12-NetStream configuration | 188.94 KB |
NetStream configuration task list
Configuring NetStream filtering·
Configuring NetStream sampling
Configuring attributes of the NetStream data export
Configuring the NetStream data export format
Configuring the refresh rate for NetStream version 9 templates
Configuring MPLS-aware NetStream··
Configuring NetStream flow aging·
Configuring the NetStream traditional data export
Configuring the NetStream aggregation data export
Displaying and maintaining NetStream
NetStream configuration examples
Overview
NetStream is an accounting technology that provides statistics on a per-flow basis. An IPv4 flow is defined by the following 7-tuple elements:
· Destination IP address.
· Source IP address.
· Destination port number.
· Source port number.
· Protocol number.
· ToS.
· Inbound or outbound interface.
NetStream architecture
A typical NetStream system includes the following elements:
· NetStream data exporter—A device configured with NetStream. The NDE provides the following functions:
¡ Classifies traffic flows by using the 7-tuple elements.
¡ Collects data from the classified flows.
¡ Aggregates and exports the data to the NSC.
· NetStream collector—A program running in an operation system. The NSC parses the packets received from the NDEs, and saves the data to its database.
· NetStream data analyzer—A network traffic analyzing tool. Based on the data in NSC, the NDA generates reports for traffic billing, network planning, and attack detection and monitoring. The NDA can collect data from multiple NSCs. Typically, the NDA features a Web-based system for easy operation.
NSC and NDA are typically integrated into a NetStream server.
H3C network devices act as NDEs in the NetStream system. This document focuses on NDE configuration.
Figure 1 NetStream system
Flow aging
NetStream uses flow aging to enable the NDE to export NetStream data to NetStream servers. NetStream creates a NetStream entry for each flow for storing the flow statistics in the cache.
When a flow is aged out, the NDE performs the following operations:
· Exports the summarized data to NetStream servers in a NetStream export format.
· Clears NetStream entry information in the cache.
For more information about flow aging types and configurations, see "Configuring NetStream flow aging."
Traditional data export
Traditional NetStream collects the statistics of each flow and exports the statistics to NetStream servers.
This method consumes more bandwidth and CPU than the aggregation method, and it requires a large cache size.
Aggregation data export
NetStream aggregation merges the flow statistics according to the aggregation criteria of an aggregation mode, and it sends the summarized data to NetStream servers. The NetStream aggregation data export uses less bandwidth than the traditional data export.
Table 1 lists the available aggregation modes. In each mode, the system merges statistics for multiple flows into statistics for one aggregate flow if each aggregation criterion is of the same value. The system records the statistics for the aggregate flow. These aggregation modes work independently and can take effect concurrently.
For example, when the aggregation mode configured on the NDE is protocol-port, NetStream aggregates the statistics of flow entries by protocol number, source port, and destination port. Four NetStream entries record four TCP flows with the same destination address, source port, and destination port, but with different source addresses. In the aggregation mode, only one NetStream aggregation entry is created and sent to NetStream servers.
Table 1 NetStream aggregation modes
Aggregation mode |
Aggregation criteria |
AS aggregation |
· Source AS number. · Destination AS number. · Inbound interface index. · Outbound interface index. |
Protocol-port aggregation |
· Protocol number. · Source port. · Destination port. |
Source-prefix aggregation |
· Source AS number. · Source address mask length. · Source prefix (source network address). · Inbound interface index. |
Destination-prefix aggregation |
· Destination AS number. · Destination address mask length. · Destination prefix (destination network address). · Outbound interface index. |
Prefix aggregation |
· Source AS number. · Destination AS number. · Source address mask length. · Destination address mask length. · Source prefix. · Destination prefix. · Inbound interface index. · Outbound interface index. |
Prefix-port aggregation |
· Source prefix. · Destination prefix. · Source address mask length. · Destination address mask length. · ToS. · Protocol number. · Source port. · Destination port. · Inbound interface index. · Outbound interface index. |
ToS-AS aggregation |
· ToS. · Source AS number. · Destination AS number. · Inbound interface index. · Outbound interface index. |
ToS-source-prefix aggregation |
· ToS. · Source AS number. · Source prefix. · Source address mask length. · Inbound interface index. |
ToS-destination-prefix aggregation |
· ToS. · Destination AS number. · Destination address mask length. · Destination prefix. · Outbound interface index. |
ToS-prefix aggregation |
· ToS. · Source AS number. · Source prefix. · Source address mask length. · Destination AS number. · Destination address mask length. · Destination prefix. · Inbound interface index. · Outbound interface index. |
ToS-protocol-port aggregation |
· ToS. · Protocol type. · Source port. · Destination port. · Inbound interface index. · Outbound interface index. |
ToS-BGP-nexthop |
· ToS. · BGP next hop. · Outbound interface index. |
If packets are not forwarded according to the BGP routing table, the AS number or BGP next hop cannot be obtained.
