11-L2VPN access to L3VPN or IP backbone commands | 96.75 KB |
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth is 100000 kbps.
L2VE interface view
L2VE subinterface view
L3VE interface view
L3VE subinterface view
The expected bandwidth for an interface affects the CBQ bandwidth and the link costs in OSPF, OSPFv3, and IS-IS. For more information, see ACL and QoS Configuration Guide and Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth for VE-L2VPN 100 to 10000 kbps.
[Sysname] interface ve-l2vpn 100
[Sysname-VE-L2VPN100] bandwidth 10000
# Set the expected bandwidth for VE-L3VPN 100 to 10000 kbps.
[Sysname] interface ve-l3vpn 100
[Sysname-VE-L3VPN100] bandwidth 10000
default
Use default to restore the default settings for an interface.
default
L2VE interface view
L3VE interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for interface VE-L2VPN 100.
[Sysname-VE-L2VPN100] default
This command will restore the default settings. Continue? [Y/N]:y
# Restore the default settings for interface VE-L3VPN 100.
[Sysname-VE-L3VPN100] default
description
Use description to configure a description for an interface.
The description for an interface is VE-L2VPNnumber Interface, for example, VE-L2VPN100 Interface.
L2VE interface view
L3VE interface view
Configure descriptions for different interfaces for identification and management purposes.
You can use the display interface command to display the configured interface description.
# Configure a description for interface VE-L2VPN 100 as L2VPN-Terminate.
[Sysname-VE-L2VPN100] description L2VPN-Terminate
# Configure a description for interface VE-L3VPN 100 as L3VPN-Access.
[Sysname-VE-L3VPN100] description L3VPN-Access
display interface
Use display interface to display interface information.
display interface [ ve-l2vpn [ interface-number | interface-number.subnumber ] | ve-l3vpn [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
ve-l2vpn: Displays information about L2VE interfaces or L2VE subinterfaces.
ve-l3vpn: Displays information about L3VE interfaces or L3VE subinterfaces.
interface-number: Specifies the number of an existing L2VE interface or an L3VE interface.
interface-number.subnumber: Specifies the number of an L2VE subinterface or L3VE subinterface. The interface-number argument represents the number of an existing L2VE interface or L3VE interface. The subnumber argument represents the number of a subinterface created on the interface. The value range for the subnumber argument is 1 to 4094.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about both L2VE and L3VE interfaces on the device.
If you specify an interface type but no interface number, this command displays information about all interfaces of the specified type.
If you specify both an interface type and an interface number, this command displays information about the specified interface.
# Display information about interface VE-L2VPN 100.
<Sysname> display interface ve-l2vpn 100
VE-L2VPN100
Current state: UP
Line protocol state: UP
Description: VE-L2VPN100 Interface
Bandwidth: 100000kbps
Maximum Transmit Unit: 1500
Internet protocol processing: disabled
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0011-2200-0202
IPv6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0011-2200-0202
Link service is PWE3 ethernet mode
Physical: L2VE, baudrate: 100000000 bps
VE-L2VPN100 |
Information about interface VE-L2VPN 100. |
Current state |
State of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down. · UP—Both the administrative and physical states of the interface are up. |
Line protocol state |
Link layer protocol state of the interface. The value is determined by parameter negotiation on the link layer. · UP—The protocol state of the interface is up. · UP (spoofing)—The link protocol state of the interface is up, but the link is temporarily set up on demand or does not exist. This attribute is available for null interfaces and loopback interfaces. · DOWN—The protocol state of the interface is down. |
Description for the interface. |
Bandwidth |
Expected bandwidth for the interface, in kbps. |
Maximum Transmit Unit |
MTU of the interface. |
Internet protocol processing |
IP address of the interface. If no IP address is assigned to the interface, this field displays Internet protocol processing: disabled, and the interface cannot process packets. Primary indicates that it is the primary IP address of the interface. |
Link service |
Link service mode: · VPLS mode—This mode is available when the interface is bound with a VPLS instance. For more information about VPLS instances, see "Configuring VPLS." · PWE3 ethernet mode—This mode is available when the interface is associated with a PW whose encapsulation type is Ethernet. For more information about PWs, see "Configuring MPLS L2VPN." · PWE3 vlan mode—This mode is available when the interface is associated with a PW whose encapsulation type is VLAN. For more information about PWs, see "Configuring MPLS L2VPN." |
Physical |
Physical type of the interface: · L2VE—L2VE interface or L2VE subinterface for terminating an MPLS L2VPN. · L3VE—L3VE interface or L3VE subinterface for accessing an MPLS L3VPN or IP backbone. |
baudrate |
Baudrate of the interface. |
Last clearing of counters |
Last time the counters were cleared by using the reset counters interface command. If the reset counters interface command has never been executed since the device started up, this field displays Never. |
