04-PIM configuration | 914.26 KB |
Administrative scoping overview
Relationship among PIM protocols
PIM-DM configuration task list
Enabling the state refresh feature
Configuring state refresh parameters
Configuring PIM-DM graft retry timer
PIM-SM configuration task list
Configuring multicast source registration
Configuring the switchover to SPT
BIDIR-PIM configuration task list
PIM-SSM configuration task list
Configuring the SSM group range
Configuring common PIM features
Configuring a multicast source policy
Configuring a PIM hello policy
Configuring PIM hello message options
Setting the maximum size of a join or prune message
Enabling SNMP notifications for PIM
Enabling NBMA mode for ADVPN tunnel interfaces
Displaying and maintaining PIM
PIM-SM non-scoped zone configuration example
PIM-SM admin-scoped zone configuration example
BIDIR-PIM configuration example
A multicast distribution tree cannot be correctly built
Multicast data is abnormally terminated on an intermediate router
An RP cannot join an SPT in PIM-SM
An RPT cannot be built or multicast source registration fails in PIM-SM
Configuring PIM
Overview
Protocol Independent Multicast (PIM) provides IP multicast forwarding by leveraging unicast static routes or unicast routing tables generated by any unicast routing protocol, such as RIP, OSPF, IS-IS, or BGP. PIM uses the underlying unicast routing to generate a multicast routing table without relying on any particular unicast routing protocol.
PIM uses the RPF mechanism to implement multicast forwarding. When a multicast packet arrives on an interface of the device, it undergoes an RPF check. If the RPF check succeeds, the device creates a multicast routing entry and forwards the packet. If the RPF check fails, the device discards the packet. For more information about RPF, see "Configuring multicast routing and forwarding."
Based on the implementation mechanism, PIM includes the following categories:
· Protocol Independent Multicast–Dense Mode (PIM-DM)
· Protocol Independent Multicast–Sparse Mode (PIM-SM)
· Bidirectional Protocol Independent Multicast (BIDIR-PIM)
· Protocol Independent Multicast Source-Specific Multicast (PIM-SSM)
In this document, a PIM domain refers to a network composed of PIM routers.
PIM-DM overview
PIM-DM uses the push mode for multicast forwarding, and is suitable for small-sized networks with densely distributed multicast members.
PIM-DM assumes that all downstream nodes want to receive multicast data from a source, so multicast data is flooded to all downstream nodes on the network. Branches without downstream receivers are pruned from the forwarding trees. When a pruned branch has new receivers, the graft mechanism turns the pruned branch into a forwarding branch.
In PIM-DM, the multicast forwarding paths for a multicast group constitutes a forwarding tree. The forwarding tree is rooted at the multicast source and has multicast group members as its "leaves." Because the forwarding tree consists of the shortest paths from the multicast source to the receivers, it is also called a "shortest path tree (SPT)."
Neighbor discovery
In a PIM domain, each PIM interface on a router periodically multicasts PIM hello messages to all other PIM routers (identified by the address 224.0.0.13) on the local subnet. Through the exchanging of hello messages, all PIM routers on the subnet determine their PIM neighbors, maintain PIM neighboring relationship with other routers, and build and maintain SPTs.
SPT building
The process of building an SPT is the flood-and-prune process:
1. In a PIM-DM domain, the multicast data from the multicast source S to the multicast group G is flooded throughout the domain. A router performs an RPF check on the multicast data. If the RPF check succeeds, the router creates an (S, G) entry and forwards the data to all downstream nodes on the network. In the flooding process, all the routers in the PIM-DM domain create the (S, G) entry.
2. The nodes without downstream receivers are pruned. A router that has no downstream receivers multicasts a prune message to all PIM routers on the subnet. When an upstream node receives the prune message, it removes the receiving interface from the (S, G) entry. In this way, the upstream stream node stops forwarding subsequent packets addressed to that multicast group down to this node.
NOTE: An (S, G) entry contains a multicast source address S, a multicast group address G, an outgoing interface list, and an incoming interface. |
A prune process is initiated by a leaf router. As shown in Figure 1, the router interface that does not have any downstream receivers initiates a prune process by sending a prune message toward the multicast source. This prune process goes on until only necessary branches are left in the PIM-DM domain, and these necessary branches constitute an SPT.
The pruned state of a branch has a finite holdtime timer. When the timer expires, multicast data is again forwarded to the pruned branch. The flood-and-prune cycle takes place periodically to maintain the forwarding branches.
Graft
A previously pruned branch might have new downstream receivers. To reduce the latency for resuming the forwarding capability of this branch, a graft mechanism is used as follows:
1. The node that needs to receive the multicast data sends a graft message to its upstream node, telling it to rejoin the SPT.
2. After receiving this graft message on an interface, the upstream node adds the receiving interface to the outgoing interface list of the (S, G) entry. It also sends a graft-ack message to the graft sender.
3. If the graft sender receives a graft-ack message, the graft process finishes. Otherwise, the graft sender continues to send graft messages at a graft retry interval until it receives an acknowledgment from its upstream node.
Assert
On a subnet with more than one multicast router, the assert mechanism shuts off duplicate multicast flows to the network. It does this by electing a unique multicast forwarder for the subnet.
As shown in Figure 2, after Router A and Router B receive an (S, G) packet from the upstream node, they both forward the packet to the local subnet. As a result, the downstream node Router C receives two identical multicast packets. In addition, both Router A and Router B, on their downstream interfaces, receive a duplicate packet forwarded by the other. After detecting this condition, both routers send an assert message to all PIM routers (224.0.0.13) on the local subnet through the interface that received the packet. The assert message contains the multicast source address (S), the multicast group address (G), and the metric preference and metric of the unicast route/MBGP route/static multicast route to the multicast source. By comparing these parameters, either Router A or Router B becomes the unique forwarder of the subsequent (S, G) packets on the shared-media LAN. The comparison process is as follows:
1. The router with a higher metric preference to the multicast source wins.
2. If both routers have the same metric preference, the router with a smaller metric wins.
3. If both routers have the same metric, the router with a higher IP address on the downstream interface wins.
PIM-SM overview
PIM-DM uses the flood-and-prune cycles to build SPTs for multicast data forwarding. Although an SPT has the shortest paths from the multicast source to the receivers, it is built with a low efficiency. Therefore, PIM-DM is not suitable for large and medium-sized networks.
PIM-SM uses the pull mode for multicast forwarding, and it is suitable for large- and medium-sized networks with sparsely and widely distributed multicast group members.
PIM-SM assumes that no hosts need multicast data. A multicast receiver must express its interest in the multicast data for a multicast group before the data is forwarded to it. A rendezvous point (RP) is the core of a PIM-SM domain. Relying on the RP, SPTs and rendezvous point trees (RPTs) are established and maintained to implement multicast data forwarding. An SPT is rooted at the multicast source and has the RPs as its leaves. An RPT is rooted at the RP and has the receiver hosts as its leaves.
Neighbor discovery
PIM-SM uses the same neighbor discovery mechanism as PIM-DM does. For more information, see "Neighbor discovery."
DR election
A designated router (DR) is required on both the source-side network and receiver-side network. A source-side DR acts on behalf of the multicast source to send register messages to the RP. The receiver-side DR acts on behalf of the multicast receivers to send join messages to the RP.
PIM-DM does not require a DR. However, if IGMPv1 runs on any shared-media LAN in a PIM-DM domain, a DR must be elected to act as the IGMPv1 querier for the LAN. For more information about IGMP, see "Configuring IGMP."
IMPORTANT: IGMP must be enabled on the device that acts as the receiver-side DR. Otherwise, the receiver hosts attached to the DR cannot join any multicast groups. |
As shown in Figure 3, the DR election process is as follows:
1. The routers on the shared-media LAN send hello messages to one another. The hello messages contain the DR priority for DR election. The router with the highest DR priority is elected as the DR.
2. The router with the highest IP address wins the DR election under one of following conditions:
¡ All the routers have the same DR election priority.
¡ A router does not support carrying the DR priority in hello messages.
If the DR fails, its PIM neighbor lifetime expires and the other routers will initiate to elect a new DR.
RP discovery
An RP is the core of a PIM-SM domain. For a small-sized, simple network, one RP is enough for multicast forwarding throughout the network. In this case, you can specify a static RP on each router in the PIM-SM domain. However, in a PIM-SM network that covers a wide area, a huge amount of multicast data is forwarded by the RP. To lessen the RP burden and optimize the topological structure of the RPT, you can configure multiple candidate-RPs (C-RPs) in a PIM-SM domain. An RP is dynamically elected from the multiple C-RPs through the bootstrap mechanism. An elected RP provides services for a different multicast group. For this purpose, you must configure a bootstrap router (BSR). A BSR acts as the administrative core of a PIM-SM domain. A PIM-SM domain has only one BSR, but can have multiple candidate-BSRs (C-BSRs). If the BSR fails, a new BSR can be automatically elected from the C-BSRs and avoid service interruption.
NOTE: · An RP can provide services for multiple multicast groups, but a multicast group only uses one RP. · A device can act as a C-RP and a C-BSR at the same time. |
As shown in Figure 4, each C-RP periodically unicasts its advertisement messages (C-RP-Adv messages) to the BSR. An advertisement message contains the address of the advertising C-RP and the multicast group range to which it is designated. The BSR collects these advertisement messages and organizes the C-RP information into an RP-set, which is a database of mappings between multicast groups and RPs. The BSR encapsulates the RP-set information in the bootstrap messages (BSMs) and floods the BSMs to the entire PIM-SM domain.
Figure 4 Information exchange between C-RPs and BSR
Based on the information in the RP-set, all routers on the network can select an RP for a specific multicast group based on the following rules:
1. The C-RP that is designated to the smallest group range wins.
2. If the C-RPs are designated to the same group ranges, the C-RP with the highest priority wins.
3. If the C-RPs have the same priority, the C-RP with the largest hash value wins. The hash value is calculated through the hash algorithm.
4. If the C-RPs have the same hash value, the C-RP with the highest IP address wins.
Anycast RP
PIM-SM requires only one active RP to serve each multicast group. If the active RP fails, the multicast traffic might be interrupted. The Anycast RP mechanism enables redundancy backup among RPs by configuring multiple RPs with the same IP address. A multicast source registers with the closest RP or a receiver joins the closest RP to implement source information synchronization.
Anycast RP has the following benefits:
· Optimal RP path—A multicast source registers with the closest RP to build an optimal SPT. A receiver joins the closest RP to build an optimal RPT.
· Redundancy backup among RPs—When an RP fails, the RP-related sources will register with the closest available RPs and the receiver-side DRs will join the closest available RPs. This provides redundancy backup among RPs.
Anycast RP is implemented in either of the following methods:
· Anycast RP through MSDP—In this method, you can configure multiple RPs with the same IP address for one multicast group and configure MSDP peering relationships between them. For more information about Anycast RP through MSDP, see "Configuring MSDP."
· Anycast RP through PIM-SM—In this method, you can configure multiple RPs for one multicast group and add them to an Anycast RP set. This method introduces the following concepts:
¡ Anycast RP set—A set of RPs that are designated to the same multicast group.
¡ Anycast RP member—Each RP in the Anycast RP set.
