23-Crypto engine configuration | 33.80 KB |
Configuring crypto engines
Overview
Crypto engines encrypt and decrypt data for service modules. Crypto engines include the following types:
· Hardware crypto engines—A hardware crypto engine is a coprocessor integrated on a CPU or hardware crypto card. Hardware crypto engines can accelerate encryption/decryption speed, which improves device processing efficiency. You can enable or disable hardware crypto engines globally as needed. By default, hardware crypto engines are enabled.
· Software crypto engines—A software crypto engine is a set of software encryption algorithms. The device uses software crypto engines to encrypt and decrypt data for service modules. They are always enabled. You cannot enable or disable software crypto engines.
If you disable hardware crypto engines, the device uses only software crypto engines for data encryption/decryption. If you enable hardware crypto engines, the device preferentially uses hardware crypto engines. If the device does not support hardware crypto engines, or if the hardware crypto engines do not support the required encryption algorithm, the device uses software crypto engines for data encryption/decryption.
Crypto engines provide encryption/decryption services for service modules. When a service module requires data encryption/decryption, it sends the desired data to a crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Displaying and maintaining crypto engines
Task |
Command |
Display crypto engine information. |
display crypto-engine |
Display crypto engine statistics (in standalone mode). |
display crypto-engine statistics [ engine-id engine-id slot slot-number ] |
Display crypto engine statistics (in IRF mode). |
display crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ] |
Clear crypto engine statistics (in standalone mode). |
reset crypto-engine statistics [ engine-id engine-id slot slot-number ] |
Clear crypto engine statistics (in IRF mode). |
reset crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number ] |
