33-Appendix
Chapters Download (336.57 KB)
The command index includes all the commands in the H3C S3600 Series EPON OLT Switches Command Manual-Release 3103, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
access-limit |
24-AAA Commands |
1-1 |
access-limit enable |
24-AAA Commands |
1-1 |
accounting |
23-QoS Commands |
2-7 |
accounting default |
24-AAA Commands |
1-2 |
accounting lan-access |
24-AAA Commands |
1-3 |
accounting login |
24-AAA Commands |
1-4 |
accounting optional |
24-AAA Commands |
1-5 |
accounting-on enable |
24-AAA Commands |
2-1 |
accounting-on enable interval |
24-AAA Commands |
2-2 |
accounting-on enable send |
24-AAA Commands |
2-2 |
acl |
02-Login Commands |
2-1 |
acl |
22-ACL Commands |
1-4 |
acl copy |
22-ACL Commands |
1-6 |
acl ipv6 |
22-ACL Commands |
1-18 |
acl ipv6 copy |
22-ACL Commands |
1-20 |
acl ipv6 name |
22-ACL Commands |
1-21 |
acl name |
22-ACL Commands |
1-7 |
active region-configuration |
15-MSTP Commands |
1-1 |
alarm bit-error-rate |
10-Extended OAM Commands |
2-1 |
alarm bit-error-rate enable |
2-2 |
alarm device-fatal-error |
2-2 |
alarm frame-error-rate |
2-3 |
alarm frame-error-rate enable |
2-4 |
alarm llid-mismatch enable |
2-4 |
alarm llid-mismatch threshold |
2-5 |
alarm local-stable |
2-6 |
alarm oam critical-event |
2-6 |
alarm oam dying-gasp |
2-7 |
alarm oam error-frame |
2-11 |
alarm oam error-frame enable |
2-12 |
alarm oam error-frame-period |
2-10 |
alarm oam error-frame-period enable |
2-11 |
alarm oam error-frame-seconds-summary |
2-13 |
alarm oam error-frame-seconds-summary enable |
2-14 |
alarm oam error-symbol-period |
2-8 |
alarm oam error-symbol-period enable |
2-9 |
alarm oam local-link-fault |
2-15 |
alarm oam-vendor-specific |
2-15 |
alarm onu-over-limitation |
2-16 |
alarm port bit-error-rate |
2-17 |
alarm registration-error |
2-17 |
alarm remote-stable |
2-18 |
alarm software-error |
2-19 |
arp check enable |
18-ARP Commands |
1-1 |
arp max-learning-num |
18-ARP Commands |
1-1 |
arp static |
18-ARP Commands |
1-2 |
arp timer aging |
18-ARP Commands |
1-3 |
ascii |
31-File System Management Commands |
2-6 |
authentication default |
24-AAA Commands |
1-6 |
authentication lan-access |
24-AAA Commands |
1-7 |
authentication login |
24-AAA Commands |
1-8 |
authentication-mode |
02-Login Commands |
1-1 |
authorization command |
24-AAA Commands |
1-8 |
authorization default |
24-AAA Commands |
1-9 |
authorization lan-access |
24-AAA Commands |
1-10 |
authorization login |
24-AAA Commands |
1-11 |
authorization-attribute |
24-AAA Commands |
1-12 |
auto-execute command |
02-Login Commands |
1-2 |
backup startup-configuration |
1-13 |
bandwidth downstream |
23-QoS Commands |
1-1 |
bandwidth downstream high-priority enable |
23-QoS Commands |
1-5 |
bandwidth downstream policy enable |
23-QoS Commands |
1-2 |
bandwidth downstream priority-queue |
23-QoS Commands |
1-6 |
binary |
2-7 |
bind onuid |
01-EPON-OLT Command |
2-1 |
bind-attribute |
24-AAA Commands |
1-14 |
boot-loader |
32-System Configuration and Debugging Command |
2-1 |
bootrom |
2-2 |
bootrom-update security-check enable |
2-2 |
bpdu-tunnel dot1q stp |
13-BPDU Tunneling Commands |
1-1 |
bpdu-tunnel tunnel-dmac |
1-2 |
broadcast-suppression |
03-Port Commands |
1-1 |
bye |
25-SSH2.0 Commands |
1-15 |
bye |
2-7 |
car |
23-QoS Commands |
2-8 |
cd |
1-15 |
cd |
1-1 |
cd |
2-8 |
cdup |
1-16 |
cdup |
2-8 |
check region-configuration |
15-MSTP Commands |
1-1 |
classifier behavior |
23-QoS Commands |
2-18 |
clock datetime |
1-1 |
clock summer-time one-off |
1-1 |
clock summer-time repeating |
1-2 |
clock timezone |
1-4 |
close |
2-9 |
command-privilege level |
1-5 |
control-vlan |
16-RRPP Commands |
1-1 |
copy |