NetStream export formats
NetStream exports data in UDP datagrams in one of the following formats:
· Version 5—Exports original statistics collected based on the 7-tuple elements and does not support the NetStream aggregation data export. The packet format is fixed and cannot be extended.
· Version 8—Supports the NetStream aggregation data export. The packet format is fixed and cannot be extended.
· Version 9—Based on templates that can be defined according to the template formats defined in RFCs. The version 9 format supports exporting the NetStream aggregation data and collecting statistics about BGP next hop and MPLS packets.
NetStream filtering
NetStream filtering uses an ACL to identify packets. Whether NetStream collects data for identified packets depends on the action in the matching rule.
· NetStream collects data for packets that match permit rules in the ACL.
· NetStream does not collect data for packets that match deny rules in the ACL.
For more information about ACL, see ACL and QoS Configuration Guide.
NetStream sampling
NetStream sampling collects statistics on fewer packets and is useful when the network has a large amount of traffic. NetStream on sampled traffic lessens the impact on the device's performance. For more information about sampling, see "Configuring samplers."
Protocols and standards
RFC 5101, Specification of the IP Flow Information Export (IPFIX) Protocol for the Exchange of IP Traffic Flow Information
When you configure NetStream, choose the following configurations as needed:
· Choose the device on which you want to enable NetStream.
· If multiple service flows are passing through the NDE, use an ACL to select the target traffic.
· If the network has a large amount of traffic, configure NetStream sampling.
· Determine the export format for the NetStream data export.
· Configure NetStream flow aging.
· To reduce the bandwidth consumption of the NetStream data export, configure NetStream aggregation.
Figure 2 NetStream configuration flow
To configure NetStream, perform the following tasks:
Tasks at a glance |
(Required.) Enabling NetStream |
(Optional.) Configuring NetStream filtering |
(Optional.) Configuring NetStream sampling |
(Optional.) Configuring attributes of the NetStream data export |
(Optional.) Configuring NetStream flow aging |
(Required.) Perform at least one of the following tasks to configure NetStream data export: |
Enabling NetStream
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
1. Enter interface view. |
N/A |
2. Enable NetStream on the interface. |
ip netstream [ inbound | outbound ] |
By default, NetStream is disabled on an interface. |
When you configure NetStream filtering, follow these restrictions and guidelines:
· When NetStream filtering and sampling are both configured, packets are filtered first, and then the permitted packets are sampled.
· The NetStream filtering feature does not take effect on MPLS packets.
To configure NetStream filtering:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Enable NetStream filtering on the interface. |
ip netstream { inbound | outbound } filter acl ipv4-acl-number |
By default, NetStream filtering is disabled. NetStream collects statistics of all IPv4 packets passing through the interface. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a sampler. |
sampler sampler-name mode { fixed | random } packet-interval rate |
For more information about a sampler, see "Configuring samplers." |
3. Enter interface view. |
N/A |
4. Enable NetStream sampling. |
ip netstream [ inbound | outbound ] sampler sampler-name |
By default, NetStream sampling is disabled. |
NetStream exports NetStream data in version 5 or version 9 format, and the data fields can be expanded to contain additional information, including the following:
· Statistics about source AS, destination AS, and peer ASs in version 5 or version 9 format.
