Network configuration workflow
Figure-1 shows the network configuration workflow, and Table-1 describes the configuration steps.
Figure-1 Network configuration workflow
Table-1 Network configuration workflow
Create a network
Required.
Configure the name, network egress, and compute AZ for the network, and then create subnets in the network to specify the available network segments.
Create a subnet
Required.
A subnet provides private IP addresses to cloud hosts in the private cloud. Both IPv4 and IPv6 network addresses are supported.
Create a router and attach it to a firewall
Optional.
Attach subnets and firewalls to routers to enable and protect the communication between cloud hosts.
This task requires the network and security services provided by UIS-Sec.
Attach subnets to a router
Optional.
Subnets attached to the same router can communicate with each other.
Configure a border gateway for a router
Optional.
Configure a border gateway for a router attached with a firewall to enable the cloud hosts to access the Internet.
