00-Preface | 83.85 KB |
Preface
This configuration guide describes OpenFlow fundamentals and configuration, including OpenFlow instance, controllers for an OpenFlow switch, OpenFlow timers, and dynamic MAC address support. OpenFlow separates the data forwarding and routing decision functions. A controller makes routing decisions and assigns flow table entries to an OpenFlow switch. An OpenFlow switch matches and forwards packets by using the flow table entries obtained from a controller.
· Audience.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
service@h3c.com
Documentation feedback
We appreciate your comments.
