Part 8 - Security
16-ARP Attack Protection Commands
Chapters Download  (78.64 KB)
ARP Defense Against IP Packet Attack Configuration Commands
arp resolving-route enable
undo arp resolving-route enable
View
Default Level
2: System level
None
Use the arp resolving-route enable command to enable ARP black hole routing.
Use the undo arp resolving-route enable command to disable the function.
By default, the function is enabled.
# Enable ARP black hole routing.
[Sysname] arp resolving-route enable
arp source-suppression enable
undo arp source-suppression enable
View
Default Level
2: System level
None
Use the arp source-suppression enable command to enable the ARP source suppression function.
Use the undo arp source-suppression enable command to disable the function.
By default, the ARP source suppression function is disabled.
Related commands: display arp source-suppression.
# Enable the ARP source suppression function.
[Sysname] arp source-suppression enable
arp source-suppression limit
undo arp source-suppression limit
View
Default Level
2: System level
limit-value: Specifies the maximum number of packets with the same source IP address but unresolvable destination IP addresses that the device can receive in five seconds. It ranges from 2 to 1024.
Use the arp source-suppression limit command to set the maximum number of packets with the same source IP address but unresolvable destination IP addresses that the device can receive in five seconds.
Use the undo arp source-suppression limit command to restore the default value, which is 10.
With this feature configured, whenever the number of packets with unresolvable destination IP addresses from a host within five seconds exceeds the specified threshold, the device suppress the sending host from triggering any ARP requests within the following five seconds.
# Set the maximum number of packets with the same source address but unresolvable destination IP addresses that the device can receive in five seconds to 100.
[Sysname] arp source-suppression limit 100
View
Default Level
2: System level
None
Use the display arp source-suppression command to display information about the current ARP source suppression configuration.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
 ARP source suppression is enabled
 Current suppression limit: 100
 Current cache length: 16
Table 1-1 display arp source-suppression command output description
The ARP source suppression function is enabled
Maximum number of packets with the same source IP address but unresolvable IP addresses that the device can receive in five seconds
Size of cache used to record source suppression information
ARP Packet Rate Limit Configuration Commands
arp rate-limit
arp rate-limit { disable | rate pps drop }
undo arp rate-limit
View
Layer-2 Ethernet interface view
Default Level
2: System level
disable: Disables ARP packet rate limit.
rate pps: ARP packet rate in pps, in the range 50 to 500..
drop: Discards the exceeded packets.
Use the arp rate-limit command to configure or disable ARP packet rate limit on an interface.
Use the undo arp rate-limit command to restore the default.
By default, ARP packet rate limit is enabled, and the ARP packet rate limit is 100 pps.
# Specify the ARP packet rate on GigabitEthernet1/0/1 as 50 pps, and exceeded packets will be discarded.
[Sysname-GigabitEthernet1/0/1] arp rate-limit rate 50 drop
Source MAC Address-Based ARP Attack Detection Configuration Commands
arp anti-attack source-mac
arp anti-attack source-mac { filter | monitor }
undo arp anti-attack source-mac [ filter | monitor ]
View
Default Level
2: System level
filter: Specifies the filter mode.
monitor: Specifies the monitor mode.
Use the arp anti-attack source-mac command to enable source MAC address-based ARP attack detection and specify the detection mode.
Use the undo arp anti-attack source-mac command to restore the default.
By default, source MAC address-based ARP attack detection is disabled.
After you enable this feature, the device checks the source MAC address of ARP packets received from the VLAN. If the number of ARP packets received from a source MAC address within five seconds exceeds the specified threshold:
l   In filter detection mode, the device displays an alarm and filters out the ARP packets from the MAC address.
l   In monitor detection mode, the device only displays an alarm.
Note that: If no detection mode is specified in the undo arp anti-attack source-mac command, both detection modes are disabled.
# Enable filter-mode source MAC address-based ARP attack detection
[Sysname] arp anti-attack source-mac filter
arp anti-attack source-mac aging-time
arp anti-attack source-mac aging-time time
undo arp anti-attack source-mac aging-time
View
Default Level
2: System level
time: Aging timer for protected MAC addresses, in the range of 60 to 6000 seconds.
