10-OSPFv3 configuration | 448.41 KB |
OSPFv3 configuration task list
Configuring OSPFv3 area parameters
Configuring an OSPFv3 virtual link
Configuring OSPFv3 network types
Configuring the OSPFv3 network type for an interface
Configuring an NBMA or P2MP neighbor
Configuring OSPFv3 route control
Configuring OSPFv3 route summarization
Configuring OSPFv3 received route filtering
Configuring Inter-Area-Prefix LSA filtering
Setting an OSPFv3 cost for an interface
Setting the maximum number of OSPFv3 ECMP routes
Setting a preference for OSPFv3
Configuring OSPFv3 route redistribution
Tuning and optimizing OSPFv3 networks
Setting LSA transmission delay
Setting SPF calculation interval
Setting the LSA generation interval
Setting a DR priority for an interface
Ignoring MTU check for DD packets
Disabling interfaces from receiving and sending OSPFv3 packets
Enabling the logging of neighbor state changes
Configuring OSPFv3 network management
Configuring prefix suppression
Setting the maximum number of OSPFv3 logs
Displaying and maintaining OSPFv3
OSPFv3 stub area configuration example
OSPFv3 NSSA area configuration example
OSPFv3 DR election configuration example
OSPFv3 route redistribution configuration example
OSPFv3 route summarization configuration example
OSPFv3 GR configuration example
OSPFv3 NSR configuration example
BFD for OSPFv3 configuration example
OSPFv3 FRR configuration example
OSPFv3 IPsec profile configuration example
Configuring OSPFv3
This chapter describes how to configure RFC 2740-compliant Open Shortest Path First version 3 (OSPFv3) for an IPv6 network. For more information about OSPFv2, see "Configuring OSPF."
Overview
OSPFv3 and OSPFv2 have the following in common:
· 32-bit router ID and area ID.
· Hello, Database Description (DD), Link State Request (LSR), Link State Update (LSU), Link State Acknowledgment (LSAck).
· Mechanisms for finding neighbors and establishing adjacencies.
· Mechanisms for advertising and aging LSAs.
OSPFv3 and OSPFv2 have the following differences:
· OSPFv3 runs on a per-link basis. OSPFv2 runs on a per-IP-subnet basis.
· OSPFv3 supports running multiple processes on an interface, but OSPFv2 does not support.
· OSPFv3 identifies neighbors by router ID. OSPFv2 identifies neighbors by IP address.
OSPFv3 packets
OSPFv3 uses the following packet types:
· Hello—Periodically sent to find and maintain neighbors, containing timer values, information about the DR, BDR, and known neighbors.
· DD—Describes the digest of each LSA in the LSDB, exchanged between two routers for data synchronization.
· LSR—Requests needed LSAs from the neighbor. After exchanging the DD packets, the two routers know which LSAs of the neighbor are missing from their LSDBs. They then send an LSR packet to each other, requesting the missing LSAs. The LSA packet contains the digest of the missing LSAs.
· LSU—Transmits the requested LSAs to the neighbor.
· LSAck—Acknowledges received LSU packets.
OSPFv3 LSA types
OSPFv3 sends routing information in LSAs. The following LSAs are commonly used:
· Router LSA—Type-1 LSA, originated by all routers. This LSA describes the collected states of the router's interfaces to an area, and is flooded throughout a single area only.
· Network LSA—Type-2 LSA, originated for broadcast and NBMA networks by the DR. This LSA contains the list of routers connected to the network, and is flooded throughout a single area only.
· Inter-Area-Prefix LSA—Type-3 LSA, originated by ABRs and flooded throughout the LSA's associated area. Each Inter-Area-Prefix LSA describes a route with IPv6 address prefix to a destination outside the area, yet still inside the AS.
· Inter-Area-Router LSA—Type-4 LSA, originated by ABRs and flooded throughout the LSA's associated area. Each Inter-Area-Router LSA describes a route to ASBR.
· AS External LSA—Type-5 LSA, originated by ASBRs, and flooded throughout the AS, except stub areas and Not-So-Stubby Areas (NSSAs). Each AS External LSA describes a route to another AS. A default route can be described by an AS External LSA.
· NSSA LSA—Type-7 LSA, originated by ASBRs in NSSAs and flooded throughout a single NSSA. NSSA LSAs describe routes to other ASs.
· Link LSA—Type-8 LSA. A router originates a separate Link LSA for each attached link. Link LSAs have link-local flooding scope. Each Link LSA describes the IPv6 address prefix of the link and Link-local address of the router.
· Intra-Area-Prefix LSA—Type-9 LSA. Each Intra-Area-Prefix LSA contains IPv6 prefix information on a router, stub area, or transit area information, and has area flooding scope. It was introduced because Router LSAs and Network LSAs contain no address information.
· Grace LSA—Type-11 LSA, generated by a GR restarter at reboot and transmitted on the local link. The GR restarter describes the cause and interval of the reboot in the Grace LSA to notify its neighbors that it performs a GR operation.
Protocols and standards
· RFC 5340, OSPF for IPv6
· RFC 2328, OSPF Version 2
· RFC 3101, OSPF Not-So-Stubby Area (NSSA) Option
· RFC 5187, OSPFv3 Graceful Restart
Enabling OSPFv3
Before you enable OSPFv3, configure IPv6 addresses for interfaces to ensure IPv6 connectivity between neighboring nodes.
To enable an OSPFv3 process on a router:
· Enable the OSPFv3 process globally.
· Assign the OSPFv3 process a router ID.
· Enable the OSPFv3 process on related interfaces.
The router ID uniquely identifies the router within an AS. If a router runs multiple OSPFv3 processes, you must specify a unique router ID for each process.
An OSPFv3 process ID has only local significance. Process 1 on a router can exchange packets with process 2 on another router.
To enable OSPFv3:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable an OSPFv3 process and enter its view. |
ospfv3 [ process-id | vpn-instance vpn-instance-name ] * |
By default, no OSPFv3 processes are enabled. |
3. Specify a router ID. |
router-id router-id |
By default, no router ID is configured. |
4. Enter interface view. |
N/A |
5. Enable an OSPFv3 process on the interface. |
ospfv3 process-id area area-id [ instance instance-id ] |
By default, no OSPFv3 processes are enabled on an interface. |
OSPFv3 has the same stub area, NSSA area, and virtual link features as OSPFv2.
After you split an OSPFv3 AS into multiple areas, the LSA number is reduced and OSPFv3 applications are extended. To further reduce the size of routing tables and the number of LSAs, configure the non-backbone areas at an AS edge as stub areas.
A stub area cannot import external routes, but an NSSA area can import external routes into the OSPFv3 routing domain while retaining other stub area characteristics.
Non-backbone areas exchange routing information through the backbone area, so the backbone and non-backbone areas (including the backbone itself) must be fully meshed. If no connectivity can be achieved, configure virtual links.
Configuration prerequisites
Before you configure OSPFv3 area parameters, enable OSPFv3.
Configuring a stub area
All the routers attached to a stub area must be configured with the stub command. The no-summary keyword is only available on the ABR of the stub area.
If you use the stub command with the no-summary keyword on an ABR, the ABR advertises a default route in an Inter-Area-Prefix LSA into the stub area. No AS External LSA, Inter-Area-Prefix LSA, or other Inter-Area-Router LSA is advertised in the area. The stub area of this kind is called a totally stub area.
To configure an OSPFv3 stub area:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter OSPFv3 view. |
N/A |
3. Enter OSPFv3 area view. |
area area-id |
N/A |
4. Configure the area as a stub area. |
stub [ default-route-advertise-always | no-summary ] * |
By default, no area is configured as a stub area. |
5. (Optional.) Set a cost for the default route advertised to the stub area. |
default-cost cost-value |
The default setting is 1. |
Configuring an NSSA area
To configure an NSSA area, configure the nssa command on all the routers attached to the area.
To configure a totally NSSA area, configure the nssa no-summary command on the ABR. The ABR of a totally NSSA area does not advertise inter-area routes into the area.
To configure an NSSA area:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Configure the area as an NSSA area. |
nssa [ default-route-advertise [ cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] * | no-import-route | no-summary | [ translate-always | translate-never ] | suppress-fa | translator-stability-interval value ] * |
By default, no area is configured as an NSSA area. |
5. (Optional.) Set a cost for the default route advertised to the NSSA area. |
The default setting is 1. This command takes effect only on the ABR/ASBR of an NSSA or totally NSSA area. |
You can configure a virtual link to maintain connectivity between a non-backbone area and the backbone, or in the backbone itself.
