| 04-VLAN termination configuration | 253.85 KB |
VLAN termination application scenarios
VLAN termination configuration task list
Configuring ambiguous Dot1q termination
Configuring unambiguous Dot1q termination
Configuring ambiguous QinQ termination
Configuring unambiguous QinQ termination
Configuring untagged termination
Configuring default termination
Enabling a VLAN termination-enabled interface to transmit broadcasts and multicasts
Configuring the TPID for VLAN-tagged packets
VLAN termination configuration examples
Unambiguous Dot1q termination configuration example
Ambiguous Dot1q termination configuration example
Configuration example for Dot1q termination supporting PPPoE server
Unambiguous QinQ termination configuration example
Ambiguous QinQ termination configuration example
Configuration example for QinQ termination supporting PPPoE server
Configuring VLAN termination
Overview
VLAN termination typically processes packets that include VLAN tags. A VLAN termination-enabled interface performs the following tasks when receiving a VLAN-tagged packet:
1. Assigns the packet to an interface according to its VLAN tags.
2. Removes the VLAN tags of the packet.
3. Delivers the packet to Layer 3 forwarding or other processing pipelines.
Before sending the packet, the VLAN termination-enabled interface determines whether to add new VLAN tags to the packet, based on the VLAN termination type.
VLAN termination can also process packets that do not include any VLAN tags.
This document uses the following VLAN tag concepts for a packet that has two or more layers of VLAN tags:
· Layer 1 VLAN tag—Specifies the outermost layer of VLAN tags.
· Layer 2 VLAN tag—Specifies the second outermost layer of VLAN tags.
The VLAN IDs of the packets are numbered in the same manner as the VLAN tags.
VLAN termination types
Types of packets to be terminated on the interface |
Tagging status of outgoing packets on the interface |
Dot1q termination |
The packets must meet both of the following requirements: · The packets include one or more layers of VLAN tags. · The outermost VLAN tag matches the configured value. |
Single-tagged |
QinQ termination |
The packets must meet both of the following requirements: · The packets include two or more layers of VLAN tags. · The outermost two layers of tags match the configured values. |
Double-tagged |
Untagged termination |
Untagged packets |
Untagged |
Default termination |
Packets that cannot be processed on any other subinterfaces of the same main interface |
Untagged |
Inter-VLAN communication
Hosts in different VLANs cannot directly communicate with each other. You can use Layer 3 routing to allow all VLANs to communicate. To restrict communication to the specified VLANs, configure VLAN termination on subinterfaces.
As shown in Figure 1, Host A and Host B are in different VLANs. The two hosts can communicate with each other after you perform the following tasks:
1. Specify 1.1.1.1/24 and 1.1.2.1/24 as the gateway IP addresses for Host A and Host B, respectively.
2. On the device, configure VLAN termination on Layer 3 Ethernet subinterfaces GigabitEthernet 1/1/1.1 and GigabitEthernet 1/1/2.1.
Figure 1 VLAN termination for inter-VLAN communication
LAN-WAN communication
Typically, WAN protocols such as Frame Relay and PPP do not recognize VLAN-tagged packets from LANs. Before packets are sent to a WAN, the sending port must locally record the VLAN information and remove VLAN tags from the packets. To do that, configure VLAN termination on subinterfaces.
As shown in Figure 2, a host is located on a customer network and wants to access the WAN network through a PPPoE connection. CVLAN and SVLAN represent the VLAN on the customer network and service provider network, respectively.
To access the WAN network, a packet originating from the host is processed as follows:
1. Layer 2 Switch A adds a CVLAN tag to the packet and sends the packet.
2. Layer 2 Switch B adds an SVLAN tag to the packet on the QinQ-enabled port.
3. The packet is forwarded on the service provider network based on the SVLAN tag.
4. The PPPoE gateway removes the two layers of VLAN tags from the packet and adds new VLAN tags on the QinQ termination-enabled port.