¡ Anycast RP member address—IP address of each Anycast RP member for communication among the RP members.
¡ Anycast RP address—IP address of the Anycast RP set for communication within the PIM-SM domain. It is also known as RPA.
As shown in Figure 5, RP 1, RP 2, and RP 3 are members of an Anycast RP set.
Figure 5 Anycast RP through PIM-SM
The following describes how Anycast RP through PIM-SM is implemented:
a. RP 1 receives a register message destined to RPA. Because the message is not from other Anycast RP members (RP 2 or RP 3), RP 1 considers that the register message is from the DR. RP 1 changes the source IP address of the register message to its own address and sends the message to the other members (RP 2 and RP 3).
If a router acts as both a DR and an RP, it creates a register message, and then forwards the message to the other RP members.
b. After receiving the register message, RP 2 and RP 3 find out that the source address of the register message is an Anycast RP member address. They stop forwarding the message to other routers.
In Anycast RP implementation, an RP must forward the register message from the DR to other Anycast RP members to synchronize multicast source information.
RPT building
Figure 6 RPT building in a PIM-SM domain
As shown in Figure 6, the process of building an RPT is as follows:
1. When a receiver wants to join the multicast group G, it uses an IGMP message to inform the receiver-side DR.
2. After getting the receiver information, the DR sends a join message, which travels hop by hop to the RP for the multicast group.
3. The routers along the path from the DR to the RP form an RPT branch. Each router on this branch adds to its forwarding table a (*, G) entry, where the asterisk (*) represents any multicast source. The RP is the root of the RPT, and the DR is a leaf of the RPT.
When the multicast data addressed to the multicast group G reaches the RP, the RP forwards the data to the DR along the established RPT, and finally to the receiver.
When a receiver is no longer interested in the multicast data addressed to the multicast group G, the receiver-side DR sends a prune message. The prune message goes hop by hop along the RPT to the RP. After receiving the prune message, the upstream node deletes the interface that connects to this downstream node from the outgoing interface list. At the same time, the upstream router checks for the existence of receivers for that multicast group. If no receivers for the multicast group exist, the router continues to forward the prune message to its upstream router.
Multicast source registration
The multicast source uses the registration process to inform an RP of its presence.
Figure 7 Multicast source registration
As shown in Figure 7, the multicast source registers with the RP as follows:
1. The multicast source S sends the first multicast packet to the multicast group G. When receiving the multicast packet, the source-side DR encapsulates the packet into a PIM register message and unicasts the message to the RP.
2. After the RP receives the register message, it decapsulates the register message and forwards the register message down to the RPT. Meanwhile, it sends an (S, G) source-specific join message toward the multicast source. The routers along the path from the RP to the multicast source constitute an SPT branch. Each router on this branch creates an (S, G) entry in its forwarding table.
3. The subsequent multicast data from the multicast source are forwarded to the RP along the established SPT. When the multicast data reaches the RP along the SPT, the RP forwards the data to the receivers along the RPT. Meanwhile, it unicasts a register-stop message to the source-side DR to prevent the DR from unnecessarily encapsulating the data.
Switchover to SPT
CAUTION: If the switch is an RP, disabling switchover to SPT might cause multicast traffic forwarding failures on the source-side DR. When disabling switchover to SPT, be sure you fully understand its impact on your network. |
This section takes a router as an example. As compared with the switchover to SPT on a router, switchover to SPT is implemented in a simpler way on a switch.
In a PIM-SM domain, only one RP and one RPT provide services for a specific multicast group. Before the switchover to SPT occurs, the source-side DR encapsulates all multicast data in register messages and sends them to the RP. After receiving these register messages, the RP decapsulates them and forwards them to the receiver-side DR along the RPT.
Multicast forwarding along the RPT has the following weaknesses:
· Encapsulation and decapsulation are complex on the source-side DR and the RP.
· The path for a multicast packet might not be the shortest one.
· The RP might be overloaded by multicast traffic bursts.
To eliminate these weaknesses, PIM-SM allows an RP or the receiver-side DR to initiate the switchover to SPT when the traffic rate exceeds a specific threshold.
· The RP initiates the switchover to SPT:
The RP periodically checks the multicast packet forwarding rate. If the RP finds that the traffic rate exceeds the specified threshold, it sends an (S, G) source-specific join message toward the multicast source. The routers along the path from the RP to the multicast source constitute an SPT. The subsequent multicast data is forwarded to the RP along the SPT without being encapsulated into register messages.
For more information about the switchover to SPT initiated by the RP, see "Multicast source registration."
· The receiver-side DR initiates the switchover to SPT:
The receiver-side DR periodically checks the forwarding rate of the multicast packets that the multicast source S sends to the multicast group G. If the forwarding rate exceeds the specified threshold, the DR initiates the switchover to SPT as follows:
a. The receiver-side DR sends an (S, G) source-specific join message toward the multicast source. The routers along the path create an (S, G) entry in their forwarding table to constitute an SPT branch.
b. When the multicast packets reach the router where the RPT and the SPT branches, the router drops the multicast packets that travel along the RPT. It then sends a prune message with the RP bit toward the RP.
c. After receiving the prune message, the RP forwards it toward the multicast source (supposed only one receiver exists). Thus, the switchover to SPT is completed. The subsequent multicast packets travel along the SPT from the multicast source to the receiver hosts.
With the switchover to SPT, PIM-SM builds SPTs more economically than PIM-DM does.
Assert
PIM-SM uses a similar assert mechanism as PIM-DM does. For more information, see "Assert."
BIDIR-PIM overview
In some many-to-many applications, such as a multi-side video conference, multiple receivers of a multicast group might be interested in the multicast data from multiple multicast sources. With PIM-DM or PIM-SM, each router along the SPT must create an (S, G) entry for each multicast source, consuming a lot of system resources.
BIDIR-PIM addresses the problem. Derived from PIM-SM, BIDIR-PIM builds and maintains a bidirectional RPT, which is rooted at the RP and connects the multicast sources and the receivers. Along the bidirectional RPT, the multicast sources send multicast data to the RP, and the RP forwards the data to the receivers. Each router along the bidirectional RPT needs to maintain only one (*, G) entry, saving system resources.
BIDIR-PIM is suitable for a network with dense multicast sources and receivers.
Neighbor discovery
BIDIR-PIM uses the same neighbor discovery mechanism as PIM-SM does. For more information, see "Neighbor discovery."
RP discovery
BIDIR-PIM uses the same RP discovery mechanism as PIM-SM does. For more information, see "RP discovery." In BIDIR-PIM, an RPF interface is the interface toward an RP, and an RPF neighbor is the address of the next hop to the RP.
In PIM-SM, an RP must be specified with a real IP address. In BIDIR-PIM, an RP can be specified with a virtual IP address, which is called the "rendezvous point address (RPA)." The link corresponding to the RPA's subnet is called the "rendezvous point link (RPL)." All interfaces connected to the RPL can act as the RPs, and they back up one another.
DF election
On a subnet with multiple multicast routers, duplicate multicast packets might be forwarded to the RP. To address this issue, BIDIR-PIM uses a designated forwarder (DF) election mechanism to elect a unique DF for each RP on a subnet. Only the DFs can forward multicast data to the RP.
DF election is not necessary for an RPL.
As shown in Figure 8, without the DF election mechanism, both Router B and Router C can receive multicast packets from Route A. They also can forward the packets to downstream routers on the local subnet. As a result, the RP (Router E) receives duplicate multicast packets.
With the DF election mechanism, once receiving the RP information, Router B and Router C multicast a DF election message to all PIM routers (224.0.0.13) to initiate a DF election process. The election message carries the RP's address, and the route preference and the metric of the unicast route or static multicast route to the RP. A DF is elected as follows:
1. The router with a higher route preference becomes the DF.
2. If the routers have the same route preference, the router with a lower metric becomes the DF.
3. If the routers have the same metric, the router with a higher IP address becomes the DF.
Bidirectional RPT building
Figure 9 RPT building at the receiver side
As shown in Figure 9, the process for building a receiver-side RPT is the same as the process for building an RPT in PIM-SM:
1. When a receiver wants to join the multicast group G, it uses an IGMP message to inform the directly connected router.
2. After receiving the message, the router sends a join message, which is forwarded hop by hop to the RP for the multicast group.
3. The routers along the path from the receiver's directly connected router to the RP form an RPT branch. Each router on this branch adds a (*, G) entry to its forwarding table.
After a receiver host leaves the multicast group G, the directly connected router multicasts a prune message to all PIM routers on the subnet. The prune message goes hop by hop along the reverse direction of the RPT to the RP. After receiving the prune message, an upstream node removes the interface that connects to the downstream node from the outgoing interface list. At the same time, the upstream router checks the existence of receivers for that multicast group. If no receivers for the multicast group exist, the router continues to forward the prune message to its upstream router.
Figure 10 RPT building at the multicast source side
As shown in Figure 10, the process for building a source-side RPT is relatively simple:
1. When a multicast source sends multicast packets to the multicast group G, the DF in each subnet unconditionally forwards the packets to the RP.
2. The routers along the path from the source's directly connected router to the RP constitute an RPT branch. Each router on this branch adds to its forwarding table a (*, G) entry.
After a bidirectional RPT is built, the multicast sources send multicast traffic to the RP along the source-side RPT. Then, the RP forwards the traffic to the receivers along the receiver-side RPT.
IMPORTANT: If a receiver and a multicast source are at the same side of the RP, the source-side RPT and the receiver-side RPT might meet at a node before reaching the RP. In this case, the multicast packets from the multicast source to the receiver are directly forwarded by the node, instead of by the RP. |
Typically, a PIM-SM domain or a BIDIR-PIM domain contains only one BSR, which is responsible for advertising RP-set information within the entire domain. The information about all multicast groups is forwarded within the network that the BSR administers. This is called the "non-scoped BSR mechanism."
Administrative scoping mechanism
To implement refined management, you can divide a PIM-SM domain or BIDIR-PIM domain into a global-scoped zone and multiple administratively-scoped zones (admin-scoped zones). This is called the "administrative scoping mechanism."
The administrative scoping mechanism effectively releases stress on the management in a single-BSR domain and enables provision of zone-specific services through private group addresses.
Admin-scoped zones are divided for multicast groups. Zone border routers (ZBRs) form the boundary of an admin-scoped zone. Each admin-scoped zone maintains one BSR for multicast groups within a specific range. Multicast protocol packets, such as assert messages and BSMs, for a specific group range cannot cross the boundary of the admin-scoped zone for the group range. Multicast group ranges that are associated with different admin-scoped zones can have intersections. However, the multicast groups in an admin-scoped zone are valid only within the local zone, and theses multicast groups are regarded as private group addresses.
The global-scoped zone maintains a BSR for the multicast groups that do not belong to any admin-scoped zones.
Relationship between admin-scoped zones and the global-scoped zone
The global-scoped zone and each admin-scoped zone have their own C-RPs and BSRs. These devices are effective only on their respective zones, and the BSR election and the RP election are implemented independently. Each admin-scoped zone has its own boundary. The multicast information within a zone cannot cross this boundary in either direction. You can have a better understanding of the global-scoped zone and admin-scoped zones based on geographical locations and multicast group address ranges.