1-1 |
copyright-info enable |
1-6 |
cut connection |
24-AAA Commands |
1-15 |
databits |
02-Login Commands |
1-3 |
data-flow-format (HWTACACS scheme view) |
24-AAA Commands |
3-1 |
data-flow-format (RADIUS scheme view) |
24-AAA Commands |
2-3 |
dba-algorithm enable |
1-1 |
dba-algorithm update |
1-2 |
dba-parameters |
1-2 |
dba-report queue-id |
2-2 |
dba-report queue-set-number |
2-2 |
debugging |
2-9 |
debugging |
3-6 |
delete |
1-16 |
delete |
1-2 |
delete |
2-11 |
delete static-routes all |
20-Static Routing Commands |
2-1 |
deregister onu |
2-3 |
description |
03-Port Commands |
1-2 |
description |
05-Link Aggregation Commands |
1-1 |
description |
11-VLAN Commands |
1-1 |
description (for IPv4) |
22-ACL Commands |
1-7 |
description (for IPv6) |
22-ACL Commands |
1-21 |
dhcp-snooping |
19-DHCP Snooping Commands |
1-1 |
dhcp-snooping information circuit-id format-type |
1-2 |
dhcp-snooping information circuit-id string |
1-2 |
dhcp-snooping information enable |
1-3 |
dhcp-snooping information format |
1-4 |
dhcp-snooping information remote-id format-type |
1-5 |
dhcp-snooping information remote-id string |
1-6 |
dhcp-snooping information strategy |
1-7 |
dhcp-snooping trust |
1-7 |
dir |
1-17 |
dir |
1-3 |
dir |
2-11 |
disconnect |
2-12 |
display acl |
22-ACL Commands |
1-8 |
display acl ipv6 |
22-ACL Commands |
1-22 |
display acl resource |
22-ACL Commands |
1-1 |
display arp |
18-ARP Commands |
1-3 |
display arp ip-address |
18-ARP Commands |
1-5 |
display arp timer aging |
18-ARP Commands |
1-5 |
display boot-loader |
2-3 |
display brief interface |
03-Port Commands |
1-3 |
display channel |
29-Information Center Commands |
1-1 |
display clipboard |
1-7 |
display clock |
1-8 |
display connection |
24-AAA Commands |
1-16 |
display cpu-usage |
2-3 |
display cpu-usage history |
2-6 |
display current-configuration |
1-8 |
display debugging |
3-7 |
display default-configuration |
1-10 |
display device |
2-8 |
display device manuinfo |
2-8 |
display dhcp-snooping |
1-8 |
display dhcp-snooping information |
1-9 |
display dhcp-snooping packet statistics |
1-10 |
display dhcp-snooping trust |
1-10 |
display diagnostic-information |
1-10 |
display dldp |
09-DLDP-Fiber Backup Commands |
1-1 |
display dldp statistics |
1-3 |
display dns domain |
30-DNS Commands |
1-1 |
display dns dynamic-host |
30-DNS Commands |
1-2 |
display dns server |
30-DNS Commands |
1-2 |
display domain |
24-AAA Commands |
1-17 |
display epon statistics interface |
1-8 |
display epon-capability interface |
1-3 |
display epon-multicast information |
21-Multicast Commands |
1-1 |
display epon-oam interface |
1-1 |
display epon-parameter |
1-5 |
display epon-version interface |
1-6 |
display epon-workmode interface |
1-7 |
display fan |
2-9 |
display fib |
17-IP Addressing-IP Performance Optimization Commands |
2-1 |
display fib ip-address |
2-3 |
display fiber-backup group |
2-1 |
display ftp client configuration |
2-13 |
display ftp-server |
2-1 |
display ftp-user |
2-2 |
display history-command |
1-11 |
display hotkey |
1-12 |
display hwtacacs |
24-AAA Commands |
3-1 |
display icmp statistics |
2-4 |
display igmp-snooping group |
2-1 |
display igmp-snooping statistics |
2-2 |
display info-center |
1-2 |
display interface |
03-Port Commands |
1-5 |
display interface vlan-interface |
11-VLAN Commands |
1-2 |
display ip host |
30-DNS Commands |
1-3 |
display ip interface |
1-1 |
display ip interface brief |
1-3 |
display ip routing-table |
1-1 |
display ip routing-table acl |
1-5 |
display ip routing-table ip-address |
1-6 |
display ip routing-table protocol |
1-8 |
display ip routing-table statistics |
1-9 |
display ip socket |
2-5 |
display ip statistics |
2-8 |
