| 22-uRPF configuration | 272.65 KB |
Displaying and maintaining uRPF
uRPF configuration example for interfaces
uRPF configuration example for security zones
Displaying and maintaining IPv6 uRPF
IPv6 uRPF configuration examples
IPv6 uRPF configuration example for interfaces
IPv6 uRPF configuration example for security zones
Configuring uRPF
Overview
Unicast Reverse Path Forwarding (uRPF) protects a network against source address spoofing attacks, such as DoS and DDoS attacks.
Attackers send packets with a forged source address to access a system that uses IP-based authentication, in the name of authorized users or even the administrator. Even if the attackers or other hosts cannot receive any response packets, the attacks are still disruptive to the attacked target.
Figure 1 Source address spoofing attack
As shown in Figure 1, an attacker on Router A sends the server (Router B) requests with a forged source IP address 2.2.2.1 at a high rate. Router B sends response packets to IP address 2.2.2.1 (Router C). Consequently, both Router B and Router C are attacked. If the administrator disconnects Router C by mistake, the network service is interrupted.
Attackers can also send packets with different forged source addresses or attack multiple servers simultaneously to block connections or even break down the network.
uRPF can prevent these source address spoofing attacks. It checks whether an interface that receives a packet is the output interface of the FIB entry that matches the source address of the packet. If not, uRPF considers it a spoofing attack and discards the packet.
uRPF check modes
uRPF supports strict and loose modes.
· Strict uRPF check—To pass strict uRPF check, the source address of a packet and the receiving interface must match the destination address and output interface of a FIB entry. In some scenarios (for example, asymmetrical routing), strict uRPF might discard valid packets. Strict uRPF is often deployed between a PE and a CE.
· Loose uRPF check—To pass loose uRPF check, the source address of a packet must match the destination address of a FIB entry. Loose uRPF can avoid discarding valid packets, but might let go attack packets. Loose uRPF is often deployed between ISPs, especially in asymmetrical routing.
Features
Default route—When a default route exists, all packets that fail to match a specific FIB entry match the default route during uRPF check and thus are permitted to pass. To avoid this situation, you can disable uRPF from using any default route to discard such packets. If you allow using the default route (set by using allow-default-route), uRPF permits packets that only match the default route. By default, uRPF discards packets that can only match a default route. Typically, you do not need to configure the allow-default-route keyword on a PE device because it has no default route pointing to the CE. If you enable uRPF on a CE that has a default route pointing to the PE, select the allow-default-route keyword.
Link layer check—Strict uRPF check can further perform link layer check on a packet. It uses the next hop address in the matching FIB entry to look up the ARP table for a matching entry. If the source MAC address of the packet matches the MAC address in the matching ARP entry, the packet passes strict uRPF check. Link layer check is applicable to ISP devices where a Layer 3 Ethernet interface connects a large number of PCs. Loose uRPF does not support link layer check.
ACL—To identify specific packets as valid packets, you can use an ACL to match these packets. Even if the packets do not pass uRPF check, they are still forwarded.
uRPF operation
Figure 2 shows how uRPF works.
1. uRPF checks address validity:
¡ uRPF permits a packet with a multicast destination address.
¡ For a packet with an all-zero source address, uRPF permits the packet if it has a broadcast destination address. (A packet with source address 0.0.0.0 and destination address 255.255.255.255 might be a DHCP or BOOTP packet and cannot be discarded.) uRPF proceeds to step 7 if the packet has a non-broadcast destination address.
¡ uRPF proceeds to step 2 for other packets.
2. uRPF checks whether the source address matches a unicast route:
¡ If yes, uRPF proceeds to step 3.
¡ If no, uRPF proceeds to step 7. A non-unicast source address matches a non-unicast route.
3. uRPF checks whether the matching route is to the host itself:
¡ If yes, the output interface of the matching route is an InLoop interface. uRPF checks whether the receiving interface of the packet is an InLoop interface. If yes, it does not check the packet. If no, it proceeds to step 7.
¡ If no, uRPF proceeds to step 4.
4. uRPF checks whether the matching route is a default route:
¡ If yes, uRPF checks whether the allow-default-route keyword is configured to allow using the default route. If yes, it proceeds to step 5. If no, it proceeds to step 7.
