Part 8 - Security
12-SFTP Commands
Chapters Download  (92.74 KB)
12-SFTP Commands
1  SFTP Configuration Commands
SFTP Server Configuration Commands
sftp server enable
sftp server enable
undo sftp server enable
View
Default Level
2: System level
None
Use the sftp server enable command to enable SFTP server.
Use the undo sftp server enable command to disable SFTP server.
By default, SFTP server is disabled.
# Enable SFTP server.
[Sysname] sftp server enable
sftp server idle-timeout
undo sftp server idle-timeout
View
Default Level
2: System level
time-out-value: Timeout period in minutes. It ranges from 1 to 35,791.
Use the sftp server idle-timeout command to set the idle timeout period for SFTP user connections.
Use the undo sftp server idle-timeout command to restore the default.
By default, the idle timeout period is 10 minutes.
# Set the idle timeout period for SFTP user connections to 500 minutes.
[Sysname] sftp server idle-timeout 500
SFTP Client Configuration Commands
bye
bye
View
SFTP client view
Default Level
3: Manage level
None
Use the bye command to terminate the connection with an SFTP server and return to user view.
This command functions as the exit and quit commands.
# Terminate the connection with the SFTP server.
sftp-client> bye
Bye
Connection closed.
<Sysname>
cd
cd [ remote-path ]
View
SFTP client view
Default Level
3: Manage level
remote-path: Name of a directory on the server.
Use the cd command to change the working directory on an SFTP server. With the argument not specified, the command displays the current working directory.
l   You can use the cd .. command to return to the parent directory.
l   You can use the cd / command to return to the root directory of the SFTP server.
# Change the working directory to new1.
sftp-client> cd new1
Current Directory is:
/new1
cdup
cdup
View
SFTP client view
Default Level
3: Manage level
None
Use the cdup command to return to the parent directory.
# From the current working directory /new1, return to the parent directory.
sftp-client> cdup
delete
delete remote-file&<1-10>
View
SFTP client view
Default Level
3: Manage level
remote-file&<1-10>: Names of the files to be deleted from the SFTP server. &<1-10> means that you can provide up to 10 filenames, which are separated by space.
Use the delete command to delete one or more files from a server.
This command functions as the remove command.
# Delete file temp.c from the server.
sftp-client> delete temp.c
The following files will be deleted:
/temp.c
Are you sure to delete it? [Y/N]:y
This operation may take a long time. Please wait...
File successfully Removed
dir
View
SFTP client view
Default Level
3: Manage level
-a: Displays the names of the files and sub-directories under the specified directory.
-l: Displays the detailed information of the files and sub-directories under the specified directory in the form of a list.
remote-path: Name of the directory to be queried.
Use the dir command to display information about the files and sub-directories under a specified directory.
With the –a and –l keyword not specified, the command displays detailed information of the files and sub-directories under the specified directory in the form of a list.
With the remote-path not specified, the command displays information about the files and sub-directories of the current working directory.
This command functions as the ls command.
# Display detailed information about the files and sub-directories under the current working directory in the form of a list.
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:28 pub1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:24 new1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:18 new2
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:30 pub2
display sftp client source
View
Default Level
1: Monitor level
None
Use the display sftp client source command to display the source IP address or source interface currently set for the SFTP client.
If neither source IP address nor source interface is specified for the SFTP client, the system displays such a message: “Neither source IP address nor source interface was specified for the SFTP client.”
Related commands: sftp client source.
# Display the source IP address of the SFTP client.
<Sysname> display sftp client source
The source IP address you specified is 192.168.0.1
exit
exit
View
SFTP client view
Default Level
3: Manage level
None
Use the exit command to terminate the connection with an SFTP server and return to user view.
This command functions as the bye and quit commands.
sftp-client> exit
Bye
Connection closed.
<Sysname>
get
View
SFTP client view
Default Level
3: Manage level
remote-file: Name of a file on the SFTP server.
local-file: Name for the local file.
Use the get command to download a file from an SFTP server and save it locally.
If you do not specify the local-file argument, the file will be saved locally with the same name as that on the SFTP server.
# Download file temp1.c and save it as temp.c locally.
sftp-client> get temp1.c temp.c
Remote  file:/temp1.c --->  Local file: temp.c
Downloading file successfully ended
help
help [ all | command-name ]
View
SFTP client view
Default Level
3: Manage level
all: Displays a list of all commands.
command-name: Name of a command.
Use the help command to display a list of all commands or the help information of an SFTP client command.
With neither the argument nor the keyword specified, the command displays a list of all commands.
# Display the help information of the get command.
sftp-client> help get
get remote-path [local-path]  Download file.Default local-path is the same
                              as remote-path
ls
View
SFTP client view
Default Level
3: Manage level
Use the ls command to display information about the files and sub-directories under a specified directory.
This command functions as the dir command.
sftp-client> ls
mkdir
mkdir remote-path
View
SFTP client view
Default Level
3: Manage level
remote-path: Name for the directory to be created on the SFTP server.
Use the mkdir command to create a directory on an SFTP server.
# Create a directory named test on the SFTP server.
sftp-client> mkdir test
New directory created
put
View
SFTP client view
Default Level
3: Manage level
local-file: Name of a local file.
remote-file: Name for the file on an SFTP server.
Use the put command to upload a local file to an SFTP server.
If you do not specify the remote-file argument, the file will be saved remotely with the same name as the local one.
