05-Layer 3 - IP Services Configuration Examples
04-S12500_GRE_Tunnel_Configuration_Examples
Chapters Download  (144.54 KB)
04-S12500_GRE_Tunnel_Configuration_Examples 144.54 KB
Introduction
This document provides GRE tunnel configuration examples.
Generic Routing Encapsulation (GRE) is a tunneling protocol that can encapsulate any network layer protocol (such as IPv6) into a virtual point-to-point tunnel over an IP network (such as an IPv4 network). Packets are encapsulated at one tunnel end and de-encapsulated at the other tunnel end. The network layer protocol of the packets before encapsulation and after encapsulation can be the same or different.
H3C S12500 switches support GRE over IPv4 tunnels, but they do not support GRE over IPv6 tunnels.
This document assumes that you have basic knowledge of GRE tunneling.
Example: Configuring an IPv4 over IPv4 GRE tunnel
Network requirements
As shown in Figure 1, Switch A, Switch B, and Switch C run the IPv4 protocol.
Configure an IPv4 over IPv4 GRE tunnel between Switch A and Switch B for PC 1 and PC 2 in the private IPv4 networks to communicate with each other.
Figure 1 Network diagram
Requirements analysis
To meet the network requirements, you must perform the following tasks:
·     For Switch A to forward packets from PC 1 to PC 2 through the GRE tunnel, configure a static route with the following settings:
?     Destination address is the IP address of PC 2.
?     Next hop is the IP address of the tunnel interface on Switch B.
Configure Switch B in the same way that Switch A is configured. (You can also configure a dynamic routing protocol on the tunnel interface and the VLAN interface that connects to PC 1. However, this example uses a static route.)
·     To make sure the tunnel source and the tunnel destination can reach each other, configure a static route to the other tunnel end on both Switch A and Switch B. The next hop for the two routes is Switch C.
Software version used
This configuration example was created and verified on S12500-CMW710-R7129.
When you configure an IPv4 over IPv4 GRE tunnel, follow these restrictions and guidelines:
·     The source interface for the tunnel must be up and must have an IP address. It can be a VLAN interface, a GigabitEthernet interface, or a loopback interface.
·     You must configure the tunnel source address and destination address at both ends of a tunnel, and the tunnel source or destination address at one end must be the tunnel destination or source address at the other end.
·     The IP address of the tunnel interface and the tunnel destination address configured on the tunnel interface must be in different subnets.
·     By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. In this example, the interfaces are already up, and you do not need to use this command.
Configuration procedures
Configuring Switch A
# Create VLANs and specify IP addresses for the VLAN interfaces as shown in Figure 1. (Details not shown.)
# Create a tunnel interface Tunnel 0 and specify the tunnel mode as GRE over IPv4.
[SwitchA] interface tunnel 0 mode gre
# Specify an IP address for the tunnel interface.
[SwitchA-Tunnel0] ip address 101.1.2.1 24
# Specify the IP address of VLAN-interface 101 on Switch A as the source address of the tunnel interface.
[SwitchA-Tunnel0] source 192.13.2.2
# Specify the IP address of VLAN-interface 200 on Switch B as the destination address of the tunnel interface.
[SwitchA-Tunnel0] destination 131.108.5.2
[SwitchA-Tunnel0] quit
# Configure a static route to PC 2 through the tunnel interface.
[SwitchA] ip route-static 10.101.2.2 255.255.255.0 Tunnel 0
# Configure a static route to the tunnel destination.
[SwitchA] ip route-static 131.108.5.2 255.255.255.0 192.13.2.1
Configuring Switch B
[SwitchB] interface tunnel 0 mode gre
[SwitchB-Tunnel0] ip address 101.1.2.2 24
# Specify the IP address of VLAN-interface 200 on Switch B as the source address of the tunnel interface.
[SwitchB-Tunnel0] source 131.108.5.2
# Specify the IP address of VLAN-interface 101 on Switch A as the destination address of the tunnel interface.
[SwitchB-Tunnel0] destination 192.13.2.2
[SwitchB-Tunnel0] quit
# Configure a static route to PC 1 through the tunnel interface.
[SwitchB] ip route-static 10.101.1.2 255.255.255.0 Tunnel 0
[SwitchB] ip route-static 192.13.2.2 255.255.255.0 131.108.5.1
Configuring Switch C
Configuring PC 1
# Configure a route to PC 2 through Switch A. This task is performed on Windows XP.
C:\>route ADD 10.101.2.0 MASK 255.255.255.0 10.101.1.1
Configuring PC 2
# Configure a route to PC 1 through Switch B. This task is performed on Windows XP.
C:\> route ADD 10.101.1.0 MASK 255.255.255.0 10.101.2.1
Verify that PC 1 and PC 2 can ping each other.