¡ If no, uRPF proceeds to step 5.
5. uRPF checks whether the receiving interface matches the output interface of the matching FIB entry:
¡ If yes, uRPF proceeds to step 6.
¡ If no, uRPF checks whether the check mode is loose. If yes, it proceeds to step 7. If no, it proceeds to step 6.
6. uRPF checks whether the link-check keyword is configured for link layer check:
¡ If no, the packet passes the check.
¡ If yes, uRPF uses the next-hop address of the FIB entry to look up the ARP table for a matching entry. Then it checks whether the MAC address of the matching ARP entry is identical with the source MAC address of the packet. If yes, the packet passes the check. If no, uRPF proceeds to step 7.
7. uRPF checks whether the packet is permitted by the ACL:
¡ If yes, the packet is forwarded (such a packet is displayed in the uRPF information as a "suppressed drop").
¡ If no, the packet is discarded.
Network application
As shown in Figure 3, strict uRPF check is configured between an ISP network and a customer network. Loose uRPF check is configured between ISPs.
For special packets or users, you can configure ACLs.
Enabling uRPF
You can enable uRPF on an interface or for a security zone. uRPF enabled on an interface takes effect only on the interface. uRPF for a security zone takes effect on all interfaces in the security zone.
Follow these guidelines when you enable uRPF:
· uRPF checks only incoming packets on interfaces.
· You can use the display ip interface command to display statistics about packets discarded by uRPF (displayed as "Drops" and "Suppressed drops").
· Do not configure the allow-default-route keyword for loose uRPF check. Otherwise, uRPF might fail to work.
To enable uRPF on an interface:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
1. Enter interface view. |
N/A |
2. Enable uRPF on the interface. |
ip urpf { loose [ allow-default-route ] [ acl acl-number ] | strict [ allow-default-route ] [ acl acl-number ] [ link-check ] } |
By default, uRPF is disabled. |
To enable uRPF for a security zone:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter security zone view. |
security-zone name zone-name |
N/A |
3. Enable uRPF for the security zone. |
Task |
Command |
Display uRPF configuration on an interface (in standalone mode). |
display ip urpf [ interface interface-type interface-number ] [ slot slot-number ] |
Display uRPF configuration on an interface (in IRF mode). |
display ip urpf [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ] |
Display uRPF configuration for a security zone (in standalone mode). |
display ip urpf [ security-zone zone-name ] [ slot slot-number ] |
Display uRPF configuration for a security zone (in IRF mode). |
display ip urpf [ security-zone zone-name ] [ chassis chassis-number slot slot-number ] |
Display uRPF statistics for a security zone (in standalone mode). |
display ip urpf statistics security-zone zone-name [ slot slot-number ] |
Display uRPF statistics for a security zone (in IRF mode). |
display ip urpf statistics security-zone zone-name [ chassis chassis-number slot slot-number ] |
Clear uRPF statistics for a security zone. |
reset ip urpf statistics security-zone zone-name |
Network requirements
As shown in Figure 4, perform the following tasks:
· Configure strict uRPF check on GigabitEthernet 1/1/1 of Router B and permit packets from network 10.1.1.0/24.
· Configure strict uRPF check on GigabitEthernet 1/1/1 of Router A and allow using the default route for uRPF check.
Configuration procedure
1. Configure Router B:
# Configure ACL 2010 to permit traffic from network 10.1.1.0/24.
<RouterB> system-view
[RouterB] acl basic 2010
[RouterB-acl-ipv4-basic-2010] rule permit source 10.1.1.0 0.0.0.255
[RouterB-acl-ipv4-basic-2010] quit
# Specify an IP address for GigabitEthernet 1/1/1.
[RouterB] interface gigabitethernet 1/1/1
[RouterB-GigabitEthernet1/1/1] ip address 1.1.1.2 255.255.255.0
# Configure strict uRPF check on GigabitEthernet 1/1/1.
[RouterB-GigabitEthernet1/1/1] ip urpf strict acl 2010
2. Configure Router A:
[RouterA] interface gigabitethernet 1/1/1
[RouterA-GigabitEthernet1/1/1] ip address 1.1.1.1 255.255.255.0
# Configure strict uRPF check on GigabitEthernet 1/1/1 and allow using the default route for uRPF check.
[RouterA-GigabitEthernet1/1/1] ip urpf strict allow-default-route
As shown in Figure 5, perform the following tasks:
· Configure strict uRPF check for security zone Untrust on Router B and permit packets from network 10.1.1.0/24.
