500 Milliseconds.
Use the qos lr command to limit the rate of incoming packets or outgoing packets on the interface.
Use the undo qos lr command to remove the rate limit.
Settings in interface view are effective on the current interface; settings in port group view are effective on all ports in the port group.
# Limit the rate of outgoing packets on OLT 1/0/1, with CIR 256 kbps, CBS 5000 bytes.
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] qos lr outbound cir 256 cbs 5000
undo bandwidth downstream high-priority enable
View
ONU port view
Default Level
2: System level
None
Use the bandwidth downstream high-priority enable command to reserve high-priority buffer for the ONU corresponding to the current port.
Use the undo bandwidth downstream high-priority enable command to restore the default.
By default, no high-priority packet buffer is reserved for any ONU.
Related commands: bandwidth downstream priority-queue.
The high-priority packet buffer configuration takes effect only when the downlink bandwidth allocation policy is enabled.
# Enable the high-priority packet buffer for the ONU corresponding to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] bandwidth downstream high-priority enable
bandwidth downstream priority-queue priority high-priority-reserved value
undo bandwidth downstream priority-queue high-priority-reserved
View
OLT port view
Default Level
2: System level
priority: Queue priority, in the range 0 to 7.
value: Buffer size reserved for packets of high-priority queues, in bytes. It is in the range 0 to 131070 and defaults to 0.
Use the bandwidth downstream priority-queue command to configure thresholds for high-priority queues and reserve user-defined buffer sizes for high-priority queues based on the thresholds.
Use the undo bandwidth downstream priority-queue high-priority-reserved command to cancel the configuration.
By default, no priority threshold or buffer size is set for high-priority packet buffer.
The downlink packets on an OLT port are considered as high-priority only if their priority is greater than or equal to the priority value.
This command just configures buffer parameters. To make these parameters take effect, use the bandwidth downstream high-priority enable command to enable high-priority packet buffer for the specified ONU.
# Reserve 100 bytes of buffer for the packets whose priorities are greater than or equal to 3.
[Sysname-Olt1/0/1] bandwidth downstream priority-queue 3 high-priority-reserved 100
display traffic classifier user-defined [ tcl-name ]
View
Default Level
1: Monitor level
user-defined: Displays user-defined classes.
tcl-name: Name of a class.
Use the display traffic classifier command to display information about classes.
If no class name is specified, information about all system-defined or user-defined classes is displayed.
# Display information about all user-defined classes.
User Defined Classifier Information:
Classifier: USER1
Operator: AND
Rule(s) : if-match ip-precedence 5
Classifier: database
Operator: AND
Rule(s) : if-match acl 3131
Table 2-1 display traffic classifier user-defined command output description
User Defined Classifier Information |
User-defined class information |
Classifier |
Class name and its match criteria |
Operator |
Logical relationship between match criteria |
Rule(s) |
Match criteria |
if-match match-criteria
undo if-match match-criteria
View
Class view
Default Level
2: System level
not: Specifies to match packets not conforming to the specified criterion.
match-criteria: Match criterion. Table 2-2 shows the available criteria.
Table 2-2 The keyword and argument combinations for the match-criteria argument
Keyword and argument combination |
acl { access-list-number | name acl-name } |
Specifies to match an IPv4 ACL specified by its number or name. The access-list-number argument specifies an ACL by its number, which ranges from 2000 to 4999; the name acl-name keyword-argument combination specifies an ACL by its name. In a class configured with the operator and, the logical relationship between rules defined in the referenced IPv4 ACL is or. |
acl ipv6 { access-list-number | name acl-name } |
Specifies to match an IPv6 ACL specified by its number or name. The access-list-number argument specifies an ACL by its number, which ranges from 2000 to 3999; the name acl-name keyword-argument combination specifies an ACL by its name. In a class configured with the operator and, the logical relationship between rules defined in the referenced IPv6 ACL is or. |
any |
Match all packets |
dscp dscp-list |
Match DSCP values. The dscp-list is a list of up to 8 DSCP values. A DSCP value is in the range 0 to 63. |
destination-mac mac-address |
Match a destination MAC address |
customer-dot1p 8021p-list |
Match the 802.1p priority of the customer network. The 8021p-list argument is a list of up to eight 802.1p priority values. An 802.1p priority is in the range 0 to 7. |
service-dot1p 8021p-list |
Match the 802.1p priority of the service provider network. The 8021p-list argument is a list of up to eight 802.1p priority values. An 802.1p priority is in the range 0 to 7. |
ip-precedence ip-precedence-list |
Match IP precedence. The ip-precedence-list is a list of up to 8 IP precedence values. An IP precedence is in the range of 0 to 7. |
protocol protocol-name |
Match a protocol. The protocol-name can be IP or IPv6. |
source-mac mac-address |
Match a source MAC address |
customer-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 } |
Match the VLAN IDs of customer networks. The vlan-id-list is a list of up to 8 VLAN IDs. The vlan-id1 to vlan-id2 specifies a VLAN ID range, where the vlan-id1 must be smaller than the vlan-id2. A VLAN ID is in the range of 1 to 4094. |
service-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 } |
Match the VLAN IDs of ISP networks. The vlan-id-list is a list of up to 8 VLAN IDs. The vlan-id1 to vlan-id2 specifies a VLAN ID range, where the vlan-id1 must be smaller than the vlan-id2. A VLAN ID is in the range of 1 to 4094. |
The undo if-match [ not ] command provides a special form to change the previous ACL referenced for traffic classification into a new ACL: undo if-match [ not ] acl [ ipv6 ] { acl-number | name acl-name } [ update acl [ ipv6 ] { acl-number | name acl-name } ].
