09-MPLS L2VPN configuration | 530.84 KB |
Remote connection establishment
Local connection establishment
MPLS L2VPN configuration task list
Configuring a Layer 3 interface
Configuring a remote CCC connection
Binding an AC to a cross-connect
Binding a Layer 3 interface to a cross-connect
Configuring static PW redundancy
Configuring interworking for a cross-connect
Enabling SNMP notifications for L2VPN PW
Displaying and maintaining MPLS L2VPN
MPLS L2VPN configuration examples
Configuring local MPLS L2VPN connections
Configuring IP interworking over local MPLS L2VPN connections
Configuring IP interworking over an LDP PW
Configuring an intra-domain multi-segment PW
Configuring an inter-domain multi-segment PW
Configuring MPLS L2VPN
MPLS L2VPN provides point-to-point and point-to-multipoint connections. This chapter describes only the MPLS L2VPN technologies that provide point-to-point connections. For information about the MPLS L2VPN technologies that provide point-to-multipoint connections, see "Configuring VPLS."
Overview
MPLS L2VPN is an implementation of Pseudo Wire Emulation Edge-to-Edge (PWE3). It offers Layer 2 VPN services over an MPLS or IP backbone. MPLS L2VPN can transparently transmit Layer 2 data for different data link layer protocols, including Ethernet, VLAN, FR, and PPP.
From a user's perspective, the MPLS or IP backbone is a Layer 2 switched network. For example, when two Ethernet networks are connected through MPLS L2VPN over an MPLS backbone, Ethernet users think they are connected directly through an Ethernet.
Basic concepts of MPLS L2VPN
· Customer edge—A CE is a customer device directly connected to the service provider network.
· Provider edge—A PE is a service provider device connected to one or more CEs. It provides VPN access by mapping and forwarding packets between user networks and public tunnels.
· Attachment circuit—An AC is a link between a CE and a PE, such as an FR DLCI, Ethernet interface, PPP connection, or VLAN.
· Pseudowire—A PW is a virtual bidirectional connection between two PEs. An MPLS PW comprises a pair of LSPs in opposite directions.
· Public tunnel—A public tunnel is a connection that carries one or more PWs across the MPLS or IP backbone. It can be an LSP tunnel, an MPLS TE tunnel, or a GRE tunnel.
· Cross-connect—A cross-connect connects two physical or virtual circuits such as ACs and PWs. It switches packets between the two physical or virtual circuits. Cross-connects include AC to AC cross-connect, AC to PW cross-connect, and PW to PW cross-connect.
· Site ID—A site ID uniquely identifies a site in a VPN. Sites in different VPNs can have the same site ID.
· Route distinguisher—A route distinguisher (RD) is added before a site ID to distinguish the sites that have the same site ID but reside in different VPNs. An RD and a site ID uniquely identify a VPN site.
· Label block—A label block is a set of labels. It includes the following parameters:
¡ Label base—The LB specifies the initial label value of the label block. A PE automatically selects an LB value that cannot be manually modified.
¡ Label range—The LR specifies the number of labels that the label block contains. The LB and LR determine the labels contained in the label block. For example, if the LB is 1000 and the LR is 5, the label block contains labels 1000 through 1004.
¡ Label-block offset—The LO specifies the offset of a label block. If the existing label block becomes insufficient as the VPN sites increase, you can add a new label block to enlarge the label range. A PE uses an LO to identify the position of the new label block. The LO value of a label block is the sum of the LRs of all previously assigned label blocks. For example, if the LR and LO of the first label block are 10 and 0, the LO of the second label block is 10. If the LR of the second label block is 20, the LO of the third label block is 30.
A label block with LB, LO, and LR as 1000, 10, and 5, respectively, is represented as 1000/10/5.
For example, a VPN has 10 sites, and a PE assigns the first label block LB1/0/10 to the VPN. When another 15 sites are added, the PE keeps the first label block and assigns the second label block LB2/10/15 to extend the network. LB1 and LB2 are the initial label values that are randomly selected by the PE.
· Route target—PEs use the BGP route target attribute (also called VPN target attribute) to manage BGP L2VPN information advertisement. PEs support the following types of route target attributes:
¡ Export target attribute—When a PE sends L2VPN information to the peer PE in a BGP update message, it sets the route target attribute in the update message to an export target. L2VPN information includes the site ID, RD, and label block.
¡ Import target attribute—When a PE receives an update message from the peer PE, it checks the route target attribute in the update message. If the route target value matches an import target, the PE accepts the L2VPN information in the update message.
Route target attributes determine from which PEs a PE can receive L2VPN information.
MPLS L2VPN network models
MPLS L2VPN network models include the remote connection and local connection models.
Remote connection model
As shown in Figure 1, this model connects two CEs through a PW on an MPLS or IP backbone.
Figure 1 Remote connection model
Local connection model
As shown in Figure 2, this model connects two CEs to the same PE so the CEs can communicate through the PE.
Figure 2 Local connection model
To set up a remote MPLS L2VPN connection:
1. Set up a public tunnel to carry one or more PWs between PEs:
The public tunnel can be an LSP, MPLS TE, or GRE tunnel.
If multiple public tunnels exist between two PEs, you can configure a tunnel policy to control tunnel selection. For more information about tunnel policies, see "Configuring tunnel policies."
If a PW is established over an LSP or MPLS TE tunnel, packets on the PW have two labels. The outer label is the public LSP or MPLS TE tunnel label that MPLS uses to forward the packet to the peer PE. The inner label is the PW label that the peer PE uses to forward the packet to the destination CE.
2. Set up a PW to connect customer networks:
PWs include static PWs, LDP PWs, BGP PWs, and Circuit Cross Connect (CCC) PWs.
To establish a static PW, configure the peer PE address, and the incoming and outgoing PW labels for the PW on the two PEs. Static PWs consume a small amount of resources but have complex configurations.
To establish an LDP PW, configure LDP and specify the peer PE address on the two PEs. LDP defines a new FEC type named PW ID FEC for PEs to exchange PW-label bindings. The new FEC type uses a PW ID and a PW data encapsulation type to identify a PW. The PW ID is the ID of the PW between PEs. The PW data encapsulation type specifies the encapsulation type for data transmitted over the PW, such as FR, Ethernet, or VLAN. PEs advertise the PW label and PW ID FEC in label mapping messages to create a PW. Dynamic PWs have simple configurations but consume more resources than static PWs.
To establish BGP PWs, BGP advertises label block information in an extended BGP update to PEs in the same VPN. Each PE uses the received label block information to calculate outgoing labels and uses its own label block to calculate incoming labels. After two PEs complete label calculation, a BGP PW is established between them. BGP PWs have the following features:
¡ Simplified configuration—There is no need to manually specify peer PEs. A PE automatically find peer PEs after receiving label block information from the peer PEs.
¡ Reduced workload—Label block advertisement enables assigning labels for multiple PWs at one time.
To establish a CCC PW, manually specify the incoming and outgoing labels for the PW on the PEs, and create two static LSPs in opposite directions on P devices between PEs. There is no need to configure a public tunnel for the CCC PW. CCC employs only one level of label to transfer packets. The static LSPs on the P devices transfer data only for the CCC PW. They cannot be used by other connections or MPLS L3VPN.
3. Set up an AC between a PE and a CE:
Set up an AC by configuring a link layer connection (such as a PPP connection) between a PE and a CE.
An AC can be one of the following types:
¡ Layer 3 physical interface or Layer 3 virtual interface—Transparently forwards received packets over the bound PW. The interface can be an Ethernet interface or an FR interface.
¡ Layer 3 subinterface—Forwards packets received from the corresponding link (such as VLAN or FR DLCI) to the bound PW. In this mode, VLANs are unique on a per interface basis rather than on a global basis.
NOTE: When VLANs are globally unique, packets with the same VLAN ID are forwarded over the PW bound with that VLAN ID regardless of the receiving interfaces. If VLANs are unique on a per interface basis, packets with the same VLAN ID from different interfaces can be forwarded over different PWs. |
4. Bind the AC to the PW:
Bind the Layer 3 physical interface or Layer 3 subinterface to the PW, so the PE forwards packets between the AC and the PW.
To set up a local MPLS L2VPN connection between two CEs:
1. Set up ACs:
Configure the link layer protocol to set up an AC between the PE and each CE. For more information, see "Set up an AC between a PE and a CE:."
2. Bind the two ACs:
Bind the PE's interfaces connected to the two CEs so the PE can forward packets between CEs.
PW data encapsulation types
MPLS L2VPN transports Layer 2 data of different data link layer protocols through PWs. A PE encapsulates a Layer 2 packet received from an AC according to the PW data encapsulation type. The PW data encapsulation type is determined by the link type of the AC, as shown in Table 1.
