05-Link Aggregation Commands
Chapters Download (94.4 KB)
Table of Contents
1 Link Aggregation Configuration Commands
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
View
Layer-2 aggregate interface view
Default Level
2: System level
text: Description of an aggregate interface, a string of 1 to 80 characters. Currently, the device supports the following types of characters or symbols: Standard English characters (case-sensitive letters and numbers), special English characters, spaces, and other characters or symbols that conform to the Unicode standard.
l An interface description can be the mixture of English characters and other Unicode characters. The mixed description cannot exceed the specified length.
l To use a type of Unicode characters or symbols in a port description, you need to install the corresponding Input Method Editor (IME) and log in to the device through remote login software that supports this character type.
l Each Unicode character or symbol (non-English characters) takes the space of two regular characters. When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character into two. As a result, garbled characters may be displayed at the end of a line.
Use the description command to set the description of the current interface.
Use the undo description command to restore the default.
By default, the description of an interface is interface-name Interface, such as Bridge-Aggregation1 Interface.
# Set the description of interface Bridge-aggregation 1 to link-aggregation interface.
[Sysname-Bridge-Aggregation1] description link-aggregation interface
display lacp system-id
View
Default Level
1: Monitor level
None
Use the display lacp system-id command to display the system ID of the local system (that is, the actor). The ID comprises the system LACP priority and the system MAC address.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 00e0-fc00-0100
Table 1-1 display lacp system-id command output description
Actor System ID |
The local system ID, which comprises the LACP system priority and the system MAC address. |
View
Default Level
1: Monitor level
None
Use the display link-aggregation load-sharing mode command to display load sharing mode for link aggregation groups.
# Display the default global link aggregation load sharing mode.
<Sysname> display link-aggregation load-sharing mode
Link-Aggregation Load-Sharing Mode:
Layer 2 traffic: destination-mac address, source-mac address
Layer 3 traffic: destination-ip address, source-ip address
Table 1-2 display link-aggregation load-sharing mode command output description
Link-Aggregation Load-Sharing Mode |
Displays the global link aggregation load sharing mode. l By default, the link aggregation load sharing modes for Layer-2 traffic, Layer-3 traffic are displayed. l If you have configured a global load sharing mode, the configured mode is displayed. |
Layer 2 traffic: destination-mac address, source-mac address |
The default load sharing mode for Layer-2 traffic. In this sample output, it is based on source MAC address and destination MAC address. |
Layer 3 traffic: destination-ip address, source-ip address |
The default load sharing mode for Layer-3 traffic. In this sample output, it is based on source IP address and destination IP address. |
display link-aggregation member-port [ interface-type interface-number [ to interface-type interface-number ] ]
View
Default Level
1: Monitor level
interface-type interface-number: Port type and port number.
to: Specifies an interface range in the form of interface-type interface-number to interface-type interface-number, where the start interface number must be smaller than the end interface number. Note that both the start interface and the end interface are inclusive.
Use the display link-aggregation member-port command to display the detailed link aggregation information of the specified interface(s) or all interfaces if no interface is specified.
For an interface in a static aggregation group, only its port number and operational key are displayed, because it is not aware of the information of the partner.
# Display the detailed link aggregation information of GigabitEthernet 1/1/1, which is in a static aggregation group.
<Sysname> display link-aggregation member-port GigabitEthernet 1/1/1
G -- Defaulted, H – Expired
GigabitEthernet1/1/1:
Aggregation Interface: Bridge-Aggregation1
Port Number: 1
Oper-Key: 1
# Display the detailed link aggregation information of GigabitEthernet 1/1/3, which is in a dynamic aggregation group.
<Sysname> display link-aggregation member-port GigabitEthernet 1/1/3
GigabitEthernet1/1/3:
Aggregation Interface: Bridge-Aggregation10
Local:
Port Number: 3
Port Priority: 32768
Oper-Key: 3
Flag: {ACDEF}
Remote:
Port Number: 26
Oper-Key: 2
Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Table 1-3 display link-aggregation member-port command output description
Flags |
One-octet LACP state flags field. From the least to the most significant bit, they are represented by A through H as follows: l A indicates whether LACP is enabled. 1 for enabled and 0 for disabled. l B indicates the timeout control value. 1 for short timeout, and 0 for long timeout. l C indicates whether the link is considered as aggregatable by the sending system. 1 for true, and 0 for false. l D indicates whether the link is considered as synchronized by the sending system. 1 for true, and 0 for false. l E indicates whether the sending system considers that collection of incoming frames is enabled on the link. 1 for true and 0 for false. l F indicates whether the sending system considers that distribution of outgoing frames is enabled on the link. 1 for true and 0 for false. l G indicates whether the receive state machine of the sending system is using default operational partner information. 1 for true and 0 for false. l H indicates whether the receive state machine of the sending system is in the expired state. 1 for true and 0 for false. If a flag bit is set to 1, the corresponding English letter that otherwise is not output is displayed. |
Aggregation Interface |
Aggregate interface to which the port belongs |
Local: Port Number Port Priority Oper-key Flag |
Information about the local end: l Port Number: Number of the port. l Port Priority: LACP priority of the port. l Oper-key: Operational key l Flag: LACP protocol state flag. |
Remote: System ID Port Number Port Priority Oper-key Flag |
Information about the remote end: l System ID: System ID of the remote end. l Port Number: Number of the port. l Port Priority: LACP priority of the port. l Oper-key: Operational key l Flag: LACP protocol state flag. |
Received LACP Packets |
Number of LACP packets received |
Illegal |
Number of illegal packets |
Sent LACP Packets |
Number of LACP packets sent |
View
Default Level
1: Monitor level
None
Use the display link-aggregation summary command to display the summary information of all aggregation groups.
You may find out that information about the remote system for a static link aggregation group is either replaced by none or not displayed at all. This is normal because this type of aggregation group is not aware of its partner.
# Display the summary information of all aggregation groups.
<Sysname> display link-aggregation summary
Aggregation Interface Type:
BAGG -- Bridge-Aggregation, RAGG -- Route-Aggregation
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG AGG Partner ID Select Unselect Share
Interface Mode Ports Ports Type
BAGG1 S none 1 0 Shar
Table 1-4 display link-aggregation summary command output description
Aggregation Interface Type |
Aggregate interface type: l BAGG for a Layer-2 aggregate interface l RAGG for a Layer-3 aggregate interface |
Aggregation Mode |
Aggregation group type: l S for static link aggregation l D for dynamic aggregation |
Loadsharing Type |
Loadsharing type: l Shar for load sharing l NonS for non-load sharing Currently, the S3600 series EPON OLT switches only support load-sharing link aggregation groups. |
Actor System ID |
Local system ID |
AGG Interface |
Abbreviated name of the aggregate interface |
AGG Mode |
Aggregation group type |
Partner ID |
System ID of the partner |
Select Ports |
The number of selected ports |
Unselect Ports |
The number of unselected ports |
Share Type |
Load sharing type |
display link-aggregation verbose [ bridge-aggregation [ interface-number ] ]
View
Default Level
1: Monitor level
bridge-aggregation: Displays detailed information about the Layer-2 aggregate groups corresponding to Layer-2 aggregate interfaces.
interface-number: Aggregate interface number. The value range for the interface-number argument depends on your device model. Note that the aggregate interface you specify must already exist.
Use the display link-aggregation verbose command to display detailed information about the aggregation groups corresponding to the aggregate interfaces.
To display the information of a specific Layer-2 aggregate group, use the display link-aggregation verbose bridge-aggregation interface-number command.
To display the information of all Layer-2 aggregate groups, use the display link-aggregation verbose bridge-aggregation command.
To display the information of all aggregate groups, use the display link-aggregation verbose command.
