After deploying UIS-Sec gateway component VMs, log in to the UIS-Sec portal of UIS Manager Standard Edition to configure the management node. Figure-1 shows the management node configuration workflow, and Table-1 describes the configuration steps.
Figure-1 Management node configuration workflow
Table-1 Management node configuration workflow
Procedure |
Log in to the UIS-Sec portal of UIS Manager Standard Edition to incorporate the UIS standard edition. |
Configure network and network enhancement parameters. |
Configure network egresses and VLAN ID ranges. |
Create and manage compute AZs, storage AZs, and network quotas for private clouds. |