Table 1 Relationship between AC types and PW data encapsulation types
AC type |
PW data encapsulation type |
Ethernet |
Ethernet |
VLAN |
PPP |
PPP |
HDLC |
HDLC |
Ethernet over MPLS
Ethernet over MPLS uses MPLS L2VPN to connect Ethernets, and delivers Ethernet packets through a PW over the MPLS backbone.
The following PW data encapsulation types are available for Ethernet over MPLS:
· Ethernet—P-tag is not transferred on a PW.
¡ For a packet from a CE:
- If the packet contains a P-tag, the PE removes the P-tag, and adds a PW label and an outer tag into the packet before forwarding it.
- If the packet contains no P-tag, the PE directly adds a PW label and an outer tag into the packet before forwarding it.
¡ For a packet to a CE:
- If the access mode is configured as VLAN by using the ac interface command, the PE adds a P-tag into the packet before sending it to the CE.
- If the access mode is configured as Ethernet by using the ac interface command, the PE directly sends the packet to the CE.
You cannot rewrite or remove existing tags.
· VLAN—Packets transmitted over a PW must carry a P-tag.
- If the peer PE does not require the ingress to rewrite the P-tag, the PE keeps the P-tag unchanged for the packet, and then encapsulates the packet. If the packet contains no P-tag, the PE adds a null label (the label value is 0) into the packet, and then encapsulates the packet.
- If the peer PE requires the ingress to rewrite the P-tag, the PE changes the P-tag to the expected VLAN tag (the tag value might be 0), and then adds a PW label and an outer tag into the packet. If the packet contains no P-tag, the PE adds a VLAN tag expected by the peer PE (the tag value might be 0), and then adds a PW label and an outer tag into the packet.
- If the access mode is configured as VLAN by using the ac interface command, the PE rewrites or retains the P-tag before forwarding the packet.
- If the access mode is configured as Ethernet by using the ac interface command, the PE removes the P-tag before forwarding the packet.
Ethernet over MPLS supports the following modes:
· Port mode—A Layer 3 Ethernet interface is bound to a PW. Packets received from the Layer 3 Ethernet interface are forwarded through the bound PW. The default PW data encapsulation type for port mode is Ethernet.
Figure 3 Packet encapsulation in port mode
· VLAN mode—A Layer 3 Ethernet subinterface is bound to a PW. Packets received from the VLAN are forwarded through the bound PW. The peer PE can modify the VLAN tag as needed. The default PW data encapsulation type for VLAN mode is VLAN.
PPP/HDLC over MPLS
PPP/HDLC over MPLS uses MPLS L2VPN to connect PPPs or HDLC networks, and delivers PPP or HDLC packets through a PW over the MPLS backbone.
If the link type of the AC is PPP, the PW data encapsulation type is PPP. If the link type of the AC is HDLC, the PW data encapsulation type is HDLC.
PPP/HDLC over MPLS supports only the port mode. You can associate a Layer 3 interface whose encapsulation type is PPP or HDLC with a PW.
In a PPP/HDLC over MPLS network, a PE processes a PPP or HDLC packet as follows:
1. After receiving a packet from a Layer 3 interface, the PE searches for the PW bound to the interface.
2. The PE encapsulates the packet and sends the packet to the peer PE through the PW.
3. The peer PE removes the outer encapsulation to get the original PPP or HDLC packet, and then forwards the packet to the user network.
Control word
The control word field is between the MPLS label stack and the Layer 2 data. It carries control information for the Layer 2 frame, for example, the sequence number.
The control word feature has the following functions:
· Avoids fragment disorder. In multipath forwarding, fragments received might be disordered. The control word feature reorders the fragments according to the sequence number carried in the control word field.
· Transfers specific Layer 2 frame flags, such as the FECN bit and BECN bit of Frame Relay.
· Identifies the original payload length for packets that include padding.
When the PW data encapsulation type is FR DLCI, packets on the PW always carry the control word field, and the control word feature cannot be disabled.
When the PW data encapsulation type is Ethernet or VLAN, the control word field is optional. You can configure whether to carry the control word field in packets sent on the PW. If you enable the control word feature on both PEs, packets transmitted on the PW carry the control word field. Otherwise, the packets do not carry the control word field.
MPLS L2VPN interworking
CEs might connect to PEs through various types of links, such as FR, HDLC, Ethernet, and PPP. MPLS L2VPN interworking connects such CEs and allow them to communicate.
MPLS L2VPN supports Ethernet interworking and IP interworking modes. The device only supports IP interworking. Only local MPLS L2VPN connections, static PWs, LDP PWs, and remote CCC connections support the interworking feature.
Figure 4 Ethernet to PPP interworking
As shown in Figure 4, a packet in an MPLS L2VPN interworking scenario is forwarded as follows:
1. CE 1 sends an Ethernet frame destined for CE 2 to PE 1.
2. PE 1 checks whether the packet encapsulated in the received Ethernet frame is an IP packet.
¡ If yes, PE 1 removes the Ethernet header, adds PW label V and tunnel label T to the IP packet, and forwards the packet to PE 2 through the tunnel.
¡ If not, PE 1 drops the frame.
3. PE 2 obtains the output interface according to the PW label V in the received packet, removes the PW label, adds an PPP header, and forwards the PPP frame through the output interface to CE 2.
In an MPLS L2VPN interworking scenario, link layer negotiation packets cannot be delivered on the backbone network. Therefore, Layer 2 connections cannot be established between CEs. CEs must establish Layer 2 connections with the PEs. For example, CE 2 and PE 2 must perform PPP negotiation to establish a PPP connection.
PW redundancy
PW redundancy provides redundant links between PEs so that the customer networks can communicate when the path over one PW fails. As shown in Figure 5, PE 1 establishes two PWs (one primary and one backup). The CEs communicate through the primary PW. When the primary PW fails, PE 1 brings up the backup PW and forwards packets from CE 1 to CE 2 through the backup PW. When CE 2 receives the packets, it updates its MAC address table, so that packets from CE 2 to CE 1 also travel through the backup PW. Only static PWs and LDP PWs support PW redundancy.
The MPLS L2VPN determines whether the primary PW fails according to the LDP session status or the BFD result. The backup PW is used when one of the following conditions exists:
· The public tunnel of the primary PW is deleted, or BFD detects that the public tunnel has failed.
· The primary PW is deleted because the LDP session between PEs goes down, or BFD detects that the primary PW has failed.
· A manual PW switchover is performed.
Multi-segment PW
A multi-segment PW includes multiple concatenated static or LDP PWs. Creating two PWs for a cross-connect on a PE can concatenate the two PWs. Upon receiving a packet from one PW, the PE removes the tunnel ID and PW label of the packet, adds the PW label of the other PW, and forwards the packet over the public tunnel. Only static and LDP PWs can form a multi-segment PW.
As shown in Figure 6, to create a multi-segment PW between PE 1 and PE 4, you can concatenate PW 1 and PW 2 on PE 2, and PW 2 and PW 3 on PE 3.
Multi-segment PWs include intra-domain multi-segment PWs and inter-domain multi-segment PWs.
Intra-domain multi-segment PW
An intra-domain multi-segment PW has concatenated PWs within an AS. You can create an intra-domain multi-segment PW between two PEs that have no public tunnel to each other.
As shown in Figure 7, there is no public tunnel between PE 1 and PE 4. There is a public tunnel between PE 1 and PE 2 and a public tunnel between PE 2 and PE 4. To create an intra-domain multi-segment PW between PE 1 and PE 4, you can perform the following operations:
1. Create a PW between PE 1 and PE 2 (PW 1) and a PW between PE 2 and PE 4 (PW 2).
2. Concatenate the two PWs on PE 2.
Intra-domain multi-segment PWs can fully use existing public tunnels to reduce end-to-end public tunnels.
Figure 7 Intra-domain multi-segment PW
Inter-domain multi-segment PW
An inter-domain multi-segment PW has concatenated PWs in different ASs, and is a method for inter-AS option B networking.
As shown in Figure 8, to create an inter-domain multi-segment PW between PE 1 and PE 2 in different ASs, you can perform the following operations:
· Concatenate PW 1 and PW 2 on ASBR 1.
· Concatenate PW 2 and PW 3 on ASBR 2.
Figure 8 Inter-domain multi-segment PW
VCCV
Virtual Circuit Connectivity Verification (VCCV) is an OAM feature for L2VPN. It verifies the connectivity of PWs on the data plane. VCCV includes the following modes:
· Manual mode—Use the ping mpls pw command to manually test the connectivity of a PW.
· Auto mode—Configure BFD or Raw BFD to automatically test the connectivity of a PW.
For more information about VCCV, see "Configuring MPLS OAM."
To establish an MPLS L2VPN, you must perform the following tasks:
1. Configure an IGP to achieve IP connectivity within the backbone.
2. Configure basic MPLS, GRE, MPLS TE, or LDP to set up public tunnels across the backbone.
3. Configure MPLS L2VPN on the PEs, including setting up PWs, and binding ACs to PWs.
This chapter only describes MPLS L2VPN configurations on the PEs.