Use the if-match command to define a match criterion.
Use the undo if-match command to remove the match criterion.
When defining match criteria, note the following:
1) Define an ACL-based match criterion
l If the ACL referenced in the if-match command does not exist, the class cannot be applied to hardware.
l For a class, you can reference an ACL twice by its name and number respectively with the if-match command.
2) Define a criterion to match a destination MAC address
l You can configure multiple destination MAC address match criteria in a class.
l A destination MAC address match criterion is significant only to Ethernet interfaces.
3) Define a criterion to match a source MAC address
l You can configure multiple source MAC address match criteria in a class.
l A criterion to match a source MAC address is significant only to Ethernet interfaces.
4) Define a criterion to match DSCP precedence values
l You can configure multiple DSCP precedence match criteria in a class. All the defined DSCP values are arranged in ascending order automatically.
l You can configure up to eight DSCP values in one command line. If multiple identical DSCP values are specified, the system considers them as one. If a packet matches one of the defined DSCP values, it is considered matching the if-match clause.
l To delete a criterion matching DSCP values, the specified DSCP values must be identical with those defined in the rule (sequence may be different).
5) Define a criterion to match the 802.1p priority values of the customer network or service provider network
l You can configure multiple 802.1p priority match criteria in a class. All the defined 802.1p values are arranged in ascending order automatically.
l You can configure up to eight 802.1p priority values in one command line. If the same 802.1p priority value is specified multiple times, the system considers them as one. If a packet matches one of the defined 802.1p priority values, it is considered matching the if-match clause.
l To delete a criterion matching 802.1p priority values, the specified 802.1p priority values in the command must be identical with those defined in the criterion (sequence may be different).
6) Define a criterion to match IP precedence values
l You can configure multiple IP precedence match criteria in a class. The defined IP precedence values are arranged automatically in ascending order.
l You can configure up to eight IP precedence values in one command line. If the same IP precedence is specified multiple times, the system considers them as one. If a packet matches one of the defined IP precedence values, it is considered matching the if-match clause.
l To delete a criterion matching IP precedence values, the specified IP precedence values in the command must be identical with those defined in the criterion (sequence may be different).
7) Define a criterion to match customer network VLAN IDs or service provider network VLAN IDs
l You can configure multiple VLAN ID match criteria in a class. The defined VLAN IDs are automatically arranged in ascending order.
l You can configure multiple VLAN IDs in one command line. If the same VLAN ID is specified multiple times, the system considers them as one. If a packet matches one of the defined VLAN IDs, it is considered matching the if-match clause.
l To delete a criterion matching VLAN IDs, the specified VLAN IDs in the command must be identical with those defined in the criterion (sequence may be different).
The matching criteria listed below must be unique in a traffic class with the operator being AND. Therefore, even though you can define multiple if-match clauses for these matching criteria or input multiple values for a list argument (such as the 8021p-list argument) listed below in a traffic class, avoid doing that. Otherwise, the QoS policy referencing the class cannot be applied to interfaces successfully.
l customer-dot1p 8021p-list
l customer-vlan-id vlan-id-list
l destination-mac mac-address
l dscp dscp-list
l ip-precedence ip-precedence-list
l service-dot1p 8021p-list
l service-vlan-id vlan-id-list
l source-mac mac-address
To create multiple if-match clauses or specify multiple values for a list argument for any of the matching criteria listed above, ensure that the operator of the class is OR.
Related commands: traffic classifier.
# Define a match criterion for class class1 to match the packets with the destination MAC address 0050-ba27-bed3.
# Define a match criterion for class class2 to match the packets with the source MAC address 0050-ba27-bed2.
# Define a match criterion for class class1 to match ACL 3101.
# Define a match criterion for class class1 to match the ACL named flow.
# Define a match criterion for class class1 to match IPv6 ACL 3101.
[Sysname-classifier-class1] if-match ipv6 acl 3101
# Define a match criterion for class class1 to match the IPv6 ACL named flow.
[Sysname-classifier-class1] if-match ipv6 acl name flow
# Define a match criterion for class class1 to match all packets.
# Define a match criterion for class class1 to match the packets with a DSCP precedence of 1, 6 or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for class class1 to match the packets with an IP precedence of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for class class1 to match the packets with a local precedence of 1 or 6.
[Sysname-classifier-class1] if-match local-precedence 1 6
# Define a match criterion for class class1 to match IP packets.
# Define a match criterion for class class1 to match the packets with customer network VLAN ID 1, 6, or 9.
# Change the match criterion of class class1 from ACL 2008 to ACL 2009.
[Sysname-classifier-class1] undo if-match acl 2008 update acl 2009
traffic classifier tcl-name [ operator { and | or } ]
undo traffic classifier tcl-name
View
Default Level
2: System level
and: Specifies the relationship between the match criteria in the class as logic AND. That is, the packets that match all the criteria belong to this class.
or: Specifies the relationship between the criteria in the class as logic OR. That is, the packets that match any of the criteria belong to this class.
tcl-name: Class name.
Use the traffic classifier command to define a class and enter class view.
Use the undo traffic classifier command to remove a class.
By default, the relationship between match criteria is and.
Related commands: qos policy, qos apply policy, classifier behavior.
# Define a class named class1.
accounting
undo accounting
View
Traffic behavior view
Default Level
2: System level
None
Use the accounting command to enable traffic accounting for the traffic behavior.