· Statistics about BGP next hop only in version 9 format.
To configure the NetStream data export format:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the NetStream data export format, and specify whether to record AS and BGP next hop information. |
· ip netstream export version 5 { origin-as | peer-as } · ip netstream export version 9 { origin-as | peer-as } [ bgp-nexthop ] |
By default: · The NetStream traditional data export uses the version 9 format. · MPLS flow data is not exported. · The peer AS numbers are exported for the source and destination. · The BGP next hop is not exported. |
Version 9 is template-based and supports user-defined formats. An NetStream device must send the version 9 templates to NetStream servers regularly, because the servers do not permanently save templates.
For a NetStream server to use correct version 9 templates, configure the refresh frequency or refresh interval for version 9 templates. If both settings are configured, templates are sent when either of the conditions is met.
A NetStream entry records the source IP address and destination IP address, and two AS numbers for each IP address. The origin-as and peer-as keywords in the ip netstream export version 5 and ip netstream export version 9 commands specify the AS numbers to be exported.
· origin-as—Specifies the source AS of the source address and the destination AS of the destination address.
· peer-as—Specifies the ASs before and after the AS where the NetStream device resides as the source AS and the destination AS, respectively.
For example, as shown in Figure 3, a flow starts at AS 20, passes AS 21 through AS 23, and then reaches AS 24. NetStream is enabled on the device in AS 22.
· The origin-as keyword defines AS 20 as the source AS and AS 24 as the destination AS.
· The peer-as keyword defines AS 21 as the source AS and AS 23 as the destination AS.
Figure 3 Recorded AS information varies by different keyword configurations
To configure the refresh rate for NetStream version 9 templates:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the refresh frequency for NetStream version 9 templates. |
By default, the version 9 templates are sent every 20 packets. |
3. Configure the refresh interval for NetStream version 9 templates. |
By default, the version 9 templates are sent every 30 minutes. |
An MPLS flow is identified by the same labels in the same position and the same 7-tuple elements. MPLS-aware NetStream collects statistics on a maximum of three labels in the label stack, with or without IP fields.
To configure MPLS-aware NetStream:
Step |
Command |
Remarks |
system-view |
N/A |
2. Collect statistics on MPLS packets. |
ip netstream mpls [ label-positions label-position1 [ label-position2 [ label-position3 ] ] ] [ no-ip-fields ] |
By default, statistics about MPLS packets are not collected. |
Flow aging methods
Periodical aging
Periodical aging uses the following methods:
· Inactive flow aging—A flow is inactive if no packet arrives for this NetStream entry within the period specified by using the ip netstream timeout inactive command. When the inactive flow aging timer expires, the following events occur:
¡ The inactive flow entry is aged out.
¡ The statistics of the flow are sent to NetStream servers and are cleared in the cache. The statistics can no longer be displayed by using the display ip netstream cache command.
When you use the inactive flow aging method, the cache is large enough for new flow entries.
· Active flow aging—A flow is active if packets arrive for the NetStream entry within the period specified by using the ip netstream timeout active command. When the active flow aging timer expires, the statistics of the active flow are exported to NetStream servers. The device continues to collect active flow statistics, which can be displayed by using the display ip netstream cache command. The active flow aging method periodically exports the statistics of active flows to NetStream servers.
Forced aging
To implement forced aging, use one of the following commands:
· Use the reset ip netstream statistics command. This command ages out all NetStream entries, and exports and clears the statistics.
· Use the ip netstream max-entry command. This command provides the following processing options when the upper limit is reached:
¡ Age out the oldest entries.
¡ Disable creation of a new entry in the cache.