display lacp system-id |
1-2 |
display link-aggregation load-sharing mode |
1-2 |
display link-aggregation member-port |
1-3 |
display link-aggregation summary |
1-6 |
display link-aggregation verbose |
1-7 |
display local-user |
24-AAA Commands |
1-18 |
display logbuffer |
1-4 |
display logbuffer summary |
1-6 |
display mac-address |
04-MAC Address Table Commands |
1-1 |
display mac-address aging-time |
1-2 |
display memory |
2-10 |
display mib-style |
27-SNMP-RMON Commands |
2-1 |
display mirroring-group |
07-Port Mirroring Commands |
1-1 |
display multicast-vlan |
3-1 |
display ntp-service sessions |
28-NTP Commands |
1-1 |
display ntp-service status |
28-NTP Commands |
1-3 |
display ntp-service trace |
28-NTP Commands |
1-4 |
display onu-event interface |
2-4 |
1-8 |
display onuinfo |
1-9 |
display onuinfo mac-address |
1-11 |
display onuinfo silent |
1-12 |
display onu-protocol |
15-MSTP Commands |
1-11 |
1-11 |
display onu-protocol igmp-snooping |
1-2 |
display optics-parameters interface |
03-Port Commands |
1-8 |
display patch information |
4-1 |
display port |
11-VLAN Commands |
1-9 |
display port combo |
03-Port Commands |
1-11 |
display port-group manual |
03-Port Commands |
1-12 |
display port-isolate group |
06-Port Isolation Commands |
1-1 |
display power |
2-10 |
display protocol-vlan interface |
11-VLAN Commands |
1-21 |
display protocol-vlan vlan |
11-VLAN Commands |
1-22 |
display public-key local public |
26-Public Key Commands |
1-1 |
display public-key peer |
1-2 |
display qos lr interface |
23-QoS Commands |
1-4 |
display qos map-table |
23-QoS Commands |
4-1 |
display qos policy |
23-QoS Commands |
2-19 |
display qos policy global |
23-QoS Commands |
2-20 |
display qos policy interface |
23-QoS Commands |
2-21 |
display qos sp |
23-QoS Commands |
3-1 |
display qos trust interface |
23-QoS Commands |
4-9 |
display qos vlan-policy |
23-QoS Commands |
2-22 |
display qos wfq interface |
23-QoS Commands |
3-6 |
display qos wrr interface |
23-QoS Commands |
3-2 |
display radius scheme |
24-AAA Commands |
2-4 |
display radius statistics |
24-AAA Commands |
2-6 |
display reboot-type |
2-11 |
display rmon alarm |
3-1 |
display rmon event |
3-2 |
display rmon eventlog |
3-3 |
display rmon history |
3-4 |
display rmon prialarm |
3-7 |
display rmon statistics |
3-8 |
display rrpp brief |
16-RRPP Commands |
1-2 |
display rrpp statistics |
16-RRPP Commands |
1-3 |
display rrpp verbose |
16-RRPP Commands |
1-5 |
display saved-configuration |
1-14 |
display schedule job |
2-11 |
display schedule reboot |
2-12 |
display sftp client source |
1-18 |
display smart-link flush |
08-Smart Link Commands |
1-1 |
display smart-link group |
1-2 |
display snmp-agent community |
1-1 |
display snmp-agent group |
1-2 |
display snmp-agent local-engineid |
1-3 |
display snmp-agent mib-view |
1-4 |
display snmp-agent statistics |
1-5 |
display snmp-agent sys-info |
1-7 |
display snmp-agent trap queue |
1-8 |
display snmp-agent trap-list |
1-8 |
display snmp-agent usm-user |
1-9 |
display ssh client source |
1-8 |
display ssh server |
1-1 |
display ssh server-info |
1-9 |
display ssh user-information |
1-2 |
display startup |
1-16 |
display stop-accounting-buffer |
24-AAA Commands |
2-9 |
24-AAA Commands |
3-3 |
display stp |
15-MSTP Commands |
1-3 |
display stp abnormal-port |
15-MSTP Commands |
1-6 |
display stp down-port |
15-MSTP Commands |
1-7 |
display stp history |
15-MSTP Commands |
1-8 |
display stp region-configuration |
15-MSTP Commands |
1-9 |
display stp root |
15-MSTP Commands |
1-10 |
display stp tc |
15-MSTP Commands |
1-11 |
display system-failure |
2-13 |
display tcp statistics |
2-9 |
display tcp status |
2-12 |