Use the undo accounting command to disable traffic accounting. You can use the display qos policy interface command and the display qos vlan-policy command to view the related statistics information.
Related commands: qos policy, traffic behavior, classifier behavior.
# Configure traffic accounting for traffic behavior database.
[Sysname-behavior-database] accounting
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ green action ] [ red action ] [ yellow action ]
undo car
View
Default Level
2: System level
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps. The committed-information-rate argument ranges from 64 to 10000000 and must be a multiple of 64.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The committed-burst-size argument ranges from 4000 to 16000000. The default CBS is the traffic transmitted at the rate of CIR in 500 Milliseconds.
ebs excess-burst-size: Specifies excess burst size (EBS) in bytes. The excess-burst-size argument ranges from 0 to 16000000, the default is 0.
pir peak-information-rate: Specifies the peak information rate (PIR) in kbps. The peak-information-rate argument ranges from 64 to 10000000.
green action: Specifies the action to be conducted for the traffic conforming to CIR. The action argument can be:
l discard: Drops the packets.
l pass: Forwards the packets.
l remark-dscp-pass new-dscp: Marks the packets with a new DSCP precedence and forwards them to their destinations. The new-dscp argument is in the range 0 to 63.
By default, packets conforming to CIR are forwarded.
red action: Specifies the action to be conducted for the traffic conforms to neither CIR nor PIR. The action argument can be:
By default, packets conforming to neither CIR nor PIR are dropped.
yellow action: Specifies the action to be conducted for the traffic conforms to PIR but does not conform to CIR. The action argument can be:
By default, packets conforming to PIR but not conforming to CIR are forwarded.
Use the car command to configure a CAR policy for the traffic behavior.
Use the undo car command to remove a CAR policy from the traffic behavior.
If this command is configured multiple times for the same traffic behavior, the last configuration takes effect.
# Configure a CAR policy for traffic behavior database. The CIR is 256 kbps, CBS is 5000 bytes and EBS is 0. The conforming packets are allowed to pass, and excess packets are marked with DSCP precedence 0 and forwarded.
[Sysname-behavior-database] car cir 256 cbs 50000 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior user-defined [ behavior-name ]
View
Default Level
1: Monitor level
user-defined: Displays user-defined traffic behaviors.
behavior-name: Behavior name. If no traffic behavior is specified, the information of all the user-defined behaviors is displayed.
Use the display traffic behavior command to display traffic behavior information.
# Display user-defined traffic behaviors.
User Defined Behavior Information:
Behavior: 1
Filter enable: deny
Mirror enable:
Mirror type: cpu
Accounting enable
Committed Access Rate:
CIR 64 (kbps), CBS 4000 (byte), EBS 4000 (byte)
Green Action: pass
Red Action: discard
Yellow Action: remark dscp af23 and pass
Redirect enable:
Redirect type: cpu
Redirect destination: cpu
Marking:
Remark dot1p COS 2
Marking:
Remark Customer VLAN ID 100
Marking:
Remark drop precedence 1
Marking:
Remark IP precedence 1
Marking:
Remark local precedence 1
Marking:
Remark qos local ID 1
Marking:
Remark Service VLAN ID 200
Table 2-3 display traffic behavior user-defined command output description
User Defined Behavior Information |
User-defined behavior information. |
Behavior |
Name of a behavior. |
Remark |
Type of precedence marked for traffic, which can be DSCP, IP precedence, MPLS EXP, FR DE, dot1p (COS), ATM CLP, qos local ID, local precedence, drop precedence, customer VLAN ID, service VLAN ID, forwarding class, or Bfi ID. For detailed information about these precedence types, refer to Traffic Behavior Configuration Commands. |
Accounting enable |
Traffic accounting mode. |
Filter enable |
Traffic filtering option: permit or deny. |
Committed Access Rate |
Information about the CAR policy. |
Green Action |
Action to be taken on green packets, which can be pass, remark-dscp-pass or discard. |
Red Action |
Action to be taken on red packets, which can be pass, remark-dscp-pass or discard. |
Yellow Action |
Action to be taken on yellow packets, which can be pass, remark-dscp-pass or discard. |
Mirror enable |
Traffic mirroring configuration information. |
Mirror type |
Traffic mirroring type, which can be VLAN, CPU, or interface. |
Mirror destination |
Mirroring destination, CPU or interface name. |
Redirect enable |
Traffic redirecting configuration information. |
Redirect type |
Traffic redirecting type, which can be redirecting the CPU, an interface, or the next-hop. |
Redirect destination |
Traffic redirecting destination, an interface name, the IP address of the next hop, or the CPU |
filter { deny | permit }
undo filter
View
Default Level
2: System level
deny: Drops the packets.
permit: Permits the packet to pass through.
Use the filter command to configure a traffic filtering action for the traffic behavior.
Use the undo filter command to remove the traffic filtering action.
# Configure the traffic filtering action as deny for traffic behavior database.
redirect { cpu | interface interface-type interface-number | next-hop { ipv4-add [ ipv4-add ] | ipv6-add [ interface-type interface-number ] [ ipv6-add [ interface-type interface-number ] ] } }
undo redirect { cpu | interface interface-type interface-number | next-hop }
View
Default Level
2: System level
cpu: Redirects traffic to the CPU.
interface: Redirects traffic to the specified interface.
interface-type interface-number: Interface identified by an interface number and interface type.
next-hop: Redirects traffic to a next hop.
ipv4-add: IPv4 address of the next hop.
ipv6-add: IPv6 address of the next hop. If the IPv6 address is a link-local address, you must specify an interface for the IPv6 address of the next hop; if the IPv6 address is not a link-local address, you need not specify an interface for the IPv6 address of the next hop.