MPLS L2VPN configurations vary by scenario:
· Remote connection—To create a remote connection, configure an AC, configure a PW in cross-connect view or auto-discovery cross-connect view, and bind the AC to the PW in cross-connect view or auto-discovery cross-connect view.
· Local connection—To create a local connection, configure two ACs and bind the two ACs in cross-connect view.
· Multi-segment PW—To create a multi-segment PW, configure two PWs and bind the two PWs in cross-connect view.
To configure MPLS L2VPN on a PE:
Tasks at a glance |
Remarks |
(Required.) Enabling L2VPN |
N/A |
(Required.) Configuring an AC |
For multi-segment PWs, skip this task. |
(Required.) Configuring a cross-connect |
N/A |
· (Optional.) Configuring a PW class · (Required.) Choose either of the following tasks to configure a PW: |
Choose a PW configuration method depending on the MPLS L2VPN implementation. Skip these tasks for local connection configuration. |
(Required.) Binding an AC to a cross-connect |
(Optional.) Configuring PW redundancy: |
Choose either task to configure PW redundancy. |
(Optional.) Configuring interworking for a cross-connect |
N/A |
(Optional.) Enabling SNMP notifications for L2VPN PW |
N/A |
Enabling L2VPN
Before you enable L2VPN, perform the following tasks:
· Configure an LSR ID for the PE with the mpls lsr-id command.
· Enable MPLS with the mpls enable command on the core-facing interface of the PE.
To enable L2VPN:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable L2VPN. |
l2vpn enable |
By default, L2VPN is disabled. |
Configuring an AC
An AC can be a Layer 3 interface or subinterface.
To create a Layer 2 link between a PE and CE, configure the Layer 3 interface that connects the PE to the CE.
The PE forwards packets received from a Layer 3 interface through the bound PW without network layer processing. Therefore, the Layer 3 interface does not need an IP address.
Configuring the interface with Ethernet or VLAN encapsulation
On a Layer 3 Ethernet interface (including Layer 3 Ethernet interface and VE-L2VPN interface), both the default PW data encapsulation type and default access mode are Ethernet. On a Layer 3 Ethernet subinterface, both the default PW data encapsulation type and default access mode are VLAN.
The PW data encapsulation type and AC access mode determine how the VLAN tag is processed by a PE. Therefore, the PW data encapsulation types and AC access modes on the local PE and the peer PE must match.
To configure the interface with Ethernet or VLAN encapsulation:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. (Optional.) Specify the default next hop IP address or MAC address. |
default-nexthop { ip ip-address | mac { mac-address | broadcast } } |
Required for MPLS L2VPN interworking. By default, no default next hop is specified. |
Configuring the interface with PPP encapsulation
Step |
Command |
Remarks |
system-view |
N/A |
interface { serial | pos } number |
N/A |
3. Configure the link layer protocol. |
link-protocol ppp |
By default, the link layer protocol is PPP. |
4. (Optional.) Configure IPCP negotiation without an IP address or specify the IPCP proxy IP address. |
· To configure IPCP negotiation without an IP
address: · To specify the IPCP proxy IP address: |
By default, IPCP negotiation without an IP address is not supported and no IPCP proxy address is specified. |
Configuring the interface with HDLC encapsulation
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
link-protocol hdlc |
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a cross-connect group and enter cross-connect group view. |
xconnect-group group-name |
By default, no cross-connect groups exist. |
3. (Optional.) Configure a description for the cross-connect group. |
description text |
By default, no description is configured for the cross-connect group. |
4. (Optional.) Enable the cross-connect group. |
undo shutdown |
By default, the cross-connect group is enabled. |
5. Create a cross-connect and enter cross-connect view. |
connection connection-name |
By default, no cross-connects exist. |
6. Set an MTU for the PW. |
mtu size |
The default MTU is 1500 bytes. The two PEs on an LDP PW must have the same MTU configured for the PW. Otherwise, the PW cannot come up. |
Configuring a PW
You can configure PW attributes such as the PW data encapsulation type and enable control word in a PW class. PWs with the same attributes can use the same PW class.
To configure a PW class:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a PW class and enter PW class view. |
pw-class class-name |
By default, no PW classes exist. |
3. (Optional.) Enable control word. |
control-word enable |
By default, control word is disabled. |
4. (Optional.) Specify the PW data encapsulation type. |
pw-type { ethernet | vlan } |
By default, the PW data encapsulation type is VLAN. |
5. (Optional.) Enable sequencing for both incoming and outgoing packets on the PW. |
sequencing both |
By default, sequencing is disabled. |
Configuring a static PW
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter cross-connect group view. |
N/A |
3. Enter cross-connect view. |
N/A |
4. Configure a static PW, and enter cross-connect PW view. |
peer ip-address pw-id pw-id in-label label-value out-label label-value [ pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no static PWs exist. |
5. Set the expected bandwidth for the PW. |
bandwidth bandwidth-value |
By default, the expected value is 10000000 kbps. |
Configuring an LDP PW
Before you configure an LDP PW, enable global and interface MPLS LDP on the PE. For information about MPLS LDP configuration, see "Configuring LDP."
To configure an LDP PW:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
4. Configure an LDP PW, and enter cross-connect PW view. |
peer ip-address pw-id pw-id [ pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no LDP PWs exist. After an LDP PW is created, the PE automatically sends a targeted hello to create an LDP session to the peer PE. Then, the PE exchanges the PW ID FEC and PW label mapping with the peer. |
By default, the expected bandwidth is 10000000 kbps. |
Configuring a BGP PW
To configure a BGP PW, perform the following configurations on PEs:
· Configure BGP to advertise MPLS L2VPN label block information.
· Create a BGP PW.
Configuring BGP to advertise MPLS L2VPN label block information
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable BGP instance and enter BGP instance view. |
bgp as-number [ instance instance-name ] |
By default, BGP is disabled. |
3. Configure the remote PE as a BGP peer. |
peer { group-name | ip-address [ mask-length ] } as-number as-number |
By default, no BGP peers exist. |
4. Create the BGP L2VPN address family and enter BGP L2VPN address family view. |
address-family l2vpn |
By default, no BGP L2VPN address family exists. |
5. Enable BGP to exchange BGP L2VPN information with the specified peer or peer group. |
peer { group-name | ip-address [ mask-length ] } enable |
By default, BGP cannot exchange BGP L2VPN information with any peer or peer group. |
6. Enable BGP to exchange label block information with the specified peer or peer group. |
peer { group-name | ip-address [ mask-length ] } signaling [ non-standard ] |
By default, BGP can exchange label block information with a BGP L2VPN peer or peer group by using RFC 4761 MP_REACH_NLRI. |
7. (Optional.) Permit the local AS number to appear in routes from the specified peer or peer group and specify the appearance times. |
peer { group-name | ip-address [ mask-length ] } allow-as-loop [ number ] |
By default, the local AS number is not allowed in routes from a peer or peer group. |
8. (Optional.) Enable route target-based filtering of incoming BGP L2VPN information. |
policy vpn-target |
By default, route target-based filtering of incoming BGP L2VPN information is enabled. |
9. (Optional.) Configure the router as a route reflector and specify a peer or peer group as its client. |
peer { group-name | ip-address [ mask-length ] } reflect-client |
By default, no route reflector or client is configured. |
10. (Optional.) Enable L2VPN information reflection between clients. |
reflect between-clients |
By default, L2VPN information reflection is enabled between clients. |
11. (Optional.) Configure the cluster ID of the route reflector. |
reflector cluster-id { cluster-id | ip-address } |
By default, a route reflector uses its own router ID as the cluster ID. |
12. (Optional.) Configure the filtering of reflected L2VPN information. |
rr-filter ext-comm-list-number |
By default, the route reflector does not filter reflected L2VPN information. |
13. (Optional.) Return to user view. |
return |
N/A |
14. (Optional.) Soft-reset L2VPN BGP sessions. |
refresh bgp [ instance instance-name ] { ip-address [ mask-length ] | all | external | group group-name | internal } { export | import } l2vpn |
N/A |
15. (Optional.) Reset L2VPN BGP sessions. |
reset bgp [ instance instance-name ] { as-number | ip-address [ mask-length ] | all | external | group group-name | internal } l2vpn |
N/A |
For more information about the peer as-number, peer enable, peer allow-as-loop, peer reflect-client, reflect between-clients, reflector cluster-id, refresh bgp l2vpn, and reset bgp l2vpn commands, see Layer 3—IP Routing Command Reference.