· In view of geographical locations:
An admin-scoped zone is a logical zone for particular multicast groups. The multicast packets for such multicast groups are confined within the local admin-scoped zone and cannot cross the boundary of the zone.
Figure 11 Relationship in view of geographical locations
As shown in Figure 11, for the multicast groups in a specific group address range, the admin-scoped zones must be geographically separated and isolated. A router cannot belong to multiple admin-scoped zones. An admin-scoped zone cannot contain a router that belongs to any other admin-scoped zone. However, the global-scoped zone includes all routers in the PIM-SM domain or BIDIR-PIM domain. Multicast packets that do not belong to any admin-scoped zones are forwarded in the entire PIM-SM domain or BIDIR-PIM domain.
· In view of multicast group address ranges:
Each admin-scoped zone is designated to specific multicast groups, of which the multicast group addresses are valid only within the local zone. The multicast groups of different admin-scoped zones might have intersections. All the multicast groups other than those of the admin-scoped zones use the global-scoped zone.
Figure 12 Relationship in view of multicast group address ranges
As shown in Figure 12, the admin-scoped zones 1 and 2 have no intersection, but the admin-scoped zone 3 is a subset of the admin-scoped zone 1. The global-scoped zone provides services for all the multicast groups that are not covered by the admin-scoped zones 1 and 2, G−G1−G2 in this case.
PIM-SSM overview
The ASM model includes PIM-DM and PIM-SM. The SSM model can be implemented by leveraging part of the PIM-SM technique. It is also called "PIM-SSM."
The SSM model provides a solution for source-specific multicast. It maintains the relationship between hosts and routers through IGMPv3.
In actual applications, part of IGMPv3 and PIM-SM techniques are adopted to implement the SSM model. In the SSM model, because receivers have located a multicast source, no RP or RPT is required. Multicast sources do not register with the RP, and the MSDP is not needed for discovering multicast sources in other PIM domains.
Neighbor discovery
PIM-SSM uses the same neighbor discovery mechanism as PIM-SM. For more information, see "Neighbor discovery."
DR election
PIM-SSM uses the same DR election mechanism as PIM-SM. For more information, see "DR election."
SPT building
The decision to build an RPT for PIM-SM or an SPT for PIM-SSM depends on whether the multicast group that the receiver joins is in the SSM group range. The SSM group range reserved by IANA is 232.0.0.0/8.
Figure 13 SPT building in PIM-SSM
As shown in Figure 13, Host B and Host C are receivers. They send IGMPv3 report messages to their DRs to express their interest in the multicast information that the multicast source S sends to the multicast group G.
After receiving a report message, the DR first checks whether the group address in this message is in the SSM group range and does the following:
· If the group address is in the SSM group range, the DR sends a subscribe message hop by hop toward the multicast source S. All routers along the path from the DR to the source create an (S, G) entry to build an SPT. The SPT is rooted at the multicast source S and has the receivers as its leaves. This SPT is the transmission channel in PIM-SSM.
· If the group address is not in the SSM group range, the receiver-side DR sends a (*, G) join message to the RP. The multicast source registers with the source-side DR.
In PIM-SSM, the term "subscribe message" refers to a join message.
In a PIM network, PIM-DM cannot run together with PIM-SM, BIDIR-PIM, or PIM-SSM. However, PIM-SM, BIDIR-PIM, and PIM-SSM can run together. Figure 14 shows how the device selects one protocol from among them for a receiver trying to join a group.
For more information about IGMP SSM mapping, see "Configuring IGMP."
Figure 14 Relationship among PIM protocols
PIM support for VPNs
To support PIM for VPNs, a multicast router that runs PIM maintains an independent set of PIM neighbor table, multicast routing table, BSR information, and RP-set information for each VPN.
After receiving a multicast data packet, the multicast router checks which VPN the data packet belongs to. Then, the router forwards the packet according to the multicast routing table for that VPN or creates a multicast routing entry for that VPN.
Protocols and standards
· RFC 3973, Protocol Independent Multicast-Dense Mode (PIM-DM): Protocol Specification(Revised)
· RFC 4601, Protocol Independent Multicast-Sparse Mode (PIM-SM): Protocol Specification (Revised)
· RFC 4610, Anycast-RP Using Protocol Independent Multicast (PIM)
· RFC 5015, Bidirectional Protocol Independent Multicast (BIDIR-PIM)
· RFC 5059, Bootstrap Router (BSR) Mechanism for Protocol Independent Multicast (PIM)
· RFC 4607, Source-Specific Multicast for IP
· Draft-ietf-ssm-overview-05, An Overview of Source-Specific Multicast (SSM)
Configuring PIM-DM
This section describes how to configure PIM-DM.
Tasks at a glance |
(Required.) Enabling PIM-DM |
(Optional.) Enabling the state refresh feature |
(Optional.) Configuring state refresh parameters |
(Optional.) Configuring PIM-DM graft retry timer |
(Optional.) Configuring common PIM features |
Configuration prerequisites
Before you configure PIM-DM, configure a unicast routing protocol so that all devices in the domain can interoperate at the network layer.
Enabling PIM-DM
Enable IP multicast routing before you configure PIM.
With PIM-DM enabled on interfaces, routers can establish PIM neighbor relationship and process PIM messages from their PIM neighbors. As a best practice, enable PIM-DM on all non-border interfaces of routers when you deploy a PIM-DM domain.
IMPORTANT: All the interfaces on a device must operate in the same PIM mode in the public network or the same VPN instance. |
To enable PIM-DM:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable IP multicast routing and enter MRIB view. |
multicast routing [ vpn-instance vpn-instance-name ] |
By default, IP multicast routing is disabled. |
3. Return to system view. |
quit |
N/A |
4. Enter interface view. |
N/A |
5. Enable PIM-DM. |
pim dm |
By default, PIM-DM is disabled. |
In a PIM-DM domain, the state refresh feature enables the PIM router that is directly connected to the source to periodically send state refresh messages. It also enables other PIM routers to refresh pruned state timers after receiving the state refresh messages. It prevents the pruned interfaces from resuming multicast forwarding. You must enable this feature on all PIM routers on a subnet.
To enable the state refresh feature:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Enable the state refresh feature. |
pim state-refresh-capable |
By default, the state refresh feature is enabled. |
The state refresh interval determines the interval at which a router sends state refresh messages. It is configurable.
A router might receive duplicate state refresh messages within a short time. To prevent this situation, you can configure the time that the router must wait to accept a new state refresh message. If the router receives a new state refresh message before the timer expires, it discards the message. If the router receives a new state refresh message after the timer expires, it accepts the message, refreshes its own PIM-DM state, and resets the waiting timer.
The TTL value of a state refresh message decrements by 1 whenever it passes a router before it is forwarded to the downstream node. The state refresh message stops being forwarded when the TTL value comes down to 0. A state refresh message with a large TTL value might cycle on a small network. To effectively control the propagation scope of state refresh messages, configure an appropriate TTL value based on the network size on the router directly connected with the multicast source.
To configure state refresh parameters:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter PIM view. |
pim [ vpn-instance vpn-instance-name ] |
N/A |
3. Configure the state refresh interval. |
state-refresh-interval interval |
The default setting is 60 seconds. |
4. Configure the amount of time to wait before accepting a new state refresh message. |
state-refresh-rate-limit time |
The default setting is 30 seconds. |
5. Configure the TTL value of state refresh messages. |
state-refresh-ttl ttl-value |
The default setting 255. |
To configure the graft retry timer:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the graft retry timer. |
pim timer graft-retry interval |
The default setting is 3 seconds. |
For more information about the configuration of other timers in PIM-DM, see "Configuring common PIM timers."
Configuring PIM-SM
This section describes how to configure PIM-SM.
Tasks at a glance |
Remarks |
(Required.) Enabling PIM-SM |
N/A |
(Required.) Configuring an RP: · (Optional.) Enabling Auto-RP listening · (Optional.) Configuring Anycast RP |
You must configure a static RP, a C-RP, or both in a PIM-SM domain. |
· (Required.) Configuring a C-BSR · (Optional.) Configuring a PIM domain border · (Optional.) Disabling BSM semantic fragmentation · (Optional.) Disabling the device from forwarding BSMs out of their incoming interfaces |
Skip the task of configuring a BSR on a network without C-RPs. |
(Optional.) Configuring multicast source registration |
N/A |
(Optional.) Configuring the switchover to SPT |
N/A |
N/A |
Before you configure PIM-SM, configure a unicast routing protocol so that all devices in the domain can interoperate at the network layer.
Enabling PIM-SM
With PIM-SM enabled on interfaces, routers can establish PIM neighbor relationship and process PIM messages from their PIM neighbors. As a best practice, enable PIM-SM on all non-border interfaces of routers when you deploy a PIM-SM domain.
IMPORTANT: All the interfaces on the same router must operate in the same PIM mode in the public network or the same VPN instance. |
To enable PIM-SM:
Step |
Command |
Remarks |
system-view |
N/A |
quit |
N/A |
N/A |
5. Enable PIM-SM. |
pim sm |
By default, PIM-SM is disabled. |
Configuring an RP
An RP can provide services for multiple or all multicast groups. However, only one RP can forward multicast traffic for a multicast group at a time.
An RP can be manually configured or dynamically elected through the BSR mechanism. For a large-scaled PIM network, configuring static RPs is a tedious job. Generally, static RPs are backups for dynamic RPs to enhance the robustness and operational manageability on a multicast network.
Configuring a static RP
If only one dynamic RP exists on a network, you can configure a static RP to avoid communication interruption caused by single-point failures. The static RP can also avoid waste of bandwidth due to frequent message exchange between C-RPs and the BSR.
When you configure static RPs for PIM-SM, follow these restrictions and guidelines:
· You can configure the same static RP for different multicast groups by using the same RP address but different ACLs.
· You do not need to enable PIM for an interface to be configured as a static RP.
· If you configure multiple static RPs for a multicast group, only the static RP with the highest IP address takes effect.
· The static RP configuration must be the same on all routers in the PIM-SM domain.
To configure a static RP for PIM-SM:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a static RP for PIM-SM. |
static-rp rp-address [ ipv4-acl-number | preferred ] * |
By default, no static RPs exist. |
Configuring a C-RP
IMPORTANT: When you configure a C-RP, reserve a relatively large bandwidth between the C-RP and other devices in the PIM-SM domain. |
In a PIM-SM domain, if you want a router to become the RP, you can configure the router as a C-RP. As a best practice, configure C-RPs on backbone routers.
The C-RPs periodically send advertisement messages to the BSR, which collects RP-set information for RP election. You can configure the interval for sending the advertisement messages.
The holdtime option in C-RP advertisement messages defines the C-RP lifetime for the advertising C-RP. The BSR starts a holdtime timer for a C-RP after it receives an advertisement message. If the BSR does not receive any advertisement message when the timer expires, it considers the C-RP failed or unreachable.
A C-RP policy enables the BSR to filter C-RP advertisement messages by using an ACL that specifies the packet source address range and multicast groups. It is used to guard against C-RP spoofing. You must configure the same C-RP policy on all C-BSRs in the PIM-SM domain.