display tftp client configuration |
3-1 |
display this |
1-13 |
display time-range |
22-ACL Commands |
1-2 |
display traffic behavior |
23-QoS Commands |
2-9 |
display traffic classifier |
23-QoS Commands |
2-1 |
display trapbuffer |
1-7 |
display udp statistics |
2-13 |
display uni-information |
03-Port Commands |
1-13 |
display user-group |
24-AAA Commands |
1-20 |
display user-interface |
02-Login Commands |
1-4 |
display vendor-specific information |
2-5 |
display version |
1-15 |
display vlan |
11-VLAN Commands |
1-3 |
dldp authentication-mode |
1-4 |
dldp delaydown-timer |
1-5 |
dldp enable |
1-5 |
dldp interval |
1-6 |
dldp reset |
1-7 |
dldp unidirectional-shutdown |
1-8 |
dldp work-mode |
1-8 |
dns domain |
30-DNS Commands |
1-4 |
dns resolve |
30-DNS Commands |
1-5 |
dns server |
30-DNS Commands |
1-5 |
domain |
24-AAA Commands |
1-20 |
domain default enable |
24-AAA Commands |
1-21 |
duplex |
03-Port Commands |
1-16 |
eap offload |
24-AAA Commands |
2-9 |
eap-profile |
24-AAA Commands |
1-22 |
enable log updown |
1-9 |
enable snmp trap updown |
1-9 |
1-10 |
encrypt enable |
2-7 |
encrypt key |
2-8 |
encryption timer |
1-12 |
epon-parameter ouilist |
1-13 |
1-2 |
execute |
1-4 |
exit |
1-18 |
expiration-date |
24-AAA Commands |
1-22 |
fast-leave (IGMP-Snooping view) |
2-3 |
2-2 |
file prompt |
1-4 |
filter |
23-QoS Commands |
2-11 |
fixdisk |
1-5 |
flow-control |
03-Port Commands |
1-17 |
flow-interval |
03-Port Commands |
1-18 |
flush enable |
1-3 |
format |
1-6 |
forward-error-correction enable |
2-9 |
free ftp user |
2-3 |
free user-interface |
02-Login Commands |
1-5 |
ftp |
2-14 |
ftp client source |
2-15 |
ftp server acl |
2-3 |
ftp server enable |
2-4 |
ftp timeout |
2-4 |
ftp update |
2-5 |
get |
1-19 |
get |
2-16 |
grant-filtering enable |
1-14 |
gratuitous-arp-learning enable |
18-ARP Commands |
1-7 |
gratuitous-arp-sending enable |
18-ARP Commands |
1-7 |
group |
24-AAA Commands |
1-23 |
group member |
2-3 |
group-member |
03-Port Commands |
1-18 |
group-policy (IGMP-Snooping view) |
2-4 |
header |
1-15 |
help |
1-20 |
history-command max-size |
02-Login Commands |
1-6 |
host-aging-time (IGMP-Snooping view) |
2-5 |
hotkey |
1-17 |
hwtacacs nas-ip |
24-AAA Commands |
3-4 |
hwtacacs scheme |
24-AAA Commands |
3-5 |
idle-cut enable |
24-AAA Commands |
1-24 |
idle-timeout |
02-Login Commands |
1-6 |
if-match |
23-QoS Commands |
2-2 |
igmp-snooping |
2-6 |
igmp-snooping drop-unknown |
2-6 |
igmp-snooping enable |
2-7 |
igmp-snooping fast-leave |
2-8 |
igmp-snooping general-query source-ip |
2-8 |
igmp-snooping group-limit |
2-9 |
igmp-snooping group-policy |
2-10 |
igmp-snooping host-aging-time |
2-11 |
igmp-snooping host-join |
2-12 |
igmp-snooping last-member-query-interval |
2-13 |
igmp-snooping max-response-time |
2-14 |
igmp-snooping overflow-replace |
2-15 |
igmp-snooping querier |
2-15 |
igmp-snooping query-interval |
2-16 |
igmp-snooping router-aging-time |
2-17 |
igmp-snooping source-deny |
2-18 |
igmp-snooping special-query source-ip |
2-18 |
igmp-snooping version |
2-19 |
import |
23-QoS Commands |
4-2 |
info-center channel name |
1-10 |
info-center console channel |
1-11 |
info-center enable |
1-11 |
info-center logbuffer |
1-12 |
info-center loghost |
1-13 |
info-center loghost source |
1-14 |
info-center monitor channel |
1-15 |
info-center snmp channel |
1-15 |
info-center source |
1-16 |
info-center synchronous |
1-19 |
info-center timestamp |
1-20 |
info-center timestamp loghost |
1-21 |
info-center trapbuffer |
1-22 |
instance |
15-MSTP Commands |
1-13 |
interface |
03-Port Commands |
1-19 |
interface bridge-aggregation |
1-10 |
11-VLAN Commands |
1-5 |
ip address |
2-9 |
ip address |
11-VLAN Commands |
1-5 |