IMPORTANT: · Both ends of a virtual link are ABRs that must be configured with the vlink-peer command. · Do not configure virtual links in the areas of a GR-capable process. |
To configure a virtual link:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Configure a virtual link. |
vlink-peer router-id [ dead seconds | hello seconds | instance instance-id | ipsec-profile profile-name | retransmit seconds | trans-delay seconds ] * |
By default, no virtual links exist. |
OSPFv3 classifies networks into the following types by the link layer protocol:
· Broadcast—When the link layer protocol is Ethernet or FDDI, OSPFv3 considers the network type as broadcast by default.
· NBMA—When the link layer protocol is Frame Relay or X.25, OSPFv3 considers the network type as NBMA by default.
· P2P—When the link layer protocol is PPP, LAPB, HDLC, or POS, OSPFv3 considers the network type as P2P by default.
Follow these guidelines when you change the network type of an OSPFv3 interface:
· An NBMA network must be fully connected. Any two routers in the network must be directly reachable to each other through a virtual circuit. If no such direct link is available, you must change the network type through a command.
· If direct connections are not available between some routers in an NBMA network, the type of interfaces associated must be configured as P2MP, or as P2P for interfaces with only one neighbor.
Before you configure OSPFv3 network types, enable OSPFv3.
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Configure a network type for the OSPFv3 interface. |
ospfv3 network-type { broadcast | nbma | p2mp [ unicast ] | p2p } [ instance instance-id ] |
By default, the network type of an interface depends on the media type of the interface. |
For NBMA and P2MP interfaces (only when in unicast mode), you must specify the link-local IP addresses of their neighbors because these interfaces cannot find neighbors through broadcasting hello packets. For NBMA interfaces, you can also specify DR priorities for neighbors.
To configure an NBMA or P2MP (unicast) neighbor and its DR priority:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify an NBMA or P2MP (unicast) neighbor and its DR priority. |
ospfv3 peer ipv6-address [ cost cost-value | dr-priority priority ] [ instance instance-id ] |
By default, no link-local address is specified for the neighbor interface. |
Before you configure OSPFv3 route control, perform the following tasks:
· Configure IPv6 addresses for interfaces to ensure IPv6 connectivity between neighboring nodes.
· Enable OSPFv3.
Route summarization enables an ABR or ASBR to summarize contiguous networks into a single network and advertise it to other areas.
Configuring route summarization on an ABR
If contiguous network segments exist in an area, you can summarize them into one network segment on the ABR. The ABR will advertise only the summary route. Any LSA on the specified network segment will not be advertised, reducing the LSDB size in other areas.
To configure route summarization on an ABR:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Configure route summarization on the ABR. |
abr-summary ipv6-address prefix-length [ not-advertise ] [ cost cost-value ] |
By default, route summarization is not configured on an ABR. |
Configuring route summarization on an ASBR
Perform this task to enable an ASBR to summarize external routes within the specified address range into a single route.
An ASBR can summarize routes in the following LSAs:
· Type-5 LSAs.
· Type-7 LSAs in an NSSA area.
· Type-5 LSAs translated by the ASBR (also an ABR) from Type-7 LSAs in an NSSA area.
If the ASBR (ABR) is not a translator, it cannot summarize routes in Type-5 LSAs translated from Type-7 LSAs.
To configure route summarization on an ASBR:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure route summarization on an ASBR. |
asbr-summary ipv6-address prefix-length [ cost cost-value | not-advertise | nssa-only | tag tag ] * |
By default, route summarization is not configured on an ASBR. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure OSPFv3 to filter routes calculated using received LSAs. |
filter-policy { ipv6-acl-number [ gateway prefix-list-name ] | prefix-list prefix-list-name [ gateway prefix-list-name ] | gateway prefix-list-name | route-policy route-policy-name } import |
By default, OSPFv3 accepts all routes calculated using received LSAs. This command can only filter routes computed by OSPFv3. Only routes not filtered out can be added into the local routing table. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Configure OSPFv3 to filter Inter-Area-Prefix LSAs. |
filter { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import } |
By default, OSPFv3 accepts all Inter-Area-Prefix LSAs. This command takes effect only on ABRs. |
You can set an OSPFv3 cost for an interface with one of the following methods:
· Set the cost value in interface view.
· Set a bandwidth reference value for the interface, and OSPFv3 computes the cost automatically based on the bandwidth reference value by using the following formula:
Interface OSPFv3 cost = Bandwidth reference value (100 Mbps) / Interface bandwidth (Mbps)
¡ If the calculated cost is greater than 65535, the value of 65535 is used.
¡ If the calculated cost is smaller than 1, the value of 1 is used.
· If no cost is set for an interface, OSPFv3 automatically computes the cost for the interface.
To set an OSPFv3 cost for an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set an OSPFv3 cost for the interface. |
ospfv3 cost cost-value [ instance instance-id ] |
By default, the OSPFv3 cost is 1 for a VLAN interface, is 0 for a loopback interface. The OSPFv3 cost is automatically computed according to the interface bandwidth for other interfaces. |
To set a bandwidth reference value:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set a bandwidth reference value. |
bandwidth-reference value |
The default setting is 100 Mbps. |
Perform this task to implement load sharing over ECMP routes.
To set the maximum number of ECMP routes:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the maximum number of ECMP routes. |
maximum load-balancing number |
By default, the maximum number of ECMP routes is 8. |
A router can run multiple routing protocols. The system assigns a priority for each protocol. When these routing protocols find the same route, the route found by the protocol with the highest priority is selected.
To set a preference for OSPFv3:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set a preference for OSPFv3. |
preference [ ase ] { preference | route-policy route-policy-name } * |
By default, the preference of OSPFv3 internal routes is 10, and the priority of OSPFv3 external routes is 150. |
Because OSPFv3 is a link state routing protocol, it cannot directly filter LSAs to be advertised. OSPFv3 filters only redistributed routes. Only routes that are not filtered out can be advertised in LSAs.
Executing the import-route or default-route-advertise command on a router makes it become an ASBR.
IMPORTANT: The import-route bgp4+ command redistributes only EBGP routes. Because the import-route bgp4+ allow-ibgp command redistributes both EBGP and IBGP routes, and might cause routing loops, use it with caution. |
Redistributing routes from another routing protocol
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure OSPFv3 to redistribute routes from other routing protocols. |
import-route protocol [ as-number ] [ process-id | all-processes | allow-ibgp ] [ allow-direct | cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] * |
By default, route redistribution is disabled. |
4. (Optional.) Configure OSPFv3 to filter redistributed routes. |
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } export [ protocol [ process-id ] ] |
By default, OSPFv3 accepts all redistributed routes. This command filters only routes redistributed with the import-route command. If the import-route command is not configured, executing this command does not take effect. |
Redistributing a default route
The import-route command cannot redistribute a default external route. Perform this task to redistribute a default route.
To redistribute a default route:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Redistribute a default route. |
default-route-advertise [ [ always | permit-calculate-other ] | cost cost-value | route-policy route-policy-name | tag tag | type type ] * |
By default, no default route is redistributed. |
Setting tags for redistributed routes
Perform this task to set tags for redistributed routes to identify information about protocols. For example, when redistributing IPv6 BGP routes, OSPFv3 uses tags to identify AS IDs.
To set a tag for redistributed routes:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set a tag for redistributed routes. |
default tag tag |
By default, the tag of redistributed routes is 1. |
This section describes configurations of OSPFv3 timers, interface DR priority, and the logging of neighbor state changes.
Before you tune and optimize OSPFv3 networks, perform the following tasks:
· Enable OSPFv3.
Setting OSPFv3 timers
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the hello interval. |
ospfv3 timer hello seconds [ instance instance-id ] |
By default, the hello interval on P2P and broadcast interfaces is 10 seconds. |
4. Set the dead interval. |
ospfv3 timer dead seconds [ instance instance-id ] |
By default, the dead interval on P2P and broadcast interfaces is 40 seconds. The dead interval set on neighboring interfaces cannot be too short. Otherwise, a neighbor is easily considered down. |
5. Set the poll interval. |
ospfv3 timer poll seconds [ instance instance-id ] |
By default, the poll interval is 120 seconds. |
6. Set the LSA retransmission interval. |
ospfv3 timer retransmit interval [ instance instance-id ] |
The default setting is 5 seconds. The LSA retransmission interval cannot be too short. Otherwise, unnecessary retransmissions will occur. |
Each LSA in the LSDB has an age that is incremented by 1 every second, but the age does not change during transmission. Therefore, it is necessary to add a transmission delay into the age time, especially for low-speed links.
To set the LSA transmission delay on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the LSA transmission delay. |
ospfv3 trans-delay seconds [ instance instance-id ] |
By default, the LSA transmission delay is 1 second. |
LSDB changes result in SPF calculations. When the topology changes frequently, a large amount of network and router resources are occupied by SPF calculation. You can adjust the SPF calculation interval to reduce the impact.
