O&M capabilities
Basic O&M
Features and functions
Related topics
System dashboard
Resource summaries
Present real-time host and VM states in tables and graphics to help you quickly gain a holistic view of resource usage across the platform.
Present system health, host and VM state statistics, usage of resources (CPUs, memory, and storage), storage cluster capacity, and system alarms.
Present top five hosts and VMs by their CPU, memory, and storage usage.
Use the system dashboard
Full-screen display
Software and hardware performance monitoring
Host hardware monitoring
Monitor the operating state and performance of host hardware. In addition, UIS Manager monitors storage, physical NICs, GPUs, and storage controllers in real time.
View hardware monitoring information for a host
Performance monitoring
Monitor hosts, VMs, and storage clusters and resource usage in the virtualized environment.
  • View resource usage and performance statistics for a host. These statistics include the CPU usage, memory usage, disk I/O throughputs, IOPS, and usage of the shared file system.
  • View resource usage and performance statistics for a VM. These statistics include the CPU usage, memory usage, disk I/O throughput statistics, network throughputs, IOPS, disk I/O delay, disk usage, and partition usage.
  • View storage performance metrics by cluster, host, or disk.
VM processes and services monitoring
Monitor active programs, processes, and services on VMs to provide their resource usage statistics.
You can obtain the username, process ID and process name of each process and their CPU usage, memory usage, and used memory capacity.
View service and process monitoring information for a VM
Storage cluster summary statistics
Obtain an overview of the storage cluster settings, performance, and health status.
Available statistics include cluster IOPS, cluster capacity, Top 5 disks by usage, cluster I/O throughputs, Top 5 disks by read latency, Top 5 disks by write latency, number of storage nodes by state, and number of disks by state.
View summary information about the storage cluster
Network topology
View the connections between vSwitches and VMs, vSwitches and physical NICs on hosts, and VMs and virtual firewalls.
View network topology
Logs
Operation log
The operation log records all operations done in UIS Manager.
You can review the operation log to audit user behavior and analyze issues. For example, you can review the operation log to identify the operator of an unscheduled operation and do an investigation.
Manage operation logs
Log collection
Collect logs about UIS Manager and its managed hosts and download the log files. For example, you can collect logs about a malfunctioning host and send the log files to technical support for help if the issue persists.
Collect logs
Task console
The task console provides quick access to the most recent tasks.
When you execute a task, for example, start a VM, the task console automatically opens to show the task execution progress. If the task fails, the task console displays the failure cause to help you troubleshoot the issue.
To open the task console, click its icon  at the top right of the page.
Advanced O&M
Related topics
Monitoring reports
Host reports
Review the resource usage statistics for a host for a specified period.
View host reports
VM reports
Review the resource usage statistics for a VM for a specified period.
View VM reports
Top N reports
Obtain TopN hosts or VMs with most resource usage over a specified period.
View TopN host or VM reports
Resource statistics
Cluster resource statistics
Obtain basic information about a cluster and its resource usage statistics. Available information about a cluster includes the number of hosts, VM distribution, VM summary, number of CPU cores, total memory, and shared storage.
View cluster resource usage statistics
Host resource statistics
Obtain basic information about a host and its resource usage statistics. Available information about a host includes its uptime, host model, CPU model, CPU usage, memory usage, and local disk capacity.
View host resource usage statistics
VM resource statistics
Obtain basic information about VMs and their resource usage. Available information about a VM includes its hostname, state, CPUs, memory, virtual disks, guest OS, CPU usage, and memory usage.
View VM resource usage statistics
IP assignment statistics
View information about IP assignment to VMs.
View IP address assignment statistics
VLAN assignment statistics
View information about the VLAN to which a VM belongs.
View VLAN assignment statistics
Storage resource statistics
View statistics about the assignment of storage resources including VM disks, network storage, and shared file systems.