Creating a BGP PW
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the cross-connect group to automatically discover neighbors and create PWs through BGP and enter auto-discovery cross-connect group view. |
auto-discovery bgp |
By default, a cross-connect group does not automatically discover neighbors or create PWs through BGP. |
4. Configure an RD for the cross-connect group. |
route-distinguisher route-distinguisher |
By default, no RD is configured for the cross-connect group. |
5. Configure route targets for the cross-connect group. |
vpn-target vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ] |
By default, no route targets are configured for the cross-connect group. |
6. (Optional.) Specify a PW class for the auto-discovery cross-connect group. |
By default, no PW class is specified. |
7. (Optional.) Set an MTU for the PW. |
mtu size |
The default MTU is 1500 bytes. |
8. Create a local site and enter site view. |
site site-id [ range range-value ] [ default-offset default-offset ] |
By default, no local sites exist. |
9. Create a cross-connect and enter auto-discovery cross-connect view. |
connection remote-site-id remote-site-id |
By default, no cross-connects exist. After you execute this command, a PW to the specified remote site is created and is bound to the cross-connect. |
10. (Optional.) Specify a tunnel policy for the auto-discovery cross-connect. |
tunnel-policy tunnel-policy-name |
By default, no tunnel policy is specified. |
To configure a remote CCC connection, perform the following configurations on the PE and P devices:
· On the two PEs, use the ccc command to specify the incoming and outgoing labels.
· On each P device between the two PEs, use the static-lsp transit command to configure a static LSP for each direction of the CCC connection. For more information about the static-lsp transit command, see MPLS Command Reference.
Follow these guidelines when you configure a remote CCC connection:
· The outgoing label specified on a device must be the same as the incoming label specified on the next-hop device.
· CCC connection settings such as the encapsulation type and control word feature must be consistent on the two PEs. Otherwise, the PEs might fail to forward packets over the CCC connection.
To configure a remote CCC connection:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
4. Create a remote CCC connection. |
ccc in-label in-label-value out-label out-label-value { nexthop nexthop | out-interface interface-type interface-number } [ pw-class class-name ] |
By default, no remote CCC connections exist. Use the out-interface keyword to specify the outgoing interface only on a point-to-point link. On other types of interfaces such as Layer 3 Ethernet interface, VLAN interface, and Layer 3 aggregate interface, you must use the nexthop keyword to specify the IP address of the next hop. |
This task is mutually exclusive with Ethernet link aggregation. If a Layer 3 Ethernet interface has been added to a link aggregation group, you cannot bind the Layer 3 interface to a cross-connect, and vice versa.
When you bind an AC to a cross-connect, you can associate Track with the AC. Then, the AC is up only when one or more of the associated track entries are positive.
Associating Track with an AC helps detecting AC failure. For example, when an AC is a VE-L2VPN interface, the interface will not go down upon a link failure because the interface is a virtual interface. To resolve the problem, you can associate Track with the AC to detect failures on the link that connects the PE-agg to the L3VPN or IP backbone. When a failure occurs on the link, the VE-L2VPN interface is set to down. Consequently, the PW bound to the AC goes down. If the PW has a backup PW, traffic can be switched to the backup PW. For more information about VE-L2VPN interfaces and L2VPN access to L3VPN or IP backbone, see "Configuring L2VPN access to L3VPN or IP backbone."
After you bind a Layer 3 interface to a cross-connect, packets received from the Layer 3 interface are forwarded through the PW or another AC bound to the cross-connect.
To bind a Layer 3 interface to a non-BGP cross-connect:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
4. Bind the Layer 3 interface to the cross-connect. |
ac interface interface-type interface-number [ track track-entry-number&<1-3> ] |
By default, no Layer 3 interface is bound to the cross-connect. |
To bind a Layer 3 interface to a BGP cross-connect:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enter auto-discovery cross-connect group view. |
N/A |
4. Enter site view. |
site site-id [ range range-value ] [ default-offset default-offset-value ] |
N/A |
5. Enter auto-discovery cross-connect view. |
N/A |
6. Bind the Layer 3 interface to the BGP cross-connect. |
By default, no Layer 3 interface is bound to the BGP cross-connect. |
This task includes the following configurations:
· Create a backup PW for the primary PW.
· Specify whether to switch traffic from the backup PW to the primary PW when the primary PW recovers, and specify the wait time for the switchover.
· Manually perform a PW switchover.
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
4. (Optional.) Specify the switchover mode and set the wait time for the switchover. |
revertive { wtr wtr-time | never } |
By default, the switchover mode is revertive and the switchover wait time is 0 seconds. |
5. Configure the dual receive feature for PW redundancy. |
protection dual-receive |
By default, the dual receive feature is disabled. When the primary PW is normal, the backup PW does not send or receive packets. |
6. Enter cross-connect PW view. |
peer ip-address pw-id pw-id [ in-label label-value out-label label-value ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] * |
N/A |
7. Configure a backup cross-connect PW and enter backup cross-connect PW view. |
backup-peer ip-address pw-id pw-id in-label label-value out-label label-value [ pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no backup PW exists. |
8. Return to user view. |
return |
N/A |
9. Manually perform a PW switchover. |
l2vpn switchover peer ip-address pw-id pw-id |
N/A |
Configuring LDP PW redundancy
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
N/A |
7. Configure a backup LDP PW and enter backup cross-connect PW view. |
backup-peer ip-address pw-id pw-id [ pw-class class-name | tunnel-policy tunnel-policy-name ] * |
By default, no backup LDP PW exists. |
return |
N/A |
9. Manually switch traffic to the backup PW of the specified PW. |
N/A |
Interworking enables a PW to connect ACs that have different link types, including FR, HDLC, Ethernet, and PPP. In an IPv4 interworking scenario, a PE extracts IPv4 packets from frames received from the AC and sends the packets to the peer PE through the PW. The peer PE uses the link protocol of the connected AC to encapsulate the IPv4 packets, and sends the packets through the AC. This method hides the link types of ACs at the two ends.
To configure MPLS L2VPN interworking, follow these restrictions and guidelines:
· When a CE is connected to a PE through an Ethernet or VLAN link:
¡ On the Ethernet network or in the VLAN, the CE and PE must be the only Layer 3 network devices.
¡ On the PE's interface connected to the CE, use the default-nexthop command to configure the default next hop address. This allows the PE to correctly encapsulate a link layer header for packets destined for the CE.
- If you specify the unicast MAC address (the MAC address of the CE) or a broadcast MAC address as the default next hop, the PE uses the MAC address as the destination address of the outgoing packets.
- If you specify the IP address of the CE as the default next hop, the PE resolves the IP address to a MAC address through gratuitous ARP, and then uses the resolved MAC address as the destination MAC address of the outgoing packets.
¡ After you enable interworking for a cross-connect, the PE responds to all ARP requests from the CE with its own MAC address. After you disable interworking on the PE, you must use the reset arp command to clear the ARP entries on the CE before the CE can learn new ARP entries.
· When a CE is connected to a PE through a PPP link:
If the PE's interface connected to the CE has an IP address, the IPCP negotiation is performed.
If the interface does not have an IP address, perform one of the following operations:
¡ Use the ppp ipcp ignore local-ip command to configure the PE to support IPCP negotiation without an IP address.
¡ Use the ppp ipcp proxy command to specify the IP address for IPCP negotiation with the CE.
To configure interworking for a cross-connect:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
4. Enable interworking for the cross-connect. |
interworking ipv4 |
By default, interworking is disabled for a cross-connect. |
This feature enables L2VPN to generate SNMP notifications when PW deletions, PW switchovers, or PW status changes occur. For L2VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
To enable SNMP notifications for L2VPN PW:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable SNMP notifications for L2VPN PW. |
snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] * |
By default, SNMP notifications for L2VPN PW are disabled. |
Task |
Command |
Display LDP PW label information. |
display l2vpn ldp [ peer ip-address [ pw-id pw-id ] | xconnect-group group-name ] [ verbose ] |
Display cross-connect forwarding information (in standalone mode). |
display l2vpn forwarding { ac | pw } [ xconnect-group group-name ] [ slot slot-number ] [ verbose ] |
Display cross-connect forwarding information (in IRF mode). |
display l2vpn forwarding { ac | pw } [ xconnect-group group-name ] [ chassis chassis-number slot slot-number ] [ verbose ] |
Display L2VPN information for Layer 3 interfaces bound to cross-connects. |
display l2vpn interface [ xconnect-group group-name | interface-type interface-number ] [ verbose ] |
Display L2VPN PW information. |
display l2vpn pw [ xconnect-group group-name ] [ protocol { bgp | ldp | static } ] [ verbose ] |
Display PW class information. |
display l2vpn pw-class [ class-name ] |
Display cross-connect group information. |
display l2vpn xconnect-group [ name group-name ] [ verbose ] |
Display L2VPN label block information. |
display l2vpn bgp [ peer ip-address | local ] [ xconnect-group group-name ] [ verbose ] |
Display BGP L2VPN peer group information. |
display bgp [ instance instance-name ] group l2vpn [ group-name group-name ] |
Display L2VPN label block information discovered by BGP. |
display bgp [ instance instance-name ] l2vpn signaling [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset [ advertise-info ] ] ] | statistics ] |
Display BGP L2VPN peer information. |
display bgp [ instance instance-name ] peer l2vpn [ ip-address mask-length | group-name group-name log-info | ip-address { log-info | verbose } | verbose ] |
Display BGP L2VPN update group information. |
display bgp [ instance instance-name ] update-group l2vpn [ ip-address ] |
Reset BGP sessions for L2VPN. |
For more information about the display bgp group l2vpn, display bgp peer l2vpn, display bgp update-group l2vpn, and reset bgp l2vpn commands, see Layer 3—IP Routing Command Reference.
