Manage the nodes in a container cluster
A container cluster contains a minimum of three controller nodes (including one master node) and a minimum of one worker node.
All these types of nodes can be physical servers or cloud hosts. You must install the system ISO image on them.
By default, the system platform components are deployed in container cluster default. You can add or remove nodes to increase or decrease the cluster capacity. You can also incorporate external container clusters to deploy additional services or applications.
Node management contains the following tasks:
Add nodes
View detailed information about a node
Place a worker node in maintenance mode
Manage the labels of a worker node
Delete a worker node from a container cluster
