Perform this task to add worker nodes or controller nodes to a cluster.
Install the system ISO image on the nodes to be added.
To add worker nodes or controller nodes to a container cluster:
Open the container cluster page, as described in "View detailed information about a container cluster."
Click the Nodes tab.
Click Add Nodes.
Add one or multiple nodes.
Parameter |
Worker Node IP |
IP address of the node on which you deploy application or services. To add a worker node, click Add Node.
Node Labels |
Use a node label to describe a node attribute for the ease of node categorization or selection. You can assign one or multiple labels to a node. To assign an existing label to the node, select that label. To assign a new label to the node, enter the label name, and then click Add.
The label key prefix and name combinations cannot be the following default keys:
Controller Nodes |
A controller node deploys components that manage and control the operation of the cluster. To add a controller node, click Add Node. You can repeat this operation to add multiple controller nodes.