Network requirements
Configure local MPLS L2VPN connections between the PE and CEs to allow Layer 2 communication between CE 1 and CE 2.
Figure 9 Network diagram
Configuration procedure
1. Configure CE 1.
<CE1> system-view
[CE1] interface gigabitethernet 1/1/1
[CE1-GigabitEthernet1/1/1] ip address 100.1.1.1 24
[CE1-GigabitEthernet1/1/1] quit
2. Configure CE 2.
<CE2> system-view
[CE2] interface gigabitethernet 1/1/1
[CE2-GigabitEthernet1/1/1] ip address 100.1.1.2 24
[CE2-GigabitEthernet1/1/1] quit
3. Configure PE:
# Enable L2VPN.
<PE> system-view
[PE] l2vpn enable
# Create a cross-connect group named vpn1, create a cross-connect named vpn1 in the group, and bind GigabitEthernet 1/1/1 and GigabitEthernet 1/1/2 to the cross-connect.
[PE] xconnect-group vpn1
[PE-xcg-vpn1] connection vpn1
[PE-xcg-vpn1-vpn1] ac interface gigabitethernet 1/1/1
[PE-xcg-vpn1-vpn1] ac interface gigabitethernet 1/1/2
[PE-xcg-vpn1-vpn1] quit
# Verify that two AC forwarding entries exist on the PE.
[PE] display l2vpn forwarding ac
Total number of cross-connections: 1
Total number of ACs: 2
AC Xconnect-group Name Link ID
GE1/1/1 vpn1 0
GE1/1/2 vpn1 1
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
CE 1 and PE are connected through Ethernet interfaces. CE 2 and PE are connected through serial interfaces, and they use PPP as the link layer protocol.
Configure local MPLS L2VPN connections between the PE and CEs and enable interworking on the PE to allow communication between CE 1 and CE 2.
Figure 10 Network diagram
1. Configure CE 1.
<CE1> system-view
[CE1-GigabitEthernet1/1/1] ip address 10.1.1.1 24
2. Configure CE 2.
<CE2> system-view
[CE2] interface serial 1/1/0
[CE2-Serial1/1/0] link-protocol ppp
[CE2-Serial1/1/0] ip address 10.1.1.2 24
[CE2-Serial1/1/0] quit
3. Configure PE:
# Enable L2VPN.
<PE> system-view
[PE] l2vpn enable
# Configure the default next hop IP address as 10.1.1.1 on GigabitEthernet 1/1/1 (the interface connected to CE 1). This interface does not need an IP address.
[PE] interface gigabitethernet 1/1/1
[PE-GigabitEthernet1/1/1] default-nexthop ip 10.1.1.1
[PE-GigabitEthernet1/1/1] quit
# Configure the IPCP proxy IP address as the IP address of CE 1 on Serial 1/1/0 (the interface connected to CE 2). This interface does not need an IP address.
[PE] interface serial 1/1/0
[PE-Serial1/1/0] link-protocol ppp
[PE-Serial1/1/0] ppp ipcp proxy 10.1.1.1
[PE-Serial1/1/0] quit
# Create a cross-connect group named vpn1, create a cross-connect named vpn1 in the group, and enable interworking for the cross-connect.
[PE-xcg-vpn1-vpn1] interworking ipv4
# Bind GigabitEthernet 1/1/1 and Serial 1/1/0 to the cross-connect.
[PE-xcg-vpn1-vpn1] ac interface serial 1/1/0
[PE-xcg-vpn1] quit
GE1/1/1 vpn1 0
Ser1/1/0 vpn1 1
Create a static PW between PE 1 and PE 2 over the backbone to allow communication between CE 1 and CE 2.
Figure 11 Network diagram
Device |
IP address |
Device |
IP address |
CE 1 |
GE1/1/1 |
100.1.1.1/24 |
P |
Loop0 |
192.4.4.4/32 |
PE 1 |
Loop0 |
192.2.2.2/32 |
GE1/1/1 |
10.1.1.2/24 |
GE1/1/1 |
GE1/1/2 |
10.2.2.2/24 |
GE1/1/2 |
10.1.1.1/24 |
PE 2 |
Loop0 |
192.3.3.3/32 |
CE 2 |
GE1/1/1 |
100.1.1.2/24 |
GE1/1/1 |
GE1/1/2 |
10.2.2.1/24 |
1. Configure CE 1.
<CE1> system-view
2. Configure PE 1:
# Configure an LSR ID.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 192.2.2.2 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 192.2.2.2
# Enable L2VPN.
[PE1] l2vpn enable
# Enable global LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure GigabitEthernet 1/1/2 (the interface connected to the P device), and enable LDP on the interface.
[PE1] interface gigabitethernet 1/1/2
[PE1-GigabitEthernet1/1/2] ip address 10.1.1.1 24
[PE1-GigabitEthernet1/1/2] mpls enable
[PE1-GigabitEthernet1/1/2] mpls ldp enable
[PE1-GigabitEthernet1/1/2] quit
# Configure OSPF for LDP to create LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.1 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 192.2.2.2 0.0.0.0
[PE1-ospf-1] quit
# Create a cross-connect group named vpna, create a cross-connect named svc in the group, and bind GigabitEthernet 1/1/1 to the cross-connect.
[PE1] xconnect-group vpna
[PE1-xcg-vpna] connection svc
[PE1-xcg-vpna-svc] ac interface gigabitethernet 1/1/1
# Create a static PW for the cross-connect to bind the AC to the PW.
[PE1-xcg-vpna-svc] peer 192.3.3.3 pw-id 3 in-label 100 out-label 200
[PE1-xcg-vpna-svc-192.3.3.3-3] quit
[PE1-xcg-vpna-svc] quit
[PE1-xcg-vpna] quit
3. Configure the P device:
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 192.4.4.4 32
[P-LoopBack0] quit
[P] mpls lsr-id 192.4.4.4
[P] mpls ldp
[P-ldp] quit
# Configure GigabitEthernet 1/1/1 (the interface connected to PE 1), and enable LDP on the interface.
[P] interface gigabitethernet 1/1/1
[P-GigabitEthernet1/1/1] ip address 10.1.1.2 24
[P-GigabitEthernet1/1/1] mpls enable
[P-GigabitEthernet1/1/1] mpls ldp enable
[P-GigabitEthernet1/1/1] quit
# Configure GigabitEthernet 1/1/2 (the interface connected to PE 2), and enable LDP on the interface.
[P] interface gigabitethernet 1/1/2
[P-GigabitEthernet1/1/2] ip address 10.2.2.2 24
[P-GigabitEthernet1/1/2] mpls enable
[P-GigabitEthernet1/1/2] mpls ldp enable
[P-GigabitEthernet1/1/2] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.2 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.2.2.2 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 192.4.4.4 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
4. Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 192.3.3.3 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 192.3.3.3
# Enable L2VPN.
[PE2] l2vpn enable
# Enable globally LDP.
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface gigabitethernet 1/1/2
[PE2-GigabitEthernet1/1/2] ip address 10.2.2.1 24
[PE2-GigabitEthernet1/1/2] mpls enable
[PE2-GigabitEthernet1/1/2] mpls ldp enable
[PE2-GigabitEthernet1/1/2] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.2.2.1 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 192.3.3.3 0.0.0.0
[PE2-ospf-1] quit
[PE2] xconnect-group vpna
[PE2-xcg-vpna] connection svc
[PE2-xcg-vpna-svc] ac interface gigabitethernet 1/1/1
[PE2-xcg-vpna-svc] peer 192.2.2.2 pw-id 3 in-label 200 out-label 100
[PE2-xcg-vpna-svc-192.2.2.2-3] quit
[PE2-xcg-vpna-svc] quit
[PE2-xcg-vpna] quit
5. Configure CE 2.
<CE2> system-view
# Verify that a static PW has been established on PE 1.
[PE1] display l2vpn pw
Flags: M - main, B - backup, BY - bypass, H - hub link, S - spoke link, N - no split horizon
Total number of PWs: 1
1 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
Xconnect-group Name: vpna
Peer PW ID/Rmt Site In/Out Label Proto Flag Link ID State
192.3.3.3 3 100/200 Static M 0 Up
# Verify that a static PW has been established on PE 2.
[PE2] display l2vpn pw
192.2.2.2 3 200/100 Static M 0 Up
Create an LDP PW between PE 1 and PE 2 over the backbone to allow communication between CE 1 and CE 2.
