Part 8 - Security
09-Port Security Commands
Chapters Download  (78.51 KB)
1  Port Security Configuration Commands
display port-security
display port-security [ interface interface-list ]
View
Default Level
2: System level
Interface interface-list: Specifies Ethernet ports by an Ethernet port list in the format of { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> means that you can specify up to 10 ports or port ranges. The starting port and ending port of a port range must be of the same type and the ending port number must be greater than the starting port number.
Use the display port-security command to display port security configuration information, operation information, and statistics about one or more ports.
If the interface interface-list parameter is not provided, the command displays port security information, operation information, and status about all ports.
Related commands: port-security enable, port-security port-mode, port-security ntk-mode, port-security intrusion-mode, port-security max-mac-count, port-security mac-address security, port-security authorization ignore, port-security oui, port-security trap.
# Display port security configuration information, operation information, and statistics about all ports.
<Sysname> display port-security
 Equipment port-security is enabled
 AddressLearn trap is enabled
 Intrusion trap is enabled
 Dot1x logon trap is enabled
 Dot1x logoff trap is enabled
 Dot1x logfailure trap is enabled
 RALM logon trap is enabled
 RALM logoff trap is enabled
 RALM logfailure trap is enabled
 Disableport Timeout: 20s
 OUI value:
   Index is 1,  OUI value is 000d1a
   Index is 2,  OUI value is 003c12
 GigabitEthernet1/0/1 is link-down
    Port mode is UserloginWithOUI
    NeedtoKnow mode is NeedToKnowOnly
    Intrusion Portection mode is DisablePort
    Max MAC address number is 50
    Stored MAC address number is 0
    Authorization is ignored
 GigabitEthernet1/0/2 is link-down
    Port mode is noRestriction
    NeedtoKnow mode is disabled
    Intrusion mode is NoAction
    Max MAC address number is not configured
    Authorization is permitted
Table 1-1 display port-security command output description
Whether the port security is enabled or not.
AddressLearn trap
Whether trapping for MAC address learning is enabled or not. If it is enabled, the port sends trap information after it learns a new MAC address.
Intrusion trap
Whether trapping for intrusion protection is enabled or not. If it is enabled, the port sends trap information after it detects illegal packets.
Dot1x logon trap
Whether trapping for 802.1X logon is enabled or not. If it is enabled, the port sends trap information after a user passes 802.1X authentication.
Dot1x logoff trap
Whether trapping for 802.1X logoff is enabled or not. If it is enabled, the port sends trap information after an 802.1X user logs off.
Dot1x logfailure
Whether trapping for 802.1X authentication failure is enabled or not. If it is enabled, the port sends trap information after a user fails the 802.1Xuthentication.
RALM logon trap
Whether trapping for MAC authentication success is enabled or not. If it is enabled, the port sends trap information when a user passes MAC address authentication.
RALM logoff trap
Whether trapping for MAC authenticated user logoff is enabled or not. If it is enabled, traps are sent when a MAC address authenticated user logs off.
Whether trapping for MAC authentication failure is enabled or not. If it is enabled, the port sends trap information when a user fails MAC address authentication.
Disableport Timeout
Silence timeout period of the port that receives illegal packets, in seconds.
OUI value
List of OUI values allowed
Port mode
Port security mode, which can be:
l  autoLearn
l  macAddressWithRadius
l  macAddressElseUserLoginSecure
l  macAddressElseUserLoginSecureExt
l  secure
l  userLogin
l  userLoginSecure
l  userLoginSecureExt
l  macAddressOrUserLoginSecure
l  macAddressOrUserLoginSecureExt
l  userLoginWithOUI
NeedtoKnow mode
NTK mode, which can be:
l  NeedToKnowOnly: Allows only unicasts with authenticated destination MAC addresses.
l  NeedToKnowWithBroadcast: Allows only unicasts and broadcasts with authenticated destination MAC addresses.
l  NeedToKnowWithMulticast: Allows unicasts, multicasts and broadcasts with authenticated destination MAC addresses.
Intrusion mode
Intrusion protection action mode, which can be :
l  BlockMacAddress: Adds the source MAC address of the illegal packet to the blocked MAC address list.
l  DisablePort: Shuts down the port that receives illegal packets permanently.
l  DisablePortTemporarily: Shuts down the port that receives illegal packets for some time.
l  NoAction: Performs no intrusion protection.