Use the redirect command to configure a traffic redirect action for the traffic behavior.
Use the undo redirect command to remove the traffic redirect action.
The action of redirecting traffic to CPU, the action of redirecting traffic to an interface, and the action of redirecting traffic to the next hop are mutually exclusive with each other in the same traffic behavior.
# Configure the action of redirecting traffic to OLT 1/0/1 for traffic behavior database.
[Sysname-behavior-database] redirect interface olt 1/0/1
remark customer-vlan-id vlan-id-value
undo remark customer-vlan-id
View
Default Level
2: System level
vlan-id-value: Customer network VLAN ID to be marked for packets, in the range of 1 to 4094.
Use the remark customer-vlan-id command to configure the action of setting the specified customer network VLAN ID for packets for the traffic behavior.
Use the undo remark customer-vlan-id command to remove the action.
# Set the customer network VLAN ID to 2.
[Sysname-behavior-database] remark customer-vlan-id 2
remark dot1p 8021p
undo remark dot1p
View
Default Level
2: System level
8021p: 802.1p priority to be marked for packets, in the range of 0 to 7.
Use the remark dot1p command to configure the action of setting the specified 802.1p priority for packets.
Use the undo remark dot1p command to remove the action.
# Set the 802.1p priority to 2.
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence drop-precedence-value
undo remark drop-precedence
View
Default Level
2: System level
drop-precedence-value: Drop precedence to be marked for packets, in the range of 0 to 2.
Use the remark drop-precedence command to configure the action of setting the specified drop precedence for packets.
Use the undo remark drop-precedence command to remove the action.
# Set drop precedence 2 for packets.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp dscp-value
undo remark dscp
View
Default Level
2: System level
dscp-value: DSCP value, in the range of 0 to 63 or a keyword, as shown in Table 2-4.
Table 2-4 DSCP keywords and values
Keyword |
DSCP value (binary) |
DSCP value (decimal) |
default |
000000 |
0 |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
ef |
101110 |
46 |
Use the remark dscp command to configure the action of setting the specified DSCP value for packets.
Use the undo remark dscp command to remove the action.
# Set the DSCP value of packets to 6.
remark ip-precedence ip-precedence-value
undo remark ip-precedence
View
Default Level
2: System level
ip-precedence-value: IP precedence value to be marked for packets, in the range of 0 to 7.
Use the remark ip-precedence command to configure the action of setting the specified IP precedence for packets.
Use the undo remark ip-precedence command to remove the action.
# Set the IP precedence of packets to 6.
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence local-precedence
undo remark local-precedence
View
Default Level
2: System level
local-precedence: Local precedence value to be marked for packets, in the range of 0 to 7.
Use the remark local-precedence command to configure the action of setting the specified local precedence for packets.
Use the undo remark local-precedence command to remove the action.
# Set the local precedence of packets to 2.
remark service-vlan-id vlan-id-value
undo remark service-vlan-id
View
Default Level
2: System level
vlan-id-value: Service provider network VLAN ID to be marked for packets, in the range of 1 to 4094.
Use the remark service-vlan-id command to configure the action of setting the specified service provider network VLAN ID for packets.
Use the undo remark service-vlan-id command to remove the action.
# Configure the action of marking packets with service provider network VLAN ID 666.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] remark service-vlan-id 666
View
Default Level
2: System level
Use the traffic behavior command to create a traffic behavior and enter traffic behavior view.
Use the undo traffic classifier command to remove a traffic behavior.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
classifier tcl-name behavior behavior-name
undo classifier tcl-name
View
Policy view
Default Level
2: System level
Use the classifier behavior command to specify a behavior for a class in the policy.
Use the undo classifier command to remove a class from the policy.
Note that:
l Each class in the policy can be associated with only one behavior.
l If the class and traffic behavior specified for the command do not exist, the system creates a null class and a null traffic behavior.
Related commands: qos policy.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
display qos policy user-defined [ policy-name [ classifier tcl-name ] ]
View
Default Level
1: Monitor level
user-defined: Displays user-defined QoS policies.
policy-name: QoS policy name, a string of 1 to 31 characters. If no policy is specified, configuration information of all the policies is displayed.
Use the display qos policy command to display QoS policy configuration information.
# Display the configuration information of user-defined QoS policies.
User Defined QoS Policy Information:
Policy: 1
Classifier: 1
Behavior: 1
Filter enable: deny
Mirror enable:
Mirror type: cpu
Accounting enable
Green Action: remark dscp af23 and pass
Red Action: discard
Yellow Action: pass
Redirect enable:
Redirect type: interface
Redirect destination: Olt1/0/1
Marking:
Remark dot1p COS 2
Marking:
Marking:
Marking:
Marking:
Marking:
Marking:
Table 2-5 display qos policy command output description
Policy |
Policy name |
Classifier |
Class name A policy can contain multiple classes, and each class is associated with a traffic behavior. A class can be configured with multiple match criteria. Refer to the traffic classifier command for related information. |
Behavior |
Behavior associated with the class. A behavior is associated with a class. It can be configured with multiple actions. Refer to the traffic behavior command for related information. |
display qos policy global [ inbound ]
View
Default Level
1: Monitor level
inbound: Displays the QoS policy applied globally in the inbound direction of all ports.
