| 06-Configuration file management configuration | 99.05 KB |
Next-startup configuration file redundancy
Startup configuration file selection
Configuration file content organization and format
Enabling configuration encryption
Comparing configurations for their differences
Saving the running configuration
Using different methods to save the running configuration
Configuring configuration rollback
Setting configuration archive parameters
Enabling automatic configuration archiving
Manually archiving the running configuration
Specifying a next-startup configuration file
Backing up the main next-startup configuration file to a TFTP server
Restoring the main next-startup configuration file from a TFTP server
Deleting a next-startup configuration file
Displaying and maintaining configuration files
Managing configuration files
Overview
You can use the CLI or the BootWare menus to manage configuration files. This chapter explains how to manage configuration files from the CLI.
A configuration file saves a set of commands for configuring software features on the device. You can save any configuration to a configuration file so the configuration can survive a reboot. You can also back up configuration files to a host for future use.
Configuration types
The device has the following types of configurations: factory defaults, startup configuration, and running configuration.
Factory defaults
The device is shipped with some basic settings called factory defaults. These default settings ensure that the device can start up and run correctly when it does not have a startup configuration file or when the configuration file is corrupt.
Factory defaults might differ from the initial default settings for the commands.
The device uses startup configuration to configure software features during startup. After the device starts up, you can specify the configuration file to be loaded at the next startup. This configuration file is called the next-startup configuration file. The configuration file that has been loaded is called the current startup configuration file.
If no next-startup configuration file exists, the device starts up with the factory defaults.
You can display the startup configuration by using one of the following methods:
· Execute the display startup command. To display detailed file contents, use the more command.
· After the device reboots, execute the display current-configuration command before making any configuration changes.
Running configuration
The running configuration includes unchanged startup settings and new settings. The running configuration is stored in the memory and is cleared at a device reboot or power off. To use the running configuration after a power cycling or reboot, save it to a configuration file.
To display the running configuration, use the display current-configuration command.
You can specify one main next-startup configuration file and one backup next-startup configuration file for redundancy.
At startup, the device tries to load the startup configuration in the following order:
1. The main next-startup configuration file.
2. The backup next-startup configuration file if the main next-startup configuration file does not exist or is corrupt.
3. The factory defaults if the backup configuration file is unavailable.
Configuration file formats
Configuration files you specify for saving configuration must use the .cfg extension. A .cfg configuration file is a human-readable text file. When you save configuration to a .cfg file, the device automatically saves the configuration to an .mdb user-inaccessible binary file that has the same name as the .cfg file. The device loads an .mdb file faster than loading a .cfg file.
At startup, the device uses the following procedure to identify the configuration file to load:
1. The device searches for a valid .cfg next-startup configuration file.
2. If one is found, the device searches for an .mdb file that has the same name and content as the .cfg file.
3. If a matching .mdb file is found, the device starts up with the .mdb file. If none is found, the device starts up with the .cfg file.
Unless otherwise stated, the term "configuration file" in this document refers to a .cfg configuration file.
IMPORTANT: To run on the device, a configuration file must meet the content and format requirements. To ensure a successful configuration load at startup, use a configuration file created on the device. If you edit the configuration file, make sure all edits are compliant with the requirements. |
A configuration file must meet the following requirements:
· All commands are saved in their complete form.
· Commands are sorted into sections by different command views, including system view, interface views, protocol views, and user line views.
· Two adjacent sections are separated by a pound sign (#).
· The configuration file ends with the word return.
The following is a sample configuration file excerpt:
local-user root class manage
password hash $h$6$Twd73mLrN8O2vvD5$Cz1vgdpR4KoTiRQNE9pg33gU14Br2p1VguczLSVyJLO2huV5Syx/LfDIf8ROLtVErJ/C31oq2rFtmNuyZf4STw==
interface GigabitEthernet1/1/1
port link-mode route
ip address 1.1.1.1 255.255.255.0
FIPS compliance
Configuration encryption enables the device to encrypt a startup configuration file automatically when it saves the running configuration. All devices running Comware 7 software use the same method to encrypt configuration files.
NOTE: Any devices running Comware 7 software can decrypt the encrypted configuration files. To prevent an encrypted file from being decoded by unauthorized users, make sure the file is accessible only to authorized users. |
To enable configuration encryption:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable configuration encryption. |
configuration encrypt { private-key | public-key } |
By default, configuration encryption is disabled. Configuration is saved unencrypted. |
You can compare configuration files or compare a configuration file with the running configuration for their differences.