Maximum number of secure MAC addresses allowed on the port
Number of secure MAC addresses stored
Authorization
Whether the authorization information from the server is ignored or not:
l  permitted: Authorization information from the RADIUS server takes effect.
l  ignored: Authorization information from the RADIUS server does not take effect.
display port-security mac-address block
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
View
Default Level
2: System level
interface interface-type interface-number: Specifies a port by its type and number.
vlan vlan-id: Specifies a VLAN by its ID, which is in the range 1 to 4094.
count: Displays only the count of the blocked MAC addresses.
Use the display port-security mac-address block command to display information about blocked MAC addresses.
With no keyword or argument specified, the command displays information about all blocked MAC addresses.
Related commands: port-security intrusion-mode.
# Display information about all blocked MAC addresses.
<Sysname> display port-security mac-address block
 MAC ADDR               From Port                  VLAN ID
 000f-1f86-3232        GigabitEthernet1/0/2      1
 --- On slot 1, 1 mac address(es) found ---
--- 1 mac address(es) found ---
# Display the count of all blocked MAC addresses.
<Sysname> display port-security mac-address block count
 --- On slot 1, 2 mac address(es) found ---
 ---2 mac address(es) found ---
# Display information about all blocked MAC addresses in VLAN 1.
<Sysname> display port-security mac-address block vlan 1
 0002-0002-0002      GigabitEthernet1/0/1                1
 000d-88f8-0577      GigabitEthernet1/0/1                1
 ---  2 mac address(es) found  ---
# Display information about all blocked MAC addresses of port GigabitEthernet 1/0/1.
# Display information about all blocked MAC addresses of port GigabitEthernet1/0/1 in VLAN 1.
<Sysname> display port-security mac-address block interface gigabitethernet 1/0/1 vlan 1
Table 1-2 display port-security mac-address block command output description
MAC ADDR
Blocked MAC address
From Port
Port having received frames with the blocked MAC address being the source address
VLAN ID
ID of the VLAN to which the port belongs
x mac address(es) found
Number of blocked MAC addresses
display port-security mac-address security
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
View
Default Level
2: System level
count: Displays only the count of the secure MAC addresses.
Use the display port-security mac-address security command to display information about secure MAC addresses.
With no keyword or argument specified, the command displays information about all secure MAC addresses.
Related commands: port-security mac-address security.
# Display information about all secure MAC addresses.
<Sysname> display port-security mac-address security
MAC ADDR        VLAN ID   STATE          PORT INDEX                          AGING TIME(s)
0002-0002-0002  1         Security       GigabitEthernet1/0/1              NOAGED
000d-88f8-0577  1         Security       GigabitEthernet1/0/1              NOAGED
# Display only the count of the secure MAC addresses.
<Sysname> display port-security mac-address security count
This operation may take a few minutes, please wait......
# Display information about secure MAC addresses in VLAN 1.
<Sysname> display port-security mac-address security vlan 1
# Display information about secure MAC addresses on port GigabitEthernet 1/0/1.
<Sysname> display port-security mac-address security interface gigabitethernet1/0/1
# Display information about secure MAC addresses on port GigabitEthernet 1/0/1in VLAN 1.
<Sysname> display port-security mac-address security interface gigabitethernet 1/0/1 vlan 1
Table 1-3 display port-security mac-address security command output description
MAC ADDR
Secure MAC address
VLAN ID
STATE
Type of the MAC address added. "Security" means it is a secure MAC address.
PORT INDEX
Port to which the secure MAC address belongs
AGING TIME(s)
Period of time before the secure MAC address ages out. "NOAGED" means do not age out the secure MAC address.
undo port-security authorization ignore
View
Ethernet interface view
Default Level
2: System level
None
Use the port-security authorization ignore command to configure a port to ignore the authorization information from the RADIUS server.
Use the undo port-security authorization ignore command to restore the default.
By default, a port uses the authorization information from the RADIUS server.
After a user passes RADIUS authentication, the RADIUS server performs authorization based on the authorization attributes configured for the user’s account. For example, it may assign a VLAN.
Related commands: display port-security.
# Configure port GigabitEthernet 1/0/1 to ignore the authorization information from the RADIUS server.
[Sysname-GigabitEthernet1/0/1] port-security authorization ignore
undo port-security enable
View
Default Level
2: System level
None
Use the port-security enable command to enable port security.
