Perform this task to obtain information about a controller or worker node, its resource usage, pods, and events.
Open the container cluster page, as described in "View detailed information about a container cluster."
Click the Nodes tab.
Click a node IP link.
Parameter |
Basic Info |
State |
Operating state of the node. |
Node Type |
Controller node or worker node. |
Started At |
Date and time when the node started up. |
Labels |
Labels assigned to the nodes for categorization purposes. |
Resource Usage |
Total CPU and memory capacity and their usage. |
Network Traffic Monitor |
Network Flow (Tx) |
The rate (in Mbps) at which the node transmits messages. |
Network Flow (Rx) |
The rate (in Mbps) at which the node receives messages. |
Disk Read/Write Rate |
Disk Write Rate |
Disk write rate on the node. |
Disk Read Rate |
Disk read rate on the node. |
Disk Partition |
Size of each disk partition on the node and its used capacity. |
Pods |
Displays information about each pod on the node. To open the remote configuration shell or log of a pod, click Remote or Log, respectively. To move a pod on a heavily loaded node to a lightly loaded node, click Drain for that node. The pod will stay on the node if the cluster does not have a suitable node. |
Events |
Displays alarm events on the node, including their severity, event description, and type. To delete an event, click Delete in the Actions column for that event. |