Figure 12 Network diagram
Table 3 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
GE1/1/1 |
100.1.1.1/24 |
P |
Loop0 |
192.4.4.4/32 |
PE 1 |
Loop0 |
192.2.2.2/32 |
GE1/1/1 |
10.1.1.2/24 |
GE1/1/1 |
GE1/1/2 |
10.2.2.2/24 |
GE1/1/2 |
10.1.1.1/24 |
PE 2 |
Loop0 |
192.3.3.3/32 |
CE 2 |
GE1/1/1 |
100.1.1.2/24 |
GE1/1/1 |
GE1/1/2 |
10.2.2.1/24 |
1. Configure CE 1.
<CE1> system-view
2. Configure PE 1:
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Create a cross-connect group named vpna, create a cross-connect named ldp in the group, and bind GigabitEthernet 1/1/1 to the cross-connect.
[PE1-xcg-vpna] connection ldp
[PE1-xcg-vpna-ldp] ac interface gigabitethernet 1/1/1
# Create an LDP PW for the cross-connect to bind the AC to the PW.
[PE1-xcg-vpna-ldp] peer 192.3.3.3 pw-id 3
[PE1-xcg-vpna-ldp-192.3.3.3-3] quit
[PE1-xcg-vpna-ldp] quit
[PE1-xcg-vpna] quit
<P> system-view
[P-LoopBack0] quit
[P] mpls ldp
[P-ldp] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
4. Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.2.2.0 0.0.0.255
[PE2-ospf-1] quit
[PE2-xcg-vpna] connection ldp
[PE2-xcg-vpna-ldp] ac interface gigabitethernet 1/1/1
[PE2-xcg-vpna-ldp] peer 192.2.2.2 pw-id 3
[PE2-xcg-vpna-ldp-192.2.2.2-3] quit
[PE2-xcg-vpna-ldp] quit
[PE2-xcg-vpna] quit
5. Configure CE 2.
<CE2> system-view
# Verify that an LDP PW has been established on PE 1.
192.3.3.3 3 1279/1279 LDP M 1 Up
# Verify that an LDP PW has been established on PE 2.
192.2.2.2 3 1279/1279 LDP M 1 Up
CE 1 and PE 1 are connected through Ethernet interfaces. CE 2 and PE 2 are connected through serial interfaces, and they use PPP as the link layer protocol.
Configure an LDP PW between PE 1 and PE 2 and enable interworking on PEs to allow communication between CE 1 and CE 2.
Figure 13 Network diagram
Table 4 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
GE1/1/1 |
100.1.1.1/24 |
P |
Loop0 |
192.4.4.4/32 |
PE 1 |
Loop0 |
192.2.2.2/32 |
GE1/1/1 |
10.1.1.2/24 |
GE1/1/1 |
GE1/1/2 |
10.2.2.2/24 |
GE1/1/2 |
10.1.1.1/24 |
PE 2 |
Loop0 |
192.3.3.3/32 |
CE 2 |
Ser1/1/0 |
100.1.1.2/24 |
Ser1/1/0 |
GE1/1/1 |
10.2.2.1/24 |
1. Configure CE 1.
<CE1> system-view
2. Configure PE 1:
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Configure the default next hop IP address as 100.1.1.1 on GigabitEthernet 1/1/1 (the interface connected to CE 1. This interface does not need an IP address.
[PE1] interface gigabitethernet 1/1/1
[PE1-GigabitEthernet1/1/1] default-nexthop ip 100.1.1.1
[PE1-GigabitEthernet1/1/1] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Create a cross-connect group named vpna, create a cross-connect named ldp in the group, enable interworking for the cross-connect, and bind GigabitEthernet 1/1/1 to the cross-connect.
[PE1-xcg-vpna-ldp] interworking ipv4
[PE1-xcg-vpna] quit
<P> system-view
[P-LoopBack0] quit
[P] mpls ldp
[P-ldp] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
4. Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
# Configure GigabitEthernet 1/1/1 (the interface connected to the P device), and enable LDP on the interface.
[PE2] interface gigabitethernet 1/1/1
[PE2-GigabitEthernet1/1/1] ip address 10.2.2.1 24
[PE2-GigabitEthernet1/1/1] mpls enable
[PE2-GigabitEthernet1/1/1] mpls ldp enable
[PE2-GigabitEthernet1/1/1] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
[PE2] interface serial 1/1/0
[PE2-Serial1/1/0] link-protocol ppp
[PE2-Serial1/1/0] ppp ipcp proxy 100.1.1.1
[PE2-Serial1/1/0] quit
# Create a cross-connect group named vpna, create a cross-connect named ldp in the group, enable interworking for the cross-connect, and bind Serial 1/1/0 to the cross-connect.
[PE2-xcg-vpna-ldp] interworking ipv4
[PE2-xcg-vpna-ldp] ac interface serial 1/1/0
[PE2-xcg-vpna] quit
5. Configure CE 2.
<CE2> system-view
[CE2-Serial1/1/0] ip address 100.1.1.2 24
Create a BGP PW between PE 1 and PE 2 to allow communication between CE 1 and CE 2.
Figure 14 Network diagram
Table 5 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
GE1/1/1 |
100.1.1.1/24 |
P |
Loop0 |
192.4.4.4/32 |
PE 1 |
Loop0 |
192.2.2.2/32 |
GE1/1/1 |
10.1.1.2/24 |
GE1/1/1 |
GE1/1/2 |
10.2.2.2/24 |
GE1/1/2 |
10.1.1.1/24 |
PE 2 |
Loop0 |
192.3.3.3/32 |
CE 2 |
GE1/1/1 |
100.1.1.2/24 |
GE1/1/1 |
GE1/1/2 |
10.2.2.1/24 |
1. Configure CE 1.
<CE1> system-view
2. Configure PE 1:
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Create an IBGP connection to PE 2, and enable BGP to advertise L2VPN information to PE 2.
[PE1] bgp 100
[PE1-bgp-default] peer 192.3.3.3 as-number 100
[PE1-bgp-default] peer 192.3.3.3 connect-interface loopback 0
[PE1-bgp-default] address-family l2vpn
[PE1-bgp-default-l2vpn] peer 192.3.3.3 enable
[PE1-bgp-default-l2vpn] quit
[PE1-bgp-default] quit
# Create a cross-connect group named vpnb, create a local site named site 1, and create a BGP PW from site 1 to the remote site site 2.
[PE1] xconnect-group vpnb
[PE1-xcg-vpnb] auto-discovery bgp
[PE1-xcg-vpnb-auto] route-distinguisher 2:2
[PE1-xcg-vpnb-auto] vpn-target 2:2 export-extcommunity
[PE1-xcg-vpnb-auto] vpn-target 2:2 import-extcommunity
[PE1-xcg-vpnb-auto] site 1 range 10 default-offset 0
[PE1-xcg-vpnb-auto-1] connection remote-site-id 2
# Bind GigabitEthernet 1/1/1 to the PW.
[PE1-xcg-vpnb-auto-1-2] ac interface gigabitethernet 1/1/1
[PE1-xcg-vpnb-auto-1-2] return
<P> system-view
[P-LoopBack0] quit
[P] mpls ldp
[P-ldp] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
4. Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Create an IBGP connection to PE 1, and enable BGP to advertise L2VPN information to PE 1.
[PE2] bgp 100
[PE2-bgp-default] peer 192.2.2.2 as-number 100
[PE2-bgp-default] peer 192.2.2.2 connect-interface loopback 0
[PE2-bgp-default] address-family l2vpn
[PE2-bgp-default-l2vpn] peer 192.2.2.2 enable
[PE2-bgp-default-l2vpn] quit
[PE2-bgp-default] quit
# Create a cross-connect group named vpnb, create a local site named site 2, and create a BGP PW from site 2 to the remote site site 1.
[PE2] xconnect-group vpnb
[PE2-xcg-vpnb] auto-discovery bgp
[PE2-xcg-vpnb-auto] route-distinguisher 2:2
[PE2-xcg-vpnb-auto] vpn-target 2:2 export-extcommunity
[PE2-xcg-vpnb-auto] vpn-target 2:2 import-extcommunity
[PE2-xcg-vpnb-auto] site 2 range 10 default-offset 0
[PE2-xcg-vpnb-auto-2] connection remote-site-id 1
[PE2-xcg-vpnb-auto-2-1] ac interface gigabitethernet 1/1/1
[PE2-xcg-vpnb-auto-2-1] return
5. Configure CE 2.
<CE2> system-view
# Verify that a BGP PW has been established on PE 1.
<PE1> display l2vpn pw
Xconnect-group Name: vpnb
192.3.3.3 2 1036/1025 BGP M 1 Up
# Verify that a BGP PW has been established on PE 2.
<PE2> display l2vpn pw
192.2.2.2 1 1025/1036 BGP M 1 Up
Create a remote CCC connection between PE 1 and PE 2 to allow communication between CE 1 and CE 2.