To configure a C-RP:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a C-RP. |
c-rp ip-address [ advertisement-interval adv-interval | group-policy ipv4-acl-number | holdtime hold-time | priority priority ] * |
By default, no C-RPs exist. |
4. (Optional.) Configure a C-RP policy. |
crp-policy ipv4-acl-number |
By default, no C-RP policies exist, and all C-RP advertisement messages are regarded legal. |
This feature enables the device to receive Auto-RP announcement and discovery messages and learn RP information. The destination IP addresses for Auto-RP announcement and discovery messages are 224.0.1.39 and 224.0.1.40, respectively.
To enable Auto-RP listening:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable Auto-RP listening. |
auto-rp enable |
By default, Auto-RP listening is disabled. |
IMPORTANT: The Anycast RP address must be different from the BSR address. Otherwise, the other Anycast RP member devices will discard the BSM sent by the BSR. |
You must configure a static RP or C-RPs in the PIM-SM domain before you configure the Anycast RP. Use the address of the static RP or the dynamically elected RP as the Anycast RP address.
When you configure Anycast RP, follow these restrictions and guidelines:
· You must add the device that the Anycast RP resides as an RP member to the Anycast RP set. The RP member address cannot be the same as the Anycast RP address.
· You must add all RP member addresses (including the local RP member address) to the Anycast RP set on each RP member device.
· As a best practice, configure no more than 16 Anycast RP members for an Anycast RP set.
· As a best practice, configure the loopback interface address of an RP member device as the RP member address. If you add multiple interface addresses of an RP member device to an Anycast RP set, the lowest IP address becomes the RP member address. The rest of the interface addresses become backup RP member addresses.
To configure Anycast RP:
Step |
Command |
Remarks |
N/A |
N/A |
3. Configure Anycast RP. |
By default, Anycast RP is not configured. You can repeat this command to add multiple RP member addresses to the Anycast RP set. |
Configuring a BSR
You must configure a BSR if C-RPs are configured to dynamically select the RP. You do not need to configure a BSR when you have configured only a static RP but no C-RPs.
A PIM-SM domain can have only one BSR, but must have a minimum of one C-BSR. Any router can be configured as a C-BSR. Elected from C-BSRs, the BSR is responsible for collecting and advertising RP information in the PIM-SM domain.
Configuring a C-BSR
The BSR election process is summarized as follows:
1. Initially, each C-BSR regards itself as the BSR of the PIM-SM domain and sends a BSM to other routers in the domain.
2. When a C-BSR receives the BSM from another C-BSR, it compares its own priority with the priority carried in the message. The C-BSR with a higher priority wins the BSR election. If a tie exists in the priority, the C-BSR with a higher IP address wins. The loser uses the winner's BSR address to replace its own BSR address and no longer regards itself as the BSR. The winner retains its own BSR address and continues to regard itself as the BSR.
The elected BSR distributes the RP-set information collected from C-RPs to all routers in the PIM-SM domain. All routers use the same hash algorithm to select an RP for a specific multicast group.
A BSR policy enables a PIM-SM router to filter BSR messages by using an ACL that specifies the legal BSR addresses. It is used to guard against the following BSR spoofing cases:
· Some maliciously configured hosts can forge BSMs to fool routers and change RP mappings. Such attacks often occur on border routers.
· When an attacker controls a router on the network, the attacker can configure the router as a C-BSR to win the BSR election. Through this router, the attacker controls the advertising of RP information.
When you configure a C-BSR, follow these restrictions and guidelines:
· Configure C-BSRs on routers that are on the backbone network.
· Reserve a relatively large bandwidth between the C-BSR and the other devices in the PIM-SM domain.
· You must configure the same BSR policy on all routers in the PIM-SM domain. The BSR policy discards illegal BSR messages, but it partially guards against BSR attacks on the network. If an attacker controls a legal BSR, the problem still exists.
· When C-BSRs connect to other PIM routers through tunnels, static multicast routes must be configured to make sure the next hop to a C-BSR is a tunnel interface. Otherwise, RPF check is affected. For more information about static multicast routes, see "Configuring multicast routing and forwarding."
To configure a C-BSR:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a C-BSR. |
c-bsr ip-address [ scope group-address { mask-length | mask } ] [ hash-length hash-length | priority priority ] * |
By default, no C-BSRs exist. |
4. (Optional.) Configure a BSR policy. |
bsr-policy ipv4-acl-number |
By default, no BSR policies exist, and all bootstrap messages are regarded legal. |
A PIM domain border determines the transmission boundary of bootstrap messages. Bootstrap messages cannot cross the domain border in either direction. A number of PIM domain border interfaces partition a network into different PIM-SM domains.
To configure a PIM domain border:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a PIM domain border. |
pim bsr-boundary |
By default, an interface is not a PIM domain border. |
BSM semantic fragmentation enables a BSR to split a BSM into multiple BSM fragments (BSMFs) if the BSM exceeds the MTU. In this way, a non-BSR router can update the RP-set information for a group range after receiving all BSMFs for the range. The loss of one BSMF only affects the RP-set information of the group ranges that the fragment contains.
If the PIM-SM domain contains a device that does not support this feature, you must disable this feature on all C-BSRs. If you do not disable this feature, such a device regards a BSMF as a BSM and updates the RP-set information each time it receives a BSMF. It learns only part of the RP-set information, which further affects the RP election.
To disable BSM semantic fragmentation:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Disable BSM semantic fragmentation. |
undo bsm-fragment enable |
By default, BSM semantic fragmentation is enabled. |
NOTE: Generally, a BSR performs BSM semantic fragmentation according to the MTU of its BSR interface. For BSMs originated due to learning of a new PIM neighbor, semantic fragmentation is performed according to the MTU of the interface that sends the BSMs. |
By default, the device forwards BSMs out of their incoming interfaces to avoid the situation that some devices cannot receive BSMs because of inconsistent routing information. This results in duplicated traffic. To reduce traffic, you can disable the device from forwarding BSMs out of their incoming interfaces if all the devices have consistent routing information.
To disable the device from forwarding BSMs out of their incoming interfaces:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Disable the device from forwarding BSMs out of their incoming interfaces. |
undo bsm-reflection enable |
By default, the device forwards BSMs out of their incoming interfaces. |
You can configure the device to calculate the checksum based on the entire register message to ensure information integrity of a register message in the transmission process. If a device that does not support this feature is present on the network, you can configure the device to calculate the checksum based on the register message header.
The RP sends a register-stop message to the source-side DR in either of the following conditions:
· The RP stops serving the receivers for a multicast group. The receivers do not receive multicast data addressed to the multicast group through the RP.
· The RP receives multicast data that travels along the SPT.
After receiving the register-stop message, the DR stops sending register messages encapsulated with multicast data and starts a register-stop timer. Before the register-stop timer expires, the DR sends a null register message (a register message without encapsulated multicast data) to the RP and starts a register probe timer. If the DR receives a register-stop message before the register probe timer expires, it resets its register-stop timer. Otherwise, the DR starts sending register messages with encapsulated data again.
The register-stop timer is set to a random value chosen uniformly from (0.5 × register_suppression_time minus register_probe_time) to (1.5 × register_suppression_time minus register_probe_time). The register_probe_time is fixed to 5 seconds.
On all C-RP routers, perform the following tasks:
· Configure a PIM register policy.
· Configure the routers to calculate the checksum based on the entire register messages or the register message header.
On all routers that might become the source-side DR, configure the register suppression time.
To configure multicast source registration:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a PIM register policy. |
register-policy ipv4-acl-number |
By default, no PIM register policies exist, and all PIM register messages are regarded legal. |
4. Configure the device to calculate the checksum based on the entire register message. |
register-whole-checksum |
By default, the device calculates the checksum based on the header of a register message. |
5. Configure the register suppression time. |
CAUTION: If the device is an RP, disabling the switchover to SPT might cause multicast traffic forwarding failures on the source-side DR. When disabling the switchover to SPT, make sure you fully understand its impact on your network. |
Both the receiver-side DR and RP can monitor the traffic rate of passing-by multicast packets and thus trigger a switchover from RPT to SPT.
To configure the switchover to SPT:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the RPT to SPT switchover. |
spt-switch-threshold { traffic-rate | immediacy | infinity } [ group-policy ipv4-acl-number ] |
By default, the first multicast data packet triggers the RPT to SPT switchover. |
NOTE: If the multicast source information is learned through MSDP, the device switches to SPT immediately after it receives the first multicast packet, regardless of the traffic rate threshold. |
Configuring BIDIR-PIM
This section describes how to configure BIDIR-PIM.
Tasks at a glance |
Remarks |
(Required.) Enabling BIDIR-PIM |
N/A |
(Required.) Configuring an RP: · (Optional.) Enabling Auto-RP listening · (Optional.) Setting the maximum number of BIDIR-PIM RPs |
You must configure a static RP, a C-RP, or both in a BIDIR-PIM domain. |
N/A |
Before you configure BIDIR-PIM, configure a unicast routing protocol so that all devices in the domain can interoperate at the network layer.
Enabling BIDIR-PIM
Because BIDIR-PIM is implemented on the basis of PIM-SM, you must enable PIM-SM before you enable BIDIR-PIM. As a best practice, enable PIM-SM on all non-border interfaces of routers when you deploy a BIDIR-PIM domain.
IMPORTANT: All interfaces on a device must be enabled with the same PIM mode. |
To enable BIDIR-PIM:
Step |
Command |
Remarks |
system-view |
N/A |
quit |
N/A |
N/A |
5. Enable PIM-SM. |
pim sm |
6. Return to system view. |
quit |
N/A |
7. Enter PIM view. |
N/A |
8. Enable BIDIR-PIM. |
bidir-pim enable |
By default, BIDIR-PIM is disabled. |
Configuring an RP
CAUTION: When both PIM-SM and BIDIR-PIM run on the PIM network, do not use the same RP to provide services for PIM-SM and BIDIR-PIM. Otherwise, exceptions might occur to the PIM routing table. |
If only one dynamic RP exists on a network, you can configure a static RP to avoid communication interruption caused by single-point failures. The static RP also avoids bandwidth waste due to frequent message exchange between C-RPs and the BSR.
In BIDIR-PIM, a static RP can be specified with an unassigned IP address. This address must be on the same subnet with the link on which the static RP is configured. For example, if the IP addresses of the interfaces at the two ends of a link are 10.1.1.1/24 and 10.1.1.2/24, you can assign 10.1.1.100/24 to the static RP. As a result, the link becomes an RPL.
When you configure static RPs for BIDIR-PIM, follow these restrictions and guidelines:
· The static RP configuration must be the same on all routers in the BIDIR-PIM domain.
To configure a static RP:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a static RP for BIDIR-PIM. |
static-rp rp-address bidir [ ipv4-acl-number | preferred ] * |
Configuring a C-RP
IMPORTANT: When you configure a C-RP, reserve a large bandwidth between the C-RP and other devices in the BIDIR-PIM domain. |
In a BIDIR-PIM domain, if you want a router to become the RP, you can configure the router as a C-RP. The BSR collects the C-RP information according to the received advertisement messages from C-RPs or the auto-RP announcements from other routers. Then, it organizes the C-RP information into the RP-set information, which is flooded throughout the entire network. Then, the other routers on the network can determine the RPs for different multicast group ranges based on the RP-set information. As a best practice, configure C-RPs on backbone routers.