# Display the detailed information of the aggregation group corresponding to Layer-2 aggregate interface Bridge-aggregation 10.
<Sysname> display link-aggregation verbose bridge-aggregation 10
Port Status: S -- Selected, U -- Unselected
G -- Defaulted, H -- Expired
Aggregation Mode: Dynamic
Local:
Port Status Priority Oper-Key Flag
GE1/1/1 S 32768 2 {ACDEF}
GE1/1/3 S 32768 2 {ACDEF}
Remote:
Actor Partner Priority Oper-Key SystemID Flag
GE1/1/1 32 32768 2 0x8000, 000f-e267-6c6a {ACDEF}
GE1/1/3 26 32768 2 0x8000, 000f-e267-6c6a {ACDEF}
Table 1-5 display link-aggregation verbose command output description
Loadsharing Type |
Port Status |
Port state: Selected or unselected. |
Flags |
Name of the aggregate interface |
Aggregation Mode |
Type of the aggregation group: Static for static aggregation, and Dynamic for dynamic aggregation. |
System ID |
Local system ID |
Local: Port Status Priority Oper-Key Flag |
Other information of the local end, including the member ports, port state, port LACP priority, operational key, and LACP protocol state flags. |
Remote: Actor Partner Priority Oper-Key SystemID Flag |
Detailed information about the remote end, including the corresponding local port, port ID, port LACP priority, operational key, system ID, and LACP protocol state flags |
enable snmp trap updown
undo enable snmp trap updown
View
Default Level
2: System level
None
Use the enable snmp trap updown command to enable linkUp/linkDown trap generation for the current aggregate interface.
Use the undo enable snmp trap updown command to disable linkUp/linkDown trap generation for the current aggregate interface.
By default, linkUp/linkDown trap generation is enabled for an aggregate interface.
Note that for an aggregate interface to generate linkUp/linkDown traps when its link state changes, you must also enable linkUp/linkDown trap generation globally with the snmp-agent trap enable [ standard [ linkdown | linkup ] * ] command.
Refer to SNMP Commands in the System Volume for information about the snmp-agent trap enable command.
# Enable linkUp/linkDown trap generation on interface Bridge-aggregation 1.
[Sysname-Bridge-Aggregation1] enable snmp trap updown
undo interface bridge-aggregation interface-number
View
Default Level
2: System level
interface-number: Layer-2 aggregate interface number. The value ranges from 1 to 1024.
Use the interface bridge-aggregation command to create a Layer-2 aggregate interface and enter the Layer-2 aggregate interface view.
Use the undo interface bridge-aggregation command to remove a Layer-2 aggregate interface.
Upon creation of a Layer-2 aggregate interface, a Layer-2 aggregation group numbered the same is created automatically. Removing the Layer-2 aggregate interface also removes the Layer-2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
An S3600 EPON OLT switch can support only one Layer 2 aggregate interface.
# Create Layer-2 aggregate interface Bridge-aggregation 1.
lacp port-priority port-priority
undo lacp port-priority
View
Ethernet port view
Default Level
2: System level
port-priority: LACP port priority, in the range of 0 to 65535.
Use the lacp port-priority command to set the LACP priority of a port.
Use the undo lacp port-priority command to restore the default.
The default LACP priority of a port is 32768.
# Set the LACP priority of GigabitEthernet 1/1/1 to 64.
[Sysname] interface gigabitethernet 1/1/1
[Sysname-GigabitEthernet1/1/1] lacp port-priority 64
lacp system-priority system-priority
undo lacp system-priority
View
Default Level
2: System level
system-priority: LACP priority of the local system, in the range of 0 to 65535.
Use the lacp system-priority command to set the LACP priority of the local system.