Configuration procedure
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Configure periodical aging. |
· Set the aging timer for active flows: · Set the aging timer for inactive flows: |
By default: · The aging timer for active flows is 30 minutes. · The aging timer for inactive flows is 30 seconds. |
3. (Optional.) Configure forced aging. |
· Set the entry upper limit or specify the
processing method when the limit is reached: · Manually age out NetStream entries: a. Return to user view: b. Age out NetStream entries: |
By default, a maximum of 500000 NetStream entries can be cached. The system ages out the oldest entries when the upper limit is reached. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a destination host for NetStream traditional data export. |
ip netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ] |
By default, no destination host is specified. No NetStream traditional data is exported. |
3. (Optional.) Specify the source interface for NetStream data packets sent to NetStream servers. |
ip netstream export source interface interface-type interface-number |
By default, no source interface is specified for NetStream data packets. The packets take the primary IP address of the output interface as the source IP address. |
4. (Optional.) Limit the data export rate. |
ip netstream export rate rate |
By default, the data export rate is not limited. |
When you configure the NetStream aggregation data export, follow these restrictions and guidelines:
· Configurations in NetStream aggregation mode view apply only to the NetStream aggregation data export, and those in system view apply to the NetStream traditional data export. If configurations in NetStream aggregation mode view are not provided, the configurations in system view apply to the NetStream aggregation data export.
· If the version 5 format is configured to export NetStream data, NetStream aggregation data export uses the version 8 format.
To configure the NetStream aggregation data export:
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a NetStream aggregation mode and enter its view. |
ip netstream aggregation { as | destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-as | tos-bgp-nexthop | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix } |
By default, no NetStream aggregation mode is configured. |
3. Specify a destination host for NetStream aggregation data export. |
By default, no destination host is specified. If you expect only NetStream aggregation data, specify the destination host only in the related NetStream aggregation mode view. |
4. (Optional.) Specify the source interface for NetStream data packets sent to NetStream servers. |
By default, no source interface is specified for NetStream data packets. The packets take the primary IP address of the output interface as the source IP address. Source interfaces in different NetStream aggregation mode views can be different. If no source interface is configured in NetStream aggregation mode view, the source interface configured in system view applies. |
5. Enable the NetStream aggregation mode. |
enable |
By default, NetStream aggregation is disabled. |
Task |
Command |
Display NetStream entry information (in standalone mode). |
Display NetStream entry information (in IRF mode). |
Display information about the NetStream data export. |
display ip netstream export |
Display NetStream template information (in standalone mode). |
Display NetStream template information (in IRF mode). |
display ip netstream template [ chassis chassis-number slot slot-number ] |
Age out and export all NetStream data, and clear the cache. |
reset ip netstream statistics |
NetStream traditional data export configuration example
Network requirements
As shown in Figure 4, configure NetStream on the router to collect statistics on packets passing through the router.
· Enable NetStream for incoming and outgoing traffic on GigabitEthernet 1/1/1.
· Configure the router to export NetStream traditional data to UDP port 5000 of the NetStream server.
# Assign an IP address to each interface, as shown in Figure 4. (Details not shown.)
# Enable NetStream for incoming and outgoing traffic on GigabitEthernet 1/1/1.
<Router> system-view
[Router] interface gigabitethernet 1/1/1
[Router-GigabitEthernet1/1/1] ip netstream inbound
[Router-GigabitEthernet1/1/1] ip netstream outbound
[Router-GigabitEthernet1/1/1] quit
# Specify 12.110.2.2 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Router] ip netstream export host 12.110.2.2 5000
# Display NetStream entry information.
[Router] display ip netstream cache
IP NetStream cache information:
Active flow timeout : 30 min
Inactive flow timeout : 30 sec
Max number of entries : 1024
IP active flow entries : 2
MPLS active flow entries : 0
L2 active flow entries : 0
IPL2 active flow entries : 0
IP flow entries counted : 0
MPLS flow entries counted : 0
L2 flow entries counted : 0
IPL2 flow entries counted : 0
Last statistics resetting time : Never
IP packet size distribution (11 packets in total):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .909 .000 .000 .090 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
Protocol Total Packets Flows Packets Active(sec) Idle(sec)
Flows /sec /sec /flow /flow /flow
Type DstIP(Port) SrcIP(Port) Pro ToS VNI APPID If(Direct) Pkts
DstMAC(VLAN) SrcMAC(VLAN)