If you specify the next-startup configuration for a comparison, the system selects the next-startup configuration file to be compared with in the following order:
2. The backup next-startup configuration file if the main next-startup configuration file is unavailable.
If both the main and backup next-startup configuration files are unavailable, the system displays a message indicating that no next-startup configuration files exist.
To compare configurations for their differences in any view:
Task |
Command |
Display the differences that a configuration file, the running configuration, or the next-startup configuration has as compared with the specified source configuration file. |
display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration } |
Display the differences that a configuration file or the next-startup configuration has as compared with the running configuration. |
display diff current-configuration { configfile file-name-d | startup-configuration } |
Display the differences that a configuration file has as compared with the next-startup configuration. |
display diff startup-configuration configfile file-name-d |
Display the differences that the running configuration has as compared with the next-startup configuration. |
· Method 1: · Method 2: |
After you remove an interface module, the interface module's settings are removed from the running configuration and will not be recovered until the replacement interface module is inserted. Saving the running configuration before installing the replacement interface module will remove the interface module's settings from the next-startup configuration file.
If you have saved the running configuration after removing an interface module, perform the following steps to restore the interface module settings to the next-startup configuration file:
1. Install the replacement interface module.
2. After the replacement interface module comes online, execute the display current-configuration command to verify that the interface module's settings have been automatically restored to the running configuration.
3. Save the running configuration to the next-startup configuration file.
IMPORTANT: To ensure a successful configuration restoration, make sure the device has not rebooted after the interface module was removed. |
On an IRF fabric, a member device's settings will be removed from the running configuration if that member device leaves because of an IRF split. Saving the running configuration before the IRF fabric recovers will remove the member device's settings from the next-startup configuration file.
If you have saved the running configuration before the member device rejoins the IRF fabric, perform the following steps to restore the member device settings to the next-startup configuration file:
1. Resolve the split issue.
2. Reboot the member device to rejoin the IRF fabric.
3. After the member device rejoins the IRF fabric, execute the display current-configuration command to verify that the member device's settings have been restored to the running configuration.
4. Save the running configuration to the next-startup configuration file on the IRF fabric.
IMPORTANT: To ensure a successful configuration restoration, make sure the IRF fabric has not rebooted after the member device left. |
When you save the running configuration to a configuration file, you can specify the file as the next-startup configuration file.
If you are specifying the file as the next-startup configuration file, use one of the following methods to save the configuration:
· Fast mode—Use the save command without the safely keyword. In this mode, the device directly overwrites the target next-startup configuration file. If a reboot or power failure occurs during this process, the next-startup configuration file is lost. You must specify a new startup configuration file after the device reboots (see "Specifying a next-startup configuration file").
· Safe mode—Use the save command with the safely keyword. Safe mode is slower than fast mode, but more secure. In safe mode, the system saves the configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a reboot or power failure occurs during the save operation, the next-startup configuration file is still retained.
Use the safe mode if the power source is not reliable or you are remotely configuring the device.
(In standalone mode.) To save the running configuration, perform one of the following tasks in any view:
Task |
Command |
Remarks |
Save the running configuration to a configuration file without specifying the file as a next-startup configuration file. |
save file-url [ all | slot slot-number ] |
N/A |
Save the running configuration to a configuration file and specify the file as a startup configuration file. |
save [ safely ] [ backup | main ] [ force ] [ mdc-all | changed ] |
Make sure you save the configuration to a file in the root directory of the storage medium. As a best practice, specify the safely keyword for reliable configuration saving. If you specify only the safely keyword, the command saves the configuration to the main startup configuration file for the MDC where you are logged in. If the force keyword is specified, the command saves the configuration to the existing next-startup configuration file. If the force keyword is not specified, the command allows you to specify a new next-startup configuration file. |
(In IRF mode.) To save the running configuration, perform one of the following tasks in any view:
Task |
Command |
Remarks |
save file-url [ all | chassis chassis-number slot slot-number ] |
N/A |
Make sure you save the configuration to a file in the root directory of the storage medium. This command saves the configuration to all IRF member devices. As a best practice, specify the safely keyword for reliable configuration saving. If you specify only the safely keyword, the command saves the configuration to the main startup configuration file for the MDC where you are logged in. If the force keyword is specified, the command saves the configuration to the existing next-startup configuration file. If the force keyword is not specified, the command allows you to specify a new next-startup configuration file. |
To replace the running configuration with the configuration in a configuration file without rebooting the device, use the configuration rollback feature. This feature helps you revert to a previous configuration state or adapt the running configuration to different network environments.