ip address |
1-4 |
ip host |
30-DNS Commands |
1-6 |
ip redirects enable |
2-14 |
ip route-static |
2-1 |
ip route-static default-preference |
2-3 |
ip ttl-expires enable |
2-14 |
ip unreachables enable |
2-15 |
jumboframe enable |
03-Port Commands |
1-19 |
key (HWTACACS scheme view) |
24-AAA Commands |
3-6 |
key (RADIUS scheme view) |
24-AAA Commands |
2-10 |
lacp port-priority |
1-11 |
lacp system-priority |
1-12 |
last-member-query-interval (IGMP-Snooping view) |
2-20 |
lcd |
2-16 |
1-12 |
link-aggregation mode |
1-13 |
link-delay |
03-Port Commands |
1-21 |
linktest |
03-Port Commands |
1-21 |
local-server authentication eap-profile |
24-AAA Commands |
1-24 |
local-user |
24-AAA Commands |
1-25 |
local-user password-display-mode |
24-AAA Commands |
1-26 |
lock |
02-Login Commands |
1-7 |
loopback |
03-Port Commands |
1-22 |
loopback enable |
03-Port Commands |
1-23 |
ls |
1-20 |
ls |
2-17 |
mac-address (Interface view) |
1-3 |
mac-address (system view) |
1-4 |
mac-address mac-learning disable |
1-5 |
mac-address max-mac-count (Interface view) |
1-6 |
mac-address timer |
1-7 |
management-vlan |
2-10 |
max-response-time (IGMP-Snooping view) |
2-21 |
max-rtt |
1-15 |
mdi |
03-Port Commands |
1-24 |
method |
24-AAA Commands |
1-27 |
mib-style |
2-1 |
mirroring-group |
1-2 |
mirroring-group mirroring-port |
1-3 |
mirroring-group monitor-egress |
1-4 |
mirroring-group monitor-port |
1-5 |
mirroring-group remote-probe vlan |
1-6 |
mirroring-port |
1-6 |
mirror-to cpu |
23-QoS Commands |
5-1 |
mirror-to interface |
23-QoS Commands |
5-1 |
mkdir |
1-21 |
mkdir |
1-6 |
mkdir |
2-18 |
monitor enable |
2-19 |
monitor-port |
1-7 |
more |
1-7 |
move |
1-8 |
multicast vlan dest-ip |
1-5 |
multicast-control host-aging-time |
1-3 |
multicast-mode |
1-4 |
multicast-suppression |
03-Port Commands |
1-25 |
multicast-vlan |
3-2 |
name |
11-VLAN Commands |
1-6 |
nas-ip (HWTACACS scheme view) |
24-AAA Commands |
3-6 |
nas-ip (RADIUS scheme view) |
24-AAA Commands |
2-11 |
ntp-service access |
28-NTP Commands |
1-5 |
ntp-service authentication enable |
28-NTP Commands |
1-6 |
ntp-service authentication-keyid |
28-NTP Commands |
1-7 |
ntp-service broadcast-client |
28-NTP Commands |
1-8 |
ntp-service broadcast-server |
28-NTP Commands |
1-9 |
ntp-service in-interface disable |
28-NTP Commands |
1-9 |
ntp-service max-dynamic-sessions |
28-NTP Commands |
1-10 |
ntp-service multicast-client |
28-NTP Commands |
1-11 |
ntp-service multicast-server |
28-NTP Commands |
1-11 |
ntp-service reliable authentication-keyid |
28-NTP Commands |
1-12 |
ntp-service source-interface |
28-NTP Commands |
1-13 |
ntp-service unicast-peer |
28-NTP Commands |
1-13 |
ntp-service unicast-server |
28-NTP Commands |
1-14 |
oam-discovery-timeout |
1-3 |
onu port-isolate |
1-3 |
onu-event |
1-24 |
onu-protocol enable |
15-MSTP Commands |
1-13 |
1-12 |
1-5 |
onu-protocol pppoe enable |
2-11 |
open |
2-19 |
overflow-replace (IGMP-Snooping view) |
2-21 |
parity |
02-Login Commands |
1-8 |
passive |
2-20 |
password |
24-AAA Commands |
1-27 |
patch active |
4-2 |
patch deactive |
4-2 |
patch delete |
4-3 |
patch install |
4-3 |
patch load |
4-4 |
patch location |
4-5 |
patch run |
4-5 |
peer-public-key end |
1-3 |
ping |
3-1 |
port |
1-3 |
port |
11-VLAN Commands |
1-10 |
port (multicast VLAN view) |
3-2 |
port access vlan |
11-VLAN Commands |
1-11 |
port fiber-backup group |
2-3 |
port hybrid protocol-vlan |
11-VLAN Commands |
1-23 |
port hybrid pvid vlan |
11-VLAN Commands |
1-12 |
port hybrid vlan |
11-VLAN Commands |
1-13 |
port link-aggregation group |
1-14 |
port link-type |
11-VLAN Commands |
1-14 |
port multicast-vlan |
3-3 |
port smart-link group |
1-4 |
port switch-over |