Use the display qos policy global command to display information about the QoS policy applied globally.
# Display information about the global QoS policy applied in the inbound direction.
<Sysname> display qos policy global inbound
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) : If-match any
Behavior: 1
Filter Enable: deny
Mirror enable:
Mirror type: cpu
Accounting Enable:
Table 2-6 display qos policy global command output description
Policy |
Policy name and its contents |
Classifier |
Class name and its contents. |
Operator |
Rule(s) |
Match criteria |
Behavior |
Name of the traffic behavior, and the actions in the traffic behavior |
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
View
Default Level
1: Monitor level
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction. Currently, the S3600 series EPON OLT switches do not support applying a QoS policy in the outbound direction of a port.
Use the display qos policy interface command to display QoS policy configuration and operational information on an interface or all interfaces.
# Display the QoS configuration and operational information on OLT 1/0/1.
<Sysname> display qos policy interface Olt1/0/1
Interface: Olt1/0/1
Direction: Inbound
Policy: 1
Classifier: 1 (Failed)
Operator: AND
Behavior: 1
Filter Enable: deny
Mirror enable:
Mirror type: cpu
Accounting Enable:
Red Action: discard
Yellow Action: pass
Table 2-7 display qos policy interface command output description
Direction |
The direction in which the policy is applied to the interface |
Policy |
Name of the policy applied to the interface |
Classifier |
Class name and corresponding configuration information |
Operator |
Logical relationship between match criteria in the class |
Rule(s) |
Match criteria in the class |
Behavior |
Behavior name and corresponding configuration information |
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ inbound ]
View
Default Level
1: Monitor level
name policy-name: Displays the information of the VLAN QoS policy specified by its name, a string of 1 to 31 characters.
vlan vlan-id: Displays the QoS policy applied to the specified VLAN.
inbound: Displays the QoS policy applied to the inbound direction of the specified VLAN.
Use the display qos vlan-policy command to display VLAN QoS policy information.
# Display information about the VLAN QoS policy test.
<Sysname> display qos vlan-policy name test
Policy test
Vlan 100: inbound
Table 2-8 display qos vlan-policy command output description
Policy |
Name of the QoS policy |
Vlan |
ID of the VLAN where the VLAN policy is applied |
Inbound |
The QoS policy is applied in the inbound direction of the VLAN. |
# Display the QoS policy applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
Direction: Inbound
Policy: 1
Operator: AND
Behavior: 1
Filter Enable: deny
Mirror enable:
Mirror type: cpu
Accounting Enable:
Red Action: discard
Yellow Action: pass
Classifier: 55 (Failed)
Operator: AND
Rule(s) : -none-
Behavior: 55
-none-
Table 2-9 display qos vlan-policy command output description
Vlan |
ID of the VLAN where the QoS policy is applied |
Direction |
The direction in which the QoS policy is applied for the VLAN. |
Classifier |
Class name and its contents |
Operator |
Rule(s) |
Match criteria |
Behavior |
Name of the behavior, and its actions |
undo qos apply policy { inbound | outbound }
View
Interface view, port group view, OLT port view, ONU port view
Default Level
2: System level
inbound: Inbound direction.
outbound: Outbound direction. Currently, the S3600 series EPON OLT switches do not support applying a QoS policy in the outbound direction of a port.
policy-name: Specifies a policy name, a string of 1 to 31 characters.
Use the qos apply policy command to apply a QoS policy.
Use the undo qos apply policy command to remove the QoS policy.
Note that: whether a QoS policy can be applied to an ONU port depends on the support of the ONU for actions in the QoS policy. For details, refer to the user manual of the ONU.
# Apply policy USER1 in the outbound direction of OLT 1/0/1.
[Sysname] interface Olt 1/0/1
[Sysname-Olt1/0/1] qos apply policy USER1 outbound
qos apply policy policy-name global inbound
undo qos apply policy global inbound
View
Default Level
2: System level
policy-name: Policy name, a string of 1 to 31 characters.
inbound: Applies the QoS policy to the incoming packets on all ports.
Use the qos apply policy global command to apply a QoS policy globally. A global QoS policy takes effect on all inbound traffic.
Use the undo qos apply policy global command to cancel the global application of the QoS policy.
# Apply the QoS policy user1 in the inbound direction globally.
[Sysname] qos apply policy user1 global inbound
qos policy policy-name
undo qos policy policy-name
View
Default Level
2: System level
Use the qos policy command to create a policy and enter policy view.
Use the undo qos policy command to remove a policy.
A policy applied to an interface cannot be deleted directly. You need to cancel application of the policy on the interface before deleting the policy with the undo qos policy command.
Related commands: classifier behavior, qos apply policy.
# Define a policy named user1.
qos vlan-policy policy-name vlan vlan-id-list inbound
undo qos vlan-policy vlan vlan-id-list inbound
View
Default Level
2: System level
vlan-id-list: A list of up to eight VLAN IDs in the range 1 to 4094. You can input individual discontinuous VLAN IDs and VLAN ID ranges in the form of start-vlan-id to end-vlan-id where the start VLAN ID must be smaller than the end VLAN ID. Each item in the VLAN list is separated by a space.
inbound: Applies the QoS policy to the incoming packets in the specified VLAN(s).
Use the qos vlan-policy command to apply a QoS policy to the specified VLAN(s).
Use the undo qos vlan-policy command to remove the QoS policy applied to the specified VLAN(s).
# Apply the QoS policy test to the inbound direction of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy global [ inbound ]
View
Default Level
1: Monitor level
Use the reset qos vlan-policy command to clear the statistics of a global QoS policy.