Last 300 seconds input rate |
Average input rate in the last 300 seconds. |
Last 300 seconds output rate |
Average output rate in the last 300 seconds. |
# Display brief information about all L2VE interfaces.
<Sysname> display interface ve-l2vpn brief
Brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface Link Protocol Main IP Description
L2VE20 DOWN DOWN --
# Display brief information about interface VE-L2VPN 2, including the entire interface description.
<Sysname> display interface ve-l2vpn 2 brief description
L2VE2 UP UP 1.1.1.1 L2VPN-Terminate
# Display information about interfaces in the physical state of DOWN and the causes.
Interface Link Cause
L2VE20 DOWN Administratively
L3VE20 DOWN Administratively
Brief information of interface(s) under route mode: |
Brief information about Layer 3 interfaces. |
Link: ADM - administratively down; Stby - standby |
Link status: · ADM—The interface has been administratively shut down. To bring it up, use the undo shutdown command. · Stby—The interface is a backup interface. To show the primary interface, use the display interface-backup state command. |
Protocol: (s) - spoofing |
(s) indicates that the link layer protocol state is UP, but the link is not available because it is an on-demand link or not present at all. |
Abbreviated interface name. |
Link |
Link state of the interface: · UP—The link is physically up. · DOWN—The link is physically down. · ADM—The link has been administratively shut down. To bring it up, use the undo shutdown command. · Stby—The interface is a backup interface. To display the primary interface, use the display interface-backup state command. |
Protocol |
Link layer protocol state whose value is determined by parameter negotiation on the link layer: · UP—The protocol state of the interface is up. · UP (s)—The link protocol state of the interface is up, but the link is temporarily set up on demand or does not exist. This attribute is available for null interfaces and loopback interfaces. · DOWN—The protocol state of the interface is down. |
Main IP |
Primary IP address of the interface. |
Cause |
Causes for the link state of DOWN: · Administratively—The link has been shut down by using the shutdown command. To bring it up, use the undo shutdown command. · Not connected—The tunnel is not established. |
interface ve-l2vpn
Use interface ve-l2vpn to create an L2VE interface or L2VE subinterface and enter its view, or enter the view of an existing L2VE interface or L2VE subinterface.
Use undo interface ve-l2vpn to delete an L2VE interface or L2VE subinterface.
interface ve-l2vpn { interface-number | interface-number.subnumber }
undo interface ve-l2vpn { interface-number | interface-number.subnumber }
No L2VE interfaces or L2VE subinterfaces exist.
interface-number: Specifies the L2VE interface number in the range of 1 to 8192.
interface-number.subnumber: Specifies the L2VE subinterface number. The interface-number argument represents the number of an L2VE interface, in the range of 1 to 8192. The subnumber argument represents the number of the subinterface to be created on the L2VE interface. The value range for the subnumber argument is 1 to 4094.
A VE-L2VPN interface (an L2VE interface) or an L2VE subinterface terminates MPLS L2VPN packets. The L2VE interface performs the following operations:
· Removes the MPLS label from an MPLS L2VPN packet.
· Sends the original Layer 2 packet to an L3VE interface or L3VE subinterface that has the same interface number as the L2VE interface.
An L2VE subinterface sends original Layer 2 packets only to the L3VE interface that has the same interface number as the L2VE subinterface.
If an L2VE subinterface receives packets that carry VLAN tags, you must configure the L2VE subinterface to terminate the VLAN tags. For more information about VLAN termination, see Layer 2—LAN Switching Configuration Guide.