5. The PPPoE gateway sends the packet to the WAN network through synchronous/asynchronous serial interface Serial 1/1/0.
Figure 2 VLAN termination enables LAN-WAN communication
When you configure VLAN termination, follow these restrictions and guidelines:
· On a portal-enabled interface, log off all portal users before you change the VLAN termination type, for example, from Dot1q termination to QinQ termination. Any portal users who remain online after the change cannot be logged off or reauthenticated. For more information about portal authentication, see Security Configuration Guide.
· A main interface cannot terminate VLAN-tagged packets. To terminate VLAN-tagged packets, you can create subinterfaces for the main interface.
· Subinterfaces (Layer 3 Ethernet subinterfaces and Layer 3 aggregate subinterfaces for example) can terminate the following packets:
¡ Packets with matching Layer 1 VLAN IDs.
¡ Packets with matching Layer 1 and Layer 2 VLAN IDs.
· After you modify the VLAN termination configuration for a Layer 3 Ethernet subinterface or Layer 3 aggregate subinterface, the subinterface automatically restarts. All dynamic ARP table entries for the subinterface are deleted.
· After you configure VLAN termination, the system finds an interface for a received packet in the following order:
¡ Subinterface configured with QinQ termination.
¡ Subinterface configured with loose QinQ termination.
¡ Subinterface configured with Dot1q termination, or subinterface that supports Dot1q termination by default.
¡ Subinterface configured with loose Dot1q termination.
¡ Subinterface configured with untagged termination.
¡ Subinterface configured with default termination.
¡ Main interface.
If default termination is enabled on a subinterface of an interface, packets are processed by the subinterface instead of the main interface.
Tasks at a glance |
(Required.) Perform one of the following tasks: · Configuring Dot1q termination ¡ Configuring ambiguous Dot1q termination ¡ Configuring unambiguous Dot1q termination · Configuring QinQ termination ¡ Configuring ambiguous QinQ termination ¡ Configuring unambiguous QinQ termination |
(Optional.) Enabling a VLAN termination-enabled interface to transmit broadcasts and multicasts |
(Optional.) Configuring the TPID for VLAN-tagged packets |
Based on the range of outermost VLAN IDs in the VLAN-tagged packets that can be terminated by a subinterface, the following types of Dot1q termination are available:
· Ambiguous Dot1q termination—Terminates VLAN-tagged packets whose outermost VLAN IDs are in the specified range. Any other VLAN-tagged packets are not allowed to pass through this subinterface.
When the subinterface receives a packet, it removes the outermost layer of tags from the packet. When the subinterface sends a packet, it tags the packet with a VLAN ID as follows:
¡ For a PPPoE packet, the VLAN ID is obtained by searching the PPPoE session entries.
¡ For a DHCP relay packet, the VLAN ID is obtained by searching the DHCP session entries.
¡ For an IPv4 or MPLS packet, the VLAN ID is obtained by searching the ARP entries.
· Unambiguous Dot1q termination—Terminates only VLAN-tagged packets whose outermost VLAN ID matches the specified VLAN ID. Any other VLAN-tagged packets are not allowed to pass through this subinterface.
When the subinterface receives a packet, it removes the outermost VLAN tag of the packet.
When the subinterface sends a packet, it tags the packet with the specified VLAN ID.
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter interface view. |
· Enter Layer 3 Ethernet subinterface view: · Enter Layer 3 aggregate subinterface view: |
N/A |
3. Configure ambiguous Dot1q termination. |
vlan-type dot1q vid vlan-id-list [ loose ] |
By default, Dot1q termination is disabled on a subinterface. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure unambiguous Dot1q termination. |
vlan-type dot1q vid vlan-id [ loose ] |
QinQ termination allows only packets that include specific VLAN tags to pass through the subinterface. The following types of QinQ termination are available:
· Ambiguous QinQ termination—Terminates QinQ packets whose outermost two layers of VLAN IDs are in the specified range.
When the subinterface receives a packet, it removes the outermost two layers of VLAN tags of the packet.
When the subinterface sends a packet, it tags the packet with the outermost two layers of VLAN IDs, which are determined as follows:
¡ For a PPPoE packet, the outermost two layers of VLAN IDs are obtained by searching the PPPoE session entries.