The configuration rollback feature compares the running configuration against the specified replacement configuration file and handles configuration differences as follows:
· If a command in the running configuration is not in the replacement file, the rollback feature executes the undo form of the command.
· If a command in the replacement file is not in the running configuration, the rollback feature adds the command to the running configuration.
· If a command has different settings in the running configuration and the configuration file, the rollback feature replaces the running command setting with the setting in the configuration file.
To facilitate configuration rollback, the configuration archive feature was developed. This feature enables the system to save the running configuration automatically at regular intervals as checkpoint references.
Configuration task list
Tasks at a glance |
(Required.) Setting configuration archive parameters |
(Required.) Perform either task: |
(Required.) Rolling back configuration |
Before archiving the running configuration, either manually or automatically, you must set a file directory and file name prefix for configuration archives.
Configuration archives are saved with the file name format prefix_serial number.cfg, for example, 20080620archive_1.cfg and 20080620archive_2.cfg. The serial number is automatically assigned from 1 to 1000, increasing by 1. After the serial number reaches 1000, it restarts from 1.
After you change the file directory or file name prefix, or reboot the device, all of the following events occur:
· The old configuration archives are regarded as common configuration files.
· The configuration archive counter is reset.
· The display archive configuration command no longer displays the old configuration archives.
· The serial number for new configuration archives starts at 1.
After the maximum number of configuration archives is reached, the system deletes the oldest archive to make room for the new archive.
Configuration guidelines
(In IRF mode.) The configuration archive feature saves the running configuration only on the master device. To make sure the system can archive the running configuration after a master/subordinate switchover, create the directory on all IRF members.
Configuration procedure
To set configuration archive parameters:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the directory and file name prefix for archiving the running configuration. |
archive configuration location directory filename-prefix filename-prefix |
(In IRF mode.) Do not include member ID information in the directory name. By default, no path or file name prefix is set for configuration archives, and the system does not regularly save configuration.
The undo form of this command performs the following operations: · Disables both manual and automatic configuration archiving. · Restores the default settings for the archive configuration interval and archive configuration max commands. · Clears the configuration archive information displayed by using the display archive configuration command. |
3. (Optional.) Set the maximum number of configuration archives. |
archive configuration max file-number |
The default number is 5. Change the setting depending on the amount of storage available on the device. |
Make sure you have set an archive path and file name prefix before performing this task.
To enable automatic configuration archiving:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable automatic configuration archiving and set the archiving interval. |
archive configuration interval interval |
By default, automatic configuration archiving is disabled. To display configuration archive names and their archiving time, use the display archive configuration command. |
To save system resources, disable automatic configuration archiving and manually archive the configuration if the configuration will not be changed very often. You can also manually archive configuration before performing complicated configuration tasks. Then, you can use the archive for configuration recovery if the configuration attempt fails.
Perform the following task in user view:
Task |
Command |
Manually archive the running configuration. |
archive configuration |
To ensure a successful rollback, follow these restrictions and guidelines:
· Do not perform the following operations while the system is rolling back the configuration:
¡ Install or remove modules.
¡ Perform a master/subordinate switchover.
· Make sure the replacement configuration file is created by using the configuration archive feature or the save command on the local device.
· If the configuration file is not created on the local device, make sure the command lines in the configuration file are fully compatible with the local device.
· The replacement configuration file is not encrypted.
To perform a configuration rollback:
Step |
Command |
Remarks |
system-view |
N/A |
2. Roll the running configuration back to the configuration defined by a configuration file. |
configuration replace file filename |
The specified configuration file must not be encrypted. |
The configuration rollback feature might fail to reconfigure some commands in the running configuration for one of the following reasons:
· A command cannot be undone because prefixing the undo keyword to the command does not result in a valid undo command. For example, if the undo form designed for the A [B] C command is undo A C, the configuration rollback feature cannot undo the A B C command. This is because the system does not recognize the undo A B C command.
· A command (for example, a hardware-dependent command) cannot be deleted, overwritten, or undone due to system restrictions.