To enable the BSR to distribute the RP-set information in the BIDIR-PIM domain, the C-RPs must periodically send advertisement messages to the BSR. The BSR learns the C-RP information, encapsulates the C-RP information and its own IP address in a BSM, and floods the BSM to all PIM routers in the domain.
An advertisement message contains a holdtime option, which defines the C-RP lifetime for the advertising C-RP. After the BSR receives an advertisement message from a C-RP, it starts a timer for the C-RP. If the BSR does not receive any advertisement message when the timer expires, it considers the C-RP failed or unreachable.
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a C-RP to provide services for BIDIR-PIM. |
c-rp ip-address [ advertisement-interval adv-interval | group-policy ipv4-acl-number | holdtime hold-time | priority priority ] * bidir |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
auto-rp enable |
In a BIDIR-PIM domain, one DF election per RP is implemented on all PIM-enabled interfaces. As a best practice to avoid unnecessary DF elections, do not configure multiple BIDIR-PIM RPs.
This configuration sets a limit on the number of BIDIR-PIM RPs. If the number of RPs exceeds the limit, excess RPs do not take effect and can be used only for DF election rather than multicast data forwarding. The system does not delete the excess RPs. They must be deleted manually.
To set the maximum number of BIDIR-PIM RPs:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the maximum number of BIDIR-PIM RPs. |
bidir-rp-limit limit |
By default, the maximum number of BIDIR-PIM RPs is 32. |
Configuring a BSR
A BIDIR-PIM domain can have only one BSR, but must have a minimum of one C-BSR. Any router can be configured as a C-BSR. Elected from C-BSRs, the BSR is responsible for collecting and advertising RP information in the BIDIR-PIM domain.
Configuring a C-BSR
IMPORTANT: Because the BSR and other devices exchange a large amount of information in the BIDIR-PIM domain, reserve a large bandwidth between the C-BSR and other devices. |
1. Initially, each C-BSR regards itself as the BSR of the BIDIR-PIM domain and sends BSMs to other routers in the domain.
The elected BSR distributes the RP-set information collected from C-RPs to all routers in the BIDIR-PIM domain. All routers use the same hash algorithm to select an RP for a specific multicast group.
A BSR policy enables the router to filter BSR messages by using an ACL that specifies the legal BSR addresses. It is used to guard against the following BSR spoofing cases:
· C-BSRs should be configured on routers on the backbone network.
· You must configure the same BSR policy on all routers in the BIDIR-PIM domain. The BSR policy discards illegal BSR messages, but it partially guards against BSR attacks on the network. If an attacker controls a legal BSR, the problem still exists.
· For C-BSRs interconnected through a GRE tunnel, configure static multicast routes to make sure the next hop to a C-BSR is a tunnel interface. For more information about static multicast routes, see "Configuring multicast routing and forwarding."
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
A PIM domain border determines the transmission boundary of bootstrap messages. Bootstrap messages cannot cross the domain border in either direction. A number of PIM domain border interfaces partition a network into different BIDIR-PIM domains.
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
pim bsr-boundary |
BSM semantic fragmentation enables a BSR to split a BSM into multiple BSM fragments (BSMFs) if the BSM exceeds the MTU. In this way, a non-BSR router can update the RP-set information for a group range after receiving all BSMFs for the group range. The loss of one BSMF only affects the RP-set information of the group ranges that the fragment contains.
If the BIDIR-SM domain contains a device that does not support this feature, you must disable this feature on all C-BSRs. If you do not disable this feature, such a device regards a BSMF as a BSM and updates the RP-set information each time it receives a BSMF. It learns only part of the RP-set information, which further affects the RP election.
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
By default, the device forwards BSMs out of their incoming interfaces to avoid the situation that some devices cannot receive BSMs because of inconsistent routing information. This results in duplicated traffic. To reduce traffic, you can disable the device to forward BSMs out of their incoming interfaces if all the devices have consistent routing information.
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
Configuring PIM-SSM
PIM-SSM requires IGMPv3 support. Enable IGMPv3 on PIM routers that connect to multicast receivers.
Tasks at a glance |
(Optional.) Configuring the SSM group range |
Before you configure PIM-SSM, configure a unicast routing protocol so that all devices in the domain can interoperate at the network layer.
Enabling PIM-SM
Before you configure PIM-SSM, you must enable PIM-SM, because the implementation of the SSM model is based on subsets of PIM-SM.
When you deploy a PIM-SSM domain, enable PIM-SM on non-border interfaces of the routers.
IMPORTANT: All the interfaces on a device must be enabled with the same PIM mode. |
To enable PIM-SM:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable IP multicast routing, and enter MRIB view. |
quit |
N/A |
N/A |
5. Enable PIM-SM. |
pim sm |
When a PIM-SM enabled interface receives a multicast packet, it checks whether the multicast group address of the packet is in the SSM group range. If the multicast group address is in this range, the PIM mode for this packet is PIM-SSM. If the multicast group address is not in this range, the PIM mode is PIM-SM.
When you configure the SSM group range, follow these restrictions and guidelines:
· Configure the same SSM group range on all routers in the entire PIM-SSM domain. Otherwise, multicast information cannot be delivered through the SSM model.
· When a member of a multicast group in the SSM group range sends an IGMPv1 or IGMPv2 report message, the device does not trigger a (*, G) join.
Configuration procedure
To configure an SSM group range:
Step |
Command |
Remarks |
system-view |
N/A |
pim |
N/A |
3. Configure the SSM group range. |
ssm-policy ipv4-acl-number |
By default, the SSM group range is 232.0.0.0/8. |
Configuration task list
Tasks at a glance |
(Optional.) Configuring a multicast source policy |
(Optional.) Configuring a PIM hello policy |
(Optional.) Configuring PIM hello message options |
(Optional.) Configuring common PIM timers |
(Optional.) Setting the maximum size of a join or prune message |
(Optional.) Enabling BFD for PIM |
(Optional.) Enabling PIM passive mode |
(Optional.) Enabling PIM NSR |
(Optional.) Enabling SNMP notifications for PIM |
(Optional.) Enabling NBMA mode for ADVPN tunnel interfaces |
Before you configure common PIM features, complete the following tasks:
· Configure a unicast routing protocol so that all devices in the domain can interoperate at the network layer.
· Configure PIM-DM or PIM-SM.
This feature enables the device to filter multicast data by using an ACL that specifies the multicast sources and the optional groups. It filters not only data packets but also register messages with multicast data encapsulated. It controls the information available to downstream receivers.
To configure a multicast source policy:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a multicast source policy. |
source-policy ipv4-acl-number |
By default, no multicast source policies exist, and all multicast data packets are forwarded. |
This feature enables the device to filter PIM hello messages by using an ACL that specifies the packet source addresses. It is used to guard against PIM message attacks and to establish correct PIM neighboring relationships.
If hello messages of an existing PIM neighbor are filtered out by the policy, the neighbor is automatically removed when its aging timer expires.
To configure a PIM hello policy:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure a PIM hello policy. |
pim neighbor-policy ipv4-acl-number |
By default, no PIM hello policies exist on an interface, and all PIM hello messages are regarded legal. |
In either a PIM-DM domain or a PIM-SM domain, hello messages exchanged among routers contain the following configurable options:
· DR_Priority (for PIM-SM only)—Priority for DR election. The device with the highest priority wins the DR election. You can configure this option for all the routers in a shared-media LAN that directly connects to the multicast source or the receivers.
· Holdtime—PIM neighbor lifetime. If a router does not receive a hello message from a neighbor when the neighbor lifetime expires, it regards the neighbor failed or unreachable.
· LAN_Prune_Delay—Delay of pruning a downstream interface on a shared-media LAN. This option has LAN delay, override interval, and neighbor tracking support (the capability to disable join message suppression).
The LAN delay defines the PIM message propagation delay. The override interval defines a period for a router to override a prune message. If the propagation delay or override interval on different PIM routers on a shared-media LAN are different, the largest ones apply.
On the shared-media LAN, the propagation delay and override interval are used as follows:
¡ If a router receives a prune message on its upstream interface, it means that there are downstream routers on the shared-media LAN. If this router still needs to receive multicast data, it must send a join message to override the prune message within the override interval.
¡ When a router receives a prune message from its downstream interface, it does not immediately prune this interface. Instead, it starts a timer (the propagation delay plus the override interval). If interface receives a join message before the timer expires, the router does not prune the interface. Otherwise, the router prunes the interface.
If you enable neighbor tracking on an upstream router, this router can track the states of the downstream nodes for which the joined state holdtime timer has not expired. If you want to enable neighbor tracking, you must enable it on all PIM routers on a shared-media LAN. Otherwise, the upstream router cannot track join messages from every downstream routers.
· Generation ID—A router generates a generation ID for hello messages when an interface is enabled with PIM. The generation ID is a random value, but only changes when the status of the router changes. If a PIM router finds that the generation ID in a hello message from the upstream router has changed, it assumes that the status of the upstream router has changed. In this case, it sends a join message to the upstream router for status update. You can configure an interface to drop hello messages without the generation ID options to promptly know the status of an upstream router.
You can configure hello message options for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
Configuring hello message options globally
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the DR priority. |
hello-option dr-priority priority |
The default setting is 1. |
4. Set the neighbor lifetime. |
hello-option holdtime time |
The default setting is 105 seconds. |
5. Set the PIM message propagation delay for a shared-media LAN. |
hello-option lan-delay delay |
The default setting is 500 milliseconds. |
6. Set the override interval. |
hello-option override-interval interval |
The default setting is 2500 milliseconds. |
7. Enable neighbor tracking. |
hello-option neighbor-tracking |
By default, neighbor tracking is disabled. |
Configuring hello message options on an interface
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
pim hello-option dr-priority priority |
pim hello-option holdtime time |
5. Set the PIM message propagation delay. |
pim hello-option lan-delay delay |
pim hello-option override-interval interval |
pim hello-option neighbor-tracking |
8. Enable dropping hello messages without the Generation ID option. |
pim require-genid |
By default, an interface accepts hello messages without the Generation ID option. |
IMPORTANT: To prevent the upstream neighbors from aging out, you must configure the interval for sending join/prune messages to be less than the joined/pruned state holdtime timer. |
The following are common timers in PIM:
· Hello interval—Interval at which a PIM router sends hello messages to discover PIM neighbors, and maintain PIM neighbor relationship.
· Triggered hello delay—Maximum delay for sending a hello message to avoid collisions caused by simultaneous hello messages. After receiving a hello message, a PIM router waits for a random time before sending a hello message. This random time is in the range of 0 to the triggered hello delay.
· Join/Prune interval—Interval at which a PIM router sends join/prune messages to its upstream routers for state update.
· Joined/Pruned state holdtime—Time for which a PIM router keeps the joined/pruned state for the downstream interfaces. This joined/pruned state holdtime is specified in a join/prune message.
· Multicast source lifetime—Lifetime that a PIM router maintains for a multicast source. If a router does not receive subsequent multicast data from the multicast source S when the timer expires, it deletes the (S, G) entry for the multicast source.