¡ For a DHCP relay packet, the outermost two layers of VLAN IDs are obtained by searching the DHCP relay entries.
¡ For an IPv4 or MPLS packet, the outermost two layers of VLAN IDs are obtained by searching the ARP entries.
· Unambiguous QinQ termination—Terminates QinQ packets whose outermost two layers of VLAN IDs match the specified values.
When the subinterface receives a packet, it removes the two layers of VLAN tags of the packet.
When the subinterface sends the packet, it tags the packet with two layers of VLAN tags as specified.
When you configure ambiguous QinQ termination, follow these restrictions and guidelines:
· If you specify the same Layer 1 VLAN ID for multiple subinterfaces under a main interface, the Layer 2 VLAN IDs specified for them must be different. However, if you specify different Layer 1 VLAN IDs for the subinterfaces, the Layer 2 VLAN IDs specified for the subinterfaces are not required to be different.
· Subinterfaces under different main interfaces can terminate VLAN-tagged packets with the same Layer 1 and Layer 2 VLAN IDs.
· When you use the vlan-type dot1q vid second-dot1q command to configure ambiguous QinQ termination multiple times, one of the following conditions occurs:
¡ If the most recently specified Layer 1 ID is the same as the current Layer 1 ID, the specified Layer 2 IDs in both configurations take effect.
¡ If the most recently specified Layer 1 ID is different from the current Layer 1 ID, you must first delete the old configuration.
To configure ambiguous QinQ termination:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure ambiguous QinQ termination by specifying the outermost two layers of VLAN IDs. |
vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any } [ loose ] |
By default, QinQ termination is disabled on a subinterface. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure unambiguous QinQ termination by specifying the outermost two layers of VLAN IDs. |
vlan-type dot1q vid vlan-id second-dot1q vlan-id [ loose ] |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure untagged termination. |
vlan-type dot1q untagged |
By default, untagged termination is disabled on a subinterface. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure default termination. |
vlan-type dot1q default |
By default, default termination is disabled on a subinterface. |
This function enables ambiguous Dot1q or QinQ termination-enabled interfaces to transmit broadcasts and multicasts.
As a best practice, use the vlan-termination broadcast ra command to enable an ambiguous Dot1q or QinQ termination-enabled interface to transmit RA multicast packets on an IPv6 network. This command prohibits transmission of broadcast packets and other types of multicast packets, and consumes less CPU resources than the vlan-termination broadcast enable command.
To enable a VLAN termination-enabled interface to transmit broadcasts and multicasts:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable the interface to transmit broadcasts and multicasts. |
· Enable the interface to transmit broadcasts
and multicasts. · Enable the interface to transmit only
RA multicasts on an IPv6 network. |
By default, an ambiguous Dot1q or QinQ termination-enabled interface does not transmit broadcasts and multicasts. |
TPID identifies whether or not a frame contains VLAN tags. By default, the value of 0x8100 identifies an IEEE 802.1Q-tagged frame. You can set another TPID value to identify VLAN-tagged packets.
To work with VLAN termination on a subinterface, set the TPID value in the outermost VLAN tag of packets on the main interface of the subinterface.
The interface processes packets as untagged packets if their outermost VLAN tag is not 0x8100 or the configured value.
When sending a packet, the interface sets the TPID value in the outermost VLAN tag to the configured value. If the packet includes two or more layers of VLAN tags, the interface sets the TPID values to 0x8100 in all VLAN tags except the outermost VLAN tag.
To set the TPID value for VLAN-tagged packets:
Step |
Command |
Remarks |
system-view |
N/A |
· Enter Layer 3 Ethernet interface view: · Enter Layer 3 aggregate interface view: · Enter L3VE interface view: |
Configurations made in the following views take effect on all the subinterfaces: · Layer 3 Ethernet interface view. · Layer 3 aggregate interface view. · L3VE interface view. |
3. Set the TPID value in the outermost VLAN tag of packets received and sent by the interface. |
dot1q ethernet-type hex-value |
The default setting is 0x8100. |
Network requirements
As shown in Figure 3, configure unambiguous Dot1q termination on subinterfaces of the device to implement intra-VLAN and inter-VLAN communications between hosts.