· The commands in different views are dependent on each other.
· Commands or command settings that the device does not support cannot be added to the running configuration.
The system outputs a message to indicate that configuration rollback fails for some command lines. To identify the command lines, use the display diff current-configuration configfile file-name-d command. The file-name-d argument specifies the replacement configuration file. The failed command lines are displayed as configuration differences between the running configuration and the replacement configuration file.
CAUTION: In an IRF fabric, use the undo startup saved-configuration command with caution. This command can cause an IRF split after the IRF fabric or an IRF member reboots. |
You can specify a .cfg file as a next-startup configuration file when you execute the save [ safely ] [ backup | main ] [ force ] command.
Alternatively, you can execute the startup saved-configuration cfgfile [ backup | main ] command to specify a .cfg configuration file as the main or backup next-startup configuration file.
When you perform this task, follow these restrictions and guidelines:
· (In standalone mode.) Make sure the specified configuration file is valid and has been saved to the root directory of a storage medium on the device.
· (In IRF mode.) Make sure the specified configuration file is valid and has been saved to the root directory of a storage medium on each IRF member device. In addition, make sure you save the file on the same type of storage medium across all member devices.
· As a best practice, specify different files as the main and backup next-startup configuration files.
· The undo startup saved-configuration command changes the attribute of the main or backup next-startup configuration file to NULL instead of deleting the file.
To specify a next-startup configuration file, perform the following task in user view:
Task |
Command |
Remarks |
Specify a next-startup configuration file. |
startup saved-configuration cfgfile [ backup | main ] |
By default, no next-startup configuration files are specified. If you do not specify the backup or main keyword, this command specifies the configuration file as the main next-startup configuration file. Use the display startup command and the display saved-configuration command in any view to verify the configuration. |
Before performing this task, make sure the following requirements are met:
· The server is reachable.
· The server is enabled with TFTP service.
· You have read and write permissions to the server.
To back up the main next-startup configuration file to a TFTP server:
Step |
Command |
Remarks |
1. (Optional.) Verify that a next-startup configuration file has been specified in user view. |
display startup |
If no next-startup configuration file has been specified, the backup operation will fail. |
2. Back up the next-startup configuration file to a TFTP server in user view. |
This command is not supported in FIPS mode. |
Perform this task to download a configuration file to the device from a TFTP server and specify the file as the main next-startup configuration file.
Before restoring the next-startup configuration file, make sure the following requirements are met:
To restore the main next-startup configuration file from a TFTP server:
Step |
Command |
Remarks |
1. Restore the main next-startup configuration file from a TFTP server in user view. |
restore startup-configuration from { ipv4-server | ipv6 ipv6-server } src-filename [ vpn-instance vpn-instance-name ] |
2. (Optional.) Verify that the specified configuration file has been set as the main next-startup configuration file. |
display startup display saved-configuration |
N/A |
CAUTION: · (In standalone mode.) This task permanently deletes a next-startup configuration file from the device. · (In IRF mode.) This task permanently deletes a next-startup configuration file from all IRF member devices. |
You can perform this task to delete a next-startup configuration file.
If both the main and backup next-startup configuration files are deleted, the device uses factory defaults at the next startup.
To delete a file that is set as both main and backup next-startup configuration files, you must execute both the reset saved-configuration backup command and the reset saved-configuration main command. Using only one of the commands removes the specified file attribute instead of deleting the file.
For example, if the reset saved-configuration backup command is executed, the backup next-startup configuration file setting is set to NULL. However, the file is still used as the main file. To delete the file, you must also execute the reset saved-configuration main command.
Task |
Command |
Remarks |
Delete a next-startup configuration file. |
reset saved-configuration [ backup | main ] |
If you do not specify the backup or main keyword, this command deletes the main next-startup configuration file. |
Task |
Command |
Display configuration archive information. |
display archive configuration |
Display the running configuration. |
display current-configuration [ configuration [ module-name ] | controller | exclude-provision | interface [ interface-type [ interface-number ] ] ] |
Display the differences between configurations. |
· display diff current-configuration { configfile file-name-d | startup-configuration } · display diff startup-configuration { configfile file-name-d | current-configuration } |
Display the contents of the configuration file for the next system startup. |
Display the names of the configuration files for this startup and the next startup. |
display startup |
Display the valid configuration in the current view. |
display this |