# Clear statistics of the global QoS policy applied in the inbound direction.
<Sysname> reset qos policy global inbound
reset qos vlan-policy [ vlan vlan-id ] [ inbound ]
View
Default Level
1: Monitor level
vlan-id: VLAN ID, in the range of 1 to 4094.
inbound: Clears the QoS policy statistics in the inbound direction of the specified VLAN.
Use the reset qos vlan-policy command to clear VLAN QoS policy statistics.
# Clear the QoS policy statistics of VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
display qos sp interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display qos sp interface command to view the strict priority (SP) queuing configuration of an interface.
If no interface is specified, the SP queuing configuration of all the interfaces is displayed.
Related commands: qos sp.
# Display the SP queuing configuration of GigabitEthernet 1/1/1.
<Sysname> display qos sp interface gigabitethernet 1/1/1
Interface: GigabitEthernet1/1/1
Output queue: Strict-priority queue
Table 3-1 display qos sp interface command output description
Output queue |
Pattern of the current output queue |
Strict-priority queue |
SP queuing is adopted for queue scheduling |
qos sp
undo qos sp
View
Default Level
2: System level
None
Use the qos sp command to configure SP queuing on an interface.
Use the undo qos sp command to restore the default.
The default queuing algorithm on an interface is SP.
Related commands: display qos sp interface.
# Enable SP queuing pattern 1 on OLT 1/0/1.
[Sysname-Olt1/0/1] qos sp
display qos wrr interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display qos wrr interface command to display the weighted round robin (WRR) queuing configuration on an interface.
If no interface is specified, the WRR queuing configuration of all the interfaces is displayed.
Related commands: qos wrr.
# Display the WRR queuing configuration of OLT 1/0/1.
<Sysname> display qos wrr interface Olt 1/0/1
Interface: Olt1/0/1
Output queue: Weighted round robin queue
Queue ID Group Weight
0 1 1
1 1 2
2 1 3
3 1 4
4 1 5
5 1 6
6 1 7
7 1 8
Table 3-2 display qos wrr interface command output description
Output queue |
Queue ID |
ID of a queue |
Group |
Number of the group a queue is assigned to. By default, all queues belong to group 1. |
Weight |
Queue weight based on which queues are scheduled. N/A indicates that the queue adopts the SP queue scheduling algorithm. |
qos wrr
undo qos wrr
View
Default Level
2: System level
None
Use the qos wrr command to enable WRR queuing.
Use the undo qos wrr command to disable WRR queuing.
Before performing WRR configuration, you need to enable WRR queuing on an interface using the qos wrr command.
# Enable WRR queuing on OLT 1/0/1.
[Sysname-Olt1/0/1] qos wrr
qos wrr queue-id group sp
undo qos wrr queue-id group sp
View
Default Level
2: System level
queue-id: Queue ID, in the range of 0 to 7.
sp: Strict priority (SP) queuing algorithm.
Use the qos wrr group sp command to assign the specified queue to the SP scheduling group on a port using the SP+WRR scheduling algorithm.
Use the undo qos wrr group sp command to remove the specified queue from the SP scheduling group.
Before configuring this command on an interface, make sure that WRR queue scheduling is enabled on the interface. An SP group is different from a common WRR priority group. Queues in an SP group are scheduled using SP queuing algorithm but not WRR queuing scheduling algorithm.
Settings in Ethernet interface view are effective on the current interface only; settings in port group view are effective on all the ports in the port group.
Related commands: display qos wrr interface.
# Enable SP+WRR queuing on OLT 1/0/1, and assign queue 0 to the SP group.
[Sysname-Olt1/0/1] qos wrr 0 group sp
qos wrr queue-id group 1 weight schedule-value
undo qos wrr queue-id group 1 weight
View
Default Level
2: System level
1: Specifies a group the queue belongs to, group 1.
weight schedule-value: Specifies the scheduling weight of a queue, rang from 1 to 15.
Use the qos wrr weight command to configure or modify WRR queuing parameters on an interface.
Use the undo qos wrr weight command to restore the default WRR queuing parameters on an interface.
# Enable WRR queuing on OLT 1/0/1, assign scheduling weight 100 to queue 0, and assign queue 0 to group 1.
[Sysname-Olt1/0/1] qos wrr 0 group 1 weight 10
display qos wfq interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display qos wfq interface command to display the weighted fair queuing (WFQ) configuration on an interface.
If no interface is specified, the WFQ configuration of all the interfaces is displayed.
Related commands: qos wfq.
# Display the HWFQ configuration of ONU 1/0/1:1.
<Sysname> display qos wfq interface onu 1/0/1:1
Interface: Onu 1/0/1:1
Output queue: Hardware weighted fair queue
Queue ID Weight Min-Bandwidth
0 100 NA
1 1 NA
2 1 NA
3 1 NA
4 1 NA
5 1 NA
6 1 NA
7 1 NA
Table 3-3 display qos wfq interface command output description
Output queue |
Queue ID |
ID of a queue |
Weight |
Queue scheduling weight |
Min-Bandwidth |
Minimum guaranteed bandwidth |
qos wfq
undo qos wfq
View
ONU port view
Default Level
2: System level
Use the qos wfq command to enable HWFQ on an interface.
Use the undo qos wfq command to restore default queuing algorithm on an interface.