For a stable network, the minimum interval is used. If network changes become frequent, the SPF calculation interval is incremented by the incremental interval × 2n-2 for each calculation until the maximum interval is reached. The value n is the number of calculation times.
To set SPF calculation interval:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the SPF calculation interval. |
spf-schedule-interval maximum-interval [ minimum-interval [ incremental-interval ] ] |
By default: · The maximum interval is 5 seconds. · The minimum interval is 50 milliseconds. · The incremental interval is 200 milliseconds. |
You can adjust the LSA generation interval to protect network resources and routers from being over consumed by frequent network changes.
For a stable network, the minimum interval is used. If network changes become frequent, the LSA generation interval is incremented by the incremental interval × 2n-2 for each generation until the maximum interval is reached. The value n is the number of generation times.
To set the LSA generation interval:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the LSA generation interval. |
lsa-generation-interval maximum-interval [ minimum-interval [ incremental-interval ] ] |
By default, the maximum interval is 5 seconds, the minimum interval is 0 milliseconds, and the incremental interval is 0 milliseconds. |
The router priority is used for DR election. Interfaces having the priority 0 cannot become a DR or BDR.
To configure a DR priority for an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set a router priority. |
ospfv3 dr-priority priority [ instance instance-id ] |
The default router priority is 1. |
When LSAs are few in DD packets, it is unnecessary to check the MTU in DD packets to improve efficiency.
To ignore MTU check for DD packets:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Ignore MTU check for DD packets. |
ospfv3 mtu-ignore [ instance instance-id ] |
By default, OSPFv3 does not ignore MTU check for DD packets. |
After an OSPFv3 interface is set to silent, direct routes of the interface can still be advertised in Intra-Area-Prefix LSAs through other interfaces, but other OSPFv3 packets cannot be advertised. No neighboring relationship can be established on the interface. This feature can enhance the adaptability of OSPFv3 networking.
To disable interfaces from receiving and sending OSPFv3 packets:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Disable interfaces from receiving and sending OSPFv3 packets. |
silent-interface { interface-type interface-number | all } |
By default, the interfaces are able to receive and send OSPFv3 packets. This command disables only the interfaces associated with the current process. However, multiple OSPFv3 processes can disable the same interface from receiving and sending OSPFv3 packets. |
With this feature enabled, the router delivers logs about neighbor state changes to its information center. The information center processes logs according to user-defined output rules (whether to output logs and where to output). For more information about the information center, see Network Management and Monitoring Configuration Guide.
To enable the logging of neighbor state changes:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the logging of neighbor state changes. |
log-peer-change |
By default, this feature is enabled. |
This task involves the following configurations:
· Bind an OSPFv3 process to MIB so that you can use network management software to manage the specified OSPFv3 process.
· Enable SNMP notifications for OSPFv3 to report important events.
· Set the SNMP notification output interval and the maximum number of SNMP notifications that can be output at each interval.
To report critical OSPFv3 events to an NMS, enable SNMP notifications for OSPFv3. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
The standard OSPFv3 MIB provides only single-instance MIB objects. To identify multiple OSPFv3 processes in the standard OSPFv3 MIB, you must assign a unique context name to each OSPFv3 process.
Context is a method introduced to SNMPv3 for multiple-instance management. For SNMPv1/v2c, you must specify a community name as a context name for protocol identification.
To configure OSPFv3 network management:
Command |
Remarks |
system-view |
N/A |
2. Bind MIB to an OSPFv3 process. |
ospfv3 mib-binding process-id |
By default, MIB is bound to the process with the smallest process ID. |
3. Enable SNMP notifications for OSPFv3. |
snmp-agent trap enable ospfv3 [ grrestarter-status-change | grhelper-status-change | if-state-change | if-cfg-error | if-bad-pkt | neighbor-state-change | nssatranslator-status-change | virtif-bad-pkt | virtif-cfg-error | virtif-state-change | virtgrhelper-status-change | virtneighbor-state-change ]* |
By default, SNMP notifications for OSPFv3 are enabled. |
4. Enter OSPFv3 view. |
N/A |
5. Configure an SNMP context for the OSPFv3 process. |
snmp context-name context-name |
By default, no SNMP context is configured for the OSPFv3 process. |
6. (Optional.) Set the SNMP notification output interval and the maximum number of SNMP notifications that can be output at each interval. |
snmp trap rate-limit interval trap-interval count trap-number |
By default, OSPFv3 outputs a maximum of seven SNMP notifications within 10 seconds. |
Setting the LSU transmit rate
Sending large numbers of LSU packets affects router performance and consumes a large amount of network bandwidth. You can configure the router to send LSU packets at an interval and to limit the maximum number of LSU packets sent out of an OSPFv3 interface at each interval.
To set the LSU transmit rate:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the LSU transmit rate. |
transmit-pacing interval interval count count |
By default, an OSPFv3 interface sends a maximum of three LSU packets every 20 milliseconds. |
Configuring stub routers
A stub router is used for traffic control. It reports its status as a stub router to neighboring OSPFv3 routers. The neighboring routers can have a route to the stub router, but they do not use the stub router to forward data.
Use either of the following methods to configure a router as a stub router:
· Clear the R-bit of the Option field in Type-1 LSAs. When the R-bit is clear, the OSPFv3 router can participate in OSPFv3 topology distribution without forwarding traffic.
· Use the OSPFv3 max-metric router LSA feature. This feature enables OSPFv3 to advertise its locally generated Type-1 LSAs with a maximum cost of 65535. Neighbors do not send packets to the stub router as long as they have a route with a smaller cost.
To configure a router as a stub router:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the router as a stub router. |
· Method 1: · Method 2: |
By default, the router is not configured as a stub router. A stub router is not related to a stub area. |
By default, an OSPFv3 interface advertises all of its prefixes in LSAs. To speed up OSPFv3 convergence, you can suppress interfaces from advertising all of their prefixes. This feature helps improve network security by preventing IP routing to the suppressed networks.
When prefix suppression is enabled:
· OSPFv3 does not advertise the prefixes of suppressed interfaces in Type-8 LSAs.
· On broadcast and NBMA networks, the DR does not advertise the prefixes of suppressed interfaces in Type-9 LSAs that reference Type-2 LSAs.
· On P2P and P2MP networks, OSPFv3 does not advertise the prefixes of suppressed interfaces in Type-9 LSAs that reference Type-1 LSAs.
IMPORTANT: As a best practice, configure prefix suppression on all OSPFv3 routers if you want to use prefix suppression. |
Configuring prefix suppression for an OSPFv3 process
Enabling prefix suppression for an OSPFv3 process does not suppress the prefixes of loopback interfaces and passive interfaces.
To configure prefix suppression for an OSPFv3 process:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable prefix suppression for the OSPFv3 process. |
prefix-suppression |
By default, prefix suppression is disabled for an OSPFv3 process. |
Configuring prefix suppression for an interface
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable prefix suppression for the interface. |
ospfv3 prefix-suppression [ disable ] [ instance instance-id ] |
By default, prefix suppression is disabled for an interface. |
OSPFv3 logs include route calculation logs, neighbor logs, and LSA aging logs.
To set the maximum number of OSPFv3 logs:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Set the maximum number of OSPFv3 logs. |
event-log { lsa-flush | peer | spf } size count |
By default, the maximum number of LSA aging logs, neighbor logs, or route calculation logs is 10. |
Configuring OSPFv3 GR
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process:
· GR restarter—Graceful restarting router. It must be Graceful Restart capable.
· GR helper—The neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
To prevent service interruption after a master/backup switchover, a GR restarter running OSPFv3 must perform the following tasks:
· Keep the GR restarter forwarding entries stable during reboot.
· Establish all adjacencies and obtain complete topology information after reboot.
After the active/standby switchover, the GR restarter sends a Grace LSA to tell its neighbors that it performs a GR. Upon receiving the Grace LSA, the neighbors with the GR helper capability enter the helper mode (and are called GR helpers). Then, the GR restarter retrieves its adjacencies and LSDB with the help of the GR helpers.
Configuring GR restarter
You can configure the GR restarter capability on a GR restarter.
IMPORTANT: You cannot enable OSPFv3 NSR on a device that acts as GR restarter. |
To configure GR restarter:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the GR capability. |
graceful-restart enable [ global | planned-only ] * |
By default, OSPFv3 GR restarter capability is disabled. |
4. (Optional.) Set the GR interval. |
graceful-restart interval interval |
By default, the GR interval is 120 seconds. |
Configuring GR helper
You can configure the GR helper capability on a GR helper.
To configure GR helper:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the GR helper capability. |
graceful-restart helper enable [ planned-only ] |
By default, the GR helper capability is enabled. |
4. Enable strict LSA checking. |
graceful-restart helper strict-lsa-checking |
By default, strict LSA checking is disabled. |
Triggering OSPFv3 GR
OSPFv3 GR is triggered by an active/standby switchover or when the following command is executed.