Figure 15 Network diagram
Device |
IP address |
Device |
IP address |
CE 1 |
GE1/1/1 |
100.1.1.1/24 |
P |
Loop0 |
192.4.4.4/32 |
PE 1 |
Loop0 |
192.2.2.2/32 |
GE1/1/1 |
10.1.1.2/24 |
GE1/1/1 |
GE1/1/2 |
10.2.2.2/24 |
GE1/1/2 |
10.1.1.1/24 |
PE 2 |
Loop0 |
192.3.3.3/32 |
CE 2 |
GE1/1/1 |
100.1.1.2/24 |
GE1/1/1 |
GE1/1/2 |
10.2.2.1/24 |
1. Configure CE 1.
<CE1> system-view
2. Configure PE 1:
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
# Configure GigabitEthernet 1/1/2 (the interface connected to the P device), and enable MPLS on the interface.
# Configure OSPF.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Create a cross-connect group named ccc, and create a remote CCC connection that has incoming label 101, outgoing label 201, and next hop 10.1.1.2.
[PE1] xconnect-group ccc
[PE1-xcg-ccc] connection ccc
[PE1-xcg-ccc-ccc] ccc in-label 101 out-label 201 nexthop 10.1.1.2
# Bind GigabitEthernet 1/1/1 to the CCC connection.
[PE1-xcg-ccc-ccc] ac interface gigabitethernet 1/1/1
[PE1-xcg-ccc-ccc] quit
[PE1-xcg-ccc] quit
<P> system-view
[P-LoopBack0] quit
# Configure GigabitEthernet 1/1/1 (the interface connected to PE 1), and enable MPLS on the interface.
# Configure GigabitEthernet 1/1/2 (the interface connected to PE 2), and enable MPLS on the interface.
# Configure a static LSP to forward packets from PE 1 to PE 2.
[P] static-lsp transit pe1-pe2 in-label 201 nexthop 10.2.2.1 out-label 202
# Configure a static LSP to forward packets from PE 2 to PE 1.
[P] static-lsp transit pe2-pe1 in-label 102 nexthop 10.1.1.1 out-label 101
# Configure OSPF.
[P] ospf
[P-ospf-1] area 0
[PE1-ospf-1] quit
4. Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
# Configure OSPF.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Create a cross-connect group named ccc, and create a remote CCC connection that has incoming label 202, outgoing label 102, and next hop 10.2.2.2.
[PE2] xconnect-group ccc
[PE2-xcg-ccc] connection ccc
[PE2-xcg-ccc-ccc] ccc in-label 202 out-label 102 nexthop 10.2.2.2
[PE2-xcg-ccc-ccc] ac interface gigabitethernet 1/1/1
[PE2-xcg-ccc-ccc] quit
[PE2-xcg-ccc] quit
5. Configure CE 2.
<CE2> system-view
# Verify that a remote CCC connection (identified by PW ID/Rmt Site "-" and Proto Static) has been established on PE 1.
Xconnect-group Name: ccc
10.1.1.2 - 101/201 Static M 0 Up
# Verify that a remote CCC connection has been established on PE 2.
10.2.2.2 - 202/102 Static M 0 Up
As shown in Figure 16, there is no public tunnel between PE 1 and PE 2. There is an MPLS TE tunnel between PE 1 and P, and an MPLS TE tunnel between P and PE 2.
Configure a multi-segment PW within the backbone to allow communication between CE 1 and CE 2. The multi-segment PW includes an LDP PW between PE 1 and P, and a static PW between P and PE 2. The two PWs are concatenated on P.
Table 7 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
GE1/1/1 |
100.1.1.1/24 |
P |
Loop0 |
192.4.4.4/32 |
PE 1 |
Loop0 |
192.2.2.2/32 |
GE1/1/1 |
23.1.1.2/24 |
GE1/1/2 |
23.1.1.1/24 |
GE1/1/2 |
26.2.2.2/24 |
CE 2 |
GE1/1/1 |
100.1.1.2/24 |
PE 2 |
Loop0 |
192.3.3.3/32 |
GE1/1/2 |
26.2.2.1/24 |
1. Configure CE 1.
<CE1> system-view
2. Configure PE 1:
<PE1> system-view
# Enable L2VPN.
[PE1] l2vpn enable
# Enable LDP globally.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure MPLS TE to establish an MPLS TE tunnel between PE 1 and P. For more information, see "Configuring MPLS TE."
# Create a cross-connect group named vpn1, create a cross-connect named ldp in the group, and bind GigabitEthernet 1/1/1 to the cross-connect.
[PE1] xconnect-group vpn1
[PE1-xcg-vpn1] connection ldp
[PE1-xcg-vpn1-ldp] ac interface gigabitethernet 1/1/1
[PE1-xcg-vpn1-ldp] peer 192.4.4.4 pw-id 1000
[PE1-xcg-vpn1-ldp-192.4.4.4-1000] quit
[PE1-xcg-vpn1-ldp] quit
[PE1-xcg-vpn1] quit
<P> system-view
[P-LoopBack0] quit
# Enable L2VPN.
[P] l2vpn enable
[P] mpls ldp
[P-ldp] quit
# Create a PW class named pwa, and configure the PW data encapsulation type as ethernet.
[P] pw-class pwa
[P-pw-pwa] pw-type ethernet
[P-pw-pwa] quit
# Configure MPLS TE to establish an MPLS TE tunnel between PE 1 and P, and between P and PE 2. For more information, see "Configuring MPLS TE."
# Create a cross-connect group named vpn1, create a cross-connect named ldpsvc in the group, and create an LDP PW and a static PW for the cross-connect to form a multi-segment PW.
[P] xconnect-group vpn1
[P-xcg-vpn1] connection ldpsvc
[P-xcg-vpn1-ldpsvc] peer 192.2.2.2 pw-id 1000 pw-class pwa
[P-xcg-vpn1-ldpsvc-192.2.2.2-1000] quit
[P-xcg-vpn1-ldpsvc] peer 192.3.3.3 pw-id 1000 in-label 100 out-label 200 pw-class pwa
[P-xcg-vpn1-ldpsvc-192.3.3.3-1000] quit
[P-xcg-vpn1-ldpsvc] quit
[P-xcg-vpn1] quit
4. Configure PE 2:
<PE2> system-view
# Enable L2VPN.
[PE2] l2vpn enable
# Configure MPLS TE to establish an MPLS TE tunnel between P and PE 2. For more information, see "Configuring MPLS TE."
# Create a cross-connect group named vpn1, create a cross-connect named svc in the group, and bind GigabitEthernet 1/1/1 to the cross-connect.
[PE2] xconnect-group vpn1
[PE2-xcg-vpn1] connection svc
[PE2-xcg-vpn1-svc] ac interface gigabitethernet 1/1/1
[PE2-xcg-vpn1-svc] peer 192.4.4.4 pw-id 1000 in-label 200 out-label 100
[PE2-xcg-vpn1-svc-192.4.4.4-1000] quit
[PE2-xcg-vpn1-svc] quit
[PE2-xcg-vpn1] quit
5. Configure CE 2.
<CE2> system-view
# Verify that two PWs have been created to form a multi-segment PW on the P device.
[P] display l2vpn pw
Total number of PWs: 2
2 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
Xconnect-group Name: vpn1
192.2.2.2 1000 1279/1150 LDP M 0 Up
192.3.3.3 1000 100/200 Static M 1 Up
# Verify that a PW has been created on PE 1.
192.4.4.4 1000 1150/1279 LDP M 1 Up
# Verify that a PW has been created on PE 2.
192.4.4.4 1000 200/100 Static M 1 Up
PE 1 and ASBR 1 belong to AS 100. PE 2 and ASBR 2 belong to AS 200.
Set up an inter-domain multi-segment PW (a method for inter-AS Option B networking) within the backbone to allow communication between CE 1 and CE 2.
Configure the inter-domain multi-segment PW as follows:
· Configure LDP PWs between PE 1 and ASBR 1, and between PE 2 and ASBR 2, and configure public tunnels through LDP to carry the PWs.
· Configure an LDP PW between ASBR 1 and ASBR 2. Advertise labeled IPv4 routes between ASBR 1 and ASBR 2 through BGP to set up the public tunnel to carry the LDP PW.
· Concatenate the two PWs on ASBR 1.
· Concatenate the two PWs on ASBR 2.