2-4 |
port trunk permit vlan |
11-VLAN Commands |
1-15 |
port trunk pvid vlan |
11-VLAN Commands |
1-17 |
port-group manual |
03-Port Commands |
1-27 |
port-isolate enable |
1-2 |
preemption delay |
1-5 |
preemption mode |
1-6 |
primary accounting (HWTACACS scheme view) |
24-AAA Commands |
3-7 |
primary accounting (RADIUS scheme view) |
24-AAA Commands |
2-12 |
primary authentication (HWTACACS scheme view) |
24-AAA Commands |
3-8 |
primary authentication (RADIUS scheme view) |
24-AAA Commands |
2-13 |
primary authorization |
24-AAA Commands |
3-9 |
priority-queue-mapping |
23-QoS Commands |
4-2 |
protected-vlan |
1-7 |
protected-vlan |
16-RRPP Commands |
1-7 |
protocol inbound |
02-Login Commands |
1-9 |
protocol-vlan |
11-VLAN Commands |
1-25 |
public-key local create |
1-6 |
public-key local destroy |
1-7 |
public-key local export dsa |
1-7 |
public-key local export rsa |
1-9 |
public-key peer |
1-10 |
public-key peer import sshkey |
1-10 |
public-key-code begin |
1-4 |
public-key-code end |
1-5 |
put |
1-21 |
put |
2-20 |
pwd |
1-22 |
pwd |
1-8 |
pwd |
2-21 |
qinq enable |
12-QinQ Commands |
1-2 |
qinq ethernet-type |
12-QinQ Commands |
1-3 |
qinq vid |
12-QinQ Commands |
1-4 |
qos apply policy (interface view, port group view) |
23-QoS Commands |
2-24 |
qos apply policy global |
23-QoS Commands |
2-24 |
qos cos-local-precedence-map |
23-QoS Commands |
4-4 |
qos lr |
23-QoS Commands |
1-5 |
qos map-table |
23-QoS Commands |
4-6 |
qos policy |
23-QoS Commands |
2-25 |
qos priority |
23-QoS Commands |
4-8 |
qos sp |
23-QoS Commands |
3-2 |
qos trust |
23-QoS Commands |
4-10 |
qos vlan-policy |
23-QoS Commands |
2-26 |
qos wfq |
23-QoS Commands |
3-7 |
qos wfq weight |
23-QoS Commands |
3-7 |
qos wrr |
23-QoS Commands |
3-3 |
qos wrr group sp |
23-QoS Commands |
3-4 |
qos wrr weight |
23-QoS Commands |
3-5 |
quit |
1-23 |
quit |
2-21 |
quit |
1-18 |
radius client |
24-AAA Commands |
2-13 |
radius nas-ip |
24-AAA Commands |
2-14 |
radius scheme |
24-AAA Commands |
2-15 |
radius trap |
24-AAA Commands |
2-16 |
raw-vlan-id inbound |
12-QinQ Commands |
1-1 |
reboot |
2-13 |
reboot onu |
2-14 |
redirect |
23-QoS Commands |
2-11 |
region-name |
15-MSTP Commands |
1-14 |
remark customer-vlan-id |
23-QoS Commands |
2-12 |
remark dot1p |
23-QoS Commands |
2-13 |
remark drop-precedence |
23-QoS Commands |
2-14 |
remark dscp |
23-QoS Commands |
2-14 |
remark ip-precedence |
23-QoS Commands |
2-15 |
remark local-precedence |
23-QoS Commands |
2-16 |
remark service-vlan-id |
23-QoS Commands |
2-17 |
remotehelp |
2-22 |
remove |
1-23 |
rename |
1-24 |
rename |
1-9 |
report-aggregation (IGMP-Snooping view) |
2-22 |
reset acl counter |
22-ACL Commands |
1-9 |
reset acl ipv6 counter |
22-ACL Commands |
1-23 |
reset arp |
18-ARP Commands |
1-6 |
reset counters interface |
03-Port Commands |
1-27 |
1-15 |
reset counters uni |
03-Port Commands |
1-28 |
reset dhcp-snooping |
1-13 |
reset dhcp-snooping packet statistics |
1-13 |
reset dldp statistics |
1-9 |
reset dns dynamic-host |
30-DNS Commands |
1-7 |
reset hwtacacs statistics |
24-AAA Commands |
3-10 |
reset igmp-snooping group |
2-23 |
reset igmp-snooping statistics |
2-23 |
reset ip routing-table statistics protocol |
1-10 |
reset ip statistics |
2-15 |
reset lacp statistics |
1-15 |
reset logbuffer |
1-23 |
reset qos policy global |
23-QoS Commands |
2-26 |
reset qos vlan-policy |
23-QoS Commands |
2-27 |
reset radius statistics |
24-AAA Commands |
2-17 |
reset recycle-bin |
1-10 |
reset rrpp statistics |
16-RRPP Commands |
1-8 |
reset saved-configuration |
1-17 |
reset smart-link statistics |
1-8 |
reset stop-accounting-buffer |
24-AAA Commands |
2-17 |
24-AAA Commands |
3-10 |
reset stp |