To trigger OSPFv3 GR, perform the following command in user view:
Task |
Command |
Trigger OSPFv3 GR. |
reset ospfv3 [ process-id ] process graceful-restart |
Configuring OSPFv3 NSR
Nonstop routing (NSR) backs up OSPFv3 link state information from the active process to the standby process. After an active/standby switchover, NSR can complete link state recovery and route regeneration without tearing down adjacencies or impacting forwarding services.
NSR does not require the cooperation of neighboring devices to recover routing information, and it is typically used more often than GR.
IMPORTANT: A device that has OSPFv3 NSR enabled cannot act as GR restarter. |
To enable OSPFv3 NSR:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
non-stop-routing |
By default, OSPFv3 NSR is disabled. This command takes effect only for the current process. As a best practice, enable OSPFv3 NSR for each process if multiple OSPFv3 processes exist. |
Configuring BFD for OSPFv3
After discovering neighbors by sending hello packets, OSPFv3 notifies BFD of the neighbor addresses, and BFD uses these addresses to establish sessions. Before a BFD session is established, it is in the down state. In this state, BFD control packets are sent at an interval of no less than 1 second to reduce BFD control packet traffic. After the BFD session is established, BFD control packets are sent at the negotiated interval, thereby implementing fast fault detection.
To configure BFD for OSPFv3, you need to configure OSPFv3 first.
To configure BFD for OSPFv3:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
4. Quit the OSPFv3 view. |
quit |
N/A |
5. Enter interface view. |
N/A |
6. Enable an OSPFv3 process on the interface. |
N/A |
7. Enable BFD on the interface. |
ospfv3 bfd enable [ instance instance-id ] |
By default, BFD is disabled on the OSPFv3 interface. |
Configuring OSPFv3 FRR
A primary link failure can cause packet loss and even a routing loop until OSPFv3 completes routing convergence based on the new network topology. OSPFv3 FRR enables fast rerouting to minimize the failover time.
Figure 1 Network diagram for OSPFv3 FRR
As shown in Figure 1, configure FRR on Router B. OSPFv3 FRR automatically calculates a backup next hop or specifies a backup next hop by using a routing policy. When the primary link fails, OSPFv3 directs packets to the backup next hop. At the same time, OSPFv3 calculates the shortest path based on the new network topology. It forwards packets over the path after network convergence.
You can configure OSPFv3 FRR to calculate a backup next hop by using the loop free alternate (LFA) algorithm, or specify a backup next hop by using a routing policy.
Before you configure OSPFv3 FRR, perform the following tasks:
· Configure IPv6 addresses for interfaces to ensure IP connectivity between neighboring nodes.
· Enable OSPFv3.
· Make sure the backup next hop is reachable.
Configuration guidelines
Do not use the fast-reroute lfa command together with the vlink-peer command.
Configuration procedure
Configuring OSPFv3 FRR to calculate a backup next hop using the LFA algorithm
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. (Optional.) Disable LFA on an interface. |
ospfv3 fast-reroute lfa-backup exclude |
By default, the interface on which LFA is enabled can be selected as a backup interface. |
4. Return to system view. |
quit |
N/A |
5. Enter OSPFv3 view. |
N/A |
6. Enable OSPFv3 FRR to calculate a backup next hop by using the LFA algorithm. |
fast-reroute lfa [ abr-only ] |
By default, OSPFv3 FRR is disabled. If abr-only is specified, the route to the ABR is selected as the backup path. |
Configuring OSPFv3 FRR to specify a backup next hop using a routing policy
Before you perform this task, use the apply ipv6 fast-reroute backup-interface command to specify a backup next hop in the routing policy to be used. For more information about the apply ipv6 fast-reroute backup-interface command and routing policy configuration, see "Configuring routing policies."
To configure OSPFv3 FRR to specify a backup next hop using a routing policy:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
By default, the interface is enabled with LFA and it can be selected as a backup interface. |
quit |
N/A |
N/A |
6. Enable OSPFv3 FRR to specify a backup next hop by using a routing policy. |
fast-reroute route-policy route-policy-name |
By default, OSPFv3 FRR is disabled. |
Configuring BFD for OSPFv3 FRR
By default, OSPFv3 FRR does not use BFD to detect primary link failures. To speed up OSPFv3 convergence, enable BFD for OSPFv3 FRR to detect primary link failures.
To configure BFD control packet mode for OSPFv3 FRR:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable BFD control packet mode for OSPFv3 FRR. |
ospfv3 primary-path-detect bfd ctrl [ instance instance-id ] |
By default, BFD control packet mode for OSPFv3 FRR is disabled. |
To configure BFD echo packet mode for OSPFv3 FRR:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the source IPv6 address of BFD echo packets. |
bfd echo-source-ipv6 ipv6-address |
By default, the source IPv6 address of BFD echo packets is not configured. The source IPv6 address cannot be on the same network segment as any local interface's IP address. For more information about this command, see High Availability Command Reference. |
3. Enter interface view. |
N/A |
4. Enable BFD echo packet mode for OSPFv3 FRR. |
ospfv3 primary-path-detect bfd echo [ instance instance-id ] |
By default, BFD echo packet mode for OSPFv3 FRR is disabled. |
Applying an IPsec profile
To protect routing information and prevent attacks, OSPFv3 can authenticate protocol packets by using an IPsec profile. For more information about IPsec profiles, see Security Configuration Guide.
Outbound OSPFv3 packets carry the Security Parameter Index (SPI) defined in the relevant IPsec profile. A device compares the SPI carried in a received packet with the configured IPsec profile. If they match, the device accepts the packet. Otherwise, the device discards the packet and will not establish a neighbor relationship with the sending device.
You can configure an IPsec profile for an area, an interface, a virtual link, or a sham link.
· To implement area-based IPsec protection, configure the same IPsec profile on the routers in the target area.
· To implement interface-based IPsec protection, configure the same IPsec profile on the interfaces between two neighboring routers.
· To implement virtual link-based IPsec protection, configure the same IPsec profile on the two routers connected over the virtual link.
· To implement sham link-based IPsec protection, configure the same IPsec profile on the two routers connected over the sham link. For more information about sham links, see MPLS Configuration Guide.
· If an interface and its area each have an IPsec profile configured, the interface uses its own IPsec profile.
· If a virtual link and area 0 each have an IPsec profile configured, the virtual link uses its own IPsec profile.
· If a sham link and its area have an IPsec profile configured, the sham link uses its own IPsec profile.
To apply an IPsec profile to an area:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Apply an IPsec profile to the area. |
enable ipsec-profile profile-name |
By default, no IPsec profile is applied. |
To apply an IPsec profile to an interface:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Apply an IPsec profile to the interface. |
ospfv3 ipsec-profile profile-name |
To apply an IPsec profile to a virtual link:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Apply an IPsec profile to a virtual link. |
vlink-peer router-id [ dead seconds | hello seconds | instance instance-id | retransmit seconds | trans-delay seconds | ipsec-profile profile-name ] * |
To apply an IPsec profile to a sham link:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
area area-id |
N/A |
4. Apply an IPsec profile to a sham link. |
sham-link source-ipv6-address destination-ipv6-address [ cost cost-value | dead dead-interval | hello hello-interval | instance instance-id | ipsec-profile profile-name | retransmit retrans-interval | trans-delay delay ] * |
Task |
Command |
Display information about the routes to OSPFv3 ABR and ASBR. |
display ospfv3 [ process-id ] abr-asbr |
Display summary route information on the OSPFv3 ABR. |
display ospfv3 [ process-id ] [ area area-id ] abr-summary [ ipv6-address prefix-length ] [ verbose ] |
Display summary route information on the OSPFv3 ASBR. |
display ospfv3 [ process-id ] asbr-summary [ ipv6-address prefix-length ] [ verbose ] |
Display OSPFv3 log information. |
display ospfv3 [ process-id ] event-log { lsa-flush | peer | spf } |
Display OSPFv3 process information. |
display ospfv3 [ process-id ] [ verbose ] |
Display OSPFv3 GR information. |
display ospfv3 [ process-id ] graceful-restart [ verbose ] |
Display OSPFv3 NSR information. |
display ospfv3 [ process-id ] non-stop-routing |
Display OSPFv3 interface information. |
display ospfv3 [ process-id ] interface [ interface-type interface-number | verbose ] |
Display OSPFv3 LSDB information. |
display ospfv3 [ process-id ] lsdb [ { external | grace | inter-prefix | inter-router | intra-prefix | link | network | nssa | router | unknown [ type ] } [ link-state-id ] [ originate-router router-id | self-originate ] | statistics | total | verbose ] |
Display OSPFv3 next hop information. |
display ospfv3 [ process-id ] nexthop |
Display OSPFv3 neighbor information. |
display ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id | statistics ] |
Display OSPFv3 request list information. |
display ospfv3 [ process-id ] [ area area-id ] request-queue [ interface-type interface-number ] [ neighbor-id ] |
Display OSPFv3 retransmission list information. |
display ospfv3 [ process-id ] [ area area-id ] retrans-queue [ interface-type interface-number ] [ neighbor-id ] |
Display OSPFv3 routing information. |
display ospfv3 [ process-id ] routing [ ipv6-address prefix-length ] |
Display OSPFv3 topology information. |
display ospfv3 [ process-id ] [ area area-id ] spf-tree [ verbose ] |
Display OSPFv3 statistics. |
display ospfv3 [ process-id ] statistics [ error ] |
Display OSPFv3 virtual link information. |
display ospfv3 [ process-id ] vlink |
Restart an OSPFv3 process. |
reset ospfv3 [ process-id ] process [ graceful-restart ] |
Restart OSPFv3 route redistribution. |
reset ospfv3 [ process-id ] redistribution |
Clear OSPFv3 statistics. |
reset ospfv3 [ process-id ] statistics |
Clear OSPFv3 logs. |
reset ospfv3 [ process-id ] event-log [ lsa-flush | peer | spf ] |
OSPFv3 configuration examples
Network requirements
As shown in Figure 2:
· Enable OSPFv3 on all routers.
