11-L2VPN access to L3VPN or IP backbone configuration | 198.99 KB |
Configuring L2VPN access to L3VPN or IP backbone
Conventional L2VPN access to L3VPN or IP backbone
Improved L2VPN access to L3VPN or IP backbone
Configuring conventional L2VPN access to L3VPN or IP backbone
Configuring improved L2VPN access to L3VPN or IP backbone
Displaying and maintaining L2VPN access to L3VPN or IP backbone
Improved L2VPN access to L3VPN or IP backbone configuration examples
Access to MPLS L3VPN through an LDP MPLS L2VPN
Access to IP backbone through an LDP VPLS
Both MPLS L2VPN and VPLS support the L2VPN access to L3VPN or IP backbone feature. MPLS L2VPN provides point-to-point connections, and VPLS provides point-to-multipoint connections.
Unless otherwise specified, the term "MPLS L2VPN" in this document refers to both MPLS L2VPN and VPLS.
For more information about MPLS L2VPN, VPLS, and MPLS L3VPN, see "Configuring MPLS L2VPN," "Configuring VPLS," and "Configuring MPLS L3VPN."
Overview
MPLS L2VPN transparently transfers Layer 2 data across an MPLS network. From the perspective of users, an MPLS L2VPN network is transparent, and an MPLS L2VPN connection is a direct physical link.
MPLS L2VPN can also act as an access network to connect users to an MPLS L3VPN or IP backbone. An MPLS L2VPN access network has the following features:
· Transparency—MPLS L2VPN is transparent to users and can be regarded as a physical link that directly connects users to the backbone.
· Cost reduction—MPLS L2VPN only requires PEs to identify users and user services, and P devices only forward packets based on labels. Therefore, you can use low-end devices as P devices to reduce your investment.
· Flexible networking—MPLS L2VPN supports various user access modes, such as Ethernet and frame relay. It allows links that run different link layer protocols to communicate with each other through interworking.
L2VPN access to L3VPN or IP backbone can be implemented in two modes: conventional and improved.
As shown in Figure 1, the access network is an MPLS L2VPN. PE 1 and PE 2 are PE devices in the MPLS L2VPN. PE 1 is connected to VPN site 1. PE 2 is connected to the MPLS L3VPN/IP backbone through PE 3. PE 3 acts as a PE in the MPLS L3VPN/IP backbone and as a CE in the MPLS L2VPN at the same time.
A packet from VPN site 1 to VPN site 2 is forwarded as follows:
1. A user in VPN site 1 sends a packet to PE 1.
2. PE 1 adds an MPLS label to the packet and sends the packet through a PW to PE 2.
3. PE 2 removes the MPLS label from the packet to obtain the original Layer 2 packet, and sends the packet to the connected CE (PE 3).
4. PE 3 looks up the routing table, and forwards the packet to the destination through the MPLS L3VPN or IP backbone.
In the conventional networking mode, two devices are required to connect the MPLS L2VPN and the MPLS L3VPN or IP backbone (PE 2 and PE 3 in this example). One (PE 2) is required for terminating the MPLS L2VPN, and the other (PE 3) is required for accessing the MPLS L3VPN or IP backbone.
As shown in Figure 2, the PE Aggregation (PE-agg) device connects the MPLS L2VPN with the MPLS L3VPN or IP backbone. PE-agg terminates the MPLS L2VPN and provides access to the MPLS L3VPN or IP backbone.
Configure the PE-agg as follows so the PE-agg can implement the functions of both PE 2 and PE 3 in Figure 1:
1. Create a terminating virtual Ethernet (VE) interface on the PE-agg to terminate MPLS L2VPN packets.
This interface is referred to as the VE-L2VPN (L2VE) interface. The functions and configurations of the interface are similar to those of the terminating interface (Terminating int) in Figure 1.
2. Create an access VE interface on the PE-agg to provide access to the backbone, and configure the interface and the L2VE interface have the same interface number.
This interface is referred to as the VE-L3VPN (L3VE) interface. The functions and configurations of the interface are similar to those of the access interface (Access int) in Figure 1. The IP address of the L3VE interface must be in the same network segment as the AC interface of CE 1. When the backbone is an MPLS L3VPN, bind the VPN instance to the L3VE interface. The interface can then forward user packets through the VPN routes.