Use the arp anti-attack source-mac aging-time command to configure the aging timer for protected MAC addresses.
Use the undo arp anti-attack source-mac aging-time command to restore the default.
By default, the aging timer for protected MAC addresses is 300 seconds (five minutes).
# Configure the aging timer for protected MAC addresses as 60 seconds.
[Sysname] arp anti-attack source-mac aging-time 60
arp anti-attack source-mac exclude-mac
arp anti-attack source-mac exclude-mac mac-address&<1-10>
undo arp anti-attack source-mac exclude-mac [ mac-address&<1-10> ]
View
Default Level
2: System level
mac-address&<1-10>: MAC address list. The mac-address argument indicates a protected MAC address in the format H-H-H. &<1-10> indicates that you can configure up to 10 protected MAC addresses
Use the arp anti-attack source-mac exclude-mac command to configure protected MAC addresses which will be excluded from ARP packet detection.
Use the undo arp anti-attack source-mac exclude-mac command to remove the configured protected MAC addresses.
By default, no protected MAC address is configured.
Note that: If no MAC address is specified in the undo arp anti-attack source-mac exclude-mac command, all the configured protected MAC addresses are removed.
# Configure a protected MAC address.
[Sysname] arp anti-attack source-mac exclude-mac 2-2-2
arp anti-attack source-mac threshold
arp anti-attack source-mac threshold threshold-value
undo arp anti-attack source-mac threshold
View
Default Level
2: System level
threshold-value: Threshold for source MAC address-based ARP attack detection, in the range of 10 to 100.
Use the arp anti-attack source-mac threshold command to configure the threshold for source MAC address-based ARP attack detection. If the number of ARP packets sent from a MAC address within five seconds exceeds this threshold, the device considers this an attack.
Use the undo arp anti-attack source-mac threshold command to restore the default.
 By default, the threshold for source MAC address-based ARP attack detection is 50.
# Configure the threshold for source MAC address-based ARP attack detection as 30.
[Sysname] arp anti-attack source-mac threshold 30
display arp anti-attack source-mac
display arp anti-attack source-mac { slot slot-number | interface interface-type interface-number }
View
Default Level
1: Monitor level
interface interface-type interface-number: Displays attacking MAC addresses detected on the interface.
slot slot-number: Displays attacking MAC addresses detected on the specified device. The slot-number argument is the member number of the device in the IRF virtual device, which you can display with the display irf command. The value range for the slot-number argument depends on the number of members and numbering conditions in the current IRF virtual device. If no IRF virtual device exists, the slot-number argument is the current device number.
Use the display arp anti-attack source-mac command to display attacking MAC addresses detected by source MAC address-based-ARP attack detection.
On a device, if no interface is specified, the display arp anti-attack source-mac command displays attacking MAC addresses detected on all the interfaces.
<Sysname> display arp anti-attack source-mac slot 1
Source-MAC          VLAN ID           Interface             Aging-time
23f3-1122-3344      4094              GE1/0/1                 10
23f3-1122-3355      4094              GE1/0/2                 30
23f3-1122-33ff      4094              GE1/0/3                 25
23f3-1122-33ad      4094              GE1/0/4                 30
23f3-1122-33ce      4094              GE1/0/5                 2
ARP Packet Source MAC Address Consistency Check Configuration Commands
arp anti-attack valid-ack enable
arp anti-attack valid-check enable
undo arp anti-attack valid-check enable
View
Default Level
2: System level
None
Use the arp anti-attack valid-check enable command to enable ARP packet source MAC address consistency check on the gateway. After you execute this command, the gateway device can filter out ARP packets with the source MAC address in the Ethernet header different from the sender MAC address in the ARP message.
Use the undo arp anti-attack valid-check enable command to restore the default.
By default, ARP packet source MAC address consistency check is disabled.
# Enable ARP packet source MAC address consistency check.
[Sysname] arp anti-attack valid-check enable
ARP Active Acknowledgement Configuration Commands
arp anti-attack active-ack enable
undo arp anti-attack active-ack enable
View
Default Level
2: System level
None
Use the arp anti-attack active-ack enable command to enable the ARP active acknowledgement function.
Use the undo arp anti-attack active-ack enable command to restore the default.
