Configure the network plan
Create a network egress named bizNet on the network planning page. You can also edit and delete existing network egresses on the network planning page.
  1. Log in to the UIS-Sec portal of UIS Manager Standard Edition.
  1. On the top navigation bar, select O&M.
  1. From the left navigation pane, select Infrastructure > Network Planning.
  1. Click the Network Automation tab.
  1. Click Create.
Figure-1 Creating a network egress
  1. Select network egress bizNet and configure the egress parameters as described in "Parameters."
  1. Click Create.