The L2VE interface directly delivers the obtained Layer 2 packets to the L3VE interface. The two VE interfaces can be considered directly connected through a physical link, like the physical link between the L2VE interface and the L3VE interface in Figure 1.
The PE-agg connects the MPLS L2VPN and the backbone through the L2VE interface and the L3VE interface. You can assume that the MPLS L2VPN is connected to the backbone through an Ethernet or VLAN link. If a user is not connected to the MPLS L2VPN through Ethernet or VLAN, you must configure MPLS L2VPN interworking on the user access PE (PE 1) and the L2VE interface of the PE-agg.
As shown in Figure 1, perform the following tasks to configure conventional L2VPN access to L3VPN or IP backbone:
1. Configure the MPLS L2VPN:
¡ Configure PE 1 and PE 2 as PE devices in the MPLS L2VPN.
¡ Configure CE 1 and PE 3 as CE devices in the MPLS L2VPN.
For more information about MPLS L2VPN configuration, see "Configuring MPLS L2VPN" and "Configuring VPLS."
2. Configure the MPLS L3VPN or IP backbone:
¡ Configure PE 3 and PE 4 as PE devices in the MPLS L3VPN or IP backbone.
¡ Configure CE 1 and CE 2 as CE devices in the MPLS L3VPN or IP backbone.
For more information about MPLS L3VPN configuration, see "Configuring MPLS L3VPN."
As shown in Figure 2, configurations required on PE 1, PE 4, CE 1, and CE 2 are similar to those on the devices in the conventional L2VPN access scenario. The PE-agg requires the following configurations:
· Create an L2VE interface and an L3VE interface that have the same interface number.
· Configure MPLS L2VPN. For more information, see "Configuring MPLS L2VPN" and "Configuring VPLS."
· Configure MPLS L3VPN or IP routes. For more information about MPLS L3VPN configuration, see "Configuring MPLS L3VPN."
Configuring an L2VE interface
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Create an L2VE interface and enter its view. |
interface ve-l2vpn interface-number |
By default, no L2VE interfaces exist. You can create a maximum of 8192 L2VE interfaces on a device. |
3. (Optional.) Configure a description for the interface. |
description text |
By default, the description for the interface is VE-L2VPNnumber Interface, for example, VE-L2VPN100 Interface. |
4. (Optional.) Set the MTU for the interface. |
mtu size |
By default, the interface MTU is 1500 bytes. |
5. (Optional.) Set the expected bandwidth for the interface. |
bandwidth bandwidth-value |
By default, the expected bandwidth is 100000 kbps. |
6. (Optional.) Restore the default settings for the interface. |
default |
N/A |
7. (Optional.) Bring up the interface. |
undo shutdown |
By default, the interface is up. |
Configuring an L3VE interface
Step |
Command |
Remarks |
system-view |
N/A |
2. Create an L3VE interface and enter its view. |
interface ve-l3vpn interface-number |
By default, no L3VE interfaces exist. You can create a maximum of 8192 L3VE interfaces on a device. |
description text |
By default, the description for the interface is VE-L3VPNnumber Interface, for example, VE-L3VPN100 Interface. |
mtu size |
default |
N/A |
undo shutdown |
Task |
Command |
Display information about L2VE interfaces or L3VE interfaces. |
display interface [ ve-l2vpn interface-number | ve-l3vpn interface-number ] [ brief [ description | down ] ] |
Clear interface statistics. |
reset counters interface [ ve-l2vpn interface-number | ve-l3vpn interface-number ] |
The MPLS L2VPN in this configuration example is a point-to-point MPLS L2VPN that provides PPP-to-Ethernet interworking.
Network requirements
The backbone is an MPLS L3VPN, which advertises VPN routes through BGP and forwards VPN packets based on MPLS labels.
CE 1 and CE 2 belong to VPN 1 whose route target is 111:1 and RD is 200:1. CE 1 is connected to PE 1 through interface Serial 1/1/0, which uses PPP encapsulation. CE 2 is connected to the MPLS L3VPN through interface GigabitEthernet 1/1/1.