Figure 17 Network diagram
Table 8 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
GE1/1/1 |
100.1.1.1/24 |
ASBR 1 |
Loop0 |
192.2.2.2/32 |
PE 1 |
Loop0 |
192.1.1.1/32 |
GE1/1/2 |
23.1.1.2/24 |
GE1/1/2 |
23.1.1.1/24 |
GE1/1/1 |
26.2.2.2/24 |
PE 2 |
Loop0 |
192.4.4.4/32 |
ASBR 2 |
Loop0 |
192.3.3.3/32 |
GE1/1/2 |
22.2.2.1/24 |
GE1/1/1 |
26.2.2.3/24 |
CE 2 |
GE1/1/1 |
100.1.1.2/24 |
GE1/1/2 |
22.2.2.3/24 |
1. Configure CE 1.
<CE1> system-view
2. Configure PE 1:
<PE1> system-view
[PE1-LoopBack0] ip address 192.1.1.1 32
[PE1] mpls lsr-id 192.1.1.1
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Configure GigabitEthernet 1/1/2 (the interface connected to ASBR 1), and enable LDP on the interface.
[PE1-GigabitEthernet1/1/2] ip address 23.1.1.1 24
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 23.1.1.1 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 192.1.1.1 0.0.0.0
[PE1-ospf-1] quit
[PE1-xcg-vpn1-ldp] peer 192.2.2.2 pw-id 1000
[PE1-xcg-vpn1-ldp-192.2.2.2-1000] quit
[PE1-xcg-vpn1] quit
3. Configure ASBR 1:
<ASBR1> system-view
[ASBR1] interface loopback 0
[ASBR1-LoopBack0] ip address 192.2.2.2 32
[ASBR1-LoopBack0] quit
[ASBR1] mpls lsr-id 192.2.2.2
# Enable L2VPN.
[ASBR1] l2vpn enable
[ASBR1] mpls ldp
[ASBR1-ldp] quit
# Configure GigabitEthernet 1/1/2 (the interface connected to PE 1), and enable LDP on the interface.
[ASBR1] interface gigabitethernet 1/1/2
[ASBR1-GigabitEthernet1/1/2] ip address 23.1.1.2 24
[ASBR1-GigabitEthernet1/1/2] mpls enable
[ASBR1-GigabitEthernet1/1/2] mpls ldp enable
[ASBR1-GigabitEthernet1/1/2] quit
# Configure GigabitEthernet 1/1/1 (the interface connected to ASBR 2), and enable MPLS on the interface.
[ASBR1] interface gigabitethernet 1/1/1
[ASBR1-GigabitEthernet1/1/1] ip address 26.2.2.2 24
[ASBR1-GigabitEthernet1/1/1] mpls enable
[ASBR1-GigabitEthernet1/1/1] quit
[ASBR1] ospf
[ASBR1-ospf-1] area 0
[ASBR1-ospf-1-area-0.0.0.0] network 23.1.1.2 0.0.0.255
[ASBR1-ospf-1-area-0.0.0.0] network 192.2.2.2 0.0.0.0
[ASBR1-ospf-1-area-0.0.0.0] quit
[ASBR1-ospf-1] quit
# Configure BGP to advertise labeled routes on ASBR 1.
[ASBR1] bgp 100
[ASBR1-bgp-default] peer 26.2.2.3 as-number 200
[ASBR1-bgp-default] address-family ipv4 unicast
[ASBR1-bgp-default-ipv4] import-route direct
[ASBR1-bgp-default-ipv4] peer 26.2.2.3 enable
[ASBR1-bgp-default-ipv4] peer 26.2.2.3 route-policy policy1 export
[ASBR1-bgp-default-ipv4] peer 26.2.2.3 label-route-capability
[ASBR1-bgp-default-ipv4] quit
[ASBR1-bgp-default] quit
[ASBR1] route-policy policy1 permit node 1
[ASBR1-route-policy-policy1-1] apply mpls-label
[ASBR1-route-policy-policy1-1] quit
# Create a cross-connect group named vpn1, create a cross-connect named ldp in the group, and create two LDP PWs for the cross-connect to form a multi-segment PW.
[ASBR1] xconnect-group vpn1
[ASBR1-xcg-vpn1] connection ldp
[ASBR1-xcg-vpn1-ldp] peer 192.1.1.1 pw-id 1000
[ASBR1-xcg-vpn1-ldp-192.1.1.1-1000] quit
[ASBR1-xcg-vpn1-ldp] peer 192.3.3.3 pw-id 1000
[ASBR1-xcg-vpn1-ldp-192.3.3.3-1000] quit
[ASBR1-xcg-vpn1-ldp] quit
[ASBR1-xcg-vpn1] quit
4. Configure ASBR 2:
<ASBR2> system-view
[ASBR2] interface loopback 0
[ASBR2-LoopBack0] ip address 192.3.3.3 32
[ASBR2-LoopBack0] quit
[ASBR2] mpls lsr-id 192.3.3.3
# Enable L2VPN.
[ASBR2] l2vpn enable
[ASBR2] mpls ldp
[ASBR2-ldp] quit
[ASBR2] interface gigabitethernet 1/1/2
[ASBR2-GigabitEthernet1/1/2] ip address 22.2.2.3 24
[ASBR2-GigabitEthernet1/1/2] mpls enable
[ASBR2-GigabitEthernet1/1/2] mpls ldp enable
[ASBR2-GigabitEthernet1/1/2] quit
# Configure GigabitEthernet 1/1/1 (the interface connected to ASBR 1), and enable MPLS on the interface.
[ASBR2] interface gigabitethernet 1/1/1
[ASBR2-GigabitEthernet1/1/1] ip address 26.2.2.3 24
[ASBR2-GigabitEthernet1/1/1] mpls enable
[ASBR2-GigabitEthernet1/1/1] quit
[ASBR2] ospf
[ASBR2-ospf-1] area 0
[ASBR2-ospf-1-area-0.0.0.0] network 22.2.2.3 0.0.0.255
[ASBR2-ospf-1-area-0.0.0.0] network 192.3.3.3 0.0.0.0
[ASBR2-ospf-1-area-0.0.0.0] quit
[ASBR2-ospf-1] quit
# Configure BGP to advertise labeled routes on ASBR 2.
[ASBR2] bgp 200
[ASBR2-bgp-default] peer 26.2.2.2 as-number 100
[ASBR2-bgp-default] address-family ipv4 unicast
[ASBR2-bgp-default-ipv4] import-route direct
[ASBR2-bgp-default-ipv4] peer 26.2.2.2 enable
[ASBR2-bgp-default-ipv4] peer 26.2.2.2 route-policy policy1 export
[ASBR2-bgp-default-ipv4] peer 26.2.2.2 label-route-capability
[ASBR2-bgp-default-ipv4] quit
[ASBR2-bgp-default] quit
[ASBR2] route-policy policy1 permit node 1
[ASBR2-route-policy-policy1-1] apply mpls-label
[ASBR2-route-policy-policy1-1] quit
[ASBR2] xconnect-group vpn1
[ASBR2-xcg-vpn1] connection ldp
[ASBR2-xcg-vpn1-ldp] peer 192.2.2.2 pw-id 1000
[ASBR2-xcg-vpn1-ldp-192.2.2.2-1000] quit
[ASBR2-xcg-vpn1-ldp] peer 192.4.4.4 pw-id 1000
[ASBR2-xcg-vpn1-ldp-192.4.4.4-1000] quit
[ASBR2-xcg-vpn1-ldp] quit
[ASBR2-xcg-vpn1] quit
5. Configure PE 2:
<PE2> system-view
[PE2-LoopBack0] ip address 192.4.4.4 32
[PE2] mpls lsr-id 192.4.4.4
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
# Configure GigabitEthernet 1/1/2 (the interface connected to ASBR 2), and enable LDP on the interface.
[PE2-GigabitEthernet1/1/2] ip address 22.2.2.1 24
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 192.4.4.4 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 22.2.2.1 0.0.0.255
[PE2-ospf-1] quit
[PE2-xcg-vpn1] connection ldp
[PE2-xcg-vpn1-ldp] ac interface gigabitethernet 1/1/1
[PE2-xcg-vpn1-ldp] peer 192.3.3.3 pw-id 1000
[PE2-xcg-vpn1-ldp-192.3.3.3-1000] quit
[PE2-xcg-vpn1-ldp] quit
[PE2-xcg-vpn1] quit
6. Configure CE 2.
<CE2> system-view
# Verify that an LDP PW has been created on PE 1.
192.2.2.2 1000 1151/1279 LDP M 1 Up
# Verify that two LDP PWs have been created to form a multi-segment PW on ASBR 1.
[ASBR1] display l2vpn pw
192.1.1.1 1000 1279/1151 LDP M 0 Up
192.3.3.3 1000 1278/1151 LDP M 1 Up
# Verify that two LDP PWs have been created to form a multi-segment PW on ASBR 2.
[ASBR2] display l2vpn pw
192.2.2.2 1000 1151/1278 LDP M 0 Up
# Verify that an LDP PW has been created on PE 2.
192.3.3.3 1000 1279/1150 LDP M 1 Up