View storage resource usage statistics
VM downtime statistics
Obtain the periods of time during which a VM is in shutdown, suspended, hibernating, or unknown state, and the total time in which a VM is in one of these states.
View VM downtime statistics
Availability center
Monitoring center
Hot keys are available for you to gain easy access to visualized, holistic view of platform performance and health status, and quickly identify issues. In addition, the system presents the availability state of the services, system, and hardware at a UIS site in a hierarchical structure. Hot keys are available for you to quickly check the health state of the UIS sites.
Manage the monitoring center
Ignoring alarm metrics
You can ignore the alarm metrics that do not require attention in the monitoring center or health check tasks. The system does not report the alarms generated for the ignored alarm metrics.
Configure ignored alarm metrics
Alarm management
Real-time alarms
View most recent alarms generated in the system. From the list of real-time alarms, you can drill down to details such as cause of the alarm and recommended actions.
Manage real-time alarms
Alarm threshold configuration
Configure threshold-based alarm triggers to monitor metrics and generates alarms when they cross the thresholds for a severity level. For example, you can configure an alarm threshold on cluster CPU usage. When the cluster CPU usage crosses that threshold, the system generates an alarm. When you configure threshold-based alarm triggers, you can also specify parameters such as the alarm duration.
Manage alarm thresholds
Ignored alarms
If you want to see only alarms of interest in the real-time alarm list, configure alarms that do not require attention as ignored alarms.
Manage ignored alarms
Alarm notifications
Configure UIS Manager to send email or SMS notifications about alarms of interest.
Special-purpose O&M
Related topics
Hot key for health check
Check system health on one click and obtain the system health score. You can check the system, compute, storage, network, and availability services for operating and performance issues and any other risks that might negatively affect VM services.
Check system health
Hot key for resource analysis
Review the resource configuration of the cluster, hosts, and VMs and their one-month CPU and memory usage summary to make informed decisions such as scaling decisions.
Analyze resource usage
Hot key for storage cleanup
Scan associations between VMs and back-end storage files for unused storage files. A file is unused if it is not an .iso guest OS image or virtualization driver file, and it is not mounted to a VM. You can delete these files to free up storage space.
Clean up storage
Hot key to export a resource report
Export a report about the resource configuration and usage of hosts or VMs. You can select the report file format and the fields to be included in the report.
Export a resource report
Hot key for VM restoration
Restore the state of VMs to a past point in time, which is called a restore point.
Restore VMs
Hot key to manage zombie VMs
Discover, start, or delete zombie VMs, which are VMs that persist in idle and down state for a long time.
Manage zombie VMs
Hot key for shutting down all hosts in the cluster
Shut down all hosts in the cluster
Hot key for hardware replacement
Hardware replacement allows you to replace the CPU, memory, motherboard, NIC, RAID controller, and disk backplane of the host used for HCI deployment. This feature provides software-related operations for hardware replacement.
Replace hardware
Custom O&M
Related topics
Operator management
Operator management
Add, edit, or delete operators, or view detailed information about an operator.
Manage operators
Operator grouping
Assign operators with the same privileges to the same operator group for the ease of management.
Manage operator groups
Online operator management
View, filter, and log off online operators.
Manage online operators
VM view
Adding VM management directories
The system provides the VM view for you to assign VMs of the same type or dependencies to the same directory or subdirectory for unified VM management, quick VM filtering, and quick search for VM details.
Manage the VM view
VM boot rule
Set the sequence to start the VMs that have dependencies. For example, you have one database VM, one application VM, and one web service VM. To start them in order, you place them in the same VM directory and set their boot priorities before you start them in bulk.
Manage the VM view
My dashboards
My dashboards
Create custom dashboards to monitor metrics of interest. In design mode, you can quickly drag and drop the monitor tiles for monitored metrics to your dashboard with ease. After you save the dashboard, you can open the dashboard to monitor the metrics of interest whenever you want. To use the whole screen to display the dashboard, use the full screen mode.
Manage my dashboards