Perform the following configurations to allow communication between CE 1 and CE 2:
· Set up an LDP PW between PE 1 and PE-agg, so that CE 1 can access the MPLS L3VPN through MPLS L2VPN.
· Configure MPLS L2VPN interworking on interface Serial 1/1/0 of PE 1 and the L2VE interface of PE-agg.
This configuration is required because CE 1 is connected to the MPLS L2VPN through PPP, not Ethernet or VLAN.
· Run EBGP between CE 1 and PE-agg and between CE 2 and PE 2 to exchange VPN routing information.
· Run MP-IBGP between PE-agg and PE 2 to exchange VPN routing information.
· Run IS-IS between PE-agg and PE 2 to ensure IP connectivity within the backbone.
· Run OSPF among PE 1, P, and PE-agg to ensure IP connectivity between the PEs.
IP address |
Device |
IP address |
CE 1 |
Ser1/1/0 |
100.1.1.1/24 |
PE-agg |
Loop0 |
3.3.3.9/32 |
PE 1 |
Loop0 |
1.1.1.9/32 |
POS1/1/0 |
10.2.2.2/24 |
POS1/1/0 |
10.2.1.1/24 |
POS1/1/1 |
10.3.3.1/24 |
P |
Loop0 |
2.2.2.9/32 |
VE-L3VPN1 |
100.1.1.2/24 |
POS1/1/0 |
10.2.1.2/24 |
PE 2 |
Loop0 |
4.4.4.9/32 |
POS1/1/1 |
10.2.2.1/24 |
POS1/1/0 |
10.3.3.2/24 |
CE 2 |
GE1/1/1 |
100.2.1.2/24 |
GE1/1/1 |
100.2.1.1/24 |
Configuration procedure
1. Configure IP addresses for interfaces as shown in Table 1. (Details not shown.)
2. Create interfaces VE-L2VPN 1 and VE-L3VPN 1 on PE-agg:
# Create interface VE-L2VPN 1.
<PEagg> system-view
[PEagg] interface ve-l2vpn 1
[PEagg-VE-L2VPN1] quit
# Create interface VE-L3VPN 1.
[PEagg] interface ve-l3vpn 1
[PEagg-VE-L3VPN1] quit
3. Configure MPLS L2VPN:
a. Configure OSPF on PE 1, P, and PE-agg, and advertise interface addresses:
# Configure PE 1.
<PE1> system-view
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure the P device.
<P> system-view
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 10.2.2.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE-agg.
[PEagg] ospf
[PEagg-ospf-1] area 0
[PEagg-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PEagg-ospf-1-area-0.0.0.0] network 10.2.2.0 0.0.0.255
[PEagg-ospf-1-area-0.0.0.0] quit
[PEagg-ospf-1] quit
b. Configure basic MPLS and MPLS LDP on PE 1, P, and PE-agg:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] lsp-trigger all
[PE1-ldp] quit
[PE1] interface pos 1/1/0
[PE1-Pos1/1/0] mpls enable
[PE1-Pos1/1/0] mpls ldp enable
[PE1-Pos1/1/0] quit
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] lsp-trigger all
[P-ldp] quit
[P] interface pos 1/1/0
[P-Pos1/1/0] mpls enable
[P-Pos1/1/0] mpls ldp enable
[P-Pos1/1/0] quit
[P] interface pos 1/1/1
[P-Pos1/1/1] mpls enable
[P-Pos1/1/1] mpls ldp enable
[P-Pos1/1/1] quit
# Configure PE-agg.
[PEagg] mpls lsr-id 3.3.3.9
[PEagg] mpls ldp
[PEagg-ldp] lsp-trigger all
[PEagg-ldp] quit
[PEagg] interface pos 1/1/0
[PEagg-Pos1/1/0] mpls enable
[PEagg-Pos1/1/0] mpls ldp enable
[PEagg-Pos1/1/0] quit
c. Enable L2VPN on PE 1 and PE-agg:
# Configure PE 1.
[PE1] l2vpn enable
# Configure PE-agg.
[PEagg] l2vpn enable
d. Configure the AC interfaces of PE 1 and PE-agg, create PWs that support interworking, and bind the interface to the PWs:
# On Serial 1/1/0 of PE 1, configure PPP to support IPCP negotiation without IP address.
[PE1] interface serial 1/1/0
[PE1-Serial1/1/0] link-protocol ppp
[PE1-Serial1/1/0] ppp ipcp ignore local-ip
[PE1-Serial1/1/0] quit
# On PE 1, create a PW that supports interworking in the group, and bind Serial 1/1/0 to the PW.
[PE1] xconnect-group 1
[PE1-xcg-1] connection 1
[PE1-xcg-1-1] ac interface serial 1/1/0
[PE1-xcg-1-1] interworking ipv4
[PE1-xcg-1-1] peer 3.3.3.9 pw-id 101
[PE1-xcg-1-1-3.3.3.9-101] quit
# On the L2VE interface of PE-agg, specify the default next hop as 100.1.1.2.
[PEagg-VE-L2VPN1] default-nexthop ip 100.1.1.2
# On PE-agg, create a PW that supports interworking in the group, and bind VE-L2VPN 1 to the PW.
[PEagg] xconnect-group 1
[PEagg-xcg-1] connection 1
[PEagg-xcg-1-1] ac interface ve-l2vpn 1
[PEagg-xcg-1-1] interworking ipv4
[PEagg-xcg-1-1] peer 1.1.1.9 pw-id 101
[PEagg-xcg-1-1-1.1.1.9-101] quit
e. Configure the AC interface of CE 1 (Serial 1/1/0).
<CE1> system-view
[CE1] interface serial 1/1/0
[CE1-Serial1/1/0] link-protocol ppp
[CE1-Serial1/1/0] ip address 100.1.1.1 24
4. Configure MPLS L3VPN:
a. Configure IS-IS on PE 2 and PE-agg, and advertise interface addresses:
# Configure PE-agg.
[PEagg] isis 1
[PEagg-isis-1] network-entity 10.0000.0000.0001.00
[PEagg-isis-1] quit
[PEagg] interface pos 1/1/1
[PEagg-Pos1/1/1] isis enable 1
[PEagg-Pos1/1/1] quit
[PEagg] interface loopback 0
[PEagg-LoopBack0] isis enable 1
[PEagg-LoopBack0] quit
# Configure PE 2.
[PE2] isis 1
[PE2-isis-1] network-entity 10.0000.0000.0002.00
[PE2-isis-1] quit
[PE2] interface pos 1/1/0
[PE2-Pos1/1/0] isis enable 1
[PE2-Pos1/1/0] quit
[PE2] interface loopback 0
[PE2-LoopBack0] isis enable 1
[PE2-LoopBack0] quit
b. Configure basic MPLS and MPLS LDP on PE-agg and PE 2:
# Configure PE-agg.
[PEagg-Pos1/1/1] mpls enable
[PEagg-Pos1/1/1] mpls ldp enable
# Configure PE 2.
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls ldp
[PE2-ldp] lsp-trigger all
[PE2-ldp] quit
[PE2-Pos1/1/0] mpls enable
[PE2-Pos1/1/0] mpls ldp enable
[PE2-Pos1/1/0] quit
c. On PE-agg and PE 2, create VPN instance VPN1, and bind the VPN instance to the interface connected to the CE:
# Configure PE-agg.
[PEagg] ip vpn-instance VPN1
[PEagg-vpn-instance-VPN1] route-distinguisher 200:1
[PEagg-vpn-instance-VPN1] vpn-target 111:1 both
[PEagg-vpn-instance-VPN1] quit
[PEagg-VE-L3VPN1] ip binding vpn-instance VPN1
[PEagg-VE-L3VPN1] ip address 100.1.1.2 24
# Configure PE 2.
[PE2] ip vpn-instance VPN1
[PE2-vpn-instance-VPN1] route-distinguisher 200:1
[PE2-vpn-instance-VPN1] vpn-target 111:1 both
[PE2-vpn-instance-VPN1] quit
[PE2] interface gigabitethernet 1/1/1
[PE2-GigabitEthernet1/1/1] ip binding vpn-instance VPN1
[PE2-GigabitEthernet1/1/1] ip address 100.2.1.1 24
[PE2-GigabitEthernet1/1/1] quit
d. Establish EBGP peer relationships between CE 1 and PE-agg, and between CE 2 and PE 2 to redistribute VPN routes:
# Configure CE 1 and specify PE-agg as the peer.
<CE1> system-view
[CE1] bgp 65010
[CE1-bgp] peer 100.1.1.2 as-number 100
[CE1-bgp] address-family ipv4
[CE1-bgp-ipv4] peer 100.1.1.2 enable
[CE1-bgp-ipv4] import-route direct
[CE1-bgp-ipv4] quit
[CE1-bgp] quit
# Configure PE-agg and specify CE 1 as the peer.
[PEagg] bgp 100
[PEagg-bgp] ip vpn-instance VPN1
[PEagg-bgp-VPN1] peer 100.1.1.1 as-number 65010
[PEagg-bgp-VPN1] address-family ipv4
[PEagg-bgp-ipv4-VPN1] peer 100.1.1.1 enable
[PEagg-bgp-ipv4-VPN1] import-route direct
[PEagg-bgp-ipv4-VPN1] quit
[PEagg-bgp-VPN1] quit
[PEagg-bgp] quit
# Configure CE 2 and specify PE 2 as the peer.
[CE2] bgp 65020
[CE2-bgp] peer 100.2.1.1 as-number 100
[CE2-bgp] address-family ipv4
[CE2-bgp-ipv4] peer 100.2.1.1 enable
[CE2-bgp-ipv4] import-route direct
[CE2-bgp-ipv4] quit
[CE2-bgp] quit
# Configure PE 2 and specify CE 2 as the peer.
[PE2] bgp 100
[PE2-bgp] ip vpn-instance VPN1
[PE2-bgp-VPN1] peer 100.2.1.2 as-number 65020
[PE2-bgp-VPN1] address-family ipv4
[PE2-bgp-ipv4-VPN1] peer 100.2.1.2 enable
[PE2-bgp-ipv4-VPN1] import-route direct
[PE2-bgp-ipv4-VPN1] quit
[PE2-bgp-VPN1] quit
[PE2-bgp] quit
e. Establish an MP-IBGP peer relationship between PE-agg and PE 2:
# Configure PE-agg.
[PEagg] bgp 100
[PEagg-bgp] peer 4.4.4.9 as-number 100
[PEagg-bgp] peer 4.4.4.9 connect-interface loopback 0
[PEagg-bgp] address-family vpnv4
[PEagg-bgp-vpnv4] peer 4.4.4.9 enable
[PEagg-bgp-vpnv4] quit
[PEagg-bgp] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp] peer 3.3.3.9 as-number 100
[PE2-bgp] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp] address-family vpnv4
[PE2-bgp-vpnv4] peer 3.3.3.9 enable
[PE2-bgp-vpnv4] quit
[PE2-bgp] quit
5. The default MTU value varies by interface type. To avoid packet fragmentation, set the MTU value for each POS interface on each device to 1500 bytes. The following shows the MTU configuration on PE 1.
[PE1-Pos1/1/0] mtu 1500
[PE1-Pos1/1/0] shutdown
[PE1-Pos1/1/0] undo shutdown
# Ping CE 2 from CE 1 to verify their connectivity.
<CE1> ping 100.2.1.2
Ping 100.2.1.2 (100.2.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 100.2.1.2: icmp_seq=0 ttl=128 time=1.073 ms
56 bytes from 100.2.1.2: icmp_seq=1 ttl=128 time=1.428 ms
56 bytes from 100.2.1.2: icmp_seq=2 ttl=128 time=19.367 ms
56 bytes from 100.2.1.2: icmp_seq=3 ttl=128 time=1.013 ms
56 bytes from 100.2.1.2: icmp_seq=4 ttl=128 time=0.684 ms
--- Ping statistics for 100.2.1.2 ---
round-trip min/avg/max/std-dev = 0.684/4.713/19.367/7.331 ms
Create an LDP PW between PE 1 and PE-agg on the VPLS access network, so that CE 1 can access the IP backbone through the PW.
Configure OSPF process 2 to advertise routing information on the IP backbone.