By default, the ARP active acknowledgement function is disabled.
Typically, this feature is configured on gateway devices to identify invalid ARP packets.
# Enable the ARP active acknowledgement function.
[Sysname] arp anti-attack active-ack enable
ARP Detection Configuration Commands
arp detection enable
undo arp detection enable
View
VLAN view
Default Level
2: System level
None
Use the arp detection enable command to enable ARP detection for the VLAN.
Use the undo arp detection enable command to restore the default.
By default, ARP detection is disabled for a VLAN.
# Enable ARP detection for VLAN 1.
[Sysname] vlan 1
[Sysname-Vlan1] arp detection enable
arp detection trust
arp detection trust
undo arp detection trust
View
Layer 2 Ethernet port view
Default Level
2: System level
None
Use the arp detection trust command to configure the port as an ARP trusted port.
Use the undo arp detection trust command to restore the default.
By default, the port is an ARP untrusted port.
# Configure GigabitEthernet1/0/1 as an ARP trusted port.
[Sysname] interface GigabitEthernet1/0/1
[Sysname-GigabitEthernet1/0/1] arp detection trust
arp detection validate
undo arp detection validate [ dst-mac | ip | src-mac ] *
View
Default Level
2: System level
dst-mac: Checks the target MAC address of ARP responses. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
ip: Checks the source and destination IP addresses of ARP packets. The all-zero, all-one or multicast IP addresses are considered invalid and the corresponding packets are discarded. With this keyword specified, the source and destination IP addresses of ARP replies, and the source IP address of ARP requests will be checked.
src-mac: Checks whether the source MAC address of an ARP packet is identical to that in its Ethernet header. If they are identical, the packet is considered valid; otherwise, the packet is discarded.
Use the arp detection validate command to configure ARP detection based on specified objects. You can specify one or more objects in one command line.
Use the undo arp detection validate command to remove detected objects. If no keyword is specified, all the detected objects are removed.
By default, ARP detection based on specified objects is disabled.
# Enable the checking of the MAC addresses and IP addresses of ARP packets.
[Sysname] arp detection validate dst-mac src-mac ip
display arp detection
View
Default Level
1: Monitor level
None
Use the display arp detection command to display the VLAN(s) enabled with ARP detection.
Related commands: arp detection enable.
# Display the VLANs enabled with ARP detection.
<Sysname> display arp detection
ARP detection is enabled in the following VLANs:
1, 2, 4-5
Table 1-2 display arp detection command output description
VLANs that are enabled with ARP detection
display arp detection statistics
display arp detection statistics [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
interface interface-type interface-number: Displays the ARP detection statistics of a specified interface.
Use the display arp detection statistics command to display statistics about ARP detection. This command only displays numbers of discarded packets. If no interface is specified, the statistics of all the interfaces will be displayed.
# Display the ARP detection statistics of all the interfaces.
<Sysname> display arp detection statistics
State: U-Untrusted  T-Trusted
ARP packets dropped by ARP inspect checking:
Interface(State)           IP            Src-MAC       Dst-MAC       Inspect
BAGG1(U)                   0             0             0             0
GE1/0/1(T)                 0             0             0             0
GE1/0/2(U)                 0             0             0             0
GE1/0/3(U)                 0             0             0             0
GE1/0/4(U)                 0             0             0             0
GE1/0/5(U)                 0             0             0             0
GE1/0/6(U)                 0             0             0             0
GE1/0/7(U)                 0             0             0             0
GE1/0/8(U)                 0             0             0             0
GE1/0/9(U)                 0             0             0             0
GE1/0/10(U)                0             0             0             0
GE1/0/11(U)                0             0             0             0
Table 1-3 display arp detection statistics command output description
Interface(State)
State T or U identifies a trusted or untrusted port.
IP
Number of ARP packets discarded due to invalid source and destination IP addresses
Src-MAC
Number of ARP packets discarded due to invalid source MAC address
Dst-MAC
Number of ARP packets discarded due to invalid destination MAC address
Inspect
Number of ARP packets that failed to pass ARP detection (based on static IP source guard binding entries/DHCP snooping entries/802.1X security entries/OUI MAC addresses)
reset arp detection statistics
reset arp detection statistics [ interface interface-type interface-number ]
View
Default Level
2: System level
interface interface-type interface-number: Clears the ARP detection statistics of a specified interface.
