01-S12500_UDP_Helper_Configuration_Examples
Chapters Download (84.89 KB)
| 01-S12500_UDP_Helper_Configuration_Examples | 84.89 KB |
This document provides UDP helper configuration examples.
UDP helper enables a device to convert received UDP broadcast packets with a specific UDP destination port number into unicast packets and forward them to a specific server on another broadcast domain.
This document assumes that you have basic knowledge of H3C UDP helper.
As shown in Figure 1, configure UDP helper on Switch A to forward broadcast packets with UDP destination port number 53 from Host A and Host B to the destination DNS server at 192.168.2.2.
To convert the broadcast packets from Host A and Host B into unicast packets and forward them to the DNS server, specify the IP address of the DNS server for UDP helper on VLAN-interface 3.
This configuration example was created and verified on S12500-CMW710-R7129.
When you configure UDP helper, follow these restrictions and guidelines:
· UDP ports 67 and 68 are used by DHCP. Do not set UDP ports 67 and 68 for UDP helper because UDP helper cannot forward DHCP broadcast packets.
· Disabling UDP helper removes all UDP ports configured for UDP helper.
· You can configure up to 20 destination servers on an interface.
· By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. This example assumes that all these interfaces are already up.
# Create VLAN 2 and VLAN 3, and configure the IP addresses of VLAN interfaces. (Details not shown.)
# Enable UDP helper.
[SwitchA] udp-helper enable
# Enable forwarding broadcast packets with the UDP destination port 53.
[SwitchA] udp-helper port 53
# Specify the destination DNS server 192.168.2.2 on VLAN-interface 3.
[SwitchA] interface Vlan-interface 3
[SwitchA-Vlan-interface3] udp-helper server 192.168.2.2
[SwitchA-Vlan-interface3] quit
# Display information about packets forwarded by UDP helper on VLAN-interface 3.
[SwitchA] display udp-helper server interface Vlan-interface 3
Interface name Server VPN Server address Packets
Vlan3 192.168.2.2 5
vlan 2 to 3
udp-helper enable
udp-helper port 53
interface Vlan-interface2
ip address 192.168.2.1 255.255.255.0
interface Vlan-interface3
interface GigabitEthernet3/0/1
port link-mode bridge
port access vlan 3
interface GigabitEthernet3/0/2
port access vlan 2
· H3C S12500 Routing Switch Series Layer 3—IP Services Configuration Guide
· H3C S12500 Routing Switch Series Layer 3—IP Services Command Reference
