Subnets in the same network cannot have overlapping CIDRs. Subnets in different networks can overlap. |
On UIS Cloud, click Cloud Services on the top navigation bar.
On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Networks.
Click the name of a network.
Click the Subnets tab.
Click Create Subnet.
Configure subnet parameters as needed.
Table-1 Configuring subnet parameters
Parameter |
Subnet Address |
Enter or select a network address. Only networks and subnets assigned to the organization are available. |
Gateway Address |
Enter a gateway address for the subnet. If you do not specify a gateway address, the system automatically assigns one, which is the first IP address in the network. |
Available Addresses |
Specify the available IP address ranges in the subnet. |
DNS |
Enter the IP address of the DNS server. |
Additional Routes |
Configure static routes for cloud hosts in the subnet. |