15-MSTP Commands |
1-15 |
reset tcp statistics |
2-16 |
reset trapbuffer |
1-23 |
reset udp statistics |
2-16 |
reset unused porttag |
2-15 |
restore startup-configuration |
1-17 |
retry |
24-AAA Commands |
2-18 |
retry realtime-accounting |
24-AAA Commands |
2-19 |
retry stop-accounting (HWTACACS scheme view) |
24-AAA Commands |
3-11 |
retry stop-accounting (RADIUS scheme view) |
24-AAA Commands |
2-20 |
return |
1-19 |
revision-level |
15-MSTP Commands |
1-15 |
ring |
16-RRPP Commands |
1-8 |
ring enable |
16-RRPP Commands |
1-10 |
rmdir |
1-24 |
rmdir |
1-11 |
rmdir |
2-24 |
rmon alarm |
3-10 |
rmon event |
3-12 |
rmon history |
3-14 |
rmon prialarm |
3-15 |
rmon statistics |
3-17 |
router-aging-time (IGMP-Snooping view) |
2-24 |
rrpp domain |
16-RRPP Commands |
1-11 |
rrpp enable |
16-RRPP Commands |
1-12 |
rule (advanced IPv4 ACL view) |
22-ACL Commands |
1-11 |
rule (advanced IPv6 ACL view) |
22-ACL Commands |
1-25 |
rule (basic IPv4 ACL view) |
22-ACL Commands |
1-10 |
rule (basic IPv6 ACL view) |
22-ACL Commands |
1-24 |
rule (Ethernet frame header ACL view) |
22-ACL Commands |
1-15 |
rule comment (for IPv4) |
22-ACL Commands |
1-17 |
rule comment (for IPv6) |
22-ACL Commands |
1-29 |
sample enable |
2-20 |
save |
1-18 |
schedule job |
2-15 |
schedule reboot at |
2-17 |
schedule reboot delay |
2-18 |
screen-length |
02-Login Commands |
1-10 |
screen-length disable |
1-20 |
secondary accounting (HWTACACS scheme view) |
24-AAA Commands |
3-11 |
secondary accounting (RADIUS scheme view) |
24-AAA Commands |
2-21 |
secondary authentication (HWTACACS scheme view) |
24-AAA Commands |
3-12 |
secondary authentication (RADIUS scheme view) |
24-AAA Commands |
2-22 |
secondary authorization |
24-AAA Commands |
3-13 |
self-service-url enable |
24-AAA Commands |
1-28 |
send |
02-Login Commands |
1-10 |
server-type |
24-AAA Commands |
2-22 |
service-type |
24-AAA Commands |
1-29 |
set authentication password |
02-Login Commands |
1-11 |
sftp |
1-25 |
1-26 |
sftp server enable |
1-13 |
sftp server idle-timeout |
1-14 |
shell |
02-Login Commands |
1-12 |
shutdown |
03-Port Commands |
1-29 |
shutdown |
1-16 |
shutdown |
11-VLAN Commands |
1-7 |
shutdown management-vlan-interface |
2-11 |
shutdown-interval |
2-20 |
smart-link flush enable |
1-8 |
smart-link group |
1-9 |
snmp-agent |
1-11 |
snmp-agent calculate-password |
1-12 |
1-13 |
snmp-agent group |
1-15 |
1-16 |
snmp-agent log |
1-17 |
1-18 |
snmp-agent packet max-size |
1-19 |
1-19 |
snmp-agent target-host |
1-21 |
snmp-agent trap enable |
1-22 |
snmp-agent trap if-mib link extended |
1-23 |
snmp-agent trap life |
1-24 |
snmp-agent trap queue-size |
1-24 |
snmp-agent trap source |
1-25 |
snmp-agent usm-user { v1 | v2c } |
1-26 |
snmp-agent usm-user v3 |
1-27 |
source-deny (IGMP-Snooping view) |
2-24 |
speed |
02-Login Commands |
1-13 |
speed |
03-Port Commands |
1-29 |
speed auto |
03-Port Commands |
1-30 |
ssh client authentication server |
1-10 |
ssh client first-time enable |
1-11 |
ssh client source |
1-11 |
ssh server authentication-retries |
1-3 |
ssh server authentication-timeout |
1-4 |
ssh server compatible-ssh1x enable |
1-5 |
ssh server enable |
1-6 |
ssh server rekey-interval |
1-6 |
ssh user |
1-7 |
ssh2 |
1-12 |
ssl-server-policy |
24-AAA Commands |
1-30 |
startup saved-configuration |
1-19 |
state |
24-AAA Commands |
1-31 |
state |
24-AAA Commands |
2-23 |
step (for IPv4) |
22-ACL Commands |
1-18 |
step (for IPv6) |
22-ACL Commands |
1-30 |
stop-accounting-buffer enable (HWTACACS scheme view) |
24-AAA Commands |
3-14 |
stop-accounting-buffer enable (RADIUS scheme view) |
24-AAA Commands |
2-24 |
stopbits |
02-Login Commands |
1-14 |
stp |
15-MSTP Commands |
1-16 |