# Upload local file temp.c to the SFTP server and save it as temp1.c.
sftp-client> put temp.c temp1.c
Local file:temp.c --->  Remote file: /temp1.c
Uploading file successfully ended
pwd
pwd
View
SFTP client view
Default Level
3: Manage level
None
Use the pwd command to display the current working directory on an SFTP server.
# Display the current working directory on the SFTP server.
sftp-client> pwd
View
SFTP client view
Default Level
3: Manage level
None
Use the quit command to terminate the connection with an SFTP server and return to user view.
This command functions as the bye and exit commands.
sftp-client> quit
Bye
Connection closed.
<Sysname>
remove
remove remote-file&<1-10>
View
SFTP client view
Default Level
3: Manage level
Use the remove command to delete one or more files from an SFTP server.
This command functions as the delete command.
sftp-client> remove temp.c
/temp.c
This operation may take a long time.Please wait...
rename
rename oldname newname
View
SFTP client view
Default Level
3: Manage level
oldname: Original name of the file or directory.
newname: New name for the file or directory.
Use the rename command to change the name of a specified file or directory on an SFTP server.
# Change the name of a file on the SFTP server from temp1.c to temp2.c.
sftp-client> rename temp1.c temp2.c
File successfully renamed
rmdir
rmdir remote-path&<1-10>
View
SFTP client view
Default Level
3: Manage level
remote-path&<1-10>: Name of the directory on the SFTP server. &<1-10> means that you can provide up to 10 directory names that are separated by space.
Use the rmdir command to delete one or more directories from an SFTP server.
# On the SFTP server, delete directory temp1 in the current directory.
sftp-client> rmdir temp1
Directory successfully removed
sftp
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { 3des | aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Default Level
3: Manage level
server: IPv4 address or host name of the server, a case-insensitive string of 1 to 20 characters.
port-number: Port number of the server, in the range 0 to 65535. The default is 22.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the server belongs. vpn-instance-name is a case-sensitive string of 1 to 31 characters.
identity-key: Specifies the algorithm for publickey authentication, either dsa or rsa. The default is dsa.
prefer-ctos-cipher: Preferred encryption algorithm from client to server, defaulted to aes128.
l   3des: Encryption algorithm 3des-cbc.
l   aes128: Encryption algorithm aes128-cbc.
l   des: Encryption algorithm des-cbc.
prefer-ctos-hmac: Preferred HMAC algorithm from client to server, defaulted to sha1-96.
l   md5: HMAC algorithm hmac-md5.
l   md5-96: HMAC algorithm hmac-md5-96.
l   sha1: HMAC algorithm hmac-sha1.
l   sha1-96: HMAC algorithm hmac-sha1-96.
prefer-kex: Preferred key exchange algorithm, defaulted to dh-group-exchange.
l   dh-group-exchange: Key exchange algorithm diffie-hellman-group-exchange-sha1.
l   dh-group1: Key exchange algorithm diffie-hellman-group1-sha1.
l   dh-group14: Key exchange algorithm diffie-hellman-group14-sha1.
prefer-stoc-cipher: Preferred encryption algorithm from server to client, defaulted to aes128.
prefer-stoc-hmac: Preferred HMAC algorithm from server to client, defaulted to sha1-96.
Use the sftp command to establish a connection to an IPv4 SFTP server and enter SFTP client view.
Note that when the client’s authentication method is publickey, the client needs to get the local private key for validation. As the publickey authentication includes RSA and DSA algorithms, you must specify an algorithm (by using the identity-key keyword) in order to get the correct data for the local private key. By default, the encryption algorithm is DSA.
# Connect to SFTP server 10.1.1.2, using the following algorithms:
l   Preferred key exchange algorithm: dh-group1.
l   Preferred encryption algorithm from server to client: aes128.
l   Preferred HMAC algorithm from client to server: md5.
l   Preferred HMAC algorithm from server to client: sha1-96.
<Sysname> sftp 10.1.1.2 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
Input Username:
sftp client ipv6 source
sftp client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
undo sftp client ipv6 source
View
Default Level
3: Manage level
ipv6 ipv6-address: Specifies a source IPv6 address.
interface interface-type interface-number: Specifies a source interface by its type and number.
Use the sftp client ipv6 source command to specify the source IPv6 address or source interface for an SFTP client.
Use the undo sftp client ipv6 source command to remove the configuration.
By default, the client uses the interface address specified by the route of the device to access the SFTP server.
Related commands: display sftp client source.
# Specify the source IPv6 address of the SFTP client as 2:2::2:2.
[Sysname] sftp client ipv6 source ipv6 2:2::2:2
sftp client source
sftp client source { ip ip-address | interface interface-type interface-number }
undo sftp client source
View
Default Level
3: Manage level
ip ip-address: Specifies a source IPv4 address.
Use the sftp client source command to specify the source IPv4 address or interface of an SFTP client.
Use the undo sftp source-interface command to remove the configuration.
By default, a client uses the IP address of the interface specified by the route to access the SFTP server.
# Specify the source IP address of the SFTP client as 192.168.0.1.
[Sysname] sftp client source ip 192.168.0.1
sftp ipv6
sftp ipv6 server [ port-number ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Default Level
3: Manage level
server: IPv6 address or host name of the server, a case-insensitive string of 1 to 46 characters.
Use the sftp ipv6 command to establish a connection to an IPv6 SFTP server and enter SFTP client view.
# Connect to server 2:5::8:9, using the following algorithms:
<Sysname> sftp ipv6 2:5::8:9 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
Input Username:
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