Use the reset arp detection statistics command to clear ARP detection statistics of a specified interface. If no interface is specified, the statistics of all the interfaces will be cleared.
# Clear the ARP detection statistics of all the interfaces.
<Sysname> reset arp detection statistics
ARP Automatic Scanning and Fixed ARP Configuration Commands
arp fixup
arp fixup
View
Default Level
2: System level
None
Use the arp fixup command to change dynamic ARP entries into static ARP entries.
Note that:
l   The static ARP entries changed from dynamic ARP entries have the same attributes as the static ARP entries manually configured. Use the arp fixup command to change the recently created dynamic ARP entries into static.
l   The number of static ARP entries changed from dynamic ARP entries is restricted by the number of static ARP entries that the device supports. As a result, the device may fail to change all dynamic ARP entries into static.
l   Suppose that the number of dynamic ARP entries is D and that of the existing static ARP entries is S. When the dynamic ARP entries are changed into static, new dynamic ARP entries may be created (suppose the number is M) and some of the dynamic ARP entries may be aged out (suppose the number is N). After the process is complete, the number of static ARP entries is D + S + M – N.
l   To delete a specific static ARP entry changed from a dynamic one, use the undo arp ip-address [ vpn-instance-name ] command. To delete all such static ARP entries, use the reset arp all or reset arp static command.
# Enable Fixed ARP.
[Sysname] arp fixup
arp scan
arp scan [ start-ip-address to end-ip-address ]
View
VLAN interface view
Default Level
2: System level
start-ip-address: Start IP address of the scanning range.
end-ip-address: End IP address of the scanning range. The end IP address must be higher than or equal to the start IP address.
Use the arp scan command to enable ARP automatic scanning.
Note that:
l   If start IP and end IP addresses are specified, the device scans the specific address range for neighbors and learns their ARP entries. If not, the device only scans the network where the primary IP address of the interface resides for neighbors.
l   The start IP address and end IP address must be on the same network as the primary IP address or manually configured secondary IP addresses of the interface.
l   IP addresses already exist in ARP entries are not scanned.
l   ARP automatic scanning may take some time. To stop an ongoing scan, press Ctrl + C. Dynamic ARP entries are created based on ARP replies received before the scan is terminated.
# Configure the device to scan the network where the primary IP address of VLAN-interface 2 resides for neighbors.
[Sysname-Vlan-interface2] arp scan
# Configure the device to scan a specific address range for neighbors.
[Sysname-Vlan-interface2] arp scan 1.1.1.1 to 1.1.1.20
ARP Gateway Protection Configuration Commands
arp filter source
arp filter source ip-address
undo arp filter source ip-address
View
Default Level
2: System level
ip-address: IP address of a protected gateway.
Use the arp filter source command to enable ARP gateway protection for a specified gateway.
Use the undo arp filter source command to disable ARP gateway protection for a specified gateway.
By default, ARP gateway protection is disabled.
Note:
l   You can enable ARP gateway protection for up to eight gateways on a port.
l   Commands arp filter source and arp filter binding cannot be both configured on a port.
# Enable ARP gateway protection for the gateway with IP address 1.1.1.1.
[Sysname-gigabitethernet1/0/1] arp filter source 1.1.1.1
ARP Filtering Configuration Commands
arp filter binding
undo arp filter binding ip-address
View
Default Level
2: System level
ip-address: Permitted sender IP address.
mac-address: Permitted sender MAC address.
Use the arp filter binding command to configure an ARP filtering entry. If the sender IP and MAC addresses of an ARP packet match an ARP filtering entry, the ARP packet is permitted. If not, it is discarded.
Use the undo arp filter binding command to remove an ARP filtering entry.
By default, no ARP filtering entry is configured.
Note:
l   You can configure up to eight ARP filtering entries on a port.
# Configure an ARP filtering entry with permitted sender IP address 1.1.1.1 and MAC address 2-2-2.
[Sysname-gigabitethernet1/0/1] arp filter binding 1.1.1.1 2-2-2
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