TopLblType(IP/MASK) Lbl-Exp-S-List
IP 10.1.1.1 (21) 100.1.1.2(1024) 1 0 N/A 0x0 GE1/1/1(I) 5
IP 100.1.1.2 (1024) 10.1.1.1 (21) 1 0 N/A 0x0 GE1/1/1(O) 5
# Display information about the NetStream data export.
[Router] display ip netstream export
IP export information:
Flow source interface : Not specified
Flow destination VPN instance : Not specified
Flow destination IP address (UDP) : 12.110.2.2 (5000)
Version 5 exported flow number : 0
Version 5 exported UDP datagrams number (failed): 0 (0)
Version 9 exported flow number : 10
Version 9 exported UDP datagrams number (failed): 10 (0)
NetStream aggregation data export configuration example
As shown in Figure 5, all routers in the network are running EBGP. Configure NetStream on the router to meet the following requirements:
· Use version 5 format to export NetStream traditional data to port 5000 of the NetStream server.
· Perform NetStream aggregation in the modes of AS, protocol-port, source-prefix, destination-prefix, and prefix.
· Export the aggregation data of different modes to 4.1.1.1, with UDP ports 2000, 3000, 4000, 6000, and 7000.
# Assign an IP address to each interface, as shown in Figure 5. (Details not shown.)
# Specify version 5 format to export NetStream traditional data.
[Router] ip netstream export version 5
# Specify 4.1.1.1 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Router] ip netstream export host 4.1.1.1 5000
# Set the aggregation mode to AS, and specify the destination host for the aggregation data export.
[Router] ip netstream aggregation as
[Router-ns-aggregation-as] enable
[Router-ns-aggregation-as] ip netstream export host 4.1.1.1 2000
[Router-ns-aggregation-as] quit
# Set the aggregation mode to protocol-port, and specify the destination host for the aggregation data export.
[Router] ip netstream aggregation protocol-port
[Router-ns-aggregation-protport] enable
[Router-ns-aggregation-protport] ip netstream export host 4.1.1.1 3000
[Router-ns-aggregation-protport] quit
# Set the aggregation mode to source-prefix, and specify the destination host for the aggregation data export.
[Router] ip netstream aggregation source-prefix
[Router-ns-aggregation-srcpre] enable
[Router-ns-aggregation-srcpre] ip netstream export host 4.1.1.1 4000
[Router-ns-aggregation-srcpre] quit
# Set the aggregation mode to destination-prefix, and specify the destination host for the aggregation data export.
[Router] ip netstream aggregation destination-prefix
[Router-ns-aggregation-dstpre] enable
[Router-ns-aggregation-dstpre] ip netstream export host 4.1.1.1 6000
[Router-ns-aggregation-dstpre] quit
# Set the aggregation mode to prefix, and specify the destination host for the aggregation data export.
[Router] ip netstream aggregation prefix
[Router-ns-aggregation-prefix] enable
[Router-ns-aggregation-prefix] ip netstream export host 4.1.1.1 7000
[Router-ns-aggregation-prefix] quit
as aggregation export information:
Flow destination IP address (UDP) : 4.1.1.1 (2000)
Version 8 exported flow number : 2
Version 8 exported UDP datagrams number (failed): 2 (0)
Version 9 exported flow number : 0
Version 9 exported UDP datagrams number (failed): 0(0)
protocol-port aggregation export information:
Flow destination IP address (UDP) : 4.1.1.1 (3000)
Version 9 exported UDP datagrams number (failed): 0 (0)
source-prefix aggregation export information:
Flow destination IP address (UDP) : 4.1.1.1 (4000)
destination-prefix aggregation export information:
Flow destination IP address (UDP) : 4.1.1.1 (6000)
Flow destination IP address (UDP) : 4.1.1.1 (7000)
Flow destination IP address (UDP) : 4.1.1.1 (5000)
Version 5 exported flow number : 10
Version 5 exported UDP datagrams number (failed): 10 (0)