· Configure strict uRPF check on GigabitEthernet 1/1/1 of Router A and allow using the default route to match packets.
# Configure strict uRPF check for security zone Untrust and allow using ACL 2010 to match packets.
[RouterB] security-zone name Untrust
[RouterB-security-zone-Untrust] ip urpf strict acl 2010
# Configure strict uRPF check on GigabitEthernet 1/1/1 and allow using the default route to match packets.
Configuring IPv6 uRPF
Overview
Figure 6 Source address spoofing attack
As shown in Figure 6, an attacker on Router A sends the server (Router B) requests with a forged source IPv6 address 2000::1 at a high rate. Router B sends response packets to IPv6 address 2000::1 (Router C). Consequently, both Router B and Router C are attacked. If the administrator disconnects Router C by mistake, the network service is interrupted.
IPv6 uRPF can prevent these source address spoofing attacks. It checks whether an interface that receives a packet is the output interface of the FIB entry that matches the source address of the packet. If not, uRPF considers it a spoofing attack and discards the packet.
IPv6 uRPF check modes
IPv6 uRPF supports strict and loose check modes.
· Strict IPv6 uRPF check—To pass strict IPv6 uRPF check, the source address of a packet and the receiving interface must match the destination address and output interface of an IPv6 FIB entry. In some scenarios (for example, asymmetrical routing), strict IPv6 uRPF might discard valid packets. Strict IPv6 uRPF is often deployed between a PE and a CE.
· Loose IPv6 uRPF check—To pass loose IPv6 uRPF check, the source address of a packet must match the destination address of an IPv6 FIB entry. Loose IPv6 uRPF can avoid discarding valid packets, but might let go attack packets. Loose IPv6 uRPF is often deployed between ISPs, especially in asymmetrical routing.
Features
Default route—When a default route exists, all packets that fail to match a specific IPv6 FIB entry match the default route during IPv6 uRPF check and thus are permitted to pass. If you allow using the default route (by using allow-default-route), IPv6 uRPF permits packets that only match the default route. By default, IPv6 uRPF discards packets that can only match a default route. Typically, you do not need to configure the allow-default-route keyword on a PE device because it has no default route pointing to the CE device. If you enable IPv6 uRPF on a CE that has a default route pointing to the PE, select the allow-default-route keyword.
IPv6 ACLs—To identify specific packets as valid packets, you can use an IPv6 ACL to match these packets. Even if the packets do not pass IPv6 uRPF check, they are still forwarded.
IPv6 uRPF operation
Figure 7 shows how IPv6 uRPF works.
1. IPv6 uRPF checks whether the received packet carries a multicast destination address:
¡ If yes, IPv6 uRPF permits the packet.
¡ If no, IPv6 uRPF proceeds to step 2.
2. IPv6 uRPF checks whether the source address matches a unicast route:
¡ If yes, IPv6 uRPF proceeds to step 3.
¡ If no, IPv6 uRPF proceeds to step 6. A non-unicast source address matches a non-unicast route.
3. IPv6 uRPF checks whether the matching route is to the host itself:
¡ If yes, the output interface of the matching route is an InLoop interface. IPv6 uRPF checks whether the receiving interface of the packet is an InLoop interface. If yes, IPv6 uRPF permits the packet. If no, IPv6 uRPF proceeds to step 6. If the source address is a link-local address and is the receiving interface address, also proceeds to step 6.
¡ If no, IPv6 uRPF proceeds to step 4.
4. IPv6 uRPF checks whether the receiving interface matches the output interface of the matching FIB entry:
¡ If yes, IPv6 uRPF proceeds to step 5.
¡ If no, IPv6 uRPF checks whether the check mode is loose. If yes, it proceeds to step 5. If no, it proceeds to step 6.
5. IPv6 uRPF checks whether the matching route is a default route:
¡ If yes, IPv6 uRPF checks whether the allow-default-route keyword is configured to allow using the default route. If yes, the packet is forwarded. If no, IPv6 uRPF proceeds to step 6.
