05-Layer 3 - IP Services Configuration Examples
02-S12500_IPv6_Address_Configuration_Examples
Chapters Download  (121.13 KB)
02-S12500_IPv6_Address_Configuration_Examples 121.13 KB
Introduction
This document provides examples for IPv6 address configuration.
You can use one of the following methods to configure an IPv6 global unicast address for an interface:
·     Manual configuration—The IPv6 global unicast address is manually configured.
·     EUI-64 IPv6 address—The IPv6 address prefix of the interface is manually configured. The interface identifier is generated automatically based on the MAC address of the interface.
·     Stateless address autoconfiguration—The IPv6 global unicast address is generated automatically based on the address prefix information contained in the RA message. H3C S12500 switches do not support this method. They support sending RA messages to the devices that connect to the switches, which supports the devices to perform stateless address autoconfiguration.
·     Stateful address autoconfiguration—The IPv6 address is obtained through the stateful autoconfiguration (for example, from a DHCPv6 server).
This document assumes that you have basic knowledge of IPv6 address configuration.
Example: Configuring IPv6 addresses
Network requirements
As shown in Figure 1:
·     Manually configure the IPv6 global unicast addresses of VLAN-interface 2 and VLAN-interface 3 on Switch A.
·     The host uses stateless address autoconfiguration to configure its IPv6 address according to the RA message. Switch A advertises the RA message in the network segment 2001::/64.
·     VLAN-interface 3 on Switch B generates its EUI-64 IPv6 address with the address prefix 3001::/64.
·     The host and Switch B can reach each other.
Figure 1 Network diagram
Requirements analysis
To meet the network requirements, perform the following tasks:
·     To make sure Switch A can advertise address prefix information in RA messages to the host, disable RA message suppression on Switch A's interface that connects to the host. By default, the interface is suppressed from sending RA messages.
·     To make Switch B can communicate with the host in another network segment, configure a route (a static route, in this example) to the host on Switch B. It is not necessary to configure a route on the host because the host uses Switch A as its default gateway.
Software version used
This configuration example was created and verified on S12500-CMW710-R7129.
Configuration procedures
Configuring Switch A
# Create VLAN 2 and assign GigabitEthernet 3/0/2 to VLAN 2.
[SwitchA] vlan 2
[SwitchA-vlan2] port GigabitEthernet 3/0/2
[SwitchA-vlan2] quit
[SwitchA] interface Vlan-interface 2
[SwitchA-Vlan-interface2] undo shutdown
[SwitchA] interface GigabitEthernet 3/0/2
[SwitchA-GigabitEthernet3/0/2] undo shutdown
[SwitchA-GigabitEthernet3/0/2] quit
# Create VLAN 3 and assign GigabitEthernet 3/0/1 to VLAN 3.
[SwitchA] vlan 3
[SwitchA-vlan3] port GigabitEthernet 3/0/1
[SwitchA-vlan3] quit
[SwitchA] interface Vlan-interface 3
[SwitchA-Vlan-interface3] undo shutdown
[SwitchA-Vlan-interface3] quit
[SwitchA] interface GigabitEthernet 3/0/1
[SwitchA-GigabitEthernet3/0/1] undo shutdown
[SwitchA-GigabitEthernet3/0/1] quit
# Specify an IPv6 global unicast address for VLAN-interface 2 and for VLAN-interface 3.
[SwitchA-Vlan-interface2] ipv6 address 2001::1 64
[SwitchA-Vlan-interface3] ipv6 address 3001::1 64
# Disable RA message suppression on VLAN-interface 2.
[SwitchA-Vlan-interface2] undo ipv6 nd ra halt
Configuring Switch B
[SwitchB] vlan 3
[SwitchB-vlan3] port GigabitEthernet 3/0/1
[SwitchB-vlan3] quit
[SwitchB] interface Vlan-interface 3
[SwitchB-Vlan-interface3] undo shutdown
[SwitchB] interface GigabitEthernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] undo shutdown
[SwitchB-GigabitEthernet3/0/1] quit
# Configure an EUI-64 IPv6 address for VLAN-interface 3. The address prefix is 3001::/64. The interface ID is generated based on the MAC address of the interface.
[SwitchB-Vlan-interface3] ipv6 address 3001:: 64 eui-64
# Configure a static IPv6 route to 2001::/64 with the next hop 3001::1.
[SwitchB] ipv6 route-static 2001:: 64 3001::1
Configuring the host
The following tasks are performed on Windows XP:
1.     Select Start and Run, and enter cmd in the Open field.
2.     Execute the following command to install IPv6:
C:\> ipv6 install
Installing...
Succeeded.
3.     After the installation succeeds, verify that the network card acquires the IPv6 link local address.
C:\> ipconfig
Windows IP Configuration
Ethernet adapter local connection:
        Connection-specific DNS Suffix  . :
        IP Address. . . . . . . . . . . . : 192.168.1.17
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        IP Address. . . . . . . . . . . . : fe80::20d:88ff:fef8:dd7%6
        Default Gateway . . . . . . . . . :
In the output, the string "%6" after the IP address indicates the sixth IPv6 interface.