· Split the AS into three areas.
· Configure Router B and Router C as ABRs to forward routing information between areas.
· Configure Area 2 as a stub area to reduce LSAs in the area without affecting route reachability.
1. Configure IPv6 addresses for interfaces. (Details not shown.)
2. Configure basic OSPFv3:
# On Router A, enable OSPFv3 and specify the router ID as 1.1.1.1.
[RouterA] ospfv3 1
[RouterA-ospfv3-1] router-id 1.1.1.1
[RouterA-ospfv3-1] quit
[RouterA] interface gigabitethernet 1/1/1
[RouterA-GigabitEthernet1/1/1] ospfv3 1 area 1
[RouterA-GigabitEthernet1/1/1] quit
[RouterA] interface gigabitethernet 1/1/2
[RouterA-GigabitEthernet1/1/2] ospfv3 1 area 1
[RouterA-GigabitEthernet1/1/2] quit
# On Router B, enable OSPFv3 and specify the router ID as 2.2.2.2.
<RouterB> system-view
[RouterB] ospfv3 1
[RouterB-ospfv3-1] router-id 2.2.2.2
[RouterB-ospfv3-1] quit
[RouterB] interface gigabitethernet 1/1/1
[RouterB-GigabitEthernet1/1/1] ospfv3 1 area 0
[RouterB-GigabitEthernet1/1/1] quit
[RouterB] interface gigabitethernet 1/1/2
[RouterB-GigabitEthernet1/1/2] ospfv3 1 area 1
[RouterB-GigabitEthernet1/1/2] quit
# On Router C, enable OSPFv3 and specify the router ID as 3.3.3.3.
<RouterC> system-view
[RouterC] ospfv3 1
[RouterC-ospfv3-1] router-id 3.3.3.3
[RouterC-ospfv3-1] quit
[RouterC] interface gigabitethernet 1/1/1
[RouterC-GigabitEthernet1/1/1] ospfv3 1 area 0
[RouterC-GigabitEthernet1/1/1] quit
[RouterC] interface gigabitethernet 1/1/2
[RouterC-GigabitEthernet1/1/2] ospfv3 1 area 2
[RouterC-GigabitEthernet1/1/2] quit
# On Router D, enable OSPFv3 and specify the router ID as 4.4.4.4.
<RouterD> system-view
[RouterD] ospfv3 1
[RouterD-ospfv3-1] router-id 4.4.4.4
[RouterD-ospfv3-1] quit
[RouterD] interface gigabitethernet 1/1/2
[RouterD-GigabitEthernet1/1/2] ospfv3 1 area 2
[RouterD-GigabitEthernet1/1/2] quit
# Display OSPFv3 neighbors on Router B.
[RouterB] display ospfv3 peer
OSPFv3 Process 1 with Router ID 2.2.2.2
Area: 0.0.0.0
Router ID Pri State Dead-Time InstID Interface
3.3.3.3 1 Full/BDR 00:00:40 0 GE1/1/1
Area: 0.0.0.1
1.1.1.1 1 Full/DR 00:00:40 0 GE1/1/2
# Display OSPFv3 neighbors on Router C.
[RouterC] display ospfv3 peer
OSPFv3 Process 1 with Router ID 3.3.3.3
Area: 0.0.0.0
2.2.2.2 1 Full/DR 00:00:40 0 GE1/1/1
Area: 0.0.0.2
4.4.4.4 1 Full/BDR 00:00:40 0 GE1/1/2
# Display OSPFv3 neighbors on Router D.
[RouterD] display ospfv3 routing
OSPFv3 Process 1 with Router ID 4.4.4.4
I - Intra area route, E1 - Type 1 external route, N1 - Type 1 NSSA route
IA - Inter area route, E2 - Type 2 external route, N2 - Type 2 NSSA route
* - Selected route
*Destination: 2001::/64
Type : IA Cost : 2
NextHop : FE80::F40D:0:93D0:1 Interface: GE1/1/2
AdvRouter : 3.3.3.3 Area : 0.0.0.2
Preference : 10
*Destination: 2001:1::/64
Type : IA Cost : 3
Preference : 10
*Destination: 2001:2::/64
Type : I Cost : 1
Nexthop : :: Interface: GE1/1/2
AdvRouter : 4.4.4.4 Area : 0.0.0.2
Preference : 10
*Destination: 2001:3::/64
Type : IA Cost : 4
Preference : 10
Total: 4
Intra area: 1 Inter area: 3 ASE: 0 NSSA: 0
3. Configure Area 2 as a stub area:
# Configure Router D.
[RouterD] ospfv3
[RouterD-ospfv3-1] area 2
[RouterD-ospfv3-1-area-0.0.0.2] stub
[RouterD-ospfv3-1-area-0.0.0.2] quit
# Configure Router C, and specify the cost of the default route sent to the stub area as 10.
[RouterC] ospfv3
[RouterC-ospfv3-1] area 2
[RouterC-ospfv3-1-area-0.0.0.2] stub
[RouterC-ospfv3-1-area-0.0.0.2] default-cost 10
# Display OSPFv3 routing table on Router D.
* - Selected route
*Destination: ::/0
Type : IA Cost : 11
Preference : 10
Type : IA Cost : 2
Preference : 10
Type : IA Cost : 3
Preference : 10
Type : I Cost : 1
Preference : 10
Type : IA Cost : 4
Preference : 10
Total: 5
Intra area: 1 Inter area: 4 ASE: 0 NSSA: 0
The output shows that a default route is added and its cost is the cost of a direct route plus the configured cost.
4. Configure Area 2 as a totally stub area to further reduce the stub area routing table size:
# Configure Area 2 as a totally stub area on Router C.
[RouterC-ospfv3-1-area-0.0.0.2] stub no-summary
* - Selected route
*Destination: ::/0
Type : IA Cost : 11
Preference : 10
Type : I Cost : 1
Preference : 10
Total: 2
Intra area: 1 Inter area: 1 ASE: 0 NSSA: 0
The output shows that route entries are reduced. All indirect routes are removed, except the default route.
As shown in Figure 3:
· Configure OSPFv3 on all routers and split the AS into three areas.
· Configure Area 1 as an NSSA area and configure Router A as an ASBR to redistribute static routes into the AS.
