Remove a container cluster
Remove a user-defined container cluster from the system if you do not need to manage it from the system. The removal does not affect services running on the cluster.
You cannot delete the Default cluster.
The applications on a container cluster will continue to operate after you remove that cluster from the system. However, you will be unable to manage or operate them.
  1. On the top navigation bar, click Resources.
  1. From the left navigation pane, select Containers.
  1. Click Delete in the Actions column for a cluster.
  1. In the dialog box that opens, click OK.