You can configure common PIM timers for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
TIP: As a best practice, use the default settings for a network without special requirements. |
Configuring common PIM timers globally
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the hello interval. |
timer hello interval |
4. Set the join/prune interval. |
timer join-prune interval |
The default setting is 60 seconds. This configuration takes effect after the current interval ends. |
5. Set the joined/pruned state holdtime. |
holdtime join-prune time |
The default setting is 210 seconds. |
6. Set the multicast source lifetime. |
source-lifetime time |
Configuring common PIM timers on an interface
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
pim timer hello interval |
4. Set the triggered hello delay. |
pim triggered-hello-delay delay |
The default setting is 5 seconds. |
5. Set the join/prune interval. |
pim timer join-prune interval |
6. Set the joined/pruned state holdtime. |
pim holdtime join-prune time |
The loss of an oversized join or prune message might result in loss of massive information. You can set a small value for the size of a join or prune message to reduce the impact.
To set the maximum size of a join or prune message:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the maximum size of a join or prune message. |
jp-pkt-size size |
The default setting is 8100 bytes. |
If a DR on a shared-media network fails, a new DR election process does not start until the DR ages out. In addition, it might take a long period of time before other routers detect the link failures and trigger a new DR election. To start a new DR election process immediately after the original DR fails, enable BFD for PIM to detect link failures among PIM neighbors.
You must enable BFD for PIM on all PIM routers on a shared-media network. For more information about BFD, see High Availability Configuration Guide.
You must enable PIM-DM or PIM-SM on an interface before you configure this feature on the interface.
To enable BFD for PIM:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable BFD for PIM. |
pim bfd enable |
By default, BFD is disabled for PIM. |
To guard against PIM hello spoofing, you can enable PIM passive mode on a receiver-side interface. The PIM passive interface cannot receive or forward PIM protocol messages (excluding register, register-stop and C-RP-Adv messages), and it acts as the DR on the subnet. In BIDIR-PIM, it also acts as the DF.
When you enable PIM passive mode, follow these restrictions and guidelines:
· This feature takes effect only when PIM-DM or PIM-SM is enabled on the interface.
· To avoid duplicate multicast data transmission and flow loop, do not enable this feature on a shared-media LAN with multiple PIM routers.
To enable PIM passive mode on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable PIM passive mode on the interface. |
pim passive |
By default, PIM passive mode is disabled on an interface. |
Enabling PIM NSR
This feature enables PIM to back up protocol state information and data, including PIM neighbor information and routes, from the active process to the standby process. The standby process immediately takes over when the active process fails. Use this feature to avoid route flapping and forwarding interruption for PIM when an active/standby switchover occurs.
To enable PIM NSR:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable PIM NSR. |
pim non-stop-routing |
By default, PIM NSR is disabled. |
To report critical PIM events to an NMS, enable SNMP notifications for PIM. For PIM event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
To enable SNMP notifications for PIM:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable SNMP notifications for PIM. |
By default, SNMP notifications for PIM are enabled. |
This feature allows ADVPN tunnel interfaces to forward multicast data to target spokes and hubs. For more information about ADVPN, see Layer 3—IP Services Configuration Guide.
When you enable NBMA mode, follow these restrictions and guidelines:
· This feature is not available for PIM-DM.
· This feature takes effect only when PIM-SM is enabled on the ADVPN tunnel interface.
· In a BIDIR-PIM domain, make sure RPs do not reside on ADVPN tunnel interfaces or on the subnet where ADVPN tunnel interfaces are located.
· Do not configure IGMP features on ADVPN tunnel interfaces that are enabled with NBMA mode.
To enable NBMA mode for an ADVPN tunnel interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable NBMA mode. |
By default, NBMA mode is disabled. This command is applicable only to ADVPN tunnel interfaces. |
Displaying and maintaining PIM
Task |
Command |
Display register-tunnel interface information. |
display interface [ register-tunnel [ interface-number ] ] [ brief [ description | down ] ] |
Display BSR information in the PIM-SM domain. |
display pim [ vpn-instance vpn-instance-name ] bsr-info |
Display information about the routes used by PIM. |
display pim [ vpn-instance vpn-instance-name ] claimed-route [ source-address ] |
Display C-RP information in the PIM-SM domain. |
display pim [ vpn-instance vpn-instance-name ] c-rp [ local ] |
Display DF information in the BIDIR-PIM domain. |
display pim [ vpn-instance vpn-instance-name ] df-info [ rp-address ] |
Display PIM information on an interface. |
display pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ] |
Display PIM neighbor information. |
display pim [ vpn-instance vpn-instance-name ] neighbor [ neighbor-address | interface interface-type interface-number | verbose ] * |
Display PIM routing entries. |
display pim [ vpn-instance vpn-instance-name ] routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number | proxy ] * |
Display RP information in the PIM-SM domain. |
display pim [ vpn-instance vpn-instance-name ] rp-info [ group-address ] |
Display statistics for PIM packets. |
display pim statistics |
Display remote end information maintained by PIM for ADVPN tunnel interfaces. |
PIM configuration examples
PIM-DM configuration example
Network requirements
As shown in Figure 15:
· OSPF runs on the network.
· VOD streams are sent to receiver hosts in multicast. The receiver groups of different organizations form stub networks, and one or more receiver hosts exist on each stub network.
· The entire PIM domain operates in the dense mode.
· Host A and Host C are multicast receivers on two stub networks N1 and N2.
· IGMPv2 runs between Router A and N1, and between Router B, Router C, and N2.
Device |
IP address |
Device |
IP address |
Router A |
10.110.1.1/24 |
Router C |
192.168.3.1/24 |
Router A |
192.168.1.1/24 |
Router D |
10.110.5.1/24 |
Router B |
10.110.2.1/24 |
Router D |
192.168.1.2/24 |
Router B |
192.168.2.1/24 |
Router D |
192.168.2.2/24 |
Router C |
10.110.2.2/24 |
Router D |
192.168.3.2/24 |
1. Assign an IP address and subnet mask for each interface, as shown in Figure 15. (Details not shown.)
2. Configure OSPF on the routers in the PIM-DM domain. (Details not shown.)
3. Enable IP multicast routing, IGMP, and PIM-DM:
# On Router A, enable IP multicast routing.
[RouterA] multicast routing
[RouterA-mrib] quit
# Enable IGMP on the receiver-side interface (GigabitEthernet 1/1/1).
[RouterA] interface gigabitethernet 1/1/1
[RouterA-GigabitEthernet1/1/1] igmp enable
[RouterA-GigabitEthernet1/1/1] quit
# Enable PIM-DM on GigabitEthernet 1/1/2.
[RouterA] interface gigabitethernet 1/1/2
[RouterA-GigabitEthernet1/1/2] pim dm
[RouterA-GigabitEthernet1/1/2] quit
# Enable IP multicast routing, IGMP, and PIM-DM on Router B and Router C in the same way Router A is configured. (Details not shown.)
# On Router D, enable IP multicast routing, and enable PIM-DM on each interface.
<RouterD> system-view
[RouterD] multicast routing
[RouterD-mrib] quit
[RouterD] interface gigabitethernet 1/1/1
[RouterD-GigabitEthernet1/1/1] pim dm
[RouterD-GigabitEthernet1/1/1] quit
[RouterD] interface gigabitethernet 1/1/2
[RouterD-GigabitEthernet1/1/2] pim dm
[RouterD-GigabitEthernet1/1/2] quit
[RouterD] interface gigabitethernet 1/1/3
[RouterD-GigabitEthernet1/1/3] pim dm
[RouterD-GigabitEthernet1/1/3] quit
[RouterD] interface gigabitethernet 1/1/4
[RouterD-GigabitEthernet1/1/4] pim dm
[RouterD-GigabitEthernet1/1/4] quit
# Display PIM information on Router D.
[RouterD] display pim interface
Interface NbrCnt HelloInt DR-Pri DR-Address
GE1/1/1 0 30 1 10.110.5.1 (local)
GE1/1/2 1 30 1 192.168.1.2 (local)
GE1/1/3 1 30 1 192.168.2.2 (local)
GE1/1/4 1 30 1 192.168.3.2 (local)
# Display the PIM neighboring relationships on Router D.
[RouterD] display pim neighbor
Total Number of Neighbors = 3
Neighbor Interface Uptime Expires Dr-Priority Mode
192.168.1.1 GE1/1/2 00:02:22 00:01:27 1
192.168.2.1 GE1/1/3 00:00:22 00:01:29 3
192.168.3.1 GE1/1/4 00:00:23 00:01:31 5
# Send an IGMP report from Host A to join multicast group 225.1.1.1. (Details not shown.)
# Send multicast data from multicast source 10.110.5.100/24 to multicast group 225.1.1.1. (Details not shown.)
# Display the PIM routing table on Router A.
[RouterA] display pim routing-table
(*, 225.1.1.1)
Protocol: pim-dm, Flag: WC
UpTime: 00:04:25
Upstream interface: NULL
Upstream neighbor: NULL
RPF prime neighbor: NULL
1: GigabitEthernet1/1/1
Protocol: igmp, UpTime: 00:04:25, Expires: -
(10.110.5.100, 225.1.1.1)
Protocol: pim-dm, Flag: ACT
UpTime: 00:06:14
Upstream interface: GigabitEthernet1/1/2
Upstream neighbor: 192.168.1.2
RPF prime neighbor: 192.168.1.2
Protocol: pim-dm, UpTime: 00:04:25, Expires: -
# Display the PIM routing table on Router D.
[RouterD] display pim routing-table
UpTime: 00:03:27
Upstream interface: GigabitEthernet1/1/1
Total number of downstreams: 2
1: GigabitEthernet1/1/2
Protocol: pim-dm, UpTime: 00:03:27, Expires: -
2: GigabitEthernet1/1/4
· Routers on the SPT path (Router A and Router D) have the correct (S, G) entries.
· Router A has the correct (*, G) entry.
PIM-SM non-scoped zone configuration example
As shown in Figure 16:
· VOD streams are sent to receiver hosts in multicast. The receivers of different subnets form stub networks, and a minimum of one receiver host exist on each stub network.
· The entire PIM-SM domain contains only one BSR.
· Host A and Host C are multicast receivers in the stub networks N1 and N2.
· Specify GigabitEthernet 1/1/3 on Router E as a C-BSR and a C-RP. The C-RP is designated to the multicast group range of 225.1.1.0/24. Specify GigabitEthernet 1/1/2 of Router D as the static RP on all the routers to back up the dynamic RP.
Device |
IP address |
Device |
IP address |
Router A |
Router D |
Router A |
Router D |
Router B |
Router E |
Router E |
Router C |
Router E |
1. Assign an IP address and subnet mask to each interface, as shown in Figure 16. (Details not shown.)
2. Configure OSPF on all routers in the PIM-SM domain. (Details not shown.)
3. Enable IP multicast routing, IGMP and PIM-SM:
[RouterA-mrib] quit
# Enable PIM-SM on the other interfaces.
[RouterA-GigabitEthernet1/1/2] pim sm
[RouterA] interface gigabitethernet 1/1/3
[RouterA-GigabitEthernet1/1/3] pim sm
[RouterA-GigabitEthernet1/1/3] quit
# Enable IP multicast routing, IGMP and PIM-SM on Router B and Router C in the same way Router A is configured. (Details not shown.)