By default, the system LACP priority is 32768.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
link-aggregation load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port source-ip | source-mac | source-port } *
undo link-aggregation load-sharing mode
View
Default Level
2: System level
destination-ip: Specifies to perform load sharing in link aggregation groups based on destination IP address.
destination-mac: Specifies to perform load sharing in load-sharing link aggregation groups based on destination MAC address.
destination-port: Specifies to perform load sharing in load-sharing link aggregation groups based on destination port.
ingress-port: Specifies to perform load sharing in load-sharing link aggregation groups based on ingress port.
source-ip: Specifies to perform load sharing in load-sharing link aggregation groups based on source IP address.
source-mac: Specifies to perform load sharing in load-sharing link aggregation groups based on source MAC address.
source-port: Specifies to perform load sharing in load-sharing link aggregation groups based on source port.
Use the link-aggregation load-sharing mode command to configure the global link aggregation load sharing mode.
Use the undo link-aggregation load-sharing mode command to restore the default.
By default, the hash keys for Layer 2 packets are source/destination MAC addresses, and those for Layer-3 packets are source/destination IP addresses.
Note that:
l The load sharing mode you configured overwrites rather than adds to the old one, if any. Therefore, to change the load sharing mode from source port based to source and destination ports based for example, you must configure the link-aggregation load-sharing mode destination-ip source-ip to overwrite the link-aggregation load-sharing mode destination-ip command rather than configure the link-aggregation load-sharing mode source-port command.
l Currently, the S3600 series EPON OLT switches do not support load sharing calculation based on source ports, destination ports, or the combination of MAC and IP addresses. The ingress-port keyword can be used as the hash keys for load sharing calculation when combined with MAC addresses, but not when combined with source ports, destination ports, or IP addresses, or alone. If you configure load sharing for link aggregation groups in modes that are not supported by the S3600 series, the system generates prompts to remind you that the load sharing modes you are configuring are not supported.
# Configure the global link aggregation load sharing mode as destination MAC-based.
[Sysname] link-aggregation load-sharing mode destination-mac
link-aggregation mode dynamic
undo link-aggregation mode
View
Default Level
2: System level
None
Use the link-aggregation mode dynamic command to configure an aggregation group to work in dynamic aggregation mode.
Use the undo link-aggregation mode command to restore the default.
By default, an aggregation group works in static aggregation mode.
If there is any member port in an aggregation group, you cannot modify the aggregation mode of the aggregation group.
# Configure the aggregation group of Bridge-aggregation 1 to work in dynamic aggregation mode.
port link-aggregation group number
undo port link-aggregation group
View
Ethernet port view
Default Level
2: System level
number: Aggregate group number. The value ranges from 1 to 1024.
Use the port link-aggregation group command to assign the current Ethernet port to the specified aggregation group.
Use the port link-aggregation group command to remove the current Ethernet port from the specified aggregation group.
Note that: An Ethernet port can belong to only one aggregation group.
# Assign GigabitEthernet 1/1/1 to aggregation group 22.
[Sysname-GigabitEthernet1/1/1] port link-aggregation group 22
reset counters interface [ bridge-aggregation [ interface-number ] ]
View
Default Level
2: System level
bridge-aggregation: Clears statistics for Layer 2 aggregate interfaces.
interface-number: Aggregate interface number. If the interface-number argument is not specified, this command clears statistics of all aggregate interfaces of the specified type.
Use the reset counters interface command to clear the statistics of the specified aggregate interface or interfaces.
Before collecting statistics for a Layer 2 aggregate interface within a specific period, you need to clear the existing statistics of the interface.
# Clear the statistics of Layer 2 aggregate interface bridge-aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
Default Level
1: Monitor level
interface-type interface-number: Interface type and interface number.
Use the reset lacp statistics command to clear the LACP statistics for the specified interface(s) or all interfaces if no interface is specified.
Related commands: display link-aggregation member-port.
# Clear the LACP statistics for all Ethernet ports.
<Sysname> reset lacp statistics
shutdown
View
Default Level
2: System level
None
Use the shutdown command to shut down the current aggregate interface.
Use the undo shutdown command to bring up the current aggregate interface.
By default, aggregate interfaces are enabled.
# Shut down aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] shutdown
