18-URPF Commands
Chapters Download (17.47 KB)
The term “router” in this document refers to a router in a generic sense or a Layer 3 switch.
ip urpf strict
undo ip urpf
View
Default Level
2: System level
None
Use the ip urpf command to enable URPF check globally.
Use the undo ip urpf command to disable URPF check.
By default, URPF check is disabled.
# Enable strict URPF check globally.
[Sysname] ip urpf strict
