Manage the labels of a worker node
Assign labels to a worker node or delete its labels as its purposes change.
  1. Open the container cluster page, as described in "View detailed information about a container cluster."
  1. Click the Nodes tab.
  1. Click Label Management for a worker node.
  1. To add a label, enter a key-value pair, and then click Add. To delete a label, click the delete icon  next to the label.
  1. Click OK.