Figure 4 Network diagram
Device |
IP address |
Device |
IP address |
CE 1 |
GE1/1/1 |
100.1.1.1/24 |
PE-agg |
Loop0 |
3.3.3.9/32 |
PE 1 |
Loop0 |
1.1.1.9/32 |
POS1/1/0 |
10.2.2.2/24 |
POS1/1/0 |
10.2.1.1/24 |
POS1/1/1 |
10.3.3.1/24 |
P |
Loop0 |
2.2.2.9/32 |
VE-L3VPN1 |
100.1.1.2/24 |
POS1/1/0 |
10.2.1.2/24 |
PE 2 |
POS1/1/0 |
10.3.3.2/24 |
POS1/1/1 |
10.2.2.1/24 |
GE1/1/1 |
100.2.1.1/24 |
CE 2 |
GE1/1/1 |
100.2.1.2/24 |
1. Configure IP addresses for interfaces as shown in Table 2. (Details not shown.)
<PEagg> system-view
# Create interface VE-L3VPN 1, and configure an IP address for the interface.
# Configure PE 1.
<PE1> system-view
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
<P> system-view
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
# Configure PE-agg.
[PEagg] ospf
[PEagg-ospf-1] quit
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Pos1/1/0] quit
[P] mpls ldp
[P-ldp] quit
[P-Pos1/1/0] quit
[P-Pos1/1/1] quit
# Configure PE-agg.
[PEagg] mpls ldp
[PEagg-ldp] quit
# Configure PE 1.
[PE1] l2vpn enable
# Configure PE-agg.
d. Create VSIs on PE 1 and PE-agg:
# On PE 1, create VSI vpna, and specify the PW signaling protocol for the VSI as LDP.
[PE1] vsi vpna
[PE1-vsi-vpna] pwsignaling ldp
# On PE 1, create LDP PW 500 to the peer PE 3.3.3.9.
[PE1-vsi-vpna-ldp] peer 3.3.3.9 pw-id 500
[PE1-vsi-vpna-ldp-3.3.3.9-500] quit
[PE1-vsi-vpna-ldp] quit
[PE1-vsi-vpna] quit
# On PE-agg, create VSI vpna, and specify the PW signaling protocol for the VSI as LDP.
[PEagg] vsi vpna
[PEagg-vsi-vpna] pwsignaling ldp
# On PE-agg, create an LDP PW: specify the peer PE address as 1.1.1.9, and set the PW ID to 500.
[PEagg-vsi-vpna-ldp] peer 1.1.1.9 pw-id 500
[PEagg-vsi-vpna-ldp-1.1.1.9-500] quit
[PEagg-vsi-vpna-ldp] quit
[PEagg-vsi-vpna] quit
e. Bind the AC interface to the VSI on PE 1 and PE-agg:
# On PE 1, bind GigabitEthernet 1/1/1 to VSI vpna.
[PE1] interface gigabitethernet 1/1/1
[PE1-GigabitEthernet1/1/1] xconnect vsi vpna
# On PE-agg, bind VE-L2VPN 1 to VSI vpna.
[PEagg-VE-L2VPN1] xconnect vsi vpna
4. Configure OSPF process 2 to advertise routing information on the IP backbone:
# Configure CE 1.
[CE1] ospf 2
[CE1-ospf-2] area 0
[CE1-ospf-2-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[CE1-ospf-2-area-0.0.0.0] quit
[CE1-ospf-2] quit
# Configure PE-agg.
[PEagg] ospf 2
[PEagg-ospf-2] area 0
[PEagg-ospf-2-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[PEagg-ospf-2-area-0.0.0.0] network 10.3.3.0 0.0.0.255
[PEagg-ospf-2-area-0.0.0.0] quit
[PEagg-ospf-2] quit
# Configure PE 2.
<PE2> system-view
[PE2] ospf 2
[PE2-ospf-2] area 0
[PE2-ospf-2-area-0.0.0.0] network 100.2.1.0 0.0.0.255
[PE2-ospf-2-area-0.0.0.0] network 10.3.3.0 0.0.0.255
[PE2-ospf-2-area-0.0.0.0] quit
[PE2-ospf-2] quit
# Configure CE 2.
<CE2> system-view
[CE2] ospf 2
[CE2-ospf-2] area 0
[CE2-ospf-2-area-0.0.0.0] network 100.2.1.0 0.0.0.255
[CE2-ospf-2-area-0.0.0.0] quit
[CE2-ospf-2] quit
[PE1] int pos 1/1/0