2. Configure basic OSPFv3 (see "OSPFv3 stub area configuration example").
3. Configure Area 1 as an NSSA area:
# Configure Router A.
[RouterA] ospfv3
[RouterA-ospfv3-1] area 1
[RouterA-ospfv3-1-area-0.0.0.1] nssa
[RouterA-ospfv3-1-area-0.0.0.1] quit
# Configure Router B.
[RouterB] ospfv3
[RouterB-ospfv3-1] area 1
[RouterB-ospfv3-1-area-0.0.0.1] nssa
[RouterB-ospfv3-1-area-0.0.0.1] quit
# Display OSPFv3 routing information on Router A.
[RouterA] display ospfv3 1 routing
OSPFv3 Process 1 with Router ID 1.1.1.1
* - Selected route
Type : IA Cost : 2
NextHop : FE80::20C:29FF:FE74:59C6 Interface: GE1/1/1
AdvRouter : 2.2.2.2 Area : 0.0.0.1
Preference : 10
Type : I Cost : 1
Nexthop : :: Interface: GE1/1/1
AdvRouter : 1.1.1.1 Area : 0.0.0.1
Preference : 10
Type : IA Cost : 3
Preference : 10
Total: 3
Intra area: 1 Inter area: 2 ASE: 0 NSSA: 0
4. Configure route redistribution:
# Configure an IPv6 static route, and configure OSPFv3 to redistribute the static route on Router A.
[RouterA] ipv6 route-static 1234:: 64 null 0
[RouterA] ospfv3 1
[RouterA-ospfv3-1] import-route static
# Display OSPFv3 routing information on Router D.
[RouterD] display ospfv3 1 routing
* - Selected route
Type : IA Cost : 2
NextHop : FE80::20C:29FF:FEB9:F2EF Interface: GE1/1/2
Preference : 10
Type : IA Cost : 3
Preference : 10
Type : I Cost : 1
NextHop : :: Interface: GE1/1/2
Preference : 10
*Destination: 1234::/64
Type : E2 Cost : 1
AdvRouter : 2.2.2.2 Area : 0.0.0.2
Preference : 10
Total: 4
Intra area: 1 Inter area: 2 ASE: 1 NSSA: 0
The output shows an AS external route imported from the NSSA area exists on Router D.
As shown in Figure 4:
· Configure router priority 100 for Router A, the highest priority on the network, so it will become the DR.
· Configure router priority 2 for Router C, the second highest priority on the network, so it will become the BDR.
· Configure router priority 0 for Router B, so it cannot become a DR or BDR.
· Router D uses the default router priority 1.
# On Router A, enable OSPFv3, and specify the router ID as 1.1.1.1.
[RouterA] ospfv3
[RouterA-GigabitEthernet1/1/1] ospfv3 1 area 0
# On Router B, enable OSPFv3, and specify the router ID as 2.2.2.2.
[RouterB] ospfv3
# On Router C, enable OSPFv3, and specify the router ID as 3.3.3.3.
[RouterC] ospfv3
# On Router D, enable OSPFv3, and specify the router ID as 4.4.4.4.
[RouterD] ospfv3
[RouterD] interface gigabitethernet 1/1/1
[RouterD-GigabitEthernet1/1/1] ospfv3 1 area 0
[RouterD-GigabitEthernet1/1/1] quit
# Display neighbors on Router A. The routers have the same default router priority 1, so Router D (the router with the highest router ID) is elected as the DR, and Router C is the BDR.
[RouterA] display ospfv3 peer
Area: 0.0.0.0
2.2.2.2 0 2-Way/DROther 00:00:36 0 GE1/1/1
3.3.3.3 2 Full/BDR 00:00:35 0 GE1/1/1
4.4.4.4 1 Full/DR 00:00:33 0 GE1/1/1
# Display neighbors on Router D. The neighbor states are all full.
[RouterD] display ospfv3 peer
Area: 0.0.0.0
1.1.1.1 100 Full/DROther 00:00:30 0 GE1/1/1
2.2.2.2 0 Full/DROther 00:00:37 0 GE1/1/1
3.3.3.3 2 Full/BDR 00:00:31 0 GE1/1/1
3. Configure router priorities for interfaces:
# Set the router priority to 100 for the interface GigabitEthernet 1/1/1 of Router A.
[RouterA-GigabitEthernet1/1/1] ospfv3 dr-priority 100
# Set the router priority to 0 for the interface GigabitEthernet 1/1/1 of Router B.
[RouterB-GigabitEthernet1/1/1] ospfv3 dr-priority 0
# Set the router priority to 2 for the interface GigabitEthernet 1/1/1 of Router C.
[RouterC-GigabitEthernet1/1/1] ospfv3 dr-priority 2
# Display neighbors on Router A. The output shows that the router priorities have been changed, but the DR and BDR are not changed.
Area: 0.0.0.0
2.2.2.2 1 2-Way/DROther 00:00:36 0 GE1/1/1
3.3.3.3 1 Full/BDR 00:00:35 0 GE1/1/1
Area: 0.0.0.0
1.1.1.1 1 Full/DROther 00:00:30 0 GE1/1/1
2.2.2.2 1 Full/DROther 00:00:37 0 GE1/1/1
3.3.3.3 1 Full/BDR 00:00:31 0 GE1/1/1
The output shows that the DR is still Router D.
4. Enable DR/BDR election:
# Perform the shutdown and undo shutdown commands on each interface to enable a new DR/BD election. (Details not shown.)
# Display neighbors on Router A. The output shows that Router C becomes the BDR.
Area: 0.0.0.0
2.2.2.2 0 Full/DROther 00:00:36 0 GE1/1/1
4.4.4.4 1 Full/DROther 00:00:33 0 GE1/1/1
Area: 0.0.0.0
1.1.1.1 100 Full/DR 00:00:30 0 GE1/1/1
2.2.2.2 0 2-Way/DROther 00:00:37 0 GE1/1/1
The output shows that Router A becomes the DR.
As shown in Figure 5:
· Router A, Router B, and Router C are in Area 2.
· OSPFv3 process 1 and OSPFv3 process 2 run on Router B. Router B communicates with Router A and Router C through OSPFv3 process 1 and OSPFv3 process 2.
· Configure OSPFv3 process 2 to redistribute direct routes and the routes from OSPFv3 process 1 on Router B, and set the default metric for redistributed routes to 3. Router C can then learn the routes destined for 1::0/64 and 2::0/64, and Router A cannot learn the routes destined for 3::0/64 or 4::0/64.
# Enable OSPFv3 process 1 on Router A.
[RouterA] ospfv3 1
[RouterA-GigabitEthernet1/1/2] ospfv3 1 area 2
[RouterA-GigabitEthernet1/1/1] ospfv3 1 area 2
# Enable OSPFv3 process 1 and OSPFv3 process 2 on Router B.
[RouterB] ospfv3 1
[RouterB-GigabitEthernet1/1/2] ospfv3 1 area 2
[RouterB] ospfv3 2
[RouterB-ospfv3-2] router-id 3.3.3.3
[RouterB-ospfv3-2] quit
[RouterB-GigabitEthernet1/1/1] ospfv3 2 area 2
# Enable OSPFv3 process 2 on Router C.
[RouterC] ospfv3 2
[RouterC-ospfv3-2] router-id 4.4.4.4
[RouterC-ospfv3-2] quit
[RouterC-GigabitEthernet1/1/2] ospfv3 2 area 2
[RouterC-GigabitEthernet1/1/1] ospfv3 2 area 2
# Display the routing table on Router C.
[RouterC] display ipv6 routing-table
Destinations : 7 Routes : 7
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 3::/64 Protocol : Direct
NextHop : :: Preference: 0
Interface : GE1/1/2 Cost : 0
Destination: 3::2/128 Protocol : Direct
Destination: 4::/64 Protocol : Direct
Interface : GE1/1/1 Cost : 0
Destination: 4::1/128 Protocol : Direct
Destination: FE80::/10 Protocol : Direct
Interface : NULL0 Cost : 0
Destination: FF00::/8 Protocol : Direct
Interface : NULL0
3. Configure OSPFv3 route redistribution:
# Configure OSPFv3 process 2 to redistribute direct routes and the routes from OSPFv3 process 1 on Router B.
[RouterB] ospfv3 2
[RouterB-ospfv3-2] default cost 3
[RouterB-ospfv3-2] import-route ospfv3 1
[RouterB-ospfv3-2] import-route direct
Destinations : 9 Routes : 9
Destination: 1::/64 Protocol : O_ASE2
NextHop : FE80::200:CFF:FE01:1C03 Preference: 150
Interface : GE1/1/2 Cost : 3
Destination: 2::/64 Protocol : O_ASE2
Interface : NULL0
As shown in Figure 6:
· OSPFv3 process 1 and OSPFv3 process 2 run on Router B. Router B communicates with Router A and Router C through OSPFv3 process 1 and OSPFv3 process 2, respectively.
· On Router A, configure IPv6 addresses 2:1:1::1/64, 2:1:2::1/64, and 2:1:3::1/64 for GigabitEthernet 1/1/1.
· On Router B, configure OSPFv3 process 2 to redistribute direct routes and the routes from OSPFv3 process 1. Router C can then learn the routes destined for 2::/64, 2:1:1::/64, 2:1:2::/64, and 2:1:3::/64.
· On Router B, configure route summarization to advertise only summary route 2::/16 to Router C.