Use the undo port-security enable command to disable port security.
By default, port security is disabled.
Note that:
1)     Port security cannot be enabled when 802.1X or MAC authentication is enabled globally.
2)     Enabling port security resets the following configurations on a port to the defaults bracketed, making them dependent completely on the port security mode:
l   802.1X (disabled), port access control method (macbased), and port access control mode (auto)
l   MAC authentication (disabled)
3)     Disabling port security resets the following configurations on a port to the defaults bracketed:
l   Port security mode (noRestrictions)
4)     Port security cannot be disabled if there is any user present on a port.
Related commands: display port-security, dot1x, dot1x port-method, and dot1x port-control in 802.1X Commands of the Command Reference - Part 8 - Security; mac-authentication in MAC Authentication Commands of the Command Reference - Part 8 – Security.
# Enable port security.
[Sysname] port-security enable
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
undo port-security intrusion-mode
View
Default Level
2: System level
blockmac: Adds the source MAC addresses of illegal frames to the blocked MAC address list and discards frames with blocked source MAC addresses. This implements illegal traffic filtering on the port. A blocked MAC address is restored to normal after being blocked for three minutes, which is fixed and cannot be changed. To view the blocked MAC address list, use the display port-security mac-address block command.
disableport: Disables the port permanently upon detecting an illegal frame received on the port.
disableport-temporarily: Disables the port for a specified period of time whenever it receives an illegal frame. Use the port-security timer disableport command to set the period.
Use the port-security intrusion-mode command to configure the intrusion protection feature, so that the interface performs configured security policies in response to received illegal packets.
Use the undo port-security intrusion-mode command to restore the default.
By default, intrusion protection is disabled.
To restore the connection of the port, use the undo shutdown command.
Related commands: display port-security, display port-security mac-address block, port-security timer disableport.
# Configure port GigabitEthernet 1/0/1 to block the source MAC addresses of illegal frames after intrusion protection is triggered.
[Sysname-GigabitEthernet1/0/1] port-security intrusion-mode blockmac
In Layer 2 Ethernet interface view:
port-security mac-address security mac-address vlan vlan-id
In system view:
port-security mac-address security mac-address interface interface-type interface-number vlan vlan-id
undo port-security mac-address security [ [ mac-address [ interface interface-type interface-number ] ] vlan vlan-id ]
View
Layer 2 Ethernet Interface view, system view
Default Level
2: System level
mac-address: Secure MAC address, in the H-H-H format.
interface interface-type interface-number: Specifies a Layer 2 Ethernet port by its type and number.
vlan vlan-id: Specifies the VLAN to which the secure MAC address belongs. vlan-id represents the ID of the VLAN, in the range 1 to 4094.
Use the port-security mac-address security command to add a secure MAC address.
Use the undo port-security mac-address security command to remove specified secure MAC addresses.
By default, no secure MAC address is configured.
Note that:
l   The port must belong to the specified VLAN.
l   You can configure a secure MAC address only if port security is enabled (with the port-security enable command) and the specified port operates in autoLearn mode (with the port-security port-mode autolearn command).
l   The undo port-security mac-address security command can be used in system view only.
# Enable port security, set the port security mode of port GigabitEthernet 1/0/1 to autoLearn, and add a secure MAC address of 0001-0001-0002 (belonging to VLAN 10) for port GigabitEthernet 1/0/1 in system view.
[Sysname-GigabitEthernet1/0/1] port-security max-mac-count 100
[Sysname-GigabitEthernet1/0/1] port-security port-mode autolearn
[Sysname] port-security mac-address security 0001-0001-0002 interface gigabitethernet 1/0/1 vlan 10
# Enable port security, set the port security mode of port GigabitEthernet 1/0/1 to autoLearn, and add a secure MAC address of 0001-0002-0003 (belonging to VLAN 4) for port GigabitEthernet 1/0/1 in interface view.
[Sysname-GigabitEthernet1/0/1] port-security mac-address security 0001-0002-0003 vlan 4
port-security max-mac-count count-value
undo port-security max-mac-count
View
Default Level
2: System level
count-value: Maximum number of secure MAC addresses allowed on the port, ranging 1 to 1024.
Use the port-security max-mac-count command to set the maximum number of secure MAC addresses allowed to be added for the port in autoLearn mode.