# Ping PC 2 from PC 1.
C:\>ping 10.101.2.2
Pinging 10.101.2.2 with 32 bytes of data:
Reply from 10.101.2.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.101.2.2:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
# Ping PC 1 from PC 2.
C:\>ping 10.101.1.2
Pinging 10.101.1.2 with 32 bytes of data:
Reply from 10.101.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.101.1.2:
Configuration files
·     Switch A:
vlan 100 to 101
interface Vlan-interface100
 ip address 10.101.1.1 255.255.255.0
interface Vlan-interface101
 ip address 192.13.2.2 255.255.255.0
interface GigabitEthernet3/0/1
 port link-mode bridge
 port access vlan 100
interface GigabitEthernet3/0/3
 port access vlan 101
interface Tunnel0 mode gre
 ip address 101.1.2.1 255.255.255.0
 source 192.13.2.2
 ip route-static 10.101.2.0 255.255.255.0 Tunnel 0
·     Switch B:
vlan 200 to 201
interface Vlan-interface200
 ip address 131.108.5.2 255.255.255.0
interface Vlan-interface201
 ip address 10.101.2.1 255.255.255.0
 port access vlan 201
 port access vlan 200
 ip address 101.1.2.2 255.255.255.0
 source 131.108.5.2
 ip route-static 10.101.1.0 255.255.255.0 tunnel 0
·     Switch C:
vlan 101
vlan 200
 ip address 192.13.2.1 255.255.255.0
 ip address 131.108.5.1 255.255.255.0
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
Example: Configuring an IPv6 over IPv4 GRE tunnel
As shown in Figure 2, configure an IPv6 over IPv4 GRE tunnel between the dual-stack switches Switch A and Switch B for PC 1 and PC 2 in the IPv6 networks to communicate with each other.
Figure 2 Network diagram
·     To make sure PC 1 and PC 2 can communicate with each other, configure an IPv6 address for the tunnel interface on Switch A and Switch B.
Configure Switch B in the same way that Switch A is configured. (You can also configure a dynamic routing protocol on the tunnel interface and the VLAN interface that connects to PC 1. This example uses a static route.)
·     To make sure the tunnel source and the tunnel destination can reach each other, configure a static route to the other end on both Switch A and Switch B. The next hop for the two routes is Switch C.
When you configure an IPv6 over IPv4 GRE tunnel, follow these restrictions and guidelines:
# Create VLANs and specify IP addresses for the VLAN interfaces as shown in Figure 2. (Details not shown.)
# Specify an IPv6 address for the tunnel interface.
[SwitchA-Tunnel0] ipv6 address 3000::1 64
[SwitchA] ipv6 route-static 2000:: 64 Tunnel 0
[SwitchB-Tunnel0] ipv6 address 3000::2 64
[SwitchB] ipv6 route-static 1000:: 64 Tunnel 0
Configuring PC 1
The following tasks are performed on Windows XP:
# Install the IPv6 protocol on PC 1.
C:\>ipv6 install
# Display the IPv6 interface configuration to obtain the interface index.
C:\>ipv6 if
# Configure an IPv6 address for the interface. Typically, the interface index is 5.
C:\>ipv6 adu 5/1000::2
# Configure a default IPv6 route.
C:\>ipv6 rtu ::/0 5/1000::1
Configuring PC 2
# Install the IPv6 protocol on PC 2.
C:\>ipv6 install
C:\>ipv6 if
C:\>ipv6 adu 5/2000::2
C:\>ipv6 rtu ::/0 5/2000::1
C:\>ping6 -s 1000::1 2000::2
Pinging 2000::2
from 1000::1 with 32 bytes of data:
Reply from 2000::2: bytes=32 time<1ms
Ping statistics for 2000::2:
C:\>ping6 -s 2000::2 1000::2
Pinging 1000::2
from 2000::2 with 32 bytes of data:
Reply from 1000::2: bytes=32 time<1ms
Ping statistics for 1000::2:
Configuration files
·     Switch A:
vlan 100 to 101
 ipv6 address 1000::1/64
 ipv6 address 3000::1/64
 source 192.13.2.2
·     Switch B:
vlan 200 to 201
 ipv6 address 2000::1/64
 ipv6 address 3000::2/64
 source 131.108.5.2
·     Switch C:
vlan 101
vlan 200
Related documentation
·     H3C S12500 Routing Switch Series Layer 3IP Services Configuration Guide
·     H3C S12500 Routing Switch Series Layer 3IP Services Command Reference