¡ If no, the packet is forwarded.
6. IPv6 uRPF checks whether the packet is permitted by the IPv6 ACL:
Network application
As shown in Figure 8, strict IPv6 uRPF check is configured between an ISP network and a customer network. Loose IPv6 uRPF check is configured between ISPs.
For special packets or users, you can configure IPv6 ACLs.
Enabling IPv6 uRPF
You can enable IPv6 uRPF on an interface or for a security zone. IPv6 uRPF enabled on an interface takes effect only on the interface. IPv6 uRPF for a security zone takes effect on all interfaces in the security zone.
Follow these guidelines when you enable IPv6 uRPF:
· IPv6 uRPF checks only incoming packets on interfaces.
· If you enable IPv6 uRPF on an interface, you can use the display ipv6 interface command to view statistics about packets discarded by IPv6 uRPF (displayed as "Drops" and "Suppressed drops"). You can use the display ipv6 interface command to display statistics about packets discarded by IPv6 uRPF (displayed as "Drops" and "Suppressed drops").
· Do not configure the allow-default-route keyword for loose IPv6 uRPF check. Otherwise, IPv6 uRPF might fail to work.
To enable IPv6 uRPF on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Enable IPv6 uRPF on the interface. |
ipv6 urpf { loose | strict } [ allow-default-route ] [ acl acl-number ] |
By default, IPv6 uRPF is disabled. |
To enable IPv6 uRPF for a security zone:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable IPv6 uRPF for the security zone. |
Task |
Command |
Display IPv6 uRPF configuration (in standalone mode). |
display ipv6 urpf [ interface interface-type interface-number ] [ slot slot-number ] |
Display IPv6 uRPF configuration (in IRF mode). |
display ipv6 urpf [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ] |
display ipv6 urpf [ security-zone zone-name ] [ slot slot-number ] |
display ipv6 urpf [ security-zone zone-name ] [ chassis chassis-number slot slot-number ] |
Display IPv6 uRPF statistics for a security zone (in standalone mode). |
display ipv6 urpf statistics security-zone zone-name [ slot slot-number ] |
Display IPv6 uRPF statistics for a security zone (in IRF mode). |
display ipv6 urpf statistics security-zone zone-name [ chassis chassis-number slot slot-number ] |
Clear IPv6 uRPF statistics for a security zone. |
reset ipv6 urpf statistics security-zone zone-name |
As shown in Figure 9, perform the following tasks:
· Configure strict IPv6 uRPF check on GigabitEthernet 1/1/1 of Router B and permit packets from network 1010::/64.
· Configure strict IPv6 uRPF check on GigabitEthernet 1/1/1 of Router A and allow using the default route for IPv6 uRPF check.
# Configure IPv6 ACL 2010 to permit traffic from network 1010::/64.
[RouterB] acl ipv6 basic 2010
[RouterB-acl-ipv6-basic-2010] rule permit source 1010:: 64
[RouterB-acl-ipv6-basic-2010] quit
# Specify an IPv6 address for GigabitEthernet 1/1/1.
[RouterB-GigabitEthernet1/1/1] ipv6 address 1000::2/64
[RouterB-GigabitEthernet1/1/1] ipv6 urpf strict acl 2010
[RouterA-GigabitEthernet1/1/1] ipv6 address 1000::1/64
# Configure strict uRPF check on GigabitEthernet 1/1/1 and allow using the default route for IPv6 uRPF check.
[RouterA-GigabitEthernet1/1/1] ipv6 urpf strict allow-default-route
As shown in Figure 10, perform the following tasks:
· Configure strict IPv6 uRPF check for security zone Untrust on Router B and permit packets from network 1010::/64.
· Configure strict IPv6 uRPF check on GigabitEthernet 1/1/1 of Router A and allow using the default route to match packets.
# Configure a security zone. For more information, see Fundamentals Configuration Guide. (Details not shown.)
# Configure strict IPv6 uRPF check for security zone Untrust and allow using IPv6 ACL 2010 to match packets.
[RouterB-security-zone-Untrust] ipv6 urpf strict acl 2010
[RouterA-GigabitEthernet1/1/1] ip address 1000::1/64
# Configure strict IPv6 uRPF check on GigabitEthernet 1/1/1 and allow using the default route to match packets.