Use the undo port-security max-mac-count command to restore the default setting.
By default, the maximum number of secure MAC addresses is not limited.
Note that:
l   You cannot change the maximum number of secure MAC addresses for a port that is working in the autoLearn mode.
l   The maximum number of secure MAC addresses allowed on a port does not include that of the static MAC addresses manually configured.
l   The maximum number of secure MAC addresses allowed on a port must not be less than the number of MAC addresses stored on the port.
# Set the maximum number of secure MAC addresses allowed on port GigabitEthernet 1/0/1 to 100.
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkonly }
undo port-security ntk-mode
View
Default Level
2: System level
ntk-withbroadcasts: Forwards only broadcast frames and unicast frames with authenticated destination MAC addresses.
ntk-withmulticasts: Forwards only broadcast frames, multicast frames, and unicast frames with authenticated destination MAC addresses.
ntkonly: Forwards only unicast frames with authenticated destination MAC addresses.
Use the port-security ntk-mode command to configure the NTK feature.
Use the undo port-security ntk-mode command to restore the default.
By default, NTK is disabled on a port and all frames are allowed to be sent.
The need to know (NTK) feature checks the destination MAC addresses in outbound frames to allow frames to be sent to only devices passing authentication, thus preventing illegal devices from intercepting network traffic.
# Set the NTK mode of port GigabitEthernet 1/0/1 to ntkonly, allowing the port to forward received packets to only devices passing authentication.
[Sysname-GigabitEthernet1/0/1] port-security ntk-mode ntkonly
port-security oui
port-security oui oui-value index index-value
undo port-security oui index index-value
View
Default Level
2: System level
oui-value: Organizationally unique identifier (OUI) string, a 48-bit MAC address in the H-H-H format. The system automatically uses only the 24 high-order bits as the OUI value.
index-value: OUI index, in the range 1 to 16.
Use the port-security oui command to configure an OUI value for user authentication. This value is used when the port security mode is userLoginWithOUI.
Use the undo port-security oui command to delete an OUI value with the specified OUI index.
By default, no OUI value is configured.
An OUI (Organizational Unique Identifier), the first 24 binary bits of a MAC address, is assigned by IEEE to uniquely identify a device vendor. Use this command when you need to configure a device to allow packets from certain wired devices to pass authentication or to allow packets from certain wireless devices to initiate authentication. For example, when a company allows only IP phones of vendor A in the Intranet, use this command to set the OUI of vendor A.
Note that an OUI value configured by using the port-security oui command takes effect only when the security mode is userLoginWithOUI.
# Configure an OUI value of 000d2a, setting the index to 4.
[Sysname] port-security oui 000d-2a10-0033 index 4
port-security port-mode { autolearn | mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | secure | userlogin | userlogin-secure | userlogin-secure-ext | userlogin-secure-or-mac | userlogin-secure-or-mac-ext | userlogin-withoui }
undo port-security port-mode
View
Interface view
Default Level
2: System level
See the following for details about the keywords of port security modes:
Keyword
Security mode
autolearn
autoLearn
In this mode, a port can learn MAC addresses. These dynamically learned MAC addresses are secure MAC addresses. You can also configure secure MAC addresses by using the port-security mac-address security command. A secure MAC address never ages out by default. In addition, you can configure MAC addresses manually by using the mac-address dynamic and mac-address static commands for a port in autoLearn mode.
The port permits only frames sourced from the MAC addresses that are in the MAC address table.
When the number of secure MAC addresses reaches the upper limit, the port turns to secure mode.
mac-authentication
In this mode, a port performs MAC authentication for users and services multiple users.
This mode is the combination of the macAddressWithRadius and userLoginSecure modes, with MAC authentication having a higher priority.
l  Upon receiving a non-802.1X frame, a port in this mode performs only MAC authentication.
l  Upon receiving an 802.1X frame, the port performs MAC authentication and then, if MAC authentication fails, 802.1X authentication.
This mode is similar to the macAddressElseUserLoginSecure mode, except that it supports multiple 802.1X and MAC authentication users on the port.
secure
secure
In this mode, MAC address learning is disabled on the port and you can configure MAC addresses by using the mac-address static and mac-address dynamic commands.
userlogin
userLogin
In this mode, a port performs 802.1X authentication and implements port-based access control.
