Manage container clusters
You deploy applications or services on the worker nodes in a container cluster.
By default, the system platform is deployed in container cluster default. You can add or remove worker nodes in that cluster to increase or decrease its cluster capacity. You can also create a new container cluster to deploy additional services or applications.
The following information describes only cluster-level management tasks. For information about managing worker nodes, see "Manage the nodes in a container cluster."
Basic container cluster management contains the following tasks:
Create a container cluster
Incorporate a container cluster
View detailed information about a container cluster
Edit a container cluster
Remove a container cluster