2. Configure OSPFv3:
[RouterA] ospfv3 1
[RouterA-GigabitEthernet1/1/1] ipv6 address 2:1:1::1 64
[RouterA-GigabitEthernet1/1/1] ipv6 address 2:1:2::1 64
[RouterA-GigabitEthernet1/1/1] ipv6 address 2:1:3::1 64
[RouterB] ospfv3 1
[RouterB] ospfv3 2
[RouterC] ospfv3 2
[RouterB] ospfv3 2
Destinations : 12 Routes : 12
Interface : GE1/1/2 Cost : 1
Destination: 2:1:1::/64 Protocol : O_ASE2
Destination: 2:1:2::/64 Protocol : O_ASE2
Destination: 2:1:3::/64 Protocol : O_ASE2
NextHop : 3::2 Preference: 0
NextHop : 4::1 Preference: 0
Interface : NULL0
4. Configure ASBR route summarization:
# On Router B, configure OSPFv3 process 2 to advertise a summary route 2::/16.
[RouterB] ospfv3 2
[RouterB-ospfv3-2] asbr-summary 2:: 16
Destination: 2::/16 Protocol : O_ASE2
Interface : NULL0
As shown in Figure 7:
· Router A, Router B, and Router C that reside in the same AS and the same OSPFv3 routing domain are GR capable.
· Router A acts as the GR restarter. Router B and Router C act as GR helpers, and synchronize their LSDBs with Router A through GR.
# On Router A, enable OSPFv3 process 1, enable GR, and set the router ID to 1.1.1.1.
[RouterA] ospfv3 1
[RouterA-ospfv3-1] graceful-restart enable
# On Router B, enable OSPFv3 and set the router ID to 2.2.2.2. (By default, GR helper is enabled on a router.)
[RouterB] ospfv3 1
[RouterB-GigabitEthernet1/1/1] ospfv3 1 area 1
# On Router C, enable OSPFv3 and set the router ID to 3.3.3.3. (By default, GR helper is enabled on a router.)
[RouterC] ospfv3 1
[RouterC-GigabitEthernet1/1/1] ospfv3 1 area 1
# Perform an active/standby switchover on Router A to trigger an OSPFv3 GR operation. (Details not shown.)
As shown in Figure 8, Router S, Router A, and Router B belong to the same AS and OSPFv3 routing domain. Enable OSPFv3 NSR on Router S to ensure correct routing when an active/standby switchover occurs on Router S.
1. Configure IP addresses and subnet masks for interfaces on the routers. (Details not shown.)
2. Configure OSPFv3 on the routers to ensure that Router S, Router A, and Router B can communicate with each other at Layer 3. (Details not shown.)
3. Configure OSPFv3:
# On Router A, enable OSPFv3 and set the router ID to 1.1.1.1.
[RouterA] ospfv3 1
[RouterB] ospfv3 1
# On Router S, enable OSPFv3, set the router ID to 3.3.3.3, and enable NSR.
<RouterS> system-view
[RouterS] ospfv3 1
[RouterS-ospfv3-1] router-id 3.3.3.3
[RouterS-ospfv3-1] non-stop-routing
[RouterS-ospfv3-1] quit
[RouterS] interface gigabitethernet 1/1/1
[RouterS-GigabitEthernet1/1/1] ospfv3 1 area 1
[RouterS-GigabitEthernet1/1/1] quit
[RouterS] interface gigabitethernet 1/1/2
[RouterS-GigabitEthernet1/1/2] ospfv3 1 area 1
[RouterS-GigabitEthernet1/1/2] quit
# Verify the following:
· When an active/standby switchover occurs on Router S, the neighbor relationships and routing information on Router A and Router B have not changed. (Details not shown.)
· The traffic from Router A to Router B has not been impacted. (Details not shown.)
As shown in Figure 9:
· Configure OSPFv3 on Router A, Router B and Router C and configure BFD over the link Router A<—>L2 Switch<—>Router B.
· After the link Router A<—>L2 Switch<—>Router B fails, BFD can quickly detect the failure and notify OSPFv3 of the failure. Then Router A and Router B communicate through Router C.
Device |
IPv6 address |
Router A |
GE1/1/1 |
2001::1/64 |
Router A |
GE1/1/2 |
2001:2::1/64 |
Router B |
GE1/1/1 |
2001::2/64 |
Router B |
GE1/1/2 |
2001:3::2/64 |
Router C |
GE1/1/1 |
2001:2::2/64 |
Router C |
GE1/1/2 |
2001:3::1/64 |
# Enable OSPFv3 and set the router ID to 1.1.1.1 on Router A.
[RouterA] ospfv3 1
[RouterA-GigabitEthernet1/1/2] ospfv3 1 area 0
# Enable OSPFv3 and set the router ID to 2.2.2.2 on Router B.
[RouterB] ospfv3 1
[RouterB-GigabitEthernet1/1/2] ospfv3 1 area 0
# Enable OSPFv3 and set the router ID to 3.3.3.3 on Router C.
[RouterC] ospfv3 1
[RouterC-GigabitEthernet1/1/2] ospfv3 1 area 0
3. Configure BFD:
# Enable BFD and configure BFD parameters on Router A.
[RouterA] bfd session init-mode active
[RouterA-GigabitEthernet1/1/1] ospfv3 bfd enable
[RouterA-GigabitEthernet1/1/1] bfd min-transmit-interval 500
[RouterA-GigabitEthernet1/1/1] bfd min-receive-interval 500
[RouterA-GigabitEthernet1/1/1] bfd detect-multiplier 7
[RouterA-GigabitEthernet1/1/1] return
# Enable BFD and configure BFD parameters on Router B.
[RouterB] bfd session init-mode active
[RouterB-GigabitEthernet1/1/1] ospfv3 bfd enable
[RouterB-GigabitEthernet1/1/1] bfd min-transmit-interval 500
[RouterB-GigabitEthernet1/1/1] bfd min-receive-interval 500
[RouterB-GigabitEthernet1/1/1] bfd detect-multiplier 6
# Display the BFD information on Router A.
<RouterA> display bfd session
Total Session Num: 1 Up Session Num: 1 Init Mode: Active
IPv6 Session Working Under Ctrl Mode:
Local Discr: 1441 Remote Discr: 1450
Source IP: FE80::20F:FF:FE00:1202 (link-local address of GigabitEthernet1/1/1 on Router A)
Destination IP: FE80::20F:FF:FE00:1200 (link-local address of GigabitEthernet1/1/1 on Router B)
Session State: Up Interface: GE1/1/1
Hold Time: 2319ms
# Display routes destined for 2001:4::0/64 on Router A.
<RouterA> display ipv6 routing-table 2001:4::0 64
Summary Count : 1
Destination: 2001:4::/64 Protocol : O_INTRA
NextHop : FE80::20F:FF:FE00:1200 Preference: 10
Interface : GE1/1/1 Cost : 1
The output shows that Router A communicates with Router B through GigabitEthernet 1/1/1. Then the link over GigabitEthernet 1/1/1 fails.
Summary Count : 1
NextHop : FE80::BAAF:67FF:FE27:DCD0 Preference: 10
Interface : GE1/1/2 Cost : 2
The output shows that Router A communicates with Router B through GigabitEthernet 1/1/2.
As shown in Figure 10, Router A, Router B, and Router C reside in the same OSPFv3 domain. Configure OSPFv3 FRR so that when Link A fails, traffic is immediately switched to Link B.
Device |
IP address |
Device |
IP address |
Router A |
GE1/1/1 |
1::1/64 |
Router B |
GE1/1/1 |
3::1/64 |
GE1/1/2 |
2::1/64 |
GE1/1/2 |
2::2/64 |
Loop0 |
10::1/128 |
Loop0 |
20::1/128 |
Router C |
GE1/1/1 |
1::2/64 |
GE1/1/2 |
3::2/64 |
1. Configure IPv6 addresses for interfaces on the routers. (Details not shown.)
2. Configure OSPFv3 on the routers to ensure that Router A, Router B, and Router C can communicate with each other at the network layer. (Details not shown.)
3. Configure OSPFv3 FRR:
You can enable OSPFv3 FRR to either calculate a backup next hop by using the LFA algorithm, or specify a backup next hop by using a routing policy.