Configuration procedure
1. Configure Host A, Host B, Host C, and Host D:
# On Host A, specify 1.1.1.1/8 and 1.0.0.1/8 as its IP address and gateway IP address, respectively. (Details not shown.)
# On Host B, specify 2.2.2.2/8 and 2.0.0.1/8 as its IP address and gateway IP address, respectively. (Details not shown.)
# On Host C, specify 3.3.3.3/8 and 3.0.0.1/8 as its IP address and gateway IP address, respectively. (Details not shown.)
# On Host D, specify 4.4.4.4/8 and 4.0.0.1/8 as its IP address and gateway IP address, respectively. (Details not shown.)
2. Configure Layer 2 Switch A:
# Create VLAN 10.
<L2_SwitchA> system-view
[L2_SwitchA] vlan 10
# Assign GigabitEthernet 1/1/2 to VLAN 10.
[L2_SwitchA-vlan10] port gigabitethernet 1/1/2
[L2_SwitchA-vlan10] quit
# Create VLAN 20.
[L2_SwitchA] vlan 20
# Assign GigabitEthernet 1/1/3 to VLAN 20.
[L2_SwitchA-vlan20] port gigabitethernet 1/1/3
[L2_SwitchA-vlan20] quit
# Configure GigabitEthernet 1/1/1 as a trunk port, and assign the port to VLANs 10 and 20.
[L2_SwitchA] interface gigabitethernet 1/1/1
[L2_SwitchA-GigabitEthernet1/1/1] port link-type trunk
[L2_SwitchA-GigabitEthernet1/1/1] port trunk permit vlan 10 20
3. Configure Layer 2 Switch B in the same way you configure Layer 2 Switch A. (Details not shown.)
4. Configure the device:
# Create GigabitEthernet 1/1/1.10, and assign an IP address to this interface.
[Device] interface gigabitethernet 1/1/1.10
[Device-GigabitEthernet1/1/1.10] ip address 1.0.0.1 255.0.0.0
# Configure GigabitEthernet 1/1/1.10 to terminate packets tagged with VLAN 10.
[Device-GigabitEthernet1/1/1.10] vlan-type dot1q vid 10
[Device-GigabitEthernet1/1/1.10] quit
# Create GigabitEthernet 1/1/1.20, and assign an IP address to this interface.
[Device] interface gigabitethernet 1/1/1.20
[Device-GigabitEthernet1/1/1.20] ip address 2.0.0.1 255.0.0.0
# Configure GigabitEthernet 1/1/1.20 to terminate packets tagged with VLAN 20.
[Device-GigabitEthernet1/1/1.20] vlan-type dot1q vid 20
[Device-GigabitEthernet1/1/1.20] quit
# Configure GigabitEthernet 1/1/2.10, and assign an IP address to this interface.
[Device] interface gigabitethernet 1/1/2.10
[Device-GigabitEthernet1/1/2.10] ip address 3.0.0.1 255.0.0.0
# Configure GigabitEthernet 1/1/2.10 to terminate packets tagged with VLAN 10.
[Device-GigabitEthernet1/1/2.10] vlan-type dot1q vid 10
[Device-GigabitEthernet1/1/2.10] quit
# Configure GigabitEthernet 1/1/2.20, and assign an IP address to this interface.
[Device] interface gigabitethernet 1/1/2.20
[Device-GigabitEthernet1/1/2.20] ip address 4.0.0.1 255.0.0.0
# Configure GigabitEthernet 1/1/2.20 to terminate packets tagged with VLAN 20.
[Device-GigabitEthernet1/1/2.20] vlan-type dot1q vid 20
[Device-GigabitEthernet1/1/2.20] quit
# Verify that Host A, Host B, Host C, and Host D can ping each other. (Details not shown.)
As shown in Figure 4, configure ambiguous Dot1q termination, so that hosts in different VLANs can communicate with the server group.