# Enable IP multicast routing and PIM-SM on Router D and Router E in the same way Router A is configured. (Details not shown.)
4. Configure C-BSRs, C-RPs, and the static RP:
# On Router E, configure the service scope of RP advertisements.
<RouterE> system-view
[RouterE] acl basic 2005
[RouterE-acl-ipv4-basic-2005] rule permit source 225.1.1.0 0.0.0.255
[RouterE-acl-ipv4-basic-2005] quit
# Configure GigabitEthernet 1/1/3 as a C-BSR and a C-RP, and configure GigabitEthernet 1/1/2 of Router D as the static RP.
[RouterE] pim
[RouterE-pim] c-bsr 192.168.9.2
[RouterE-pim] c-rp 192.168.9.2 group-policy 2005
[RouterE-pim] static-rp 192.168.1.2
[RouterE-pim] quit
# On Router A, configure GigabitEthernet 1/1/2 of Router D as the static RP.
[RouterA] pim
[RouterA-pim] static-rp 192.168.1.2
[RouterA-pim] quit
# Configure the static RP on Router B, Router C, and Router D in the same way Router A is configured. (Details not shown.)
# Display PIM information on Router A.
[RouterA] display pim interface
GE1/1/3 1 30 1 192.168.9.2
# Display BSR information on Router A.
[RouterA] display pim bsr-info
Scope: non-scoped
State: Accept Preferred
Bootstrap timer: 00:01:44
Elected BSR address: 192.168.9.2
Priority: 64
Hash mask length: 30
Uptime: 00:11:18
# Display BSR information on Router E.
[RouterE] display pim bsr-info
Scope: non-scoped
State: Elected
Priority: 64
Uptime: 00:11:18
Candidate BSR address: 192.168.9.2
Priority: 64
# Display RP information on Router A.
[RouterA] display pim rp-info
BSR RP information:
Scope: non-scoped
Group/MaskLen: 225.1.1.0/24
RP address Priority HoldTime Uptime Expires
192.168.9.2 192 180 00:51:45 00:02:22
Static RP information:
RP address ACL Mode Preferred
192.168.1.2 ---- pim-sm No
PIM-SM admin-scoped zone configuration example
As shown in Figure 17:
· VOD streams are sent to receiver hosts in multicast. The entire PIM-SM domain is divided into admin-scoped zone 1, admin-scoped zone 2, and the global-scoped zone. Router B, Router C, and Router D are ZBRs of the three zones, respectively.
· Source 1 and Source 2 send different multicast data to multicast group 239.1.1.1. Host A receives the multicast data only from Source 1, and Host B receives the multicast data only from Source 2. Source 3 sends multicast data to multicast group 224.1.1.1. Host C is a multicast receiver for multicast group 224.1.1.1.
· GigabitEthernet 1/1/2 of Router B acts as a C-BSR and a C-RP for admin-scoped zone 1, and GigabitEthernet 1/1/1 of Router D acts as a C-BSR and a C-RP for admin-scoped zone 2. Both of the two interfaces are designated to multicast group range 239.0.0.0/8. GigabitEthernet 1/1/1 of Router F acts as a C-BSR and a C-RP for the global-scoped zone, and is designated to all the multicast groups that are not in the range 239.0.0.0/8.
· IGMPv2 runs between Router A, Router E, Router I, and the receivers that directly connect to them, respectively.
Table 3 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
GE1/1/1 |
192.168.1.1/24 |
Router A |
GE1/1/2 |
10.110.1.1/24 |
Router D |
Router B |
GE1/1/1 |
192.168.2.1/24 |
Router D |
Router B |
GE1/1/2 |
10.110.1.2/24 |
Router B |
GE1/1/3 |
10.110.2.1/24 |
Router E |
Router B |
GE1/1/4 |
10.110.3.1/24 |
Router E |
Router C |
GE1/1/1 |
192.168.3.1/24 |
Router C |
GE1/1/2 |
10.110.4.1/24 |
Router F |
Router C |
GE1/1/3 |
10.110.5.1/24 |
Router F |
Router C |
GE1/1/4 |
10.110.2.2/24 |
Router C |
GE1/1/5 |
10.110.6.1/24 |
Router G |
Router H |
GE1/1/1 |
10.110.5.2/24 |
Router H |
GE1/1/2 |
10.110.7.1/24 |
Router I |
GE1/1/1 |
Router I |
GE1/1/2 |
1. Assign an IP address and subnet mask to each interface, as shown in Figure 17. (Details not shown.)
3. Enable IP multicast routing, IGMP, and PIM-SM:
[RouterA-mrib] quit
# Enable PIM-SM on GigabitEthernet 1/1/2.
# Enable IP multicast routing, IGMP and PIM-SM on Router E and Router I in the same way Router A is configured. (Details not shown.)
# On Router B, enable IP multicast routing, and enable PIM-SM on each interface.
<RouterB> system-view
[RouterB] multicast routing
[RouterB-mrib] quit
[RouterB] interface gigabitethernet 1/1/1
[RouterB-GigabitEthernet1/1/1] pim sm
[RouterB-GigabitEthernet1/1/1] quit
[RouterB] interface gigabitethernet 1/1/2
[RouterB-GigabitEthernet1/1/2] pim sm
[RouterB-GigabitEthernet1/1/2] quit
[RouterB] interface gigabitethernet 1/1/3
[RouterB-GigabitEthernet1/1/3] pim sm
[RouterB-GigabitEthernet1/1/3] quit
[RouterB] interface gigabitethernet 1/1/4
[RouterB-GigabitEthernet1/1/4] pim sm
[RouterB-GigabitEthernet1/1/4] quit
# Enable IP multicast routing and PIM-SM on Router C, Router D, Router F, Router G, and Router H in the same way Router B is configured. (Details not shown.)
4. Configure admin-scoped zone boundaries:
# On Router B, configure GigabitEthernet 1/1/3 and GigabitEthernet 1/1/4 as the boundaries of admin-scoped zone 1.
[RouterB-GigabitEthernet1/1/3] multicast boundary 239.0.0.0 8
[RouterB-GigabitEthernet1/1/4] multicast boundary 239.0.0.0 8
# On Router C, configure GigabitEthernet 1/1/4 and GigabitEthernet 1/1/5 as the boundaries of admin-scoped zone 2.
<RouterC> system-view
[RouterC] interface gigabitethernet 1/1/4
[RouterC-GigabitEthernet1/1/4] multicast boundary 239.0.0.0 8
[RouterC-GigabitEthernet1/1/4] quit
[RouterC] interface gigabitethernet 1/1/5
[RouterC-GigabitEthernet1/1/5] multicast boundary 239.0.0.0 8
[RouterC-GigabitEthernet1/1/5] quit
# On Router D, configure GigabitEthernet 1/1/3 as the boundary of admin-scoped zone 2.
[RouterD-GigabitEthernet1/1/3] multicast boundary 239.0.0.0 8
5. Configure C-BSRs and C-RPs:
# On Router B, configure the service scope of RP advertisements.
[RouterB] acl basic 2001
[RouterB-acl-ipv4-basic-2001] rule permit source 239.0.0.0 0.255.255.255
[RouterB-acl-ipv4-basic-2001] quit
# Configure GigabitEthernet 1/1/2 as a C-BSR and a C-RP for admin-scoped zone 1.
[RouterB] pim
[RouterB-pim] c-bsr 10.110.1.2 scope 239.0.0.0 8
[RouterB-pim] c-rp 10.110.1.2 group-policy 2001
[RouterB-pim] quit
# On Router D, configure the service scope of RP advertisements.
[RouterD] acl basic 2001
[RouterD-acl-ipv4-basic-2001] rule permit source 239.0.0.0 0.255.255.255
[RouterD-acl-ipv4-basic-2001] quit
# Configure GigabitEthernet 1/1/1 as a C-BSR and a C-RP for admin-scoped zone 2.
[RouterD] pim
[RouterD-pim] c-bsr 10.110.5.2 scope 239.0.0.0 8
[RouterD-pim] c-rp 10.110.5.2 group-policy 2001
[RouterD-pim] quit
# On Router F, configure GigabitEthernet 1/1/1 as a C-BSR and a C-RP for the global-scoped zone.
<RouterF> system-view
[RouterF] pim
[RouterF-pim] c-bsr 10.110.9.1
[RouterF-pim] c-rp 10.110.9.1
[RouterF-pim] quit
# Display BSR information on Router B.
[RouterB] display pim bsr-info
Scope: non-scoped
Elected BSR address: 10.110.9.1
Priority: 64
Uptime: 00:01:45
Scope: 239.0.0.0/8
State: Elected
Bootstrap timer: 00:00:06
Elected BSR address: 10.110.1.2
Priority: 64
Uptime: 00:04:54
Candidate BSR address: 10.110.1.2
Priority: 64
# Display BSR information on Router D.
[RouterD] display pim bsr-info
Scope: non-scoped
Priority: 64
Uptime: 00:01:45
Scope: 239.0.0.0/8
State: Elected
Bootstrap timer: 00:01:12
Elected BSR address: 10.110.5.2
Priority: 64
Uptime: 00:03:48
Candidate BSR address: 10.110.5.2
Priority: 64
# Display BSR information on Router F.
[RouterF] display pim bsr-info
Scope: non-scoped
State: Elected
Bootstrap timer: 00:00:49
Priority: 64
Uptime: 00:11:11
Candidate BSR address: 10.110.9.1
Priority: 64
# Display RP information on Router B.
[RouterB] display pim rp-info
BSR RP information:
Scope: non-scoped
Group/MaskLen: 224.0.0.0/4
10.110.9.1 192 180 00:03:39 00:01:51
Scope: 239.0.0.0/8
Group/MaskLen: 239.0.0.0/8
10.110.1.2 (local) 192 180 00:07:44 00:01:51
# Display RP information on Router D.
[RouterD] display pim rp-info
BSR RP information:
Scope: non-scoped
10.110.9.1 192 180 00:03:42 00:01:48
Scope: 239.0.0.0/8
10.110.5.2 (local) 192 180 00:06:54 00:02:41
# Display RP information on Router F.
[RouterF] display pim rp-info
BSR RP information:
Scope: non-scoped
10.110.9.1 (local) 192 180 00:00:32 00:01:58
BIDIR-PIM configuration example
As shown in Figure 18:
· Source 1 and Source 2 send multicast data to multicast group 225.1.1.1.
· Host A and Host B are receivers of this multicast group.
· GigabitEthernet 1/1/1 of Router C acts as the C-BSR. Loopback 0 of Router C acts as the C-RP.
· IGMPv2 runs between Router B and Host A, and between Router D and Host B.