# Enable WFQ on ONU 1/0/1:1
[Sysname-Onu1/0/1:1] qos wfq
qos wfq queue-id weight schedule-value
undo qos wfq queue-id weight
View
Default Level
2: System level
schedule-value: Scheduling weight of the queue.
Use the qos wfq weight command to configure a scheduling weight for an WFQ queue on the interface.
Use the undo qos wfq weight command to restore the default scheduling weight for an WFQ queue on the interface.
Related commands: display qos wfq interface.
# Configure the scheduling weight 100 for WFQ queue 0 on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] qos wfq 0 weight 100
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp ]
View
Default Level
1: Monitor level
dot1p-dp: 802.1p-to-drop priority mapping table.
dot1p-lp: 802.1p-to-local priority mapping table.
dscp-dot1p: DSCP-to-802.1p priority mapping table.
dscp-dp: DSCP-to-drop priority mapping table.
dscp-dscp: DSCP-to-DSCP priority mapping table.
Use the display qos map-table command to display the configuration of a priority mapping table.
If no priority mapping table is specified, the configuration information of all priority mapping tables is displayed.
Related commands: qos map-table.
# Display the configuration information of the 802.1p-to-drop priority mapping table.
<Sysname> display qos map-table dot1p-dp
MAP-TABLE NAME: dot1p-dp TYPE: pre-define
IMPORT : EXPORT
0 : 0
1 : 0
2 : 0
3 : 0
4 : 0
5 : 0
6 : 0
7 : 0
Table 4-1 display qos map-table command output description
MAP-TABLE NAME |
Name of the mapping table |
TYPE |
Type of the mapping table |
IMPORT |
Input values of the mapping table |
EXPORT |
Output values of the mapping table |
View
Priority mapping table view
Default Level
2: System level
import-value-list: List of input values.
export-value: Output value.
all: Deletes all the mappings in the priority mapping table.
Use the import command to configure a mapping from one or multiple input values to an output value.
Use the undo import command to restore the specified or all mappings to the default mappings.
Related commands: display qos map-table.
# Configure the 802.1p-to-drop priority mapping table to map 802.1p priority values 4 and 5 to drop precedence 1.
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
priority-queue-mapping { downstream | upstream} { value } &<1-8>
undo priority-queue-mapping { downstream | upstream}
View
OLT port view
Default Level
2: System level
downstream: Downlink packets.
upstream: Uplink packets.
value : Local precedence, in the range 0 to 7.
&<1-8>: Indicates that you can specify up to eight priority queue values.
Use the priority-queue-mapping command to configure the 802.1p-to-local priority mapping table of uplink and downlink packets on the OLT port.
The default 802.1p-to-local priority mapping table on an OLT port is as shown in Table 4-2.
Table 4-2 Default 802.1p-to-local priority mapping table of the packets on an OLT port
802.1p priority |
Local precedence |
0 |
0 |
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
# Configure the 802.1p-to-local priority mapping table of downlink packets on the OLT port.
[Sysname-Olt1/0/1] priority-queue-mapping downstream 1 1 2 3 4 5 6 7
Table 4-3 shows the 802.1p-to-local priority mapping table of downlink packets on the OLT port after the configuration is compete.
Table 4-3 802.1p-to-local priority mapping table
802.1p priority |
Local precedence |
0 |
1 |
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
qos cos-local-precedence-map cos0-map-local-prec cos1-map-local-prec cos2-map-local-prec cos3-map-local-prec cos4-map-local-prec cos5-map-local-prec cos6-map-local-prec cos7-map-local-prec
undo qos cos-local-precedence-map
View
ONU port view
Default Level
2: System level
cos0-map-local-prec: Local precedence to which 802.1p priority 0 is to be mapped, in the range of 0 to 3.
cos1-map-local-prec: Local precedence to which 802.1p priority 1 is to be mapped, in the range of 0 to 3.
cos2-map-local-prec: Local precedence to which 802.1p priority 2 is to be mapped, in the range of 0 to 3.
cos3-map-local-prec: Local precedence to which 802.1p priority 3 is to be mapped, in the range of 0 to 3.
cos4-map-local-prec: Local precedence to which 802.1p priority 4 is to be mapped, in the range of 0 to 3.
cos5-map-local-prec: Local precedence to which 802.1p priority 5 is to be mapped, in the range of 0 to 3.
cos6-map-local-prec: Local precedence to which 802.1p priority 6 is to be mapped, in the range of 0 to 3.
cos7-map-local-prec: Local precedence to which 802.1p priority 7 is to be mapped, in the range of 0 to 3.
Use the qos cos-local-precedence-map command to configure the 802.1p-to-local priority mapping table on an ONU port.
Use the undo qos cos-local-precedence-map command to restore the 802.1p-to-local priority mapping table on an ONU port to defaults.
Table 4-4 shows the default 802.1p-to-local priority mapping table of the packets on an ONU port.
This command takes effect on the downlink data stream only.
Table 4-4 Default 802.1p-to-local priority mapping table
802.1p priority |
Local precedence |
0 |
0 |
1 |
0 |
2 |
1 |
3 |
1 |
4 |
2 |
5 |
2 |
6 |
3 |
7 |
3 |
# Configure the 802.1p-to-local priority mapping table of the packets on the ONU port.
[Sysname] interface onu1/0/1:1
[Sysname-Onu1/0/1:1] qos cos-local-precedence-map 0 1 1 0 2 2 3 3
Table 4-5 shows the 802.1p-to-local priority mapping table after the configuration is compete.
