06-HABP Commands
Chapters Download (44.36 KB)
display habp
View
Default Level
1: Monitor level
None
Use the display habp command to display HABP configuration information.
# Display HABP configuration information.
<Sysname> display habp
Global HABP information:
HABP Mode: Server
Sending HABP request packets every 20 seconds
Bypass VLAN: 2
Table 1-1 display habp command output description
HABP Mode |
HABP mode of the current device, server or client |
Sending HABP request packets every 20 seconds |
Interval at which the switch sends HABP request packets |
Bypass VLAN |
ID of the VLAN in which HABP packets are transmitted |
display habp table
View
Default Level
1: Monitor level
None
Use the display habp table command to display HABP MAC address table entries.
# Display HABP MAC address table entries.
<Sysname> display habp table
MAC Holdtime Receive Port
001f-3c00-0030 53 GigabitEthernet1/0/1
Table 1-2 display habp table command output description
MAC |
MAC address |
Holdtime |
Lifetime of an entry in seconds. The initial value is three times of the interval to send HABP request packets. An entry will age out if it is not updated during the period. |
Receive Port |
Port that learned the MAC address |
display habp traffic
View
Default Level
1: Monitor level
None
Use the display habp traffic command to display HABP packet statistics.
# Display HABP packet statistics.
<Sysname> display habp traffic
HABP counters :
Packets output: 0, Input: 0
ID error: 0, Type error: 0, Version error: 0
Sent failed: 0
Table 1-3 display habp traffic command output description
Packets output |
Number of HABP packets sent |
Input |
Number of HABP packets received |
ID error |
Number of packets with an incorrect ID |
Type error |
Number of packets with an incorrect type |
Version error |
Number of packets with an incorrect version number |
Sent failed |
Number of packets failed to be sent |
habp enable
undo habp enable
View
Default Level
2: System level
None
Use the habp enable command to enable HABP.
Use the undo habp enable command to disable HABP.
By default, HABP is enabled.
# Enable HABP.
[Sysname] habp enable
habp server vlan vlan-id
undo habp server
View
Default Level
2: System level
vlan-id: ID of the VLAN in which HABP packets are to be transmitted, in the range 1 to 4094.
Use the habp server vlan command to configure HABP to work in server mode and specify the VLAN in which HABP packets are to be transmitted.
Use the undo habp server command to configure HABP to work in the default mode.
By default, HABP works in client mode.
Note that in a cluster, if a member device with 802.1X authentication or MAC authentication enabled is attached with some other member devices of the cluster, you also need to configure HABP server on this device. Otherwise, the cluster management device will not be able to manage the devices attached to this member device. For information about the cluster function, see Cluster Management Configuration in the Configuration Guide - Part 1 - Login.
# Configure HABP to work in server mode and specify the VLAN for HABP packets as VLAN 2.
[Sysname] habp server vlan 2
habp timer interval
undo habp timer
View
Default Level
2: System level
interval: Interval (in seconds) at which the switch sends HABP request packets, in the range 5 to 600.
Use the habp timer command to set the interval at which the switch sends HABP request packets.
Use the undo habp timer command to restore the default.
The default interval is 20 seconds.
This command is required only on the HABP server.
# Set the interval at which the switch sends HABP request packets to 50 seconds.
[Sysname] habp timer 50