Table 4 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
GE1/1/1 |
192.168.1.1/24 |
Router D |
GE1/1/1 |
192.168.3.1/24 |
Router A |
GE1/1/2 |
10.110.1.1/24 |
Router D |
GE1/1/2 |
192.168.4.1/24 |
Router B |
GE1/1/1 |
192.168.2.1/24 |
Router D |
GE1/1/3 |
10.110.3.2/24 |
Router B |
GE1/1/2 |
10.110.1.2/24 |
Source 1 |
192.168.1.100/24 |
Router B |
GE1/1/3 |
10.110.2.1/24 |
Source 2 |
192.168.4.100/24 |
Router C |
GE1/1/1 |
10.110.2.2/24 |
Receiver 1 |
192.168.2.100/24 |
Router C |
GE1/1/2 |
10.110.3.1/24 |
Receiver 2 |
192.168.3.100/24 |
Router C |
Loop0 |
1.1.1.1/32 |
1. Assign an IP address and subnet mask to each interface, as shown in Figure 18. (Details not shown.)
2. Configure OSPF on the routers in the BIDIR-PIM domain. (Details not shown.)
3. Enable IP multicast routing, PIM-SM, BIDIR-PIM, and IGMP:
# On Router A, enable IP multicast routing, enable PIM-SM on each interface, and enable BIDIR-PIM.
[RouterA-mrib] quit
[RouterA-GigabitEthernet1/1/1] pim sm
[RouterA] pim
[RouterA-pim] bidir-pim enable
[RouterA-pim] quit
# On Router B, enable IP multicast routing.
[RouterB-mrib] quit
[RouterB-GigabitEthernet1/1/1] igmp enable
# Enable BIDIR-PIM.
[RouterB] pim
[RouterB-pim] bidir-pim enable
[RouterB-pim] quit
# On Router C, enable IP multicast routing, enable PIM-SM on each interface, and enable BIDIR-PIM.
[RouterC] multicast routing
[RouterC-mrib] quit
[RouterC] interface gigabitethernet 1/1/1
[RouterC-GigabitEthernet1/1/1] pim sm
[RouterC-GigabitEthernet1/1/1] quit
[RouterC] interface gigabitethernet 1/1/2
[RouterC-GigabitEthernet1/1/2] pim sm
[RouterC-GigabitEthernet1/1/2] quit
[RouterC] interface loopback 0
[RouterC-LoopBack0] pim sm
[RouterC-LoopBack0] quit
[RouterC] pim
[RouterC-pim] bidir-pim enable
# On Router D, enable IP multicast routing.
[RouterD-mrib] quit
[RouterD-GigabitEthernet1/1/1] igmp enable
# Enable PIM-SM on other interfaces.
[RouterD-GigabitEthernet1/1/2] pim sm
[RouterD-GigabitEthernet1/1/3] pim sm
# Enable BIDIR-PIM.
[RouterD] pim
[RouterD-pim] bidir-pim enable
[RouterD-pim] quit
4. On Router C, configure GigabitEthernet 1/1/1 as the C-BSR, and Loopback 0 as the C-RP for the entire BIDIR-PIM domain.
[RouterC-pim] c-bsr 10.110.2.2
[RouterC-pim] c-rp 1.1.1.1 bidir
[RouterC-pim] quit
1. Display the DF information of BIDIR-PIM:
# Display the DF information of BIDIR-PIM on Router A.
[RouterA] display pim df-info
RP address: 1.1.1.1
Interface State DF-Pref DF-Metric DF-Uptime DF-Address
GE1/1/1 Win 100 2 01:08:50 192.168.1.1 (local)
GE1/1/2 Lose 100 1 01:07:49 10.110.1.2
# Display the DF information of BIDIR-PIM on Router B.
[RouterB] display pim df-info
RP address: 1.1.1.1
GE1/1/1 Win 100 1 01:24:09 192.168.2.1 (local)
GE1/1/2 Win 100 1 01:24:09 10.110.1.2 (local)
GE1/1/3 Lose 0 0 01:23:12 10.110.2.2
# Display the DF information of BIDIR-PIM on Router C.
[RouterC] display pim df-info
RP address: 1.1.1.1
Loop0 - - - - -
GE1/1/1 Win 0 0 01:06:07 10.110.2.2 (local)
GE1/1/2 Win 0 0 01:06:07 10.110.3.1 (local)
# Display the DF information of BIDIR-PIM on Router D.
[RouterD] display pim df-info
RP address: 1.1.1.1
GE1/1/1 Win 100 1 01:19:53 192.168.3.1 (local)
GE1/1/2 Win 100 1 00:39:34 192.168.4.1 (local)
GE1/1/3 Lose 0 0 01:21:40 10.110.3.1
2. Display information about the DF for multicast forwarding:
# Display information about the DF for multicast forwarding on Router A.
[RouterA] display multicast forwarding df-info
Total 1 RP, 1 matched
00001. RP address: 1.1.1.1
Flags: 0x0
Uptime: 00:08:32
RPF interface: GigabitEthernet1/1/2
List of 1 DF interfaces:
# Display information about the DF for multicast forwarding on Router B.
[RouterB] display multicast forwarding df-info
Flags: 0x0
Uptime: 00:06:24
RPF interface: GigabitEthernet1/1/3
List of 2 DF interfaces:
2: GigabitEthernet1/1/2
# Display information about the DF for multicast forwarding on Router C.
[RouterC] display multicast forwarding df-info
Flags: 0x0
Uptime: 00:07:21
RPF interface: LoopBack0
# Display information about the DF for multicast forwarding on Router D.
[RouterD] display multicast forwarding df-info
Flags: 0x0
Uptime: 00:05:12
PIM-SSM configuration example
As shown in Figure 19:
· The receivers receive VOD information through multicast. The receiver groups of different organizations form stub networks, and one or more receiver hosts exist in each stub network. The entire PIM domain operates in the SSM mode.
· Host A and Host C are multicast receivers on two stub networks.
· The SSM group range is 232.1.1.0/24.
· IGMPv3 runs between Router A and N1, and between Router B, Router C, and N2.
Table 5 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
GE1/1/1 |
10.110.1.1/24 |
Router D |
GE1/1/1 |
10.110.5.1/24 |
Router A |
GE1/1/2 |
192.168.1.1/24 |
Router D |
GE1/1/2 |
192.168.1.2/24 |
Router A |
GE1/1/3 |
192.168.9.1/24 |
Router D |
GE1/1/3 |
192.168.4.2/24 |
Router B |
GE1/1/1 |
10.110.2.1/24 |
Router E |
GE1/1/1 |
192.168.3.2/24 |
Router B |
GE1/1/2 |
192.168.2.1/24 |
Router E |
GE1/1/2 |
192.168.2.2/24 |
Router C |
GE1/1/1 |
10.110.2.2/24 |
Router E |
GE1/1/3 |
192.168.9.2/24 |
Router C |
GE1/1/2 |
192.168.3.1/24 |
Router E |
GE1/1/4 |
192.168.4.1/24 |
1. Assign an IP address and subnet mask to each interface, as shown in Figure 19. (Details not shown.)
2. Configure OSPF on the routers in the PIM-SSM domain. (Details not shown.)
[RouterA-mrib] quit
# Enable IGMPv3 on GigabitEthernet 1/1/1 (the interface that connects to the stub network).
[RouterA-GigabitEthernet1/1/1] igmp version 3
# Enable IP multicast routing, IGMP, and PIM-SM on Router B and Router C in the same way Router A is configured. (Details not shown.)
4. Configure the SSM group range:
# On Router A, specify 232.1.1.0/24 as the SSM group range.
[RouterA] acl basic 2000
[RouterA-acl-ipv4-basic-2000] rule permit source 232.1.1.0 0.0.0.255
[RouterA-acl-ipv4-basic-2000] quit
[RouterA] pim
[RouterA-pim] ssm-policy 2000
[RouterA-pim] quit
# Configure the SSM group range on Router B, Router C, Router D, and Router E in the same way Router A is configured (Details not shown.)
# Send an IGMPv3 report from Host A to join the multicast source and group (10.110.5.100/24, 232.1.1.1). (Details not shown.)
(10.110.5.100, 232.1.1.1)
Protocol: pim-ssm, Flag:
UpTime: 00:13:25
Protocol: igmp, UpTime: 00:13:25, Expires: 00:03:25
# Display PIM routing entries on Router D.
Protocol: pim-ssm, Flag: LOC
UpTime: 00:12:05
Protocol: pim-ssm, UpTime: 00:12:05, Expires: 00:03:25
The output shows that routers on the SPT path (Router A and Router D) have generated the correct (S, G) entries.
Troubleshooting PIM
A multicast distribution tree cannot be correctly built
Symptom
No multicast forwarding entries are established on the routers (including routers directly connected with multicast sources or receivers) in a PIM network. This means that a multicast distribution tree cannot be correctly built.
Solution
To resolve the problem:
1. Use display ip routing-table to verify that a unicast route to the multicast source or the RP is available.
2. Use display pim interface to verify PIM information on each interface, especially on the RPF interface. If PIM is not enabled on the interfaces, use pim dm or pim sm to enable PIM-DM or PIM-SM for the interfaces.
3. Use display pim neighbor to verify that the RPF neighbor is a PIM neighbor.
4. Verify that PIM and IGMP are enabled on the interfaces that directly connect to the multicast sources or the receivers.
5. Use display pim interface verbose to verify that the same PIM mode is enabled on the RPF interface on a router and the connected interface of the router's RPF neighbor.
6. Use display current-configuration to verify that the same PIM mode is enabled on all routers. For PIM-SM, verify that the BSR and C-RPs are correctly configured.
7. If the problem persists, contact H3C Support.
Multicast data is abnormally terminated on an intermediate router
Symptom
An intermediate router can receive multicast data successfully, but the data cannot reach the last-hop router. An interface on the intermediate router receives multicast data but does not create an (S, G) entry in the PIM routing table.
Solution
1. Use display current-configuration to verify the multicast forwarding boundary settings. Use multicast boundary to change the multicast forwarding boundary settings to make the multicast packet able to cross the boundary.
2. Use display current-configuration to verify the multicast source policy. Change the ACL rule defined in the source-policy command so that the source/group address of the multicast data can pass ACL filtering.
3. If the problem persists, contact H3C Support.
An RP cannot join an SPT in PIM-SM
Symptom
An RPT cannot be correctly built, or an RP cannot join the SPT toward the multicast source.
Solution
1. Use display ip routing-table to verify that a unicast route to the RP is available on each router.
2. Use display pim rp-info to verify that the dynamic RP information is consistent on all routers.
3. Use display pim rp-info to verify that the same static RPs are configured on all routers on the network.
4. If the problem persists, contact H3C Support.
An RPT cannot be built or multicast source registration fails in PIM-SM
Symptom
The C-RPs cannot unicast advertisement messages to the BSR. The BSR does not advertise BSMs containing C-RP information and has no unicast route to any C-RP. An RPT cannot be correctly established, or the source-side DR cannot register the multicast source with the RP.
Solution
1. Use display ip routing-table on each router to view routing table information. Verify that unicast routes to the C-RPs and the BSR are available on each router and that a route is available between each C-RP and the BSR.
2. Use display pim bsr-info to verify that the BSR information exists on each router.
3. Use display pim rp-info to verify that the RP information is correct on each router.
4. Use display pim neighbor to verify that PIM neighboring relationship has been correctly established among the routers.
5. If the problem persists, contact H3C Support.