stp bpdu-protection |
15-MSTP Commands |
1-17 |
stp bridge-diameter |
15-MSTP Commands |
1-18 |
stp compliance |
15-MSTP Commands |
1-18 |
stp config-digest-snooping |
15-MSTP Commands |
1-19 |
stp cost |
15-MSTP Commands |
1-20 |
stp edged-port |
15-MSTP Commands |
1-22 |
stp loop-protection |
15-MSTP Commands |
1-23 |
stp max-hops |
15-MSTP Commands |
1-23 |
stp mcheck |
15-MSTP Commands |
1-24 |
stp mode |
15-MSTP Commands |
1-25 |
stp no-agreement-check |
15-MSTP Commands |
1-26 |
stp pathcost-standard |
15-MSTP Commands |
1-26 |
stp point-to-point |
15-MSTP Commands |
1-28 |
stp port priority |
15-MSTP Commands |
1-29 |
stp port-log |
15-MSTP Commands |
1-30 |
stp priority |
15-MSTP Commands |
1-30 |
15-MSTP Commands |
1-31 |
stp root primary |
15-MSTP Commands |
1-32 |
stp root secondary |
15-MSTP Commands |
1-33 |
stp root-protection |
15-MSTP Commands |
1-33 |
stp tc-protection |
15-MSTP Commands |
1-34 |
stp tc-protection threshold |
15-MSTP Commands |
1-35 |
stp timer forward-delay |
15-MSTP Commands |
1-35 |
stp timer hello |
15-MSTP Commands |
1-36 |
stp timer max-age |
15-MSTP Commands |
1-37 |
stp timer-factor |
15-MSTP Commands |
1-38 |
stp transmit-limit |
15-MSTP Commands |
1-39 |
subvlan (multicast VLAN view) |
3-4 |
super |
1-20 |
super password |
1-21 |
sysname |
1-22 |
system-failure |
2-20 |
system-view |
1-23 |
tcp timer fin-timeout |
2-17 |
tcp timer syn-timeout |
2-17 |
tcp window |
2-18 |
telnet |
02-Login Commands |
1-15 |
terminal debugging |
1-25 |
terminal logging |
1-26 |
terminal monitor |
1-26 |
terminal trapping |
1-27 |
tftp |
3-2 |
tftp client source |
3-3 |
tftp-server acl |
3-1 |
timer |
16-RRPP Commands |
1-12 |
timer monitor |
2-21 |
timer quiet (HWTACACS scheme view) |
24-AAA Commands |
3-15 |
timer quiet (RADIUS scheme view) |
24-AAA Commands |
2-25 |
timer realtime-accounting (HWTACACS scheme view) |
24-AAA Commands |
3-15 |
timer realtime-accounting (RADIUS scheme view) |
24-AAA Commands |
2-26 |
timer response-timeout (HWTACACS scheme view) |
24-AAA Commands |
3-16 |
timer response-timeout (RADIUS scheme view) |
24-AAA Commands |
2-27 |
timer sample |
2-21 |
time-range |
22-ACL Commands |
1-3 |
tracert |
3-4 |
traffic behavior |
23-QoS Commands |
2-17 |
23-QoS Commands |
2-6 |
undelete |
1-12 |
uni auto-negotiation |
03-Port Commands |
1-33 |
uni classification-marking |
23-QoS Commands |
4-6 |
uni description |
03-Port Commands |
1-34 |
uni duplex |
03-Port Commands |
1-34 |
uni flow-control |
03-Port Commands |
1-35 |
uni igmp-snooping fast-leave |
1-6 |
uni mdi |
03-Port Commands |
1-36 |
uni mirroring-port |
1-8 |
uni monitor-port |
1-9 |
uni multicast vlan |
1-7 |
uni multicast-control |
1-8 |
uni multicast-group-number |
1-9 |
uni multicast-strip-tag |
1-10 |
uni port-isolate |
1-4 |
uni port-policy |
23-QoS Commands |
1-3 |
uni restart auto-negotiation |
03-Port Commands |
1-37 |
uni shutdown |
03-Port Commands |
1-37 |
uni speed |
03-Port Commands |
1-38 |
uni virtual-cable-test |
03-Port Commands |
1-39 |
uni vlan-mode tag pvid |
11-VLAN Commands |
1-18 |
uni vlan-mode translation pvid |
11-VLAN Commands |
1-19 |
uni vlan-mode transparent |
11-VLAN Commands |
1-20 |
unicast-suppression |
03-Port Commands |
1-31 |
update onu |
2-21 |
update onu onu-type |
2-22 |
upstream-sla |
2-12 |
user |
2-25 |
user privilege level |
02-Login Commands |
1-16 |
user-group |
24-AAA Commands |
1-32 |
user-interface |
02-Login Commands |
1-15 |
user-name-format (HWTACACS scheme view) |
24-AAA Commands |
3-17 |
user-name-format (RADIUS scheme view) |
24-AAA Commands |
2-27 |
using onu |
03-Port Commands |
1-40 |
verbose |
2-25 |
vlan |
11-VLAN Commands |
1-8 |
vlan-mapping modulo |
15-MSTP Commands |
1-40 |