In this example, L2 switch B uses the factory configuration.
1. Configure Host A, Host B, and Host C:
# Assign 1.1.1.1/24, 1.1.1.2/24, and 1.1.1.3/24 to Host A, Host B, and Host C, respectively. (Details not shown.)
# Specify 1.1.1.11/24 as the gateway IP address for the hosts. (Details not shown.)
# Create VLAN 11.
[L2_SwitchA] vlan 11
# Assign GigabitEthernet 1/1/1 to VLAN 11.
[L2_SwitchA-vlan11] port gigabitethernet 1/1/1
[L2_SwitchA-vlan11] quit
# Create VLAN 12.
[L2_SwitchA] vlan 12
# Assign GigabitEthernet 1/1/2 to VLAN 12.
[L2_SwitchA-vlan12] port gigabitethernet 1/1/2
[L2_SwitchA-vlan12] quit
# Create VLAN 13.
[L2_SwitchA] vlan 13
# Assign GigabitEthernet 1/1/3 to VLAN 13.
[L2_SwitchA-vlan13] port gigabitethernet 1/1/3
[L2_SwitchA-vlan13] quit
# Configure GigabitEthernet 1/1/7 as a trunk port, and assign the port to VLANs 11 through 13.
[L2_SwitchA] interface gigabitethernet 1/1/7
[L2_SwitchA-GigabitEthernet1/1/7] port link-type trunk
[L2_SwitchA-GigabitEthernet1/1/7] port trunk permit vlan 11 to 13
3. Configure the device:
# Create Ethernet subinterface GigabitEthernet 1/1/1.10, and assign an IP address to the subinterface.
[Device-GigabitEthernet1/1/1.10] ip address 1.1.1.11 255.255.255.0
# Enable Dot1q termination on GigabitEthernet 1/1/1.10 to terminate VLAN-tagged packets whose Layer 1 VLAN IDs are 11, 12, or 13.
[Device-GigabitEthernet1/1/1.10] vlan-type dot1q vid 11 to 13
# Enable GigabitEthernet 1/1/1.10 to transmit broadcasts and multicasts.
[Device-GigabitEthernet1/1/1.10] vlan-termination broadcast enable
# Assign an IP address to GigabitEthernet 1/1/2.
[Device-GigabitEthernet1/1/2] ip address 1.1.2.11 255.255.255.0
4. Configure the server group:
# Assign each device in the server group an IP address on the network segment 1.1.2.0/24. (Details not shown.)
# Specify 1.1.2.11/24 as the gateway IP address for the server group. (Details not shown.)
# Verify that Host A, Host B, and Host C can ping the device in the server group. (Details not shown.)
As shown in Figure 5, the router acts as a PPPoE server. Hosts in different VLANs access the Internet through the PPPoE server.
Configure Dot1q termination so that hosts in different VLANs can access the Internet.
# Configure VLANs and Dot1q termination. For the configuration procedure, see "Ambiguous Dot1q termination configuration example." (Details not shown.)
# Configure the router as the PPPoE server. Configure PPPoE settings on GigabitEthernet 1/1/1.10 on the router. For more information about the PPPoE configuration, see Layer 2—WAN Configuration Guide. (Details not shown.)
As shown in Figure 6:
· Layer 2 Switch C supports only single VLAN-tagged packets.
· On Layer 2 Switch B, GigabitEthernet 1/1/2 is enabled with QinQ to adds an SVLAN tag 100 to the packets with CVLAN ID 11.
Configure unambiguous QinQ termination so that Host A can communicate with Host B.
In this example, Layer 2 Switch C uses the factory configuration.
1. Configure Host A and Host B:
# On Host A, specify 1.1.1.1/24 and 1.1.1.11/24 as its IP address and gateway IP address, respectively. (Details not shown.)
# On Host B, specify 1.1.2.1/24 and 1.1.2.11/24 as its IP address and gateway IP address, respectively. (Details not shown.)