If one 802.1X user passes authentication, all the other 802.1X users of the port can access the network without authentication.
userlogin-secure
userLoginSecure
In this mode, a port performs 802.1X authentication and implements MAC-based access control. It services only one user passing 802.1X authentication.
userLoginSecureExt
Similar to the userLoginSecure mode except that this mode supports multiple online 802.1X users.
This mode is the combination of the userLoginSecure and macAddressWithRadius modes, with 802.1X authentication having a higher priority.
For a user using a wired connection, the port performs MAC authentication upon receiving non-802.1X frames and performs 802.1X authentication upon receiving 802.1X frames.
This mode is similar to the macAddressOrUserLoginSecure mode, except that it supports multiple 802.1X and MAC authentication users on the port.
userlogin-withoui
userLoginWithOUI
Similar to the userLoginSecure mode. In addition, a port in this mode also permits frames from a user whose MAC address contains a specified OUI (organizationally unique identifier).
For wired users, the port performs 802.1X authentication upon receiving 802.1X frames, and performs OUI check upon receiving non-802.1X frames.
Use the port-security port-mode command to set the port security mode of a port.
Use the undo port-security port-mode command to restore the default.
By default, a port operates in noRestrictions mode, where port security does not take effect.
Note that:
l   Configuration of port security mode on a port is mutually exclusive with the configuration of 802.1X authentication, port access control method, port access control mode, and MAC authentication on the port.
l   With port security enabled, you can change the port security mode of a port only when the port is operating in noRestrictions mode, the default mode. To restore the default port security mode, use the undo port-security port-mode command.
l   Before configuring the port security mode to autoLearn, be sure to configure the maximum number of secure MAC addresses allowed on the port by using the port-security max-mac-count command.
l   You cannot change the port security mode of a port with users online.
# Enable port security and configure the port security mode of port GigabitEthernet 1/0/1 as secure.
[Sysname-GigabitEthernet1/0/1] port-security port-mode secure
# Change the port security mode of port GigabitEthernet 1/0/1 to userLogin.
[Sysname-GigabitEthernet1/0/1] undo port-security port-mode
[Sysname-GigabitEthernet1/0/1] port-security port-mode userlogin
port-security timer disableport time-value
undo port-security timer disableport
View
Default Level
2: System level
time-value: Silence timeout period during which the port remains disabled, in seconds. It ranges from 20 to 300.
Use the port-security timer disableport command to set the silence timeout period during which the port remains disabled.
Use the undo port-security timer disableport command to restore the default.
By default, the silence timeout period is 20 seconds.
If you configure the intrusion protection policy as disabling the port temporarily whenever it receives an illegal frame, you can use this command to set the silence period.
# Configure the intrusion protection policy as disabling the port temporarily whenever it receives an illegal frame and set the silence timeout period to 30 seconds.
[Sysname] port-security timer disableport 30
[Sysname-GigabitEthernet1/0/1] port-security intrusion-mode disableport-temporarily
port-security trap
port-security trap { addresslearned | dot1xlogfailure | dot1xlogoff | dot1xlogon | intrusion | ralmlogfailure | ralmlogoff | ralmlogon }
undo port-security trap { addresslearned | dot1xlogfailure | dot1xlogoff | dot1xlogon | intrusion | ralmlogfailure | ralmlogoff | ralmlogon }
View
Default Level
2: System level
addresslearned: Trapping for learning of new MAC addresses. When enabled, this function allows the device to send trap information when a port learns a new MAC address.
dot1xlogfailure: Trapping for 802.1X authentication failure.
dot1xlogon: Trapping for successful 802.1X authentication.
dot1xlogoff: Trapping for 802.1X user logoff events.
intrusion: Trapping for detection of illegal frames.
ralmlogfailure: Trapping for MAC authentication failure.
ralmlogoff: Trapping for MAC authentication user logoff events.
ralmlogon: Trapping for successful MAC authentication.
RALM (RADIUS Authenticated Login using MAC-address) means RADIUS authentication based on MAC address.
Use the port-security trap command to enable trapping for port security.
Use the undo port-security trap command to disable trapping for port security.
By default, trapping for port security is disabled.
With the trapping feature, a device can send traps upon detecting frames that result from, for example, intrusion, abnormal login/logout operations, allowing you to monitor user behaviors.
# Enable trapping for learning of new MAC addresses.
[Sysname] port-security trap addresslearned
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