You can display all IPv6 interfaces on the PC by using the ipv6 if command.
When receiving the IPv6 address prefix 2001::/64 periodically advertised by Switch A, the host automatically generates global unicast addresses with the prefix without manual intervention.
1.     Verify the IPv6 global unicast addresses manually configured on Switch A.
# Display brief information about the IPv6 addresses of all interfaces.
[SwitchA] display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface                     Physical Protocol IPv6 Address
Vlan-interface2               down     down     2001::1 [TENTATIVE]
Vlan-interface3               down     down     3001::1 [TENTATIVE]
2.     Verify that the host automatically generates IPv6 global unicast addresses.
# (Method 1) Display the automatically generated IPv6 addresses on the host:
C:\> ipconfig
        IP Address. . . . . . . . . . . . : 2001::dc36:939:d072:7d3f
        IP Address. . . . . . . . . . . . : 2001::20d:88ff:fef8:dd7
        Default Gateway . . . . . . . . . : fe80::20f:e2ff:fe00:1024%6
¡     The host generates two IPv6 global unicast addresses: 2001::DC36:939:D072:7D3F and 2001::20D:88FF:FEF8:DD7.
¡     The default gateway of the host is the link local address of VLAN-interface 2 on Switch A, FE80::20F:E2FF:FE00:1024.
·     After acquiring the network address prefix, Windows XP generates two global unicast addresses. The interface ID of one address is automatically generated based on the MAC address of the interface, while that of the other address is generated randomly. You can choose the latter global unicast address to prevent leakage of the former interface ID.
·     Windows Server 2003 does not randomly generate an interface ID.
# (Method 2) Display IPv6 address information for the host on Switch A.
[SwitchA] display ipv6 neighbors interface GigabitEthernet 3/0/2
                Type: S-Static    D-Dynamic
IPv6 Address                   Link-layer     VID  Interface      State T Age
FE80::20D:88FF:FEF8:DD7        000d-88f8-0dd7 2   GE3/0/2         REACH D 1
2001::20D:88FF:FeF8:DD7        000d-88f8-0dd7 2   GE3/0/2         REACH D 11
3.     Verify the EUI-64 IPv6 address generated on VLAN-interface 3 of Switch B.
[SwitchB] display ipv6 interface Vlan-interface 3
Vlan-interface3 current state: DOWN
Line protocol current state: DOWN
IPv6 is enabled, link-local address is FE80::BAAF:67FF:FE30:3300 [TENTATIVE]
  Global unicast address(es):
    3001::BAAF:67FF:FE30:3300, subnet is 3001::/64 [TENTATIVE] [EUI-64]
  Joined group address(es):
    FF02::1
    FF02::2
    FF02::1:FF30:3300
  MTU is 1500 bytes
IPv6 Packet statistics:
  InReceives:                    0
  InTooShorts:                   0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    0
  OutRequests:                   0
  OutForwDatagrams:              0
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   0
  InMcastNotMembers:             0
  OutMcastPkts:                  0
4.     Verify the connectivity between devices by using the ping command on the host, Switch A, and Switch B.
# Ping Switch A from Switch B.
[SwitchB] ping ipv6 -c 1 3001::1
  PING 3001::1 : 56  data bytes, press CTRL_C to break
    Reply from 3001::1
    bytes=56 Sequence=1 hop limit=64  time = 6 ms
  --- 3001::1 ping statistics ---
    1 packet(s) transmitted
    1 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 6/6/6 ms
# Ping the host from Switch B.
[SwitchB] ping ipv6 -c 1 2001::20D:88FF:FEF8:DD7
  PING 2001::20D:88FF:FEF8:DD7 : 56  data bytes, press CTRL_C to break
    Reply from 2001::20D:88FF:FEF8:DD7
    bytes=56 Sequence=1 hop limit=63  time = 17 ms
  --- 2001::20D:88FF:FEF8:DD7 ping statistics ---
    0.00% packet loss
    round-trip min/avg/max = 17/17/17 ms
Similarly, you can successfully ping Switch A and Switch B from the host, and ping Switch B and the host from Switch A.
Configuration files
·     Switch A:
vlan 2 to 3
interface Vlan-interface2
 ipv6 address 2001::1/64
interface Vlan-interface3
 ipv6 address 3001::1/64
interface GigabitEthernet3/0/2
 port link-mode bridge
 port access vlan 2
interface GigabitEthernet3/0/1
 port access vlan 3
·     Switch B:
vlan 3
 ipv6 address 3001::/64 eui-64
 port access vlan 3
Related documentation
·     H3C S12500 Routing Switch Series Layer 3IP Services Configuration Guide
·     H3C S12500 Routing Switch Series Layer 3IP Services Command Reference