# Create VLAN 11.
# Assign GigabitEthernet 1/1/2 to VLAN 11.
[L2_SwitchA-vlan11] port gigabitethernet 1/1/2
# Configure GigabitEthernet 1/1/1 as a trunk port, and assign the port to VLAN 11.
[L2_SwitchA-GigabitEthernet1/1/1] port trunk permit vlan 11
3. Configure Layer 2 Switch B:
# Configure GigabitEthernet 1/1/2 as a trunk port, and assign the port to VLAN 11 and VLAN 100.
<L2_SwitchB> system-view
[L2_SwitchB] interface gigabitethernet 1/1/2
[L2_SwitchB-GigabitEthernet1/1/2] port link-type trunk
[L2_SwitchB-GigabitEthernet1/1/2] port trunk permit vlan 11 100
# Set the PVID of GigabitEthernet 1/1/2 to VLAN 100.
[L2_SwitchB-GigabitEthernet1/1/2] port trunk pvid vlan 100
# Enable QinQ on GigabitEthernet 1/1/2.
[L2_SwitchB-GigabitEthernet1/1/2] qinq enable
[L2_SwitchB-GigabitEthernet1/1/2] quit
# Configure GigabitEthernet 1/1/1 as a trunk port, and assign the port to VLAN 100.
[L2_SwitchB] interface gigabitethernet 1/1/1
[L2_SwitchB-GigabitEthernet1/1/1] port link-type trunk
[L2_SwitchB-GigabitEthernet1/1/1] port trunk permit vlan 100
4. Configure the router:
<Router> system-view
[Router] interface gigabitethernet 1/1/1.10
[Router-GigabitEthernet1/1/1.10] ip address 1.1.1.11 255.255.255.0
# Enable QinQ termination on GigabitEthernet 1/1/1.10 to terminate the VLAN-tagged packets with the Layer 1 VLAN ID 100 and the Layer 2 VLAN ID 11.
[Router-GigabitEthernet1/1/1.10] vlan-type dot1q vid 100 second-dot1q 11
[Router-GigabitEthernet1/1/1.10] quit
[Router] interface gigabitethernet 1/1/2
[Router-GigabitEthernet1/1/2] ip address 1.1.2.11 255.255.255.0
# Verify that Host A and Host B can ping each other. (Details not shown.)
As shown in Figure 7, QinQ is enabled on GigabitEthernet 1/1/2 of Layer 2 Switch B.
Configure ambiguous QinQ termination, so that hosts can communicate with the server group.
# Assign IP addresses 1.1.1.1/24, 1.1.1.2/24, and 1.1.1.3/24 to Host A, Host B, and Host C, respectively. (Details not shown.)
# Specify 1.1.1.11/24 as the gateway address for the hosts. (Details not shown.)
# Create VLAN 11.
# Create VLAN 12.
# Create VLAN 13.
# Configure GigabitEthernet 1/1/2 as a trunk port, and assign the port to VLANs 11 through 13 and VLAN 100.
[L2_SwitchB-GigabitEthernet1/1/2] port trunk permit vlan 11 to 13 100
# Configure GigabitEthernet 1/1/1.10 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is 11, 12, or 13.
[Router-GigabitEthernet1/1/1.10] vlan-type dot1q vid 100 second-dot1q 11 to 13
[Router-GigabitEthernet1/1/1.10] vlan-termination broadcast enable
5. Configure the server group:
# Verify that Host A, Host B, and Host C can ping the server group. (Details not shown.)
As shown in Figure 8:
· QinQ is enabled on GigabitEthernet 1/1/2 of Layer 2 Switch B.
· The router acts as a PPPoE server. Hosts in different VLANs access the Internet through the PPPoE server.
Configure QinQ termination, so that the hosts can access the Internet.
# Configure VLANs and QinQ termination. For the configuration procedure, see "Ambiguous QinQ termination configuration example." (Details not shown.)
# Configure the router as the PPPoE server. Configure PPPoE settings on GigabitEthernet 1/1/1.10 on the router. For more information about PPPoE configuration, see Layer 2—WAN Configuration Guide. (Details not shown.)