Deleting an L2VE interface also deletes all subinterfaces on the interface.
Before you create an L2VE subinterface, the main L2VE interface of the subinterface must already exist.
The VPLS access to L3VPN or IP backbone model does not support creating L2VE subinterfaces.
# Create L2VE interface VE-L2VPN 100, and enter L2VE interface view.
# Create L2VE subinterface VE-L2VPN 100.10, and enter L2VE subinterface view.
[Sysname] interface ve-l2vpn 100.10
[Sysname-VE-L2VPN100.10]
interface ve-l3vpn
Use interface ve-l3vpn to create an L3VE interface or L3VE subinterface and enter its view, or enter the view of an existing L3VE interface or L3VE subinterface.
Use undo interface ve-l3vpn to delete an L3VE interface or L3VE subinterface.
interface ve-l3vpn { interface-number | interface-number.subnumber }
undo interface ve-l3vpn { interface-number | interface-number.subnumber }
No L3VE interfaces or L3VE subinterfaces exist.
interface-number: Specifies the L3VE interface number in the range of 1 to 8192.
interface-number.subnumber: Specifies the L3VE subinterface number. The interface-number argument represents the number of an L3VE interface, in the range of 1 to 8192. The subnumber argument represents the number of the subinterface to be created on the L3VE interface. The value range for the subnumber argument is 1 to 4094.
A VE-L3VPN interface (an L3VE interface) provides access to an MPLS L3VPN or IP backbone for packets. The L3VE interface forwards packets received from the backbone to an L2VE interface that has the same interface number as the L3VE interface.
If packets entering an MPLS L3VPN or IP backbone carry VLAN tags, you must create an L3VE subinterface on the L3VE interface to terminate the VLAN tags. For more information about VLAN termination, see Layer 2—LAN Switching Configuration Guide.
Deleting an L3VE interface also deletes all subinterfaces on the interface.
Before you create an L3VE subinterface, the main L3VE interface of the subinterface must already exist.
# Create L3VE interface VE-L3VPN 100, and enter L3VE interface view.
[Sysname-VE-L3VPN100] quit
# Create L3VE subinterface VE-L3VPN 100.10, and enter L3VE subinterface view.
[Sysname] interface ve-l3vpn 100.10
[Sysname-VE-L3VPN100.10]
mtu
Use mtu to set the MTU for an interface.
mtu size
undo mtu
The interface MTU is 1500 bytes.
L2VE interface view
L3VE interface view
mtu-size: Specifies the MTU in the range of 46 to 9600 bytes.
# Set the MTU for interface VE-L2VPN 100 to 1430 bytes.
[Sysname-VE-L2VPN100] mtu 1430
# Set the MTU for interface VE-L3VPN 100 to 1430 bytes.
[Sysname-VE-L3VPN100] mtu 1430
Use reset counters interface to clear interface statistics.
reset counters interface [ ve-l2vpn [ interface-number | interface-number.subnumber ] | ve-l3vpn [ interface-number | interface-number.subnumber ] ]
ve-l2vpn: Clears statistics for L2VE interfaces or L2VE subinterfaces.
ve-l3vpn: Clears statistics for L3VE interfaces or L3VE subinterfaces.
If you do not specify an interface type, this command clears statistics for both L2VE and L3VE interfaces on the device.
If you specify an interface type but no interface number, this command clears statistics for all interfaces of the specified type.
If you specify both an interface type and an interface number, this command clears statistics for the specified interface.
# Clear statistics for interface VE-L2VPN 100.
<Sysname> reset counters interface ve-l2vpn 100
# Clear statistics for interface VE-L3VPN 100.
<Sysname> reset counters interface ve-l3vpn 100
display interface
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
L2VE interfaces, L2VE subinterfaces, L3VE subinterfaces, and L3VE interfaces are up.
L2VE interface view
L3VE interface view
# Shut down interface VE-L2VPN 100.
[Sysname-VE-L2VPN100] shutdown
# Shut down interface VE-L3VPN 100.
[Sysname-VE-L3VPN100] shutdown