Table 4-5 802.1p-to-local priority mapping table
802.1p priority |
Local precedence |
0 |
0 |
1 |
1 |
2 |
1 |
3 |
0 |
4 |
2 |
5 |
2 |
6 |
3 |
7 |
3 |
qos map-table { dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp }
View
Default Level
2: System level
Use the qos map-table command to enter the specified priority mapping table view.
# Enter the 802.1p-to-drop priority mapping table view.
uni uni-number classification-marking index index queue qid priority priority { selector operator matched-value } &<1-4>
undo uni uni-number classification-marking index index
View
ONU port view
Default Level
2: System level
index: UNI index number, in the range 1 to 8. The match rule configured on the UNI port with the smallest index number is used first.
qid: Queue ID, in the range 0 to 7.
priority: Mapping priority, in the range 0 to 7.
selector: Match field. Table 4-6 lists possible selector values.
operator: Match rule. Table 4-7 lists possible operator values.
matched-value: Match field value.
Selector |
always-match |
Perform a match on physical ports for traffic classification |
dst-ip |
Perform a match on the destination IP addresses of the packets |
dst-mac |
Perform a match on the destination MAC addresses of the packets |
dst-port |
Perform a match on the port numbers of the packets |
eth-pri |
Perform a match on the CoS precedence of the packets |
eth-type |
Perform a match on the Ethernet frame types of the packets |
ip-precedence |
Perform a match on the IP precedence of the packets |
ip-tos-dscp |
Perform a match on the ToS precedence or DSCP precedence of the packets |
ip-type |
Perform a match on the IP protocol types of the packets |
never-match |
Performs no traffic classification for the traffic received by the specified UNI port |
src-ip |
Perform a match on the source IP addresses of the packets |
src-mac |
Perform a match on the source MAC addresses of the packets |
src-port |
Perform a match on the source port numbers of the packets |
vlan-id |
Perform a match on the VLAN numbers of the packets |
Operator |
equal |
The value of matched-value is equal to that of the corresponding field of the packet. |
not-equal |
The value of matched-value is not equal to that of the corresponding field of the packet. |
greater-equal |
The value of matched-value is greater than or equal to that of the corresponding field of the packet. |
less-equal |
The value of matched-value is less than or equal to that of the corresponding field of the packet. |
exist |
The corresponding packet field exists. |
not-exist |
The corresponding packet field does not exist. |
Use the uni classification-marking command to map packets to different priority queues based on the configured keywords.
Use the undo uni classification-marking command to remove the configuration.
# Set the priority of packets whose destination MAC address is 000F-E2D7-925A to 3.
[Sysname-Onu1/0/1:1] uni 1 classification-marking index 1 queue 3 priority 3 dst-mac equal 000F-E2D7-925A
qos priority priority-value
undo qos priority
View
Default Level
2: System level
priority-value: Port priority value. The port priority is local precedence, which defaults to 0 and ranges from 0 to 7.
Use the qos priority command to configure a priority for the current port.
Use the undo qos priority command to restore the default value.
The default port priority is 0.
In interface view, the setting is effective on the current interface only; in port group view, the setting is effective on all the ports in the port group.
# Set the priority of OLT 1/0/1 to 2.
[Sysname-Olt1/0/1] qos priority 2
# Set the priority of ONU 1/0/1 to 2.
[Sysname] interface Onu 1/0/1:1
[Sysname-Onu1/0/1:1] qos priority 2
View
Default Level
1: Monitor level
Use the display qos trust interface command to display the trusted precedence type and priority of an interface.
If no interface is specified, the trusted precedence types on all interfaces are displayed.
# Display the trusted precedence type and priority of OLT 1/0/1.
<Sysname> display qos trust interface Olt 1/0/1
Interface: Olt1/0/1
Port priority information
Port priority: 2
Port priority trust type: dot1p
Table 4-8 display qos trust interface command output description
Port priority |
Port priority |
Port priority trust type |
Trusted precedence type, which can be dot1p or dscp |
qos trust dscp
undo qos trust
View
Default Level
2: System level
dscp: Trusts the DSCP precedence and uses this precedence for priority mapping.
Use the qos trust command to configure the trusted precedence type on an interface.
Use the undo qos trust command to restore the default.
The default trusted precedence type on an interface is 802.1p.
# Configure OLT 1/0/1 to trust the DSCP precedence.
[Sysname-Olt1/0/1] qos trust dscp
mirror-to cpu
undo mirror-to cpu
View
Default Level
2: System level
cpu: Mirrors traffic to the CPU.
Use the mirror-to cpu command to configure the action of mirroring traffic to the CPU for the traffic behavior.
Use the undo mirror-to cpu command to remove the action.
By default, the action of mirroring traffic to the CPU is not configured for a traffic behavior.
In a traffic behavior, the action of mirroring traffic to an interface and the action of mirroring traffic to the CPU are mutually exclusive. Therefore, you can configure only one of them for a traffic behavior.
# Configure the action of mirroring traffic to the CPU for the traffic behavior 1.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
View
Default Level
2: System level
Use the mirror-to interface command to configure the action of mirroring traffic to a specified interface for the traffic behavior.
Use the undo mirror-to interface command to remove the action.
By default, the action of mirroring traffic to a specified interface is not configured for a traffic behavior.
The action of mirroring traffic to an interface and the action of mirroring traffic to the CPU are mutually exclusive. Therefore, you can configure only one of them for a traffic behavior.
# Configure the action of mirroring traffic to OLT 1/0/1 for traffic behavior 1.
[Sysname-behavior-1] mirror-to interface Olt 1/0/1
