Edit a container cluster
Perform this task to edit the name and description of a user-defined container cluster. The Default cluster is not editable.
  1. On the top navigation bar, click Resources.
  1. From the left navigation pane, select Containers.
  1. Click Edit for a cluster.
  1. In the dialog box that opens, edit the cluster name or description, and then click OK.
