Configure an overall plan
You can use the UIS-Sec basic services after configuring an overall plan and configure quotas in the plan. You can also edit and view the existing overall plan.
Create an overall plan
  1. Log in to the UIS-Sec portal of UIS Manager Standard Edition.
  1. On the top navigation bar, click O&M.
  1. From the left navigation pane, select Resource Quotas > Overall Plan.
  1. Click Create.
  1. Configure the overall plan parameters as described in "Parameters."
Figure-1 Configuring overall plan parameters
  1. Click Create.