¡ (Method 1.) Enable OSPFv3 FRR to calculate a backup next hop by using the LFA algorithm:
[RouterA] ospfv3 1
[RouterA-ospfv3-1] fast-reroute lfa
[RouterB] ospfv3 1
[RouterB-ospfv3-1] fast-reroute lfa
¡ (Method 2.) Enable OSPFv3 FRR to specify a backup next hop by using a routing policy:
[RouterA] ipv6 prefix-list abc index 10 permit 10:: 128
[RouterA] route-policy frr permit node 10
[RouterA-route-policy-frr-10] if-match ipv6 address prefix-list abc
[RouterA-route-policy-frr-10] apply ipv6 fast-reroute backup-interface gigabitethernet 1/1/1 backup-nexthop 1::2
[RouterA-route-policy-frr-10] quit
[RouterA] ospfv3 1
[RouterA-ospfv3-1] fast-reroute route-policy frr
[RouterB] ipv6 prefix-list abc index 10 permit 20:: 128
[RouterB] route-policy frr permit node 10
[RouterB-route-policy-frr-10] if-match ipv6 address prefix-list abc
[RouterB-route-policy-frr-10] apply ipv6 fast-reroute backup-interface gigabitethernet 1/1/1 backup-nexthop 3::2
[RouterB-route-policy-frr-10] quit
[RouterB] ospfv3 1
[RouterB-ospfv3-1] fast-reroute route-policy frr
# Display the route 20::1/128 on Router A to view the backup next hop information.
[RouterA] display ipv6 routing-table 20::1 128 verbose
Summary count : 1
Destination: 20::1/128
Protocol: O_INTRA
Process ID: 1
SubProtID: 0x1 Age: 00h03m45s
Cost: 6 Preference: 10
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
TableID: 0xa OrigAs: 0
NibID: 0x23000005 LastAs: 0
AttrID: 0xffffffff Neighbor: ::
Flags: 0x10041 OrigNextHop: FE80::7685:45FF:FEAD:102
Label: NULL RealNextHop: FE80::7685:45FF:FEAD:102
BkLabel: NULL BkNextHop: FE80::34CD:9FF:FE2F:D02
Tunnel ID: Invalid Interface: GigabitEthernet1/1/2
BkTunnel ID: Invalid BkInterface: GigabitEthernet1/1/1
FtnIndex: 0x0 TrafficIndex: N/A
Connector: N/A
# Display the route 10::1/128 on Router B to view the backup next hop information.
[RouterB] display ipv6 routing-table 10::1 128 verbose
Summary count : 1
Destination: 10::1/128
Protocol: O_INTRA
Process ID: 1
SubProtID: 0x1 Age: 00h03m10s
Cost: 1 Preference: 10
NibID: 0x23000006 LastAs: 0
Flags: 0x10041 OrigNextHop: FE80::34CC:E8FF:FE5B:C02
Label: NULL RealNextHop: FE80::34CC:E8FF:FE5B:C02
BkLabel: NULL BkNextHop: FE80::7685:45FF:FEAD:102
Connector: N/A
OSPFv3 IPsec profile configuration example
As shown in Figure 11, all routers run OSPFv3, and the AS is divided into two areas.
Configure IPsec profiles on the routers to authenticate and encrypt protocol packets.
2. Configure OSPFv3 basic features:
[RouterA] ospfv3 1
[RouterB] ospfv3 1
[RouterC] ospfv3 1
3. Configure OSPFv3 IPsec profiles:
¡ On Router A:
# Create an IPsec transform set named trans.
[RouterA] ipsec transform-set trans
# Specify the encapsulation mode as transport.
[RouterA-ipsec-transform-set-trans] encapsulation-mode transport
# Specify the ESP encryption and authentication algorithms.
[RouterA-ipsec-transform-set-trans] esp encryption-algorithm 3des-cbc
[RouterA-ipsec-transform-set-trans] esp authentication-algorithm md5
# Specify the AH authentication algorithm.
[RouterA-ipsec-transform-set-trans] ah authentication-algorithm md5
[RouterA-ipsec-transform-set-trans] quit
# Create a manual IPsec profile named profile001.
[RouterA] ipsec profile profile001 manual
# Use IPsec transform set trans.
[RouterA-ipsec-profile-profile001-manual] transform-set trans
# Configure the inbound and outbound SPIs for AH.
[RouterA-ipsec-profile-profile001-manual] sa spi inbound ah 100000
[RouterA-ipsec-profile-profile001-manual] sa spi outbound ah 100000
# Configure the inbound and outbound SPIs for ESP.
[RouterA-ipsec-profile-profile001-manual] sa spi inbound esp 200000
[RouterA-ipsec-profile-profile001-manual] sa spi outbound esp 200000
# Configure the inbound and outbound SA keys for AH.
[RouterA-ipsec-profile-profile001-manual] sa string-key inbound ah simple abc
[RouterA-ipsec-profile-profile001-manual] sa string-key outbound ah simple abc
# Configure the inbound and outbound SA keys for ESP.
[RouterA-ipsec-profile-profile001-manual] sa string-key inbound esp simple 123
[RouterA-ipsec-profile-profile001-manual] sa string-key outbound esp simple 123
[RouterA-ipsec-profile-profile001-manual] quit
¡ On Router B:
[RouterB] ipsec transform-set trans
[RouterB-ipsec-transform-set-trans] encapsulation-mode transport
[RouterB-ipsec-transform-set-trans] esp encryption-algorithm 3des-cbc
[RouterB-ipsec-transform-set-trans] esp authentication-algorithm md5
[RouterB-ipsec-transform-set-trans] ah authentication-algorithm md5
[RouterB-ipsec-transform-set-trans] quit
[RouterB] ipsec profile profile001 manual
[RouterB-ipsec-profile-profile001-manual] transform-set trans
[RouterB-ipsec-profile-profile001-manual] sa spi inbound ah 100000
[RouterB-ipsec-profile-profile001-manual] sa spi outbound ah 100000
[RouterB-ipsec-profile-profile001-manual] sa spi inbound esp 200000
[RouterB-ipsec-profile-profile001-manual] sa spi outbound esp 200000
[RouterB-ipsec-profile-profile001-manual] sa string-key inbound ah simple abc
[RouterB-ipsec-profile-profile001-manual] sa string-key outbound ah simple abc
[RouterB-ipsec-profile-profile001-manual] sa string-key inbound esp simple 123
[RouterB-ipsec-profile-profile001-manual] sa string-key outbound esp simple 123
[RouterB-ipsec-profile-profile001-manual] quit
# Create a manual IPsec profile named profile002.
[RouterB] ipsec profile profile002 manual
[RouterB-ipsec-profile-profile002-manual] transform-set trans
[RouterB-ipsec-profile-profile002-manual] sa spi inbound ah 400000
[RouterB-ipsec-profile-profile002-manual] sa spi outbound ah 400000
[RouterB-ipsec-profile-profile002-manual] sa spi inbound esp 256
[RouterB-ipsec-profile-profile002-manual] sa spi outbound esp 256
[RouterB-ipsec-profile-profile002-manual] sa string-key inbound ah simple hello
[RouterB-ipsec-profile-profile002-manual] sa string-key outbound ah simple hello
[RouterB-ipsec-profile-profile002-manual] sa string-key inbound esp simple byebye
[RouterB-ipsec-profile-profile002-manual] sa string-key outbound esp simple byebye
[RouterB-ipsec-profile-profile002-manual] quit
¡ On Router C:
[RouterC] ipsec transform-set trans
[RouterC-ipsec-transform-set-trans] encapsulation-mode transport
[RouterC-ipsec-transform-set-trans] esp encryption-algorithm 3des-cbc
[RouterC-ipsec-transform-set-trans] esp authentication-algorithm md5
[RouterC-ipsec-transform-set-trans] ah authentication-algorithm md5
[RouterC-ipsec-transform-set-trans] quit
[RouterC] ipsec profile profile002 manual
[RouterC-ipsec-profile-profile002-manual] transform-set trans
[RouterC-ipsec-profile-profile002-manual] sa spi inbound ah 400000
[RouterC-ipsec-profile-profile002-manual] sa spi outbound ah 400000
[RouterC-ipsec-profile-profile002-manual] sa spi inbound esp 256
[RouterC-ipsec-profile-profile002-manual] sa spi outbound esp 256
[RouterC-ipsec-profile-profile002-manual] sa string-key inbound ah simple hello
[RouterC-ipsec-profile-profile002-manual] sa string-key outbound ah simple hello
[RouterC-ipsec-profile-profile002-manual] sa string-key inbound esp simple byebye
[RouterC-ipsec-profile-profile002-manual] sa string-key outbound esp simple byebye
[RouterC-ipsec-profile-profile002-manual] quit
4. Apply the IPsec profiles to areas:
[RouterA] ospfv3 1
[RouterA-ospfv3-1-area-0.0.0.1] enable ipsec-profile profile001
[RouterB] ospfv3 1
[RouterB-ospfv3-1] area 0
[RouterB-ospfv3-1-area-0.0.0.0] enable ipsec-profile profile002
[RouterB-ospfv3-1-area-0.0.0.0] quit
[RouterB-ospfv3-1-area-0.0.0.1] enable ipsec-profile profile001
# Configure Router C.
[RouterC] ospfv3 1
[RouterC-ospfv3-1] area 0
[RouterC-ospfv3-1-area-0.0.0.0] enable ipsec-profile profile002
[RouterC-ospfv3-1-area-0.0.0.0] quit
# Verify that OSPFv3 packets between Routers A, B, and C are protected by IPsec. (Details not shown.)
